Orchestration Dependency Editor Wait for Condition Tab
Use the Wait For Condition tab to specify the conditions that must be satisfied before an order component with dependencies on another order component can execute.
Wait For Condition
Use the Wait for Condition area to specify the conditions that must be satisfied before the transition can occur.
| Field | Use |
Task State Completed |
Select this option to specify that the dependency target order component cannot run until the subprocess task associated with the dependency source order component reaches the completed state. |
Data Change Notification |
Select this option to indicate that the dependency target order component cannot run until the value you select for the data change notification property of the order item changes. For example, you can configure a data change notification on a status field in the order template so that if the status changes to Failed, OSM generates a fallout notification to an administrator. When you select Data Change Notification, you also define the following fields:
Wait Delay
Use the Wait Delay area to configure a delay in addition to the information defined in the Wait For Condition area. You configure the wait delay against either the Task State or the Data Change Notification wait condition options. After the conditions specified in the Wait for Condition area are met, OSM delays the execution of the corresponding target order component using the information defined here.
The wait delay setting defers the start of the waiting order component until after the dependencies have been resolved. For example, you can use this to defer the resolution of the condition until two days after a task completes.
If order items have Wait Delay making it impossible to complete the order component on the requested delivery date, Use Calculated Start Date is ignored. See "Order Component Specification Editor Details Tab" for more information.
| Field | Use |
Wait Delay area |
In the Wait Delay area, do one of the following:
Duration fields |
Use these fields to set a static amount of time to delay. Only available if the Duration option is selected. |
Duration Expression |
Create an XQuery expression in the Duration Expression field to run against a specific order item property. See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls. If the Duration option is selected, write the XQuery expression to return a string in the xs:duration format (for example,"PT15M"). See "About Wait Delay Duration XQuery Expressions" for more information. If the Date Time Expression option is selected, write the XQuery expression to return a string in the xs:dateTime format (for example, "2012-09-15T15:30:00-4:00"). See "About Wait Delay Date and Time XQuery Expressions" for more information. |
