Assign a Static IP Address to a LAN-Connected Device
Assign a static IP address to a LAN-connected device from the Manage Devices drawer.
Context:
You can assign a static IP address only to a device detected on the edge node LAN. The device can be either onboarded in Oracle ECP or unmanaged.
Prerequisites:
  • Access to the device's MAC address.
  • A static IP range must be configured on this Cloud Connector before you can assign a static IP address to a device. (See Edit LAN DHCP or Static IP Values)
Procedure
  1. Open the Manage Devices drawer in one of the following ways:
    • Select the Network tab, select a LAN interface, and then select Manage Devices.
    • Select the Devices tab, select LAN devices, and then select Manage Devices.
  2. (Optional) Select Add Device to set a static IP address for an onboarded device.
    A new row in the table is created for you to edit.
  3. Select the pencil icon in the target device's row.
  4. Choose a static IP address from the drop-down.
  5. Select the check mark in the actions column.
  6. (Optional) repeat for additional devices.
  7. Select Update to submit the changes for this edge node.
