Orchestration Dependency Editor Order Item Dependencies Tab
Use the Order Item Dependencies tab to define the property order items must share to create a dependency.
By default, an order item in the To Component field has a dependency when the same order item exists in the From Component field. However, you can use order item dependencies if you want to create a dependency on two different order items. For example, order items in a shipping order component may not be identical to order items in an install order component, but a dependency between those order items exists.
Field | Use |
Order Item |
The order item dependency default value is Order Item. To create order item dependencies between two different order items based on a different attribute, select a different option in this tab. |
Fulfillment Pattern |
Select to create a dependency on two different order items that share the same orchestration fulfillment pattern. |
Property Correlation |
Select to create a dependency on two different order items that share the same property correlation. If you select this option, enter an XQuery expression to select the order item property that order items in the dependency target order component must share with order items in the dependency source order component. See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls. See "About Order Item Dependency Property Correlation XQuery Expressions" for more information about this XQuery field. |
