A MSS User Interface Impacted by the Resolution Process
This appendix provides information on Oracle Communications MetaSolv Solution (MSS) user interface (UI) windows, which are impacted during the Address Correction Utility resolution process.
Table A-1 lists the MSS UI that may be impacted after the resolution processing by the Address Correction utility based on the resolution scenario.
Table A-1 MSS UI Impacted After Resolution Process
Subsystem MSS UI Impacted Navigation Applicable Scenario
Connection Design
Locations tab
In the Connection Design window, under Provisioning, click the Additional Detail link, and then click the Locations tab.
Scenario 1Foot 1
Scenario 2Foot 2
Scenario 3Foot 3
Connection Design
Connection Design Search window
On the navigation bar, select Inventory Management, and then click Connection Design.
Scenario 11
Scenario 33
Connection Design
Equipment Assignments tab
In the Connection Design window, under Provisioning, click the CLR/DLR Design link, and then click the Reconcile Assignments link. In the Connection Reconciliation window, click the Equipment Assignments tab.
Scenario 11
Scenario 33
Connection Design
Connection Summary view
In the Connection Design window, click the Connection Summary link.
Scenario 11
Scenario 22
Scenario 33
Connection Design
Print Preview window
In the Connection Design window, from the Outputs menu, select Preview CLR or Preview CLR/DLR.
In the Trouble Ticket Queue window or the Trouble Ticket Search window, click the Service Item tab, and then click View Design.
Scenario 11
Scenario 22
Scenario 33
Connection Design
CLR/DLR Design view
In the Connection Design window, under Provisioning, click the CLR/DLR Design link.
Scenario 11
Scenario 33
Connection Design
Schematic Design view
In the Connection Design window, under Provisioning, click the Schematic Design link.
Scenario 11
Scenario 22
Scenario 33
Connection Design
Activation Report
In the Connection Design window, from the Outputs menu, select Activation Report.
In the Trouble Ticket Queue window or the Trouble Ticket Search window, click the Service Item tab, and then click View Activation Rpt.
Scenario 11
Scenario 22
Scenario 33
Product Service Request
Service Location
In the Product Service Request window, under Order Maintenance, click the Services link.
Scenario 11
Scenario 22
Scenario 33
PRILOC/SECLOC Info tab
In the Product Service Request window, under Order Maintenance, click the Services link. Expand the product hierarchy, select a service item, and then click the PRILOC/SECLOC Info tab. The PRILOC/SECLOC Info tab is displayed only for the products that have information about primary location and secondary location.
Scenario 11
Scenario 22
Scenario 33
Summary Info tab
In the Product Service Request window, under Order Maintenance, click the Services link. Expand the product hierarchy, select a service item, and then click the Summary Info tab.
Scenario 11
Scenario 22
Scenario 33
Do you want to include any of these existing locations? window.
In the PSR Ordering Dialog, click the Existing Locations link.
Scenario 11
Scenario 22
Scenario 33
Is the list of locations correct? window
In the PSR Ordering Dialog, click the List of Locations link.
Scenario 11
Scenario 22
Scenario 33
Product History tab
In the Service Request Search window, click the Product History tab.
Scenario 11
Scenario 22
Scenario 33
New PSR Order from Existing PSR Order
In the Service Request Search window, select a service request. From the File menu, select New From.
Scenario 11
Scenario 22
Scenario 33
PSR Order Split Selection window
In the Service Request Search window, select a service request and select Order Split.
Scenario 11
Scenario 22
Scenario 33
Address tab
In the TN Records Search window, open a telephone number. In the E911 Extract window, click the Address tab.
Scenario 22
Customer Accounts
List of Customer Locations window
In the Customer Account Search window, from the Options menu, select Customer Profile. In the Customer Summary window, under Related Pages, click the Locations link.
Scenario 11
Scenario 22
Scenario 33
Customer Accounts
List of Circuits/Connections window
In the Customer Account Search window, from the Options menu, select Customer Profile. In the Customer Summary window, under Related Pages, click the Circuits/Connections link.
Scenario 11
Scenario 22
Scenario 33
Customer Accounts
Customer Product Transfer window
In the Customer Account Search window, from the Options menu, select Customer Profile. In the Customer Summary window, under Actions, click the Transfer link.
Scenario 11
Scenario 22
Scenario 33
Customer Accounts
Customer Services window
In the Customer Account Search window, open a customer account. In the Customer Summary window, under Related Pages, click the Services link.
Scenario 11
Scenario 22
Scenario 33
Equipment
Location Search window - Results tab
On the navigation bar, select Inventory Management, and then click Equipment Inventory. Click the query button beside the Location field. In the Location Search window, enter any search criteria and click Search, and then click the Results tab.
Scenario 11
Scenario 33
Equipment
Equipment Inventory window
Scenario 11
Scenario 33
Equipment
Hard-Wired Cross-Connects window
In the Equipment Inventory window, right-click an equipment that you want to cross-connect and select Cross-Connect. Right-click another equipment and select Cross-Connect To.
Scenario 11
Scenario 33
Equipment
Assembly Cross-Connect Report
In the Equipment Inventory window, right-click an equipment and select X-con Report.
Scenario 11
Scenario 33
Dedicated Plant
Dedicated Plant Search window
On the navigation bar, select Inventory Management, and then click Dedicated Plant.
Scenario 11
Scenario 22
Scenario 33
Dedicated Plant
Dedicated Plant Maintenance window
In the Dedicated Plant Search window, open a dedicated plant.
Scenario 11
Scenario 22
Scenario 33
Network System
Managing a Component window
In the Network System Design window, right-click a component and select Properties.
Scenario 11
Scenario 33
Network System
On the navigation bar, select Inventory Management, and then click Network Systems. On the Network List panel, double-click a template type or click the menu icon and select Search, and then double-click a network system.
Scenario 11
Scenario 22
Scenario 33
Network System
Network System Print Preview
Open a network system. From the File menu, select Print. In the Network Design Print window, click Preview.
In the Trouble Ticket Queue window or the Trouble Ticket Search window, click the Service Item tab, and then click View Net Design.
Scenario 11
Scenario 33
Network System
Customer Connections window
In the Network System Design window, right-click a component and select Customer Connections.
Scenario 22
Network System
Viewing Extensions window
In the Network System Design window, right-click a component and select Customer Connections. Double-click the Customer Connections window.
Scenario 22
End User Location
End User Location Maintenance window
In the End User Location Search window, open an end user location.
Scenario 11
Scenario 22
Scenario 33
End User Location
Additional Addresses tab
In the End User Location Maintenance window, click the Additional Addresses tab.
Scenario 11
Scenario 22
Scenario 33
End User Location
Terminal Location window
In the Terminal Location Search window, open a terminal location. In the Terminal Location window, click the rightmost icon at the bottom of the window.
Scenario 11
Scenario 22
Scenario 33
Access Service Request
Service Address Location Information List window
Open an ASR order. Under SALI, click Address Detail.
Scenario 11
Scenario 22
Scenario 33
Service Address Location Information Maintenance window
Open an ASR order. Under SALI, click Address Detail. In the Service Address Location Information List window, double-click a link.
Scenario 11
Scenario 22
Scenario 33
CABS Billing Navigator window
In the Service Request Search window, from the Options menu, select CABS Billing.
Scenario 11
Scenario 22
Scenario 33
Local Service Request
Location and Access Maintenance window
Open an LSR order, under End User, click Location and Access List.
Scenario 11
Scenario 22
Scenario 33
Location and Access Detail window
Open an LSR order, under End User, click Location and Access List. In the Location and Access Maintenance window, click a link in the LOCNUM column.
Scenario 11
Scenario 22
Scenario 33
Service-specific forms
Open an LSR order and navigate to the service-specific form, and then click a link in the LOCNUM column.
Scenario 11
Scenario 33
Internal Service Request
Locations tab
In the Service Request Search window, open an ISR order, and then click the Locations tab.
Scenario 11
Scenario 22
Scenario 33
Internal Service Request Location Maintenance window
In the Service Request Search window, open an ISR order, and then click the Locations tab. On the Locations tab, double-click a location.
Scenario 11
Scenario 22
Scenario 33
Engineering Work Order
Manage Equipment view
In the Engineering Work Order Search window, open a work order. In the Engineering Work Order Summary window, under Related Pages, click the Manage Equipment link.
Scenario 11
Scenario 33
Trouble Ticket
Service Item tab
On the navigation bar, select Order Management, and then click Trouble Ticker Queue. In the Trouble Ticket Queue window, click the Service Item tab.
Scenario 11
Scenario 22
Scenario 33
Footnote 1
Scenario 1: Multiple end user locations having the same address.
Footnote 2
Scenario 2: Multiple active addresses of same address format at the same end user location.
Footnote 3
Scenario 3: Multiple end user locations having the same address in MSAG and OBF structured formats.
