Valid CIC Ranges for SI and MSU Types in Routing Key Static Entries
Table A-4 lists the valid CIC ranges for use with SI and MSU types in Routing Key table static entries.
Table A-4 Valid CIC Ranges for SI and MSU Types
| SI | MSU for ANSI DPC | MSU for ITU DPC | Comments |
4 (TUP) |
N/A |
CIC is 12 bits. Range is 0-4095. |
The TUP protocol is used only in ITU networks. |
5 (ISUP) |
CIC is 14 bits. Range is 0-16383. |
13 (QBICC) |
CIC is 32 bits. Range is 0-4294967295. |
