A Hardware Baselines
Baseline Tables
The following tables list the configurable hardware components for each release. A bold X in a table cell indicates the component listed on the left is valid for the release indicated at the top of the column. To obtain configuration information about hardware and release compatibility for each release use:
- EAGLE Release 46.5 through 46.9 in EAGLE Release 46.6 Through 46.9
- EAGLE Cable Assemblies and Adapters:
- E1 Cable Assemblies in Table A-2
- T1 MIM LIM Cable Assemblies Table A-3
- E5-ATM Adapters Table A-4
- ENET Adapters Table A-5
- Fast Copy Adapters Table A-7
- Terminal/Printer Cables and Adapters Table A-8
- Modem Cables and Adapters Table A-9
- Application Server Table A-10
- Application Server Serial Adapters Table A-11
Exceptions, additions, and clarifications to the following tables are mentioned in table footnotes.
Table A-1 Hardware Baseline EAGLE Release 46.6 Through 46.9
| NAME | PART NUMBER | REV | 46.6 | 46.7 | 46.8 | 46.9 |
Air Management Card |
870-1824-01 |
A |
X Foot 1 |
X Foot 1 |
X Foot 1 |
X Foot 1 |
870-1824-02 |
A |
X Foot 1 |
X Foot 1 |
X Foot 1 |
X Foot 1 |
CTRL SHELF |
870-0775-03 Foot 2 |
E |
X Foot 3 |
X Foot 3 |
X Foot 3 |
X Foot 3 |
CTRL SHELF |
870-2321-02 |
A |
X Foot 4 |
X Foot 4 |
X Foot 4 |
X Foot 4 |
CTRL SHELF |
870-2321-04 |
A |
X Foot 4, |
X Foot 4 |
X Foot 4 |
X Foot 4 |
CTRL SHELF |
870-2321-08 Foot 4 |
A |
X Foot 4 |
X Foot 4 |
X Foot 4 |
X Foot 4 |
CTRL SHELF |
870-2377-01 |
A |
X Foot 5 |
X Foot 5 |
X Foot 5 |
X Foot 5 |
CTRL SHELF |
870-2377-02 Foot 5 |
A |
X Foot 5 |
X Foot 5 |
X Foot 5 |
X Foot 5 |
CTRL SHELF |
7335031 |
N/A |
X Foot 5 |
X Foot 5 |
X Foot 5 |
X Foot 5 |
E5-APP-B |
870-3096-xx |
A |
X |
X |
X |
X |
E5-ATM-B |
870-2972-01 |
D |
X Foot 6 |
X Foot 6 |
X Foot 6 |
X Foot 6 |
E5-E1T1-B |
870-2970-01 |
D |
X Foot 6 |
X Foot 6 |
X Foot 6 |
X Foot 6 |
E5-ENET-B |
870-2971-01 |
E |
X Foot 6 |
X Foot 6 |
X Foot 6 |
X Foot 6 |
E5-MASP |
870-2903-01 |
A |
X Foot 7 |
X Foot 7 |
X Foot 7 |
X Foot 7 |
E5-MASP |
870-2903-02 |
A |
X Foot 7 |
X Foot 7 |
X Foot 7 |
X Foot 7 |
E5-MASP |
7346924 |
N/A |
X Foot 7 |
X Foot 7 |
X Foot 7 |
X Foot 7 |
E5-MCPM-B |
870-3089-01 |
A |
X Foot 6 |
X Foot 6 |
X Foot 6 |
X Foot 6 |
E5-MDAL |
870-2900-01 |
C |
X Foot 8 |
X Foot 8 |
X Foot 8 |
X Foot 8 |
E5-MDAL |
7346923 |
N/A |
X Foot 8 |
X Foot 8 |
X Foot 8 |
X Foot 8 |
E5-SM8G-B (Double-slot) |
870-2990-01 |
A |
X Foot 6 |
X Foot 6 |
X Foot 6 |
X Foot 6 |
EXTN SHELF |
870-0776-02 |
C |
X Foot 9 |
X Foot 9 |
X Foot 9 |
X Foot 9 |
EXTN SHELF |
870-0776-03 |
D |
X Foot 9 |
X Foot 9 |
X Foot 9 |
X Foot 9 |
EXTN SHELF |
870-0776-06 |
A |
X |
X |
X |
X |
EXTN SHELF |
870-0776-07 |
A |
X |
X |
X |
X |
EXTN SHELF |
870-0776-08 |
A |
X |
X |
X |
EXTN SHELF |
870-0776-11 |
A |
X |
X |
X |
X |
EXTN SHELF |
870-2378-01 |
A |
X Foot 10 |
X Foot 10 |
X Foot 10 |
X Foot 10 |
EXTN SHELF |
870-2378-02 |
A |
X Foot 10 |
X Foot 10 |
X Foot 10 |
X Foot 10 |
EXTN SHELF |
7335033 |
N/A |
X Foot 10 |
X Foot 10 |
X Foot 10 |
X Foot 10 |
FAP |
870-1606-01 |
A |
X |
X |
X |
X |
FAP |
870-1606-02 |
A |
X Foot 11 |
X Foot 11 |
X Foot 11 |
X Foot 11 |
FAP |
870-1606-02 |
C |
X Foot 12 |
X Foot 12 |
X Foot 12 |
X Foot 12 |
FAP |
870-1606-05 |
A |
X Foot 12 |
X Foot 12 |
X Foot 12 |
X Foot 12 |
FAP |
870-1823-01 |
B |
X |
X |
X |
X |
FAP |
870-2320-01 |
A |
X Foot 10 |
X Foot 10 |
X Foot 10 |
X Foot 10 |
FAP |
870-2320-01 |
J |
X Foot 13 |
X Foot 13 |
X Foot 13 |
X Foot 13 |
FAP |
870-2320-03 |
A |
X Foot 10 |
X Foot 10 |
X Foot 10 |
X Foot 10 |
FAP-CF/EF |
870-0243-08 |
C |
X |
X |
X |
X |
FAP- MISC |
870-0243-09 |
C |
X |
X |
X |
X |
FAP |
870-2804-01 |
B |
X |
X |
X |
X |
HIGH-SPEED FIBER CHANNEL CABLE |
830-1344-xx |
X |
X |
X |
X |
830-1141-xx |
830-0221-xx |
HIPR2 |
870-2872-01 |
A |
X Foot 14 |
X Foot 14 |
X Foot 14 |
X Foot 14 |
HIPR2 |
870-2872-02 |
A |
X |
X |
X |
X |
HIPR2 |
870-2872-03 |
A |
X |
X |
X |
X |
HIPR2 |
7333484 |
X |
X |
X |
X |
X |
FAN ASSY |
890-1038-01 |
D |
X |
X |
X |
X |
FAN ASSY |
890-0001-01 |
A |
X Foot 2 |
X Foot 2 |
X Foot 2 |
X Foot 2 |
FAN ASSY |
890-0001-02 |
A |
X Foot 2 |
X Foot 2 |
X Foot 2 |
X Foot 2 |
FAN ASSY |
890-0001-04 |
A |
X Foot 2 |
X Foot 2 |
X Foot 2 |
X Foot 2 |
FAN ASSY |
7315823 |
N/A |
X Foot 2 |
X Foot 2 |
X Foot 2 |
X Foot 2 |
KIT,E1 |
890-1037-01 |
A |
X |
X |
X |
X |
KIT,E1 |
890-1037-06 |
A |
X |
X |
X |
X |
KIT, HLDOVRCLKASSY |
890-1013-01 |
A |
X |
X |
X |
X |
MPS DC Frame |
890-1843-01 |
C |
X |
X |
X |
X |
MPSDC Frame |
890-1843-02 |
A |
X |
X |
X |
X |
| SLIC |
7094646 |
N/A |
X Foot 6 |
X Foot 6 |
X Foot 6 |
X Foot 6 |
SLIC |
7352578 |
N/A |
X Foot 6 |
X Foot 6 |
X Foot 6 |
X Foot 6 |
Telco 24 port switch for ExAP-SM interconnectivity |
870-2904-01 |
N/A |
X |
X |
X |
X |
Footnote 1 Required in all empty slots in shelves when using fan tray 890-0001-xx.
Footnote 2 Control shelf P/N 870-0775-03 with backplane P/N 850-0330-04 can be used with minor modifications and addition of adapter cable P/N 830-1185-01.
Footnote 3 NEBS will support Source Timing with adapter 830-1183-01.
Footnote 4 Control shelf P/N 870-2321-08 with backplane P/N 850-0330-06/07 and 7333412 can be used together in standard frames.
Footnote 5 Control shelf P/N 870-2377-02 with backplane P/N 850-0330-06/07 and 7333412 can be used in heavy-duty frames.
Footnote 6 Requires fan tray assembly.
Footnote 7 Requires E5-MDAL.
Footnote 8 Requires E5-MASP.
Footnote 9 If any E5 type cards are used in the shelf, HIPR2 870-2872-02, -03, or 7333484 are required. The HIPR2 870-2872-01 is not supported.
Footnote 10 Required for heavy-duty frames. Rev. J required for HCMIM shelves.
Footnote 11 Required for standard frames. Rev. C required for HCMIM shelves.
Footnote 12 60 Amp FAP required for standard frames that contain shelves with HCMIM modules.
Footnote 13 60 Amp FAP required for Heavy-duty frames that contain shelves with HCMIM modules.
Footnote 14 Not supported on Extension shelf 870-0776-02 and -03.
Table A-2 E1 Cable Assemblies
| P/N | Description | |
non-ROHS |
ROHS |
830-0622-xx |
830-1233-xx |
E1 Dual TX/RX, XX ft., NTW |
830-0623-xx |
830-1256-xx |
E1 Patch, D26M to D26M, 120 OHM, XX ft., NTW |
Table A-3 T1 MIM LIM Cable Assemblies
non-ROHS |
ROHS |
830-0949-xx |
830-1198-01 |
T1 LIm to MPL Cable Adapter |
830-0948-xx |
830-1197-xx |
T1 MIM Lim XX ft. Unterminated |
830-0857-xx |
830-1185-01 |
Adapter A Clk in HMUX |
830-0846-xx |
830-1183-01 |
DB-25M to DB-25F and DB-15F Y Clk / HS Timing |
Table A-4 E5-ATM Adapter
| P/N | Description |
830-1342-05 |
Dual DB-26M to DB-26F / RJ11 |
Table A-5 ENET Adapters
| P/N | Description |
830-1102-02 |
DB-26M to Dual RJ45 10/100/1000 |
830-1103-02 |
DB-26M to DB-26F 10/100 |
830-1104-02 |
DB-26M to RJ45 10/100 |
830-1104-03 |
DB-26M to RJ45 10/100/1000 |
Table A-6 SLIC Adapter
| P/N | Description |
830-1102-03 |
Table A-7 Fast Copy Adapters
| P/N | Description |
830-1343-01 |
CABLE ASSY_ADAPTER_PRE-MOLD_UPPER_EAGLE FAST COPY_DUAL DB26_RJ45 (E5_ENET) |
830-1343-02 |
CABLE ASSY_ADAPTER_PRE-MOLD_LOWER_EAGLE FAST COPY_DUAL DB26_RJ45 (E5-ENET) |
Table A-8 Terminal/Printer Cables and Adapters
| Cable P/N | Necessary Adapter |
830-0394-xx |
830-0531-02 |
830-0535-xx |
None |
830-1154-xx (ROHS) |
None |
Table A-9 Modem Cables and Adapters
830-0394-xx |
830-0531-03 |
830-0535-xx |
830-0531-04 |
830-1153-04 (ROHS) |
830-0680-01 |
None |
830-1165-01 (ROHS) |
None |
Table A-10 Application Server Site Specific Cables
| non-ROHS | ROHS | |
830-0963-xx |
830-1201-xx |
Optional DB9F/DB15M Serial w/Flow Control |
830-0964-xx |
830-1202-xx |
DB9/DB25 M/M Site Specific Null Modem Serial Cable |
830-0978-xx |
830-1204-xx |
DB26-RJ45 Site Specific Straight Through Cable - Non Shielded |
830-0979-xx |
830-1205-xx |
DB26-RJ45 Site Specific Crossover Cable - Non Shielded |
Table A-11 Application Server Serial Adapters
| P/N | Description |
830-0915-01 |
RJ45-DB15M Adapter_NTW |
830-0915-02 |
RJ45-DB15M Adapter_MRV |
830-0915-03 |
RJ45-DB15M Adapter_EAGLE/Cyclades |
