1 Introduction
This chapter provides a brief overview of the Oracle Communications EAGLE Application B Card (E5-APP-B). This chapter also includes the scope, audience, and organization of this manual; how to find related publications; and how to contact the My Oracle Support (MOS).
Overview
The Oracle Communications EAGLE Application B Card (E5-APP-B) is a complete application server platform designed to operate within a heavy duty EAGLE shelf. An E5-APP-B card consists of the card, a microprocessor, 8 GB RAM, and two removable drive modules with an operating system and an application, such as EPAP, loaded.
This guide includes links to documents that are specific to a given product. For more information about linked documents, see guide.Each time this guide is published, the revision level is changed. For example, the first time this guide is published, it uses Revision 1; the second time it is published, it uses Revision 2.
Scope and Audience
The scope of this manual includes Oracle Communications EAGLE Application B Card hardware installation and removal procedures. This manual also contains network integration information for ExAP, LSMS and IMF.
References
For more information, refer to the following documents:
- ELAP Administration and LNP Feature Activation Guide
- EPAP Administration Guide
- TPD Initial Product Manufacture User's Guide
Applications Documents and Related Specifications
The E5-APP-B card supports a variety of applications. For information about additional publications that are related to this document, refer to the Oracle Help Center site. See Locate Product Documentation on the Oracle Help Center Site for more information on related product publications.
Application documentation may also contain information about additional hardware.Locate Product Documentation on the Oracle Help Center Site
Locating E5-APP-B Card Part Numbers
Each E5-APP-B card FRU has labels that contain the following information that may be needed for the RMA:
Part number (to identify the type of FRU)
Serial number (to provide more information about the specific FRU)
CLEI (Common Language Equipment Identifier, a label that identifies the manufacturer and the part)
In addition to part numbers on each FRU, the E5-APP-B card has several labels that contain part number information for drive module FRUs on the E5-APP-B card. These labels allow part number information to be gathered without removing the E5-APP-B card.
E5-APP-B card, use Locating E5-APP-B Card Part Number Information
Drive module assembly, use Locating Drive Module Assembly Part Number Information
The part number information for drive module assemblies is located on the label on the drive module assembly. Use this label to verify the correct part number if you ever need to replace a drive module assembly. See Figure 1-1.
Figure 1-1 E5-APP-B Card Label Locations
- Serial Number Label (1)
- CLEI Label (2)
- Part Number Label (3)
- Revision Label (4)
