D Part Numbers
Overview
This chapter lists the part numbers of Oracle equipment, components, cables, and miscellaneous parts described in this manual.
Each table provides the item name, part number, and related notes. Items are listed by their name (as described in this manual) in alphabetical order. Shaded part numbers indicate that the item is obsolete or no longer shipped. Unless the item is indicated as obsolete, the item is still supported in the field.
Oracle reserves the right to ship compatible part numbers or revisions for new installations and replacements. Always check the latest Hardware Baseline for your release. The latest hardware baseline can be found in the Feature Notice of your release.RoHS 5/6 - As of July 1, 2006, all products that comprise new installations shipped to European Union member countries will comply with the EU Directive 2002/95/EC "RoHS" (Restriction of Hazardous Substances). The exemption for lead-based solder described in the Annex will be exercised. RoHS 5/6 compliant components will have unique part numbers and are identified as the International part number in this manual.
International part numbers will eventually replace North American part numbers to make all part numbers RoHS compliant. The items of either part number are of equivalent function or quality otherwise.WEEE - All products shipped to European Union member countries comply with the EU Directive 2002/96/EC, Waste Electronic and Electrical Equipment. All components that are WEEE compliant will be appropriately marked. For more information regarding Oracle's WEEE program, contact your sales representative.
Cables, Adapters
Table D-1 EAGLE Cables, Connectors, and Power Cords
Name | Part Numbers | Note | |
North America | International | ||
Adapter, 15-Pin to 26-Pin |
830-0425-01 |
Adapter cables |
830-0846-01 |
830-1183-01 |
backplanes -03 and -04 for source timing and HS clock cable 830-0873-xx |
Alarm cable |
830-0543-01 |
Holdover Clock |
Alarm cable |
830-0638-xx |
830-1163-xx |
see Filtered Rack Alarm cable |
AlarmNETRA Server Cable |
830-0900-xx |
ATM Cable |
830-0987-xx |
SCSI/DB44 |
ATME1/T1 cable |
830-0959-xx |
EMS; DB-44 to RJ45 4 Port |
B Clock Cable |
830-0404-xx |
replaced by 830-0398-xx (NA) or 830-1150-xx (I) both are for HMUX |
B Clock Cable |
830-0398-xx |
830-1150-xx |
A and B Frame Clock cable |
see B Clock Cable |
BITS clock cable |
830-0226-xx |
830-1146-xx |
Backplanes -03 and -04 |
BITS clock cable |
830-0873-xx |
Backplane -06 |
BNC pen end cable |
830-0625-xx |
830-1161-xx |
BNC to BNC cable assembly |
830-0624-xx |
830-1160-xx |
Breaker-to-Terminal Strip Power Cable |
830-0866-xx |
830-1236-xx |
CD-ROM Cable |
830-0421-xx |
Frame Ground cable |
830-0715-xx |
830-1171-xx |
ESP |
Composite clock cable |
See BITS clock cable |
Converter |
804-0176-01 |
Crossover (CAT-5) Cable |
830-0723-xx |
830-1173-xx |
Crossover Patch Panel Cable |
830-0789-xx |
830-1178-xx |
DCM |
DB-26 to RJ-45 |
830-1102-02 |
830-1102-02 |
for new installations, with shielded Cat 5E cable; E5-ENET |
DB-26 to DB-26 |
830-1103-02 |
830-1103-02 |
for current installations that use DCM cable, 830-0978-xx. Does not support Gigabit Ethernet; E5-ENET |
DCM, 100-BASETX Interface to unterminated -xx |
830-0711-xx |
DCM_100 BASETX Interface_DB26 to Non-shielded RJ45 |
830-0978-xx |
DCM 100BASE TX Interface_DB26 to RJ45 Plus to Minus |
830-0788-xx |
830-1177-xx |
Drive Power Cable |
830-0224-xx |
DS1 Cable |
830-0849-xx |
830-1184-xx |
E1 cable |
830-0622-xx |
830-1233-xx |
E1 patch cable |
830-0605-02 |
830-1116-02 |
E1-T1MIM 22 AWG |
830-0932-01 |
830-1106-xx |
E1/T1MIMLIM Cable |
830-0948-01 |
830-1197-xx |
4 Port 24 AWG |
E1/T1MIMLIM to MPL Adapter |
830-0949-01 |
830-1197-01 |
E5-ENET Fast Copy Adapter - Lower |
830-1343-01 |
E5-ENET Fast Copy Adapter - Upper |
830-1343-02 |
E5-MASP Ethernet Adapter |
830-1333-02 |
830-1333-02 |
Connects to J-17 and J19 on Ctrl shelf backplane 06/07 for E5-OAM Integrated Meas |
Ethernet cable* |
830-0788-xx |
830-1177-xx |
DCM, DSM and EDCM |
External alarm cable |
830-0435-xx |
830-1151-xx |
Fan cable |
830-0690-01 |
AC power |
Fan power/alarm cable |
830-0609-01 |
830-1157-01 |
incl. with fan assembly |
Fifty Position Cable Hard Drive I/O |
830-0656-01 |
Filter Rack Alarm Cable |
830-0638-xx |
830-1163-xx |
Force Transition Card |
850-0496-01 |
830-0715-xx |
830-1171-xx |
ESP |
Ground Breaker Panel-to-Frame cable |
830-0830-01 |
830-1181-01 |
ESP |
Ground Hub-to-Frame cable |
830-0822-xx |
ESP |
Hazard Ground Cable |
830-0257-xx |
High Speed (BITS) Clock Cable |
830-0873-xx |
830-1189-xx |
High Speed Source Timing Adapter |
830-0846-01 |
830-1183-01 |
HMUX Adapter Cable |
830-0857-01 |
830-1185-01 |
690-0108-07 |
690-0108-R07 |
IMT Cable |
830-1344-xx |
830-1344-xx |
Interface Cable |
830-0366-xx |
830-1149-xx |
Local Maintenance Center Cable |
830-0231-xx |
830-1144-xx |
Loop Back Cable Adapter |
830-0763-01 |
830-1176-xx |
MMI Port Cable |
830-0708-xx |
830-1169-xx |
Modem/Terminal Cable |
830-0709-xx |
830-1170-xx |
Multi-port LIM Diagnostic Cable |
803-0029-0 |
Multi-port LIM DS0 cable |
830-0772-xx |
26 AWG, inactive |
830-0892-xx |
830-1194-xx |
24 AWG, inactive |
Multi-Port Power Cable |
830-0814-xx |
830-1282-xx |
Network Cable |
830-0710-xx |
830-1257-xx |
Null Modem Cable |
830-0759-xx |
Null-Modem for Terminal Cable |
830-0859-xx |
830-1186-xx |
Output panel frame ground cable |
690-0009 |
Pin Protector Assembly |
830-0880-01 |
use with clock cable replacement (66 min for 6 shelves) |
Power Cable |
830-0315-xx |
830-1147-xx |
Power Cable, –48V |
830-0651-xx |
Power Cable, DC, BP to Hub |
830-0868-xx |
830-1235-xx |
Power Cable, DC, Netra 1400 |
830-0814-xx |
830-1282-xx |
Power Cable, MPS |
830-0965-xx |
Power Ring |
830-0908-xx |
AXi |
Rack Alarm Cable |
RAID Power Cable |
830-0872-xx |
DC |
Remote Maintenance Center Cable |
830-0233-xx |
830-1146-xx |
RJ45/RJ45 Cable (CAT-5) (Yellow) |
830-0888-xx |
RJ45/RJ45 Cable (CAT-5) (Blue) |
830-0889-xx |
830-1192-xx |
RJ45 to 9 Pin Adapter |
830-0917-01 |
Row Alarm Cable |
830-0232-xx |
830-1145-xx |
Router Power Cable |
830-0869-xx |
830-1188-xx |
DC |
RS232 Cable |
830-0527-xx |
830-1152-xx |
ATM Cable |
830-0987-xx |
SCSI/DB44 |
Serial I/O Transition Card |
850-0514-01 |
Serial Interface Converter Cable |
830-0531-01 |
inactive |
Serial Interface/Modem Adapter |
830-0531-03 |
830-1153-03 |
use with 830-0394-xx |
830-0531-04 |
830-1153-04 |
use with 830-0535-xx |
Serial DB44 to DB9 (X4) cable |
830-0972-01 |
830-1231-01 |
36-inch T1x00 AS |
Serial Interface, Terminal, Printer Adapter |
830-0531-02 |
830-1153-02 |
Straight Through Cable (CAT-5) |
830-0724-xx |
RJ-45 CAT-5E |
Straight Through Cable (Patch Panel) |
see DCM 100BASE TX Interface_DB26 to RJ45 Plus to Minus |
Switch-to-Frame Ground Cable |
830-0884-01 |
Terminal/Converter Cable |
830-0528-01 |
Terminal/Printer Cable |
830-0535-xx |
830-1154-xx |
Terminal/Server Serial Cable |
830-1201-xx |
DB9F/DB15M Serial w/Flow Control |
Terminal/Server Serial Port Adapter |
830-0915-01 |
RJ45-DB15M Adapter_NTW |
830-0915-02 |
RJ45-DB15M Adapter_MRV |
830-0915-03 |
RJ45-DB15M Adapter_EAGLE/Cyclades |
Tone and Announcement Server Alarm Cable |
830-0901-xx |
T1LIM-to-MPL Cable Adapter |
830-0895-01 |
T1MIM cable |
830-0894-xx |
Terminal cable adapter |
see Terminal/Printer cable |
* See Customer Supplied Ethernet Cable Requirements for customer-supplied Ethernet cable requirements.
Components
Table D-2 EAGLE Components
Acronym | Name | Part Numbers | Note | |
North America | International | |||
Air Management Card |
870-1824-01 |
870-1824-02 |
single slot, needed for empty slots when using Fan Tray 890-0001-02 |
Breaker Panel Alarm Card |
804-1489-01 |
804-1489-R01 |
Clock Interface Card (Holdover Clock) |
804-0165-01 |
DSM |
Database Service Module |
870-2371-08 |
870-2371-13 |
1GB |
E5-APP-B |
EAGLE Application B Card |
870-3096-XX |
See EAGLE Application B Card Hardware and Installation Guide | |
E5-ATM-B Interface Module |
870-2972-01 |
870-2972-01 |
E5-ENET-B Interface Module |
870-2971-01 |
870-2971-01 |
E5 Maintenance Administration Subsystem Processor Card |
7346924 870-2903-01 |
E5-MCPM-B Measurements Collection and Polling Module |
870-3089-01 |
870-3089-01 |
E5 Maintenance Disk and Alarm Card |
7346923 870-2900-01 |
E5-SM8G-B DSM Module |
870-2990-01 |
870-2990-01 |
Enhanced Database Communications Module |
870-2197-01 |
double-slot Pre-IP7 SG 4.0 |
HIPR2 |
High-Speed IMT Packet Router 2 Module |
7333484 870-2872-01 |
870-2872-01 |
Replaces IPMX, HMUX, HIPR |
IPMX |
Interprocessor Message Transport Power and Multiplexer |
870-1171-01 |
replaced by HMUX |
MCA |
Matrix Controller Automatic (Holdover Clock) |
000-0028-xx |
MCAP |
Maintenance Administration Subsystem (MAS) Communications Applications Processor |
870-1013-xx 870-1307-xx |
Replaced by GPSM-II as of 30.0 |
MIS |
Maintenance Interface System Card (Holdover Clock) |
804-0175-xx |
MPS |
Multi-purpose Server |
890-1287-xx 890-1374-xx |
OEM Open System |
SLIC |
Service and Link Interface Card |
7094646 |
Runs multiple applications |
Timing Output Composite Automatic (Holdover Clock) |
804-0166-xx |
Frames, Backplanes, FAPs, and Fans
Table D-3 EAGLE Frames, Backplanes, FAPs, and Fans
BP |
Breaker Panel |
804-1423-01 |
804-1423-R01 |
BP |
Breaker Panel |
870-1814-01 |
Control Shelf Backplane -02 |
850-0330-02 |
inactive |
Control Shelf Backplane -03 |
850-0330-03 |
inactive |
Control Shelf Backplane -04 |
850-0330-04 |
Control Shelf Backplane -05 |
850-0330-05 |
not active |
Control Shelf Backplane -06 |
850-0330-06 |
850-0330-07 |
shelves 6 and 7 no longer supported |
Control Shelf Backplane |
7333412 |
ROHS number |
E1 Backplane |
850-0459-01 |
850-0459-02 |
Extension Shelf Backplane |
850-0356-01 |
inactive |
850-0356-02 |
inactive |
850-0356-03 |
inactive |
850-0356-04 |
850-0356-06 |
7333417 |
ROHS number |
Fan Assembly |
7315823 |
ROHS number |
Fan Assembly |
890-0001-02 |
890-0001-04 |
All systems with HCMIMs EAGLE 33.0 |
Fan Assembly |
890-1038-01 |
890-1038-03 890-1038-04 |
Standard frame Heavy Duty frame |
Filter, fan tray |
551-0032-01 |
Fan filter |
551-0022-01 |
FAP |
Fuse and Alarm Panel |
860-0434-01 |
860-0434-03 860-0434-04 |
Heavy Duty Frame |
FAP |
870-1606-02 Rev C |
Standard Frame 60 Amp feeds |
FAP |
870-1606-02 Rev B |
Standard 40 Amp feeds |
FAP |
870-2320-028 Rev J |
870-2320-04 |
Heavy Duty Frame 60 Amp feeds |
FAP |
870-2320-01 Rev A - I |
870-2320-03 |
Heavy Duty Frame 40 Amp feeds |
FAP |
870-0243-08 Rev C |
Control/ Extension Frame |
FAP |
870-0243-09 Rev C |
Misc Frame |
FAP Jumper Board |
870-1641-01 |
FAP Jumper Board |
870-1641-02 |
Heavy Duty Frame |
860-0434-01 |
FAP |
870-2804-01 |
870-2804-01 |
FAP Shorting Board |
870-2805-01 |
870-2805-01 |
FAP Jumper Board |
870-2806-01 |
870-2806-01 |
Labels
Table D-4 EAGLE Labels
Label, Control frame |
658-0486-01 |
Label, Extension frame 00 |
658-0486-02 |
Label, Extension frame 01 |
658-0486-03 |
Label, Extension frame 02 |
658-0486-04 |
Label, Extension frame 03 |
658-0486-05 |
Label, Extension frame 04 |
658-0486-06 |
Label, Miscellaneous frame 00 |
658-0374-01 |
Label, Miscellaneous frame 01 |
658-0374-02 |
Label, Heavy Duty Frame |
658-0374-01 |
Label, CF-00, Shelf 1 |
658-0490-01 |
Label, CF-00, Shelf 2 |
658-0490-02 |
Label, CF-00, Shelf 3 |
658-0490-03 |
Label, EF-00, Shelf 1 |
658-0490-04 |
Label, EF-00, Shelf 2 |
658-0490-05 |
Label, EF-00, Shelf 3 |
658-0490-06 |
Label, EF-01, Shelf 1 |
658-0490-07 |
Label, EF-01, Shelf 2 |
658-0490-08 |
Label, EF-01, Shelf 3 |
658-0490-09 |
Label, EF-02, Shelf 1 |
658-0490-10 |
Label, EF-02, Shelf 2 |
658-0490-11 |
Label, EF-02, Shelf 3 |
658-0490-12 |
Label, EF-03, Shelf 1 |
658-0490-13 |
Label, EF-03, Shelf 2 |
658-0490-14 |
Label, EF-03, Shelf 3 |
658-0490-15 |
Label, EF-04, Shelf 1 |
658-0490-16 |
Label, Field Tool Identification |
658-0941-01 |
Label, Field Tool Identification wrap |
658-0941-02 |
Miscellaneous Parts
Table D-5 EAGLE Miscellaneous Part Numbers
Drives |
Dual CD-RW\DVD-ROM |
870-2746-01 |
870-2746-02 |
T1x00 AS |
Disk Drive, 120GB |
804-1804-01 |
804-1804-R01 |
ULTRAATA/100/133_7200RPM |
Panels |
Alarm side panel |
870-0259-02 |
Alarm indicator lamps |
525-0067-R01 |
Blank side panel |
840-0017-02 |
654-0075-01 |
654-0075-R01 |
Brackets, unit separation |
652-0609-01 |
652-0609-02 |
Bracket |
652-0954-01 |
652-0954-02 |
Fan |
Kits |
Cable Rack Mounting Kit |
804-1571-01 |
Heay duty frame |
804-0219-01 804-0219-02 |
804-0219-R01 804-0219-R02 |
raised floor |
External tooth washers |
606-0062-01 |
fan bracket |
Diode Board A |
870-1608-01 |
Diode Board A |
870-1608-03 |
Diode Board B |
870-1608-02 |
Diode Board B |
870-1608-04 |
Diode Upgrade kit |
840-0139-01 |
For 870-1606-02 |
Diode Upgrade kit |
840-0139-02 |
For 870-2320-01 |
E1 Interface Kit |
890-1037-01 |
890-1037-06 |
Mounting hardware kit |
840-0092-01 |
840-0092-03 |
For heavy duty frame. South America/India only |
Brackets, Screws, and other small items |
652-0609-01 |
652-0609-02 |
Bracket |
652-0954-01 |
652-0954-02 |
Fan |
Bracket, fan tray |
652-0012-01 |
652-0012-02 |
Fan tray |
Bracket, side, fan tray |
652-0015-01 |
652-0015-02 |
Fan tray |
Heat-shrink |
804-0229-01 |
Heat-shrink |
804-0228-01 |
Lugs, # 6 two-hole |
502-0085-01 |
502-0085-R01 |
FAP connector |
#6 AWG |
690-0131-01 |
690-0131-R01 |
804-0977-01 |
804-0977-R01 |
830-0880-01 |
Screws (12) |
601-0010-01 |
Screws |
600-0193-01 |
12x24 .500 cs zinc fan bracket |
Terminal lug |
804-0817-02 |
804-0817-R02 |
Terminating resistor |
104-0032-01 |
E1 backplane |
Power Cords for Peripherals
Table D-6 Power Cords for Peripherals
Country | Part Number | Country | Part Number |
USA |
Cord provided |
Latvia |
804-1185-R01 |
Argentina |
804-1185-R02 |
Liechtenstein |
804-1185-R11 |
Australia |
804-1185-R02 |
Lithuania |
804-1185-R01 |
Austria |
804-1185-R01 |
Luxembourg |
804-1185-R01 |
Belgium |
804-1185-R01 |
Malaysia |
804-1185-R03 |
Brazil |
804-1185-R01 |
Malta |
804-1185-R03 |
Bulgaria |
804-1185-R01 |
Mexico |
Cord provided |
Canada |
Cord provided |
Monaco |
804-1185-R01 |
Chile |
804-1185-R01 |
Netherlands |
804-1185-R01 |
China |
804-1185-R09 |
New Zealand |
804-1185-R02 |
Columbia |
Cord provided |
Norway |
804-1185-R01 |
Cyprus |
804-1185-R03 |
Peru |
804-1185-R01 |
Czech Republic |
804-1185-R01 |
Philippines |
Cord provided |
Denmark |
804-1185-R04 |
Poland |
804-1185-R01 |
Egypt |
804-1185-R01 |
Portugal |
804-1185-R01 |
Estonia |
804-1185-R01 |
Romania |
804-1185-R01 |
Finland |
804-1185-R01 |
Russia |
804-1185-R01 |
France |
804-1185-R07 |
Saudi Arabia |
Cord provided |
Germany |
804-1185-R01 |
Singapore |
804-1185-R03 |
Greece |
804-1185-R01 |
Slovakia |
804-1185-R01 |
Hong Kong |
804-1185-R03 |
South Africa |
804-1185-R06 |
Hungary |
804-1185-R01 |
South Korea |
804-1185-R01 |
Iceland |
804-1185-R01 |
Spain |
804-1185-R01 |
India |
804-1185-R06 |
Sweden |
804-1185-R01 |
Ireland |
804-1185-R03 |
Switzerland |
804-1185-R11 |
Israel |
804-1185-R12 |
Taiwan |
Cord provided |
Italy |
804-1185-R07 |
Turkey |
804-1185-R01 |
Ivory Coast |
804-1185-R01 |
United Kingdom |
804-1185-R03 |
Japan |
804-1185-R10 |
United Arab |
804-1185-R03 |
