Orchestration Dependency Editor
Use the Orchestration Dependency editor to configure dependencies that exist between order items within a set of order components that are not based on fulfillment patterns.
When modeling orchestration dependencies, refer to the following topics:
The following fields are common to multiple tabs in the Orchestration Dependency editor:
Field | Use |
Description |
Edit the display name of the orchestration dependency. |
Namespace |
Select an existing namespace or enter a unique namespace in which to include the orchestration dependency. Design Studio uses the last saved namespace as the default value. |
