I Environment Planning Worksheet
This appendix contains worksheets to use in your environment planning.
Environment Profiles
Use Table I-1 and Table I-2 to write down your hardware and software specifications, for example disk size, type, processor speed, and operating system type/version.
Table I-1 Hardware/Software Specifications for the Current Environment
Environment and Purpose AppServers DB Servers Background Processor Citrix Server Max Concurrent Users
Test
Development
Production
Table I-2 Hardware/Software Specifications for the Anticipated MSS 8.0 Environment
Test
Development
Production
Functional Areas
Rank the following areas of the application in Table I-3, with 10 being most heavily used and 0 being not used at all. If there is a specific function not listed that is particularly high use or important to your process, add it to the list.
Table I-3 Functional Areas and Level of Use
Functional Area Level of Use (0-10)
PSR
ASR
ISR
USO
ASR to PSR Mapping
Product Catalog
Customer Management
Trouble Management
Work Management
PERT Chart
Rules and Behaviors
Equipment Specifications
Equipment Installation
Auto Design
Path Analysis
IP Address Management
TN Administration
Group Assign
Reconciliation
Engineering Work Order (EWO)
LERG
NPA/NXX Split Utility
Custom Attributes
APIs (list which ones)
Diversity Module
SONET Module
SONET AutoBuild
Broadband Design Module
(non-template ATM/FR and DSL)
DSL Module (non-template)
VPN Module (non-template)
Network Design Canvas
(general templates and graphical design)
ATM/FR Technology Module
(template based)
DLC Technology Module
(template based)
DSL Technology Module
(template based)
Ethernet Technology Module
(template based)
Fiber Based Broadband Delivery Module
(template based)
IP Technology Module
(template based)
MPLS Technology Module
(template based)
Optical/TDM Technology Module
(template based)
