Properties Events Automation Tab
Use the Properties Events Automation tab to configure an automation plug-in that performs the work or sends data to an external system when the notification is triggered.
Field Use
Add
Click to open the Add Automation dialog box opens.
Name
Enter a name for the automation entry.
Action
Select the automation plug-in type from the available list.
Click OK to add the automation entry to the Automation table.
Properties
Select any entry in the table and click to define the automation properties.
See "Configuring Automation Plug-In Properties" for information about defining automation properties on the Properties tab.
