Process Editor Flow Properties Events Tab
Use the Properties Events Details tab create event notifications for a single task transition in a specific process that only triggers if a specific rule evaluates to true. When defining event notifications for task transitions in the Process editor Properties Events tab, you can name the task and transitional events, specify the rule that triggers the event, set the priority level, enable or disable the event, specify whether to send the notification by email, and create automation plug-ins to perform the work of the notification. See "Properties Events Detail Tab" for more information about the fields on the Events Detail tab. See "Creating Task Status-Based Event Notifications" for information about creating event notifications at the Process editor level.
