4 Configuring the NAS
This section provides steps for initial configuration of the Oracle Communications LSMS Network Attached Storage (NAS), which is performed on the LSMS server.
4.1 Initial Configuration
The Oracle Communications LSMS Network Attached Storage (NAS) configuration is performed on the LSMS server through the lsmsmgr utility.
The initial configuration is performed on the LSMS server after the fresh installation. If the NAS is connected with the LSMS for the first time, or the TPD has been re-installed on the NAS, the initial configuration is required for the NAS. The NAS will be configured initially through the primary LSMS using tty serial terminal.
