Order Item Parameter Binding Editor Properties Tab
Use the Properties tab to define the entities to use for the parameter bindings.
See "Order Item Parameter Binding Editor" for information about fields that appear on multiple Order Item Parameter Binding editor tabs.
Field | Use |
Order Item Specification |
Click Select to select an order item from the list of all of the order items in the workspace. The order items in this list are the order items defined in the same project as the order item parameter binding and the order items in any project on which this project depends. See "Managing Project Dependencies" for more information about project dependencies. |
Conceptual Model Entity |
Click Select to select a conceptual model entity that contains the parameters to which order line items will be mapped. |
Related Topics
