SER MGT Ports
The SER MGT RJ-45 serial management port, located on the server back panel, provides the default management connection to the Oracle ILOM SP. See E6-2L Back Panel Features.
For DTE to DTE communications, you can use a RJ-45 to DB-9 crossover adapter with a standard RJ-45 cable to achieve the required null modem configuration.
Figure 6-5 SER MGT Ports
SER MGT Ports
