4.277 dlt-vlr-roaming
Use this command to delete a Visitor Location Register (VLR) Roaming entry for a mobile subscriber for existing entries.
Parameters
oldvlr (mandatory)
VLR Number from which mobile subscriber has moved, hexadecimal digit GT number with variable length (1 to 16).
Range:
Hexadecimal digit string 1 to 16 digits
newvlr (mandatory)
VLR Number to which mobile subscriber has moved, hexadecimal digit GT number with variable length (1 to 16).
Range:
Example
dlt-vlr-roaming:newvlr=12345:oldvlr=56780
Dependencies
VLR_PROF table must be accessible.
VLR DBMM table must be accessible.
VLR_ROAM table must be accessible.
OLDVLR and NEWVLR parameter length must be in the range 1 to 5 digits as per current restriction.
OLDVLR or NEWVLR parameter must be existing in VLR-PROF table
The entry should be existing in VLR_ROAM table
Output
tekelecstp 17-11-23 16:23:44 MST  EAGLE 46.5.1.5.0-73.2.0
    dlt-vlr-roaming:oldvlr=1234:newvlr=56545:time=20
    Command entered at terminal #17.
    DLT-VLR-ROAMING: MASP A - Cannot access standby fixed disk.
    DLT-VLR-ROAMING: MASP A - Simplex database update.
Command Accepted - Processing
    VLR-ROAMING table is (1 of 1000) 1% full.
    DLT-VLR-ROAMING: MASP A - COMPLTD
