4.2 DIU Upgrade Phases
The following table shows the DIU upgrade process by procedure and estimated time. Actual times may vary with typing speed and system configuration. Perform the DIU upgrade on ELAP B first, then on ELAP A. Complete the phases in the order shown.
Table 4-4 DIU upgrade Phases
Phase Elapsed Time (Minutes) Activity Procedure
This Step Cum.
Connectivity setup
15
15
Set up connectivity to the MPS servers.
Procedure 1
Verify DIU upgrade
9
10
Verify this should be an DIU upgrade.
Procedure 26
Requirements check
2
5
Verify requirements for DIU upgrade are met.
Procedure 27
Assess readiness for DIU upgrade
15
20
Assess the server’s readiness for DIU upgrade.
Procedure 29
Pre-DIU upgrade health check
7
15
Run the syscheck utility to verify the MPS server is operationally sound.
Procedure 3
Pre-DIU upgrade system time check
5
60
Pre-DIU upgrade system time check.
Procedure 30
Pre-DIU upgrade Backups
22
75
Backup application databases and other pertinent information.
Procedure 5,
Procedure 31
Perform DIU upgrade
22
120
Run the DIU upgrade procedure on MPS B and A.
Procedure 32
Post-DIU upgrade health check
7
15
Procedure 3
Accept the upgrade after successful soak period.
Note: User will not be able to perform backout procedure in case of any problem once the
upgrade is accepted.
4
This is done in a separate MTC
Accept the upgrade on both MPS-A and MPS-B after sufficient soak period of around 1-7 days (depending upon customer provisioning volume) to see that everything works fine after the upgrade.
Procedure 33
7
15
Procedure 3
