H Deployment Configuration Examples
This appendix contains examples of three deployment configurations:
  • Small (100 users)
  • Medium (300 to 400 users)
  • Large (1000 users)
The hardware proposed for each deployment size is based on the equation for calculating capacity presented in "Hardware Sizing Guidelines".
The examples presented here are based on the number of concurrent users, which is only one criteria used to determine hardware sizing. The examples are general and are intended as a learning tool. Estimates on equipment and configuration settings cannot be exact because needs vary between MetaSolv Solution installations based on criteria such as the number of users, the volume of transactions, whether the application is being used on a WAN, and so on. To ensure that you have planned for the appropriate equipment and software, Oracle recommends that you contact its Professional Services Organization before you proceed with an installation.
When assessing your business situation to estimate hardware needs, you should consider a combination of factors such as API transactions and the type and number of transactions being processed, then adjust accordingly.
Small Deployment Example (100 users)
The following sections describe a small deployment example and include details on deployment size assumptions and hardware configuration.
Deployment Description
Table H-1 shows the size assumptions made for this deployment example.
Table H-1 Size Assumptions for a Small Deployment
Size and Usage Requirement Nonclustered Nonredundant Environment Clustered Redundant Environment
Number of concurrent users
100
100
Number of orders per day
8,000
8,000
Circuit assignment
700
700
Number of trouble tickets
4,000
4,000
Reliability/availability
98%
99.5%
Hardware Configuration
Table H-2 shows the hardware configurations for this deployment example.
Table H-2 Example Small Deployment Hardware Configuration
Computer Nonclustered Nonredundant Environment Clustered Redundant Environment
Client computer (one per user)
Windows-based computer
(2.6+ GHz; 8 GB+ RAM)
Administration server computer
N/A
You can use the WebLogic application server computer (below) to handle the administration server as well. No additional hardware is needed.
1 SPARC T8-1
  • Dual cores of 1 x 5.0 GHz SPARC M8 processor
  • 16 GB RAM, 2 X 600 GB Disk
2 SPARC T8-1
  • Dual cores of 2 x 5.0 GHz SPARC M8 processor
External load balancers
N/A
***2 load balancers
Customer's choice
Example: F5 BIG-IP LTM
Database server
(Oracle) computer
1 SPARC T8-1
  • Quad cores of 1 x 5.0 GHz SPARC M8 processor
2 SPARC T8-1
(Active/Passive)
  • Quad cores of 2 x 5.0 GHz SPARC M8 processor
Background Processor computer
1 Windows-based computer
  • 2 CPUs @ 3.4+ GHz
  • 8 GB RAM
2 Windows-based computers
  • 2 CPUs @ 3.4+ GHz
  • 8 GB RAM
*Clustering with non-redundancy does not apply here. Oracle recommends one Oracle application server per 2 CPUs.
**Only one Oracle Application Server will reside on each computer.
***Access Oracle requirements for hardware load balancer. See the following website:
https://docs.oracle.com/en/middleware/fusion-middleware/weblogic-server/14.1.2/clust/load_balancing.html
For a configuration example using BIG-IP LTM as hardware load balancer, see the following website:
https://docs.oracle.com/en/middleware/fusion-middleware/weblogic-server/14.1.2/clust/bigip.html
Medium Deployment Example (300 to 400 users)
The following sections describe a medium deployment example, and include details on size assumptions and hardware configuration.
Table H-3 shows the size assumptions for this deployment example.
Table H-3 Size Assumptions for a Medium Deployment
Size and Usage Requirement Clustered Nonredundant Environment Clustered Redundant Environment
300-400
300-400
30,000
30,000
Circuit assignment
3,000
3,000
16,000
16,000
99.5%
99.9%
Hardware Configuration shows the hardware configurations for this deployment example.
Table H-4 Example Medium Deployment Hardware Configuration
Computer Clustered Nonredundant Environment Clustered Redundant Environment
(3.4+ GHz; 8 GB+ RAM)
N/A
1 SPARC T8-1
  • 32 GB RAM, 2 X 250 GB Disk
2 SPARC T8-1
  • Quad cores each of 2 x 5.0 GHz SPARC M8 processor
*** 1 load balancer
Customer's choice
***2 load balancers
Customer's choice
Database server
(Oracle) computer
1 SPARC T8-1
  • Eight cores of 1 x 5.0 GHz SPARC M8 processor
  • 32 GB RAM, 2 x 600 GB HDD/SSD
2 SPARC T8-1
  • Eight cores each of 2 x 5.0 GHz SPARC M8 processor
  • 2 CPUs @ 3.4+ GHz
  • 8 GB RAM
  • 2 CPUs @ 3.4+ GHz
  • 8 GB RAM
*For better performance and reliability, a clustered environment is recommended for medium-sized customers.
**The recommendation is for four Oracle application server processes to run on each computer.
Large Deployment Example (1,000 users)
The following sections describe a large deployment example, and include details on size assumptions and hardware configuration.
Table H-5 shows the size assumptions for this deployment example.
Table H-5 Size Assumptions for a Large Deployment
1,000
1,000
100,000
100,000
Circuit assignment
7,200
7,200
42,000
42,000
99.5%
99.9%
Hardware Recommendations
Table H-6 shows the hardware configurations for this deployment example.
Table H-6 Example Large Deployment Hardware Configuration
(3.4+ GHz; 512 MB+ RAM)
N/A
1 SPARC T8-2
  • Sixteen cores each of 2 x 5.0 GHz SPARC M8 processor
  • 64 GB RAM, 2 x 350 GB HDD/SSD
2 SPARC T8-2
  • Sixteen cores each of 4 x 5.0 GHz SPARC M8 processor
***1 load balancer
Customer's choice
***2 load balancers
Customer's choice
Database server
(Oracle) computer
1 SPARC T8-2
  • 64 GB RAM, 2 x 600 GB HDD/SSD
2 SPARC T8-2
  • 2 CPUs @ 3.4+ GHz
  • 8 GB RAM
  • 2 CPUs @ 3.4+ GHz
  • 8 GB RAM
*For better performance and reliability, a clustered environment is recommended for large-sized customers.
**The recommendation is for eight Oracle application server processes to run on each computer.
