6 Inventory Web Service Reference
This chapter provides information about Oracle Communications MetaSolv Solution (MSS) Inventory Web Service.
About the Inventory Web Service
The Inventory Web Service enables an external system to and maintain inventory in MetaSolv Solution. Inventory Web Service operations enable you to:
  • Create, get, and update locations.
  • Create new inventory items.
  • Get available physical ports.
  • Create, get, and update entities.
  • Get IP addresses.
  • Get network areas, locations, and components.
  • Get, validate, and update telephone numbers.
About the Inventory Web Service Packaging
The Inventory Web Service is packaged in the MSS_WebService.ear file, which contains the inventory.war file. When the installer deploys the EAR file, the Inventory Web Service is automatically deployed and ready to use.
The MSS_WebService.ear file also includes the other MSS web service operations. See "Web Services Overview" for information about these operations.
About the Inventory WSDL, WAR, and Schema Files
The Inventory Web Service is defined by the InventoryAPI.wsdl file and is supported by numerous schema files. The WSDL file and supporting schema files are located in the inventory.war file.
See "Understanding How MSS Defines Web Services" for more information about WSDL and WAR files, and about their directory locations in the EAR file.
About Inventory Schema Files
Several schema files support the Inventory Web Service. Within inventory.war file, the schema files are located in the WEB-INF/wsdls directory. These schemas are categorized as common schemas, entity schemas, and data schemas.
Common Schemas
For information about the common schema files, see "About Schema Files".
Entity Schemas
The entity schemas define elements, such as keys and types, specific to the web service.
The Inventory entity schemas are defined in the following files:
  • CustomerManagementEntities.xsd
  • InventoryManagementEntities.xsd
  • MIPCommonEntities.xsd
  • OrderManagementEntities.xsd
  • OrderManagementEvents.xsd
  • ServiceEntities.xsd
Data Schemas
The data schemas contain numerous complex type structures, enumerations, and simple types.
The Inventory data schemas are defined in the following files:
  • CustomerManagementData.xsd
  • InventoryManagementData.xsd
  • OrderAncillaryManagementData.xsd
  • OrderManagementData.xsd
  • ServiceData.xsd
API Schemas
The API schemas contain the high-level response and request type definitions and exception definitions.
The Inventory API schemas are defined in the following files:
  • InventoryManagementAPI.xsd
  • OrderManagementAPI.xsd
auditTrailRecording Operation
This operation returns the success or failure of AuditTrail recording information.
The following are the request and response structures:
Request Structure: auditTrailRecording
Response Structure: auditTrailRecordingResponse
auditTrailRecording
The auditTrailRecording element contains the input information for the operation. Each row in Table 6-1 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-1 Payload Information for the Request
Name Defined As Type Description File Name
auditTrailRecording
element
queryInventoryManagementResponse
InventoryAPI.wsdl
element
MimQueryResponse
MimQueryResponse
element
MetaSolvInventoryQueryResponseChoice
complexType
queryMSAGResponse
This operation uses only queryMSAGResponse and not queryTelephoneNumberInventoryResponse.
queryMSAGResponse
element
msagSearch
msagSearch
element
MetaSolvMSAGSearch
MetaSolvMSAGSearch
complexType
StructureFormatType
StructureFormatType
complexType
StructureFormatComponentType
complexType
Contains a list of fields
This operation only uses queryMSAGResponse and not queryTelephoneNumberInventoryResponse. Therefore, only queryMSAGResponse is defined in this operation.
Table 6-2 describes the required fields for auditTrailRecording.
Table 6-2 Required Fields for auditTrailRecording
Field Name Data Type Field Description
partnerId
string
Partner ID.
successOrFailure
string
Success or failure response for the operation.
Table 6-3 describes the required fields for MetaSolvMSAGSearch.
Table 6-3 Required Fields for MetaSolvMSAGSearch
keyValue
string
Specifies whether the Master Street Address Guide (MSAG) information uses the NENA 2.0 standards.
partnerId
string
Partner ID.
Table 6-4 describes the required fields for StructureFormatType.
Table 6-4 Required Fields for StructureFormatType
sfType
string
Category that describes a structure.
name
string
Name of a specific customizing of a structured format type.
Table 6-5 describes the required fields for StructureFormatComponentType.
Table 6-5 Required Fields for StructureFormatComponentType
Id
int
ID of a component of a structured format.
name
string
Name of a component of a structured format.
componentType
string
Type of component, such as table-driven drop-down or valid value drop-down.
Value
string
Name of a value for a component.
The auditTrailRecordingResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-6 describes the returned information in the response.
Table 6-6 Payload Information for the Response
element
Contains the auditTrailRecordingResult string
InventoryAPI.wsdl
Table 6-7 describes the error messages for the operation.
Table 6-7 Error Messages for the Operation
Error Messages Cause Resolution
Not running the stored procedure SP_PSR_MSAG_CUSTOM_VALIDATION because the partyId is either null or is an empty string
The party ID passed on the input is either null or an empty string.
Populate a valid party ID in the input structure to get a successful output.
createEntityByValueRequest Operation
This operation creates an end user location or a network location and returns the key for the new object. This operation also creates a new inventory item using createNumberInventoryValue.
Request Structure: createEntityByValueRequest
Response Structure: createEntityByValueResponse
The createEntityByValueRequest element contains the input information for the operation. Each row in Table 6-8 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-8 Payload Information for the Request
element
mimCreateEntityByValueRequest
InventoryAPI.wsdl
element
createEntityValue
createEntityValue
element
CreateEntityValueChoice
complexType
Contains the following:
  • createPSRServiceLocationValue
  • createNumberInventoryValue
element
CreatePSRServiceLocationValue
complexType
serviceLocationValue
complexType
Extension of LocationValue
serviceLocationKey
serviceLocationKey
element
EndUserLocationKey
networkLocationKey
element
networkLocationKey
networkLocationKey
element
networkLocationKey
structureFormats
element
StructureFormatType
StructureFormatType
complexType
Table 6-9 describes the required fields for serviceLocationValue.
Table 6-9 Required Fields for serviceLocationValue
serviceLocationRef
integer
Reference value of Service Location.
endUserLocatoinName
string
End user location name.
servLocClliCodeTn
string
Network location with switch detail. If you select a value from the drop-down, you must enter a value in the Switch Network Area field on the End User Location Maintenance Window - Network Areas tab.
servLocClliCodeData
string
Network location that is not in one of the following categories: Customer or Non-building.
e911PayableEntity
string
Company that receives the E911 surcharge collected for a customer with E911 service.
switchedNetworkArea
integer
Switch network area associated with an end user location.
associatedNA
integer
Network areas associated with the end user location.
updateAddressMode
Enum
Valid values of UpdateModeEnumType.
Table 6-10 describes the required fields for EndUserLocationKey.
Table 6-10 Required Fields for EndUserLocationKey
endUserLocationPrimaryKey
string
The end user location ID value of the end user location.
Table 6-11 describes the required fields for NetworkLocationKey.
Table 6-11 Required Fields for NetworkLocationKey
networkLocationPrimaryKey
string
The network location ID value of the network location.
Table 6-12 describes the required fields for NumberInventoryValue.
Table 6-12 Required Fields for NumberInventoryValue
identText
string
Logical identifier of the inventory item stored in the repository, for instance, IP Addresses and Domain Names.
identTextSuffix
string
Value that uniquely defines the Ident Text within an item type category.
userPassword
string
User password for access to the internet.
emailPassword
string
User password for access to the email box.
nIStatus
string
Specifies the status of the inventory item.
apiActivity
string
Code set by the API to pre-assign or flag Number Inventories (for instance, telephone numbers and email addresses) that are used in a subsequent API order import process. The API pre-assign process exists because of the time-lag between the assignment of the number inventory to a customer and the actual assignment of that number inventory through the API order import.
toEffectDate
CbeDateTime
Date the entity type instance became inactive.
fromEffectDate
CbeDateTime
Date the entity type instance became effective.
numberInventoryType
string
Defines the valid Number Inventory Types that can be stored in number inventory.
Table 6-13 describes the required fields for metaSolvNumberInventoryKey.
Table 6-13 Required Fields for metaSolvNumberInventoryKey
numberInventoryKey
int
Foreign key to the entity NI_NBR_INV. The TEL_NUM_INV table stores all the US telephone numbers. This table is a subtype of number inventory table. This new attribute establishes a relationship between TEL_NUM_INV and the Number Inventory tables.
The createEntityByValueResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-14 describes the returned information in the response.
Table 6-14 Payload Information for the Response
Name Defined As Type Definition File Name
createEntityByValueRequestResponse
element
InventoryAPI.wsdl
element
createEntityValueResponse
element
CreateEntityResponseChoice
complexType
  • createPSRServiceLocationResponse
  • createNumberInventoryResponse
element
CreatePSRServiceLocationRespone
CreatePSRServiceLocationResponse
complexType
  • endUserLocationKey
  • addressKey
endUserLocationKey
complexType
addressKey
element
String
element
CreateNumberInventoryRespone
complexType
complexType
Table 6-15 describes the error messages for the operation.
Table 6-15 Error Messages for the Operation
Error Message Cause Resolution
Invalid Relationship: Network Area is Invalid for switch.
The input switch details do not map with network area information.
Populate the switch details which has the provided network area.
Missing Data: End User Location does not exist.
The input end user location ID does not exist in the database.
Verify the end user location ID and provide a valid value.
Missing Data: Network Location does not exist for this LocationIdSr.
The input network location ID (location_id_sr) does not exist in the database.
Please verify the network location id (location_id_sr) and provide a valid value.
Error. E-mail name is required for importing E-mail Number Inventory Item
The input email name is empty.
For creating inventory of EMAIL, you must pass the email ID.
Error. URL Domain is required for importing URL Number Inventory Item.
The input URL domain value is passed as an empty value.
For creating URL inventory, URL domain name is required in the input structure.
createLocationRequest Operation
This operation creates an end user, or network location object in the system and returns the key for the new object.
Request Structure: createLocationRequest
Response Structure: createLocationRequestResponse
The createLocationRequest element contains the input information for the operation. Each row in Table 6-16 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-16 Payload Information for the Request
element
mimCreateLocationRequest
InventoryAPI.wsdl
element
locationValue
locationValue
element
MimLocationValue
MimLocationValue
complexType
networkLocationValue
element
NetworkLocationValue
complexType
NetworkLocationRelationship
complexType
endUserLocationValue
element
complexType
  • EndUserLocationAddressRange
  • SecondaryLSO
endUserLocationKey
complexType
complexType
SecondaryLSO
complexType
netLocAddress
element
netLocAddress
netLocAddress
complexType
sfAddress
sfAddress
element
StructureFormatType
StructureFormatType
complexType
complexType
caUsageInstance
element
CaUsageInstanceType
CaUsageInstanceType
complexType
caUsageValue
caUsageValue
element
CaUsageValueType
CaUsageValueType
complexType
metaSolvUserDataValue
element
complexType
MetaSolvUserDataValueType
complexType
UserDataValueType
UserDataValueType
complexType
BaseNameValueType
tandemType
element
TandemType
TandemType
complexType
associatedNetworkArea
element
AssociatedNetworkArea
complexType
Table 6-17 describes the required fields for MimLocationValue.
Table 6-17 Required Fields for MimLocationValue
locationType
Enum
Valid values of LocationTypeEnumType. Indicates if a location is a network location, end-user location, or both (an end-user location with a network location alias).
locationId
string
Numeric value. New location when locationId is equal to 0. If locationId ID greater then 0, then it is an update of the location.
Table 6-18 describes the required fields for NetworkLocationValue.
Table 6-18 Required Fields for NetworkLocationValue
locationCodeFormat
string
Select CLLI if you use 8- to 11-character Telcordia standard code.
locationCode
string
Location identification code that identifies specific locations or terminations. This code may be free-form and user-defined, or the Common Language Location. Identification (CLLI) code administered by Telcordia.
locationName
string
Full name of the network location.
switchingOfficeClass
string
Class of a switch in a telephone network.
exchangeArea
string
The CO exchange area, or central office, related to the network location. This item is created on the CO Exchange Area window.
locationCategory
string
Class of network locations.
locationTypeId
string
Function a network location plays in supporting a network and a business.
intraNodalSwitching
boolean
Indicates a network location can provide switching functions on either a routine or an emergency basis.
emergencySwitching
boolean
Indicates the network location that can provide switching functions on an emergency basis only.
owned
boolean
Indicates you own the network location and the network location does not serve as an access customer terminal location (ACTL)/Gateway.
ACTL
boolean
Indicates the network location serves as an access customer terminal location or gateway.
Table 6-19 describes the required fields for NetworkLocationRelationship.
Table 6-19 Required Fields for NetworkLocationRelationship
locationIdRel
string
Location ID rel value.
locationRelTypeCode
string
Relationship to the network location entered in the Exchange Area field on the Network Location Assistant - Physical Location Information: Classes and Functions window.
actionCode
string
Action code.
Table 6-20 describes the required fields for EndUserLocationValue.
Table 6-20 Required Fields for EndUserLocationValue
endUserLocationName
string
Full name of the end user location.
endUserLocationType
string
Identifies the type of location.
e911PayableEntity
string
telephoneNumberSwitchLocationId
string
Sequence number that uniquely identifies a location. In this case it is the location associated with this address.
dataSwitchLocationId
string
Table 6-21 describes the required fields for EndUserLocationKey.
Table 6-21 Required Fields for EndUserLocationKey
string
End user location ID value.
Table 6-22 describes the required fields for EndUserLocationAddressRange.
Table 6-22 Required Fields for EndUserLocationAddressRange
fromRange
long
Starting point for a range.
toRange
long
Ending number in a range of address numbers.
numberPattern
string
Enables selection of odd or even numbering for an address number range.
Table 6-23 describes the required fields for SecondaryLSO.
Table 6-23 Required Fields for SecondaryLSO
networkLocationId
string
Code for identifying a physical point in a network.
servingOfficeTypeCode
string
Type of local serving office (LSO) used for a circuit.
actionCode
string
Action code.
Table 6-24 describes the required fields forNetLocAddress.
Table 6-24 Required Fields for NetLocAddress
primaryIndicator
boolean
Indicates if this record is the primary network location address and whether to display the primary address of a network location in infrastructure.
addressImpactMode
string
Address impact mode.
addressId
string
Address ID.
Table 6-25 describes the required fields for CaUsageInstanceType.
Table 6-25 Required Fields for CaUsageInstanceType
caUsageKey
integer
Unique ID of a custom attribute.
caValueLabel
string
Label of a custom attribute.
Table 6-26 describes the required fields for CaUsageValueType.
Table 6-26 Required Fields for CaUsageValueType
caValueKey
integer
Key of valid value CA.
caValue
string
Value of a custom attribute.
caUom
string
Unit of measure, for example: meters, feet.
caUsageVvKey
integer
Table 6-27 describes the required fields for UserDataValueType.
Table 6-27 Required Fields for UserDataValueType
tableNm
string
Table where the user data is stored. This table corresponds to where the user data was originally defined.
keyColumnNm
string
Actual primary key column name of the product area. This is required so the user data row can be associated with one item.
keyValue
integer
Actual value of the product area.
Table 6-28 describes the required fields for BaseNameValueType.
Table 6-28 Required Fields for BaseNameValueType
column
string
User data column that is updated.
value
string
Value entered into the defined column.
dataType
string
Function of a user data field. Determines the kind of information a user can enter in a field on the User Data window. Valid Values: Number, Decimal, VARCHAR2, Date, Dropdown.
Table 6-29 describes the required fields for TandemType.
Table 6-29 Required Fields for TandemType
tandemLocationId
string
Unique identifier for a specific location. This ID, visible only to the system, is used to store and retrieve information about the location.
tandemServiceType
string
Code that identifies the type of function performed by the tandem and whether this function is for originating (ORIG) or terminating (TERM) traffic from or to a subtending End Office.
tandemTrafficType
string
Code indicating whether the end office uses this tandem for ORIG or TERM traffic of a specific type.
actionCode
string
Action code.
Table 6-30 describes the required fields for AssociatedNetworkArea.
Table 6-30 Required Fields for AssociatedNetworkArea
networkAreaId
string
Sequence number that uniquely identifies entities of this type.
Name
string
Name of the network area.
actionCode
string
Action code value.
The createLocationRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-31 describes the returned information in the response.
Table 6-31 Payload Information for the Response
element
createLocationResponse
InventoryAPI.wsdl
element
CreateLocationResponse
complexType
networkLocationKey
networkLocationKey
complexType
Table 6-32 describes the error messages for the operation.
Table 6-32 Error Messages for the Operation
Location not found.
The input network location ID does not exist.
Populate a valid network location ID in the input
The End User Location Type must be populated with a valid value (NEWARCH, PREMISE, PRILOC, or SECLOC).
The input end user location type is not valid.
Populate the end user location type with one of the valid values NEWARCH, PREMISE, PRILOC, or SECLOC.
The network area {0} cannot be a switch network area for this Location because it is not served by the specified TN Switch.
The populated network area is not served by the TN switch populated.
Populate the network area which is associated to the specified TN switch.
createNewInventoryItemRequest Operation
This operation creates a new inventory item by populating the inventory item structure.
Request Structure: createNewInventoryItemRequest
Response Structure: createNewInventoryItemResponse
The createNewInventoryItemRequest element contains the input information for the operation. Each row in Table 6-33 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-33 Payload Information for the Request
element
mimCreateNewInventoryItemRequest
InventoryAPI.wsdl
element
inventoryItem
inventoryItem
complexType
  • metaSolvNumberInventoryKey
  • inventoryType
  • inventorySubType
  • inventoryStatus
complexType
inventoryType
complexType
inventorySubType
complexType
inventoryStatus
complexType
Table 6-34 describes the required fields for MetaSolvNumberInventoryKey.
Table 6-34 Required Fields for MetaSolvNumberInventoryKey
numberInventoryKey
int
Number Inventory Identifier is the foreign key to the entity NI_NBR_INV. The Tel_Num_Inv table stores all the US telephone numbers. This table is a subtype of number inventory table. This new attribute establishes a relationship between Tel_Num_Inv and the Number Inventory tables.
Table 6-35 describes the required fields for inventoryType.
Table 6-35 Required Fields for inventoryType
Code
Enum
Valid values of InventoryTypeCodeTypeEnum. The code that identifies the type of inventory item stored.
Alpha
string
Alpha equivalent of the Number Inventory type code.
Table 6-36 describes the required fields for InventorySubType.
Table 6-36 Required Fields for InventorySubType
Code
Enum
Valid values of InventoryTypeCodeTypeEnum. The code that identifies the inventory item type subtype.
Alpha
string
Alpha equivalent of valid subtype code of inventory item type.
Table 6-37 describes the required fields for InventoryStatus.
Table 6-37 Required Fields for InventoryStatus
Code
Enum
Valid values of InventoryTypeCodeTypeEnum. The code that identifies the status of the inventory item.
Alpha
string
Alpha equivalent of the Number Inventory status code Alpha Description.
The createNewInventoryItemResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-38 describes the returned information in the response.
Table 6-38 Payload Information for the Response
Name Defined As Type Description File name
element
InventoryAPI.wsdl
element
complexType
networkLocationKey
networkLocationKey
complexType
getAvailablePhysicalPortsRequest Operation
This operation retrieves the available physical port details for the provided network node key.
Request Structure: getAvailablePhysicalPortsRequest
Response Structure: getAvailablePhysicalPortsRequestResponse
The getAvailablePhysicalPortsRequest element contains the input information for the operation. Each row in Table 6-39 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-39 Payload Information for the Request
getAvailablePhysiclaPortsRequest
element
mimGetAvailablePhysicalPortsRequest
InventoryAPI.wsdl
element
GetAvailablePhysicalPortsRequestValue
element
getAvailablePhysicalPortsRequestValueType
element
networkNodeKey
networkNodeKey
complexType
networkNodePrimaryKey
Table 6-40 describes the required fields for networkNodeKey.
Table 6-40 Required Fields for networkNodeKey
string
The network node ID where the physical port details are configured.
The getAvailablePhysicalPortsRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-41 describes the returned information in the response.
Table 6-41 Payload Information for the Response
element
getAvailablePhysicalPortsResponse
InventoryAPI.wsdl
element
physicalPort
physicalPort
complexType
  • Port
  • hasSubPorts
Port
complexType
equipmentKey
element
EquipmentKey
Table 6-42 describes the error messages for the operation.
Table 6-42 Error Messages for the Operation
Network Node Key is required criteria.
The network node ID is not populated in the input structure.
Populate the network node ID value on the network node key.
getDlrByKeyRequest Operation
This operation retrieves the location information by using the supplied location key.
Request Structure: getDlrByKeyRequest
Response Structure: getDlrByKeyRequestResponse
getDlrByKeyRequest
The getDlrByKeyRequest element contains the input information for the operation. Each row in Table 6-43 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-43 Payload Information for the Request
getDlrByKeyRequest
element
mimGetEntityByKeyRequest
InventoryAPI.wsdl
element
getEntityByKeyValueChoice
complextype
  • getPSRServiceLocationByKey
  • getDlrByKey
element
serviceLocationKey
serviceLocationKey
complexType
endUserLocationKey
endUserLocationKey
complexType
getDlrByKey
element
metaSolvDLRKey
metaSolvDLRKey
element
MetaSolvDLRKey
MetaSolvDLRKey
complexType
Extension of EntityKey
Contains: dlrPrimaryKey
dlrPrimaryKey
complexType
DLRPrimaryKey
Table 6-44 describes the required fields for endUserLocationKey.
Table 6-44 Required Fields for endUserLocationKey
string
End user location ID of the location.
Table 6-45 describes the required fields for DLRPrimaryKey.
Table 6-45 Required Fields for DLRPrimaryKey
circuitDesignIDNumber
long
Circuit design ID value for which the DLR information is required.
Issue
long
Issue number of the circuit for which the DLR is required. Zero (0) should be passed if all the issue details are required.
The getDlrByKeyRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-46 describes the returned information in the response.
Table 6-46 Payload Information for the Response
element
getEntityByKeyResponse
InventoryAPI.wsdl
element
getEntityByKeyResponseChoice
complexType
  • getPSRServiceLocationResponse
  • getDlrByKeyResponse
complexType
  • serviceLocationValue
  • addressKey
addressKey
complexType
addressPrimaryKey
complexType
serviceLocationKey
element
EndUserLocationKey
networkLocationKey
element
networkLocationKey
structureFormats
element
StructureFormatType
getDlrByKeyResponse
element
dlrValue
dlrValue
complexType
dlrKey
element
MetaSolvDLRKey
dlrCircuitInfo
element
DLRCircuitInfo
dlrAdminInfo
element
DLRAdminInfo
dlrDesignInfo
element
DLRDesignInfo
dlrEndUserInfo
element
DLREndUserInfo
designLines
element
DLRDesignLine
Notes
element
DLRNote
Table 6-47 describes the error messages for the operation.
Table 6-47 Error Messages for the Operation
DLR Data Not Found for CircuitDesignId=circuitDesignIdInput Issue Number=issueNumberInput
The DLR data does not exist for the provided input values of circuit design ID and issue number.
Populate the circuit design ID and issue number with values that has DLR data existing in the database.
Circuit design id is not valid
The circuit design ID passed in the input is not valid.
Populate the circuit design ID with a value that is valid and exists in the database.
DLR for circuit issue not found
For the provided circuit design ID, the issue number does not exist.
Populate a valid issue number of the circuit design ID to get the DLR output.
getDlrByOrderKey Operation
This operation retrieves the Circuit Design (DLR) information for an input order key (document number).
Request Structure: getDlrByOrderKey
Response Structure: getDlrByOrderKeyResponse
getDlrByOrderKey
The getDlrByOrderKey element contains the input information for the operation. Each row in Table 6-48 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-48 Payload Information for the Request
getDlrByOrderKey
element
getServiceRequestDLRsValue
InventoryAPI.wsdl
element
GetServiceRequestDLRsValue
complexType
Extension of MomQueryValue
  • orderKey
orderKey
element
OrderKey
OrderKey
complexType
primaryKey
Table 6-49 describes the required fields for OrderKey.
Table 6-49 Required Fields for OrderKey
primaryKey
string
Document number of the circuit for which the DLR information is required.
The getDlrByOrderKeyResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-50 describes the returned information in the response.
Table 6-50 Payload Information for the Response
element
getServiceRequestDLRsResponse
InventoryAPI.wsdl
complexType
  • orderKey
  • dlrResults
orderKey
element
primaryKey
dlrResults
element
DLRResult
DLRResult
complexType
dlrIssues
element
DLRIssue
DLRIssue
complexType
Table 6-51 describes the error messages for the operation.
Table 6-51 Error Messages for the Operation
Document Number is not populated.
The input value of document number is not populated.
Populate the document number with a valid value.
getEntityByKeyRequest Operation
The getEntityByKeyRequest operation provides the following:
  • Retrieving the PSR Service Location details.
  • Retrieving the DLR information.
Request Structure: getEntityByKeyRequest
Response Structure: getEntityByKeyRequestResponse
The getEntityByKeyRequest element contains the input information for the operation. Each row in Table 6-52 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-52 Payload Information for the Request
element
InventoryAPI.wsdl
element
complexType
  • getDlrByKey
complexType
serviceLocationKey
serviceLocationKey
complexType
endUserLocationKey
getDlrByKey
element
metaSolvDLRKey
metaSolvDLRKey
element
MetaSolvDLRKey
MetaSolvDLRKey
complexType
dlrPrimaryKey
complexType
DLRPrimaryKey
Table 6-53 describes the required fields for EndUserLocationKey.
Table 6-53 Required Fields for EndUserLocationKey
string
Table 6-54 describes the required fields for DLRPrimaryKey.
Table 6-54 Required Fields for DLRPrimaryKey
long
Issue
long
The getEntityByKeyRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-55 describes the returned information in the response.
Table 6-55 Payload Information for the Response
element
InventoryAPI.wsdl
element
complexType
complexType
  • addressKey
addressKey
complexType
addressPrimaryKey
complexType
serviceLocationKey
element
EndUserLocationKey
networkLocationKey
element
networkLocationKey
structureFormats
element
StructureFormatType
getDlrByKeyResponse
element
dlrValue
dlrValue
complexType
dlrKey
element
MetaSolvDLRKey
dlrCircuitInfo
element
DLRCircuitInfo
dlrAdminInfo
element
DLRAdminInfo
dlrDesignInfo
element
DLRDesignInfo
dlrEndUserInfo
element
DLREndUserInfo
designLines
element
DLRDesignLine
Notes
element
DLRNote
Table 6-56 describes the error messages for the operation.
Table 6-56 Error Messages for the Operation
Location data not found for Location Key
The location details does not exist for the provided location ID.
Populate the location ID which has the service location details.
getIpAddressesRequest Operation
This operation retrieves IP Addresses based on the criteria specified in the request. You must specify either the network area name or network area key.
Request Structure: getIpAddressesRequest
Response Structure: getIpAddressesRequestResponse
The getIpAddressesRequest element contains the input information for the operation. Each row in Table 6-57 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-57 Payload Information for the Request
element
mimGetIpAddressesRequest
InventoryAPI.wsdl
element
GetIpAddressesRequestValue
element
IpAddressCriteria
IpAddressCriteria
complexType
  • networkArea
  • ipAddressesValue
networkArea
complexType
networkAreaKey
networkAreaKey
complexType
networkAreaPrimaryKey
ipAddressesValue
complexType
Table 6-58 describes the required fields for networkAreaKey.
Table 6-58 Required Fields for networkAreaKey
string
Identifier or key for the network area.
Table 6-59 describes the required fields for ipAddressesValue.
Table 6-59 Required Fields for ipAddressesValue
IPaddress
string
IP address for which the details are required.
Subnet
string
Defines the portion of the IP address that is the network prefix. The remaining portion of the IP address is the host number. If not populated, then the value is defaulted to 0.
Status
Enum
Valid values of IpAddressStatusEnumType. Assignment status of the IP address. If not defined or value equal to 0, then the search ignores the status.
useGroupCode
string
Used to describe the intended use for IP addresses. If not populated, then the value is defaulted to 0. If value is 0, then the use group is ignored.
useCodeCode
string
Used with use groups to identify intended IP address usage more specifically. If not populated, then the value is defaulted to 0 and the use code is ignored.
retrivalLimit
string
Number of IP Addresses that should be returned. If not defined or value equal to 0, then all IP Addresses are returned.
The getIpAddressesRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-60 describes the returned information in the response.
Table 6-60 Payload Information for the Response
element
getIpAddressesResponse
InventoryAPI.wsdl
element
GetIpAddressesResponseValue
element
IpAddressesValue
IpAddressesValue
complexType
getLocationRequest Operation
This operation retrieves the location information for the input location key.
Request Structure: getLocationRequest
Response Structure: getLocationRequestResponse
getLocationRequest
The getLocationRequest element contains the input information for the operation. Each row in Table 6-61 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-61 Payload Information for the Request
getLocationRequest
element
getLocationRequest
InventoryAPI.wsdl
getLocationRequest
element
mimGetLocationRequest
element
networkLocationKey
networkLocationKey
complexType
The getLocationRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-62 describes the returned information in the response.
Table 6-62 Payload Information for the Response
element
getLocationResponse
InventoryAPI.wsdl
getLocationResponse
element
locationValue
locationValue
element
MimLocationValue
MimLocationValue
complexType
locationType
element
element
element
netLocAddress
element
netLocAddress
caUsageInstance
element
CaUsageInstanceType
element
tandemType
element
TandemType
element
Table 6-63 describes the error messages for the operation.
Table 6-63 Error Messages for the Operation
The location details do not exist for the provided location ID.
Populate the location ID with a valid value that has service location details.
getNetworkAreasByGeoAreaRequest Operation
This operation retrieves the network areas given the input geographical area criteria. You must pass the geographic area values in the order of the Geo Area Type (GAT) hierarchy defined for the country in the Utilities application. A GAT hierarchy can consist of up to seven GA types.
Request Structure: getNetworkAreasByGeoAreaRequest
Response Structure: getNetworkAreasByGeoAreaRequestResponse
The getNetworkAreasByGeoAreaRequest element contains the input information for the operation. Each row in Table 6-64 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-64 Payload Information for the Request
element
mimGetNetworkAreasByGeoAreaRequest
InventoryAPI.wsdl
element
geoAreaCriteria
geoAreaCriteria
complexType
Table 6-65 describes the required fields for GeoAreaCriteria.
Table 6-65 Required Fields for GeoAreaCriteria
geoAreaValue
string
Value represents the name or abbreviation of a geographic area.
isAbbreviation
boolean
Element indicates if the value defined in geoAreaValue element is abbreviated.
The getNetworkAreasByGeoAreaRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-66 describes the returned information in the response.
Table 6-66 Payload Information for the Response
element
getNetworkAreasByGeoAreaResponse
InventoryAPI.wsdl
element
networkArea
networkArea
complexType
  • networkAreaName
  • networkAreaKey
networkAreaKey
element
Table 6-67 describes the error messages for the operation.
Table 6-67 Error Messages for the Operation
At least one Geographic area is required.
No geographic area details are populated in the input.
Populate any one of the geographic area details in the input.
getNetworkComponentsRequest Operation
This operation retrieves network components based on the network area, component type and component status. The operation only retrieves network elements if the schema element networkElementOnly is set to true. You must either specify the network area name or network area key.
Request Structure: getNetworkComponentsRequest
Response Structure: getNetworkComponentsRequestResponse
The getNetworkComponentsRequest element contains the input information for the operation. Each row in Table 6-68 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-68 Payload Information for the Request
element
mimGetNetworkComponentsRequest
InventoryAPI.wsdl
element
GetNetworkComponentsRequestValue
element
getNetworkComponentsRequestValueType
complexType
networkArea
networkArea
element
networkArea
Table 6-69 describes the required fields for getNetworkComponentsRequestValueType.
Table 6-69 Required Fields for getNetworkComponentsRequestValueType
componentType
string
User-defined category for a network component, such as DSLAM. If populated, must be a valid component type.
componentStatus
Enum
Valid values of ComponentStatusEnumType. Status of the network component.
networkElementsOnly
boolean
Indicates that the query should return only components that are defined as network elements and are contained in a network system. If no value is passed, it defaults to false.
The getNetworkComponentsRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-70 describes the returned information in the response.
Table 6-70 Payload Information for the Response
element
getNetworkComponentsResponse
InventoryAPI.wsdl
element
networkComponent
networkComponent
complexType
componentStatus
element
componentKey
element
componentKey
N/A
componentLocationKey
element
N/A
networkNodeKey
element
networkNodeKey
N/A
Table 6-71 describes the error messages for the operation.
Table 6-71 Error Messages for the Operation
At least one network area is required.
No network area details are populated in the input.
Populate network area details in the input.
Network area name and network area key are not populated. Either can be populated, but both cannot be blank.
Network area name and key is not populated.
Populate with either a network area name or key or both. At least one value is required.
inventoryAssociationRequest Operation
This operation associates inventory details such as IP Address to IP Address, IP Address to Domain, and Domain to URL. You define the parent and child inventory IDs along with the type of association as input.
Request Structure: inventoryAssociationRequest
Response Structure: inventoryAssociationRequestResponse
The inventoryAssociationRequest element contains the input information for the operation. Each row in Table 6-72 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-72 Payload Information for the Request
element
createInventoryAssociationRequest
InventoryAPI.wsdl
element
importInventoryAssociationType
element
ImportInventoryAssociation
complexType
parentInventoryID
element
childInventoryID
element
Table 6-73 describes the required fields for ImportInventoryAssociation.
Table 6-73 Required Fields for ImportInventoryAssociation
inventoryRelationTypeCode
Enum
Valid values of InventoryRelationTypeCodeTypeEnum. Indicates the relation of the inventory items passed.
The inventoryAssociationRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-74 describes the returned information in the response.
Table 6-74 Payload Information for the Response
element
createInventoryAssociationResponse
InventoryAPI.wsdl
complexType
Status
processTNRecallRequestDocument Operation
This operation takes the input telephone number and recalls the specified telephone number.
Request Structure: processTNRecallRequest
Response Structure: processTNRecallResponse
The processTNRecallRequest element contains the input information for the operation. Each row in Table 6-75 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-75 Payload Information for the Request
element
InventoryAPI.wsdl
complexType
tn
Table 6-76 describes the required fields for processTNRecallRequest.
Table 6-76 Required Fields for processTNRecallRequest
tn
string
Telephone number for which the TN Recall should be invoked.
The processTNRecallResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-77 describes the returned information in the response.
Table 6-77 Payload Information for the Response
processTNRecallRequestDocumentResponse
element
element
ProcessTNRecallResponseValue
complexType
ProcessTNRecallResponseValueType
complexType
Table 6-78 describes the error messages for the operation.
Table 6-78 Error Messages for the Operation
Telephone Number {0} is not in the inventory
The telephone number does not exist in the inventory.
Populate the TN which exist in the inventory for RECALL.
queryEndUserLocation Operation
This operation requests end user location for specific criteria and limiting the number of records returned.
Request Structure: queryEndUserLocation
Response Structure: queryEndUserLocationResponse
The queryEndUserLocation element contains the input information for the operation. Each row in Table 6-79 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-79 Payload Information for the Request
element
queryEndUserLocationRequest
InventoryAPI.wsdl
complexType
queryEndUserLocationRequestValue
element
EndUserLocationQueryValue
complexType
sfAddress
sfAddress
element
StructureFormatType
StructureFormatType
complexType
complexType
Table 6-80 describes the required fields for EndUserLocationQueryValue.
Table 6-80 Required Fields for EndUserLocationQueryValue
networkLocationName
string
Name for a location.
enduserLocationName
string
Name of the end user location where the circuit is being provided.
countryId
long
Unique ID implemented with an Oracle sequence that identifies a GA instance for a structure format.
custAcctNbr
string
Customer account number.
The queryEndUserLocationResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-81 describes the returned information in the response.
Table 6-81 Payload Information for the Response
element
mimQueryEndUserLocationResponse
InventoryAPI.wsdl
element
queryEndUserLocationResponseValue
element
EndUserLocationResultValue
complexType
Table 6-82 describes the error messages for the operation.
Table 6-82 Error Messages for the Operation
Country not found in the database.
The country passed as input does not exist in the database.
Populate the country which exists in the database.
Cannot have a structure format address and the address lines or country id populated on the same query.
Both structure format and country ID has been populated in the input.
Either one of the structured format or country ID has to be populated.
queryInventoryManagementRequest Operation
This operation retrieves the inventory for queryTelephoneNumberInventoryValue and queryMSAGInventoryValue.
Request Structure: queryInventoryManagementRequest
Response Structure: queryInventoryManagementRequestResponse
The queryInventoryManagementRequest element contains the input information for the operation. Each row in Table 6-83 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-83 Payload Information for the Request
element
mimQueryInventoryManagementRequest
InventoryAPI.wsdl
complexType
MimQueryValue
MimQueryValue
element
MetaSolvInventoryQueryValueChoice
complexType
  • queryTelephoneNumberInventoryValue
  • queryMSAGInventoryValue
complexType
telephoneNumberSearchCritera
element
MetaSolvTelephoneNumberSearchCriteria
complexType
  • strucFmt
  • customerAccountKey
  • statusSeq
  • telnbrTypeCd
strucFmt
element
StructureFormatType
complexType
msagSearch
msagSearch
element
MetaSolvMSAGSearch
MetaSolvMSAGSearch
complexType
StructureFormatType
StructureFormatType
complexType
complexType
customerAccountKey
complexType
customerAccountPrimaryKey
statusSeq
element
TelephoneNumberStatusEnumArray
complexType
telephoneNumberStatus
element
TelephoneNumberStatusEnumType
telnbrTypeCd
element
TelephoneNumberTypeEnumArray
complexType
telephoneNumberType
telephoneNumberType
element
TelephoneNumberTypeEnumType
Table 6-84 describes the required fields for MetaSolvTelephoneNumberSearchCriteria.
Table 6-84 Required Fields for MetaSolvTelephoneNumberSearchCriteria
inventorySubTypeCd
int
Inventory sub type code.
locationCode
string
networkAreaCity
int
Oracle sequence that uniquely identifies a GA instance for a city. It enables the ability to tie a network area to an actual city.
networkAreaStateProv
int
Oracle sequence that uniquely identifies a GA instance for a state.
networkAreaCountry
int
Oracle sequence that uniquely identifies a GA instance for a country.
tniCategoryId
int
Telephone number category ID.
tniSubcategoryId
int
Telephone number sub category ID.
Table 6-85 describes the required fields for MetaSolvMSAGSearch.
Table 6-85 Required Fields for MetaSolvMSAGSearch
keyValue
string
partnerId
string
Partner ID.
Table 6-86 describes the required fields for StructureFormatType.
Table 6-86 Required Fields for StructureFormatType
sfType
string
name
string
Table 6-87 describes the required fields for StructureFormatComponentType.
Table 6-87 Required Fields for StructureFormatComponentType
Id
int
name
string
componentType
string
Value
string
Table 6-88 describes the required fields for customerAccountKey.
Table 6-88 Required Fields for customerAccountKey
MetaSolvCustom customerAccountPrimaryKey
string
Customer account primary key value which is the customer account number.
Table 6-89 describes the required fields for TelephoneNumberStatusEnumArray.
Table 6-89 Required Fields for TelephoneNumberStatusEnumArray
Enum
Valid values of TelephoneNumberStatusEnumType.
Table 6-90 describes the required fields for TelephoneNumberTypeEnumArray.
Table 6-90 Required Fields for TelephoneNumberTypeEnumArray
telephoneNumberType
Enum
Valid values of TelephoneNumberTypeEnumType.
The queryInventoryManagementRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-91 describes the returned information in the response.
Table 6-91 Payload Information for the Response
element
InventoryAPI.wsdl
element
MimQueryResponse
MimQueryResponse
element
complexType
  • queryTelephoneNumberInventoryResponse
  • queryMSAGResponse
QueryTelephoneNumberInventoryResponse
complexType
  • telephoneNumberArray
  • checkOutId
element
TelephoneNumberValueArray
element
item
Item
element
MetaSolvTelephoneNumberValue
complexType
element
customerAccountKey
element
MetaSolvCustomerAccountKey
structureFormat
element
StructureFormatType
Reservation
element
TelephoneNumberReservationType
QueryMSAGResponse
complexType
  • msagAddress
  • errorMessages
msagAddress
element
MetaSolvMSAGAddress
MetaSolvMSAGAddress
element
MSAGAddressType
MSAGAddressType
complexType
Table 6-92 describes the error messages for the operation.
Table 6-92 Error Messages for the Operation
Status, Customer Id or Reservation is required.
Status, customer ID or reservation is not populated.
Populate either status, customer ID or reservation in the input structure.
Inventory subtype code is required.
Inventory subtype code is not populated.
Populate Inventory subtype code in the input structure.
Miscellaneous Error: No Network Preference set up.
EnableNetworkAreas preference is not set.
Enable the EnableNetworkAreas preference.
queryNetworkLocation Operation
This operation requests network locations for specific criteria and limits the number of records returned.
Request Structure: queryNetworkLocation
Response Structure: queryNetworkLocationResponse
The queryNetworkLocation element contains the input information for the operation. Each row in Table 6-93 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-93 Payload Information for the Request
element
queryNetworkLocationRequest
InventoryAPI.wsdl
complexType
queryNetworkLocationRequestValue
element
NetworkLocationQueryValue
complexType
sfAddress
StructureFormatType
complexType
complexType
Table 6-94 describes the required fields for NetworkLocationQueryValue.
Table 6-94 Required Fields for NetworkLocationQueryValue
locationCodeFormat
long
Indicates the industry format used to create the location code.
networkLocationCode
string
Location identification code that identifies specific locations or terminations. This code may be free-form and user-defined, or the Common Language Location Identification (CLLI) code administered by Telcordia.
networkLocationName
string
Name for a location. This name often appears in the Description field of the Telcordia CLLI practice.
networkLocationTypeId
long
Unique identifier sequence number that identifies the Network Location Type.
countryId
long
Unique ID implemented with an Oracle sequence that identifies a GA instance for a structure format. This is required if the query is done using Country ID. This is not required if the search uses structure format.
version
string
Used to convert the container to the appropriate generated structure class. Currently not used and defaulted to 1.
maxRow
string
Number of End User Location that should be returned. If not defined or the value is equal to 0, then all End User Locations are returned.
The queryNetworkLocationResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-95 describes the returned information in the response.
Table 6-95 Payload Information for the Response
element
mimQueryNetworkLocationResponse
InventoryAPI.wsdl
element
queryNetworkLocationResponseValue
element
NetworkLocationResultValue
complexType
sfAddress
element
StructureFormatType
processtnValidationRequest Operation
This operation validates an input telephone number including the additional input as criteria.
Request Structure: processTNValidationRequest
Response Structure: processTNValidationResponse
The processTNValidationRequest element contains the input information for the operation. Each row in Table 6-96 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-96 Payload Information for the Request
tnValidationRequest
element
InventoryAPI.wsdl
complexType
Table 6-97 describes the required fields for processTNValidationRequest.
Table 6-97 Required Fields for processTNValidationRequest
tnNumber
string
Telephone number for which the validation is required.
validationType
Enum
Valid values of TNValidationTypeEnumType.
activityType
Enum
Valid values of TNActivityTypeEnumType.
allowICP
boolean
Indicates whether to allow the ICP or not.
The processTNValidationResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-98 describes the returned information in the response.
Table 6-98 Payload Information for the Response
tnValidationRequestResponse
element
InventoryAPI.wsdl
complexType
ProcessTNValidationResponseValue
Table 6-99 describes the error messages for the operation.
Table 6-99 Error Messages for the Operation
The Telephone Number is incomplete.
The populated telephone number is not complete number.
Populate a valid telephone number in the input structure.
The Telephone Number activity is invalid.
The activity populated is not valid.
Populate a valid TN activity in the input structure.
updateEntityByValueRequest Operation
This operation updates the inventory details for the following:
  • The attributes of the location that are populated (updatePSRServiceLocationValue)
  • Releases the previously reserved telephone numbers (updatePreAssignTelephoneNumberValue)
This operation only updates the attributes that are populated.
Request Structure: updateEntityByValueRequest
Response Structure: updateEntityByValueRequestResponse
The updateEntityByValueRequest element contains the input information for the operation. Each row in Table 6-100 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-100 Payload Information for the Request
element
mimUpdateEntityByValueRequest
InventoryAPI.wsdl
element
updateEntityValue
updateEntityValue
element
UpdateEntityValueChoice
complexType
  • updatePSRServiceLocationValue
  • updatePreAssignTelephoneNumberValue
element
complexType
  • serviceLocationKey
  • networkLocationKey
  • updateAddressMode
  • structureFormats
serviceLocationKey
element
EndUserLocationKey
networkLocationKey
element
networkLocationKey
updateAddressMode
element
UpdateModeEnumType
structureFormats
element
StructureFormatType
element
UpdatePreAssignTelephoneNumberValue
complexType
preAssignTelephoneNumberValue
element
complexType
Extension of ResourceValue
Contains a list of fields and the following: metaSolvNumberInventoryKey
complexType
See Table 6-13.
Table 6-101 describes the required fields for EndUserLocationKey.
Table 6-101 Required Fields for EndUserLocationKey
string
Table 6-102 describes the required fields for NetworkLocationKey.
Table 6-102 Required Fields for NetworkLocationKey
string
Table 6-103 describes the required fields for StructureFormatType.
Table 6-103 Required Fields for StructureFormatType
sfType
string
name
string
Table 6-104 describes the required fields for PreAssignTelephoneNumberValue.
Table 6-104 Required Fields for PreAssignTelephoneNumberValue
inventorySubTypeCd
int
checkOutId
int
System generated number that is set by the operation when a number is exported.
quantity
int
Number to range from the starting point.
releaseIndicator
boolean
Specifies if these telephone numbers should be released.
activityIndicator
Enum
Valid values of TelephoneNumberActivityEnumType.
Activity code set by the operation to pre-assign or flag Number Inventories (for instance, telephone numbers and email addresses) that are used in a subsequent operation order import process.
The updateEntityByValueRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-105 describes the returned information in the response.
Table 6-105 Payload Information for the Response
element
updateEntityByValueResponse
InventoryAPI.wsdl
element
updateEntityResponse
complextype
  • updatePSRServiceLocationResponse
  • updatePreAssignTelephoneNumberResponse
complexType
  • locationKey
  • addressKey
locationKey
element
MetaSolvLocationKeyChoice
complexType
ServiceLocationKey
element
ServiceLocationKey
ServiceLocationKey
complexType
EndUserLocationKey
EndUserLocationKey
complexType
endUserLocationKey
element
EndUserLocationKey
EndUserLocationKey
complexType
networkLocationKey
element
NetworkLocationKey
NetworkLocationKey
complexType
addressKey
element
AddressKey
AddressKey
complexType
complexType
element
complexType
complexType
element
customerAccountKey
element
structureFormat
element
StructureFormatType
Reservation
element
updateLocationRequest Operation
This operation changes the attributes of a location. The operation only updates the attributes that are populated.
Request Structure: updateLocationRequest
Response Structure: updateLocationRequestResponse
The updateLocationRequest element contains the input information for the operation. Each row in Table 6-106 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-106 Payload Information for the Request
element
InventoryAPI.wsdl
element
mimUpdateLocationRequest
element
locationValue
locationValue
element
MimLocationValue
MimLocationValue
complexType
  • NetworkLocationValue
  • EndUserLocationValue
  • NetLocAddress
  • CaUsageInstanceType
  • metaSolvUserDataValue
  • TandemType
  • AssociatedNetworkArea
element
element
netLocAddress
element
netLocAddress
caUsageInstance
element
CaUsageInstanceType
element
tandemType
element
TandemType
element
The updateLocationRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-107 describes the returned information in the response.
Table 6-107 Payload Information for the Response
element
updateLocationResponse
InventoryAPI.wsdl
element
UpdateLocationResponse
complexType
networkLocationKey
networkLocationKey
complexType
updateTNRequest Operation
This operation updates the telephone number.
Request Structure: updateTNRequest
Response Structure: updateTNRequestResponse
updateTNRequest
The updateTNRequest element contains the input information for the operation. Each row in Table 6-108 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 6-108 Payload Information for the Request
updateTNRequest
element
mimUpdateTNRequest
InventoryAPI.wsdl
mimUpdateTNRequest
element
UpdateTNRequestValue
element
complexType
  • structureFormat
  • reservation
element
customerAccountKey
element
structureFormat
element
StructureFormatType
reservation
element
element
telephoneNumberTypeCode
element
Table 6-109 describes the required fields for MetaSolvTelephoneNumberValue.
Table 6-109 Required Fields for MetaSolvTelephoneNumberValue
countryCode
string
Identifies the country code for a telephone number. This is different from the postal country code on the country table. It defaults from a preference.
telephoneNumberSuf
string
Used when numbers are in high demand and limited supply. This allows for faster turn around time on reuse of a number as toll can be tracked down to this PIN.
Enum
Valid values of TelephoneNumberStatusEnumType. This gives information about the state of a telephone number.
Enum
Valid values of TelephoneNumberTypeEnumType. Determines the type of telephone number.
locationId
long
Required code for identifying a network location.
Table 6-110 defines the reservation element.
Table 6-110 reservation Definition
reservation
element
complexType
  • telephoneNumberReservationKey
TelephoneNumberReservationKey
complexType
reservationKey
customerAccountKey
element
complexType
Table 6-111 describes the required fields for reservation.
Table 6-111 Required Fields for reservation
qtyOfWtn
int
Number of telephone numbers that are reserved on this telephone number reservation.
reservationNbr
int
Identifier of the reservation that is meaningful for the customer/user reserving the phone numbers.
reservationExpiredInd
YesNoIndicatorType
If a telephone number reservation has expired, then set this indicator to Y. The other valid value is the default N.
endUserLoc
string
Free form text area where the customer reserving the telephone numbers can indicate an end user location for which the numbers are being reserved.
reservedReason
string
Indicates why this telephone number is reserved. For example, it can be reserved because it is a vanity number, or because a customer has requested it.
requestedByName
string
Person who initiated the request for the customer, such as the salesperson.
Table 6-112 describes the required fields for TelephoneNumberReservationKey.
Table 6-112 Required Fields for TelephoneNumberReservationKey
reservationKey
integer
Reservation key.
The updateTNRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 6-113 describes the returned information in the response.
Table 6-113 Payload Information for the Response
element
updateTNResponse
InventoryAPI.wsdl
updateTNResponse
complexType
UpdateTNReponseValue
