5 Customizing the Application
Oracle Communications MetaSolv Solution (MSS) provides the ability for the administrator to customize the application. You can:
- Customize the Navbar
Customize the error and warning messages
Customize reports
Code stored procedures in user exits
Coding the user exits is a developer task and usually requires DBA assistance.
Customizing the Navbar
The Navbar tab on the GUI navigation bar contains the standard navigation for MetaSolv Solution. Use the My Navbar tab on the navigation bar to display a custom configuration of groups and links. After you customize the My Navbar tab, it becomes the default navigation for all users. You can select the Navbar tab on the navigation bar to return to the original navigation.
To allow users to customize the default navigation bare, ensure the Allow users to customize My Desktop preference is set to Y.
To customize My Navbar:
Click My Desktop at the top of the navigation bar.
Select Options > Customize Navigation Bar from the menu.
To modify the My Navbar tab on the navigation bar, do one of the following:
Click the Add a new group link.
Enter the group name, select each link you want to add, and click the right arrow button to add.
To add external links to documents, Web pages, or applications, click the Add your own links link at the bottom of the window. After entering the link name and file location, you can click the Test Link button before adding it to the list.
Click the Edit a group link.
Click the Change the order of groups link.
Complete the necessary windows, following instructions in the online Help.
To delete all My Navbar changes:
Display My Navbar.
Open the Options menu.
Click Customize My Navigation Bar.
Click the Reset My Navbar button.
Customizing the Error and Warning Messages
You can customize the error and warning messages only when running the application in English language as the existing localization process already supports this capability when running in other languages.You can use MSS database tables to customize all the error and warning
messages after you log in to the MSS application. You must use the mss.ini file
to customize the error and warning login messages such as invalid
username/password, that you see while logging in the MSS application.
Customizing the Application Messages
You can use MSS database tables to customize the error and warning messages that you see after you log in to the MSS application. To enable the customization of application messages, set the system preference Enable Display of Custom Messages to Y in System Information in the MSS application.
To set up custom error and warning messages:
Prepare the application to support message customization.
Locate and run the custom_msgs.sql in the prodfixsql directory using ASAP user.@driveletter:installation_directory/prodfixsql/custom_msgs.sql
This script creates the standard text entries for all of the messages that you can customize within the application. They are represented within the
ASAP.MSGStable having theLANGUAGE_CDas '0409'.Review the log files in the same prodfixsql directory that is generated for each SQL file in custom_msgs.sql.
Configure the custom messages to be displayed in place of the standard messages.
Run the following SQL statement to get all the standard English messages that can be customized.
SELECT * FROM ASAP.MSGS WHERE LANGUAGE_CD = '0409';
Identify the messages that you want to customize from the result.
Insert new rows into the
ASAP.MSGStable withLANGUAGE_CD= '0000' for the messages that you want to customize. For example,INSERT INTO ASAP.MSGS(MSG_ID, LANGUAGE_CD, MSG_STRING, OBJECT_NM, CONTEXT, LAST_MODIFIED_USERID, LAST_MODIFIED_DATE) VALUES(MSG_ID,'0000','Customized message','Object_name_that_messagebox_is_in','Notes','userID', sysdate)Ensure that you insert the rows in
ASAP.MSGStable for all the messages that you want to customize.Note:
When inserting the customized text in theASAP.MSGStable, ensure that theMSG_IDfor the inserted rows with the LANGUAGE_CD as '0000' is same as theMSG_IDof the English row with the LANGUAGE_CD as '0409'.
Configure the MSS application to enable customization.
To enable customization of messages:
Log in to the MSS application with the user who has ASAP privileges.
Set the system preference Enable Display of Custom Messages to Y in System Information.
- Log out of the MSS application.
When the system preference is set to Y, the application displays the
customized messages from the ASAP.MSGS table. When the preference is
set to Y and there is no corresponding custom messages in
ASAP.MSGS table, the application displays the standard error and
warning messages.
Customizing Login Messages
[Custom Login Messages] in mss.ini file. You can
customize the following messages by adding customized error
messages:[Custom Login Messages]
invalid username/password; logon denied=Customized error message
Please enter a User ID to logon.=Customized error message
The User ID you entered is not active. Use an active User ID or ask the security administrator to activate the inactive User ID.=Customized error message
The User ID is not in the security database. To correct the problem ask the security administrator to add this User ID to the security database.=Customized error message
The user ID you entered is not valid. Please use a valid User ID or ask your manager for assistance.=Customized error message
Your User ID is not configured to run Metasolv Solution. Please use another User ID or contact your support personnel for further assistance.=Customized error message
The following messages appear in the application when the preference Use MSS Password Validation Including Password Expiration is set to Y. To customize these messages, add your custom error messages to the mss.ini file.
Your password has expired. Please enter a new password in the next window.=Customized error message
Your password expires today. Please change your password before it expires.=Customized error message
Your password expires at the end of the day tomorrow. Please change your password before it expires.=Customized error message
In the mss.ini file, you must enter the standard English message before the equals to sign and enter the equivalent custom error message after the equals to sign.
If you do not enter the custom message in the mss.ini file, the application displays the standard messages.
The messageYour password will
expire in x days cannot be customized because it is generated dynamically
based on the number of days until expiration.
Producing Custom Reports
MetaSolv Solution provides preloaded GUI reports through the reporting, trouble management, and security functions. The reporting function provides a variety of reports that can be selected. Instructions for producing these reports appear in the online Help.
When MetaSolv Solution is installed, the installation process deploys a PowerBuilder file named I_rpt.pbl, a file that contains predefined MetaSolv Solution reports in the form of datawindows.
You can also create custom reports that you add to the Selected Report list.To create customized reports for MetaSolv Solution, you must purchase and install PowerBuilder or InfoMaker and follow directions in that documentation to create a report and copy it to the reporting pbl.
For information on using PowerBuilder or InfoMaker, investigate the Appeon website at:
Creating a Customized Report
To create a customized report and add it to MetaSolv Solution:
Create the report using PowerBuilder or InfoMaker.
See the third-party documentation for instructions. Use PowerBuilder to copy the report datawindow to I_rpt.pbl on the machine where mss.exe runs.
Log in to MetaSolv Solution.
Click the Reporting group.
Click Register Reports and follow directions in the Help to add a new report.
Once registered, the customized report can be selected from the Selected Report drop-down on the Reports window. See the online Help topic about generating a custom report for instructions.
Retaining Customized Reports After an Upgrade
When a new release is installed, the installation process deploys a new copy of I_rpt.pbl. Pre-existing customized reports must then be manually added to the new I_rpt.pbl using PowerBuilder.
To retain customized reports:
Copy the existing copy of I_rpt.pbl with a different name and save it.
Open the copy of I_rpt.pbl in PowerBuilder.
Copy the datawindows for pre-existing custom reports to the new I_rpt.pbl.
Manually distribute the updated I_rpt.pbl to all client machines.
If you select a report, you may get the following error message:
The selected report does not have a datawindow object in I_RPT.BPL.
This error message indicates that the datawindow has not been added to the I_rpt.pbl file on your machine.
If a data window name for a custom report cannot be found in the drop-down after an upgrade:
Unregister the report through the application by deleting the row in the Register Reports window.
Register the report again in the new version of MetaSolv Solution.
Using Stored Procedure Exits
MetaSolv Solution provides user exits for the purpose of making database calls. The exits are empty shells of stored procedures that are already part of the application code. To code these exits, you should be familiar with PL/SQL. Because these are empty shells, you are responsible for any impact a user exit has on performance or data. You must optimize your company's code.
- Oracle Global Customer Support (GCS) supports user exits as they are written within the delivered code. GCS does not support any customer-developed code that is stored within these shells nor do we support any residual affects to our delivered code or to any data stored in the database caused by customer-derived code.
- Oracle recommends COMMIT or ROLLBACK statements NOT be used in the custom logic implemented in the custom stored procedure exit point code or subsequent third party code called from within them unless it has been separated from the main transaction using AUTONOMOUS_TRANSACTION Pragma. The MetaSolv Solution client issues COMMIT and ROLLBACK statements as necessary and their use in the custom logic can cause data integrity problems resulting from an "incremental commit or rollback" within the transaction used by the application. This restriction also applies to custom triggers created on tables.
With these exits, you can have MetaSolv Solution perform tasks that are specific to your business needs, such as:
Performing custom validation and pre-PSR validation
Defining dependencies
Changing optional fields to required
Defining default fields, such as a Web host user ID
Generating free-format circuit IDs
Validate e-mail, ID, and password entries on e-mail service items and Web host items
Supplement canceling a PSR order
You cannot use these exits to perform other functions or to call other applications.
Retaining User Exits After an Upgrade
When a new release is installed, the installation process deploys new stored procedures. Pre-existing customized stored procedures (exits) must be saved before the service pack or new release is installed.
To retain existing user exits:
Copy the existing stored procedures with different names.
Install the service pack or new release.
Copy the customized user exits files back to the updated version of the application.
Coding User Exits
These exits are stored in files in the procs directory. The procs directory is installed at the location where the database installer was run. Contact a DBA to find the location.
The following sections provide information for each user exit, including:
Description
Exit name
File name
To add code to a stored procedure exit:
Locate the appropriate file for the exit you want to use.
Open the file with Notepad or other basic text editor.
Add lines of SQL code to define the task you want the application to perform.
Save the file.
Run the file, so the proc with the new code can exist on the database.
Generate a Circuit ID
You can add code to this exit to set the format for a custom circuit ID. The exit is only available for OTF and OTS circuit format types. To call this procedure, the user must first set the Customer Generated Freeformat Circuit ID preference to Y. After setting the preference to Y, the user can access the Connection Identification Maintenance window for a circuit and see an option called Generate Circuit ID.
Table 5-1 describes the circuit ID exit.
Table 5-1 Circuit ID Exit
| Identifier | Description |
GUI location |
Connection Identification Maintenance window |
Exit name |
pkg_generate_freeformat_ecckt.sp_generate_ecckt |
File name |
paecckt.sql |
Generate a Custom Customer Account Number
You can add code to this exit to generate a custom customer account number when creating or selecting a customer for a new Product Service Request. If the user is in Customer Maintenance, the procedure is called by clicking the Apply button or moving from the General tab. If the user is creating the customer directly from the PSR, the procedure is called by clicking OK after entering all of the customer information or selecting an existing customer.
Table 5-2 describes the customer account number exit.
Table 5-2 Customer Account Number Exit
GUI location |
Customer Account Maintenance window |
Exit name |
sp_PSR_cust_acct_number |
File name |
custacct.sql |
Perform Custom Validation on Network Locations
You can add code to this exit to create custom validations for network locations. This procedure functions when the user clicks the OK button on the Network Location window for a new or existing network location.
Table 5-3 describes the custom validation on network locations exit.
Table 5-3 Custom Validation on Network Locations Exit
GUI location |
Network Location New window |
Exit name |
sp_NL_custom_validation |
File name |
nlcustom.sql |
PSR Custom Pre-Validation
You can add code to this exit to automatically pre-validate a PSR order. This stored procedure exit is called when validating or finishing a PSR order and is called prior to MetaSolv Solution's validation and prior to the other PSR custom validation user exit discussed in "Perform Custom Validation on a PSR Order".
Table 5-4 describes the PSR custom pre-validation exit.
Table 5-4 PSR Custom Pre-Validation Exit
GUI location |
PSR order |
Exit name |
Sp_psr_custom_pre_validation |
File name |
soppreval.sql |
You can add code to this exit to perform custom validation on a PSR order. To call this procedure, the user validates or finishes a PSR order.
Table 5-5 describes the PSR custom validation exit.
Table 5-5 PSR Custom Validation Exit
GUI location |
PSR Order |
Exit name |
Sp_psr_custom_validation |
File name |
socustom.sql |
Perform Custom Validation at Task Completion
You can add code to this exit to perform a custom validation at task completion. This stored procedure is called when a user completes any Work Management task, if the Perform Custom Validation at Task Completion preference is set to Y.
Table 5-6 describes the custom validation at task completion exit.
Table 5-6 Custom Validation at Task Completion Exit
GUI location |
Task Completion Maintenance window |
Exit name |
sp_wm_custom_validation |
File name |
wmcustom.sql |
Populate the Internet Dial Up User ID
You can add code to this exit to automatically populate the Internet Dial Up user ID. This stored procedure is called when a user first accesses the Dial Up Info tab on a PSR, including an Internet Dial Up service item.
Table 5-7 describes the Internet Dial Up user ID exit.
Table 5-7 Internet Dial Up User ID Exit
GUI location |
Dial Up Info tab |
Exit name |
pkg_psr_custom_keys.sp_custom_dialup_userid |
File name |
papsrcky.sql |
Populate the Internet Dial Up Password
You can add code to this exit to automatically populate the Internet Dial Up password. This stored procedure is called when a user first accesses the Dial Up Info tab on a PSR, including an Internet Dial Up service item.
Table 5-8 describes the Internet Dial Up password exit.
Table 5-8 Internet Dial Up Password Exit
GUI location |
Dial Up Info tab |
Exit name |
pkg_psr_custom_keys.sp_custom_dialup_password |
File name |
papsrcky.sql |
Populate the PSR Email Password
You can add code to this exit to automatically populate the PSR email password. This stored procedure is called when a user first accesses an Email item's Email Info tab on a PSR order.
Table 5-9 describes the PSR email password exit.
Table 5-9 PSR Email Password Exit
GUI location |
Email Info tab |
Exit name |
pkg_psr_custom_keys.sp_custom_email_password |
File name |
papsrcky.sql |
Populate the Web Hosting User ID
You can add code to this exit to automatically populate the Web Hosting user ID. This stored procedure is called when a user first accesses the Web Host Info tab on a PSR for a Web Hosting item.
Table 5-10 describes the Web Hosting user ID exit.
Table 5-10 Web Hosting User ID Exit
GUI location |
Web Host Info tab |
Exit name |
pkg_psr_custom_keys.sp_custom_webhost_userid |
File name |
papsrcky.sql |
Populate the Web Hosting Password
You can add code to this exit to automatically populate the Web Hosting password. This stored procedure is called when a user first accesses the Web Host Info tab on a PSR for a Web Hosting item.
Table 5-11 describes the web hosting password exit.
Table 5-11 Web Hosting Password Exit
GUI location |
Web Host Info tab |
Exit name |
pkg_psr_custom_keys.sp_custom_webhost_password |
File name |
papsrcky.sql |
Populate the URL
You can add code to this exit to automatically populate the URL on the Dial Up Info tab. This stored procedure exit is called when a user first accesses the Dial Up Info tab on a PSR for an Internet Dial Up service item.
Table 5-12 describes the Dial Up URL exit.
Table 5-12 Dial Up URL Exit
GUI location |
Dial Up Info tab |
Exit name |
pkg_psr_custom_keys.sp_custom_url |
File name |
papsrcky.sql |
Validate an Email Address
You can add code to this exit to automatically validate the email address entered on an Email service item email Info tab. This stored procedure exit is called on a save, when the user tries to move to another service item or when the user validates.
Table 5-13 describes the email address validation exit.
Table 5-13 Email Address Validation Exit
GUI location |
Email tab of email service item |
Exit name |
pkg_psr_custom_keys.sp_custom_email_validation |
File name |
papsrsky.sql |
Validate a User ID
You can add code to this exit to automatically validate the user ID entered in the GUI locations listed below. This stored procedure exit is called on a save, when the user tries to move to another service item or when the user validates.
Table 5-14 describes the user ID validation exit.
Table 5-14 User ID Validation Exit
GUI location |
Exit name |
pkg_psr_custom_keys.sp_custom_userid_ validation |
File name |
papsrcky.sql |
Validate a Password
You can add code to this exit to automatically validate the password entered the GUI locations listed in the table below. This stored procedure exit is called on a save, when the user tries to move to another service item or when the user clicks validate.
Table 5-15 describes the password validation exit.
Table 5-15 Password Validation Exit
GUI location |
Exit name |
pkg_psr_custom_keys.sp_custom_password_validation |
File name |
papsrcky.sql |
Generate an MSAG Validation Audit Trail
You can add code to this exit to generate an MSAG validation audit trail. The stored procedure is called from the End User Location Maintenance window, after the MSAG validation occurs.
Table 5-16 describes the MSAG validation audit trail exit.
Table 5-16 MSAG Validation Audit Trail Exit
GUI location |
End User Location Maintenance window |
Exit name |
sp_psr_msag_custom_validation |
File name |
somsagcustom.sql |
Supplement Canceling a PSR Order
You can add code to this exit to perform a custom operation when supplement canceling a PSR order.
This functionality is supported only through the GUI.
Table 5-17 describes the PSR custom supplement cancel exit.
Table 5-17 PSR Custom Supplement Cancel Exit
| Item | Description |
| GUI location | PSR Order |
| Exit name | sp_psr_custom_supp_cancel |
| File name | socustsuppcan.sql |
The socustsuppcan.sql file is stored in the installation_directory/procs directory, where installation_directory is the directory on a client machine or on the database server where you extract the contents of the MSS.R6_3_x.byyy_DBInstall.zip file; yyy is the build number.
