Properties Events Notify Roles Tab
Use the Properties Events Notify Roles tab to select the roles to be notified when the event occurs.
Select a predefined notification from the list in the left column to activate a list of available roles. See "Working with Roles" for information about defining roles. Using the directional arrow buttons, move the roles (those groups to whom you want the notification sent) into the Selected Column.
If the notification message will be consumed by an automation plug-in, ensure that you include the role whose credentials are used when running the automation plug-in. See "Working with Automated Tasks" for more information.
