A LED Information
A.1 Introduction
This section shows the card face plates and describes the Light Emitting Diodes (LEDs) for each card. This section assists maintenance personnel in troubleshooting.
EAGLE frames are configured with modules (cards) that provide specific functions and services. LEDs together with part numbers, text and bar codes are located on the faceplates of the cards. The cards are listed in alphabetical order of the full card name. Each card is identified by its acronym first, then by the full name of the card.
A.2 CI, Clock Interface Card, Holdover Clock
Figure A-1 Holdover Clock CI Card LEDs
img/t_replacing_cards_in_the_holdover_clock_maintmanual_fig1.jpg
A.3 E5-ATM-B Interface Module
Figure A-2 E5-ATM-B Interface Module
img/r_e5_atm-b_leds.jpg
A.4 E5-E1T1-B Interface Module
Figure A-3 E5-E1T1-B Interface Module
img/r_e5_e1t1-b_leds.jpg
A.5 E5-ENET-B Interface Module
Figure A-4 E5-ENET-B Interface Module
img/r_e5_enet-b_leds.jpg
Must be used with the E5-MASP card.
The E5-ENET-B is provisionable for multiple functions, but does not support multiple functions on a single card simultaneously.
A.6 E5-MASP Card
Figure A-5 E5-MASP Card
img/870-2903-xx_e5_masp_led_table.jpg
A.7 E5-MCPM-B Module
Figure A-6 E5-MCPM-B Module
img/r_e5_e1t1_e5_e1t1_interface_module_im-fig1.jpg
img/r_e5_mcpm-b_leds.jpg
A.8 E5-MDAL Card
Figure A-7 E5-MDAL Card
img/870-2903-xx_e5-mdal.jpg
A.9 E5-SM8G-B Module
Figure A-8 E5-SM8G-B Interface Module
img/r_e5_sm8g-b_leds.jpg
Table A-1 E5-SM8G Interface Module LEDs
LED Color Descriptions
APPL
PROC
Red
Application processor is not running or is failing diagnostics.
Amber
Card is loading an application or is being polled (may be prevented from loading by maintenance-out-of-service condition)
Green
Card is running an application.
IMT
Red
Card is off IMT bus
Amber
Card is on IMT bus, but testing is not complete.
Green
Card is on IMT bus
Blank
Communication processor is not operating.
ACT
Red
No signal detected
Green
Signal detected
Off
Card nonfunctional
PORT
Amber
Data link active operating at 1 Gbps
Green
Data link active operating at 10/100 Mbps
Off
Card non-functional
A.10 HIPR2, High-Speed IMT Packet Router 2 Module
Figure A-9 HIPR2 LEDs
img/870-2879-01_hipr2.jpg
A.11 MIS, Maintenance Interface System, Holdover Clock
Figure A-10 Holdover Clock MIS Card LEDs
img/r_mis_maintenance_interface_system_holdover_clock_im-fig1.jpg
Table A-2 MIS LEDs
LEDs Descriptions
FAIL
RED – This card or its power supply has failed.
BLANK – No card or power supply failure detected.
CRITICAL
RED – Holdover clock system has failed.
BLANK – No holdover clock system failure detected.
MAJOR
RED – Holdover clock system or any holdover clock card has a major alarm.
BLANK – No major alarm detected.
MINOR
YELLOW – Holdover clock system or any holdover clock card has a minor alarm.
BLANK – No minor alarm detected.
ACO
GREEN – The ACO push button has been pressed to silence the alarm during an alarm state.
A.12 MCA, Matrix Controller Assembly Card, Holdover Clock
Figure A-11 Holdover Clock MCA Card LEDs
img/r_mca_matrix_controller_assembly_card_holdover_clock_im-fig1.jpg
Table A-3 MCA LEDs
LEDs Descriptions
FAIL
RED – This card has failed or there is a loss of all input references to this card.
BLANK – No card or input reference failure detected.
AUTO
GREEN – Indicates output failure was protected automatically.
BLANK – No failures detected.
MAN
GREEN – Indicates output failure was protected manually.
A.13 SLIC Module
Alarms and LEDs
The SLIC has 21 LEDs visible on the faceplate. The LEDs are visible with the aid of a light pipe, which directs the light from the LED to the front panel.
Figure A-12 SLIC Module
img/c_slic_front_oracle.jpg
Table A-4 SLIC Front Panel LEDs
LED Name Control Colors Definition
APPL FPGA / Application Software Off / Red / Green
Off - No power
Red - Card is booting
Green - Card is running Application
IMTA LIIC FPGA / Communication Software Red / Green
Red -Not connected to BUS
Green - Active and Connected to Bus
Amber - MUX card on the same shelf is seated and not inhibited; bus not available
IMTB LIIC FPGA / Communication Software Red / Green
Red - Not connected to BUS
INTERFACES E1/T1 FPGA / Application Software Green / Off
Green - Enabled
Off - Disabled
INTERFACES ENET FPGA / Application Software Green / Off
Green - Enabled
Off - Disabled
PORT1-PORT8 PHY / Application Software Off / Red / Green
Off - Not configured
Red - Cable removed and/or not synced
Green - 10/100Mb link speed
LINK1-LINK8 FPGA / Application Software Off / Red / Green
Off - No SLKS configured
Red - All Configured SLKS OOS
Green - All SLKS aligned
A.14 ST3, Stratum-3 Clock Card, Holdover Clock
Table A-5 ST3 LEDs
LEDs Descriptions
FAIL
RED – This card has failed.
BLANK – No card failure detected.
LOCK
RED – Input has failed.
BLANK – No input failure detected.
REF A
GREEN – Card is tracking the output of clock input card A.
BLANK – Not tracking output of clock input card A.
REF B
GREEN – Card is tracking the output of clock input card B.
BLANK – Not tracking output of clock input card B.
If the FAIL and LOCK LEDs are both illuminated, the ST3 is in holdover mode and the card has not failed. Holdover Clock ST3 Card LEDs
A.15 TOCA, Timing Output Composite Automatic, Holdover Clock
Table A-6 TOCA LEDs
LEDs Descriptions
FAIL
PORT ALM
RED – One to five outputs have failed or have been externally shorted.
BLANK – No output failures detected.
ST
GREEN – An active clock is supplying the input reference for this card.
BLANK – No active clock detected.
INPUT
GREEN – Card is receiving a reference signal from one or more of the following: clock input A, clock input B, clock card A, clock card B.
BLANK – Card is not receiving a reference signal from any of the above sources.
500’
Not used
1000’
Not used
