4.367 ent-vlr-roaming
Use this command to enter a Visitor Location Register (VLR) roaming entry for a mobile subscriber. A VLR-Roaming entry uses existing entries for both new as well as old entries from vlr-prof table.
Parameters
oldvlr (mandatory)
VLR Number from which mobile subscriber has moved, hexadecimal digit GT number with variable length (1 to 16).
Range:
Hexadecimal digit string 1 to 16 digits
newvlr (mandatory)
VLR Number to which mobile subscriber has moved, hexadecimal digit GT number with variable length (1 to 16).
Range:
time (mandatory)
Duration for which the roaming must occur. Time is in minutes.
Range:
1-1440
Example
ent-vlr-roaming:newvlr=12345:oldvlr=56780:time=10
Dependencies
VLR_PROF table must be accessible.
VLR DBMM table must be accessible.
VLR_ROAM table must be accessible.
OLDVLR as well as NEWVLR parameter length must be in the range 1 to 5 digits as per current restriction.
OLDVLR or NEWVLR parameter must be existing in VLR-PROF table
The entry should not be existing in VLR_ROAM table
OLDVLR as well as NEWVLR parameter must not be mentioned as blacklisted in vlr table.
Entries over 1000 are not allowed
Value for OLDVLR and NEWVLR parameter must not be same.
Output
ent-vlr-roaming:oldvlr=1234:newvlr=56545:time=20
tekelecstp 17-11-23 16:23:44 MST  EAGLE 46.5.1.5.0-73.2.0
    Command entered at terminal #17.
    ENT-VLR-ROAMING: MASP A - Cannot access standby fixed disk.
    ENT-VLR-ROAMING: MASP A - Simplex database update.
    Command Accepted - Processing
    VLR-ROAMING table is (1 of 1000) 1% full.
    ENT-VLR-ROAMING: MASP A - COMPLTD
