LAN-connected Device Management
LAN-connected device management includes the functions used to manage devices detected by an edge node on a LAN interface. You can assign static IP addresses to LAN-connected devices and block devices by MAC address.
Assigning a static IP address reserves an IP address for a LAN-connected device. To assign a static IP address, the device must be onboarded into Oracle ECP with a matching MAC address, and the selected address must come from the configured static IP range (configured in a LAN-Facing Ethernet Interface or Wi-Fi Interface).
Blocking a device by MAC address prevents a LAN-connected device from using the edge node for connectivity. You can block a device that is already detected by the edge node, or you can manually add a MAC address to block a device.
Both functions are available from the same Manage Devices drawer. Open the drawer from the Network tab when a LAN interface is selected, or from the Devices tab when LAN device is selected.
