USB Port
One USB 3.0 port is located at the server back panel. For Oracle Communications Server E6-2L see the location of the USB port at E6-2L Back Panel Features.
The USB port supports hot-plug insertion and removal. You can connect and disconnect a USB cable or a peripheral device while the server is running without affecting server operations. The USB port supplies 5V output at 2A.
