4.368 flash-card
Use this command to load all flash images (GPL)
supported by a specified card. This command performs the same functions as the
init-flash
and the
act-flash
commands.
Parameters
- loc (mandatory)
- Card address. The location of the card as
stenciled on the shelf of the system.
- Range:
- 1101 - 1108, 1111 - 1113, 1115, 1201 - 1208, 1211 - 1218, 1301 - 1308, 1311 - 1318, 2101 - 2108, 2111 - 2118, 2201 - 2208, 2211 - 2218, 2301 - 2308, 2311 - 2318, 3101 - 3108, 3111 - 3118, 3201 - 3208, 3211 - 3218, 3301 - 3308, 3311 - 3318, 4101 - 4108, 4111 - 4118, 4201 - 4208, 4211 - 4218, 4301 - 4308, 4311 - 4318, 5101 - 5108, 5111 - 5118, 5201 - 5208, 5211 - 5218, 5301 - 5308, 5311 - 5318, 6101 - 6108, 6111 - 6118
- force (optional)
- This parameter is used to force the command to work on an IS-NR card. Links provisioned on the card are inhibited during command execution. The card and inhibited links are restored to their previous state when the command is completed.
- mode (optional)
- This parameter converts the flash GPL of cards present in the Upgrade SET
lists (
RTRV-UPGRADE-CONFIG:DISPLAY=SETS
)- Range:
- migrate2
- Flashes all the cards present in the Upgrade
SETs that are running on BLMCAP and/or BLSLC32.
Converts BLMCAP to BLDC32 and BLSLC32 to BLSLC932
respectively.
Cards running BLDC32 or BLSLC64 are not affected.
Uses the data in the SETs to decide which cards to migrate simultaneously. The migration sequence follows the same sequence as used by the Upgrade operations. The OAM cancels the links and boots the cards as the flash GPL changes occur. The use of SETs by the OAM ensures that sufficient signaling link capacity remains available at all times, and prevents disabling all links in the same linkset.
Example
flash-card:loc=1105:code=trial
flash-card:loc=1105:code=appr:force=yes
flash-card:mode=migrate2
Dependencies
Cards do not have to be provsioned to use the
flash-card
command. However, if the specified card is provisioned and
not inhibited, use of the
force parameter is required.
The specified card locations must be running a flashable software image.
This command cannot be used to load flash images for
MUX cards. Use the
init-flash
command.
If the even-numbered E5-TDM (1114,1116) is specified, the flash occurs on the odd-numbered E5-MCAP running OAM (1113,1115).
The specified card location cannot be the active E5-MASP (either the active E5-MCAP or the active E5-TDM).
No other action command can be in progress when this command is entered.
The card specified in the location parameter must be present and able to communicate over the IMT. The card does not have to be provisioned in the database.
If the card is already running the specified code load, it cannot be loaded by this command.
This command cannot be entered if an IMT Rate Change sequence is in progress.
This command cannot be entered during an Extended Bit Error Rate Test (BERT).
Notes
The specified card must be present and able to communicate over the IMT.
A card that is already running the specified code load
cannot be reflashed using the
force parameter. The
act-flash
and
init-flash
commands must then be used
to reload the same code level.
Output
flash-card:code=appr:force=yes:loc=1112
Command Accepted - Processing
tekelecstp 18-01-18 16:06:22 MST EAGLE 46.5.1.5.0-73.3.0
Command entered at terminal #1.
tekelecstp 18-01-18 16:06:55 MST EAGLE 46.5.1.5.0-73.3.0
Flash Card: FLASH GPL required to be downloaded on card 1112
BLMCAP : Running version 143-001-000 Expected version 143-002-000
tekelecstp 18-01-18 16:07:14 MST EAGLE 46.5.1.5.0-73.3.0
Flash Card: Downloading BLMCAP on card 1112
Flash Card: Card(s) will reset after the flash GPL download.
tekelecstp 18-01-18 16:07:56 MST EAGLE 46.5.1.5.0-73.3.0
Flash Card: Activating BLMCAP on card 1112
tekelecstp 18-01-18 16:08:25 MST EAGLE 46.5.1.5.0-73.3.0
Flash Card: Card 1112 flash activation complete.
Flash Card: Activating links on card 1112.
tekelecstp 18-01-11 16:09:11 EST EAGLE5 39.0.0
Command Completed.
tklc1121001 20-03-02 01:05:43 EST EAGLE 46.9.0.0.0-76.11.0
Command entered at terminal #3.
Recovery Required: Manually flash inhibited card 1112.
Recovery Required: Manually flash inhibited card 1107.
Network Conversion: Inhibiting card 1108.
** 8007.0539 ** ENET 1108,A Ethernet Interface Down
tklc1121001 20-03-02 01:06:04 EST EAGLE 46.9.0.0.0-76.11.0
* 8010.0107 * IMT BUS A Minor IMT failure detected
tklc1121001 20-03-02 01:06:06 EST EAGLE 46.9.0.0.0-76.11.0
8011.0106 IMT BUS A IMT Bus alarm cleared
Network Conversion: Downloading BLSL932 on IPSG card 1108
Network Conversion: Card(s) will reset after the flash GPL download.
tklc1121001 20-03-02 01:06:07 EST EAGLE 46.9.0.0.0-76.11.0
MBUS DBG: GPL download timeout: 1140000 (MS) 19 (MINS)
tklc1121001 20-03-02 01:07:56 EST EAGLE 46.9.0.0.0-76.11.0
Network Conversion: Card 1108 flash download complete.
tklc1121001 20-03-02 01:08:11 EST EAGLE 46.9.0.0.0-76.11.0
* 8023.0004 * GPL SYSTEM BLSL932 Card is running non-activated GPL
tklc1121001 20-03-02 01:08:14 EST EAGLE 46.9.0.0.0-76.11.0
Network Conversion: FLASH GPL(s) required to be activated on card 1108
BLSL932 : Running inactive version 059-011-000
Network Conversion: Activating BLSL932 on card 1108
tklc1121001 20-03-02 01:08:53 EST EAGLE 46.9.0.0.0-76.11.0
Network Conversion: Card 1108 flash activation complete.
tklc1121001 20-03-02 01:09:00 EST EAGLE 46.9.0.0.0-76.11.0
8029.0005 GPL SYSTEM BLSL932 Alarm cleared running non-activated GPL
tklc1121001 20-03-02 01:09:06 EST EAGLE 46.9.0.0.0-76.11.0
Network Conversion: Allowing card 1108
tklc1121001 20-03-02 01:09:07 EST EAGLE 46.9.0.0.0-76.11.0
MBUS DBG: Card Loading Timeout: 8 minutes.
Network Conversion: Cards loading, wait for them to return to IS-NR.
tklc1121001 20-03-02 01:09:39 EST EAGLE 46.9.0.0.0-76.11.0
8033.0096 CARD 1108 IPSG69 Card has been reloaded
tklc1121001 20-03-02 01:09:48 EST EAGLE 46.9.0.0.0-76.11.0
8035.0540 ENET 1108,A Ethernet Interface Up
tklc1121001 20-03-02 01:10:24 EST EAGLE 46.9.0.0.0-76.11.0
Command Completed.
Related Topics
