Orchestration Dependency Editor Details Tab
Use the Details tab to specify the order components that have dependencies.
Dependency Source
Use the Dependency Source area to define the source order components upon which the Dependency Target order components will have dependencies.
Field | Use |
Base Component Functions Search |
Use these fields to limit the number of order components that appear in the Dependency Source area. The Dependency Source area displays all order component specifications defined in the workspace. Use Base Component to limit the display to a single root-level order component and its dependencies. Use Functions to limit the scope to executable order components (order components associated with a process). Enter a value in the Search field to search for a specific order component. |
Dependency Source |
Specify the order components that contain the order items on which the order items defined in the Dependency Target field depend.
Dependency Target
Field | Use |
Dependency Target |
Specify the order components that cannot run until the order items included in order components specified in the Dependency Source field have met their specified conditions.
Selected Order Component
Select a checked order component in the Order Source area and define an XQuery condition that must evaluate to true for the dependency to exist. See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls.
