2 LSMS Overview
This chapter provides an overview of LSMS system architecture, proactive termination and re-establishment of LSMS connectivity, hardware and software design features that provide high availability of the LSMS, and third-party and Oracle software components used by the LSMS.
2.1 Introduction
The LSMS is a secure and reliable Local Number Portability (LNP) system that enables customers to administer their LNP data in a central place. The LSMS provides the following functions:
Receives LNP data from Number Portability Administration Centers (NPACs)
Enables customers to enter locally provisioned data such as Override Global Title Translation (OGTT) data
Forwards all NPAC and locally provisioned data to up to eight EAGLE systems
For more information about the LNP functions provided by the LSMS, refer to Database Administrator's Guide and LNP Database Synchronization User's Guide.
This chapter provides an overview of:
Proactive termination and re-establishment of LSMS connectivity
Hardware and software design features that provide high availability of the LSMS
Third-party and Oracle software components used by the LSMS
For additional information about the hardware, refer to Application B Card Hardware and Installation Guide.
2.2 LSMS Connectivity
The main function of the LSMS is to provision LNP data through the ELAP to the EAGLE. To perform this task, the LSMS maintains active connections with one or more NPAC region servers and one or more EAGLE nodes. While it is the goal of the LSMS to maintain active connections to each NPAC server and EAGLE node as nearly full-time as possible, the more important goal is to reliably forward the data from the NPAC to the EAGLE as quickly as possible. To that end, a number of protective problem detection and recovery mechanisms are built into the LSMS design. Several of these protections actually allow for the termination of application connectivity in order to gracefully restore full connectivity and guarantee total recovery of data.
The performance of the LSMS is based on network connectivity that meets a Quality of Service expectation. The expectations by Oracle for network Quality of Service are as follows:
- Network RTT latency of <= 70ms and network loss due to network error <= 0.1%
OR
- Network RTT latency of <= 120ms and network loss due to network error <= 0.01%
In the following situations, the LSMS proactively terminates and re-establishes application connectivity with the NPAC and EAGLE nodes:
- If the LSMS detects network level connectivity failures with either the NPAC or EAGLE, the respective LSMS processes terminate the socket level connection and then reconnect. This disconnect and reconnect occurs in a matter of seconds. Built in resynchronization mechanisms ensure data recovery. The data transmission is delayed by the time required to disconnect and reconnect, but the execution of the recovery procedures prevents data loss.
- If the LSMS detects critical internal errors that would cause system outages, the LSMS processes are designed to terminate and allow the LSMS
sentryprocess to restart them. This is only done for significant internal errors that jeopardize internal LSMS communications. Once thesentryprocess restarts the LSMS processes, resynchronization provides full data recovery.
2.3 LSMS Hardware Overview
Table 2-1 provides an overview of LSMS hardware.
Table 2-1 LSMS Hardware Components
| Qty | Hardware Item | For more detail, see: |
2 |
E5-APP-B-02 cards (P/N 870-3096-02), one for each LSMS server; each card includes the following components:
LSMS runs on E5-APP-B cards with Oracle Communications Tekelec Platform (TPD) 7 (64 bit). |
Application B Card Hardware and Installation Guide |
1 |
E5-APP-B-02 card (P/N 870-3096-02) for Oracle Communications LSMS Network Attached Storage (NAS) NAS runs on an E5-APP-B card with TPD 7 (64 bit). |
Table 2-2 LSMS Hardware Components
| Qty | Hardware Item | For more detail, see: | To replace, see: |
2 |
Tekelec 1100 AS main unit; each unit has the following cards added during manufacturing:
Each Tekelec 1100 AS main unit has 8 gigabytes of Random Access Memory (RAM) installed and available. |
Tekelec 1100 Application Server Hardware Manual |
1 |
Network Attached Storage (NAS) 1 |
Contact the Tekelec Customer Care Center. |
1 |
Breaker panel (for DC version only) |
2 |
Power Distribution Units (for AC version only) |
E5-APP-B Card LEDs
This section describes the LEDs found on the front face of the E5-APP-B card.
Figure 2-1 shows the E5-APP-B card LEDs on the front panel
Figure 2-1 E5-APP-B Card LEDs
The following light-emitting diode (LED) status indicators can be found on the E5-APP-B card:
- One Server Status indicator (A)
- Four E-Net link and Active LED status indicators (B)
- Two drive module status indicators (C)
- One Card Eject status indicator (D)
Table 2-3 E5-APP-B LED Table
| LED Name | HW/SW Controlled | Description |
| Server Status | SW |
Solid Red - Server is halted Flashing Red - Server is booting Solid Amber - TKLC configuration beginning Solid Green - TPD loaded/operational state Flashing Green - Server is shutting down |
| Drive 1 Status | SW/HW |
HW: Flashing Green - Drive activity SW: Flashing Red - Impending drive removal SW: Steady red - Drive ready for removal |
| Drive 2 Status | SW/HW |
| Eject Status | SW |
Red - Card ready for extraction Flashing Red - Card preparing for extraction Off - Card is not ready for extraction |
| Act LED A1 | HW | Flashing Green - Link Activity |
| Act LED A2 | HW | Flashing Green - Link Activity |
| Act LED B1 | HW | Flashing Green - Link Activity |
| Act LED B2 | HW | Flashing Green - Link Activity |
| Link LED A1 | HW |
Green - 10/100 Link Speed Amber - 1000 Link Speed |
| Link LED A2 | HW |
| Link LED B1 | HW |
| Link LED B2 | HW |
NAS Overview
LSMS uses NAS on E5-APP-B for network backup of the system logs, application logs, and databases.
- Hardware Modifications
The E5-APP-B NAS uses a two-drive RAID configuration to save the LSMS logs and database. The E5-APP-B NAS uses the TPD 7 OS.
- Keys Exchange
The key exchange feature provided by TPD is used to exchange keys between LSMS and NAS. This feature facilitates user access to NAS from LSMS and to LSMS from NAS without providing a user ID and password.
- Backup
Both manual and automatic backup are supported. The LSMS interface is used to initiate the manual backup. The automatic backup is scheduled at 23:55 and cannot be rescheduled. A maximum of 4 backups are retained on NAS.
- Class Type for Storage Data
The class type of data must be known before storing the data. The class type can be defined specific to the server being backed up, or it can be files/data to be backed up on different servers based on the state of the system. For example, 'database' can be used to back up the database regardless of which server is performing the back up. The class types available are:
- logs
- DB
- lsmspri
- lsmssec
- logs_lsmspri
- logs_lsmssec
- Restore
You have the option to restore the backups stored on NAS to LSMS. The restore operation is performed on the LSMS server.
- Alarms
The NAS sends SNMP traps to LSMS, which in turn raises an alarm on LSMS. Multiple alarms can be raised simultaneously, which are triggered upon failure of a service. The NAS monitors two services:
- Free space
The free space service monitors the available space on a mounted device (/Volumes), and sends an alert when the free space is less than 5%.
- RAID
The RAID service monitors RAID set degradation and rebuilds.
An alarm is cleared when a service makes the state transition from failure to success, if a corresponding alarm was previously sent.
- Free space
- Login
After configuring NAS with LSMS, you can log into it by using the
ssh backupservercommand or theminicom nascommand from the LSMS command line interface.
2.4 LSMS Software Overview
Figure 2-2 shows the layered organization of third party and Oracle application software used in the LSMS system. For more information about the LSMS applications, see LSMS Applications.
Figure 2-2 Software Allocation on the LSMS Platform
Following are descriptions of the various software elements by layer.
2.4.1 Operating System Layer
The following elements appear in the Operating System Layer.
TPD is the operating system used for LSMS on E5-APP-B. The TPD software is installed on one internal disk drive and mirrored to a second internal disk for each server.
Redundant Array on Inexpensive Disks (RAID)
The TPD uses Linux RAID for monitoring disks and recovery from disk problems. RAID provides the following benefits:
Redundancy
Recoverability from hard-disk crashes
2.4.2 Base Platform Software
Following are the elements of the base platform software.
OSI Stack
This package implements the OSI protocol to allow communications between the LSMS and the NPACs.
LSMS HA
LSMS High Availability (HA) is software for a two-node cluster that provides automated switchover from an active server to a standby server when a server or monitored application experiences a failure. In the LSMS, the two servers are peers: either server can act as the active server (although only one server at a time can be the active server). When either automatic or manual switchover causes the standby server to become the active server, it can continue to be the active server until another switchover is needed.
After switchover, the state of the previously active server is UNINITIALIZED "INHIBITED". As soon as possible, you need to perform the procedure described in Starting a Server to return the state of that server to STANDBY so that it is available when switchover is needed again.2.4.3 Support/Base Utilities Components
The following elements make up the Support/Base software utilities.
Apache
The Apache process (httpd) is a Web server. When the optional IP User Interface feature is enabled, theThe Apache process serves the GUI based on Java™ 1.7 technology to client browsers.
MySQL
The MySQL 5.6.31 database was selected for the LNP database to store all the LNP and service provider data. This database consists of a runtime application programming interface (API) and data files. The data files are organized as follows:
One database that stores locally provisioned data
One database for each supported NPAC region
A resynchronization database that is used for automatic resynchronizations with network elements; this database can store up to one million data objects
Whenever the two LSMS servers are in active/standby mode, all databases are replicated between the two servers, with the active server acting as the source and the standby server acting as the replica.
SSH/SSL
SSH/SSL is a robust, commercial-grade, and full-featured toolkit that implements the security and network encryption.
SSH/SSL provides secure data transmission through encryption keys. Encryption is required for the connection between the NPAC and the LSMS. The LSMS has a key for each NPAC that it services. For more information about keys, refer to the Configuration Guide.
2.4.4 LSMS Applications
The LSMS applications work together as shown below.
Figure 2-3 LSMS Applications
The LSMS applications provide the following functions:
Local Services Manager
The Local Services Manager (lsman) is responsible for providing an interface between the Local GUI and the web-based GUIs and other LSMS processes. It acts as a gateway to the GUIs for processes (EBDA, Report Manager, and NPAC agents) that do not have direct access to the GUI, using Extensible Markup Language (XML) messages to communicate.
The Local Services Manager also manages how many users can be running simultaneously. The maximum number of users allowed on the LSMS system is eight. A user is defined as a GUI session.
A local GUI
A web-based GUI
A running lsmsclaa application instance. An lsmsclaa application instance provides a command-line interface that can be used by a script or by entering commands on a keyboard. For more information, see LSMS Applications and Overview of LSMS Application Commands Entered at the Command-Line Prompt.
The Support for Additional Users optional feature enables you to have a maximum of 25 simultaneous users.
If you attempt to exceed the maximum allowable number of GUI sessions, an error message displays. For example, if you do not have the optional Support for Additional Users feature enabled and you start LSMS GUI sessions on eight different terminals and then attempted to start a ninth GUI session on another terminal, the following error message displays stating that the maximum number of users had been reached:
Maximum number of users reached.
Local Data Manager
The Local Data Manager (supman) is responsible for:
Provisioning of LSMS configuration information and local data
Communicating with the GUIs using XML messages
Broadcasts all locally provisioned LNP data updates using a Reliable Multicast Transport Protocol (RMTP II) multicast mechanism on a single channel
Updating the resynchronization database with locally provisioned data to facilitate automatic resynchronization with Element Management Systems (EMSs) at the supported network elements
NPAC Agents
The NPAC Agent application (npacagent) is responsible for:
Connecting with a single NPAC system using the Q.3 protocol and providing all functions required by published NPAC standards
Broadcasting all its updates using the RMTP II multicast mechanism over one broadcast channel
Communicating with the GUIs through the Local Services Manager
One instance of the npacagent process exists for each enabled NPAC region.
EAGLE Agents
The EAGLE Agent application (eagleagent) is responsible for:
Subscribing to the broadcast channels to receive all NPAC and local data updates
Connecting with a single EAGLE node using the High Speed Operations Protocol (HSOP) and forwarding LNP updates to the EAGLE
Filtering LNP data based on the provisioned filter information before forwarding it to the EAGLE (for more information, refer to the Database Administrator's Guide)
Performing automatic resynchronization with an EAGLE node upon connection establishment (for more information, refer to the LNP Database Synchronization User's Guide)
One instance of the eagleagent process exists for each supported EAGLE node.
RMTPManager
The RMTPManager (rmtpmgr) is responsible for facilitating the reliable multicast mechanism that allows LNP data updates to reach every EAGLE agent. It acts as a top node in an RMTP broadcast tree. A maximum of 9 broadcast channels exists (up to 8 channels for NPAC agents and 1 for the Local Data Manager).
RMTPAgent
The RMTPAgent (rmtpagent) is responsible for keeping the broadcast mechanism flowing even when no EAGLE agents are running. The RMTPAgent subscribes to all (up to 9) broadcast channels.
Local GUI
The Local GUI application is responsible for providing a graphical user interface to allow operation of the LSMS by users who are logged into the LSMS administration console or a network-connected workstation through which they have made a telnet connection to the LSMS. Multiple instances of the Local GUI can exist.
Web-Based GUI
The Web-based GUI application runs outside of the LSMS system on a client platform. It provides an IP-based GUI to operate the LSMS and has the same appearance and functionality as the local GUI. Multiple instances of the Web-based GUI can exist.
Report Manager
The Report Manager (reportman) is responsible for producing reports on demand. It can produce up to 10 reports simultaneously.
EBDA
The Enhanced Bulk Download and Audit process (ebda) is responsible for providing the capability of performing audits, reconciles, bulk loads and user-initiated resynchronizations of an EAGLE LNP database. Multiple instances of the ebda process can exist for different EAGLE nodes.
Sentry
The Sentry process (sentryd) monitors other software processes and attempts to restart them automatically in certain failure conditions. For more information about the Sentry application, see “Automatically Restarting Software Processes”.
Surveillance
The LSMS Surveillance process (survMon) continually surveys the LSMS hardware and software and sends surveillance notifications to the server’s serial port. Users who want to display surveillance notifications on an administration console can connect Serial Port 3 to the administration console (see Configuring a Customer-Provided Administration Console).
Surveillance is also responsible for monitoring and restarting the sentryd and Service Assurance processes. For more information, see “Understanding the Surveillance Feature”.
Service Assurance
The Service Assurance feature allows an external system to access subscription version data from the LNP databases in the LSMS. For more information, see “Understanding the Service Assurance Feature”.
SNMPAgent
The SNMPAgent (lsmsSNMPAgent) is a process running on the LSMS platform that supports only the SNMPv1 and SNMPv3 trap operation. This process receives (through UDP Linux sockets) LSMS notification events from other LSMS processes and formats these events into trap requests. For more information, see “Understanding the SNMP Agent Process”.
Logger
The Logger process (lsmslogd) is responsible for:
Receiving log entries from application processes
Storing them in appropriate log files
Starting new log files every midnight
2.5 Overview of High Availability
To provide a high likelihood of the LSMS being able to function (high availability), the LSMS is implemented with hardware redundancies and with software that monitors hardware status and allows the LSMS functions to be run on either server (but not both at once).
2.5.1 Hardware Redundancies
Each server contains two internal mirrored disks.
The LSMS is implemented with a pair of redundant servers and the following redundant heartbeat connections between them:
A bonded pair of Ethernet connections for heartbeats
A serial cable connection for heartbeats
Figure 2-4 LSMS Servers Connected with Heartbeat Links
Redundant Servers
Two servers, one active and one standby, provide redundancy in processing. If the active server fails, the LSMS can run on the standby server.
Changing from one server to another is called switchover. The server on which the LSMS is running at a given time is called the active server and the other server is called the standby server.
For some types of failure on the active server, the LSMS automatically attempts to switch over. You can also manually switch over at any time. For more information about switching over, see the following:
Redundant Data
The LSMS is designed with the following data redundancies:
Each server contains mirrored disks. If both sides of the mirrors fail on the active server, the LSMS automatically attempts to switch over to the standby server. For more information, see Automatic Switchover Due to Hardware-Related Failure.
The database on the active server is replicated by the standby server.
Redundant Heartbeats
The servers use heartbeats to monitor each other. The servers are connected by a pair of redundant Ethernet connections and a serial connection. As long as each server is functioning, it sends its heartbeat to the other server over these connections. These two Ethernet connections are implemented on separate Ethernet cards, so that the failure of one Ethernet card does not prevent heartbeats from being sent.
The heartbeats are monitored by the Surveillance feature. If a heartbeat cannot be detected, one of the following notifications is posted:
LSMS4015|14:58 Jun 22, 2000|xxxxxxx|Notify:Sys Admin - Heartbeat 1 failure
LSMS4016|14:58 Jun 22, 2000|xxxxxxx|Notify:Sys Admin - Heartbeat 2 failure
2.5.2 Software Availability Design
The following LSMS software design features enhance the availability of the LSMS:
The LSMS HA utility monitors the states of both servers, detects failure conditions, and automatically switches over for certain failures on the active server. For more information, see Managing Server States
The Surveillance feature monitors critical processes and interfaces and posts notifications. For more information, see “Understanding the Surveillance Feature”.
The
sentrydfeature detects certain application failures and automatically attempts to restart the failed applications. Full functionality of this feature requires that the Surveillance feature be enabled. For more information aboutsentryd, see Restarting Software Processes -
The LSMS provides the following automatic attempts to reassociate and resynchronize after outages between NPACs and the LSMS or between the LSMS and network elements (when automatic recovery is not possible, notifications are posted, and operator-initiated recovery procedures are documented as indicated):
Automatic reassociation with an NPAC after some association outages (for operator-initiated recovery procedures, refer to the Configuration Guide)
Automatic resynchronization of NPAC and LSMS data after reassociation (when automatic resynchronization is not possible, notifications are posted, and operator-initiated recovery procedures are documented in “Resynchronizing After an Outage Between an NPAC and the LSMS”)
Automatic resynchronization of the LSMS and network element data after outage (when automatic recovery is not possible, notifications are posted, and operator-initiated recovery procedures are documented in the LNP Database Synchronization User's Guide)
2.6 Enhancing High Availability with a Shadow LSMS
To further enhance the availability of LSMS functions, you can choose to implement a shadow LSMS, where a shadow LSMS is an entire LSMS (with its own service provider ID) located in a separate geographical location from the main LSMS. Having a shadow LSMS available reduces the time needed to restore service in situations of severe error or disaster, such as fire or flood. The following types of shadow strategies are available:
Active shadow—a shadow LSMS that is connected to NPACs
Inactive shadow—a shadow LSMS exists but is not connected to NPACs
For more information about a shadow LSMS, and recovery procedures for each strategy, see Recovering from Site Failures. This chapter also describes the procedure for restoring a main LSMS after a site failure when no shadow is available.
2.7 Understanding the Surveillance Feature
On each server, the LSMS Surveillance feature continually surveys the LSMS hardware and software and sends surveillance notifications to Serial Port 3 on each server. The Surveillance feature also logs all surveillance notifications in the file survlog.log in the/var/TKLC/lsms/logs directory. The Surveillance feature starts when LSMS starts.
Figure 2-5 T1100 - Rear View - Showing Serial Ports
The Surveillance feature also monitors network interfaces. For information about configuring the Surveillance feature for this purpose, refer to the Configuration Guide.
The Surveillance feature enables remote personnel to monitor the LSMS and detect conditions that require immediate action. Some surveillance notifications are sent only when the event occurs; other notifications are sent both when the event first occurs and also every five minutes thereafter until the condition is cleared. Every five minutes, the Surveillance feature also sends a keep alive notification to the Surveillance serial port and logs the keep alive in the file survlog.log.
The following topics are described in this section:
- Configuring a Customer-Provided Administration Console
- Controlling the Surveillance Feature
- Understanding Surveillance Notifications
- Logging Surveillance Notifications
If customers desire a local administration console for displaying Surveillance notifications, they can attach their own administration console to Serial Port 3 on each of the LSMS servers. The following requirements are needed to provide and configure a customer-provided administration console:
- A workstation that can display text
- Two cables that connect to the RJ-45 interface used by Serial Port 3 on each LSMS server
- Configure the connections as:
- 115200 baud
- Parity 8E1
- Software running on the workstation that can determine from which cable the Surveillance notification is arriving (the Surveillance notifications do not identify which server is generating them)
2.7.1 Controlling the Surveillance Feature
The Surveillance feature starts on each server when the server starts. The following topics explain how to use LSMS commands to start, stop, and check the status of the Surveillance feature.
These commands affect only the server on which they are entered.2.7.1.1 Starting the Surveillance Feature
Use the lsmssurv start command to start the Surveillance feature on the server that you are logged into.
2.7.1.2 Stopping the Surveillance Feature
Use the lsmssurv stop command to stop the Surveillance feature on the server that you are logged into.
2.7.2 Understanding Surveillance Notifications
Introduction provides information about the format of Surveillance notifications and how they correlate to GUI notifications and traps. In addition, for each Surveillance notification, ordered by its event number, the appendix provides the following information:
- It output text string
- Explanation of possible cause, beyond the text that fits into the notification text string
- Suggested recovery actions
- Source from which the notification is sent
- Frequency with which the notification appears
In addition to displaying Surveillance notifications, the Surveillance feature logs all Surveillance notifications in the file survlog.log in the/var/TKLC/lsms/logs directory.
If the LSMS Surveillance feature becomes unable to properly report conditions, it logs the error information in a file, named lsmsSurv.log, in the /var/TKLC/lsms/logs directory on each server’s system disk. When the size of lsmsSurv.log exceeds 1MB, it is copied to a backup file, named lsmsSurv.log.bak, in the same directory. There is only one LSMS Surveillance feature backup log file, which limits the amount of log disk space to approximately 2MB.
2.8 Understanding the Service Assurance Feature
The Service Assurance feature allows an external system to access subscription version data from the LNP databases in the LSMS. This information is useful in verifying correct porting of data, and helps in troubleshooting problems. There is one LNP database for each of the NPACs associated with the LSMS.
The external system uses Service Assurance Manager (SAM) application software to initiate service assurance data requests and associations. Single or multiple SAMs may exist on the external computer system. The SAM communicates with the LSMS through the Service Assurance Agent (SAA) application software that resides in the LSMS. The SAM application software is not Oracle software and is only resident on the external system.
The SAA decodes the queries from the SAM and then accesses the LNP database. The SAA forms the subscription version data into a message and that message is sent to the SAM making the query.
Service Assurance works in conjunction with the Surveillance feature. The Surveillance feature issues the command to start the Service Assurance agent (part of the Service Assurance feature that is described in this document), and it monitors the status of the Service Assurance agent.
A maximum of eight SAM/SAA sessions are allowed at one time.
Figure 2-6 Service Assurance System within a Network
The architecture used to provide the access is a Connection Oriented Manager/Agent using Common Management Information Protocol (CMIP). CMIP provides an industry standard interface between Manager and Agent applications. This allows you to use standard products and tool kits to develop applications.
Service Assurance Terminology
The following terms are used to describe Service Assurance:
- Service Assurance Manager (SAM): Initiator of service assurance associations and data requests. This is not part of the LSMS application. A SAM application runs on a computer but is not the computer itself. Multiple SAMs can run on the same computer, or each SAM can run on a different computer.
- Service Assurance Agent (SAA): Software residing on the LSMS and considered part of the LSMS application. This software consists of one or more Linux processes and one or more Linux scripts.
- NPAC Database: This refers to the database stored on the NPAC.
- LNP Database: This refers to the database that contains subscriptionVersions, Service Provider Network, Service Provider LRN and Service Provider NPA-NXX objects. This database resides on the LSMS. Each NPAC has one LNP Database on the LSMS.
- Manager/Agent: This term describes the two peer processes that work together to implement the Service Assurance feature. The Manager is the customer’s application, which is used to initiate the association and send the query to the Agent process. The Agent process decodes the query message, then accesses the LNP Database.
The Agent extracts the data from the database, then builds and sends the reply to the Manager. This feature allows the Manager to send a single subscription TN or list of subscription TNs to query. The Agent extracts each instance that it can find from the LNP Database and returns a response to the Manager.
The architecture is connection oriented to restrict access to the LNP databases. This system is assumed to be within the customer’s private network, so no encryption security is included. The CMIP protocol defines the method for establishing and terminating associations. This application uses the access control and user data space in the association messages to restrict access to the system.
The SAM is restricted to querying subscription versions by the subscriptionTN field. Up to four SAMs can query the LSMS at the same time.
The Service Assurance feature interfaces to the LSMS by means of a 10 Mbps Ethernet interface. The Application WAN is also used as the interface for the X-terminals connected to the LSMS. The network connecting the Service Assurance systems to the LSMS is the responsibility of the customer.
Interface Implementation
The LSMS Service Assurance interface is implemented over a standard CMIP/CMISE-based OSI protocol stack (Q.3). RFC1006 is used for the transport layer.
This interface is limited to the retrieve capabilities of the local LSMS database. The object to be retrieved is the subscription Version defined in NPAC SMS Interoperable Interface Specification, NANC Version 1.5, September 1997.
Allowed Functions on the Interface
The LSMS responds to association (bind) requests, release (unbind) requests, aborts, and subscription query (m-get) messages. No other functions are allowed over this interface and will be rejected.
Support of OSI Addresses
The LSMS supports four OSI address connections for Service Assurance interfaces, which correspond to eight domains.
Each Service Assurance system needs to establish only the associations it requires, without regard to whether the LSMS is operating with the primary or secondary server. Upon switchover, the association is momentarily lost. The Service Assurance system tries to reestablish the association. When the active system finishes coming up, it then responds to the Service Assurance system association requests. The Service Assurance system does not know whether the primary or secondary system is running.
Association information is specified by Oracle. This information must be present in the bind request. This data in the association information, such as the system name, is used to verify the source of a bind request. Bind requests with invalid association information are rejected.
Establishment of association between the LSMS and the Service Assurance system is initiated by the Service Assurance Manager. This applies to initial association as well as to reestablishing the association after outages (regardless of the cause of the loss of association). When it does not have an association, the Service Assurance system periodically tries to establish the association until a successful response is received from the LSMS. The minimum retry interval is one minute.
The LSMS provides a response to the bind request to indicate:
- Successful connection
- Access control failure (authority violation - unknown address requesting association)
- LSMS data access failure
- Resource failure (maximum number of associations already established)
Number of Associations Per Service Assurance System
The LSMS supports one association per Service Assurance system.
If a Service Assurance agent within the LSMS is unable to establish a connection with the LSMS NPAC database, the association with the Service Assurance system is aborted.
Notification Upon Loss of Association
The LSMS provides a notification when the association with any of the Service Assurance Manager is lost or established.
2.9 Understanding the SNMP Agent Process
The optional Remote Monitoring feature provides the capability for the LSMS to report certain events and alarms to a remote location, using the industry-standard Simple Network Management Protocol (SNMP). The LSMS implements an SNMP agent with the SNMP agent process running on the LSMS platform.
Customers can use this feature to cause the LSMS to report events and alarms to another location, which implements an SNMP Network Management System (NMS). An NMS is typically a standalone device, such as a workstation, which serves as an interface through which a human network manager can monitor and control the network. The NMS typically has a set of management applications (for example, data analysis and fault recovery applications). The SNMP feature must be enabled while configuring the NMS.
Overview of SNMP Protocols
An SNMP agent, such as that implemented by the LSMS, is responsible for SNMP managed objects; each managed object represents a data variable. A collection of managed objects is called a management information base (MIB). A copy of the MIB is maintained both at the SNMP agent and also at the NMS. The MIB can be read with a text editor.
An SNMP agent can do the following:
- Respond to requests from the NMS for information and/or action. The SNMP architecture defines a limited set of management commands and responses. The NMS can issue Get, GetNext, and Set messages to retrieve single or multiple object variables or to modify the value of a single variable. The SNMP agent sends a response message to complete the Get, GetNext, or Set. This release of the LSMS does not support these functions.
- Send event notifications, called trap requests, to the NMS to identify the occurrence of conditions, such as the failure or restoration of a link interface.
The SNMP protocol uses the User Datagram Protocol (UDP) transport protocol in a TCP/IP network. UDP is a connectionless protocol and does not guarantee reliable delivery of data. Therefore, SNMP does not use a preestablished connection to send data and does not guarantee reliable delivery of data.
MIB Structure
Figure 2-7 MIB Structure
New Object definition:
sourceIP OBJECT-TYPE
SYNTAX OCTET STRING
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"Th“ source ip of the device where event was generated."
” ::= { tekelecLSMSEventObjects 44 }
resyncVar OBJECT-TYPE
SYNTAX INTEGER(0..1)
MAX-ACCESS read-write
STATUS current
DESCRIPTION "Th“ object is available to be set by the NMS to indicate a request for alarm resynchronization.
Object value=0 indicates a request to stop an ongoing resnchronization and Object value=1 indicates a resynchronization request."
:”= { tekelecLSMSEventObjects 45 }
resyncEventCnt OBJECT-TYPE
SYNTAX Unsigned32
TUS current
DESCRIPTION "Th“ total number of Resync alarms to be sent."
” { tekelecLSMSEventObjects 46 }
alarmSequence OBJECT-TYPE
SYNTAX Unsigned32
STATUS current
DESCRIPTION
"Un“que sequence number identifying an SNMP Alarm Trap instance."
” ::= { tekelecLSMSEventObjects 48 }
lsmsUptime OBJECT-TYPE
SYNTAX TimeTicks
STATUS current
DESCRIPTION
"Ti“e since LSMS is up."
::={ tekelecLSMSEventObjects 49 }
specificOid OBJECT-TYPE
SYNTAX OCTET STRING
STATUS current
DESCRIPTION "Trap ID."
::= { tekelecLSMSEventObjects 50 }
currentTimeOBJECT-TYPE
SYNTAX OCTET STRING
STATUS current
DESCRIPTION "Date and time string."
::= { tekelecLSMSEventObjects 51 }
resyncErrCode OBJECT-TYPE
SYNTAX OCTET STRING
STATUS current
DESCRIPTION
"errorCode = 0, Resynchronization completed successfully.
errorCode = 1, Resynchronization aborted by NMS.
errorCode = 2, Resynchronization already in progress for the NMS.
errorCode = 3, Resynchronization Aborted, Database error occurred.
errorCode = 4, Resynchronization not in progress."
::= { tekelecLSMSEventsVer 218 }
New Trap Definition:
Existing traps defined for SNMP v1 are modified to include the following for the MIB for SNMP v3:
- sourceIP
- alarmSequence
New SNMPv3 MIB Traps:
tekelecLSMSEventsV3 OBJECT IDENTIFIER ::= { tekelecLSMSEvents 3 }
resyncStartTrap NOTIFICATION-TYPE
OBJECTS { lsmsUptime, sourceIP }
DESCRIPTION "The trap is sent by the LSMS to NMS when the LSMS is about to start resynchronization"
::= {tekelecLSMSEventsV3 212 }
resyncStopTrap NOTIFICATION-TYPE
OBJECTS { lsmsUptime, sourceIP, resyncEventCnt, resyncErrCode }
DESCRIPTION "The trap is sent by the LSMS to NMS when resynchronization is complete"
::= {tekelecLSMSEventsV3 213 }
resyncRejectTrap NOTIFICATION-TYPE
OBJECTS { lsmsUptime, sourceIP, resyncErrCode }
DESCRIPTION "The trap is sent by the LSMS to NMS when a resynchronization request is rejected by LSMS "
::= {tekelecLSMSEventsV3 214 }
resyncRequiredTrap NOTIFICATION-TYPE
DESCRIPTION "The trap is sent by the LSMS to NMS when the LSMS is rebooted or LSMS is started"
::= {tekelecLSMSEventsV3 215 }
heartBeatTrap NOTIFICATION-TYPE
DESCRIPTION "The trap is sent by the LSMS to NMS periodically to indicate that the LSMS is up"
::= {tekelecLSMSEventsV3 216 }
lsmsAlarmTrapV3 NOTIFICATION-TYPE
OBJECTS { currentTime,specificOid ,sourceIP, alarmSequence,specificAlarm}
STATUS current
DESCRIPTION "The trap will indicate that the following information is for a particular event"
::= {tekelecLSMSEventsVer 217 }
The MIB "choice fields" is added to accept a different number of arguments at runtime:
SPECIFICALARM::=
CHOICE{
OBJECTID-VALUE
TEKELECLSMSEVENTSVER
Varbinds "sourceIP" and "alarmSequence" are added as a part of SNMPv3 and will be fixed varbinds to keep SNMPv1 backward compatible. SNMPv1 information will be passed as a part of "choice field."
A "currentTime" field conveys information about time when an alarm is triggered.
Current definition for SNMPv3 Trap:
LSMSALARMTRAPV3 NOTIFICATION-TYPE
OBJECTS { CURRENTTIME, SPECIFICOID ,SOURCEIP, ALARMSEQUENCE,SPECIFICALARM}
STATUS CURRENT
DESCRIPTION "THE TRAP WILL INDICATE THAT THE FOLLOWING INFORMATION IS FOR A PARTICULAR EVENT"
::= {TEKELECLSMSEVENTSVER 217 }
Description of different varbinds of SNMPv3 Trap:
Table 2-4 Description of Different Varbinds of SNMPv3 Trap
| MIB OBJECTS | OID | Description |
| currentTime | 1.3.6.1.4.1.323.5.3.4.1.1.51.0 | Time when alarm is generated. |
| specificOid | 1.3.6.1.4.1.323.5.3.4.1.1.50.0 | Oid which uniquely identifies a SNMPV3 alarm |
| sourceIP | 1.3.6.1.4.1.323.5.3.4.1.1.44.0 | IP address of active alarm |
| alarmSequence | 1.3.6.1.4.1.323.5.3.4.1.1.48.0 | Sequence number of triggered alarm |
| specifcAlarm | List of OID for different varbinds | List of oid for different varbind and values |
Sample SNMPv3 trap for alarm 4021:
DISMAN-EVENT-MIB::SYSUPTIMEINSTANCE = TIMETICKS: (44365220) 5 DAYS, 3:14:12.20
SNMPV2-MIB::SNMPTRAPOID.0 = OID: SNMPV2-SMI::ENTERPRISES.323.5.3.4.2.0.217
SNMPV2-SMI::ENTERPRISES.323.5.3.4.1.1.51.0 = STRING: "02/01/10 20:31:31" SNMPV2-S
MI::ENTERPRISES.323.5.3.4.1.1.50 .0= STRING: "1.3.6.1.4.1.323.5.3.4.2.0.40"
SNMPV2-SMI::ENTERPRISES.323.5.3.4.1.1.44.0 = STRING: "192.168.59.30" SNMPV2-S
MI::ENTERPRISES.323.5.3.4.1.1.48.0 = GAUGE32: 44 SNMPV2-SMI::ENTERPRISES.323.5.3.
4.1.1.1.0 = INTEGER: 4021 SNMPV2-SMI::ENTERPRISES.323.5.3.4.1.1.17.0 = STR
ING: "LMGRD"
MIB FOR ALARM 4021
LSMSAPPSNOTRUNNING NOTIFICATION-TYPE
OBJECTS { EVENTNBR, PROCESSNAME, SOURCEIP, ALARMSEQUENCE }
STATUS CURRENT
DESCRIPTION
"THIS NOTIFICATION INDICATES THAT A SPECIFIC LSMS APPLICATION
OR SYSTEM DAEMON IS NOT RUNNING."
::= {TEKELECLSMSEVENTSVER 40 }
Decoding SNMPv3 Trap for alarm 4021:
Table 2-5 Decode SNMPv3 Trap for Alarm 4021
| OID | MIB OBJECT | Value |
| 1.3.6.1.4.1.323. 5.3.4.2.0.217 | lsmsAlarmTrapV3 (Indicating SNMPv3 Alarm) | NO value |
| 1.3.6.1.4.1.323.5.3.4.1.1.51.0 | currentTime | 02/01/10 20:31:31 |
| 1.3.6.1.4.1.323.5.3.4.1.1.50.0 | specificOid (unique oid of lsms alarm) | 1.3.6.1.4.1.323.5.3.4.2.0.40 |
| 1.3.6.1.4.1.323.5.3.4.1.1.44.0 | sourceIP | 192.168.59.30 |
| 1.3.6.1.4.1.323.5.3.4.1.1.48.0 | alarmSequence | 44 |
| 1.3.6.1.4.1.323.5.3.4.1.1.1.0, 1.3.6.1.4.1.323. 5.3.4.1.1.17.0 | eventNbr,processName(variable varbinds) | 4021,lmgrd |
There is no SNMPv3 trap for event numbers 8102 to 8105 and 8110 to 8118, as there is no trap definition for these events. These events will exhibit SNMPv1 behavior.TKLC-LSMS-MIB
TEKELEC-LSMS-TRAP-MIB DEFINITIONS ::= BEGIN-- Copyright 2015 Oracle Corporation IMPORTS tekelecLSMS FROM TEKELEC-TOPLEVEL-REG NOTIFICATION-TYPE, OBJECT-TYPE, IpAddress, TimeTicks, Unsigned32, CHOICE FROM SNMPv2-SMI;-- LSMS Object group sub-tree tekelecLSMSObjects OBJECT IDENTIFIER ::= { tekelecLSMS 1 }-- LSMS Product Events sub-tree tekelecLSMSEvents OBJECT IDENTIFIER ::= { tekelecLSMS 2 }-- LSMS Events Object group sub-tree tekelecLSMSEventObjects OBJECT IDENTIFIER ::= { tekelecLSMSObjects 1 }-- LSMS SNMP Events compatible for both version1 and version3tekelecLSMSEventsVer OBJECT IDENTIFIER ::= { tekelecLSMSEvents 0 }specificAlarm ::= CHOICE{ objectID-value tekelecLSMSEventsVer }---- OBJECTS DEFINITIONS--eventNbr OBJECT-TYPE SYNTAX INTEGER (1..2147483647) MAX-ACCESS read-only STATUS current DESCRIPTION "Tekelec specific unique identifier for the notification error number. The value can be any positive integer value except 0" ::= { tekelecLSMSEventObjects 1 } -- Varying in length from 0 to 65535 for SNMPv1 OCTET STRINGnPACRegion OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "a string indicating the name of the NPAC Region." ::= { tekelecLSMSEventObjects 2 } -- Varying in length from 0 to 65535 for SNMPv1 OCTET STRINGneCLLI OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "a string indicating the network element CLLI." ::= { tekelecLSMSEventObjects 3 } npacId OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "a string that identifies the specific LSMS NPAC association. Valid values are: primary,secondary." ::= { tekelecLSMSEventObjects 4 } npacRegionId OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "A 2 character string 2 that uniquelly identifies each NPAC region. Valid value are: MW - Midwest MA - Mid-Atlantic NE - Northeast SE - Southeast SW - Southwest WE - West Regional WC - West Coast CA - Canada " ::= { tekelecLSMSEventObjects 5 } oldNPA OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "The old number planning area (area code) value." ::= { tekelecLSMSEventObjects 6 } newNPA OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "The new number planning area (area code) value." ::= { tekelecLSMSEventObjects 7 } nXX OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "The exchange code value (NXX). " ::= { tekelecLSMSEventObjects 8 } npacRecoveryRetryInterval OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Positive integer value indicating the NPAC recovery retry interval." ::= { tekelecLSMSEventObjects 9 } retryTimes OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Integer values indicating the number of retries." ::= { tekelecLSMSEventObjects 10 } fromPeriod OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Beginning time specification YYYYMMDDhhmmss " ::= { tekelecLSMSEventObjects 11 } toPeriod OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Ending time specification YYYYMMDDhhmmss " ::= { tekelecLSMSEventObjects 12 } controllerId OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "The specific controller number (either 0 or 1)." ::= { tekelecLSMSEventObjects 13 } driveSpecId OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Disk drive specification." ::= { tekelecLSMSEventObjects 14 } shareDriveId OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Shared disk drive physical Id." ::= { tekelecLSMSEventObjects 15 } hotSpareDriveId OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Hot-spare disk drive physical id." ::= { tekelecLSMSEventObjects 16 } processName OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Name of the process (either lsmsagent or supagent)." ::= { tekelecLSMSEventObjects 17 } diskVolName OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Disk Volume name." ::= { tekelecLSMSEventObjects 18 } backUpType OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "DATABASE or FILESYSTEM." ::= { tekelecLSMSEventObjects 19 } volumeName OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "The specific problem disk volume." ::= { tekelecLSMSEventObjects 20 } fileSystem OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Specific LSMS filesystem with problem." ::= { tekelecLSMSEventObjects 21 } logFileName OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "The EMS log file name." ::= { tekelecLSMSEventObjects 22 } errorCode OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "errorCode = 2 , the LOG_DIR in the ShadowAudit.cfg does not exist. errorCode = 3, LSMS_DIR is not set in the global.shrc file. errorCode = 4, VERSANT_ROOT or VERSANT_REL is not set in the global.shrc file. errorCode = 6, the /usr/local/etc/global.shrc file does not exist. errorCode = 7, the ShadowAudit.cfg file does not exist in the $LSMS_DIR/config directory. errorCode = 8, the lsmsmate entry in the /etc/hosts file does not exist or is inaccessible. errorCode = 9, the LSMS is unable to use the SecureShell keys or the authorized_keys file on the shadow LSMS is missing. errorCode = 10, the directory /var/TKLC/lsms/logs does not have at least 20 megabytes of available disk space." ::= { tekelecLSMSEventObjects 23 } servAssuranceMgrName OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Service assurance manager name." ::= { tekelecLSMSEventObjects 24 } queueMgrName OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Queue manager name." ::= { tekelecLSMSEventObjects 25 } operationCode OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "create, delete, modify" ::= { tekelecLSMSEventObjects 26 } npanxxValue OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "NPA-NXX" ::= { tekelecLSMSEventObjects 27 } effectiveTimeStamp OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "YYYYMMDDhhmmss" ::= { tekelecLSMSEventObjects 28 } sPID OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "4 digits alphanumeric value." ::= { tekelecLSMSEventObjects 29 } nPANXX OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "npanxx value being created or deleted." ::= { tekelecLSMSEventObjects 30 } npacIP OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "NPAC IP address." ::= { tekelecLSMSEventObjects 31 } lRN OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Local Routing Number (LRN) value being created, modified or deleted." ::= { tekelecLSMSEventObjects 32 } id2 OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Second id." ::= { tekelecLSMSEventObjects 33 } hostname OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Name or IP address of host." ::= { tekelecLSMSEventObjects 34 } alarmBitMask OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Bit mask of Eagle alarm." ::= { tekelecLSMSEventObjects 35 } svNpbUsage OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Usage of SV/NPB storage database." ::= { tekelecLSMSEventObjects 36 } dbReplErr OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Error message from database replication." ::= { tekelecLSMSEventObjects 37 } dbMonErr OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Error message from database monitor daemon." ::= { tekelecLSMSEventObjects 38 } eagleAgentDataErr OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Error message preventing record from being sent to network element." ::= { tekelecLSMSEventObjects 39 } svNpbThreshold OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "SV/NPB configurable usage threshold." ::= { tekelecLSMSEventObjects 40 } oldMySQLPortNumber OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Old MySQL Port Number." ::= { tekelecLSMSEventObjects 41 }newMySQLPortNumber OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "New MySQL Port Number." ::= { tekelecLSMSEventObjects 42 }binlogsThreshold OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Threshold of forceful binlogs purge." ::= { tekelecLSMSEventObjects 43 } sourceIP OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "The source ip of the device where event was generated." ::= { tekelecLSMSEventObjects 44 }resyncVar OBJECT-TYPE SYNTAX INTEGER(0..1) MAX-ACCESS read-write STATUS current DESCRIPTION "The object is available to be set by the NMS to indicate a request for alarm resynchronization. Object value=0 indicates a request to stop an ongoing resnchronization and Object value=1 indicates a resynchronization request." ::= { tekelecLSMSEventObjects 45 }resyncEventCnt OBJECT-TYPE SYNTAX Unsigned32 MAX-ACCESS read-only STATUS current DESCRIPTION "The total number of Resync alarms to be sent." ::= { tekelecLSMSEventObjects 46 }resyncErrCode OBJECT-TYPE SYNTAX INTEGER MAX-ACCESS read-only STATUS current DESCRIPTION "Enumerated value that indicates the reason for the trap." ::= { tekelecLSMSEventObjects 47 }alarmSequence OBJECT-TYPE SYNTAX Unsigned32 MAX-ACCESS read-only STATUS current DESCRIPTION "Unique sequence number identifying an SNMP Alarm Trap instance." ::= { tekelecLSMSEventObjects 48 }lsmsUptime OBJECT-TYPE SYNTAX TimeTicks MAX-ACCESS read-only STATUS current DESCRIPTION "Time since LSMS is up." ::= { tekelecLSMSEventObjects 49 }specificOid OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Trap ID." ::= { tekelecLSMSEventObjects 50 }currentTime OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Date and time string." ::= { tekelecLSMSEventObjects 51 }-- -- TRAP DEFINITIONS-- eagleAgentStarted NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the eagleagent process has been started. " ::= {tekelecLSMSEventsVer 1 } eagleAgentStoppedbyscript NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the eagleagent process has been stopped by the sup script." ::= {tekelecLSMSEventsVer 2 } nPACagentStarted NOTIFICATION-TYPE OBJECTS { eventNbr, nPACRegion } STATUS current DESCRIPTION "This notification indicates that the NPACagent for the region has been started." ::= {tekelecLSMSEventsVer 3 } lsmsCommandStoppedNPACagent NOTIFICATION-TYPE OBJECTS { eventNbr, nPACRegion } STATUS current DESCRIPTION "This notification indicates that the NPACagent process has been stopped using the lsms command." ::= {tekelecLSMSEventsVer 4 } primaryEMSAssocLostSecEstablished NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS has lost association with the primary EMS, switching to secondary EMS association." ::= {tekelecLSMSEventsVer 5 } npacAssocEstablished NOTIFICATION-TYPE OBJECTS { eventNbr, npacRegionId, npacId } STATUS current DESCRIPTION "This notification indicates that the NPAC association was successfully established." ::= {tekelecLSMSEventsVer 7 } primaryEMSAssocEstablished NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS has established the primary association with the EMS." ::= {tekelecLSMSEventsVer 8 } npacAbortByUser NOTIFICATION-TYPE OBJECTS { eventNbr, npacRegionId, npacId } STATUS current DESCRIPTION "This notification indicates that the NPAC association has been aborted by the user." ::= {tekelecLSMSEventsVer 9 }npaSplitActOk NOTIFICATION-TYPE OBJECTS { eventNbr, oldNPA, newNPA, nXX } STATUS current DESCRIPTION "This notification indicates that the activated split was successful." ::= {tekelecLSMSEventsVer 10 }switchOverStarted NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the active server has initiated an automatic switchover to the inactive server." ::= {tekelecLSMSEventsVer 11 }switchOverCompleted NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the LSMS service Switchover process has completed." ::= {tekelecLSMSEventsVer 12 }switchOverFailed NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the LSMS service Switchover could not be switched over to the inactive server." ::= {tekelecLSMSEventsVer 13 }diskContrService NOTIFICATION-TYPE OBJECTS { eventNbr, controllerId } STATUS current DESCRIPTION "This notification indicates that the disk controller <controllerId> is out of service and is affecting shared storage. This notification is only valid on E3000 systems." ::= {tekelecLSMSEventsVer 14 }npacInterfaceFailure NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates an NPAC interface failure. Its is generated when the ping utility has not receive a response from the interface associated with the NPAC." ::= {tekelecLSMSEventsVer 15 } emsInterfaceFailure NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates an EMS Ethernet interface failure. Its is generated when the ping utility has not receive a response from the interface associated with the EMS." ::= {tekelecLSMSEventsVer 16 } appsInterfaceFailure NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Ethernet interface used to connect to the APPLICATION network has a problem." ::= {tekelecLSMSEventsVer 17 }adminInterfaceFailure NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Ethernet interface used to connect to the ADMINISTRATION network has a problem." ::= {tekelecLSMSEventsVer 18 }survFeatureOn NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Surveillance feature is running." ::= {tekelecLSMSEventsVer 19 }systemDiskSynch NOTIFICATION-TYPE OBJECTS { eventNbr, driveSpecId } STATUS current DESCRIPTION "This notification indicates that the system disk has lost synchronization, possibly due to a hardware problem." ::= {tekelecLSMSEventsVer 20 }dataReplError NOTIFICATION-TYPE OBJECTS { eventNbr, dbReplErr } STATUS current DESCRIPTION "This notification indicates that database replication has failed." ::= {tekelecLSMSEventsVer 21 }dbMonitorFail NOTIFICATION-TYPE OBJECTS { eventNbr, dbMonErr } STATUS current DESCRIPTION "This notification indicates that the DB process monitor has failed." ::= {tekelecLSMSEventsVer 22 }internalDiskError NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that Volume Manager does not recognize a shared disk that was logically replaced by the hot-spared disk." ::= {tekelecLSMSEventsVer 23 }hotSparedDataResynch NOTIFICATION-TYPE OBJECTS { eventNbr, shareDriveId, hotSpareDriveId } STATUS current DESCRIPTION "This notification indicates that the hot-spare feature has completed automatic data resynchronization." ::= {tekelecLSMSEventsVer 24 }dbReplInfo NOTIFICATION-TYPE OBJECTS { eventNbr, dbReplErr } STATUS current DESCRIPTION "This notification indicates that DB replication delay threshold has crossed." ::= {tekelecLSMSEventsVer 25 }cpuUtilizationOver60 NOTIFICATION-TYPE OBJECTS { eventNbr, processName, id2 } STATUS current DESCRIPTION "This notification indicates that the eagleagent agent or an NPACagent for a specific region is utilizing 79 percent or more of the LSMS's CPU resource." ::= {tekelecLSMSEventsVer 26 }primaryServerInhibited NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the primary servers state is inhibited." ::= {tekelecLSMSEventsVer 27 }secondaryServerInhibited NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the secondary servers state is inhibited." ::= {tekelecLSMSEventsVer 28 }heartbeatLinkDown NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that a Heartbeat link is down." ::= {tekelecLSMSEventsVer 29 }heartbeatLinkTwoDown NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Heartbeat 2 link is down." ::= {tekelecLSMSEventsVer 30 }lsmsNtwkConfigError NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the LSMS network configuration is incorrect." ::= {tekelecLSMSEventsVer 31 }networkConfigNotSupported NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the LSMS network configuration is not supported or recommended." ::= {tekelecLSMSEventsVer 32 }emsRequiresResynchWithLSMS NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that an EMS (OAP) requires a resynchronization with the LSMS. See customer documentation for database synchronization procedure." ::= {tekelecLSMSEventsVer 33 }resynchLogMidFull NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the network element resynchronization database contains more then 1000000 entries. Run devresync utility." ::= {tekelecLSMSEventsVer 34 }primaryEMSAssocLostNoSec NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS has lost association with the primary EMS and the secondary association is not established." ::= {tekelecLSMSEventsVer 36 }lostNPACAssoc NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC association was disconnected gracefully by the user." ::= {tekelecLSMSEventsVer 37 }diskVolume95Usage NOTIFICATION-TYPE OBJECTS { eventNbr, diskVolName } STATUS current DESCRIPTION "This notification indicates that the disk volume specified by diskVolName has exceeded the 95 percent usage threshold." ::= {tekelecLSMSEventsVer 38 }swapSpaceCritical NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the server's system check has raised a swap space critical alarm." ::= {tekelecLSMSEventsVer 39 }lsmsAppsNotRunning NOTIFICATION-TYPE OBJECTS { eventNbr, processName } STATUS current DESCRIPTION "This notification indicates that a specific LSMS application or system daemon is not running." ::= {tekelecLSMSEventsVer 40 }backupCompleted NOTIFICATION-TYPE OBJECTS { eventNbr, backUpType } STATUS current DESCRIPTION "This notification indicates that a backup of the specified LSMS disk (DATABASE or FILESYSTEM) has completed successfully." ::= {tekelecLSMSEventsVer 41 }backupFailed NOTIFICATION-TYPE OBJECTS { eventNbr, backUpType } STATUS current DESCRIPTION "This notification indicates that a backup of the specified LSMS disk (DATABASE or FILESYSTEM) has failed." ::= {tekelecLSMSEventsVer 42 }emsPendingQueueHalfFull NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the pending queue used to hold the transactions to send to the network element is over half full." ::= {tekelecLSMSEventsVer 43 }emsPendingQueueMaxReached NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the pending queue used to hold the transactions to send to the network element is completely full." ::= {tekelecLSMSEventsVer 44 }failedNPACConnectivity NOTIFICATION-TYPE OBJECTS { eventNbr, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the LSMS is not able to confirm the physical connectivity with the NPAC whose NPAC region is npacRegionId" ::= {tekelecLSMSEventsVer 45 }eagleAgentIgnoreRecord NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI, eagleAgentDataErr } STATUS current DESCRIPTION "This notification indicates that there was a data error in a record preventing the eagleagent from sending it to the network element" ::= {tekelecLSMSEventsVer 46 }primaryServerNotOnline NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the primary LSMS server is not online." ::= {tekelecLSMSEventsVer 63 }secServerNotPreparedForTakeover NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the secondary LSMS server is not prepared to take over LSMS service." ::= {tekelecLSMSEventsVer 64 }secServerProvidingLSMSService NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the secondary LSMS server is currently providing the LSMS service." ::= {tekelecLSMSEventsVer 65 }secServerCannotDeterminePrimAvail NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the secondary LSMS server cannot determined the availability of the LSMS service on the primary server." ::= {tekelecLSMSEventsVer 66 }serviceAssuranceAgentStarted NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Service Assurance agent has started successfully." ::= {tekelecLSMSEventsVer 67 }establishServAssuranceMgrAssoc NOTIFICATION-TYPE OBJECTS { eventNbr, servAssuranceMgrName } STATUS current DESCRIPTION "This notification indicates that the association with the Service Assurance manager has been established successfully." ::= {tekelecLSMSEventsVer 68 }servAssuranceMgrAssocBroken NOTIFICATION-TYPE OBJECTS { eventNbr, servAssuranceMgrName } STATUS current DESCRIPTION "This notification indicates that the association with the Service Assurance manager has been stopped or disconnected." ::= {tekelecLSMSEventsVer 69 }servAssuranceAgentNotRunning NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Service Assurance agent is not currently running." ::= {tekelecLSMSEventsVer 70 }noPhysicalConnectivityToDCM NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS is not able to confirm physical connectivity with the DCM." ::= {tekelecLSMSEventsVer 73 }lsmsEagleAgentFailed NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS eagleagent process has failed. The sentry daemon process will attempt to restart." ::= {tekelecLSMSEventsVer 74 }lsmsEagleAgentRestarted NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS eagleagent process has been successfully restarted by the sentry daemon process." ::= {tekelecLSMSEventsVer 75 }failureToRestartEagleAgent NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the sentry daemon process was unable to restart the eagleAgent." ::= {tekelecLSMSEventsVer 76 }nPACagentForRegionFailure NOTIFICATION-TYPE OBJECTS { eventNbr, nPACRegion } STATUS current DESCRIPTION "This notification indicates that the NPACagent process for the region specified by nPACRegion has failed. The sentry daemon will attempt to restart the NPACagent process." ::= {tekelecLSMSEventsVer 78 }nPACagentForRegionRestarted NOTIFICATION-TYPE OBJECTS { eventNbr, nPACRegion } STATUS current DESCRIPTION "This notification indicates that the NPACagent process for the region specified by nPACRegion has been successfully restarted by the sentry daemon." ::= {tekelecLSMSEventsVer 79 }failureToRestartNPACagentRegion NOTIFICATION-TYPE OBJECTS { eventNbr, nPACRegion } STATUS current DESCRIPTION "This notification indicates that the sentry daemon process was unable to restart the NPACagent process for the region specified by nPACRegion." ::= {tekelecLSMSEventsVer 80 }osiDeamonFailure NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the one of the Sunlink OSI daemons, either osinetd or osilogd, has failed. The lsmssentry process will attempt to restart." ::= {tekelecLSMSEventsVer 88 }osiDeamonRestarted NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the osinetd or osilogd, daemon has been successfully restarted by the lsmssentry process." ::= {tekelecLSMSEventsVer 89 }osiDeamonRestartFailure NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the lsmssentry process was not able to restart the osinet or osilogd daemons." ::= {tekelecLSMSEventsVer 90 }lsmssentryFailure NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Surveillance feature has detected that the sentry daemon process is no longer running." ::= {tekelecLSMSEventsVer 91 }iddAgentRestarted NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the surveillance process has detected that the Legacy lddAgent process has restarted and all functionality has resumed." ::= {tekelecLSMSEventsVer 92 }scpmsIddAgentRestarted NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the surveillance process has detected that the SCPMS lddAgent process has restarted and all functionality has resumed." ::= {tekelecLSMSEventsVer 93 }npacRejectedAssocAccessCtrlFail NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC aborted association because it received a message from LSMS that failed security checks." ::= {tekelecLSMSEventsVer 95 }npacRejectedAssocInvalidData NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC aborted the association because NPAC received invalid data from LSMS." ::= {tekelecLSMSEventsVer 96 }emaAssociationAbortedQueueFull NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that all associations to the EMS are aborted, since the pending queue used to hold transactions to be send to the EMS/NE is full." ::= {tekelecLSMSEventsVer 97 }emsAssocAbortedMaxResend NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that all associations to the EMS are aborted, since the eagleagent has already tried resending the same message the maximum number of times." ::= {tekelecLSMSEventsVer 98 }assocRespNPACTimeout NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the LSMS did not receive an association response from the NPAC within the timeout period. The LSMS will attempt the association with the NPAC again after configurable amount of time." ::= {tekelecLSMSEventsVer 100 }assocRejectedRetrySameHost NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC association was rejected by the NPAC, and the LSMS was informed to attempt the NPAC association again to the same NPAC host after configurable amount of time." ::= {tekelecLSMSEventsVer 101 }assocRejectedRetryOtherHost NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC association was rejected by the NPAC, and the LSMS was informed to attempt the NPAC association again to the other NPAC host after after configurable amount of time." ::= {tekelecLSMSEventsVer 102 } nwtkProblemRetryNPACAssoc NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that a problem exists in the network connectivity. The LSMS will attempt the association with the NPAC again after configurable amount of time." ::= {tekelecLSMSEventsVer 103 }lsmsAbortedNPACassocDowRecFail NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the LSMS received three consecutive responses from the NPAC with a download status of failure from a recovery request. The LSMS has aborted the associations and will attempt to associate again after configurable amount of time. The LSMS will retry the recovery action after the association is reestablished." ::= {tekelecLSMSEventsVer 104 }nwtkConnProblemNPACAssocAborted NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC association was aborted due to a network connectivity loss between the LSMS and the NPAC." ::= {tekelecLSMSEventsVer 105 }assocRejDueToAccessControl NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC rejected the association request because it could not validate access control." ::= {tekelecLSMSEventsVer 106 }npacAssocRejDuetoAccessDenied NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC rejected the association with an indication of access denied." ::= {tekelecLSMSEventsVer 107 }npacConnFailedCMIP NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC connection attempt failed, because the userInfo value in the cmipUserInfo portion of the NPAC association response CMIP message is invalid." ::= {tekelecLSMSEventsVer 108 }npacAssocGracefullyTerminated NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the NPAC association was terminated gracefully by the NPAC." ::= {tekelecLSMSEventsVer 109 }lsmsDataLostBadResynch NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the LSMS was not resynchronized properly with the NPAC. There are multiple steps in recovery. All steps failed." ::= {tekelecLSMSEventsVer 112 }badNPACresynchTime NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the LSMS was not resynchronized properly with the NPAC. There are multiple steps in recovery. Some steps failed." ::= {tekelecLSMSEventsVer 113 }assocAbortedBadKeys NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that the LSMS aborted the NPAC association because the LSMS received a message from the NPAC that did not have the correct LSMS key signature." ::= {tekelecLSMSEventsVer 114 }scpmsMqSeriesFault NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the LDD SCPMS Confirmation of Arrival message retry attempts have been exhausted. The MQSeries interface is not operational or network connectivity to the remote system is lost." ::= {tekelecLSMSEventsVer 116 }scpmsNotActive NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the LDD SCPMS system has not provided a response within the time limit specified by the LDD_SCP_SYSTEM_RESPONSE_TOMEOUT configuration parameter. The SCPMS system is not active." ::= {tekelecLSMSEventsVer 117 }legacyMqSeriesFault NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the LDD Legacy Confirmation of Arrival message retry attempts have been exhausted. The MQSeries interface is not operational or network connectivity to the remote system is lost." ::= {tekelecLSMSEventsVer 118 }scpmsLegacyNotActive NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the LDD Legacy system has not provided a response within the time limit specified by the LDD_SCP_SYSTEM_RESPONSE_TOMEOUT configuration parameter. The SCPMS system is not active." ::= {tekelecLSMSEventsVer 119 }mqQeriesQueueManagerNotActive NOTIFICATION-TYPE OBJECTS { eventNbr, queueMgrName } STATUS current DESCRIPTION "This notification indicates that A connection could not be made to the MQSeries local queue manager. The local queue manager is not started or operational." ::= {tekelecLSMSEventsVer 120 }npacAutoAssociationRetryCanceled NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that an NPAC automatic associations retry has been canceled." ::= {tekelecLSMSEventsVer 122 }npacRecoveryFailureResourceLimitation NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId, retryTimes, npacRecoveryRetryInterval } STATUS current DESCRIPTION "This notification indicates that the LSMS received a response from the NPAC with a download status of failure from a recovery action request. The NPAC is unable to process the recovery action due to a temporary resource limitation. The LSMS will retry the request after five minutes." ::= {tekelecLSMSEventsVer 123 }npacAssocPeriodDowm NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId, fromPeriod, toPeriod } STATUS current DESCRIPTION "This notification indicates that the NPAC association will be down for the specified period of time due to NPAC-scheduled down time." ::= {tekelecLSMSEventsVer 124 }npacAssocRequestSentAfterRetryTimer NOTIFICATION-TYPE OBJECTS { eventNbr, npacId, npacRegionId } STATUS current DESCRIPTION "This notification indicates that an associate request has been sent to the NPAC after retry timer has expired." ::= {tekelecLSMSEventsVer 125 }npanxxGTTValueNotFound NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI, operationCode } STATUS current DESCRIPTION "This notification indicates that the EMS/NE has rejected the NPANXX GTT creation, deletion or modification transaction, and the NPANXX value in the transaction could not be determined." ::= {tekelecLSMSEventsVer 126 }npanxxGTTValueRejected NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI, operationCode, npanxxValue } STATUS current DESCRIPTION "This notification indicates that the EMS/NE has rejected the NPANXX GTT creation, deletion or modification transaction for the specified NPANXX value." ::= {tekelecLSMSEventsVer 127 }overrideGTTValueNotFound NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI, operationCode } STATUS current DESCRIPTION "This notification indicates that the EMS/NE has rejected the Override GTT creation, deletion or modification transaction, and the LRN value in the transaction could not be determined." ::= {tekelecLSMSEventsVer 128 }overrideGTTValueRejected NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI, operationCode, lRN } STATUS current DESCRIPTION "This notification indicates that the EMS/NE has rejected the Override GTT creation, deletion or modification transaction for the specified LRN value." ::= {tekelecLSMSEventsVer 129 }secondaryEMSAssocLost NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS has lost association with the secondary EMS, the primary association is still up." ::= {tekelecLSMSEventsVer 130 }unableToCompleteAutoResynch NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS was not able to complete automatic synchronization with the EMS/NE." ::= {tekelecLSMSEventsVer 131 }autoResynchNEStarted NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS has started its automatic synchronization with the EMS/NE." ::= {tekelecLSMSEventsVer 132 }dbResynchCompleted NOTIFICATION-TYPE OBJECTS { eventNbr, npacId } STATUS current DESCRIPTION "This notification indicates that the Automatic resynchronization of databases after an outage between the LSMS and the NPAC has completed successfully." ::= {tekelecLSMSEventsVer 133 }secondaryEMSAssocEstablished NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS has established the second association with the EMS. This association is only established if a primary association already exists." ::= {tekelecLSMSEventsVer 134 }emsShortSynchCompleted NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the LSMS has completed Short Synchronization with the EMS." ::= {tekelecLSMSEventsVer 138 }transactionToSecondary NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that the Primary EMS association is either down or is inhibited, such that transaction sent to the primary EMS will not be received by the network element. Transactions are being sent to the secondary EMS instead of the primary EMS." ::= {tekelecLSMSEventsVer 139 }pendingQueueHalfFullClear NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the EMS Pending Queue is less than half full." ::= {tekelecLSMSEventsVer 141 }pendingQueueFullClear NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the EMS Pending Queue is no longer full." ::= {tekelecLSMSEventsVer 142 }dcmConnectionRestored NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that physical connection has been restored with the DCM." ::= {tekelecLSMSEventsVer 143 }connToMqSeriesQueueMngrRest NOTIFICATION-TYPE OBJECTS { eventNbr, queueMgrName } STATUS current DESCRIPTION "This notification indicates that the connection to the MQSeries local queue manager has been established following an outage." ::= {tekelecLSMSEventsVer 144 }npaNxxOpenedForPortabilityAtTS NOTIFICATION-TYPE OBJECTS { eventNbr, sPID, nPANXX, effectiveTimeStamp } STATUS current DESCRIPTION "This notification indicates that the specified NPA-NXX is opened for portability starting at value of the EffectiveTimeStamp field." ::= {tekelecLSMSEventsVer 145 }npaNxxPortedAtTS NOTIFICATION-TYPE OBJECTS { eventNbr, sPID, nPANXX, effectiveTimeStamp } STATUS current DESCRIPTION "This notification indicates that the first telephone number in the specified NPA-NXX is ported stating at the value of the EffectiveTimeStamp field." ::= {tekelecLSMSEventsVer 146 }ebdaAuditActive NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that an Audit is currently running." ::= {tekelecLSMSEventsVer 147 }ebdaAuditSuccess NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that an Audit has completed successfully." ::= {tekelecLSMSEventsVer 148 }ebdaAuditFailure NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that an Audit has failed." ::= {tekelecLSMSEventsVer 149 }ebdaAuditAbortedByUser NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that an Audit has been aborted by the user prior to completion." ::= {tekelecLSMSEventsVer 150 }ebdaReconcileActive NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a reconcile is currently running." ::= {tekelecLSMSEventsVer 151 }ebdaReconcileSuccess NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a reconcile has completed successfully." ::= {tekelecLSMSEventsVer 152 }ebdaReconcileFailure NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a reconcile has failed." ::= {tekelecLSMSEventsVer 153 }ebdaReconcileAbortedByUser NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a reconcile has been aborted by the user prior to completion." ::= {tekelecLSMSEventsVer 154 }ebdaBulkLoadActive NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a bulk load is currently running." ::= {tekelecLSMSEventsVer 159 }ebdaBulkLoadSuccess NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a bulk load has completed successfully." ::= {tekelecLSMSEventsVer 160 } ebdaBulkLoadFailure NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a bulk load has failed." ::= {tekelecLSMSEventsVer 161 }ebdaBulkLoadAbortedByUser NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a bulk load has been aborted by the user prior to completion." ::= {tekelecLSMSEventsVer 162 }ebdaResyncActive NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a re-sync is currently running." ::= {tekelecLSMSEventsVer 163 }ebdaResyncSuccess NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a re-sync has completed successfully." ::= {tekelecLSMSEventsVer 164 }ebdaResyncFailure NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a re-sync has failed." ::= {tekelecLSMSEventsVer 165 }ebdaResyncAbortedByUser NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI } STATUS current DESCRIPTION "This notification indicates that a re-sync has been aborted by the user prior to completion." ::= {tekelecLSMSEventsVer 166 }sprintIddAgentCommFailureLegSys NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Sprint lddAgent has failed to communicate with the Sprint Legacy System." ::= {tekelecLSMSEventsVer 167 }sprintIddAgentCommFailureScpmsSys NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Sprint lddAgent has failed to communicate with the Sprint SCPMS System." ::= {tekelecLSMSEventsVer 168 }lsmsMirroringInconsistance NOTIFICATION-TYPE OBJECTS { eventNbr, volumeName } STATUS current DESCRIPTION "This notification indicates an LSMS mirroring inconsistentane." ::= {tekelecLSMSEventsVer 169 }lsmsFilesystemNotWritable NOTIFICATION-TYPE OBJECTS { eventNbr, fileSystem } STATUS current DESCRIPTION "This notification indicates that the LSMS filesystem is not writeable." ::= {tekelecLSMSEventsVer 170 }automaticFileTransferFeatureFailure NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the Automatic File Transfer feature has a failure." ::= {tekelecLSMSEventsVer 171 }npaSplitActFailed NOTIFICATION-TYPE OBJECTS { eventNbr, oldNPA, newNPA, nXX } STATUS current DESCRIPTION "This notification indicates the failure of an NPASplit activation." ::= {tekelecLSMSEventsVer 172 }activeSplitsPastEndDates NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that some active splits are past their End Dates and should be deleted." ::= {tekelecLSMSEventsVer 173 }lddScpmsAgentSwitchToBackupScpms NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates the LDD SCPMS agent is switching from primary to backup SCPMS system." ::= {tekelecLSMSEventsVer 174 }lddScpmsAgentSwitchFromBackupToPrim NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates the LDD SCPMS agent is switching from backup to primary SCPMS system." ::= {tekelecLSMSEventsVer 175 }lddScpmsPrimary NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates the LDD SCPMS current system is primary SCPMS." ::= {tekelecLSMSEventsVer 176 }lddScpmsBackup NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates the LDD SCPMS current system is backup SCPMS." ::= {tekelecLSMSEventsVer 177 }emsNeRejNpaNxxSplitNotDetermined NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI, operationCode } STATUS current DESCRIPTION "This notification indicates that the EMS/NE has rejected the NPANXX Split creation or deletion transaction, and the NPANXX value in the transaction could not be determined." ::= {tekelecLSMSEventsVer 178 }emsNeRejectedNpaNxxSplit NOTIFICATION-TYPE OBJECTS { eventNbr, neCLLI, operationCode, nPANXX } STATUS current DESCRIPTION "This notification indicates that the EMS/NE has rejected the NPANXX Split creation or deletion transaction for the specified NPANXX value." ::= {tekelecLSMSEventsVer 179 }physicalConnectivityWithQueryServerLost NOTIFICATION-TYPE OBJECTS { eventNbr, hostname } STATUS current DESCRIPTION "This notification indicates that the LSMS is not able to confirm the physical connectivity with the Query Server for the specified hostname." ::= {tekelecLSMSEventsVer 180 }queryServerConnectionWithLsmsLost NOTIFICATION-TYPE OBJECTS { eventNbr, hostname } STATUS current DESCRIPTION "This notification indicates that the Query Server identified by the hostname does not have a connection with the LSMS." ::= {tekelecLSMSEventsVer 181 }nPACagentStopRegDBaccessFault NOTIFICATION-TYPE OBJECTS { eventNbr, nPACRegion } STATUS current DESCRIPTION "This notification indicates that the NPACagent process has been stopped due to fault in accessing the regional database." ::= {tekelecLSMSEventsVer 189 }swapSpaceWarning NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the server's system check has raised a swap space warning alarm." ::= {tekelecLSMSEventsVer 190 }minorPlatAlarmMask NOTIFICATION-TYPE OBJECTS { eventNbr, alarmBitMask } STATUS current DESCRIPTION "This notification indicates that minor Platform alarms have been raised as indicated by the alarm BitMask." ::= {tekelecLSMSEventsVer 191 }majorPlatAlarmMask NOTIFICATION-TYPE OBJECTS { eventNbr, alarmBitMask } STATUS current DESCRIPTION "This notification indicates that major Platform alarms have been raised as indicated by the alarm BitMask." ::= {tekelecLSMSEventsVer 192 }criticalPlatAlarmMask NOTIFICATION-TYPE OBJECTS { eventNbr, alarmBitMask } STATUS current DESCRIPTION "This notification indicates that critical Platform alarms have been raised as indicated by the alarm BitMask." ::= {tekelecLSMSEventsVer 193 }svNpbPercentUsage NOTIFICATION-TYPE OBJECTS { eventNbr, svNpbThreshold, svNpbUsage } STATUS current DESCRIPTION "This notification indicates that the SV/NPB storage database has exceeded the configured percent usage threshold." ::= {tekelecLSMSEventsVer 194 }dataReplClear NOTIFICATION-TYPE OBJECTS { eventNbr, dbReplErr } STATUS current DESCRIPTION "This notification indicates that the system is ready for database replication." ::= {tekelecLSMSEventsVer 195 }dbMonitorClear NOTIFICATION-TYPE OBJECTS { eventNbr, dbMonErr } STATUS current DESCRIPTION "This notification indicates that the DB process monitor has been cleared." ::= {tekelecLSMSEventsVer 196 } minorPlatAlarmClear NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the server's system check process has cleared all minor platform alarms." ::= {tekelecLSMSEventsVer 197 } majorPlatAlarmClear NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the server's system check process has cleared all major platform alarms." ::= {tekelecLSMSEventsVer 198 } criticalPlatAlarmClear NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that the server's system check process has cleared all critical platform alarms." ::= {tekelecLSMSEventsVer 199 }dbCorruptIndex NOTIFICATION-TYPE OBJECTS { eventNbr, dbMonErr } STATUS current DESCRIPTION "This notification indicates that the LSMS database has corruption." ::= {tekelecLSMSEventsVer 200 }invalidSnapshot NOTIFICATION-TYPE OBJECTS { eventNbr, dbMonErr } STATUS current DESCRIPTION "This notification indicates that the LSMS server has an Invalid Snapshot." ::= {tekelecLSMSEventsVer 201 }invalidSnapshotClear NOTIFICATION-TYPE OBJECTS { eventNbr, dbMonErr } STATUS current DESCRIPTION "This notification indicates that the Invalid Snapshot has been cleared from the LSMS server." ::= {tekelecLSMSEventsVer 202 }fullSnapshot NOTIFICATION-TYPE OBJECTS { eventNbr, dbMonErr } STATUS current DESCRIPTION "This notification indicates that the snapshot space usage is greater than the MAX_USAGE percent." ::= {tekelecLSMSEventsVer 203 }fullSnapshotClear NOTIFICATION-TYPE OBJECTS { eventNbr, dbMonErr } STATUS current DESCRIPTION "This notification indicates that the snapshot full space usage Error is cleared." ::= {tekelecLSMSEventsVer 204 }mateServerDown NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that mate server is Down." ::= {tekelecLSMSEventsVer 205 }mateServerUp NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that mate server is Up." ::= {tekelecLSMSEventsVer 206 }svNpbBelowLimit NOTIFICATION-TYPE OBJECTS { eventNbr, svNpbThreshold, svNpbUsage } STATUS current DESCRIPTION "This notification indicates that the SV/NPB storage database usage is below the configured percent usage threshold." ::= {tekelecLSMSEventsVer 207 }mysqlPortUpdated NOTIFICATION-TYPE OBJECTS { eventNbr, oldMySQLPortNumber, newMySQLPortNumber } STATUS current DESCRIPTION "This notification indicates that the MySQL Port has been updated. LSMS application restart is required." ::= {tekelecLSMSEventsVer 208 }queryServerResetConfiguration NOTIFICATION-TYPE OBJECTS { eventNbr, oldMySQLPortNumber, newMySQLPortNumber } STATUS current DESCRIPTION "This notification indicates that the MySQL Port has been updated. Query Server configuration needs to be updated." ::= {tekelecLSMSEventsVer 209 }purgeConfirmRequired NOTIFICATION-TYPE OBJECTS { eventNbr } STATUS current DESCRIPTION "This notification indicates that at least one of the directly connected query server is out of sync and binary log purging requires confirmation from the user." ::= {tekelecLSMSEventsVer 210 }purgeImminent NOTIFICATION-TYPE OBJECTS { eventNbr, binlogsThreshold } STATUS current DESCRIPTION "This notification indicates that the disk usage is reaching the threshold and forceful purge of binary logs is imminent." ::= {tekelecLSMSEventsVer 211 }resyncStartTrap NOTIFICATION-TYPE OBJECTS { lsmsUptime, sourceIP } STATUS current DESCRIPTION "The trap is sent by the LSMS to NMS when the LSMS is about to start resynchronization" ::= {tekelecLSMSEventsVer 212 }resyncStopTrap NOTIFICATION-TYPE OBJECTS { lsmsUptime, sourceIP, resyncEventCnt, resyncErrCode } STATUS current DESCRIPTION "The trap is sent by the LSMS to NMS when resynchronization is complete" ::= {tekelecLSMSEventsVer 213 }resyncRejectTrap NOTIFICATION-TYPE OBJECTS { lsmsUptime, sourceIP, resyncErrCode } STATUS current DESCRIPTION "The trap is sent by the LSMS to NMS when a resynchronization request is rejected by LSMS " ::= {tekelecLSMSEventsVer 214 }resyncRequiredTrap NOTIFICATION-TYPE OBJECTS { lsmsUptime, sourceIP } STATUS current DESCRIPTION "The trap is sent by the LSMS to NMS when the LSMS is rebooted or LSMS is started" ::= {tekelecLSMSEventsVer 215 }heartBeatTrap NOTIFICATION-TYPE OBJECTS { lsmsUptime, sourceIP } STATUS current DESCRIPTION "The trap is sent by the LSMS to NMS periodically to indicate that the LSMS is up" ::= {tekelecLSMSEventsVer 216 }lsmsAlarmTrapV3 NOTIFICATION-TYPE OBJECTS { currentTime,specificOid ,sourceIP, alarmSequence,specificAlarm} STATUS current DESCRIPTION "The trap will indicate that the following information is for a perticular event" ::= {tekelecLSMSEventsVer 217 }resyncErrCode OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "errorCode = 0, Resynchronization completed successfully. errorCode = 1, Resynchronization aborted by NMS. errorCode = 2, Resynchronization already in progress for the NMS. errorCode = 3, Resynchronization Aborted, Database error occurred. errorCode = 4, Resynchronization not in progress." ::= { tekelecLSMSEventsVer 218 }END
LSMS-NAS-MIB
LSMS-NAS-MIB DEFINITIONS ::= BEGIN-- Copyright 2000 Tekelec CorporationIMPORTS enterprises FROM RFC1155-SMI OBJECT-TYPE FROM RFC-1212 TRAP-TYPE FROM RFC-1215;tekelecCorp OBJECT IDENTIFIER ::= { enterprises 323 }tekelecPrivate OBJECT IDENTIFIER ::= { tekelecCorp 1 }tekelecRegistration OBJECT IDENTIFIER ::= { tekelecCorp 2 }tekelecGeneric OBJECT IDENTIFIER ::= { tekelecCorp 3 }tekelecCapabilities OBJECT IDENTIFIER ::= { tekelecCorp 4 }tekelecProductGroups OBJECT IDENTIFIER ::= { tekelecCorp 5 }tekelecRequirements OBJECT IDENTIFIER ::= { tekelecCorp 6 }tekelecExperimental OBJECT IDENTIFIER ::= { tekelecCorp 7 }tekelecCallCenterGroup OBJECT IDENTIFIER ::= { tekelecProductGroups 1 }tekelecDiagnosticsGroup OBJECT IDENTIFIER ::= { tekelecProductGroups 2 }tekelecSwitchingGroup OBJECT IDENTIFIER ::= { tekelecProductGroups 3 }experimental OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 1 }generic OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 2 }tekelecEAGLE OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 3 }tekelecLSMS OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 4 }tekelecOAP OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 5 }tekelecIP7 OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 6 }tekelecINSIGHT7 OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 7 }tekelecTALON OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 8 }tekelecVOX OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 9 }tekelecSCP OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 10 }tekelecIVR OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 11 }tekelecNetworkSwitch OBJECT IDENTIFIER ::= { tekelecSwitchingGroup 12 }-- LSMS Object group sub-treetekelecLSMSObjects OBJECT IDENTIFIER ::= { tekelecLSMS 1 }-- LSMS Product Events sub-treetekelecLSMSEvents OBJECT IDENTIFIER ::= { tekelecLSMS 2 }-- LSMS Events Object group sub-treetekelecLSMSEventObjects OBJECT IDENTIFIER ::= { tekelecLSMSObjects 1 }-- LSMS SNMPv1 EventstekelecLSMSEventsV1 OBJECT IDENTIFIER ::= { tekelecLSMSEvents 0 } volumeNearlyFull TRAP-TYPE ENTERPRISE tekelecLSMSEventsV1 DESCRIPTION "At least one volume is more than 95% full. The string sent with the trap gives the name of the volume or volumes which exceed the threshold." ::= 212 volumeRepaired TRAP-TYPE ENTERPRISE tekelecLSMSEventsV1 DESCRIPTION "All volumes are now under 95% full." ::= 213 diskFailed TRAP-TYPE ENTERPRISE tekelecLSMSEventsV1 DESCRIPTION "One or more disks failed. The trap includes a string describing the failed disk(s)." ::= 214 diskRepaired TRAP-TYPE ENTERPRISE tekelecLSMSEventsV1 DESCRIPTION "The failed disks have been repaired." ::= 215END
The LSMS SNMP Agent Implementation
The LSMS SNMP agent process supports only the SNMP version 1 trap operation. The SNMP agent receives (through UDP Linux sockets) LSMS notification events from the following processes and formats these events into trap requests:
- The Surveillance process, which continually monitors the LSMS hardware and software.
- The LSMS graphical user interface (GUI) process.
- One or more regional agent (
npacagent) processes, each of which receives commands from Number Portability Administration Centers (NPACs) and the GUI process, interprets those commands, and initiates appropriate LSMS activities to manage regional NPAC data. The LSMS can support up to eight regions; each region corresponds to an NPAC. - One or more
eagleagentprocesses, each of which receives commands from the GUI process, interprets those commands, and initiates appropriate LSMS activities to send data to the network elements. The LSMS can support up to eight pairs of network elements. - The Local Data Manager (
supman) process, which manages locally provisioned data that is entered through the GUI and sent to the network elements which the LSMS supports.
The LSMS SNMP agent formats the information received from these processes into an SNMPv1 trap protocol data unit (PDU) and sends the trap request to one or more NMSs. Each NMS (provided by the customer) has a local copy of the LSMS MIB. When the NMS receives a trap request from the LSMS, it compares the information in the trap request to information in its own MIB to determine what event has occurred at the LSMS.
For information about the format of a trap and which events are reported in traps, see Automatic Monitoring of Events
Configuring the SNMP Agent
If you install the optional Remote Monitoring feature, refer to the Configuration Guide to configure the IP addresses and community names for each of the NMSs to which you want the LSMS to send trap requests. You can also perform this procedure if you want to add or delete NMSs after you have started the LSMS. The LSMS can support up to five NMSs simultaneously.
Controlling the SNMP Agent
If the optional Remote Monitoring feature is installed,
it is managed by the
sentry process (sentryd)
and can also be controlled by the user.
After the
LSMS boots up, the
constantly monitors the
LSMS
SNMP agent process. If
the
SNMP agent process exits
abnormally, the
restarts it.
Any user who belongs to the
lsmsadm permission group can use the
lsmsSNMP command to start, stop, or
display status of the
LSMS
SNMP agent.
2.9.3 Determining the Status of the SNMP Agent
Perform the following procedure to determine the status of the SNMP agent process:
2.9.4 Logging SNMP Agent Actions
When the LSMS SNMP agent process starts, stops, or sends a trap request, it logs information about the action in a log file. The log file is named lsmsSNMP.log<MMDD>, where <MMDD> represents the current month and day. The log file is stored in the directory /usr/TKLC/lsms/logs/snmp and is automatically deleted after 7 days. If either the log file or its directory does not already exist, the agent process creates the file or the directory, or both, when one of these actions occurs.
The log file has a maximum size of 5 MB. After the log is completely filled, its contents are copied to a backup file lsmsSNMP.log.backup in the same directory, and actions are logged from the beginning of a fresh lsmsSNMP.log file.
For more information about what is logged in this file, see “Logging SNMP Agent Actions”.
2.10 Configuring the SNMP Agent
To configure trap forwarding, follow these general steps:
- Set the SNMP global mode as needed.
See SNMP Global Mode.
If the SNMPv1 ONLY mode is set, skip to step 5.
SNMPv1 provides no authentication and no privacy. - Configure SNMPv3 views.
- Configure one or more SNMPv3 groups that use the SNMPv3 views.
- Configure SNMPv3 users associated with the SNMPv3 groups.
- Configure the NMS on LSMS.
See NMS Configuration.
- Configure the NMS.
To see what was configured in step 5, use .
2.11 SNMP Global Mode
LSMS supports three SNMP global modes:
- SNMPv1 ONLY
- SNMPv3 ONLY
- Both
By default after a fresh installation or upgrade/re-installation, LSMS supports only the SNMPv3 ONLY global mode. SNMPv3 trap forwarding is recommended because of the encryption and secured authentication mechanisms provided.
For SNMPv1 trap forwarding, you can choose to change the SNMP global mode setting to Both or SNMPv1 ONLY.
SNMPv1 provides no authentication and no privacy.Figure 2-8 Set Global Mode
Following are details on the SNMP global modes:
- SNMPv1 ONLY
Selecting this mode results in LSMS supporting only SNMPv1 as follows:
- LSMS will forward SNMPv1 traps to only NMS(s) configured to support SNMPv1.
- LSMS will allow addition of any new NMS that supports SNMPv1, and will not allow modification of an existing SNMPv1-based NMS to SNMPv3.
- Prior to changing the mode to SNMPv3 ONLY, any NMS(s) configured (as in NMS Configuration) to support SNMPv1 must be removed.
- SNMPv3 ONLY (recommended mode)
Selecting this mode results in LSMS supporting only SNMPv3 as follows:
- LSMS will forward SNMPv3 traps to only NMS(s) configured to support SNMPv3.
- LSMS will allow addition of any new NMS that supports SNMPv3, and will not allow modification of an existing SNMPv3-based NMS to SNMPv1.
- Prior to changing the mode to SNMPv1 ONLY, any NMS(s) configured (as in NMS Configuration) to support SNMPv3 must be removed. Changing the mode to SNMPv1 ONLY is not recommended.
- Both
Selecting this mode results in LSMS supporting both SNMPv1 and SNMPv3 as follows:
- LSMS will forward traps to all NMS(s) configured to support SNMPv1 or SNMPv3.
- LSMS will allow addition of any new NMS that supports SNMPv1 or SNMPv3.
- LSMS will allow update of any NMS that supports SNMPv1 or SNMPv3.
2.12 SNMPv3 Access View Management
To support view-based access control for SNMPv3, LSMS provides the menu options. These menu options are accessible only when the SNMP Global Mode is set to SNMPv3 ONLY or Both. Following is an example of the Add menu.
Figure 2-9 Add SNMPv3 View Screen
The submenus include fields for the View Name and the OID of the associated LSMS MIB object.
View names must be unique, 1 - 32 alphanumeric characters in length, and are case sensitive. The OID associated with a view is mandatory.
The resyncVar object with OID 1.3.6.1.4.1.323.5.3.4.1.1.45 is the only object available in the LSMS MIB for read/write operations by a NMS. By default, LSMS provides a view named resyncVarView that is sufficient for controlling read/write access to the resyncVar object. The resyncVarView cannot be modified or deleted. Use of another OID for view configuration is not restricted.
A view that is associated to any group cannot be deleted. For information about groups, see SNMPv3 Group Management.
2.13 SNMPv3 Group Management
To support user-based security for SNMPv3, LSMS provides the menu options. These menu options are accessible only when the SNMP Global Mode is set to SNMPv3 ONLY or Both. Following is an example of the Add menu.
Figure 2-10 Add Group Screen
The Group Name must be unique, 1 - 32 alphanumeric characters in length, and is case sensitive.
Table 2-6 SNMPv3 Security Levels
| Level | Authentication | Encryption | Details |
| noAuthNoPriv (no authentication, no privacy) |
Username | No | Uses a username match for authentication |
| AuthNoPriv (authentication, no privacy) |
Yes (SHA) | No | Provides authentication based on the algorithms available in the net-snmp API |
| AuthPriv (authentication and privacy) | Yes (SHA) | Yes (DES/AES) | Provides authentication and encryption based on the algorithms available in the net-snmp API |
The Read View name is optional, and must be specified exactly as configured in the view. The specified view must already be configured to be added to the group. If a read view is not selected for a group, the group will not have read access to any of the LSMS MIB objects.
The Write View name is optional, and must be specified exactly as configured in the view. The specified view must already be configured to be added to the group. If a write view is not selected for a group, the group will not have write access to any of the LSMS MIB objects.
A group that is associated with any user cannot be deleted. For information about users, see SNMPv3 User Management.
2.14 SNMPv3 User Management
To support user-based security for SNMPv3, LSMS provides the menu options. These menu options are accessible only when the SNMP Global Mode is set to SNMPv3 ONLY or Both. Following is an example of the initial Add menu.
Figure 2-11 Initial Add User Screen
The User Name must be unique, 1 - 50 alphanumeric characters in length, and is case sensitive.
The Group Name must be already configured to be specified for a user, and must exactly match (case sensitive) a configured group name.
- If the security level configured for the specified group is noAuthNoPriv, user configuration is complete.
- If the security level configured for the specified group is AuthNoPriv or AuthPriv, a second screen is displayed containing the configured security fields for the specified group. Following is an example for a group having the AuthPriv security level:
Figure 2-12 Add User Screen for AuthPriv
When the security level configured for the specified group is AuthNoPriv, input fields Priv Protocol, and Priv Password will not be displayed.Select or specify the Auth Protocol, Auth Password, Priv Protocol, and Priv Password fields as needed:
- The default and only valid value for Auth Protocol is SHA.
- Valid values for Priv Protocol are DES and AES.
- The Auth Password and Priv Password fields must be 8 - 255 characters in length. Valid characters include alphanumeric characters and the following special characters:
The Auth Password and Priv Password fields are encrypted in the database.
A user that is associated with any NMS cannot be deleted. For information about associating a user with an NMS, see NMS Configuration.
2.15 NMS Configuration
To configure the NMS with which LSMS will interact to send alarms, LSMS provides the menu options. The specific screen/submenu displayed depends upon the SNMP global mode set in SNMP Global Mode (the default mode is SNMPv3 ONLY).
- Name
- The Name is a unique logical name for the NMS server consisting of 5 - 20 alphanumeric, case-sensitive characters. The Name is mandatory for SNMPv3 configuration and optional for SNMPv1 configuration.
- IP
- The IP must be non-empty and unique.
- Port
- The Port must be a valid value in the range 1 - 65535, excluding the pre-defined ports.
Figure 2-13 Add an NMS Server Screen for SNMPv1 ONLY
The community string is stored in encrypted form in the database.
For the SNMPv3 ONLY mode, in addition to the commone fields, the HeartBeat (sec) and User fields are also displayed.
Figure 2-14 Add an NMS Server Screen for SNMPv3 ONLY
Valid values for the HeartBeat (sec) field are 0 or between 5 - 7200, with a default value of 60.
The User field is mandatory, and must be specified exactly (case sensitive) as previously configured (see SNMPv3 User Management).
If the SNMP Global Mode is Both, all previous fields are displayed along with the SNMP Version field. Either v3 or v1 must be selected for SNMP Version.
Figure 2-15 Add an NMS Server Screen for Both
When the SNMP Global Mode is Both, the SNMP Community String and User fields are mutually exclusive. The HeartBeat (sec) field is applicable only for SNMPv3.
Run the following command to restart TKLCsnmp services
# systemctl restart TKLCsnmp
2.16 Autonomous Events Trap Forwarding
The LSMS SNMP agent forwards all autonomous events generated at the LSMS, in the form of SNMPv1 traps to an NMS configured for SNMPv1 or SNMPv3 traps to an NMS configured for SNMPv3. A circular queue is maintained to support asynchronized trap requests so that traps are not missed if an NMS is disconnected from LSMS for any reason.
Trap forwarding from LSMS to an SNMPv3-based NMS is the same as to an SNMPv1-based NMS, except for the following:
- A new varbind currentTime is introduced in the LSMS MIB to indicate the time when an alarm was generated.
- A new varbind sourceIp is introduced in the LSMS MIB to include the source IP address of the network element in traps.
- A new varbind alarmSequence is introduced in the LSMS MIB to maintain a sequence number with traps. The minimum sequence number value is 1 and the maximum value is 4294967295, after which the value will roll over.
- The trap PDU includes additional information related to the USM entry for the NMS.
- LSMS sends heartbeat traps to an NMS periodically to indicate that the connection is still up. The periodicity of the heartbeat trap is the HeartBeat (sec) value configured for the NMS.
2.17 Resynchronization
The MIB element resyncVar is supported and its value used to coordinate the alarm resynchronization process. The value is set to 1 to start resynchronization. Get and set operations are allowed only for resyncVar.
2.18 Connectivity between LSMS and NMS
LSMS listens at SNMP agent standard port 161 for Get/Set messages. When a Get/Set message is received, LSMS checks the Set message for validity (whether the v3 user that sent the Set request for resyncVar is valid and has permission to set the variable). If the request is valid, resyncVar is set and thereafter the alarm resynchronization mechanism (including error scenarios) between LSMS and the v3-based NMS will start.
