9.2 EMS Configuration Component
9.2.1 Creating an EMS Configuration Component
For each network element to be supported by the LSMS, create an EMS Configuration component using the following procedure:
For each EMS configuration created, you must perform a bulk download to the associated EMS/network element. Refer to the LNP Database Synchronization User's Guide for bulk loading procedures.
  1. Log into the LSMS as a user in the lsmsadm or lsmsall group.
  2. From the LNP System menu, shown in the following figure:
    Figure 9-27 LNP System Menu – Create EMS
    , select Configure, and then LNP System, and then EMS, and then Create.
    The EMS Configuration Component window displays. The window usually opens with the Address Info tab displayed; if the Address Info tab is not displayed, click its tab to display it.
    Figure 9-28 Create LNP System EMS Address Info Tab
  3. Ensure that the radio button for an ELAPMPS or a TekPath MPS is selected. For an ELAPMPS (ELAP version 7 or older), enter the IP addresses for MPS A and MPS B (enter a value from 0 to 255 in each of the first three octets and a value from 0 to 254 in the forth octet). For a TekPath MPS, enter the IP address for MPS A only.
  4. Click the Component Info tab, shown in Figure 9-30.
    Figure 9-29 Create LNP System EMS Component Info
  5. Enter the Component Info data as follows (all fields in this tab must contain data):
    • Owner ID – ID of the network element owner (maximum 20 alphanumeric characters)
    • Platform Type – hardware platform of the network element (maximum 20 alphanumeric characters)
    • Platform Supplier – name of the supplier of the network element hardware platform (maximum 20 alphanumeric characters)
    • Platform SW Release – release level of the software running on the network element platform (maximum 20 alphanumeric characters)
    • Platform Model – model number of the network element platform (maximum 20 alphanumeric characters)
    • CLLI – CLLI code of the network element (maximum 11 numeric and uppercase alphabetic characters)
    • Mate CLLI– CLLI of the mate EMS component (maximum 11 numeric and uppercase alphabetic characters)
    • PC – point code of the EMS component (must contain three 3-digit octets; first octet must have a value from 1 to 255; last two octets must have a value from 0 to 255; second octet must not be 001 if the first octet has a value from 1 to 5)
    • Mate PC – point code of the mate EMS component (must contain three 3-digit octets; first octet must have a value from 1 to 255; last two octets must have a value from 0 to 255; second octet must not be 001 if the first octet has a value from 1 to 5)
    • LNP Capability PC – LNP capability point code of the network element (must contain three 3-digit octets; first octet must have a value from 1 to 255; last two octets must have a value from 0 to 255; second octet must not be 001 if the first octet has a value from 1 to 5)
  6. Click the Contact Info tab, shown in Figure 9-29.
    Figure 9-30 Create LNP System EMS Contact Info
  7. All fields in this tab are optional. If you wish to enter the Contact Info data, do so as follows:
    • Name – name of the person to contact for network element information (maximum 40 alphanumeric characters)
    • Email – email address of the network element contact person (maximum 60 alphanumeric characters)
    • Street – street address of the network element contact person (maximum 40 alphanumeric characters)
    • City – city address of the network element contact person (maximum 20 alphanumeric characters)
    • State – state address of the network element contact person (two-letter uppercase abbreviation). If you use the Province field, enter -- (the default).
    • ZIP Code – the postal zip code of the network element contact person (five numeric characters)
    • Province – the province of the network element contact person (two-letter uppercase abbreviation). If you use the State field, enter -- (the default).
    • Country – country of the network element contact person (maximum 20 alphanumeric characters).
    • Phone Number – phone number of the network element contact person (ten numeric characters required).
    • FAX Number – FAX number of the network element contact person (ten numeric characters required).
    • Pager Number – pager number of the network element contact person (ten numeric characters required)
    • Pager PIN– pager PIN number of the network element contact person (ten numeric characters maximum)
  8. When finished, click OK to apply the changes.
    • If the Update Successful dialog, Figure 9-31 appears, click OK. The GUI returns to the main console window.
      Figure 9-31 Update Successful Dialog
    • When a mandatory field is empty or a field is not properly configured, the Field Required Figure 9-32 dialog displays.
      Figure 9-32 Field Required Dialog
      Click OK and correct the appropriate field.
      Repeat this step until you receive an Update Successful notification.
9.2.2 Modifying an EMS Configuration Component
To modify an existing EMS configuration component, use the following procedure.
  2. Click the EMS status icon for the EMS you wish to modify so that the icon is highlighted.
  3. From the Main Menu, select Configure, and then LNP System, and then EMS, and then Modify, as shown in Figure 9-33.
    Figure 9-33 LNP System Menu – Modify EMS
    img/t_modifying_an_ems_configuration_component_config-fig1.jpg
    The Modify LNP System EMS window, Figure 9-34, appears.
    Figure 9-34 Modify LNP System EMS Window
    img/c_modifying_an_ems_configuration_component_config-fig2a.jpg
  4. Modify the EMS data as required.
    See Creating an EMS Configuration Component for detailed field information.
  5. Click OK.
    The EMS Routing dialog appears, Figure 9-35 .
    Figure 9-35 EMS Routing Dialog
    img/t_modifying_an_ems_configuration_component_config-fig3.jpg
    Click OK.
    The Update Successful dialog displays, Figure 9-36.
    Figure 9-36 Update Successful Dialog
    img/t_modifying_an_ems_configuration_component_config-fig4.jpg
You have completed this procedure.
If a mandatory field is empty or a field is not properly configured, the More Fields Needed message is displayed, Figure 9-37.
Figure 9-37 More Fields Needed Dialog
img/t_modifying_an_ems_configuration_component_config-fig5.jpg
Changes do not take effect until the eagleagent is restarted (refer to "Manually Verifying and Restarting the Eagle Agents" in the Alarms and Maintenance Guide).
9.2.3 Viewing an EMS Configuration Component
To view EMS configuration component information, use the following procedure.
  1. Log into the LSMS as a user in the lsmsview, lsmsuser, lsmsuext, or lsmsadm group.
  2. Click the EMS status icon for the EMS you wish to view (highlight the icon).
  3. From the Main Menu, select Configure, and then LNP System, and then EMS, and then View.
    The View LNP System EMS dialog displays, Figure 9-38.
    Figure 9-38 View LNP System EMS Dialog
    img/figure-47-view-ems.jpg
  4. Click on any of the tabs to view additional information.
    For more information about the meaning of the fields on any of the tabs, see Creating an EMS Configuration Component.
    You cannot modify information in any of the tabs.
  5. When finished viewing, click OK.
9.2.4 Deleting an EMS Configuration Component
To delete an EMS configuration component, use the following procedure.
  2. Click the EMS Status icon for the EMS you wish to delete (highlight the icon).
  3. From the Main Menu, select Configure, and then LNP System, and then EMS, and then Delete.
    The Delete LNP EMS dialog displays, Figure 9-39.
    Figure 9-39 Delete LNP System EMS Dialog
    img/figure-48-delete-ems.jpg
  4. View the information in this window to verify that this is the EMS you wish to delete.
    Click on any of the tabs to view additional information. For more information about the meaning of the fields on any of the tabs, see Creating an EMS Configuration Component. You cannot modify information in any of the tabs.
  5. Click OK or Cancel.
    • If you click Cancel, you are returned to the LSMS console window.
    • If you click OK, the Update Successful dialog displays, Figure 9-40.
    Figure 9-40 Update Successful Dialog
    img/t_deleting_an_ems_configuration_component_config-fig2.jpg
  6. Click OK.
