B Automatic Monitoring of Events
This appendix contains overviews of monitored events, GUI and surveillance notifications, and traps.
B.1 Introduction
This appendix contains:
  • “Overview of Monitored Events”, which describes how the LSMS monitors itself for events and alarms and how it reports them.
  • “Overview of GUI Notifications”, which describes the display, format, and logging of notifications that appear on the graphical user interface.
  • “Overview of Surveillance Notifications”, which describes the display, format, and logging of Surveillance notifications.
  • “Overview of Traps”, which describes the transmission, format, and logging of SNMP traps.
  • A listing of all events, in numerical order, starting on page B-18. For each event, this appendix includes:
    • Explanation of the probable cause for the event
    • Suggested recovery
    • Indication of whether the event results in a GUI notification, Surveillance notification, trap, or some combination of these.
B.2 Overview of Monitored Events
This section describes:
Types of Events and Alarms Reported
The LSMS monitors itself for the types of events and alarms shown in Table B-1 . When one of these events occurs, the LSMS does one or more of the following:
  • Displays a notification on the graphical user interface (GUI notification)
  • Posts a Surveillance notification at a certain frequency to the administration console by default, or to the second serial port if so configured
  • Sends a trap to a Network Management System (NMS) if you have installed the optional Remote Monitoring feature
Every GUI notification and Surveillance notification contains its associated event number. Traps contain a trap ID, which is explained in Overview of Traps.
Table B-1 Notification Event Number Categories
Event Number Range Category Description
0000–1999
EMS
Events that pertain to an Element Management System (EMS). The EMS is a process that runs on the Multi-Purpose Server (MPS) at a network element.
2000–3999
NPAC
Events that pertain to a Number Portability Administration Center (NPAC)
4000–5999
Platform and switchover (some of these events do not produce GUI notifications)
Events that pertain to system resources, such as disks, hardware, memory, central processing unit (CPU) utilization and to switchover functions
6000–7999
Main LSMS processes
Events that pertain to one of the following main LSMS processes: lsman, supman, npacagent, or eagleagent
8000–8999
Applications
Events that pertain to LSMS applications that are feature or application dependent, such as LNP Database Synchronization, Service Assurance, or NPA Split Administration
How Servers Report Alarms and Events
The LSMS 9.0 servers perform the following functions to monitor and report events:
  • The standby server:
    • Monitors itself only for:
      • Platform events (see Platform Alarms)
      • Switchover-readiness events, such as those that describe database replication or critical network interfaces
    • Controls the appropriate AlarmLED (Critical, Major, or Minor) on the front of the server by illuminating the LED when one or more platform alarm in that category exists and turning off the LED when no platform alarms in that category exist
    • Sends any notification to its Serial Port 3 and logs the notification in its Surveillance log
    • Sends the notification to the active server
  • The active server performs the following functions:
    • Monitors itself for both platform events and application events
    • Sends all platform events for itself, events reported from the standby server, and appropriate application events for itself to its Serial Port 3 and also logs the event as appropriate in its Surveillance log (some event notifications are reported repeatedly; for more information about which events are reported repeatedly, see the individual event descriptions)
      • Alarms that originate from the active server contain the alarm text with no hostname
      • Alarms that originate from the standby server contain the alarm text preceded by the standby server’s hostname
        Although all events are reported through SNMP traps and all platform alarms are reported through Surveillance notifications, not all application alarms are reported both through the GUI and through Surveillance notifications; for more information about which alarms are reported in which way, see the individual event descriptions.
    • Displays one time on the GUI each platform or application event for itself and each platform event received from the standby server:
      • Alarms that originate from the active server display the alarm text with no hostname
      • Alarms that originate from the standby server display the alarm text preceded by the standby server’s hostname
    • Sends one Simple Network Management Protocol (SNMP) trap for each platform or application event for itself and for each platform event received from the standby server. Each trap contains the IP address of the server from which the notification originated.
B.3 Overview of GUI Notifications
Displaying GUI Notifications
GUI notifications are displayed on the GUI only if the GUI is active when the reported event occurs, but all GUI notifications are logged in an appropriate log as described in Logging GUI Notifications. Figure B-1 shows an example of notifications displayed on the GUI.
Figure B-1 GUI Notifications
img/c_overview_of_gui_notifications_mm-fig1-r13.jpg
B.3.1 Format of GUI Notifications
This section describes the general format used for most GUI notifications, as well as additional fields used for GUI event notifications (used to report information only) and for EMS GUI notifications. The formats are expressed as an ordered sequence of variables. Variables are expressed with the name of the variable enclosed by angle brackets; for example, <Severity> indicates a variable for the severity assigned to a GUI notification. Variables Used in GUI Notification Format Descriptionsshows the variables used in GUI notification formats.
General Format for GUI Notifications
The format for most GUI notifications is:
[<Severity>]:<Time Stamp> <Event Number> <Message Text String>
In addition, the following types of GUI notifications contain additional fields:
Format for EMS GUI Notifications
EMS GUI notifications (event numbers in the range 0000–1999) contain a <CLLI> value to indicate the Common Language Location Identifier for the network element where the EMS resides. The format for EMS GUI notifications is:
[<Severity>]:<Time Stamp> <Event Number> <CLLI>: <Message Text String>
Format for GUI Notifications with EVENT Severity
Notifications that have the severity EVENT can contain additional event data fields. The format for GUI notifications with severity EVENT is:
[EVENT]:<Time Stamp> <Event Number> <EventType>:<EventData1>, [<EventData2>],...
B.3.1.1 Variables Used in GUI Notification Format Descriptions
Table B-2 shows the possible values and meanings for each of the variables shown in format definitions for GUI notifications.
Table B-2 Variables Used in GUI Notifications
Field Description
<Severity>
Indicates seriousness of event, using both text and color, as follows:
Text
Color
Meaning
[Critical]
Red
Reports a serious condition that requires immediate attention
[Major]
Yellow
Reports a moderately serious condition that should be monitored, but does not require immediate attention
[Minor] Turquoise Reports a condition of minor significance that should be monitored, but which does not require immediate attention.
[Cleared]
Green
Reports status information or the clearing of a condition that caused previous posting of a [Critical] or [Major] GUI notification
[EVENT]
White
For information only
<Time Stamp>
Indicates time that the event was detected, in format:
YYYY-MM-DD hh:mm:ss where fields are as follows:
Field
Meaning
Possible Values
YYYY
Year
Any four digits
MM
Month
01 through 12
DD
Day
01 through 31
hh
Hour
00 through 23
mm
Minute
00 through 59
ss
Second
00 through 59
<Event Number>
Four-digit number that identifies the specific GUI notification (also indicates the type of GUI notification, as shown in Table B-1 ).
Text string (which may contain one or more variables defined in Table B-3 ) that provides a small amount of information about the event. For more information about the event, look up the corresponding event number in this appendix; for each event number, this appendix shows the text string as it appears in a GUI notification, as well as a more detailed explanation and suggested recovery.
<CLLI>
Used in all EMS GUI notifications to indicate the Common Language Location Identifier for the network element where the EMS resides.
<EventType>: <EventData1>, [<EventData2>],...
Optional event data fields, as indicated by square brackets around the field, included in GUI notifications with severity [EVENT]. If no data is available for a given field, the field is empty. If other fields follow an empty field, the empty field is indicated by consecutive commas with no intervening data. One of the optional fields in an event notification is an effective timestamp field. This field indicates the time that the event actually occurred. When present, it uses the ASN.1 Generalized Time format.
B.3.2 Variables Used in Message Text String of GUI Notifications
Table B-3 shows the variables that can appear in the message text of a GUI notification.
Table B-3 Variables Used in Message Text of GUI Notifications
Symbol Possible Values and Meanings Number of Characters
<PRIMARY|SECONDARY>
PRIMARY=Primary NPAC
SECONDARY=Secondary NPAC
7 or 9
<retry_interval>
Time, in minutes, between retries of a request sent to an NPAC after it sent a failure response
1-10
<retry_number>
Number of times the LSMS will retry to recover from a failure response sent by NPAC
1-10
<YYYYMMDDhhmmss>
Year, month, day, hour, minute, second
14
<NPAC_region_ID>
CA = Canada
MA = MidAtlantic
MW = Midwest
NE = Northeast
SE = Southeast
SW = Southwest
WE = Western
WC = WestCoast
2
B.3.3 Examples of GUI Notifications
Example of General Format GUI Notifications
Following is an example of a general GUI notification (for a description of its format, see General Format for GUI Notifications):
[Critical]:1998-07-05 11:49:56 2012 NPAC PRIMARY-NE Connection Attempt Failed:
Access Control Failure
Example of an EMS GUI Notification
Following is an example of an EMS GUI notification (for a description of its format, see Format for EMS GUI Notifications). In this example, <CLLI> has the value LNPBUICK:
[Critical]:1998-07-05 11:49:56 0003 LNPBUICK: Primary Association Failed
Example of GUI Notification with EVENT Severity Level
Following is an example of a GUI notification with severity [EVENT]. For a description of its format, see Format for GUI Notifications with EVENT Severity:
[EVENT]: 2000-02-05 11:49:56 8069 LNPBUICK: Audit LNP DB Synchronization Aborted
B.3.4 Logging GUI Notifications
When an event that generates a GUI notification occurs, that notification is logged in the file created for those events. Table B-4 shows the types of log files used for each of these file names, where <mmdd> indicates the month and day the event was logged.
Table B-4 Logs for GUI Notifications
Event Type Log File
EMS Alarms, NPAC Alarms, and Main LSMS Process Alarms
/var/TKLC/lsms/logs/alarm/LsmsAlarm.log.<mmdd>
Non-alarm Events
/var/TKLC/lsms/logs/<region>/LsmsEvent.log.<mmdd>, where <region> indicates the region of the NPAC that generated the information
For information about the format of the logs and how to view the logs, refer to the Database Administrator's Guide.
B.4 Overview of Surveillance Notifications
Surveillance notifications are created by the Surveillance feature. These notifications can report status that is not available through the GUI notifications and report status that can be monitored without human intervention.
Displaying Surveillance Notifications
Surveillance notifications are sent to Serial Port 3 on each server.
Format of Surveillance Notifications
All Surveillance notifications reported on the same server where the event occurred have the following format:
<Event Number>|<Time Stamp>|<Message Text String>
Surveillance notifications that originated from the non-active server and are reported on the active server where the event occurred have an additional field that shows the hostname of the server where the event occurred, as shown in the following format:
<Event Number>|<Time Stamp>|<Host Name>|<Message Text String>
B.4.1 Variables Used in Surveillance Notification Format Descriptions
Table B-5 shows the possible values and meanings for each of the variables shown in format definition for Surveillance notifications.
Table B-5 Variables Used in Surveillance Notifications
Field Description
<Event Number>
Four-digit number that identifies the specific Surveillance notification and also indicates the type of Surveillance notification, as shown in Table B-2 .
<Time Stamp>
hh:mm Mon DD, YYYY where fields are as follows:
Field
Meaning
Possible Values
hh
Hour
00 through 23
mm
Minute
00 through 59
Mon
Month
First three letters of month’s name
DD
Day
01 through 31
YYYY
Year
Any four digits
<Host Name>
First seven letters of the name of the host (one of two redundant servers) that noted the event. (In addition, the documentation of the individual event includes information about whether the event is reported by the active server or inactive server, or both servers.)
Text string (which may contain one or more variables defined in Table B-6) that provides a small amount of information about the event. For more information about the event, look up the corresponding event number in this appendix; for each event number, this appendix shows the text string as it appears in a Surveillance notification, as well as a more detailed explanation and suggested recovery.
B.4.2 Variables Used in Message Text String of Surveillance Notifications
Table B-6 shows the variables that can appear in the message text of a Surveillance notification.
Table B-6 Variables Used in Message Text of Surveillance Notifications
<CLLI>
11
<PRIMARY|SECONDARY>
7 or 9
<NPAC_cust_ID>
0000 = Midwest
0001 = MidAtlantic
0002 = Northeast
0003 = Southeast
0004 = Southwest
0005 = Western
0006 = WestCoast
0008 = Canada
4
<NPAC_IP_Address>
IP address of the NPAC
10
<process_name>
First 12 characters of process name
12
<region>
Midwest
MidAtlantic
Northeast
Southeast
Southwest
Western
WestCoast
Canada
6 to 12
<return_code>
Return code
1 or 2
<Service_Assurance_Manager_name>
System name of machine that implements the Service Assurance Manager
12
<volume_name>
Name of disk volume, for example: a01
3
<volume_name_of_disk_
partition>
3
B.4.3 Example of a Surveillance Notification
Following is an example of a Surveillance notification:
LSMS8088|14:58 Mar 10, 2000|lsmspri|Notify: sys Admin - Auto Xfer Failure
B.4.4 Logging Surveillance Notifications
In addition to displaying Surveillance notifications, the Surveillance feature logs all Surveillance notifications in the file survlog.log in the/var/TKLC/lsms/logs directory.
If the LSMS Surveillance feature becomes unable to properly report conditions, it logs the error information in a file, named lsmsSurv.log, in the /var/TKLC/lsms/logs directory on each server’s system disk. When the size of lsmsSurv.log exceeds 1MB, it is copied to a backup file, named lsmsSurv.log.bak,in the same directory. There is only one LSMS Surveillance feature backup log file, which limits the amount of log disk space to approximately 2MB.
B.5 Overview of Traps
The optional Remote Monitoring feature provides the capability for the LSMS to report certain events and alarms to a remote location, using the industry-standard Simple Network Management Protocol (SNMP). The LSMS implements an SNMP agent.
Customers can use this feature to cause the LSMS to report events and alarms to another location, which implements an SNMP Network Management System (NMS). An NMS is typically a standalone device, such as a workstation, which serves as an interface through which a human network manager can monitor and control the network. The NMS typically has a set of management applications (for example, data analysis and fault recovery applications).
For more information about the LSMS implementation of an SNMP agent, see “Understanding the SNMP Agent Process”.
SNMP Version 3 Trap PDU Format
An SNMPv3 trap PDU consists of the following fields:
  • PDU Type
    Specifies the type of PDU (in this case, trap).
  • Request ID
    Used to associate requests with responses.
  • Error Status
    Specifies an error or error type in response PDUs only (else set to 0)
  • Error Index
    Associates an error with a particular object instance in response PDUs only (else set to 0)
  • Variable Bindings
    Each variable binding contains an object field followed by its value field. The object and value fields together specify information about the event being reported.
SNMP Version 1 Trap PDU Format
Following is an overview of the format of the SNMP version 1 trap request. For more information about SNMP message formats, refer to SNMP, SNMPv2, SNMPv3, and RMON 1 and 2, Third Edition, William Stallings, Addison Wesley, ISBN 0-201-48534-6, 1999.
Each SNMP message consists of the following fields:
  • SNMP authentication header, which consists of:
    • Version identifier, used to ensure that both the sender and receiver of the message are using the same version of the SNMP protocol. Currently, the LSMS supports only version 1, which has a version identifier of 0 (zero).
    • Community name, used to authenticate the NMS. The SNMP agent uses this field as a password to ensure that the sender of the message is allowed to access the SNMP agent’s information. The LSMS supports only trap requests, which originate at the LSMS; therefore, this field is not significant.
  • Protocol data unit (PDU), which for a trap request consists of:
An SNMPv1 trap PDU consists of the following fields:
  • PDU Type field, which specifies the type of PDU (in this case, trap).
  • Enterprise field, which identifies the device generating the message. For the LSMS SNMP agent, this field is 323.
  • Agent address field, which contains the IP address of the host that runs SNMP agent. For the LSMS SNMP agent, this field contains the IP address of the LSMS active server.
  • Generic trap type, which can be set to any value from 0 through 6. Currently, the LSMS supports only the value 6, which corresponds to the enterpriseSpecific type of trap request.
  • Specific trap type, which can be used to identify a specific trap.
  • Time stamp, which indicates how many hundredths of a second have elapsed since the last reinitialization of the host that runs the SNMP agent.
  • One or more variables bindings, each of which contains an object field followed by a value field. The object and value fields together specify information about the event being reported.
B.5.1 Logging SNMP Agent Actions
When the LSMS SNMP agent process starts, stops, or sends a trap request, it logs information about the action in a log file. The log file is named lsmsSNMP.log.<MMDD>, where <MMDD> represents the current month and day. The log file is stored in the directory /usr/TKLC/lsms/logs/snmp.
Table B-7 shows the actions and information logged by the LSMS SNMP agent.
Table B-7 Information Logged by the LSMS SNMP Agent
Action Information Logged
The SNMP agent starts
Action, followed by day, date, time, and year; for example:
LSMS SNMP agent started: Thu Mar 09 09:02:53 2000
The SNMP agent stops
LSMS SNMP agent stopped: Thu Mar 09 15:34:50 2000
The SNMP agent sends a trap request
The following fields, delimited by pipe characters:
  • Timestamp, recorded as YYYYMMDDhhmmss (year, month, date, hour, minute, second)
  • trap_ID, a unique numeric identifier that corresponds to the specific trap request sent.
  • For each NMS configured (up to five allowed):
    • The NMS’s IP address
    • Status (either of the following):
      • S to indicate that the LSMS SNMP agent succeeded in sending the trap request. (Even if the LSMS SNMP agent successfully sends the trap request, there is no guarantee that the NMS receives it.)
      • F to indicate that the LSMS SNMP agent failed in sending the trap request.
Following is a sample entry logged when a trap is sent (in this entry, a trap with a trap_ID of 3 is sent to two NMSs):
20000517093127|3|10.25.60.33|S|10.25.60.10|S
B.6 Event Descriptions
0001
Explanation
The EMS Ethernet interface has a problem. The ping utility did not receive a response from the interface associated with the EMS.
Recovery
Consult with your network administrator.
Event Details
Table B-8 Event 0001 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - EMS interface failure
Source
Both servers
Frequency
Every 2.5 minutes as long as condition exists
Trap
Trap ID
16
Trap MIB Name
emsInterfaceFailure
0002
Explanation
The EMS, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text, requires a resynchronization with the LSMS that cannot be accomplished by automatic resynchronization between the LSMS and the EMS.
Recovery
Perform one of the synchronization procedures described in the LNP Database Synchronization User's Guide.
Event Details
Table B-9 Event 0002 Details
GUI Notification
Severity
Critical
Text
DB Maintenance Required
Text
Notify:Sys Admin - NE CLLI=<CLLI>
Source
Active server
Frequency
As soon as condition occurs, and at five-minute intervals as long as condition exists
Trap
Trap ID
33
Trap MIB Name
emsRequiresResynchWithLSMS
0003
Explanation
The LSMS has lost association with the primary EMS of the network element, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text; the association with the secondary EMS is established.
Recovery
Determine why the primary association failed (connectivity problem, EMS software problems, NE software problem, etc.). Correct the problem. Association will be automatically retried.
Event Details
Table B-10 Event 0003 Details
GUI Notification
Severity
Major
Text
Text
Source
Active server
Frequency
Trap
Trap ID
5
Trap MIB Name
primaryEMSAssocLostSecEstablished
0004
Explanation
The LSMS has lost association with the primary EMS of the network element, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text; the association with the secondary EMS is not established.
Recovery
Determine why the primary association failed (connectivity problem, EMS software problems, NE software problem, etc.). Correct the problem, and then reestablish the association with the primary EMS.
Event Details
Table B-11 Event 0004 Details
GUI Notification
Severity
Critical
Text
Text
Source
Active server
Frequency
Trap
Trap ID
36
Trap MIB Name
primaryEMSAssocLostNoSec
0006
Explanation
The pending queue used to hold transactions to be sent to the EMS/NE, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text, is full. To help ensure that no updates are lost, the eagleagent will abort associations with both the primary EMS and secondary EMS. Updates will be queued in a resynchronization log until the EMS reassociates.
Recovery
Determine why the EMS/NE is not receiving LNP updates, and correct the problem.
Event Details
Table B-12 Event 0006 Details
GUI Notification
Severity
Critical
Text
All Association(s) Aborted: Pending Queue Full
Text
None
Source
Frequency
Trap
Trap ID
97
Trap MIB Name
emsAssociationAbortedQueueFull
0007
Explanation
The network element, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text, is busy and is sending ’retry later’ in response to a message sent by the eagleagent. The eagleagent has already tried resending the same message the maximum number of times. The eagleagent has aborted associations with both the primary EMS and secondary EMS.
Recovery
Correct the problem at the network element. When the EMS reconnects with the LSMS, the LSMS will automatically resynchronize the network element’s LNP database.
Event Details
Table B-13 Event 0007 Details
GUI Notification
Severity
Critical
Text
All Association(s) Aborted: Retries Exhausted
Text
None
Source
Frequency
Trap
Trap ID
98
Trap MIB Name
emsAssocAbortedMaxResend
0008
Explanation
The LSMS has lost association with the secondary EMS which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text. The association with the primary EMS is still up.
Recovery
Determine why the secondary association failed (connectivity problem, EMS software problems, NE software problem, etc.) and then reestablish the association with the secondary EMS.
Event Details
Table B-14 Event 0008 Details
GUI Notification
Severity
Major
Text
Secondary Association Failed
Text
Source
Active server
Frequency
Once, as soon as condition occurs
Trap
Trap ID
130
Trap MIB Name
secondaryEMSAssocLost
0009
Explanation
The LSMS has established the first association with the network element (NE) which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text. The first association established is called the primary association. This EMS is called the primary EMS.
Recovery
No action required; this notification is for information only.
Event Details
Table B-15 Event 0009 Details
GUI Notification
Severity
Cleared
Text
Primary Association Established
Text
None
Source
Frequency
Trap
Trap ID
8
Trap MIB Name
primaryEMSAssocEstablished
0010
Explanation
The LSMS has established the second association with the network element (NE) which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text. The association is established only if a primary association already exists. This EMS is called the secondary EMS.
Recovery
Event Details
Table B-16 Event 0010 Details
GUI Notification
Severity
Cleared
Text
Secondary Association Established
Text
None
Source
Frequency
Trap
Trap ID
134
Trap MIB Name
secondaryEMSAssocEstablished
0011
Explanation
The primary association for the EMS/NE, which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text, is either down or is inhibited, such that transactions sent to the primary EMS will not be received by the NE. Transactions are being sent to the secondary EMS instead of the primary EMS.
Recovery
Determine why the primary association failed (connectivity problem, EMS software problem, NE software problem, or other problem). Correct the problem. Association will be automatically retried. When the association is reestablished, it will be a secondary association, and the EMS will be the secondary EMS.
Event Details
Table B-17 Event 0011 Details
GUI Notification
Severity
Cleared
Text
Successful Switchover Occurred to Secondary EMS
Text
None
Source
Frequency
Trap
Trap ID
139
Trap MIB Name
transactionToSecondary
2000
Explanation
The NPAC Ethernet interface has a problem. The ping utility did not receive a response from the interface associated with the NPAC.
Recovery
Event Details
Table B-18 Event 2000 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - NPAC interface failure
Source
Both primary and secondary servers
Frequency
Trap
Trap ID
15
Trap MIB Name
npacInterfaceFailure
2001
Explanation
The association with the NPAC identified by <NPAC_region_ID> has been disconnected by the user.
Recovery
Examine additional GUI notifications to determine whether the LSMS is retrying the association. Follow the recovery actions described for the GUI notification.
Event Details
Table B-19 Event 2001 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Disconnected
Text
Notify:Sys Admin - NPAC=<PRIMARY|SECONDARY>-<NPAC_region_ID>
Source
Active server
Frequency
Trap
Trap ID
37
Trap MIB Name
lostNPACAssoc
2002
Explanation
The LSMS is not able to confirm the physical connectivity with the NPAC, which is specified in the System field on the GUI or is indicated by <NPAC_region_ID> in the Surveillance notification.
Recovery
Check the physical connection between the LSMS and the NPAC. The problem may be in the network, a router, or both.
Event Details
Table B-20 Event 2002 Details
GUI Notification
Severity
Critical
Text
LSMS Physical Disconnect with NPAC
Text
Notify:Sys Admin - NPAC=<NPAC_region_ID>
Source
Active server
Frequency
Trap
Trap ID
45
Trap MIB Name
failedNPACConnectivity
2003
Explanation
The NPAC (PRIMARY or SECONDARY, as indicated) identified by <NPAC_region_ID> rejected the association because it received a message from the LSMS that failed security checks. This can be due to one of the following:
  • The CMIP departure time is more than five minutes out of synchronization with the NPAC servers.
  • The security key is not valid.
  • The CMIP sequence number is out of sequence (messages must be returned to the NPAC in the same order in which they were received).
Recovery
Do the following:
  1. Log in as lsmsadm to the active server.
  2. Enter the following command to determine what the LSMS system time is:
    $ date
  3. Contact the NPAC administrator to determine what the NPAC time is. If the NPAC time is more than five minutes different from the LSMS time, reset the LSMS system time on both servers and on the administration console using one of the procedures described in “Managing the System Clock”.
  4. After you have verified that the NPAC and LSMS times are within five minutes of each other, cause a different security key to be used by stopping and restarting the regional agent. Enter the following commands, where <region> is the name of the region in which this notification occurred:
    $LSMS_DIR/lsms stop <region> $LSMS_DIR/lsms start <region>
  5. Start the GUI again.
  6. Attempt to reassociate with the NPAC. For information about associating with an NPAC, refer to the Configuration Guide.
  7. If the problem persists, contact Oracle Technical Service.
Event Details
Table B-21 Event 2003 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted by PEER: Access Control Failure
Text
Source
Active server
Frequency
Trap
Trap ID
95
Trap MIB Name
npacRejectedAssocAccessCtrlFail
2004
Explanation
The primary or secondary NPAC, identified by <NPAC_region_ID>, rejected the association because it received data that was not valid.
Recovery
Contact the NPAC administrator.
Event Details
Table B-22 Event 2004 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted by PEER: Invalid Data Received
Text
Source
Active server
Frequency
Trap
Trap ID
96
Trap MIB Name
npacRejectedAssocInvalidData
2005
Explanation
The LSMS has lost association with the primary or secondary NPAC identified by <NPAC_region_ID> because the user aborted the association.
Recovery
Reassociate with the NPAC when the reason for aborting the association no longer exists. For information about associating with an NPAC, refer to the Configuration Guide.
Event Details
Table B-23 Event 2005 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>]-<NPAC_region_ID> Association Aborted by User
Text
Source
Active server
Frequency
Trap
Trap ID
9
Trap MIB Name
npacAbortByUser
2006
Explanation
The LSMS did not receive an association response from the NPAC within the timeout period. The LSMS will attempt the association with the NPAC again after an interval that defaults to two minutes, but can be configured to a different value by Oracle.
Recovery
Determine whether there is a network connection problem and/or contact the NPAC administrator to determine whether the NPAC is up and running.
Event Details
Table B-24 Event 2006 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Bind Timed Out - Auto Retry After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
As soon as condition occurs, and at two-minute intervals as long as condition exists
Trap
Trap ID
100
Trap MIB Name
assocRespNPACTimeout
2007
Explanation
The NPAC association attempt was rejected by the NPAC, and the LSMS was informed to attempt the NPAC association again to the same NPAC host after an interval that defaults to two minutes, but can be configured to a different value by Oracle.
Recovery
No action required; the LSMS will automatically try to associate again.
Event Details
Table B-25 Event 2007 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted by PEER - Auto Retry Same Host After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
Trap
Trap ID
101
Trap MIB Name
assocRejectedRetrySameHost
2008
Explanation
The NPAC association attempt was rejected by the NPAC, and the LSMS was informed to attempt the NPAC association again to the other NPAC host after an interval that defaults to two minutes, but can be configured to a different value by Oracle.
Recovery
Event Details
Table B-26 Event 2008 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>]-<NPAC_region_ID>- Connection Aborted by PEER - Auto Retry Other Host After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
Trap
Trap ID
102
Trap MIB Name
assocRejectedRetryOtherHost
2009
Explanation
A problem exists in the network connectivity. The LSMS will attempt the association with the NPAC again after an interval that defaults to two minutes, but can be configured to a different value by Oracle.
Recovery
Check the network connectivity for errors. Verify the ability to ping the NPAC from the LSMS.
Event Details
Table B-27 Event 2009 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted by PROVIDER - Auto Retry Same Host After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
Trap
Trap ID
103
Trap MIB Name
nwtkProblemRetryNPACAssoc
2010
Explanation
The LSMS received three consecutive responses from the NPAC with a download status of failure from a recovery action request. The LSMS has aborted the association and will attempt to associate again after a retry interval that defaults to five minutes, but can be configured to a different value by Oracle. The LSMS will retry the recovery action after the association is reestablished.
Recovery
Event Details
Table B-28 Event 2010 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted Due to Recovery Failure - Auto Retry After NPAC_RETRY_INTERVAL
Text
Source
Active server
Frequency
Trap
Trap ID
104
Trap MIB Name
lsmsAbortedNPACassocDowRecFail
2011
Explanation
The LSMS has disconnected the association with the NPAC region in question due to the lack of a response to heartbeat messages from the LSMS to the NPAC.
Recovery
Contact My Oracle Support.
Event Details
Table B-29 Event 2011 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Disconnected by Heartbeat
Text
Source
Active server
Frequency
Trap
Trap ID
111
Trap MIB Name
lostNPACAssoc
2012
Explanation
The NPAC (primary or secondary, as indicated) identified by <NPAC_region_ID> rejected the association because of an access control failure. This can be due to one of the following:
  • The OSI Presentation Address is incorrect.
  • The Service Provider ID in the regional configuration file is incorrect.
Recovery
Do the following:
  1. Verify that the correct PSEL, SSEL, TSEL, and NSAP values have been configured for the OSI Presentation Address (for more information, refer to “Viewing a Configured NPAC Component” in the Configuration Guide). If you need to change the values, use the procedure described in “Modifying an NPAC Component” in the Configuration Guide.
  2. Verify that the configured Service Provider ID (SPID) is the same as the SPID assigned by the NPAC. For more information about this configuration file, refer to “Modifying LSMS Configuration Components” in the Configuration Guide.
  3. Verify that the configured NPAC_SMS_NAME is the same as the value assigned by the NPAC (this field is case-sensitive). For more information about this configuration file, refer to “Modifying an NPAC Component” in the Configuration Guide.
  4. Log in as lsmsadm to the active server.
  5. Enter the following command to determine what the LSMS system time is:
    $ date
  6. Contact the NPAC administrator to determine what the NPAC time is. If the NPAC time is more than five minutes different from the LSMS time, reset the LSMS system time on both servers and on the administration console by performing one of the procedures described in “Managing the System Clock”.
  7. After you have verified that the NPAC and LSMS times are within five minutes of each other, cause a different security key to be used by stopping and restarting the regional agent. Enter the following commands, where <region> is the name of the region in which this notification occurred:
    $ $LSMS_DIR/lsms stop <region> $ $LSMS_DIR/lsms start <region>
  8. Start the GUI again.
  9. Attempt to reassociate with the NPAC.
  10. If the problem persists, contact Oracle Technical Service.
Event Details
Table B-30 Event 2012 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Attempt Failed: Access Control Failure
Text
Source
Active server
Frequency
Trap
Trap ID
106
Trap MIB Name
assocRejDueToAccessControl
2014
Explanation
The userInfo value in the cmipUserInfo portion of the NPAC association response CMIP message is not valid.
Recovery
Contact the NPAC administrator to determine why the NPAC is sending an invalid association response.
Event Details
Table B-31 Event 2014 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Attempt Failed: Invalid Data Received
Text
Source
Active server
Frequency
Trap
Trap ID
108
Trap MIB Name
npacConnFailedCMIP
2015
Explanation
The NPAC association was terminated gracefully by the NPAC.
Recovery
According to the NANC specifications, this should never occur; if this message is seen, contact the NPAC administrator for the reason for the association unbind.
Event Details
Table B-32 Event 2015 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Disconnected by NPAC
Text
Source
Active server
Frequency
Trap
Trap ID
109
Trap MIB Name
npacAssocGracefullyTerminated
2018
Explanation
The LSMS was unable to properly resynchronize (with the NPAC) the data that was lost while the LSMS was not associated with the NPAC.
Recovery
Do the following:
  1. Abort the NPAC association (refer to the Configuration Guide).
  2. Attempt to reassociate with the NPAC (refer to the Configuration Guide).
  3. If the reassociation is not successful, contact the NPAC and contact My Oracle Support.
Event Details
Table B-33 Event 2018 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Recovery Failed
Text
None
Source
Frequency
Trap
Trap ID
112
Trap MIB Name
lsmsDataLostBadResynch
2019
Explanation
The LSMS data lost during the resynchronization time was not resynchronized properly with the NPAC.
Recovery
Do the following:
  2. Reestablish the NPAC association (refer to the Configuration Guide).
  3. Determine whether notification 8055 NPAC <PRIMARY|SECONDARY> Recovery Complete is posted. If instead notification 2019 reappears, perform a resynchronization for a period of time starting one hour before the 2019 notification first appeared, using either the GUI (refer to “Resynchronizing for a Defined Period of Time Using the GUI” in the Database Administrator's Guide).
  4. If 2019 continues to appear, contact My Oracle Support.
Event Details
Table B-34 Event 2019 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Recovery Partial Failure
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Recovery Failure
Source
Active server
Frequency
Once , as soon as condition occurs
Trap
Trap ID
113
Trap MIB Name
badNPACresynchTime
2020
Explanation
The LSMS aborted the NPAC association because the LSMS received a message from the NPAC that did not have the correct LSMS key signature.
Recovery
Verify that the correct keys are being used by both the NPAC and the LSMS.
Event Details
Table B-35 Event 2020 Details
GUI Notification
Severity
Critical
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Security Violation. Association Aborted. Retrying
Text
Source
Active server
Frequency
Trap
Trap ID
114
Trap MIB Name
assocAbortedBadKeys
2021
Explanation
An associate retry timer was in effect. The retry attempt was canceled because a GUI user issued an Associate, Abort or Disconnect request. If an Associate request was issued, the association is attempted immediately.
Recovery
No action required; for information only.
Event Details
Table B-36 Event 2021 Details
GUI Notification
Severity
Major
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Automatic Association Retry Canceled
Text
None
Source
Frequency
Trap
Trap ID
122
Trap MIB Name
npacAutoAssociationRetryCanceled
2022
Explanation
Either the LSMS did not receive any response from the NPAC before a timeout expired or the LSMS received a response from the NPAC with a download status of failure from a recovery action request. The NPAC is unable to process the recovery action due to a temporary resource limitation. The LSMS will retry the request for the number of times indicated by <retry_number> with the interval between each retry indicated by <retry_interval> minutes. If recovery is not successful after the indicated number of retries, the LSMS will abort the association and post the following notification:
[Critical]: <Timestamp>  2010
:  NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Aborted Due to Recovery Failure - Auto Retry After NPAC_RETRY_INTERVAL
Recovery
Event Details
Table B-37 Event 2022 Details
GUI Notification
Severity
Major
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Fail/No Response from NPAC Recovery - Auto Retry <retry_number> Times in <retry_interval> Minutes
Text
None
Source
Frequency
Trap
Trap ID
123
Trap MIB Name
npacRecoveryFailureResourceLimit
2023
Explanation
The NPAC association will be down for the specified period of time (from the first time field shown in the notification to the second time field shown in the notification) due to NPAC-scheduled down time.
Recovery
When the scheduled down time is over, manually reestablish the NPAC association. For information about aborting and reestablishing an association, refer to the Configuration Guide.
Event Details
Table B-38 Event 2023 Details
GUI Notification
Severity
Major
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] ScheduleDownTime from [<YYYYMMDDhhmmss>] to [<YYYYMMDDhhmmss>]
Text
None
Source
Frequency
Trap
Trap ID
124
Trap MIB Name
npacAssocPeriodDown
2024
Explanation
An Associate request has been sent to the NPAC after a retry timer expired.
Recovery
Event Details
Table B-39 Event 2024 Details
GUI Notification
Severity
Major
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Timer Expired - Resending Association Request
Text
None
Source
Frequency
Trap
Trap ID
125
Trap MIB Name
npacAssocRequestSentAfterRetryTimer
2025
Explanation
The NPAC association was successfully established.
Recovery
Event Details
Table B-40 Event 2025 Details
GUI Notification
Severity
Cleared
Text
NPAC [<PRIMARY|SECONDARY>-<NPAC_region_ID>] Connection Successfully Established
Text
None
Source
Frequency
Trap
Trap ID
7
Trap MIB Name
npacAssocEstablished
4000
Explanation
The active server has initiated an automatic switchover to the inactive server.
Recovery
Event Details
Table B-41 Event 4000 Details
GUI Notification
Severity
Event
Text
Switchover Initiated
Text
Notify:Sys Admin - Switchover initiated
Source
Active server
Frequency
Once, soon as condition occurs.
Trap
Trap ID
11
Trap MIB Name
switchOverStarted
4001
Explanation
LSMS service has been switched over.
Recovery
Event Details
Table B-42 Event 4001 Details
GUI Notification
Severity
Event
Text
Switchover complete
Text
Notify:Sys Admin - Switchover complete
Source
Active server
Frequency
Trap
Trap ID
12
Trap MIB Name
switchOverCompleted
4002
Explanation
LSMS service could not be switched over to the inactive server; the inactive server was not able to start LSMS service.
Recovery
Event Details
Table B-43 Event 4002 Details
GUI Notification
Severity
Event
Text
Switchover Failed
Text
Notify:Sys Admin - Switchover Failed
Source
Active server
Frequency
Once, as soon as condition occurs.
Trap
Trap ID
13
Trap MIB Name
switchOverFailed
4003
Explanation
This notification indicates that the disk controller <controllerId> is out of service and is affecting shared storage. This notification is only valid on E3000 systems.
controllerId= The specific controller number (either 0 or 1).
Recovery
Contact My Oracle Support for assistance.
Event Details
Table B-44 Event 4003 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Loss of disk on < controllerId>
Source
Either server
Frequency
Every 5 minutes as long as condition exists
Trap
Trap ID
14
Trap MIB Name
diskContrService
4004
Explanation
The Ethernet interface used to connect to the application network has a problem. This interface usually connects to network-connected workstations. The ping utility did not receive a response from the interface associated with the application network.
Recovery
Event Details
Table B-45 Event 4004 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - APP interface failure
Source
Either server
Frequency
Trap
Trap ID
17
Trap MIB Name
appsInterfaceFailure
4005
Explanation
This notification indicates that the Ethernet interface used to connect to the ADMINISTRATION network has a problem.
Recovery
Event Details
Table B-46 Event 4005 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - ADMIN interface faire
Source
Either server
Frequency
Trap
Trap ID
18
Trap MIB Name
adminInterfaceFailure
4006
Explanation
This notification indicates that the system disk has lost synchronization, possibly due to a hardware problem.
driveSpecId= disk drive specification.
Recovery
Event Details
Table B-47 Event 4006 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - < driveSpecId >
Source
Either server
Frequency
Trap
Trap ID
20
Trap MIB Name
systemDiskSynch
4007
Explanation
Database replication has failed.
Recovery
Event Details
Table B-48 Event 4007 Details
GUI Notification
Severity
Critical
Text
DB Repl Err - <dbReplErr>
Text
Notify:Sys Admin - DB repl error
Source
Both servers
Frequency
Every minute as long as condition exists.
Trap
Trap ID
21
Trap MIB Name
dataReplError
4008
Explanation
The database replication process monitor has failed.
Recovery
Event Details
Table B-49 Event 4008 Details
GUI Notification
Severity
Critical
Text
DB Proc Mon Err - <dbMonErr>
Text
Notify:Sys Admin - DB monitor failure
Source
Active server
Frequency
Every five minutes as long as condition exists.
Trap
Trap ID
22
Trap MIB Name
dbMonitorFail
4009
Explanation
The server has an internal disk error.
Recovery
Event Details
Table B-50 Event 4009 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Internal Disk Error
Source
Either server
Frequency
Within five minutes of the condition occurring and at five-minute intervals as long as condition exists
Trap
Trap ID
23
Trap MIB Name
internalDiskError
4010
Explanation
This notification indicates that the hot-spare feature has completed automatic data resynchronization.
Recovery
Event Details
Table B-51 Event 4010 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - < driveSpecId >- < driveSpecId >
Source
Either server
Frequency
Once
Trap
Trap ID
24
Trap MIB Name
hotSparedDataResynch
4011
Explanation
This notification indicates that LSMS database replication is delayed.
Recovery
No action required.
Event Details
Table B-52 Event 4011 Details
GUI Notification
Severity
N/A
Text
DB Repl Info
Text
Notify:Sys Admin - DB repl info
Source
Either server
Frequency
Within five minutes of the condition occurring and every minute thereafter as long as condition exists.
Trap
Trap ID
25
Trap MIB Name
dataReplInfo
4012
Explanation
A process specified by <process_name> is utilizing 40 percent or more of the LSMS’s CPU resource and the <second_ID> indicates a specific instance of the process, as follows:
  • When the <process_name> is eagleagent, the <second_ID> specifies the Common Language Location Indicator (CLLI) of the network element
  • When the <process_name> is npacagent, the <second_ID> specifies the name of the region
  • When the <process_name> is not eagleagent or npacagent, the <second_ID> specifies the process ID (PID) of the process.
Recovery
Because this notification is posted every five minutes as long as the condition exists, you may choose to ignore this notification the first time that it appears. However, if this notification is repeated several times in a row, do one of the following:
  1. If the <process_name> is not npacagent, go to step 4. Otherwise, determine whether the npacagent is still using 40% or more of the CPU resource by entering the following command, where <region> can be optionally specified (it is the name of the region as displayed at the end of the notification text):
    $ ps -eo pid,pcpu,args | grep npacagent | grep <region>
  2. If the npacagent is still using 40% or more of the CPU resource, enter the following commands to stop the npacagent and restart it, where <region> is the name of the NPAC region whose npacagent is using 40% or more of the CPU resource:
    $ cd $LSMS_DIR
    $ lsms stop <region>
    $ lsms start <region>
  3. Repeat step 1. If the npacagent you tried to stop is still using 40% or more of the CPU resource, contact My Oracle Support.
  4. If the <process_name> is not eagleagent, go to step 7. Otherwise, determine whether the eagleagent is still using 40% or more of the CPU resource by entering the following command, where <CLLI> can be optionally specified (it is the name of the network element as displayed at the end of the notification text):
    $ ps -eo pid,pcpu,args | grep eagleagent | grep <CLLI>
  5. If the eagleagent is still using 40% or more of the CPU resource, enter the following commands to stop the eagleagent and restart it, where <CLLI> is the Common Language Location Indicator (CLLI) of the network element whose eagleagent is using 40% or more of the CPU resource:
    $ cd $LSMS_DIR
    $ eagle stop <CLLI>
    $ eagle start <region>
  6. Repeat step 1. If the process you tried to stop is still using 40% or more of the CPU resource, contact My Oracle Support.
  7. If the <process_name> is not eagleagent or npacagent, contact My Oracle Support.
Event Details
Table B-53 Event 4012 Details
GUI Notification
Severity
Major
Text
Process [<process_name>-<second_ID>] Utilizing High Percentage of CPU
Text
Notify:Sys Admin - [<process_name>-<second_ID>]
Source
Either server
Frequency
Trap
Trap ID
26
Trap MIB Name
cpuUtilitzationOver39
4013
Explanation
The LSMS server with default hostname lsmspri has been inhibited.
Recovery
As soon as possible, start the server by performing the procedure described in “Starting a Server”.
Event Details
Table B-54 Event 4013 Details
GUI Notification
Severity
Major
Text
Primary Server Inhibited
Text
Notify:Sys Admin - Primary inhibited
Source
Server with default hostname lsmspri
Frequency
Trap
Trap ID
27
Trap MIB Name
primaryServerInhibited
4014
Explanation
The LSMS server with default hostname lsmssec has been inhibited.
Recovery
Event Details
Table B-55 Event 4014 Details
GUI Notification
Severity
Major
Text
Secondary Server Inhibited
Text
Notify:Sys Admin - Secondary inhibited
Source
Server with default hostname lsmssec
Frequency
Trap
Trap ID
28
Trap MIB Name
secondaryServerInhibited
4015
Explanation
A heartbeat link is down.
Recovery
Event Details
Table B-56 Event 4015 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Heartbeat failure
Source
Both servers
Frequency
Trap
Trap ID
29
Trap MIB Name
heartbeatLinkDown
4016
Explanation
This notification indicates that the Heartbeat 2 link is down.
Recovery
Event Details
Table B-57 Event 4016 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Heartbeat 2 failure
Source
Both server
Frequency
Once
Trap
Trap ID
30
Trap MIB Name
heartbeatLinkTwoDown
4017
Explanation
This notification indicates that the LSMS network configuration is incorrect.
Recovery
Customer or field engineers should:
  • Verify network configuration and network cabling
  • Verify serial configuration and cabling if serial keepalive is configured
  • If the problem persists, contact My Oracle Support
Event Details
Table B-58 Event 4017 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Network setup error
Source
Active server
Frequency
Every 5 minutes
Trap
Trap ID
31
Trap MIB Name
lsmsNtwkConfigError
4018
Explanation
This notification indicates that the LSMS network configuration is not supported or recommended.
Recovery
Event Details
Table B-59 Event 4018 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Network setup unsupp
Source
Active server
Frequency
Every 5 minutes
Trap
Trap ID
32
Trap MIB Name
lsmsNtwkConfigNotSupported
4019
Explanation
This notification indicates that the disk volume specified by diskVolName has exceeded the 95 percent usage threshold.
Recovery
Event Details
Table B-60 Event 4019 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - < diskVolName >
Source
Either server
Frequency
Every 5 minutes
Trap
Trap ID
38
Trap MIB Name
diskVolume95Usage
4020
Explanation
The server’s swap space has exceeded the critical usage threshold (default = 95%).
Recovery
If the problem persists, contact My Oracle Support.
Event Details
Table B-61 Event 4020 Details
GUI Notification
Severity
Critical
Text
Swap space exceeds Critical
Text
Notify:Sys Admin - Swap space Critical
Source
Either server
Frequency
Trap
Trap ID
39
Trap MIB Name
swapSpaceCritical
4021
Explanation
The LSMS application or system daemon whose name has <process_name> as the first 12 characters is not running.
Recovery
No user action is necessary. The Surveillance process automatically restarts the Service Assurance process (sacw) and the sentryd process automatically restarts other processes.
Event Details
Table B-62 Event 4021 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - <process_name> failed
Source
Active server
Frequency
Trap
Trap ID
40
Trap MIB Name
lsmsAppsNotRunning
4022
Explanation
The backup of the LSMS database has completed successfully.
Recovery
Event Details
Table B-63 Event 4022 Details
GUI Notification
Severity
None
Text
Text
DATABASE backup complete
Source
Standby server
Frequency
Trap
Trap ID
41
Trap MIB Name
backupCompleted
4023
Explanation
The backup of the LSMS database has failed.
Recovery
Review backup output to determine why backup failed, correct the problems, and run backup script again manually.
Determine whether the NAS can be reached using the ping command. If the NAS cannot be reached, restart the NAS. To restart the NAS turn the power off, then turn the power on. If the NAS can be reached, contact My Oracle Support for assistance.
Event Details
Table B-64 Event 4023 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - DATABASE backup failed
Source
Standby server
Frequency
Trap
Trap ID
42
Trap MIB Name
backupFailed
4024
Explanation
The primary LSMS server (Server 1A) is not providing the LSMS service.
Recovery
Event Details
Table B-65 Event 4024 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Primary not online
Source
Frequency
Trap
Trap ID
63
Trap MIB Name
primaryServerNotOnline
4025
Explanation
The standby server is not prepared to take over LSMS service.
Recovery
Event Details
Table B-66 Event 4025 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Can't switch to standby
Source
Standby server
Frequency
Trap
Trap ID
64
Trap MIB Name
standbyNotReadyForSwitchover
4026
Explanation
The secondary LSMS server (Server 1B) is currently providing the LSMS service.
Recovery
Event Details
Table B-67 Event 4026 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Secondary online
Source
Frequency
Trap
Trap ID
65
Trap MIB Name
secServerProvidingLSMSService
4027
Explanation
The standby LSMS server cannot determine the availability of the LSMS service on the active server.
Recovery
Determine if the other server is working normally. Also, verify that the heartbeat connections (eth2, eth3, and the serial cable) are connected and functioning properly
Event Details
Table B-68 Event 4027 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - Primary status unknown
Source
Standby server
Frequency
Trap
Trap ID
66
Trap MIB Name
secServerCannotDeterminePrimAvailability
4028
Explanation
This notification indicates an LSMS mirroring inconsistency.
Recovery
Event Details
Table B-69 Event 4028 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - < volume_name >
Source
Either server
Frequency
Every 5 minutes
Trap
Trap ID
169
Trap MIB Name
lsmsMirroringInconsistance
4029
Explanation
This notification indicates that the LSMS filesystem is not writeable.
Recovery
Event Details
Table B-70 Event 4029 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - < fileSystem >
Source
Either server
Frequency
Every 5 minutes
Trap
Trap ID
170
Trap MIB Name
lsmsFilesystemNotWritable
4030
Explanation
The server’s swap space has exceeded the major usage threshold (default = 80%).
Recovery
Event Details
Table B-71 Event 4030 Details
GUI Notification
Severity
Major
Text
Swap Space Warning
Text
Notify:Sys Admin - Swap space warning
Source
Both servers
Frequency
Trap
Trap ID
190
Trap MIB Name
swapSpaceWarning
4031
Explanation
A database replication error that was reported earlier by the 4007 event has now been cleared.
Recovery
No action necessary.
Event Details
Table B-72 Event 4031 Details
GUI Notification
Severity
Cleared
Text
Database Replication cleared - <dbReplErr>
Text
None
Source
Frequency
Trap
Trap ID
195
Trap MIB Name
dataReplClear
4032
Explanation
A database process monitor error that was reported earlier by the 4008 event has now been cleared.
Recovery
Event Details
Table B-73 Event 4032 Details
GUI Notification
Severity
Cleared
Text
Database Replication cleared - <dbMonErr>
Text
None
Source
Frequency
Trap
Trap ID
196
Trap MIB Name
dbMonitorCLear
4033
Explanation
The LSMS database failed count operation, which suggests a corrupt MySQL index.
Recovery
Event Details
Table B-74 Event 4033 Details
GUI Notification
Severity
Critical
Text
Database Corrupt Index
Text
None
Source
Both servers
Frequency
Every 30 minutes.
Trap
Trap ID
200
Trap MIB Name
dbCorruptIndex
4034
Explanation
This notification indicates that the Invalid Snapshot has been detected.
Recovery
Clean Up After Failed or Interrupted Snapshot
Event Details
Table B-75 Event 4034 Details
GUI Notification
Severity
Critical
Text
Invalid Snapshot - <snapName>
Text
Notify:Sys Admin - Invalid Snapshot
Source
Active server
Frequency
Every 30 minutes
Trap
Trap ID
201
Trap MIB Name
snapInvalidErr
4035
Explanation
This notification indicates that the Invalid Snapshot error has been cleared.
Recovery
Event Details
Table B-76 Event 4035 Details
GUI Notification
Severity
Cleared
Text
Invalid Snapshot cleared - <snapName>
Text
Source
Active server
Frequency
Every 30 minutes
Trap
Trap ID
202
Trap MIB Name
snapInvalidClear
4036
Explanation
This notification indicates that the Snapshot is greater than 80% full.
Recovery
Event Details
Table B-77 Event 4036 Details
GUI Notification
Severity
Critical
Text
Full Snapshot - <snapName>
Text
Notify:Sys Admin - Full Snapshot
Source
Active server
Frequency
Every 30 minutes
Trap
Trap ID
203
Trap MIB Name
fullSnapshot
4037
Explanation
This notification indicates that the Snapshot full error is cleared.
Recovery
Event Details
Table B-78 Event 4037 Details
GUI Notification
Severity
Cleared
Text
Full Snapshot cleared - <snapName>
Text
Source
Active server
Frequency
Every 30 minutes
Trap
Trap ID
204
Trap MIB Name
fullSnapshotClear
4038
Explanation
The mate server is down.
Recovery
Event Details
Table B-79 Event 4038 Details
GUI Notification
Severity
Critical
Text
Mate Server Down
Text
Notify:Sys Admin - Mate Server Down
Source
Both servers
Frequency
Trap
Trap ID
205
Trap MIB Name
mateServerDown
4039
Explanation
The mate server is up.
Recovery
No action is required.
Event Details
Table B-80 Event 4039 Details
GUI Notification
Severity
Cleared
Text
Mate Server Up
Text
Notify:Sys Admin - Mate Server Up
Source
Both servers
Frequency
As soon as condition clears
Trap
Trap ID
206
Trap MIB Name
mateServerUp
4100
Explanation
One or more platform alarms in the minor category exists. To determine which minor platform alarms are being reported, see “How to Decode Platform Alarms”. When the active server reports minor platform alarms that originated on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
If you received Event 4100 in response to an snmpget error, contact My Oracle Support to have the NAS snmp daemon stopped and restarted.
Event Details
Table B-81 Event 4100 Details
GUI Notification
Severity
Minor
Text
Minor Platform Alarm [hostname]: <alarm_string>
Text
Notify:Sys Admin - ALM <alarm_string>
Source
Both servers
Frequency
Trap
Trap ID
191
Trap MIB Name
minorPlatAlarmMask
4101
Explanation
All platform alarms in the minor category have been cleared. When the active server reports that all minor platform alarms have cleared on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
Event Details
Table B-82 Event 4101 Details
GUI Notification
Severity
Cleared
Text
Minor Platform Alarms Cleared
Text
Notify:Sys Admin - Minor Plat alrms clear
Source
Both servers
Frequency
Trap
Trap ID
197
Trap MIB Name
minorPlatAlarmClear
4200
Explanation
One or more platform alarms in the major category exists. To determine which major platform alarms are being reported, see “How to Decode Platform Alarms”. When the active server reports major platform alarms that originated on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
Event Details
Table B-83 Event 4200 Details
GUI Notification
Severity
Major
Text
Major Platform Alarm [hostname]: <alarm_string>
Text
Source
Both servers
Frequency
Trap
Trap ID
192
Trap MIB Name
majorPlatAlarmMask
4201
Explanation
All platform alarms in the major category have been cleared. When the active server reports that all major platform alarms have cleared on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
Event Details
Table B-84 Event 4201 Details
GUI Notification
Severity
Cleared
Text
Major Platform Alarms Cleared
Text
Notify:Sys Admin - Major Plat alrms clear
Source
Both servers
Frequency
Once
Trap
Trap ID
198
Trap MIB Name
majorPlatAlarmClear
4300
Explanation
One or more platform alarms in the critical category exists. To determine which critical platform alarms are being reported, see “How to Decode Platform Alarms”. When the active server reports critical platform alarms that originated on the other server, the hostname of the other server is inserted before the alarm string.
Recovery
Event Details
Table B-85 Event 4300 Details
GUI Notification
Severity
Critical
Text
Critical Platform Alarm [hostname]: <alarm_string>
Text
Source
Both servers
Frequency
Once
Trap
Trap ID
193
Trap MIB Name
criticalPlatAlarmMask
4301
Explanation
Recovery
Event Details
Table B-86 Event 4301 Details
GUI Notification
Severity
Cleared
Text
Critical Platform Alarms Cleared
Text
Notify:Sys Admin - Crit Plat alrms clear
Source
Both servers
Frequency
Once
Trap
Trap ID
199
Trap MIB Name
criticalPlatAlarmClear
6000
Explanation
The eagleagent process has been started.
Recovery
Event Details
Table B-87 Event 6000 Details
GUI Notification
Severity
Cleared
Text
Eagleagent <CLLI> Has Been Started
Text
Notify:Sys Admin - <CLLI> started
Source
Active server
Frequency
Trap
Trap ID
1
Trap MIB Name
eagleAgentStarted
6001
Explanation
The eagleagent process has been stopped by the eagle script.
Recovery
Event Details
Table B-88 Event 6001 Details
GUI Notification
Severity
Critical
Text
Eagleagent <CLLI> Has Been Stopped by User
Text
Notify:Sys Admin - <CLLI> norm exit
Source
Active server
Frequency
Trap
Trap ID
2
Trap MIB Name
eagleAgentStoppedbyscript
6002
Explanation
The npacagent for the region indicated by <NPAC_region_ID> has been started.
Recovery
Event Details
Table B-89 Event 6002 Details
GUI Notification
Severity
Cleared
Text
NPACagent Has Been Started
Text
Notify:Sys Admin - <NPAC_region_ID> NPACagent started
Source
Active server
Frequency
Trap
Trap ID
3
Trap MIB Name
NPACAgentStarted
6003
Explanation
The npacagent for the region indicated by <region> has been stopped using the lsms command.
Recovery
No action required; for information only. If you desire to restart the agent, do the following:
  1. Log in to the active server as lsmsadm.
  2. Enter the following commands to start the npacagent where <region> is the name of the NPAC region:
    $ cd $LSMS_DIR
Event Details
Table B-90 Event 6003 Details
GUI Notification
Severity
Critical
Text
NPACAgent Has Been Stopped by User
Text
Notify:Sys Admin - <NPAC_region_ID> norm exit
Source
Active server
Frequency
Trap
Trap ID
4
Trap MIB Name
lsmsCommandStoppedNPACAgent
6004
Explanation
The eagleagent process for the network element identified by <CLLI> has failed. The sentryd process will attempt to restart.
Recovery
No action required; the sentryd process will attempt to restart the eagleagent process.
Event Details
Table B-91 Event 6004 Details
GUI Notification
Severity
Critical
Text
Eagleagent [<CLLI>] Has Failed
Text
Notify:Sys Admin - FAILD: <CLLI>
Source
Active server
Frequency
Trap
Trap ID
74
Trap MIB Name
lsmsEagleAgentFailed
6005
Explanation
The eagleagent process for the network element identified by <CLLI> has been successfully restarted by the sentryd process.
Recovery
No action required.
Event Details
Table B-92 Event 6005 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RECOV: <CLLI>
Source
Active server
Frequency
Trap
Trap ID
75
Trap MIB Name
lsmsEagleAgentRestarted
6006
Explanation
The sentryd process was unable to restart the eagleagent process for the network element identified by <CLLI>.
Recovery
Event Details
Table B-93 Event 6006 Details
GUI Notification
Severity
Critical
Text
Failure Restarting Eagleagent [<CLLI>]
Text
Notify:Sys Admin - RFAILD: <CLLI>
Source
Active server
Frequency
Trap
Trap ID
76
Trap MIB Name
failureToRestartEagleAgent
6008
Explanation
The npacagent process for the region specified by <NPAC_region_ID> has failed. The sentryd process will attempt to restart.
Recovery
No action required; the sentryd process will attempt to restart the npacagent process.
Event Details
Table B-94 Event 6008 Details
GUI Notification
Severity
Critical
Text
NPACagent [<NPAC_region_ID>] Failure
Text
Notify:Sys Admin - FAILD: <NPAC_region_ID> agent
Source
Active server
Frequency
Trap
Trap ID
78
Trap MIB Name
NPACagentForRegionFailure
6009
Explanation
The npacagent process for the region specified by <NPAC_region_ID> has been successfully restarted by the sentryd process.
Recovery
No action required. Any active LSMS GUI processes will automatically reconnect.
Event Details
Table B-95 Event 6009 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RECOV: <NPAC_region_ID> agent
Source
Active server
Frequency
Trap
Trap ID
79
Trap MIB Name
NPACagentForRegionRestarted
6010
Explanation
The sentryd process was unable to restart the npacagent process for the region specified by <NPAC_region_ID>.
Recovery
Event Details
Table B-96 Event 6010 Details
GUI Notification
Severity
Critical
Text
Failure Restarting NPACagent [<NPAC_region_ID>]
Text
Notify:Sys Admin - RFAILD: <NPAC_region_ID> agent
Source
Active server
Frequency
Trap
Trap ID
80
Trap MIB Name
failureToRestartNPACagentRegion
6020
Explanation
The npacagent process has been stopped due to a fault in accessing the regional database.
Recovery
A database error has occurred. Contact My Oracle Support.
Event Details
Table B-97 Event 6020 Details
GUI Notification
Severity
Critical
Text
NPACagent Has Been Shut Down - Database Access Error
Text
Notify:Sys Admin - <NPAC_region_ID> DB error
Source
Active server
Frequency
Trap
Trap ID
189
Trap MIB Name
NPACagentStopRegDBaccessFault
8000
Explanation
The LSMS Surveillance feature is in operation.
Recovery
Event Details
Table B-98 Event 8000 Details
GUI Notification
Severity
None
Text
Text
Keep alive
Source
Frequency
Trap
Trap ID
19
Trap MIB Name
survFeatureOn
8001
Explanation
The network element resynchronization database contains more than 1 million entries.
Recovery
Each day, as part of a cron job, the LSMS trims the resynchronization database so that it contains 768,000 entries. The occurrence of this event means that more than 232,000 transactions have been received since the last cron job. If this event occurs early in the day, contact My Oracle Support.
Event Details
Table B-99 Event 8001 Details
GUI Notification
Severity
Major
Text
ResyncDB Contains 1 Mil Entries
Text
Notify:Sys Admin - ResyncDB 1 Mil
Source
Active server
Frequency
Once
Trap
Trap ID
34
Trap MIB Name
resynchLogMidFull
8003
Explanation
The pending queue, used to hold the transactions to send to the network element (which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text), is over half full.
Recovery
No recovery is required. Informational only.
Event Details
Table B-100 Event 8003 Details
GUI Notification
Severity
Major
Text
EMS Pending Queue Is Half full
Text
Notify:Sys Admin - CLLI=<CLLI>
Source
Active server
Frequency
Trap
Trap ID
43
Trap MIB Name
ensPendingQueueHalfFull
8004
Explanation
The pending queue, used to hold the transactions to send to the network element (which is indicated in the System field on the GUI or whose CLLI has the value that replaces <CLLI> in the Surveillance notification text), is completely full. The association to that EMS will be broken.
Recovery
No manual recovery required. The LSMS will automatically re-establish the association to the EMS and synchronization will take place.
Event Details
Table B-101 Event 8004 Details
GUI Notification
Severity
Critical
Text
EMS Pending Queue Is Full
Text
Source
Active server
Frequency
Trap
Trap ID
44
Trap MIB Name
emsPendingQueueMaxReached
8005
Explanation
There was a data error in a record that prevented the LSMS eagleagent from sending the record to the network element.
Recovery
Both the error and the ignored record are written to the file /var/TKLC/lsms/logs/trace/LsmsTrace.log.<mmdd>, where <mmdd> indicates the month and day the error occurred. Examine the log file for the month and day this error was reported to determine what the error was. Enter the data manually or send it again.
Event Details
Table B-102 Event 8005 Details
GUI Notification
Severity
Minor
Text
Eagleagent <CLLI> Ignoring Record: <DataError>
Text
None
Source
Frequency
Trap
Trap ID
46
Trap MIB Name
eagleAgentIgnoredRecord
8024
Explanation
The Service Assurance agent has started successfully.
Recovery
Event Details
Table B-103 Event 8024 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin
Source
Active server
Frequency
Trap
Trap ID
67
Trap MIB Name
serviceAssuranceAgentStarted
8025
Explanation
Association with the Service Assurance Manager, identified by <Service_Assurance_Manager_Name>, has been established successfully.
Recovery
Event Details
Table B-104 Event 8025 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - <Service_Assurance_Manager_Name>
Source
Active server
Frequency
Trap
Trap ID
68
Trap MIB Name
establishServAssuranceMgrAssoc
8026
Explanation
Association with the Service Assurance Manager, identified by <Service_Assurance_Manager_Name>, has been stopped or disconnected.
Recovery
Contact the Service Assurance system administrator to determine the cause of disconnection, then have Service Assurance system administrator reassociate the Service Assurance Manager to the Service Assurance Agent.
Event Details
Table B-105 Event 8026 Details
GUI Notification
Severity
None
Text
Text
Source
Active server
Frequency
Trap
Trap ID
69
Trap MIB Name
servAssuranceMgrAssocBroken
8027
Explanation
The Service Assurance agent is not currently running.
Recovery
No action required; the Service Assurance agent should be restarted automatically.
Event Details
Table B-106 Event 8027 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin
Source
Active server
Frequency
Trap
Trap ID
70
Trap MIB Name
servAssuranceAgentNotRunning
8030
Explanation
This notification indicates that the LSMS is not able to confirm physical connectivity with the DCM.
Recovery
Event Details
Table B-107 Event 8030 Details
GUI Notification
Severity
Critical
Text
EBDA Physical Connection Lost
Text
Notify:Sys Admin - NE=< NE CLLI > EBDA conn lost
Source
Active server
Frequency
Every 5 minutes
Trap
Trap ID
73
Trap MIB Name
noPhysicalConnectivityToDCM
8037
Explanation
The OSI process has failed. The sentryd process will attempt to restart.
Recovery
No action required; the sentryd process will attempt to restart the failed process.
Event Details
Table B-108 Event 8037 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - FAILD: OSI
Source
Active server
Frequency
Trap
Trap ID
88
Trap MIB Name
osiDaemonFailure
8038
Explanation
The OSI process has been successfully restarted by the sentryd process.
Recovery
No action required. The sentryd process will attempt to restart the npacagent processes for all active regions. Any active LSMS GUI processes will automatically reconnect.
Event Details
Table B-109 Event 8038 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RECOV: OSI
Source
Active server
Frequency
Trap
Trap ID
89
Trap MIB Name
osiDaemonRestarted
8039
Explanation
The sentryd process was not able to restart the OSI process.
Recovery
Event Details
Table B-110 Event 8039 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RFAILD: OSI
Source
Active server
Frequency
Trap
Trap ID
90
Trap MIB Name
osiDaemonRestartFailure
8040
Explanation
The Surveillance feature has detected that the sentryd process is no longer running.
Recovery
No action required; the LSMS HA software will attempt to restart the sentryd process.
Event Details
Table B-111 Event 8040 Details
GUI Notification
Severity
None
Text
Surveillance Notification
Text
Notify:Sys Admin - FAILD: sentryd
Source
Active server
Frequency
Trap
Trap ID
91
Trap MIB Name
sentrydFailure
8041
Explanation
This notification indicates that the surveillance process has detected that the Legacy lddAgent process has restarted and all functionality has resumed.
Recovery
Event Details
Table B-112 Event 8041 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RECOV: lddAgent legacy
Source
Both servers
Frequency
Once, as soon as the condition occurs
Trap
Trap ID
92
Trap MIB Name
IddAgentRestarted
8042
Explanation
This notification indicates that the surveillance process has detected that the SCPMS lddAgent process has restarted and all functionality has resumed.
Recovery
Event Details
Table B-113 Event 8042 Details
GUI Notification
Severity
None
Text
Text
Notify:Sys Admin - RECOV: lddAgent scpms
Source
Both servers
Frequency
Trap
Trap ID
93
Trap MIB Name
scpmsIddAgentRestarted
8044
Explanation
This notification indicates that the LDD SCPMS Confirmation of Arrival message retry attempts have been exhausted. The MQSeries interface is not operational or network connectivity to the remote system is lost.
Recovery
Event Details
Table B-114 Event 8044 Details
GUI Notification
Severity
Critical
Text
LDD SCPMS COA Retry Attempts Exhausted
Text
None
Source
Frequency
Trap
Trap ID
116
Trap MIB Name
scpmsMqSeriesFault
8045
Explanation
This notification indicates that the LDD SCPMS system has not provided a response within the time limit specified by the LDD_SCP_SYSTEM_RESPONSE_TIMEOUT configuration parameter. The SCPMS system is not active.
Recovery
Event Details
Table B-115 Event 8045 Details
GUI Notification
Severity
Critical
Text
LDD SCPMS Response Retry Attempts Exhausted
Text
None
Source
Frequency
Trap
Trap ID
117
Trap MIB Name
scpmsNotActive
8046
Explanation
This notification indicates that the LDD Legacy Confirmation of Arrival message retry attempts have been exhausted.
Recovery
Event Details
Table B-116 Event 8046 Details
GUI Notification
Severity
Critical
Text
Text
None
Source
Frequency
Trap
Trap ID
118
Trap MIB Name
legacyMqSeriesFault
8047
Explanation
This notification indicates that the LDD Legacy system has not provided a response within the time limit specified by the LDD_SCP_SYSTEM_RESPONSE_TOMEOUT configuration parameter. The SCPMS system is not active.
Recovery
Event Details
Table B-117 Event 8047 Details
GUI Notification
Severity
Critical
Text
LDD Legacy Response Retry Attempts Exhausted
Text
None
Source
Frequency
Trap
Trap ID
119
Trap MIB Name
scpmsLegacyNotActive
8048
Explanation
This notification indicates that a connection could not be made to the MQSeries local queue manager. The local queue manager is not started or operational.
Recovery
Event Details
Table B-118 Event 8048 Details
GUI Notification
Severity
Critical
Text
Unable to Connect to Queue Manager:
< queueMgrName >
Text
None
Source
Frequency
Trap
Trap ID
120
Trap MIB Name
mqSeriesQueueManagerNotActive
8049
Explanation
The EMS/NE has rejected the NPANXX GTT creation, deletion, or modification transaction, and the NPANXX value in the transaction could not be determined.
Recovery
Look in the transaction log file, /var/TKLC/lsms/logs/<CLLI>/LsmsTrans.log.MMDD, and locate the NE’s response to the NPANXX GTT command to determine why the command failed. Re-enter the NPANXX GTT data correctly, which will cause the LSMS to try to command again.
Event Details
Table B-119 Event 8049 Details
GUI Notification
Severity
Major
Text
<CLLI>: NPANXX GTT <type_of_operation> Failed
Text
None
Source
Frequency
Trap
Trap ID
126
Trap MIB Name
npanxxGTTValueNotFound
8050
Explanation
The EMS/NE has rejected the NPANXX GTT creation, deletion, or modification transaction for the specified NPANXX value.
Recovery
Event Details
Table B-120 Event 8050 Details
GUI Notification
Severity
Major
Text
<CLLI>: NPANXX GTT <type_of_operation> Failed for NPANXX <NPANXX_value>
Text
None
Source
Frequency
Trap
Trap ID
127
Trap MIB Name
npanxxGTTValueRejected
8051
Explanation
The EMS/NE has rejected the Override GTT creation, deletion, or modification transaction, and the LRN value in the transaction could not be determined.
Recovery
Look in the transaction log file, /var/TKLC/lsms/logs/<CLLI>/LsmsTrans.log.MMDD, and locate the NE’s response to the Override GTT command to determine why the command failed. Re-enter the Override GTT data correctly, which will cause the LSMS to try to command again.
Event Details
Table B-121 Event 8051 Details
GUI Notification
Severity
Major
Text
<CLLI>: Override GTT <type_of_operation> Failed
Text
None
Source
Frequency
Trap
Trap ID
128
Trap MIB Name
overrideGTTValueNotFound
8052
Explanation
The EMS/NE has rejected the Override GTT creation, deletion, or modification transaction for the specified LRN value.
Recovery
Event Details
Table B-122 Event 8052 Details
GUI Notification
Severity
Major
Text
<CLLI>: Override GTT <type_of_operation> Failed for LRN <LRN_value>
Text
None
Source
Frequency
Trap
Trap ID
129
Trap MIB Name
overrideGTTValueRejected
8053
Explanation
The LSMS was not able to complete the automatic synchronization with the EMS/NE. Possible reasons include:
  • The network failed temporarily but not long enough to cause the association with the EMS to fail.
  • The EMS/NE rejected the data because it is busy updating its databases.
Recovery
Verify the connection between the LSMS and the EMS; then reinitialize the MPS. If this notification appears again, perform one of the bulk download procedures in the LNP Database Synchronization User's Guide.
Event Details
Table B-123 Event 8053 Details
GUI Notification
Severity
Major
Text
Short Synchronization Failed
Text
None
Source
Frequency
Trap
Trap ID
131
Trap MIB Name
unableToCompleteAutoResynch
8054
Explanation
The LSMS has started its automatic synchronization with the EMS/NE.
Recovery
Event Details
Table B-124 Event 8054 Details
GUI Notification
Severity
Major
Text
Short Synchronization Started
Text
None
Source
Frequency
Trap
Trap ID
132
Trap MIB Name
autoResynchNEStarted
8055
Explanation
The automatic resynchronization of databases after an outage between the LSMS and the NPAC has completed successfully.
Recovery
Event Details
Table B-125 Event 8055 Details
GUI Notification
Severity
Cleared
Text
Recovery Complete
Text
None
Source
Frequency
Trap
Trap ID
133
Trap MIB Name
dbResynchCompleted
8059
Explanation
The LSMS has completed its automatic synchronization with the EMS/NE.
Recovery
Event Details
Table B-126 Event 8059 Details
GUI Notification
Severity
Cleared
Text
Short Synchronization Complete
Text
None
Source
Frequency
Trap
Trap ID
138
Trap MIB Name
emsShortSynchCompleted
8060
Explanation
The EMS pending queue used to hold the transactions to send to the EMS/NE identified by <CLLI> in the Survellance notification, has fallen sufficiently below the halfway full point.
Recovery
Event Details
Table B-127 Event 8060 Details
GUI Notification
Severity
Cleared
Text
EMS Pending Queue Less Than Half Full
Text
Source
Active server
Frequency
Trap
Trap ID
141
Trap MIB Name
pendingQueueHalfFull
8061
Explanation
The EMS pending queue used to hold the transactions to send to the EMS/NE identified by <CLLI> in the Survellance notification, has fallen sufficiently below the full point.
Recovery
Event Details
Table B-128 Event 8061 Details
GUI Notification
Severity
Cleared
Text
EMS Pending Queue No Longer Full
Text
Source
Active server
Frequency
Trap
Trap ID
142
Trap MIB Name
pendingQueueNotFull
8062
Explanation
This notification indicates that physical connection has been restored with the DCM.
Recovery
Event Details
Table B-129 Event 8062 Details
GUI Notification
Severity
Cleared
Text
EBDA Physical Connection Restored
Text
None
Source
Frequency
Trap
Trap ID
143
Trap MIB Name
dcmConnectionRestored
8063
Explanation
This notification indicates that the connection to the MQSeries local queue manager has been established following an outage.
Recovery
Event Details
Table B-130 Event 8063 Details
GUI Notification
Severity
Cleared
Text
Connected to Queue Manager: < queueMgrName >
Text
None
Source
Frequency
Trap
Trap ID
144
Trap MIB Name
connToMqSeriesQueueMngrRest
8064
Explanation
The specified NPA-NXX is opened for portability starting at the value of the <EffectiveTimestamp> field.
Recovery
Event Details
Table B-131 Event 8064 Details
GUI Notification
Severity
Event
Text
New NPA-NXX: SPID [<SPID>], NPANXX [<NPANXX>], TS [<EffectiveTimestamp>]
Text
None
Source
Frequency
Trap
Trap ID
145
Trap MIB Name
npaNxxOpenedForPortabilityAtTS
8065
Explanation
The first telephone number in the specified NPA-NXX is ported starting at the value of the <EffectiveTimestamp> field.
Recovery
Event Details
Table B-132 Event 8065 Details
GUI Notification
Severity
Event
Text
First use of NPA-NXX: SPID [<SPID>], NPANXX [<NPANXX>], TS [<EffectiveTimestamp>]
Text
None
Source
Frequency
Trap
Trap ID
146
Trap MIB Name
npaNxxPortedAtTS
8066
Explanation
An audit of the network element identified by <CLLI> has begun.
Recovery
Event Details
Table B-133 Event 8066 Details
GUI Notification
Severity
Cleared
Text
Audit LNP DB Synchronization Started
Text
NE <CLLI> Audit started
Source
Active server
Frequency
Trap
Trap ID
147
Trap MIB Name
ebdaAuditActive
8067
Explanation
An audit of the network element identified by <CLLI> has completed successfully.
Recovery
Event Details
Table B-134 Event 8067 Details
GUI Notification
Severity
Cleared
Text
Audit LNP DB Synchronization Completed
Text
NE <CLLI> Audit completed
Source
Active server
Frequency
Trap
Trap ID
148
Trap MIB Name
ebdaAuditSuccess
8068
Explanation
An audit of the network element identified by <CLLI> has failed.
Recovery
Inspect the log file /var/TKLC/lsms/logs/<CLLI>/LsmsTrans.log.MMDD for details as to the cause of the error. After clearing the cause of the error, start the audit again.
Event Details
Table B-135 Event 8068 Details
GUI Notification
Severity
Critical
Text
Audit LNP DB Synchronization Failed
Text
NE <CLLI> Audit failed
Source
Active server
Frequency
Trap
Trap ID
149
Trap MIB Name
ebdaAuditFailure
8069
Explanation
The user aborted an audit of the network element identified by <CLLI> before it had completed.
Recovery
Event Details
Table B-136 Event 8069 Details
GUI Notification
Severity
Cleared
Text
Audit LNP DB Synchronization Aborted
Text
NE <CLLI> Audit aborted
Source
Active server
Frequency
Trap
Trap ID
150
Trap MIB Name
ebdaAuditAbortedByUser
8070
Explanation
A reconcile has started at the completion of an audit.
Recovery
Event Details
Table B-137 Event 8070 Details
GUI Notification
Severity
Cleared
Text
Reconcile LNP DB Synchronization Started
Text
NE <CLLI> Reconcile started
Source
Active server
Frequency
Trap
Trap ID
151
Trap MIB Name
ebdaReconcileActive
8071
Explanation
A reconcile, which was performed at the end of an audit, has completed.
Recovery
Event Details
Table B-138 Event 8071 Details
GUI Notification
Severity
Cleared
Text
Reconcile LNP DB Synchronization Complete
Text
NE <CLLI> Reconcile completed
Source
Active server
Frequency
Trap
Trap ID
152
Trap MIB Name
ebdaReconcileSuccess
8072
Explanation
A reconcile, which was performed at the end of an audit, has failed before it completed.
Recovery
Inspect the log file /var/TKLC/lsms/logs/<CLLI>/LsmsAudit.log.MMDD for details as to the cause of the error. After clearing the cause of the error, start the reconcile again.
Event Details
Table B-139 Event 8072 Details
GUI Notification
Severity
Critical
Text
Reconcile LNP DB Synchronization Failed
Text
NE <CLLI> Reconcile failed
Source
Active server
Frequency
Trap
Trap ID
153
Trap MIB Name
ebdaReconcileFailure
8073
Explanation
The user has stopped a reconcile before it completed.
Recovery
Event Details
Table B-140 Event 8073 Details
GUI Notification
Severity
Cleared
Text
Reconcile LNP DB Synchronization Aborted
Text
NE <CLLI> Reconcile aborted
Source
Active server
Frequency
Trap
Trap ID
154
Trap MIB Name
ebdaReconcileAbortedByUser
8078
Explanation
A bulk download is currently running.
Recovery
Event Details
Table B-141 Event 8078 Details
GUI Notification
Severity
Cleared
Text
Bulk Load LNP DB Synchronization Started
Text
NE <CLLI> Bulk load started
Source
Active server
Frequency
Trap
Trap ID
159
Trap MIB Name
ebdaBulkLoadActive
8079
Explanation
A bulk download has completed successfully.
Recovery
Event Details
Table B-142 Event 8079 Details
GUI Notification
Severity
Cleared
Text
Bulk Load LNP DB Synchronization Complete
Text
NE <CLLI> Bulk load completed
Source
Active server
Frequency
Trap
Trap ID
160
Trap MIB Name
ebdaBulkLoadSuccess
8080
Explanation
A bulk download has failed before it completed.
Recovery
Inspect the log file /var/TKLC/lsms/logs/<CLLI>/LsmsBulkLoad.log.MMDD for details as to the cause of the error. After clearing the cause of the error, start the bulk download again.
Event Details
Table B-143 Event 8080 Details
GUI Notification
Severity
Critical
Text
Bulk Load LNP DB Synchronization Failed
Text
NE <CLLI> Bulk load failed
Source
Active server
Frequency
Trap
Trap ID
161
Trap MIB Name
ebdaBulkLoadFailure
8081
Explanation
The user has stopped a bulk download before it completed.
Recovery
Event Details
Table B-144 Event 8081 Details
GUI Notification
Severity
Cleared
Text
Bulk Load LNP DB Synchronization Aborted
Text
NE <CLLI> Bulk load aborted
Source
Active server
Frequency
Trap
Trap ID
162
Trap MIB Name
ebdaBulkLoadAbortedByUser
8082
Explanation
A user-initiated resynchronization is currently running.
Recovery
Event Details
Table B-145 Event 8082 Details
GUI Notification
Severity
Cleared
Text
Re-sync LNP DB Synchronization Started
Text
NE <CLLI> Re-sync started
Source
Active server
Frequency
Trap
Trap ID
163
Trap MIB Name
ebdaResyncActive
8083
Explanation
A user-initiated resynchronization has completed successfully.
Recovery
Event Details
Table B-146 Event 8083 Details
GUI Notification
Severity
Cleared
Text
Re-sync LNP DB Synchronization Complete
Text
NE <CLLI> Re-sync completed
Source
Active server
Frequency
Trap
Trap ID
164
Trap MIB Name
ebdaResyncSuccess
8084
Explanation
A user-initiated resynchronization has failed before it completed.
Recovery
Inspect the contents of the file /var/TKLC/lsms/logs/<CLLI>/LsmsResync.log.MMDD to determine the cause of the error. After clearing the cause of the error, start the user-initiated resynchronization again.
Event Details
Table B-147 Event 8084 Details
GUI Notification
Severity
Critical
Text
Re-sync LNP DB Synchronization Failed
Text
NE <CLLI> Re-sync failed
Source
Active server
Frequency
Trap
Trap ID
165
Trap MIB Name
ebdaResyncFailure
8085
Explanation
The user has stopped a user-initiated resynchronization before it completed.
Recovery
Event Details
Table B-148 Event 8085 Details
GUI Notification
Severity
Cleared
Text
Re-sync LNP DB Synchronization Aborted
Text
NE <CLLI> Re-sync aborted
Source
Active server
Frequency
Trap
Trap ID
166
Trap MIB Name
ebdaResyncAbortedByUser
8086
Explanation
This notification indicates that the Sprint lddAgent has failed to communicate with the Sprint Legacy System.
Recovery
Event Details
Table B-149 Event 8086 Details
GUI Notification
Severity
None
Text
Text
FAILED:IddAgent legacy
Source
Both servers
Frequency
Trap
Trap ID
167
Trap MIB Name
sprintIddAgentCommFailureLegSys
8087
Explanation
This notification indicates that the Sprint lddAgent has failed to communicate with the Sprint SCPMS System.
Recovery
Event Details
Table B-150 Event 8087 Details
GUI Notification
Severity
None
Text
Text
FAILED:IddAgent scpms
Source
Both servers
Frequency
Trap
Trap ID
168
Trap MIB Name
sprintIddAgentCommFailureScpmsSys
8088
Explanation
A scheduled file transfer has failed.
Recovery
Inspect the error log file/var/TKLC/lsms/logs/aft/aft.log.MMDD for details as to the cause of the error.
Event Details
Table B-151 Event 8088 Details
GUI Notification
Severity
Major
Text
Automatic File Transfer Failure - See Log for Details
Text
Notify:Sys Admin- Auto xfer Failure
Source
Active server
Frequency
Trap
Trap ID
171
Trap MIB Name
automaticFileTransferFeatureFailure
8089
Explanation
An NPA-NXX split activation completed successfully.
Recovery
Event Details
Table B-152 Event 8089 Details
GUI Notification
Severity
Cleared
Text
Activate Split Successful OldNPA=<old_NPA> NewNPA=<new_NPA> NXX=<NXX>
Text
None
Source
Frequency
Trap
Trap ID
10
Trap MIB Name
npaSplitActOk
8090
Explanation
An NPA-NXX split activation failed.
Recovery
Perform and audit and reconcile of NPA Split information at the network element.
Event Details
Table B-153 Event 8090 Details
GUI Notification
Severity
Critical
Text
Activate Split Failed OldNPA=<old_NPA> NewNPA=<new_NPA> NXX=<NXX>
Text
None
Source
Frequency
Trap
Trap ID
172
Trap MIB Name
npaSplitActFailed
8091
Explanation
At least one active NPA-NXX split is past its end date and needs to be deleted.
Recovery
Do the following:
  1. View all split objects (for information, refer to the Database Administrator's Guide) to determine which objects have end dates that have already passed.
  2. Delete the objects whose end dates have passed (for information, refer to the Database Administrator's Guide).
Event Details
Table B-154 Event 8091 Details
GUI Notification
Severity
Major
Text
Active Splits Are Past Their End Dates
Text
None
Source
Frequency
Trap
Trap ID
173
Trap MIB Name
activeSplitsPastEndDates
8092
Explanation
This notification indicates the LDD SCPMS agent is switching from primary to backup SCPMS system.
Recovery
No action required; this notification is for information only.
Event Details
Table B-155 Event 8092 Details
GUI Notification
Severity
Critical
Text
LDD SCPMS Agent Switching from Primary to Backup SCPMS System
Text
None
Source
Frequency
Trap
Trap ID
174
Trap MIB Name
lddScpmsAgentSwitchToBackupScpms
8093
Explanation
This notification indicates the LDD SCPMS agent is switching from backup to primary SCPMS system.
Recovery
Event Details
Table B-156 Event 8093 Details
GUI Notification
Severity
Critical
Text
LDD SCPMS Agent Switching from Backup to Primary SCPMS System
Text
None
Source
Frequency
Trap
Trap ID
175
Trap MIB Name
lddScpmsAgentSwitchFromBackupToPrim
8094
Explanation
This notification indicates the LDD SCPMS current system is primary SCPMS.
Recovery
Event Details
Table B-157 Event 8094 Details
GUI Notification
Severity
Cleared
Text
LDD SCPMS Current System is Primary SCPMS
Text
None
Source
Frequency
Trap
Trap ID
176
Trap MIB Name
lddScpmsPrimary
8095
Explanation
This notification indicates the LDD SCPMS current system is backup SCPMS.
Recovery
Event Details
Table B-158 Event 8095 Details
GUI Notification
Severity
Cleared
Text
LDD SCPMS Current System is Backup SCPMS
Text
None
Source
Frequency
Trap
Trap ID
177
Trap MIB Name
lddScpmsBackup
8096
Explanation
The EMS/NE has rejected the NPANXX Split operation indicated by <operation>, and the NPANXX value in the transaction could not be determined.
Recovery
Look in the transaction log file, /var/TKLC/lsms/logs/<CLLI>/LsmsTrans.log.MMDD, and locate the NE’s response to the NPANXX Split command to determine why the command failed. Delete and re-enter the NPANXX Split data correctly, which will cause the LSMS to try to command again.
Event Details
Table B-159 Event 8096 Details
GUI Notification
Severity
Major
Text
<CLLI>: NPANXX Split <operation> Failed
Text
None
Source
Frequency
Trap
Trap ID
178
Trap MIB Name
EmsNeRejNpaNxxSplitNotDetermined
8097
Explanation
The EMS/NE has rejected the NPANXX Split operation indicated by <operation> for the indicated NPANXX value.
Recovery
Event Details
Table B-160 Event 8097 Details
GUI Notification
Severity
Major
Text
<CLLI>: NPANXX Split <operation> Failed for New NPANXX <NPANXX>
Text
None
Source
Frequency
Trap
Trap ID
179
Trap MIB Name
EmsNeRejectedNpaNxxSplit
8098
Explanation
The LSMS is not able to confirm the physical connectivity with the directly connected query server identified by <hostname>. The problem may be one of the following:
  • Physical connectivity issues between the LSMS and directly connected Query Server.
  • The query server host name is not associated with the appropriate Internet Protocol (IP) address in /etc/hosts file.
  • The Internet Protocol (IP) address specified for the special replication user for the for the query server is incorrect.
  • The proper TCP/IP ports are not open in the firewall(s) between the LSMS and the query servers.
Recovery
  • Check the physical connectivity of the LSMS to the query server.
  • Check that the query server hosts name is associated with corresponding Internet Protocol (IP) addresses in /etc/hosts file.
  • Verify that the IP address for the query server is correct. Display the IP address of all configured query servers by using the $LSMS_TOOLS_DIR/lsmsdb -c queryservers command.
  • Verify that the firewall TCP/IP port configuration is set correctly for both the LSMS and query servers directly connected to the LSMS (refer to Appendix A, “Configuring the Query Server,” of the Configuration Guide for information about port configuration for firewall protocol filtering).
Event Details
Table B-161 Event 8098 Details
GUI Notification
Severity
Major
Text
Query Server <hostname> Physical Connection Lost
Text
Query Server=<hostname> Physical Conn Lost
Source
Active Server
Frequency
As soon as condition occurs, and at five-minute intervals as long as condition exists
SNMP Trap
Trap ID
180
Trap MIB Name
physicalConnectivityWithQueryServerLost
8099
Explanation
The query server identified by <hostname> does not have a replication connection established with the LSMS. The problem may be one of the following:
  • Query server cannot establish a connection with the source.
  • Query server not properly configured to connect to the source.
  • A query that succeeded on the source failed on the query server.
  • The binary log(s) that are needed by the query server to resynchronize itself to its source no longer exist.
  • Data on the query server does not agree with what is on the source when the binary log was started.
  • Replication was stopped at the query server by a user.
Recovery
  1. At the query server, perform the following substeps:
    1. Start the MySQL command line utility on the replica server:
      # cd /opt/mysql/mysql/bin
      # mysql -u root -p
      Enter password:
      <Query Server/s MySql root user password>
    2. Determine whether the query server is running by entering the following command and looking at the Replica_IO_Running and Replica_SQL_Running column values.
      mysql> SHOW REPLICA STATUS \G;
      • If the Replica_IO_Running and Replica_SQL_Running column values show that the replica is not running, verify the query server's /usr/mysql1/my.cnf option file (refer to “MySQL Replication Configuration for Query Servers,” in Appendix A, “Configuring the Query Server,” of the Configuration Guide) and check the error log (/usr/mysql1/<hostname>.err) for messages.
      • If the Replica_IO_Running and Replica_SQL_Running column values show that the replica (query server) is running, enter the following command to verify whether the replica established a connection with the source (LSMS or another query server acting as a source/replica).
        mysql> SHOW PROCESSLIST;
        Find the thread with the system user value in the User column and none in the Host column, and check the State column. If the State column says “connecting to source,” verify that the source hostname is correct, that the DNS is properly set up, whether the source is actually running, and whether it is reachable from the replica (refer to Appendix A, “Configuring the Query Server,” of the Configuration Guide for information about port configuration for firewall protocol filtering if the source and replica are connecting through a firewall).
      • If the replica was running, but then stopped, enter the following command:
        mysql> SHOW REPLICA STATUS;
        Look at the output. This error can happen when some query that succeeded on the source fails on the replica, but this situation should never happen while the replication is active if you have taken a proper snapshot of the source and never modify the data on the replica outside of the replica thread.
  2. However, if this is not the case, or if the failed items are not needed and there are only a few of them, try the following:
    1. First see if there is some stray record in the way on the query server. Understand how it got there, then delete it from the query server database and run start replica.
    2. If the above does not work or does not apply, try to understand if it would be safe to make the update manually (if needed) and then ignore the next query from the LSMS.
    3. If you have decided you can skip the next query, enter one of the following command sequences:
      • To skip a query that uses AUTO_INCREMENT or LAST_INSERT_ID(), enter:
        mysql> SET GLOBAL SQL_REPLICA_SKIP_COUNTER=2;
        mysql> start replica;
        Queries that use AUTO_INCREMENT or LAST_INSERT_ID() take two events in the binary log of the source.
      • Otherwise, enter:
        mysql> SET GLOBAL SQL_REPLICA_SKIP_COUNTER=1;
  3. If you are sure the query server database started out perfectly in sync with the LSMS database, and no one has updated the tables involved outside of the replica thread, contact My Oracle Support so you will not have to do the above steps again.
  4. If all else fails, read the error log, /usr/mysql/<hostname>.err. If the log is big, run the following command on the replica:
    grep -i replica /usr/mysql1/<hostname>.err
    (There is no generic pattern to search for on the source, as the only errors it logs are general system errors. If it can, the source will send the error to the replica when things go wrong.)
    • If the error log on the replica conveys that it could not find a binary log file, this indicates that the binary log files on the source have been removed (purged). Binary logs are periodically purged from the source to prevent them from growing unbounded and consuming large amounts of disk resources. However, if a query server was not replicating and one of the binary log files it wants to read is purged, it will be unable to replicate once it comes up. If this occurs, the query server is required to be reset with another snapshot of data from the source or another query server (see “Reload a Query Server Database from the LSMS” and “Reload a Query Server Database from Another Query Server”).
    • When you have determined that there is no user error involved, and replication still either does not work at all or is unstable, please contact My Oracle Support.
Event Details
Table B-162 Event 8099 Details
GUI Notification
Severity
Major
Text
Query Server <hostname> Replication Connection Lost
Text
Query Server=<hostname> Replication Conn Lost
Source
Active Server
Frequency
SNMP Trap
Trap ID
181
Trap MIB Name
queryServerConnectionWithLsmsLost
8100
Explanation
The SV/NPB storage database has exceeded the configured percent usage threshhold.
Recovery
Event Details
Table B-163 Event 8100 Details
GUI Notification
Severity
Event
Text
SV/NPB Storage Exceeds <%> percent
Text
Notify:Sys Admin - SV/NPB threshold %
Source
Both servers
Frequency
Every 5 minutes after condition occurs
Trap
Trap ID
194
Trap MIB Name
svNpbPercentUsage
8101
Explanation
This event indicates that the SV/NPB storage database usage is below the configured percent usage threshold.
Recovery
Event Details
Table B-164 Event 8101 Details
GUI Notification
Severity
Cleared
Text
SV/NPB storage falls below <%> percent
Text
Notify: Sys Admin - SV/NPB cleared
Source
Both servers
Frequency
Trap
Trap ID
207
Trap MIB Name
svNpbBelowLimit
8102
Explanation
The event number present in the untilClear filter list is cleared. The event number is removed from the untilClear filter list.
Recovery
Event Details
Table B-165 Event 8102 Details
GUI Notification
Severity
Event
Text
<Event number> in the untilClear filter list, event clear received at <%s>
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8103
Explanation
The alarm filter counter has reached its limit; the counter will start again from one.
Recovery
Event Details
Table B-166 Event 8103 Details
GUI Notification
Severity
Event
Text
Counter associated with event <event number> exceeds limit <%s>. Resetting counter.
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8104
Explanation
The event number present in the untilTimeout filter list is cleared. The event number is removed from the untilTimeout filter list.
Recovery
Event Details
Table B-167 Event 8104 Details
GUI Notification
Severity
Event
Text
<Event number> in the untilTimeout filter list, event timeout at <%s>
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8105
Explanation
The log capture started by the user has failed.
Recovery
Event Details
Table B-168 Event 8105 Details
GUI Notification
Severity
Minor
Text
Logs Capture Failed
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8106
Explanation
The MySQL Port has been updated. The LSMS application must be restarted.
Recovery
The application must be restarted. Restart the LSMS application first on the active server and then on the standby server. For more information, refer to the Configuration Guide.
Event Details
Table B-169 Event 8106 Details
GUI Notification
Severity
Event
Text
MySQL Port changed from <%s> to <%s>. LSMS application restart required.
Text
Notify: Sys Admin - LSMS restart required
Source
Active server
Frequency
Trap
Trap ID
208
Trap MIB Name
mysqlPortUpdated
8107
Explanation
The MySQL Port has been updated. The Query Server configuration needs to be updated with the new MySQL port.
Recovery
Configure the Query Server with the updated MySQL port. For more information, refer to the Configuration Guide.
Event Details
Table B-170 Event 8107 Details
GUI Notification
Severity
Event
Text
MySQL Port changed from <%s> to <%s>. Query Server configuration updated required.
Text
Notify: Sys Admin - QS updated required
Source
Active server
Frequency
Trap
Trap ID
209
Trap MIB Name
queryServerResetConfiguration
8108
Explanation
At least one of the connected Query Servers is out of sync, and the binary logs cannot be purged without user confirmation.
Recovery
When the Query Server is out of sync, automatic purging is not possible. To delete all but the last 10 binary logs, log on to the active LSMS server as root and enter the following command:
pruneBinaryLogs -force
Event Details
Table B-171 Event 8108 Details
GUI Notification
Severity
Minor
Text
Automatic purging of binary logs cannot be done. User confirmation required.
Text
Notify: Sys Admin - Purge need confirmation
Source
Both servers
Frequency
Every 45 minutes
Trap
Trap ID
210
Trap MIB Name
purgeConfirmRequired
8109
Explanation
Disk usage is reaching the capacity threshold, and an automatic purge of binary logs is imminent.
Recovery
Event Details
Table B-172 Event 8109 Details
GUI Notification
Severity
Minor
Text
Disk usage reaching <%> percent. Purging of binary logs is imminent.
Text
Notify: Sys Admin - Purging is imminent
Source
Both servers
Frequency
Every 45 minutes
Trap
Trap ID
211
Trap MIB Name
purgeImminent
8110
Explanation
Logs capture has been started by the user.
Recovery
Event Details
Table B-173 Event 8110 Details
GUI Notification
Severity
Cleared
Text
Logs Capture Started
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8111
Explanation
The logs capture started by the user completed successfully.
Recovery
Event Details
Table B-174 Event 8111 Details
GUI Notification
Severity
Minor
Text
Logs Captured Successfully
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8112
Explanation
Syscheck was not able to restart automatically by the cron job.
Recovery
Event Details
Table B-175 Event 8112 Details
GUI Notification
Severity
Event
Text
Failed to restart syscheck services
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8116
Explanation
The HTTP protocol is enabled but secure HTTP (HTTPS) is recommended.
Recovery
For information on configuring the protocols, see Starting a Web-Based LSMS GUI Session.
Event Details
Table B-176 Event 8116 Details
GUI Notification
Severity
Event
Text
HTTP is enabled and it is recommended to use HTTPS.
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8117
Explanation
HTTP is disabled and HTTPS is enabled.
Recovery
No recovery required; only HTTPS is enabled now.
Event Details
Table B-177 Event 8117 Details
GUI Notification
Severity
Event
Text
Only HTTPS is enabled now.
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
8118
Explanation
Both HTTP and HTTPS are enabled, but using only HTTPS is recommended.
Recovery
Event Details
Table B-178 Event 8118 Details
GUI Notification
Severity
Event
Text
Both HTTP and HTTPS are enabled and it is recommended to use HTTPS.
Text
None
Source
Frequency
Trap
Trap ID
None
Trap MIB Name
Additional Trap Information
Trap Id Trap MIB Name Notification Description Trap variables def Retry Interval Severity Event Num GUI Event Text Pair Event Num
25 dataReplInfo This notification indicates that database replication is delayed. eventNbr = Oracle specific unique identifier for event notification. This eventNbr field can be used to reference Oracle documentation. dbReplInfo = Info message from database replication. Every 5 mins event_notif_event 4011 DB Repl Info - %s 0
201 snapInvalidErr This notification indicates that the Invalid Snapshot has been detected. eventNbr = Oracle specific unique identifier for event notification. This eventNbr field can be used to reference Oracle documentation. snapName = Name of the invalid snapshot. Every 30 mins event_notif_critical 4034 Invalid Snapshot - %s 4035
203 snapFullErr This notification indicates that the Snapshot is greater than 80% full. eventNbr = Oracle specific unique identifier for event notification. This eventNbr field can be used to reference Oracle documentation. snapName = Name of the invalid/hanging snapshot. Every 30 mins event_notif_critical 4036 Full Snapshot - %s 4037
Trap Id Trap MIB Name Notification Description Frequency Source Clearing behavior
212 resyncStartTrap The trap is sent by the LSMS to NMS when the LSMS is about to start resynchronization Every time when starting a resynchronization with a NMS /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
213 resyncStopTrap The trap is sent by the LSMS to NMS when resynchronization is complete Every time when a resynchronization with a NMS is complete /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
214 resyncRejectTrap The trap is sent by the LSMS to NMS when a resynchronization request is rejected by LSMS Every time when a resynchronization request is initialized while an existing resynchronization is still being processed /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
215 resyncRequiredTrap The trap is sent by the LSMS to NMS when the LSMS is rebooted or LSMS is started Every time when LSM S is rebooted or restarted /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
216 heartBeatTrap The trap is sent by the LSMS to NMS periodically to indicate that the LSMS is up Per the configured value in second (0, 5-7200), where 0 indicates the heartbeat trap is disabled. /vobs/lsms/apps/snmp/ lsmsSnmpHeartbeatSender.pl None
217 lsmsAlarmTrapV3 The trap will indicate that the following information is for a particular event Every v3 trap message sent to nms will carry this OID /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
218 resyncErrCode errorCode = 0, Resynchronization completed successfully. errorCode = 1, Resynchronization aborted by NMS. errorCode = 2, Resynchronization already in progress for the NMS. errorCode = 3, Resynchronization Aborted, Database error occurred. errorCode = 4, Resynchronization not in progress. Every time when either resyncStopTrap or resyncRejectTrap sent to NMS /vobs/lsms/apps/snmp/ lsmsSNMPResyncHandler.pl None
B.7 Platform Alarms
This section describes the following:
How Platform Alarms Are Reported
Each server runs syscheck periodically and reports any problems found through platform alarms. The severity of platform alarms is one of the following:
  • Critical, reported through event 4300
  • Major, reported through event 4200
  • Minor, reported through event 4100
When one or more problems in a given category has been found, the server reports one corresponding event notification to its Surveillance log and its serial port 3. If the server is not the active server, it also sends the event notification to the active server. The active server reports its own platform events to its own Surveillance log and to its Serial Port 3, and also sends an SNMP trap and displays a GUI notification for either its own platform events or for the non-active server’s platform events.
Each of the events 4100, 4200, and 4300 contain a 16-character hexadecimal bitmasked string that indicates all of the platform events in that category that currently exist. To decode which platform events exist, use the procedure described in “How to Decode Platform Alarms”.
Each time the combination of platform events in a given category changes, a new event is reported. Following is an example of how platform events are reported:
  1. At first, only one major platform event is reported on the standby server. A 4200 event with the alarm number of the event is reported.
  2. One minute later, another platform event exists on the standby server (and the first one still exists). Another 4200 event is reported, with a bitmasked string that indicates both of the platform events that exist.
  3. One minute later, another platform event exists on the standby server (and the previous ones still exist). Another 4200 event is reported, with a bitmasked string that indicates all of the platform events that exist.
  4. One minute later, the first platform event is cleared. Another 4200 event is reported, with a bitmasked string that indicates the two platform events that still exist.
B.7.1 How to Decode Platform Alarms
Use the following procedure to determine all the platform alarms that exist in a given category:
  1. Look in Platform Alarms to see if the alarm number is shown there.
    • If the alarm number matches one of the alarms shown in this table, only one alarm (the one that appears in the table) is being reported and you have completed this procedure.
    • If the alarm number does not match one of the alarms shown in this table, perform the remaining steps of this procedure.
  2. Log in as any user to either server.
  3. Enter the following command to decode the reported hexadecimal alarm string:
    $ /usr/TKLC/plat/bin/almdecode <alarm_number>
    The output displays the information about the alarm category and displays the text string for each of the alarms that is represented by the string. For example, if you enter:
    $ /usr/TKLC/plat/bin/almdecode 3000000000000180
    the following text displays:
    The string alarm value comes from the Major Platform alarm category.
    The following alarms are encoded within the hex string:
    Server Swap Space Shortage FailureServer Provisioning Network Error
B.7.2 Platform Alarms
Platform errors are grouped by category and severity. The categories are listed from most to least severe:
Table B-179 shows the alarm numbers and alarm text for all alarms generated by the MPS platform. The order within a category is not significant. Some of the alarms described are not available with specific configurations.
Table B-179 Platform Alarms
Alarm Codes and Error Descriptor
3000000000000001 – Server fan failure
3000000000000002 - Server Internal Disk Error
3000000000000008 - Server Platform Error
3000000000000010 - Server File System Error
3000000000000020 - Server Platform Process Error
3000000000000080 - Server Swap Space Shortage Failure
3000000000000100 - Server provisioning network error
3000000000001000 - Server Disk Space Shortage Error
3000000000002000 - Server Default Route Network Error
3000000000004000 - Server Temperature Error
3000000000008000 - Server Mainboard Voltage Error
3000000000010000 - Server Power Feed Error
3000000000020000 - Server Disk Health Test Error
3000000000040000 - Server Disk Unavailable Error
3000000000080000 - Device Error
3000000000100000 - Device Interface Error
3000000008000000 - Server HA Keepalive Error
3000000010000000 - DRBD block device can not be mounted
3000000020000000 - DRBD block device is not being replicated to peer
3000000040000000 - DRBD peer needs intervention
3000000400000000 - Multipath device access link problem
3000000800000000 – Switch Link Down Error
3000001000000000 - Half-open Socket Limit
3000002000000000 - Flash Program Failure
3000004000000000 - Serial Mezzanine Unseated
5000000000000001 - Server Disk Space Shortage Warning
5000000000000002 - Server Application Process Error
5000000000000004 - Server Hardware Configuration Error
5000000000000008 - Server RAM Shortage Warning
5000000000000020 - Server Swap Space Shortage Warning
5000000000000040 - Server Default Router Not Defined
5000000000000080 – Server temperature warning
5000000000000100 - Server Core File Detected
5000000000000200 - Server NTP Daemon Not Synchronized
5000000000000400 - Server CMOS Battery Voltage Low
5000000000000800 - Server Disk Self Test Warning
5000000000001000 - Device Warning
5000000000002000 - Device Interface Warning
5000000000004000 - Server Reboot Watchdog Initiated
5000000000008000 - Server HA Failover Inhibited
5000000000010000 - Server HA Active To Standby Transition
5000000000020000 - Server HA Standby To Active Transition
5000000000040000 - Platform Health Check Failure
5000000000080000 - NTP Offset Check Failure
5000000000100000 - NTP Stratum Check Failure
5000000000200000 - SAS Presence Sensor Missing
5000000000400000 - SAS Drive Missing
5000000000800000 - DRBD failover busy
5000000001000000 - HP disk resync
5000000020000000 – Server Kernel Dump File Detected
5000000040000000 – TPD Upgrade Failed
5000000080000000 - Half Open Socket Warning Limit
NOTE: The order within a category is not significant.
B.7.3 Alarm Recovery Procedures
This section provides recovery procedures for the MPS, listed by alarm category and Alarm Code (alarm data string) within each category.
B.7.4 Major Platform Alarms
Major platform alarms involve hardware components, memory, and network connections.
B.7.4.1 3000000000000001 – Server fan failure
Alarm Type: TPD
Description: This alarm indicates that a fan in the EAGLE fan tray in the EAGLE shelf where the E5-APP-B is "jacked in" is either failing or has failed completely. In either case, there is a danger of component failure due to overheating.
Severity: Major
OID: TpdFanErrorNotify 1.3.6.1.4.1.323.5.3.18.3.1.2.1
Alarm ID: TKSPLATMA13000000000000001
Recovery
  1. Run syscheck in Verbose mode to verify a fan failure using the following command:
    [root@hostname1351690497 ~]# syscheck -v hardware fan
    Running modules in class hardware...
             fan: Checking Status of Server Fans.
    *         fan: FAILURE:: MAJOR::3000000000000001 -- Server Fan Failure. This test uses the leaky bucket algorithm.
    *         fan: FAILURE:: Fan RPM is too low, fana: 0, CHIP: FAN
    One or more module in class "hardware" FAILED
    LOG LOCATION: /var/TKLC/log/syscheck/fail_log
  2. Refer to the procedure for determining the location of the fan assembly that contains the failed fan and replacing a fan assembly in the appropriate hardware manual. After you have opened the front lid to access the fan assemblies, determine whether any objects are interfering with the fan rotation. If some object is interfering with fan rotation, remove the object.
  3. Contact My Oracle Support.
B.7.4.2 3000000000000002 - Server Internal Disk Error
This alarm indicates that the server is experiencing issues replicating data to one or more of its mirrored disk drives. This could indicate that one of the server disks has failed or is approaching failure.
Recovery
  1. Run syscheck in Verbose mode.
  2. Contact My Oracle Support and provide the system health check output.
B.7.4.3 3000000000000008 - Server Platform Error
This alarm indicates a major platform error such as a corrupt system configuration or missing files, or indicates that syscheck itself is corrupt.
Recovery
B.7.4.4 3000000000000010 - Server File System Error
This alarm indicates that syscheck was unsuccessful in writing to at least one of the server file systems.
Recovery
  1. Contact My Oracle Support for assistance.
B.7.4.5 3000000000000020 - Server Platform Process Error
This alarm indicates that either the minimum number of instances for a required process are not currently running or too many instances of a required process are running.
Recovery
  1. Contact My Oracle Support for recovery procedures.
B.7.4.6 3000000000000080 - Server Swap Space Shortage Failure
This alarm indicates that the server’s swap space is in danger of being depleted. This is usually caused by a process that has allocated a very large amount of memory over time.
In order for this alarm to clear, the underlying failure condition must be consistently undetected for a number of polling intervals. Therefore, the alarm may continue to be reported for several minutes after corrective actions are completed.
Recovery
B.7.4.7 3000000000000100 - Server provisioning network error
Alarm Type: TPD
Description: This alarm indicates that the connection between the server’s eth01ethernet interface and the customer network is not functioning properly. The eth01 interface is at the upper right port on the rear of the server on the EAGLE backplane.
The interface identified as eth01 on the hardware is identified as eth91 by the software (in syscheck output, for example).
Severity: Major
OID: TpdProvNetworkErrorNotify 1.3.6.1.4.1.323.5.3.18.3.1.2.9
Alarm ID: TKSPLATMA93000000000000100
Recovery
  1. Check the physical network connectivity between the LSMS and the NAS.
  2. Contact My Oracle Support.
B.7.4.8 3000000000001000 - Server Disk Space Shortage Error
This alarm indicates that one of the following conditions has occurred:
  • A file system has exceeded a failure threshold, which means that more than 90% of the available disk storage has been used on the file system.
  • More than 90% of the total number of available files have been allocated on the file system.
  • A file system has a different number of blocks than it had when installed.
Recovery
  1. Run syscheck.
  2. Examine the syscheck output to determine if the file system /var/TKLC/lsms/free is low on space. If it is, continue to the next step; otherwise go to Step 4.
  3. If possible, recover space on the free partition by deleting unnecessary files:
    1. Log in to the server generating the alarm as the root user:
      Login: root
      Password:<Enter root password>
    2. Change to the /var/TKLC/lsms/free directory: # cd /var/TKLC/lsms/free
    3. Confirm that you are in the /var/TKLC/lsms/free directory: # pwd /var/TKLC/lsms/free
    4. When the pwd command is executed, if /var/TKLC/lsms/free is not output, go back to Sub-step b
    5. List files to be deleted and delete them using the rm command
    6. Re-run syscheck
    If the alarm is cleared, the problem is solved. If the alarm is not cleared, go to the next Step.
  4. If the file system mounted on /var/TKLC/lsms/logs is the file system that syscheck is reporting to be low on space, execute the following steps:
      Login: root
    2. Change to the /var/TKLC/lsms/logs directory: # cd /var/TKLC/lsms/logs
    3. Confirm that you are in the /var/TKLC/lsms/logs directory: # pwd /var/TKLC/lsms/logs
    4. When the pwd command is executed, if /var/TKLC/lsms/logs is not output, go back to Sub-step b
    5. Look for files with names matching: logs_(hostname)_(date/timestamp).tar, where (hostname) is replaced by the server’s hostname, and (date/timestamp) is any date or timestamp. # ls logs_'hostname'_*.tar. Any files listed may be safely deleted, so for each file listed in the ls output, execute an rm command: # rm <filename> where <filename> is replaced by the name of the file to be deleted.
    6. Re-run syscheck
  5. Core files can occupy a large amount of disk space and may the cause of this alarm. To collect and remove any core files from the server:
      Login: root
    2. Change directory to /var/TKLC/core and list the core files. # cd /var/TKLC/core # ls -l
    The ls command shown above will list any core files found and then compresses and renames the file, adding a ".gz" extension. If any core files are found, transfer them off the system and save them for examination by Oracle Engineering. Once a copy of a compressed file has been saved, it is safe to delete it from the server.
    1. Re-run syscheck
  6. Execute the following Sub-steps if the file system reported by syscheck is /tmp, otherwise skip to Step 7:
      Login: root
    2. Change to the /tmp directory: # cd /tmp
    3. Confirm that you are in the /tmpdirectory: # pwd /tmp
    4. When the pwd command is executed, if /tmp is not output, go back to Step 5.
    5. Look for possible candidates for deletion: # ls *.iso *.bz2 *.gz *.tar *.tgz *.zip
    6. If any deletable files exist, the output of the ls will show them. For each of the files listed, execute the rm command to delete the file: # rm <filename>
    7. Run syscheck
      If the alarm is cleared, the problem is solved. If the alarm is not cleared, go to Step 4.
    8. Upon a reboot, the system will clean the /tmp directory.
      To reboot the system issue the # shutdown -r now command.
    9. Re-run syscheck
  7. Execute the following steps if the file system reported by syscheck is /var, otherwise skip to Step 10:
      Login: root
    2. Change to the /var/tmp directory: # cd /var/tmp
    3. Confirm that you are in the /var/tmp directory: # pwd, then /var/tmp
    4. When the pwd command is executed, if /var/tmp is not output, go back to Step 5.
    5. Since all files in this directory can be safely deleted, execute the rm * command to delete all files from the directory: # rm -i *.
    6. Re-run syscheck
      If the alarm is cleared, the problem is solved. If the alarm is not cleared, go to Step 10.
  8. Execute the following steps if the file system reported by syscheck is /var/TKLC, otherwise skip to Step 10.
      Login: root
    2. Change to the /var/TKLC/upgrade directory: # cd /var/TKLC/upgrade
    3. Confirm that you are in the /var/TKLC/upgrade directory: # pwd, then /var/TKLC/upgrade
    6. Re-run syscheck
  9. For any other file system, execute the following command, where <mountpoint> is the file system’s mount point: # find <mountpoint> -type f -exec du -k {} \; | sort -nr > /tmp/file_sizes.txt
    This will produce a list of files in the given file system sorted by file size in the file /tmp/file_sizes.txt.
    The find command above may take a few minutes to complete if the given mountpoint contains many files. Do not delete any files unless care certain that they are not needed. Continue to Step 10.
  10. Run savelogs to gather all application logs (see Saving Logs Using the LSMS GUI or Command Line).
  11. Contact My Oracle Support.
B.7.4.9 3000000000002000 - Server Default Route Network Error
This alarm indicates that the default network route of the server is experiencing a problem. Running syscheck in Verbose mode will provide information about which type of problem.
Caution:
When changing the network routing configuration of the server, verify that the modifications will not impact the method of connectivity for the current login session. The route information must be entered correctly and set to the correct values. Incorrectly modifying the routing configuration of the server may result in total loss of remote network access.
Recovery
    The output should indicate one of the following errors:
    • The default router at <IP_address> cannot be pinged.
      This error indicates that the router may not be operating or is unreachable. If the syscheck Verbose output returns this error, go to the next Step.
    • The default route is not on the provisioning network.
      This error indicates that the default route has been defined in the wrong network. If the syscheck Verbose output returns this error, go to Step 3.
    • An active route cannot be found for a configured default route.
      This error indicates that a mismatch exists between the active configuration and the stored configuration. If the syscheck Verbose output returns this error, go to Step 4.
    If the syscheck Verbose output does not indicate one of the errors above, go to step 5.
  2. Perform the following substeps when syscheck Verbose output indicates:
    1. Verify that the network cables are firmly attached to the server, network switch, router, Ethernet switch or hub, and any other connection points.
    2. Verify that the configured router is functioning properly.
      Request that the network administrator verify the router is powered on and routing traffic as required.
    3. Request that the router administrator verify that the router is configured to reply to pings on that interface.
    4. Run syscheck.
      • If the alarm is cleared, the problem is resolved and this procedure is complete.
      • If the alarm is not cleared, go to step 5.
  3. Perform Network Reconfiguration from the Command Line using su - lsmsmgr command. Update the default router.
  4. Contact the Customer Care Center for further assistance. Provide the syscheck output collected in the previous steps.
B.7.4.10 3000000000004000 - Server Temperature Error
Alarm Type: TPD
Description: The internal temperature within the server is unacceptably high.
Severity: Major
OID: TpdTemperatureErrorNotify 1.3.6.1.4.1.323.5.3.18.3.1.2.15
Alarm ID: TKSPLATMA153000000000004000
Recovery
  1. Ensure that nothing is blocking the fan's intake. Remove any blockage.
  2. Verify that the temperature in the room is normal with the following table. If it is too hot, lower the temperature in the room to an acceptable level.
    Table B-180 Server Environmental Conditions
    Ambient Temperature
    Operating: 5 degrees C to 40 degrees C
    Exceptional Operating Limit: 0 degrees C to 50 degrees C
    Storage: -20 degrees C to 60 degrees C
    Ambient Temperature
    Operating: 5° C to 35° C
    Storage: -20° C to 60° C
    Relative Humidity
    Operating: 5% to 85% non-condensing
    Storage: 5% to 950% non-condensing
    Elevation
    Operating: -300m to +300m
    Storage: -300m to +1200m
    Heating, Ventilation, and Air Conditioning
    Capacity must compensate for up to 5100 BTUs/hr for each installed frame.
    Calculate HVAC capacity as follows:
    Determine the wattage of the installed equipment. Use the formula: watts x 3.143 = BTUs/hr
    Be prepared to wait the appropriate period of time before continuing with the next step. Conditions need to be below alarm thresholds consistently for the alarm to clear. The alarm may take up to five minutes to clear after conditions improve. It may take about ten minutes after the room returns to an acceptable temperature before syscheck shows the alarm cleared.
  3. Verify that the temperature in the room is normal. If it is too hot, lower the temperature in the room to an acceptable level.
    Be prepared to wait the appropriate period of time before continuing with the next step. Conditions need to be below alarm thresholds consistently for the alarm to clear. It may take about ten minutes after the room returns to an acceptable temperature before the alarm cleared.
  4. Run syscheck Check to see if the alarm has cleared
    • If the alarm has been cleared, the problem is resolved.
    • If the alarm has not been cleared, continue with the next step.
  5. Run syscheck Check to see if the alarm has cleared
  6. Replace the filter (refer to the appropriate hardware manual).
    Be prepared to wait the appropriate period of time before continuing with the next step. Conditions need to be below alarm thresholds consistently for the alarm to clear. The alarm may take up to five minutes to clear after conditions improve. It may take about ten minutes after the filter is replaced before syscheck shows the alarm cleared.
  7. Run syscheck.
  8. If the problem has not been resolved, contact My Oracle Support.
B.7.4.11 3000000000008000 - Server Mainboard Voltage Error
This alarm indicates that at least one monitored voltages on the server mainboard is not within the normal operating range.
Recovery
B.7.4.12 3000000000010000 - Server Power Feed Error
This alarm indicates that one of the power feeds to the server has failed.
Recovery
  1. Locate the server supplied by the faulty power feed. Verify that all connections to the power supply units are connected securely. To determine where the cables connect to the servers, see the Power Connections and Cables page of the NAS on LSMS E5-APP-B Interconnect.
  2. Run syscheck.
    1. If the alarm is cleared, the problem is resolved.
    2. If the alarm is not cleared, go to the next step.
  3. Trace the power feed to its connection on the power source.
    Verify that the power source is on and that the power feed is properly secured.
  4. Run syscheck.
  5. If the power source is functioning properly and all connections are secure, request that an electrician check the voltage on the power feed.
  6. Run syscheck.
  7. If the problem is not resolved, contact My Oracle Support for assistance.
  8. Run savelogs_plat to gather system information for further troubleshooting, (see Saving Logs Using the LSMS GUI or Command Line), and contact My Oracle Support..
B.7.4.13 3000000000020000 - Server Disk Health Test Error
This alarm indicates that the hard drive has failed or failure is imminent.
Recovery
  1. Immediately contact My Oracle Support for assistance with a disk replacement.
B.7.4.14 3000000000040000 - Server Disk Unavailable Error
This alarm indicates that the smartd service is not able to read the disk status because the disk has other problems that are reported by other alarms. This alarm appears only while a server is booting.
Recovery
  1. Perform the recovery procedures for the other alarms that accompany this alarm.
B.7.4.15 3000000000080000 - Device Error
This alarm indicates that the offboard storage server has a problem with its disk volume filling.
Recovery
B.7.4.16 3000000000100000 - Device Interface Error
This alarm indicates that the IP bond is either not configured or not functioning.
Recovery
B.7.4.17 3000000400000000 - Multipath device access link problem
Alarm Type: TPD
Description: One or more "access paths" of a multipath device are failing or are not healthy, or the multipath device does not exist.
Severity: Major
OID: TpdMpathDeviceProblemNotify1.3.6.1.4.1.323.5.3.18.3.1.2.35
Alarm ID: TKSPLATMA353000000400000000
Recovery
  1. My Oracle Support should do the following:
    1. Check in the MSA administration console (web-application) that correct "volumes" on MSA exist, and read/write access is granted to the blade server.
    2. Check if multipath daemon/service is running on the blade server: service multipathd status. Resolution:
      1. start multipathd: service multipathd start
    3. Check output of "multipath -ll": it shows all multipath devices existing in the system and their access paths; check that particular /dev/sdX devices exist. This may be due to SCSI bus and/or FC HBAs haven't been rescanned to see if new devices exist. Resolution:
      1. run "/opt/hp/hp_fibreutils/hp_rescan -a",
      2. "echo 1 > /sys/class/fc_host/host*/issue_lip",
      3. "echo '- - -' > /sys/class/scsi_host/host*/scan"
    4. Check if syscheck::disk::multipath test is configured to monitor right multipath devices and its access paths: see output of "multipath -ll" and compare them to "syscheckAdm disk multipath - -get - -var=MPATH_LINKS" output. Resolution:
      1. configure disk::multipath check correctly.
B.7.4.18 3000000800000000 – Switch Link Down Error
This alarm indicates that the switch is reporting that the link is down. The link that is down is reported in the alarm. For example, port 1/1/2 is reported as 1102.
Recovery Procedure:
  1. Verify cabling between the offending port and remote side.
  2. Verify networking on the remote end.
  3. If problem persists, contact My Oracle Support to verify port settings on both the server and the switch.
B.7.4.19 3000001000000000 - Half-open Socket Limit
Alarm Type: TPD
Description:This alarm indicates that the number of half open TCP sockets has reached the major threshold. This problem is caused by a remote system failing to complete the TCP 3-way handshake.
Severity: Major
OID: tpdHalfOpenSocketLimit 1.3.6.1.4.1.323.5.3.18.3.1.2.37
Alarm ID: TKSPLATMA37 3000001000000000
Recovery
B.7.4.20 3000002000000000 - Flash Program Failure
Alarm Type: TPD
Description: This alarm indicates there was an error while trying to update the firmware flash on the E5-APP-B cards.
Severity: Major
OID: tpdFlashProgramFailure 1.3.6.1.4.1.323.5.3.18.3.1.2.38
Alarm ID: TKSPLATMA383000002000000000
Recovery
B.7.4.21 3000004000000000 - Serial Mezzanine Unseated
Alarm Type: TPD
Description:This alarm indicates the serial mezzanine board was not properly seated.
Severity: Major
OID: tpdSerialMezzUnseated 1.3.6.1.4.1.323.5.3.18.3.1.2.39
Alarm ID: TKSPLATMA393000004000000000
Recovery
B.7.4.22 3000000008000000 - Server HA Keepalive Error
This alarm indicates that heartbeat process has detected that it has failed to receive a heartbeat packet within the timeout period.
Recovery
  1. Determine if the mate server is currently operating. If the mate server is not operating, attempt to restore it to operation.
  2. Determine if the keepalive interface is operating.
  3. Determine if heartbeart is running (service TKLCha status).
  4. Contact My Oracle Support for assistance.
B.7.4.23 3000000010000000 - DRBD block device can not be mounted
This alarm indicates that DRBD is not functioning properly on the local server. The DRBD state (disk state, node state, or connection state) indicates a problem.
Recovery
B.7.4.24 3000000020000000 - DRBD block device is not being replicated to peer
This alarm indicates that DRBD is not replicating to the peer server. Usually this alarm indicates that DRBD is not connected to the peer server. A DRBD Split Brain may have occurred.
Recovery
  2. Contact My Oracle Support for assistance.
B.7.4.25 3000000040000000 - DRBD peer needs intervention
This alarm indicates that DRBD is not functioning properly on the peer server. DRBD is connected to the peer server, but the DRBD state on the peer server is either unknown or indicates a problem.
Recovery
B.7.5 Minor Platform Alarms
Minor platform alarms involve disk space, application processes, RAM, and configuration errors.
B.7.5.1 5000000000000001 - Server Disk Space Shortage Warning
  • A file system has exceeded a warning threshold, which means that more than 80% (but less than 90%) of the available disk storage has been used on the file system.
  • More than 80% (but less than 90%) of the total number of available files have been allocated on the file system.
Recovery
  1. Run syscheck.
      Login: root
    6. Re-run syscheck
  4. Run savelogs to gather all application logs (see Saving Logs Using the LSMS GUI or Command Line).
  5. Contact My Oracle Support.
B.7.5.2 5000000000000002 - Server Application Process Error
Recovery
  2. If a 3000000000000020 - Server Platform Process Error alarm is also present, execute the recovery procedure associated with that alarm before proceeding.
  3. Log in to the LSMS CLI using root password.
  4. Stop the LSMS application.
  5. Start the LSMS Application.
  6. Capture the log files on both LSMSs (see Saving Logs Using the LSMS GUI or Command Lineand contact My Oracle Support.
B.7.5.3 5000000000000004 - Server Hardware Configuration Error
This alarm indicates that one or more of the server’s hardware components are not in compliance with proper specifications (refer to Application B Card Hardware and Installation Guide.
Recovery
  1. Run syscheck in verbose mode.
B.7.5.4 5000000000000008 - Server RAM Shortage Warning
This alarm indicates one of two conditions:
  • Less memory than the expected amount is installed.
  • The system is swapping pages in and out of physical memory at a fast rate, indicating a possible degradation in system performance.
This alarm may not clear immediately when conditions fall below the alarm threshold. Conditions must be below the alarm threshold consistently for the alarm to clear. The alarm may take up to five minutes to clear after conditions improve.
Recovery
B.7.5.5 5000000000000020 - Server Swap Space Shortage Warning
This alarm indicates that the swap space available on the server is less than expected. This is usually caused by a process that has allocated a very large amount of memory over time.
Recovery
B.7.5.6 5000000000000040 - Server Default Router Not Defined
This alarm indicates that the default network route is either not configured or the current configuration contains an invalid IP address or hostname.
Caution:
When changing the server’s network routing configuration it is important to verify that the modifications will not impact the method of connectivity for the current login session. It is also crucial that this information not be entered incorrectly or set to improper values. Incorrectly modifying the server’s routing configuration may result in total loss of remote network access.
Recovery
  1. To define the default router:
    1. Obtain the proper Provisioning Network netmask and the IP address of the appropriate Default Route on the provisioning network. These are maintained by the customer network administrators.
    2. Log in to the LSMS CLI from lsmspri server with username root and run su - lsmsmgr
    3. Select Network Configuration Menu, from the LSMS Configuration Menu
    4. Select Network Reconfiguration Menu from the Network Configuration Menu. The following warning appears:
      WARNING: This action is service impacting. Are you sure?
    5. Chose yes. This displays the configuration screen. See the Configuration Guide for Initial Configuration information.
    6. Do the configuration.
    7. Exit from the lsmsmgr menu.
    8. Run syscheck again. If the alarm has not been cleared, go to Sub-step j.
    9. Run savelogs to gather all application logs.
    10. Contact My Oracle Support.
B.7.5.7 5000000000000080 – Server temperature warning
Alarm Type: TPD
Description: This alarm indicates that the internal temperature within the server is outside of the normal operating range. A server Fan Failure may also exist along with the Server Temperature Warning.
Severity: Minor
OID: tpdTemperatureWarningNotify 1.3.6.1.4.1.323.5.3.18.3.1.3.8
Alarm ID: TKSPLATMI85000000000000080
Recovery
  2. Verify that the temperature in the room is normal. If it is too hot, lower the temperature in the room to an acceptable level.
    Table B-181 Server Environmental Conditions
    Ambient Temperature
    Relative Humidity
    Elevation
  4. Run syscheck to see if the alarm has cleared
  5. Replace the filter (refer to the appropriate hardware manual).
    Be prepared to wait the appropriate period of time before continuing with the next step. Conditions need to be below alarm thresholds consistently for the alarm to clear. It may take about ten minutes after the filter is replaced before the alarm cleared.
  6. Run syscheck to see if the alarm has cleared
    • If the alarm has not been cleared, contact My Oracle Support and provide the system health check output.
B.7.5.8 5000000000000100 - Server Core File Detected
This alarm indicates that an application process has failed and debug information is available.
Recovery
  2. Run savelogs to gather system information (see Saving Logs Using the LSMS GUI or Command Line).
B.7.5.9 5000000000000200 - Server NTP Daemon Not Synchronized
This alarm indicates that the NTP daemon (background process) has been unable to locate a server to provide an acceptable time reference for synchronization.
Severity: Minor
Alarm ID: TKSPLATMI10
Recovery
B.7.5.10 5000000000000400 - Server CMOS Battery Voltage Low
The presence of this alarm indicates that the CMOS battery voltage has been detected to be below the expected value. This alarm is an early warning indicator of CMOS battery end-of-life failure which will cause problems in the event the server is powered off.
Recovery
B.7.5.11 5000000000000800 - Server Disk Self Test Warning
A non-fatal disk issue (such as a sector cannot be read) exists.
Recovery
B.7.5.12 5000000000001000 - Device Warning
This alarm indicates that either a snmpget cannot be performed on the configured SNMP OID or the returned value failed the specified comparison operation.
Recovery
B.7.5.13 5000000000002000 - Device Interface Warning
This alarm can be generated by either an SNMP trap or an IP bond error. If syscheck is configured to receive SNMP traps, this alarm indicates that a SNMP trap was received with the set state. If syscheck is configured for IP bond monitoring, this alarm can mean that a replica device is not operating, a primary device is not active, or syscheck is unable to read bonding information from interface configuration files.
Recovery
B.7.5.14 5000000000004000 - Server Reboot Watchdog Initiated
This alarm indicates that the server has been rebooted due to a hardware watchdog.
Recovery
    This condition should never happen.
B.7.5.15 5000000000008000 - Server HA Failover Inhibited
This alarm indicates that the server has been inhibited and HA failover is prevented from occurring.
Recovery
B.7.5.16 5000000000010000 - Server HA Active To Standby Transition
This alarm indicates that the server is in the process of transitioning HA state from Active to Standby.
Recovery
B.7.5.17 5000000000020000 - Server HA Standby To Active Transition
This alarm indicates that the server is in the process of transitioning HA state from Standby to Active.
Recovery
B.7.5.18 5000000000040000 - Platform Health Check Failure
This alarm indicates a syscheck configuration error.
Recovery
B.7.5.19 5000000000080000 - NTP Offset Check Failure
This alarm indicates that time on the server is outside the acceptable range or offset from the NTP server. The alarm message provides the offset value of the server from the NTP server and the offset limit set for the system by the application.
Alarm Type: TPD
Severity: Minor
Alarm ID: TKSPLATMI20
Recovery
B.7.5.20 5000000000100000 - NTP Stratum Check Failure
This alarm indicates that NTP is syncing to a server, but the stratum level of the NTP server is outside the acceptable limit. The alarm message provides the stratum value of the NTP server and the stratum limit set for the system by the application.
Recovery
B.7.5.21 5000000020000000 – Server Kernel Dump File Detected
Alarm Type: TPD
Description: This alarm indicates that the kernel has crashed and debug information is available.
Severity: Minor
OID: 1.3.6.1.4.1.323.5.3.18.3.1.3.30
Alarm ID: TKSPLATMI305000000020000000
Recovery
B.7.5.22 5000000040000000 – TPD Upgrade Failed
Alarm Type: TPD
Description: This alarm indicates that a TPD upgrade has failed.
Severity: Minor
OID: tpdServerUpgradeFailDetectedNotify 1.3.6.1.4.1.323.5.3.18.3.1.3.31
Alarm ID: TKSPLATMI315000000040000000
Recovery
  1. Run the following command to clear the alarm.
    /usr/TKLC/plat/bin/alarmMgr –clear TKSPLATMI31
B.7.5.23 5000000080000000 - Half Open Socket Warning Limit
Alarm Type: TPD
Severity: Minor
OID: tpdHalfOpenSocketWarningNotify1.3.6.1.4.1.323.5.3.18.3.1.3.32
Alarm ID: TKSPLATMI325000000080000s000
Recovery
  1. Run syscheck.
  2. Contact the Customer Care Center and provide the system health check output.
B.7.5.24 5000000000200000 - SAS Presence Sensor Missing
This alarm indicates that the server drive sensor is not working.
Recovery
  1. Contact My Oracle Support for assistance with a replacement server.
B.7.5.25 5000000000400000 - SAS Drive Missing
This alarm indicates that the number of drives configured for this server is not being detected.
Recovery
  1. Contact My Oracle Support to determine if the alarm is caused by a failed drive or failed configuration.
B.7.5.26 5000000000800000 - DRBD failover busy
This alarm indicates that a DRBD sync is in progress from the peer server to the local server. The local server is not ready to bethe primary DRBD node because its data is not current.
Recovery
  1. Wait for approximately 20 minutes, then check if the DRBD sync has completed. A DRBD sync should take no more than 15 minutes to complete.
  2. If the alarm persists longer than this time interval, contact My Oracle Support for assistance.
B.7.5.27 5000000001000000 - HP disk resync
This alarm indicates that the HP disk subsystem is currently resyncing after a failed or replaced drive, or after another change in the configuration of the HP disk subsystem. The output of the message will include the disk that is resyncing and the percentage complete. This alarm eventually clears after the resync of the disk is completed. The time to clear is dependant on the size of the disk and the amount of activity on the system..
Recovery
  2. If the percent recovering is not updating, wait at least 5 minutes between subsequent runs of syscheck, then contact My Oracle Support with the syscheck output.
B.7.6 Saving Logs Using the LSMS GUI or Command Line
During some corrective procedures, it may be necessary to provide Oracle Communications with information about the LSMS for help in clearing an alarm. These log files are used to aid My Oracle Support when troubleshooting the LSMS.
Use the following procedure to save logs using menu selections from the LSMS GUI.
  1. Log in to the User Interface screen of the LSMS GUI (see Starting a Web-Based LSMS GUI Session).
  2. From the menu, select Logs>Capture Logs.
    img/t_savelogs.jpg
  3. Select the number of days for which you want to capture the logs, as well as the specific logs, and click OK.
  4. To capture logs from the Command Line, enter the following command: /usr/TKLC/plat/sbin/savelogs_plat
