9 EMS, RTDB, and LSMS-Related Functions
This chapter describes and provides procedures for the following functions:
  • ELAP EMS Routing and Configuration
  • Copying, Bulk Loading, Restoring, Verifying, and Distributing the Real Time Database (RTDB)
  • Manually Verifying and Restarting the EAGLE Agents on the LSMS
9.1 EMS Routing
EMS routing information enables the LSMS to send subscription information to the proper network elements. The EMS routing function allows you to modify or view the routing info that you defined using the TN Filters and GTT Groups (see Chapter 4 of Database Administratior's Guide for LSMS).
9.2 Managing Bulk Load from the LSMS
This section describes how to perform a bulk load, view bulk load log files, and understand bulk load error messages.
9.2.1 Bulk Load Procedure
Use the following procedure to manage a bulk load from the LSMS user interface.
Before starting this procedure, contact Customer Care Center to be available for assistance if any problems are encountered while performing this procedure.
  1. Perform the following substeps to ensure that no NPA Splits will activate during the bulk download procedure:
    1. As lsmsadm, enter the following lsmsdb commands to output the counts for both Subscription Version and Number Pool Block objects:
      %  cd $LSMS_DIR/../tools
      %  lsmsdb -c counts | grep SubscriptionVersion
      1,012,345 ... CanadaDB.SubscriptionVersion
      5,434,123 ... MidAtlanticDB.SubscriptionVersion
      7,111,222 ... MidwestDB.SubscriptionVersion
      6,333,999 ... NortheastDB.SubscriptionVersion
      8,044,000 ... SoutheaststDB.SubscriptionVersion
      4,999,800 ... SouthwestDB.SubscriptionVersion
      6,500,000 ... WestCoastDB.SubscriptionVersion
      5,250,500 ... WesternDB.SubscriptionVersion
      %  lsmsdb -c counts | grep NumberPoolBlock
      1,205 ....... CanadaDB.NumberPoolBlock
      10,400 ...... MidAtlanticDB.NumberPoolBlock
      8,005 ....... MidwestDB.NumberPoolBlock
      4,000 ....... NortheastDB.NumberPoolBlock
      7,500 ....... SoutheaststDB.NumberPoolBlock
      1,225 ....... SouthwestDB.NumberPoolBlock
      7,700 ....... WestCoastDB.NumberPoolBlock
      5,500 ....... WesternDB.NumberPoolBlock
    2. Total the counts listed in the first column of the output from both commands in substep a.
      Divide this total by 2 million, to determine the estimated number of hours for the bulk load.
    3. Generate an NPA Split Report.
      Select Pending for Status and All NPAC Regions for NPAC Region. For information about creating and viewing NPA Split Data Reports, refer to LSMS Database Administrator's Guide.
    4. Determine if NPA Splits are scheduled to be activated during the time the Bulk Load is to be performed:
      • If no Pending NPA Splits were listed in the report in substep c, or if none of the Pending NPA Splits has a PDP Start Date that occurs within the time period required to complete the Bulk Load, go to step 2.
      • If any Pending NPA Split has a PDP Start Date that occurs within the time period required to complete the Bulk Load, continue with next substep.
    5. Determine the date on which you want the NPA Splits to be activated.
      This should be the next day after the expected completion of the Bulk Load Procedure (based on the start date/time anticipated and the estimated length of the Bulk Load procedure, from substep b). For example, if the Bulk Load is estimated to require 24 hours to complete and the Bulk Load planned to be performed starting at 12 noon on April 1st, the NPA Split should be postponed until April 3rd.
    6. Postpone the NPA Split. (Refer to LSMS Database Administrator's Guide.
  2. Ensure that the network element is prepared to receive a bulk load by doing the following:
    1. Connect your web browser to the ELAP user interface. See Setting Up an ELAP Workstation.
    2. Log in with the user name and password for a user who is authorized to access the menu items shown in this procedure.
      The ELAP GUI is displayed, as shown in Figure 9-1.
      Figure 9-1 ELAP Main Menu
      img/t_managing_bulk_load_from_the_lsms_dbs-fig1.jpg
    3. Select Maintenance > LSMS HS Bulk Download > Change Enabled.
      The window shown in Figure 9-2is displayed.
      Figure 9-2 Enabling Change HS Bulk Download
    4. If the information field indicates that the Bulkload for the ELAP is currently enabled, click the Disable Bulkload for this ELAP button and this will allow the audit.
  3. At the LSMS, log in as a member of the lsmsuser, lsmsuext, or lsmsall user group.
  4. Start the Bulk Load window using either of the following:
    1. From the Main Menu on the LSMS Console window, select LSMS > LNP Database Synchronization > Bulk Load > <CLLI> , where <CLLI> is the Common Language Location Identifier for the network element that requires the bulk load.
    2. Right-click the LSMS Console window’s EMS status icon that corresponds to the network element requiring the bulk load, and select LNP Database Synchronization , and then Bulk Load.
      The Bulk Load window displays. An example of this window is shown in Figure 9-3.
      Figure 9-3 Bulk Load Window
      Bulk Load Window
  5. To initiate the bulk load, click the Start button.
    The Start button is replaced by the Abort button, and the View Log button becomes selectable. Progress is indicated by start time, elapsed time, numbers of successful and failed update commands, and status reported in the status field at the bottom of the window. When the bulk load phase completes (as indicated in the status field and by a value appearing in the End Date/Time field for the Bulk Load phase), the Re-sync phase begins and progress continues to be indicated in the same ways. All other buttons become non-selectable. Table 9-1 shows the meaning of each of the fields that appears in this window.
    Table 9-1 Fields in Bulk Load Window
    Field Description Possible Values
    Bulk Loaded
    Total number of LNP commands that were successfully transmitted and applied to the NE’s LNP database during the initial download phase of the bulk load operation.
    0 — 99,999,999
    Resynced
    Total number of LNP commands that were successfully transmitted and applied to the NE’s LNP database during the resynchronization phase of the bulk load operation.
    0 — 99,999,999
    Download Total
    Total number of LNP commands that were successfully transmitted and applied to the NE’s LNP database during initial download and the resynchronization phases of the bulk load operation.
    0 — 99,999,999
    Errors
    Total number of commands that were successfully transmitted but rejected by the NE during the initial download and the resynchronization phases of the bulk load operation.
    0 — 99,999,999
    Bulk Load Start Date/Time
    Time at which the initial download phase of the bulk load operation was started by the user.
    MM/DD hh:mm:ss1
    Bulk Load End Date/Time
    Time at which the initial download phase of the bulk load operation completed successfully or terminated abnormally.
    MM/DD hh:mm:ss1
    Bulk Load Elapsed Date/Time
    Amount of time the initial download phase of the bulk load operation took to complete or the amount of time it ran before the user aborted it.
    MM/DD hh:mm:ss1[A|F]2
    Re-sync Start Date/Time
    Time at which the resynchronization phase of the bulk load operation was started by the user.
    MM/DD hh:mm:ss1
    Re-sync End Date/Time
    Time at which the resynchronization phase of the bulk load operation completed successfully (with or without command rejections at the NE) or terminated abnormally.
    MM/DD hh:mm:ss1
    Re-sync Elapsed Date/Time
    Amount of time the resynchronization phase of the bulk load operation took to complete or the amount of time it ran before the user aborted it.
    hh:mm:ss1[A|F]2
    Status
    Appears as text at the bottom left of the window to indicate the current status of the resynchronization operation.
    Varies
    1 MM indicates month, range 01—12
    DD indicates day, range 01—31
    hh indicates hour, range 00—23
    mm indicates minute, range 00—59
    ss indicates second, range 00—59
    2 A is appended at the end of the time if the operation is aborted.
    F is appended at the end of the time if the operation fails.
    The time required to download a database from the LSMS to the network element varies depending on the number of records provisioned in the database and the quality of the transmission and connections. To view the bulk load log file, see Bulk Load Log File. To abort during either the bulk load phase or the resynchronization phase of an electronic bulk load is in progress, click the Abort button. A confirmation dialog displays, as shown in Figure 9-4.
    Figure 9-4 Abort Bulk Load Operation Dialog
    1. Click the Yes button to immediately terminate the operation in progress.
      Go to Step 7 as if the bulk load had completed.
    2. Click the No button to close the Abort confirmation dialog and return back to the main Bulk Load window with no other effect.
  6. When the bulk load operation completes, the information dialog shown in Figure 9-5appears.
    Figure 9-5 Bulk Load Complete Information Dialog
    Click OK.
  7. When the bulk load operation completes or is aborted, the Abort and Close buttons are replaced by Commit and Discard buttons, as shown in Figure 9-6 .
    Figure 9-6 Bulk Load Complete
    Bulk Load Complete
    Commit before you click the Discard button, you can view the bulk load log file by clicking the View Log button (for more information about the file, including how to view it at other times, see Bulk Load Log File). To conclude the bulk load operation, you must click one of the following buttons:
    • Click the Discard button to end the bulk load application (closing the Bulk Load window) and to send the NE a discard command that results in changes to the ELAP RTDB that cannot be undone. (For whatever reason you are performing this procedure, the ELAP RTDB is now in a state of requiring database maintenance, but the bulk load application is no longer running.)
    On the active MPS, verify that the DB Status is Coherent and the RTDB Level is greater than zero before copying the newly downloaded database to the mated ELAP.
  8. The NE operator must continue with the following steps to cause the RTDB to be distributed and return the NE to normal operation as follows:
    1. Copy the newly restored RTDB to its mate ELAP RTDB, as described in Copy RTDB from Remote.
    2. Distribute the data to the Service Module cards, as described in Distributing an RTDB to Service Module Cards.
9.2.2 Support ELAP Reload Via Database Image Function
The Support ELAP Reload via Database Image (SERVDI) function performs bulk data downloads (BDD) that significantly reduces the time needed to reload an ELAP database.
The SERVDI function is executed on the LSMS system and creates an ELAP RTDB image file directly from the LSMS LNP databases. See Figure 9-7. The SERVDI download file must be transferred to the ELAP system backup directory. Once transferred, the file is activated by using the Restore RTDB on ELAP process in the ELAP GUI.
Figure 9-7 ELAP Reload Via DB Image Function
img/c_support_elap_reload_via_database_image_function.jpg
Although the SERVDI is run from the Active LSMS, the SERVDI backup is normally taken from the standby LSMS. If Standby LSMS is not available, the SERVDI takes the backup from the Active LSMS.
9.2.2.1 SERVDI Bulk Download
Use the following procedure to perform an ELAP bulk download from the LSMS.
SERVDI is part of the optional LNP feature. Contact Customer Care Center for more information.
The LSMS bulk download SERVDI creates the bulkload file, but cannot send it to the active ELAP unless the Secure Shell Keys (SSKs) have been exchanged. The procedure for exchanging the keys is part of the ELAP configuration procedure, and is illustrated in Copy RTDB from Remote. After the key exchange procedure is complete, the SERVDI bulk download can be sent from the LSMS to the active ELAP.
  1. Log in to the LSMS GUI as a member of the permission group that is authorized to perform this operation.
  2. From the LSMS Console window, select LSMS, and then LNP Database Synchronization, and then ELAP Reload Via DB Image, and then <CLLI> where <CLLI> is the ELAP network element that requires the bulk download.
    Figure 9-8 ELAP Reload Via DB Image
  3. Click Generate Image.
    Figure 9-9 Generate Image
    Generate Image
  4. The LSMS creates a database file of the ELAP database image. When the process completes, a confirmation dialog appears.
    Figure 9-10 Database Image Completed
    Click OK to continue.
    If necessary, you can stop the bulk download process before the database image is complete. To stop the bulk download process, click Abort. A confirmation dialog appears. Click Yes to terminate the bulk download in progress. Click No to continue with the bulk download.
    Figure 9-11 Abort Bulk Download
    Abort Bulk Download
    Figure 9-12 Abort Confirmation
    Abort Confirmation
  5. Click Transfer Image to transfer the bulk download to the ELAP.
    Figure 9-13 Transfer Database Image to ELAP
    When the transfer completes, a confirmation dialog appears. Click OK to continue.
    Figure 9-14 Image Transfer Complete
  6. Click Close to return to the main LSMS Console window.
In order to complete this process, you must reload the ELAP database using the file generated in Step 4. For more information about how to reload an ELAP database, refer to the procedure, Restore RTDB on ELAP.
9.2.3 Bulk Load Log File
This section describes the following topics:
Viewing the Bulk Load Log File
After a resynchronization has begun, you can view the electronic bulk load log file by clicking the View Log button. The browser window displays the log file LsmsBulkload.log.<MMDD>. The file is located in the directory /usr/local/LSMS/logs/<CLLI>. <CLLI> is the Common Language Location Identifier of the network element receiving the bulk load. < MMDD> is the timestamp that contains month and day that the file was created.
You can also use one of the following methods to open the window shown in Figure 9-15 to browse for this log:
  • Select Logs > Other... from the main menu of the LSMS Console window.
  • Click on the LSMS Console window’s EMS Status icon that corresponds to the network element receiving the bulk load so that the icon is highlighted. Right-click and select Logs > LNP Database Synchronization > Bulk Load.
    The Open Log Files window displays.
    Figure 9-15 Open Log Files Window
    img/c_bulk_load_log_file_dbs-fig1.jpg
Scroll down to find the folder that has the <CLLI> name for the NE that was bulk loaded. Double-click the folder name, and then double-click the file name LsmsBulkload.log.<MMDD> that corresponds to the month and day you desire.
Log files are maintained for seven days and then automatically removed from the LSMS.
Bulk Load Log File Contents
When a bulk load is started, the bulk load log file for that day is appended (if this is the first bulk load of the day, the file is created). For each bulk load performed on that day, the bulk load log file contains information similar to the information displayed on the Bulk Load main window, such as start and end times for the bulk load, and numbers of successes and failures in various LNP categories.
The bulk load log file contains the following sections:
  • Header Section
  • Bulk Load Section
  • Resynchronization Section
  • Summary Section
  • Download Commit/Discard Section
    Refer to Appendix C of LNP Database Synchronization User's Guide for more information on these sections.
Figure 9-16 shows an example of a bulk load log file.
Figure 9-16 Example Bulk Load Log File
img/c_bulk_load_log_file_dbs-fig2.jpg
img/c_bulk_load_log_file_dbs-fig3.jpg
9.2.4 Bulk Load Error Messages
For a listing of error messages that can appear on the GUI, along with explanation of possible cause and suggested recovery, refer to Appendix A in LNP Database Synchronization User's Guide.
9.3 Copying One RTDB from Another RTDB
This section describes the two methods for copying an EAGLE LNP Application Processor (ELAP) Real Time Database (RTDB) from another ELAP RTDB to reload a corrupted or backlevel RTDB:
For more information about when to perform each method, refer to the "Choosing a Database Maintenance Procedure" section in LNP Database Synchronization User's Guide.
Restore the RTDB from the Mated ELAP
ELAP uses a Distributed Replicated Block Device (DRBD) to replicate the database. The DRBD replicates the database by using a snapshot image of the database. The Support ELAP Reload Via Database Image function, or SERVDI, is executed on the LSMS for the bulk download, and the process is completed with the procedure to restore the RTDB. See Restore RTDB on ELAP for the detailed procedure.
For more information on the SERVDI function, see SERVDI Bulk Download.
Copy RTDB from Remote ELAP
ELAP uses a snapshot image of the database to replicate the database. The Copy RTDB from Remote procedure is used to copy the RTDB from the remote ELAP.
After completing the copy procedure, the database must be restored to make the transferred file the active RTDB. See Restore RTDB on ELAP for the procedure to restore the RTDB.
9.4 Verifying RTDB Status
Before or after executing the Copy One RTDB to Another RTDB procedure, verify the status of the RTDBs using either or both of the following methods:
9.4.1 Verifying RTDB Status at the EAGLE Terminal
To verify the status of the ELAP RTDBs at the EAGLE terminal, enter the rept-stat-db:db=mps command.
The command output displays the database timestamp (DBTS) of both ELAP RTDBs in the RTDB-EAGLE field, as shown in bold in the following example. The DBTS indicates the last time an update was received by this RTDB from the LSMS. If the two DBTS values are not the same, the RTDB with the lower DBTS may need database maintenance.
    tekelecstp 02-10-29 08:55:54 NZST EAGLE 39.0.0
                     ELAP A  ( ACTV )
                     C  BIRTHDATE               LEVEL     EXCEPTION
    RTDB             Y  02-10-29 08:20:04       12345        -
    RTDB-EAGLE 02-10-29 08:20:04 12345 -
                     ELAP B ( STDBY )
9.4.2 Verifying RTDB Status at the ELAP User Interface
To verify the status of ELAP RTDBs at the ELAP Graphic User Interface (view the status of the databases), perform the following procedure.
  1. Open a browser window and connect your web browser to the ELAP GUI.
  2. Log into the ELAP GUI with the user name and password for a user who is authorized to access the menu items shown in this procedure.
    The ELAP GUI is displayed, as shown in Figure 9-17.
    Figure 9-17 ELAP Main Screen
    img/c_elap_gui_main_screen_elapgui_elapadmin-fig1a.jpg
  3. From the Main Menu, select RTDB > View RTDB Status.
    The ELAP GUI workspace displays the RTDB status, as shown in Figure 9-18.
    Figure 9-18 ELAP RTDB Status
    img/t_verifying_rtdb_status_at_the_elap_user_interface_dbs-fig2.jpg
    Note the values displayed for DB Level and DB Birthday for both the local RTDB and the mate RTDB.
  4. To verify that both RTDBs are ready for normal service, ensure that:
    1. The status for both RTDBs displays
    2. Both RTDBs are coherent
    3. Both RTDBs have the same birthday
    4. Both RTDBs have the same level (if provisioning is occurring, the levels might be different by a small number)
      If you are not sure how to interpret the status of the RTDBs, contact My Oracle Support (MOS).
    You have now completed this procedure.
9.5 Restore RTDB on ELAP
Follow these steps to restore the RTDB from a backup file after performing a bulk download.
  1. Open a browser window and connect your Web browser to the ELAP GUI.
  2. Log into the ELAP GUI with the user name and password for an authorized user.
  3. From the ELAP GUI menu, select Process Control, and then Stop Software to ensure that no other updates are occurring. The screen shown in Figure 9-19 displays. Click the Stop ELAP Software button.
    Figure 9-19 Stopping Software on the ELAP GUI
    img/t_procedure_to_copy_an_rtdb_from_the_mate_elap_dbs-fig3.jpg
    After the software on the selected ELAP has stopped, the screen shown in Figure 9-20 is displayed.
    Figure 9-20 Stop ELAP Software - Success
    img/t_restoring_databases_from_backup_files_mps_maintenance_t1100mps_maintmanual-fig2.jpg
  4. Select RTDB , and then Maintenance, and then Restore RTDB.
    The Restore the RTDB screen displays, Figure 9-21.
    Figure 9-21 Restore the RTDB
    img/c_rtdb_menu_elapgui_elapadmin-fig10aa.jpg
  5. Select the appropriate file to restore and click the Restore RTDB from the Selected File button.
  6. To confirm restoring the file, click the Confirm RTDB Restore button on the confirmation dialog, Figure 9-22.
    Figure 9-22 Confirm RTDB Restore
    img/c_rtdb_menu_elapgui_elapadmin-fig11a.jpg
  7. After the file is successfully restored, the screen shown in Figure 9-23 displays.
    Figure 9-23 Successful RTDB Restoration
    img/c_rtdb_menu_elapgui_elapadmin-fig12.jpg
9.6 Copy RTDB from Remote
The software does not have to be stopped before performing this procedure.
Restore the RTDB to make the transferred file the active RTDB.
Follow these steps to copy the RTDB from a remote ELAP to the local ELAP.
  3. From the ELAP GUI menu, select RTDB , and then Maintenance, and then Copy from Remote .
    The Figure 9-24 screen is displayed.
    Figure 9-24 Copy RTDB from Remote Screen
    img/copy_rtdb_from_remote.jpg
  4. To copy the remote RTDB, enter the remote box's IP address and a password for the "elapdev" user ID in the fields shown in Figure 9-24. Then, click the Select File To Transfer button.
  5. Select the appropriate source from the screen that is displayed, as shown in Figure 9-25. Then, click the Copy the selected remote RTDB backup button.
    Figure 9-25 Copy RTDB from Remote Selection
    img/copy_rtdb_from_remote_selection.jpg
    After the copy is complete, a confirmation message is displayed.
    To reload the RTDB, follow the procedure as shown in Restore RTDB on ELAP.
9.7 Distributing the LNP Database after LSMS-Based Operation or RTDB Copy
The network element has multiple copies of the LNP database. Synchronization operations are performed on one database. After an RTDB copy or a synchronization operation initiated from the LSMS GUI, the remaining NE LNP databases must be synchronized with the newly synchronized NE database in one of the following ways:
  • Automatic Data Distribution
    After the following LNP database synchronization operations, data is distributed automatically from the network element’s newly synchronized LNP database to all other LNP databases at the network element:
    • Automatic resynchronization (see “Automatic Resynchronization Process” in LNP Database Synchronization User's Guide
    • Reconcile (see “Audit and Reconcile Overview” in LNP Database Synchronization User's Guide)
  • Network Element Database is not Required after Copying an RTDB from its Mate ELAP
    If network element’s database synchronization is accomplished only by copying an RTDB from its mate ELAP’s RTDB, but not when copying from the mate RTDB is performed after copying an RTDB from the remote mated network element or after a bulk load from the LSMS, it is not necessary to distribute the data to the Service Module cards because they are already synchronized with the RTDB that was used to restore from. Therefore, after the copy, the Service Module cards are now synchronized with both RTDBs.
  • Other Network Element Database Distribution
    After other LNP database synchronization operations, the network element main LNP database must be distributed by operator intervention to other LNP databases within the network element (both the mate RTDB and the Service Module cards). See Distributing an RTDB to Service Module Cards.
9.7.1 Distributing an RTDB to Service Module Cards
This section describes how to distribute the data from the ELAP RTDB to the Service Module cards after the RTDB has been updated by one of the following actions:
  1. Distribute the imported RTDB onto each Service Module card, which will also silence the LNP database alarms.
    Use one of the following methods:
    • Method A loads the imported LNP database onto one Service Module card at a time by reloading each Service Module card.
      This method allows the global title translation and LNP functions to continue running while the new RTDB is being loaded. When the Service Module card is reinitializing, its database goes temporarily out of service for the period of time that it takes to reload the database on the Service Module card. The time required to reload the database depends upon the size of the database and can take as long as 23 minutes for an RTDB containing 384 million LNP subscriptions.
    • Method B loads the imported RTDB onto all Service Module cards in the EAGLE by reinitializing all the Service Module cards at once.
      Caution:
      This method not only loads the imported LNP database onto the Service Module cards at the same time, but takes all the Service Module cards out of service and the LNP subsystem will be offline. This method should be used only in emergency situations.
    Method A: Perform steps1 and2 in this method for each Service Module card, one Service Module card at a time.
    1. Take the Service Module card out of service with the rmv-card command specifying the location of the Service Module card. If there is only one Service Module card in the EAGLE, the force=yes parameter must be specified with the rmv-card command. For this example, enter this command:
      rmv-card:loc=1301
      After successful completion of this command, the EAGLE returns the following output:
      rlghncxa03w 06-08-01  11:11:28 GMT  EAGLE5 39.0
      Card has been inhibited.
    2. Return the Service Module card to service with the alw-card command with the location of the Service Module card and the option data=persist to allow a warm restart if possible. This command validates that the RTDB on the specified Service Module card is correct. If the RTDB is correct, no further loading is required. If the LNP database is not correct, it is automatically reloaded from the ELAP RTDB; loading may require up to an hour. For this example, enter this command:
      alw-card:loc=1301:data=persist
      rlghncxa03w 06-06-01  11:11:28 GMT  Eagle5 39.0.0
      Card has been allowed.
      When the Service Module card is returned to service, the major alarm is silenced and UAM 0431, LNP database has been corrected, is generated.
    3. Repeat 1 and 2 of Method A for each of the other Service Module cards in the EAGLE.
      If any of the Service Module cards continue to boot, contact My Oracle Support (MOS).
    Method B: Load the imported RTDB onto all Service Module cards in the EAGLE by reinitializing all the Service Module cards at once by entering the following command:
    init-card:appl=vsccp
    Caution:
    This command initializes all the Service Module cards at once and not only loads the imported RTDB onto the Service Module cards at the same time, but takes all the Service Module cards out of service and the LNP subsystem will be offline. This method should only be used in emergency situations.
    A more graceful way of initializing the Service Module cards is to reroute all global title translation traffic, including LNP traffic, to the mate network element using theinh-map-ss command. Theinh-map-ss command takes the mated application subsystem out of service. When the mated application subsystem is out of service, all global title translation traffic, including LNP traffic, is rerouted to the mate network element.
    The mated application subsystem must be inhibited with theinh-map-ss command before the Service Module cards are reinitialized with theinit-card:appl=vsccp command. After the init-card:appl=vsccp command has finished executing and all the Service Module cards have reinitialized, return the mated application subsystem to service with the alw-map-ss command.
    When the imported database has been loaded onto each Service Module card, UAM 0431 is displayed for each Service Module card showing that the UAM 0429 has been cleared and the database on the Service Module card matches the database on the MASPs.
  2. Verify that the Service Module cards are in-service by entering the rept-stat-sccp command.
    The state of the Service Module cards, shown in the PST field of the rept-stat-sccp command output, should be IS-NR (in-service normal). If the state of any Service Module card is not IS-NR, contact My Oracle Support (MOS).
    The rept-stat-sccp command output contains fields that are not used by this procedure. If you want to see the fields displayed by the rept-stat-sccpcommand, see the rept-stat-sccp command description in the Commands User's Guide for EAGLE.
9.7.2 Disabling Bulk Load
If you have distributed a restored the RTDB LNP data to the Service Module cards (as described in Distributing an RTDB to Service Module Cards) after an LSMS-initiated procedure, perform the following procedure.
  1. If you do not already have a browser window connected to the ELAP, open a browser window and connect your web browser to the ELAP graphical user interface. See Setting Up an ELAP Workstation.
    Log in with the user name and password of a user who is authorized to access the menu items shown in this procedure.
  2. Select Maintenance, and then LSMSHS Bulk Download, and then Change Enabled.
    The Change LSMS HS Bulk Download Enabled dialog opens, Figure 9-26.
    Figure 9-26 Change LSMS HS Bulk Download Enabled Dialog
    img/t_disabling_bulk_load_lnp_feature_activation-fig1.jpg
    The information field should show that the LSMS Bulk Download for this ELAP is currently enabled.
  3. Click the Disable LSMSHS Bulk Download for this ELAP button.
You have completed this procedure.
9.8 Manually Verifying and Restarting the Eagle Agents on the LSMS
This procedure explains how to verify that an Eagle agent has started on the LSMS. It also explains how to stop and start the agent, using the eagle command.
The Eagle Agent application (eagleagent) is responsible for:
  • Subscribing to the broadcast channels to receive all NPAC and local data updates
  • Connecting with a single EAGLE node using the HSOP (High Speed Operations Protocol) protocol and forwarding LNP updates to the EAGLE
  • Filtering LNP data based on the provisioned filter information before forwarding it to the EAGLE (for more information, refer to EMS Routing)
  • Performing automatic resynchronization with an EAGLE node upon connection establishment (for more information, refer to LNP Database Synchronization User's Guide)
One instance of the eagleagent process exists for each supported EAGLE node.
  1. Log in to the LSMS as lsmsadm on the active server.
  2. Enter the following command to display the status of all EAGLE processes:
    $ eagle status
    CLLI Pid   State     Resync Conn A Conn B EBDA Debug Queue Memory CPU Timestamp
    STPB 27111 NONE_ACTIVE NO_CONNECTION DOWN --- IDLE OFF 0 % 70 M 0.0 % 13:32:53
    STPA --- not running
    STPC 14616 A_ACTIVE COMPLETE ACTIVE --- IDLE OFF 0 % 70 M 1.0 % 13:32:53
    If a line similar to the one shown in bold above appears for each supported EAGLE node, you have completed the procedure. If, instead, a line similar to the following line appears, one of these processes has failed; perform the remaining steps of this procedure to restart the processes.
  3. Start the Eagle agent by entering this command at the active server, where <CLLI> is the Common Language Location Identifier (such as STPA in the example above) for the EAGLE node:
    $LSMS_DIR/eagle start <CLLI>
  4. Verify that the Eagle agent has started by repeating Step 2.
    If the Eagle agent fails to start, contact My Oracle Support.
