Spare and Private Point Code Subtype Prefixes
The Spare Point Code Support feature and the Internal Point Code Support feature provide optional point code subtype prefixes. The Spare Point Code feature must be enabled before a point code subtype prefix can be specified for a point code.
The SEAS interface does not support point code subtype prefixes.
The values p-, s-, and ps- are valid point code subtype prefixes. The dash- separates the point code subtype prefix from the remainder of the point code. The prefixes are displayed in lower case. The syntax for the remainder of the point code remains the same.
The Spare Point Code prefix (s-) applies only to ITU-I and ITU-N point code domains (ITU-N24 point codes do not support the Spare Point Code prefix), to allows the EAGLE to fully support ITU National and International Spare Point Codes. Table A-2 lists the commands that support the Spare Point Code subtype prefix.
The Private (Internal) Point Code prefix (p-) applies to all point code domain types (including ITU-N24 point codes), to allow messages destined to the End Office Node to be routed from the inbound LIM to the outbound IPGWx. Table A-3 lists the commands that support the Private Point Code subtype prefix.
The subtype prefix ps- can be specified when the point code parameter supports both the spare and private point code prefixes.
Table A-2 Commands that support the Spare Point Code Prefix
Command Description Applicable Point Code Parameters
alm
Alarm
dpci and dpcn
appl-rtkey
Application Route Key
dpci and dpcn; opci and opcn
cspc
Concerned Signaling Point Code
pci and pcn
dstn
Destination
spci and spcn; dpci and dpcn; and Alias combinations.
ent-trace
Enter Trace
gsmmap-scrn
GSM MAP Screening
npci and npcn
gsmopts
GSM Options
ppsmspci1, ppsmspci2, ppsmspcn1, ppsmspcn2
gsms-opcode
GSM Short Message Services OP-Code
pci and pcn
gtt/gta
Global Title Translation/Global Title Address
pci and pcn
ls
Linkset
apci and apcn
map
Mated Application
pci and pcn; mpci and mpcn
mrn
Mated Relay Node
pci and pcn; pci1 and pcn1; pci2 and pcn2; pci3 and pcn3; pci4 and pcn4
na
Network Appearance
type=ituis, type=ituns
pass
Pass Commands
Syntax for routing keys
rmt-appl
Remote Application
ipci and ipcn
rte
Route
dpci and dpcn
scr-aftpc
Gateway Screening Allowed Affected Point Code
pcst and pctype
scr-blkdpc
Gateway Screening Blocked Destination Point Code
pcst and pctype
scr-blkopc
Gateway Screening Blocked Origination Point Code
pcst and pctype
scr-cdpa
Gateway Screening Called Party (CDPA PC Destination) Point Code
pcst and pctype
scr-cgpa
Gateway Screening Calling Party (Origination) Point Code
pcst and pctype
scr-destfld
Gateway Screening Affected Destination (Concerned) Point Code
pcst and pctype
scr-dpc
Gateway Screening Destination Point Code
pcst and pctype
scr-opc
Gateway Screening Origination Point Code
pcst and pctype
sid
Site ID
True pci and pcn; cpci and cpcn; ncpci and ncpcn.
spc
Secondary Point Code
spci and spcn
Table A-3 Commands that support the Private Point Code Prefix
dstn
Destination
spci and spcn; dpc, dpca, dpci,, and dpcn Does not apply to Aliases
ls
Linkset
If ipgwapc=yes, apc, apcn, apci, and apcn
gtt/gta
pc, pca, pci, and pcn
inh/unhb-alm
Destination alarm inhibit
dpc, dpca, dpci, and dpcn
rept-stat-cluster
Report Cluster Status
dpc and dpca
rept-stat-dstn
Report Destination Status
rmt-appl
Remote Application
ipc, ipca, ipci, and ipcn
rst-dstn
Restore Destination
dpc and dpca
rte
Route
