Data Provider Editor
Use the Data Provider editor to configure the system settings and interface parameters necessary to retrieve information from external systems. You use data providers in conjunction with Data Instance behaviors to augment order information by retrieving information from external systems.
When configuring system settings and interface parameters in the Data Provider editor, see the following topics:
