About Orchestration Fulfillment Pattern Order Component XQuery Expressions
The Orchestration Fulfillment Pattern editor provides the following areas to define XQuery expressions related to order decomposition:
About Orchestration Fulfillment Pattern Order Component Condition XQuery Expressions
About Associating Order Items Using Property Correlations XQuery Expressions
The XQuery expressions discussed in this chapter also apply to the Orchestration Dependency editor.
