3 Running the Oracle WebLogic Server
Oracle Communications MetaSolv Solution (MSS) provides several means of monitoring and maintaining the product at its intended capacity. For instance, regularly monitoring log files can assure continued high performance. Other normal maintenance tasks are required when changes or problems occur. This chapter provides detailed instructions about the following:
Starting and stopping the MetaSolv Solution application server
Managing the MetaSolv Solution log files
Monitoring the client logons
Managing the Oracle WebLogic server
Resetting the server-to-database connections
When tuning the Oracle WebLogic server, refer to "Oracle WebLogic Server Configuration Settings" for suggested settings.
Starting and Stopping the MetaSolv Solution
The MetaSolv Solution database and servers should always be up and running, ready for access by clients. Shutdown should occur only during normal system maintenance.
Components must be started in the following order:
Database
Application server
Web server (Internet Information Services (IIS) server or NGINX server if using power client)
After the database is up and running, use the MetaSolv Solution start script to start the Oracle WebLogic server. The script sets values for arguments and provides the settings required to make the Oracle WebLogic server start successfully.
The start scripts are located in the domain directory. The script name includes the server name. For example, if a server is named MSLV01, it will have a start script named startMSLV01.sh in the domain directory.
If you change the HTTP port for the server process (using the Oracle WebLogic domain wizard) without reinstalling MSS, you must also change it in the start script for the server process.
Starting MetaSolv Solution with a script
To start MetaSolv Solution with a script:
MetaSolv Solution provides scripts to start a server. Use the following command depending on which type of machine you are using:
For UNIX/Linux:
./startMSLVServer.sh
For Windows:
startMSLVServer.cmd
Use the following as the admin URL argument:
http://host_name:admin_port
Use the following as the admin URL argument when using SSL port:
https://host_name:admin_sslport
To start or stop the administration server and managed servers (in a cluster environment) using the SSL port, you must add an s after http in the ADMIN_URL argument in the startup/stop server scripts for the administration server and for each managed server. For example:
https://host_name:admin_sslportIf running in a cluster environment:
After managed servers are started, the Admin server can be shut down to release resources that the process would otherwise consume. However, the Admin server must be running to allow access to the Remote Console or to perform any administrative function.
Stopping MetaSolv Solution with a script
To stop MetaSolv Solution with a script:
MetaSolv Solution provides scripts to shut down a server. Use the following command depending on which type of machine you are using:
For UNIX/Linux:
./stopMSLVServer.sh <password> -
For Windows:
stopMSLVServer.cmd <password>
http://host_name:admin_portUse the following as the admin URL argument when using SSL port:
https://host_name:admin_sslportStarting the Web Servers
You must use IIS server for Windows and NGINX for Linux if you are using power client to install MSS client application. See "Installing IIS Server on Windows" in MSS Installation Guide for starting IIS server. See "Installing NGINX Server on Linux" in MSS Installation Guide for starting NGINX server.
Managing the WebLogic Server
The WebLogic Remote Console is an administrative tool for managing resources, including such tasks as starting and stopping servers, balancing the load on servers or connection pools, tuning and monitoring the configuration of resources, detecting and correcting problems, monitoring and evaluating system performance, and making sure the application is correctly deployed to the target servers or to a cluster.
See the WebLogic Server documentation for more information.
See "Delivering File Changes" for specific configuration and tuning recommendations for MetaSolv Solution and the WebLogic Server.
You can use the MetaSolv Solution Runtime page link to the WebLogic Remote Console. This link appears on the Runtime Page drop-down. "Getting Oracle WebLogic Server Runtime Information" for details about the Runtime page.
The Remote Console manages the following WebLogic Server tasks:
Configuring the server
Tuning the Oracle WebLogic server
Debugging and monitoring
Deployments
Managing WebLogic logs
Monitoring Oracle WebLogic server performance
Executing queues
Managing database connections
Managing Oracle WebLogic security
Follow directions in the Oracle documentation to perform specific WebLogic tasks. Follow instructions in the MetaSolv Solution Installation Guide regarding basic Oracle WebLogic settings before making changes.
Getting Started with the Remote Console
Oracle WebLogic Remote Console is a graphical user interface that administers Oracle WebLogic Server domains.
https://docs.oracle.com/en/middleware/fusion-middleware/weblogic-remote-console/administer/set-console.htmlNote:
The Administration server must be running before you can use the Remote Console.
Among the key tasks you will perform using the Remote Console are:
Executing queues
Monitoring the Oracle WebLogic server through the Runtime page
See "Delivering File Changes" before making any changes to the number of threads.
The MetaSolv Solution Runtime page provides detailed Oracle WebLogic server information. It also provides links to important administrative tools that provide specialized information.
To view the Runtime Information page:
Enter the following in your Web browser:
http://host_name:port/mainNote:
If you start the Administration server using Secure Socket Layer (SSL), you must add an s after http. For example:
https://host_name:port/mainThe Runtime Information page is displayed.
Server Details
The MetaSolv Solution Appserver Runtime page provides a detailed snapshot of an Oracle WebLogic server, providing details about the following:
Client Information
Enterprise Archive (ear) Version
Server Information
WebLogic Server instance
URL
Stored Procedures with Invalid Version (if any)
JAR file information
Classpath JARs
Java System Properties
Links to Administrative Tools
You can select Link to the Remote Console from the Runtime page drop-down list to open the WebLogic Remote Console.
You can view a runtime page for each server in your MetaSolv Solution configuration. The information in each report should be the same. If it is not, the Oracle WebLogic server in your MetaSolv Solution system are out of sync and you may need to re-install the product.
Managing MetaSolv Solution Log Files
MetaSolv Solution provides three consolidated log files for all modules. When system or user errors occur, you can review a file and discover the source of the problem.
Table 3-1 describes the log files.
Table 3-1 Log Files
| File name | Purpose |
appserver.log |
System-wide log file. |
appserverlog_misc.log |
Miscellaneous catch-all log file. This file traces any activity not specified for |
appserver_audit.log |
This file contains the records of log on and log off activities, and includes successful and failed client logon attempts. Each attempt to log on is recorded, whether it is successful or not. Since, the audit log file contains the logon and logoff information only, a large archive can be maintained for longer periods of time than when using appserver.log. The appserver_audit.log configuration is independently controlled from the main log file's configuration (using the appserverAuditLog appender of loggingconfig.xml). |
Table 3-2 describes each field of the appserver.log and appserverlog_misc.log log files.
Table 3-2 MetaSolv Solution Log File Fields
| Field | Description |
appServerName |
Application server where the event occurred. |
className |
Name of the JAVA class logging the message. This is typically where the problem occurred. If a developer has not specified this field, it appears as an indeterminate "DEF_CLASS." Note: Provide this information if working with Oracle Global Customer Support. |
debugCode |
A message may simply contain a zero or an arbitrary number for this debug code. |
Events |
Occurrences of log messages that meet the criteria specified. |
Level |
Severity of the event. Severity levels are: Alert, Fatal, Error, Warning, Performance, Info, and Debug. (Performance is not currently in use.) |
machineName |
Identifies the hardware. |
Message |
Information provided about the event. |
messageID |
A unique ID for the message that may be useful if working with Oracle Global Customer Support. |
moduleName |
Specifies the product module in which the event occurred, such as PSR, Security, etc. Audit file logs occur only with the Security module. |
productName |
MetaSolv Solution. |
thread |
Debugging aid for internal development. |
Time |
Time the event occurred. |
userName |
Identifies the user associated with the event. |
Archiving the Log Files
When a MetaSolv Solution log file reaches the maximum size specified in loggingconfig.xml, it is automatically archived. The default size is 10 MB. The ten newest archived log files are maintained and older files are automatically deleted. As each log file is archived, the older files are renamed.
When a log file is archived, MetaSolv Solution appends a number to the file. The lowest number is the newest file. For instance, your company's three newest archived log files are named:
appserver.log.1 (Newest archive)
appserver.log.2
appserver.log.3 (Oldest archive)
Changing the Log File Location
The main logging directory to which log files will be written is specified in the start script startMSLVmanaged.sh or startMSLVsingle.sh in the domain directory. This value is determined by the mslv.log.dir setting specified in this script. By default this value will be set to the appserver/logs directory under each server's installation directory.
You can modify the mslv.log.dir value in the startMSLVmanaged.sh or startMSLVsingle.sh script after the installation is completed.
The new value must point to a directory, where the Oracle WebLogic server has permission to create and delete log files.
Setting the Logging Configuration Parameters
When troubleshooting, you can change the settings in the logging configuration files loggingconfig.xml and mslvloggingconfig.xml so that more or less information is captured in the log file for any given module of the software.
To set the loggingconfig.xml and mslvloggingconfig.xml parameters:
Access the loggingconfig.xml file in the Oracle WebLogic server config folder.
Make a backup copy.
Make any necessary parameter changes using any text editor.
For UNIX/Linux, a vi, emacs or /usr/dt/bin/dtpad editor may be used.
On the Windows platform, Notepad or WordPad may be used for this purpose.
- Repeat the steps from 1 to 3 to modify the parameters in mslvloggingconfig.xml.
Most parameters in appserver.log should not be changed, and are reserved for error situations that may require assistance from Oracle Global Customer Support. However, as you encounter system or user problems in day-to-day operations, you will want to reset some parameters so you can screen for specific information.
The logging configuration files consist of several sections, listed in "Table 3-3" and "Table 3-4".
Table 3-3 loggingconfig.xml Sections
| Section | Description and parameters |
Logging File specification and configuration |
Describes whether log file information is appended or written over, log file size, archiving specifications. See "Table 3-5" for information about editable parameters. |
Category |
Modules and components for which event levels can be set. Valid levels are fatal, error, warn, info, and debug in decreasing order of severity. See "Table 3-6" for a complete list. |
Table 3-4 mslvloggingconfig.xml Sections
Message Resourcebundles specification |
Defines the resource bundle names and their locations in the JAVA library packages. This section must never be modified unless instructed by Oracle Global Customer Support. |
Pluggable interface specification |
Implementation classes for the logging framework. This section must never be modified unless instructed by Oracle Global Customer Support. |
SQL Tracing configuration |
Captures SQL debugging messages when JDBCTrace module's debug value is also set to "on." Only one parameter can be changed: <param value="off" name="debug"/>
Row Retrieval Specification |
Defines the number of rows that a user is allowed to retrieve and describes the threshold for the "too-many-rows" alert. The two parameters are: <param value="32000" name="query-results-row-limit"/> <param value="20000" name="too-many-rows-alert-threshold"/> |
Editable Logging File Specifications
The following table describes the editable logging file specifications that can be changed. Locate the listed keyword in the file and edit the parameters shown. Only the following log files can be edited:
appserver.log
appserver_audit.log
The last section of the loggingconfig.xml file lets you specify the level at which you want to trace events for each category.
Table 3-5 lists the logging file editable specifications.
Table 3-5 Logging File Editable Specifications
| Keywords to search | Editable Logging File Specifications |
RollingFile name="appserverLog" |
<RollingFile name="appserverLog" fileName="${sys:mslv.log.dir}/appserver.log" filePattern="${sys:mslv.log.dir}/appserver-%i.log">
<PatternLayout>
<pattern>%d{MM-dd-yyyy HH:mm:ss,SSS}|%p|%m%n</pattern>
</PatternLayout>
<Policies>
<SizeBasedTriggeringPolicy size="10 MB" />
</Policies>
<DefaultRolloverStrategy max="10"/>
</RollingFile>
RollingFile name="appserverAuditLog" |
<RollingFile name="appserverAuditLog" fileName="${sys:mslv.log.dir}/appserver_audit.log" filePattern="${sys:mslv.log.dir}/appserver_audit-%i.log">
<PatternLayout>
</PatternLayout>
<Policies>
</Policies>
</RollingFile> |
RollingFile name="appserverMiscLog" |
<RollingFile name="appserverMiscLog" fileName="${sys:mslv.log.dir}/appserverlog_misc.log" filePattern="${sys:mslv.log.dir}/appserverlog_misc-%i.log">
<PatternLayout>
</PatternLayout>
<Policies>
</Policies>
</RollingFile> |
Table 3-6 lists the available modules for setting trace levels.
Do not keep event severity levels at Info or Debug level during normal operations. Doing so would cause all events to be logged. Logging all events can have an adverse impact on system performance.
Table 3-6 Logging Categories
| Category | Description or Direction |
CaCache |
Custom attributes (CAs) are characteristics end users can define generically and associate with network templates, element types, connection types, connection specifications, network systems, and allocations of connections or elements within a system. |
DLR |
Oracle's software supports two types of design layout reports (DLRs):
Internal DLRs have always existed for circuits designed in Oracle's software and have been referred to merely as DLRs. The external DLR process begins when a customer sends a service request to a provider requesting the use of part of their network for designing connections. The provider receives the service request and sends the customer a firm order confirmation (FOC) to verify the service request. See the Help for more information. |
DLR_Equipment |
When users edit equipment or equipment specifications, or move equipment with assigned connections, the design layout records (DLRs) for those connections are reconciled to reflect the change - including pending assignments. See the Help for more information. |
DLR_NGN_Activation |
References NGN activation. See the Help for more information. |
DLR_Circuit |
References DLR circuits. See the Help for more information. |
EventServer |
For MetaSolv Solution internal use only. Use the default settings. |
Event2Server |
Framework |
MSS internal framework code that is used/depended on extensively by the other modules. This consists of logging, security, and desktop portlet related logging. |
Framework.Cache |
MSS internal framework code that specifically deals with database query caching. |
GLR |
GLR is a generic term used to refer to the Graphical Layout Record. The GLR provides information about a specific virtual connection, such as administrative information, design lines, and a graphical-view of the design. The report is generated from Connection Design. |
invFromPB |
Infrastructure |
Refers to application startup settings listed on the GUI navigation bar. |
Infrastructure_NetworkLocation |
Refers to Network Location settings in the GUI. |
INTEGRATION_CONVERSION |
WORK_MANAGEMENT_CONVERSION |
INTEGRATION_EVENT_SERVER |
INTEGRATION_MANAGER |
Integration.API |
This exists to log the messages regarding Web Services. |
JDBCTrace |
The module which logs the SQL statements before they are run for D/B bound operations. |
MSLVSessionBean |
This exists to log all the entry and exit messages regarding the invocations of various methods in all Stateless Session type Enterprise Java Beans in the MSS application. |
NetworkManagement |
NetProv |
NetProv_Plant |
NetProv_Activation |
NI |
PSR |
PSR provides service request tracking and provisioning functionality for products defined in the product catalog. |
E911 |
E911 functionality lets a user enter and maintain detailed information about a telephone number and its service location. |
CNAM |
Caller Name identification (CNAM) lets users view the calling name and telephone number of a caller on a caller ID display panel. |
LIDB |
Line Information Database (LIDB) lets users place restrictions on third-party calls. |
PSRAncillary |
PSREUB |
PSR End User Billing extracts billing information from the order to pass to an end user billing interface. |
Security |
For MetaSolv Solution internal use only, if requested by Global Customer care. Use the default settings. |
SYSTEM |
MetaSolv Solution startup and shutdown and DB initialization module related logging. |
TEST |
TimedEventProcess |
TMS |
TroubleBatchWorkerThread |
KeepAliveTroubleBatch |
WDI |
WM |
WM_TskSv |
Sample Log File Messages
The following sample log files can be reviewed to find the source of the problem, when there is an error.
The appserver_audit.log log file contains the following information for the user login and log out:
09-28-2022 11:36:11,955|INFO|[appServerName :: DEF_APPSERVER][userName :: ASAP][machineName ::machinename ][productName :: nur][debugCode :: 0][moduleName :: cmm.Security][messageID :: 0001][className :: DEF_CLASS]::Login detected for ASAP.::User has signed on.::None.:: 09-28-2022 11:36:12,034|INFO|[appServerName :: DEF_APPSERVER][userName :: ASAP][machineName :: ][productName :: nur][debugCode :: 0][moduleName :: cmm.Security][messageID :: 0002][className :: DEF_CLASS]::Logout detected for ASAP.::Logout by user or Client disconnected.::None.::
The appserver_audit.log log file contains the following information for an incorrect password:
09-28-2022 22:03:40,673|WARN|[appServerName :: DEF_APPSERVER][userName :: ASAP][machineName :: machinename ][productName :: nur][debugCode :: 0][moduleName :: cmm.Security][messageID :: 0003][className :: DEF_CLASS]::Login attempt failed for ASAP. Exception: ORA-01017: invalid username/password; logon denied ::Invalid username and/or incorrect password.::Please supply correct user/password.::
The appserver.log log file contains the following message if the MSS version of the client and server software are different:
09-22-2022 10:45:34,798|ERROR|[appServerName :: DEF_APPSERVER][userName :: ASAP][machineName :: machinename][productName :: nur][debugCode :: 0][moduleName :: cmm.invFromPB][messageID :: 10122][className :: DEF_CLASS]::The server encountered the following Error: Software versions do not match. Client=8.0.0.1 Server=8.0.0.2 ::The server encountered the following Error:::The server encountered the following Error:::
