7 Order Web Service Reference
This chapter provides information about Oracle Communications MetaSolv Solution (MSS) Order Web Service.
About the Order Web Service
The Order Web Service enables an external system to import and maintain order information in MSS. Order Web Service operations enable you to:
  • Create, get, update, and finish an order.
  • Complete, reopen, and a transfer task for an order.
  • Assign a provisioning plan to an order.
  • Process a supplement order.
  • Get and update CNAM/LIDB and E911 data.
    The following summarizes the CNAM/LIDB and E911 data terms:
    • Calling Name (CNAM) is a telephone service used to display the name and telephone number of the caller.
    • Line Database (LIDB) is a telephone service used to verify a telephone number for toll service and third-party billing, such as for validation of calling card numbers.
    • E911 is a telephone service used to provide emergency (911) operators with the caller's telephone number and location.
About the Order Web Service Packaging
The Order Web Service is packaged in the MSS_WebService.ear file, which contains the order.war file. When the installer deploys the EAR file, the Order Web Service is automatically deployed and ready to use.
The MSS_WebService.ear file also includes the other MSS web service operations. See "Web Services Overview" for information about these operations.
About the Order WSDL, WAR, and Schema Files
The Order Web Service is defined by the OrderAPI.wsdl file and is supported by numerous schema files. The WSDL file and supporting schema files are located in the order.war file.
See "Understanding How MSS Defines Web Services" for more information about WSDL and WAR files, and about their directory locations in the EAR file.
About Order Schema Files
Numerous schema files support the Order Web Service. Within the order.war file, the schema files are located in the WEB-INF/wsdls directory. These schemas are categorized as common schemas, entity schemas, and data schemas, and API schemas.
Common Schemas
For information about the common schema files, see "About Schema Files".
Entity Schemas
The entity schemas define elements, such as keys and types, specific to the web service.
The Order entity schemas are defined in the following files:
  • CustomerManagementEntities.xsd
  • InventoryManagementEntities.xsd
  • MIPCommonEntities.xsd
  • OrderManagementEntities.xsd
  • ServiceEntities.xsd
Data Schemas
The data schemas contain numerous complex type structures, enumerations, and simple types.
The Order data schemas are defined in the following files:
  • CustomerManagementData.xsd
  • InventoryManagementData.xsd
  • OrderAncillaryManagementData.xsd
  • OrderManagementData.xsd
  • ServiceData.xsd
  • ServiceOrderData.xsd
API Schemas
The API schemas contain the high-level response and request type definitions and exception definitions.
The Order API schemas are defined in the following files:
  • InventoryManagementAPI.xsd
  • OrderAPI.wsdl
  • OrderManagementAPI.xsd
addTaskRequest Operation
The addTaskRequest operation enables external systems to add a task to an existing provisioning plan assigned order which is not completed.
The following are the request and response structures:
Request Structure: addTaskRequest
Response Structure: addTaskRequestResponse
addTaskRequest
The addTaskRequest element contains the input information for the operation. Each row in Table 7-1 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-1 Payload Information for the Request
Name Defined As Type Description File Name
addTaskRequest
element
momAddTaskRequest
OrderAPI.wsdl
momAddTaskRequest
element
addTaskRequestValue
addTaskRequestValue
element
AddTaskRequestValueType
ComplexType
ComplexType with task, taskKey, addTaskPolicy
task
element
Task
Task
ComplexType
ComplexType with a list of fields
taskKey
element
TaskOrderKey
TaskOrderKey
ComplexType
addTaskPolicy
element
AddTaskPolicy
AddTaskPolicy
ComplexType
Table 7-2 describes the required fields for addTaskRequest.
Table 7-2 Required Fields
File Name Data Type Field Description
primaryKey
string
A system-assigned identifier for the document number. Value should be zero for creating new order.
The addTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-3 describes the returned information in the response.
Table 7-3 Payload Information for the Request
element
addTaskResponse
OrderAPI.wsdl
addTaskResponse
element
addTaskResponseValue
element
AddTaskResponseValueType
ComplexType
ComplexType with task, planKey, planDefinition
task
element
Task
Task
ComplexType
planKey
element
PlanKey
PlanKey
ComplexType
planDefinition
element
PlanDefinition
PlanDefinition
ComplexType
addTaskJeopardyRequest Operation
This operation enables external systems to add jeopardy information for a task. Adding jeopardy information with reason codes identifies a task as being at risk of completing late and specifies the reason for the risk.
Request Structure: addTaskJeopardyRequest
Response Structure: addTaskJeopardyResponse
The addTaskJeopardyRequest element contains the input information for the operation. Each row in Table 7-4 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-4 Payload Information for the Request
element
momAddTaskJeopardyRequest
OrderAPI.wsdl
element
addTaskJeopardyRequestValue
element
AddTaskJeopardyRequestValueType
complexType
Contains a list of fields
Table 7-5 describes the required fields for addTaskJeopardyRequest.
Table 7-5 Required Fields
Field Name Data Type Field Description
jeopId
int
Oracle-generated sequence that uniquely identifies the object in the MSS database.
docNum
OrderKey
System-assigned identifier for the document number.
taskNum
TaskKey
System-assigned identifier for the task.
jeopardyReasonCode
string
Four-digit numeric code for identifying why a key date was missed and why a task was not performed by the scheduled completion date.
The addTaskJeopardyResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-6 describes the returned information in the response.
Table 7-6 Payload Information for the Response
addTaskJeopardyRequestResponse
element
Contains the addTaskJeopardyResponse string
OrderAPI.wsdl
Table 7-7 describes the error messages for the operation.
Table 7-7 Error Messages for the Operation
Error Message Cause Resolution
The document number is not found.
The provided document number does not exist in the database.
Verify and pass in a valid document number.
The jeopardy reason code is not valid.
An invalid jeopardy reason code was provided in the request.
Verify and provide a valid jeopardy reason code value in the request.
assignProvPlanRequest Operation
This operation assigns a provisioning plan to the order. This operation takes the provisioning plan ID and order key as the input.
Request Structure: assignProvPlanRequest
Response Structure: assignProvPlanRequestResponse
The assignProvPlanRequest element contains the input information for the operation. Each row in Table 7-8 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-8 Payload Information for the Request
element
assignProvisionPlanProcedureRequest
OrderAPI.wsdl
element
AssignProvisionPlanProcedureValue
complexType
Extension of MetaSolvAssignProvPlanValue
Table 7-9 describes the required fields for ProvPlanRequest.
Table 7-9 Required Fields for ProvPlanRequest
OrderKey
OrderKey
Document number of the order to assign the provisioning plan.
ProvisioningPlanKey
string
Provisioning plan key value to be assigned to this order.
The assignProvPlanRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-10 describes the returned information in the response.
Table 7-10 Payload Information for the Response
element
assignProvisionPlanProcedureResponse
OrderAPI.wsdl
element
mommekey
Mommekey
element
MetaSolvOrderKeyChoice
complexType
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
Extension of ManagedEntityKey
Table 7-11 describes the error messages for the operation.
Table 7-11 Error Messages for the Operation
Miscellaneous Error: Tasks cannot be assigned. Order status is invalid.
Tasks are requested assignment when the order status is not valid for task assignment.
Change the status of the input order number or change the input order number.
billingTelephoneNumberRequest Operation
This operation assigns the billing telephone number (BTN) on an order that has multiple telephone numbers. This operation assigns and unassigns the billing telephone number. It takes the number inventory ID as input for the telephone number.
Request Structure: billingTelephoneNumberRequest
The billingTelephoneNumberRequest element contains the input information for the operation. Each row inTable 7-12 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-12 Payload Information for the Request
Name Defined As Type Definition File Name
element
OrderAPI.wsdl
complexType
Table 7-13 describes the required fields for billingTelephoneNumberRequest.
Table 7-13 Required Fields for billingTelephoneNumberRequest
documentNumber
long
Document number of the order where the billing telephone number is being set.
servItemId
long
Corresponding Service Item ID for the billing telephone number values.
BtnFunctionEnum
Enum
Corresponding BTN function ' 0 - Assign and 1 - Unassign'.
nbrInvId
long
Corresponding Number Inventory ID of the telephone number.
billingTelephoneNumberRequestResponse
The billingTelephoneNumberRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-14 describes the returned information in the response.
Table 7-14 Payload Information for the Response
element
billingTelephoneNumberResponse
OrderAPI.wsdl
complexType
Contains the documentNumber integer for the order
Table 7-15 describes the error messages for the operation.
Table 7-15 Error Messages for the Operation
BTN Assign/UnAssign is allowed only for ''pending'' or ''electronically received'' orders.
You are requesting an assign or unassign of billing telephone number for an order that is not in correct status.
You can only perform this action when the order is pending or electronically received.
completeTaskRequest Operation
This operation completes a task for an order. It takes order number and task number as input and marks the task as complete.
This completeTaskRequest operation is used for only complete task requests. The following are in the schema files, however this operation does not support:
  • updateServicesInOrderProcedureValue
  • updateOrderTaskGWEventValue
To run these operations, use the updateOrderRequest operation.
Request Structure: completeTaskRequest
Response Structure: completeTaskRequestResponse
completeTaskRequest
The completeTaskRequest element contains the input information for the operation. Each row in Table 7-16 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-16 Payload Information for the Request
completeTaskRequest
element
updateOrderManagementRequest
OrderAPI.wsdl
element
updateValue
updateValue
element
MetaSolvUpdateProcedureValueChoice
complexType
completeTaskProcedureValue
element
CompleteTaskProcedureValue
complexType
See Table 7-17
Table 7-17 defines CompleteTaskProcedureValue.
Table 7-17 CompleteTaskProcedureValue Definition
complexType
whyMissInputs
element
WhyMissInputType
WhyMissInputType
complexType
Table 7-18 describes the required fields for completeTaskRequest.
Table 7-18 Required Fields for completeTaskRequest
taskNumber
long
Task Number of the task to be completed.
OrderKey
OrderKey
Document Number of the order where the task is assigned.
whyMissReasonCode
string
Reason code for why the task was not completed on time. This field is only required when the task exceeds the actual completion date.
The completeTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful.Table 7-19 describes the returned information in the response.
Table 7-19 Payload Information for the Response
element
completeTaskProcedureResponse
OrderAPI.wsdl
element
CompleteTaskProcedureResponse
complexType
mommekey
mommekey
element
complexType
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
Table 7-20 describes the error messages for the operation.
Table 7-20 Error Messages for the Operation
Task row not found for document number, task number.
For the input document number and task number, the task could not be found in inventory.
Check that the document number and task number exist for the document number/order.
The task requires a why missed code before it can be completed.
For the input task number, the why-missed code is not yet populated to complete the task.
Populate the why-missed code for the task and then request the task completion again.
createAttachment Operation
The createAttachment operation creates an attachment for the input order.
Request Structure: createAttachment
Response Structure: createAttachmentResponse
createAttachment
The createAttachment element contains the input information for the operation. Each row in Table 7-21 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-21 Payload Information for the Request
CreateAttachment
element
createAttachmentRequest
OrderAPI.wsdl
element
CreateAttachmentRequestValue
element
CreateAttachmentType
complexType
Table 7-22 describes the required fields for createAttachment.
Table 7-22 Required Fields for createAttachment
attachmentKey
string
Valid PSR document number.
attachmentName
string
Valid attachment name which appears in GUI.
transformationName
string
Name of the XSL file stored in ms_attachment_transform table.
attachmentType
Enum
ORDER is the valid enum value for attachment.
The createAttachmentResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-23 describes the returned information in the response.
Table 7-23 Payload Information for the Response
element
momCreateAttachmentResponse
OrderAPI.wsdl
element
Contains the CreateAttachmentResponseValue long
createISROrderRequest Operation
This operation creates a new ISR order in the system and returns the new order key. A single OrderValue is the only value passed into the request. The state values in OrderValue are ignored; the state is initialized to STARTED by the system.
Request Structure: createISROrderRequest
Response Structure: createISROrderResponse
The createISROrderRequest element contains the input information for the operation. Each row in Table 7-24 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
This operation only supports the metaSolvISROrderValue schema in the request. For creating a PSR order using the metaSolvPSROrderValue schema, use the createOrderRequest and createPSROrderRequest operations.
Table 7-24 Payload Information for the Request
element
createOrderByValueRequest
OrderAPI.wsdl
element
Mommevalue
Mommevalue
element
MetaSolvOrderValueChoice
complexType
complexType with a choice of type:
  • metaSolvPSROrderValue
  • metaSolvISROrderValue
complexType
See Table 7-41
The complexType metaSolvISROrderValue for the create IRS order operation. metaSolvISROrderValue is a choice in the MetaSolvOrderValueChoice definition. The metaSolvISROrderValue element is mutually exclusive with the PSR order information metaSolvPSROrderValue.
Table 7-25 describes the required fields for ISROrderHeaderType.
Table 7-25 Required Fields for ISROrderHeaderType
externalOrderKey
string
External order key from the external system.
requestType
string
Request type for the ISR order.
activityCd
string
Activity code for the order.
broadbandServiceCategory
string
Broad band service category if required.
uniValue
string
UNI value for the order.
organizationId
string
Organization ID for the order.
userId
string
User ID for the order.
desiredDueDate
string
Desired due date for the order that is planned.
serviceOrderDate
string
Service order date for the order that is planned.
servReqStatus
int
Service request status of the order.
quantityUnit
string
Quantity on the order.
quantityCircuitUnit
int
Quantity of circuit on the order.
quantityVirtConnUnit
int
Quantity of virtual circuit on the order.
activeInd
string
Active Indicator for the order.
Table 7-26 describes the required fields for ISRContactType.
Table 7-26 Required Fields for ISRContactType
actionCd
string
Action code for the contact.
orderKey
int
Document number of the order.
companyContact
string
Company contact details of the order.
assocContactName
string
Associate contact details.
customerContactName
string
Customer contact details.
Table 7-27 describes the required fields for ISRNoteValueType.
Table 7-27 Required Fields for ISRNoteValueType
noteKey
int
Note key value.
actionCd
string
Action code for the note.
noteText
string
Data to be entered on the note.
circuitNoteInd
string
Note for the circuit.
Table 7-28 describes the required fields for ISRLocationValueType.
Table 7-28 Required Fields for ISRLocationValueType
isTerminationPoint
boolean
Indicates if this is a termination point.
netLocUse
string
Network location use code.
Table 7-29 describes the required fields for ISRServiceValueType.
Table 7-29 Required Fields for ISRServiceValueType
actionCd
string
Action code for the service.
activityCd
string
Activity code for the service.
serviceItemKey
string
Service item id of the ISR order.
orderKey
int
Table 7-30 describes the required fields for ISRRemarkType.
Table 7-30 Required Fields for ISRRemarkType
orderKey
int
formId
string
Form ID value.
seqNumber
int
Sequence number of the order.
remarkText
string
Remark that can be updated.
The createISROrderResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-31 describes the returned information in the response.
Table 7-31 Payload Information for the Response
element
createOrderByValueResponse
OrderAPI.wsdl
element
mommekey
mommekey
element
complexType
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
createOrderRelationship Operation
This operation creates a relationship between two input order numbers. The input values are parent order ID and child order ID.
Request Structure: createOrderRelationship
Response Structure: createOrderRelationshipResponse
The createOrderRelationship element contains the input information for the operation. Each row in Table 7-32 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-32 Payload Information for the Request
element
createOrderRelationshipRequest
OrderAPI.wsdl
complexType
Contains the following:
  • parentOrderKey
  • childOrderKey
Table 7-33 describes the required fields for createOrderRelationship.
Table 7-33 Required Fields for createOrderRelationship
parentOrderKey
OrderKey
Document number of the parent order of the relationship.
childOrderKey
OrderKey
Document number of the child order of the relationship.
The createOrderRelationshipResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-34 describes the returned information in the response.
Table 7-34 Payload Information for the Response
element
Contains the momCreateOrderRelationshipResponse string
OrderAPI.wsdl
createOrderRequest Operation
The createOrderRequest operation enables external systems to create orders in MSS. You can request two different types of orders with this operation: PSR orders and ISR orders.
Request Structure: createOrderRequest
Response Structure: createOrderRequestResponse
createOrderRequest
The createOrderRequest element contains the input information for the operation. Each row in Table 7-35 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-35 Payload Information for the Request
createOrderRequest
element
OrderAPI.wsdl
element
mommevalue
mommevalue
element
complexType
complexType
Described in Table 7-36
complexType
Described in Table 7-41
Table 7-36 describes the metaSolvPSROrderValue definition information for the create PSR order operation. metaSolvPSROrderValue was referenced in Table 7-35 as a choice in the MetaSolvOrderValueChoice definition. The metaSolvPSROrderValue element is mutually exclusive with the ISR order information.
Table 7-36 metaSolvPSROrderValue Definition
element
MetaSolvPSROrderValue
complexType
Extension of OrderValue
OrderHeaderType
metaSolvUserDataValue
MetaSolvServiceValueChoice
LineDirType
OrderValue
complexType
Extension of ManagedEntityValue
OrderHeaderType
complexType
complexType with a list of fields
complexType
MetaSolvUserDataValueType
complexType
UserDataValueType
UserDataValueType
complexType
BaseNameValueType
complexType
choice of metaSolvServiceValue
ServiceEntities.xsd
element
ServiceEntities.xsd
complexType
Extension of ServiceValue and a list of fields
ServiceEntities.xsd
ServiceValue
complexType
Extension of EntityValue
Service.xsd
EntityValue
complexType
CBEManagedEntityValue
Core.xsd
LineDirType
complexType
lineDirectoryType
lineDirectoryType
complexType
Table 7-37 describes the required fields for OrderValue.
Table 7-37 Required Fields for OrderValue
PrimaryKey
OrderKey
Value should be 0 if it is new or change order and the document number for update order.
Table 7-38 describes the required fields for OrderHeaderType.
Table 7-38 Required Fields for OrderHeaderType
organizationId
string
Organization responsible for processing the order and providing service.
servReqStatus
Enum
Valid values are defined in OrderStatusEnumType.
Any new or change order created through an API should have osRECEIVED which refers as Electronically Received order. For update order, the corresponding order status should be passed.
customerAccountKey
integer
Customer account key to associate to the order.
orderedByFirstName
string
First name of the individual placing the order.
orderedByLastName
string
Last name of the individual placing the order.
orderedByTelephoneNr
string
Telephone number of the individual placing the order.
desiredDueDate
CbeDateTime
Date that the customer desires the products to be installed and in-service.
serviceOrderDate
CbeDateTime
Date the order is placed (entered).
responsibleParty
string
Person responsible for the order, such as the customer care rep or the sales person.
orderActivityCd
Enum
Valid values are oaNEW, oaCHANGE and oaDISCONNECT
billActivationDate
CbeDateTime
Date for the customer invoice.
suppType
Enum
Valid values are stcorrect, stcancell, stduedate and stnone.
For a new order, this is always the value stnone and for update orders, this can be updated according to the requirement.
Table 7-39 describes the required fields for UserDataValueType.
Table 7-39 Required Fields for UserDataValueType
tableNm
string
Table where the user data is stored. This table corresponds to where the user data was originally defined.
keyColumnNm
string
Actual primary key column name of the product area. This is required so the user data row can be associated with one item.
keyValue
integer
Actual value of the product area.
Table 7-40 describes the required fields for BaseNameValueType.
Table 7-40 Required Fields for BaseNameValueType
column
string
Field is the user data column that is updated.
value
string
Value entered into the defined column.
dataType
string
Function of a user data field. Determines the kind of information a user can enter in a field on the User Data window. Valid values are Number, Decimal, VARCHAR2, Date, Dropdown.
Table 7-41 describes the metaSolvISROrderValue definition information for the create IRS order operation. metaSolvISROrderValue was referenced in Table 7-35 as a choice in the MetaSolvOrderValueChoice definition. The metaSolvISROrderValue element is mutually exclusive with the PSR order information metaSolvPSROrderValue.
Table 7-41 metaSolvISROrderValue Definition
element
MetaSolvISROrderValue
complexType
Extension of OrderValueISROrderHeaderType
ISROrderHeaderType
complexType
complexType with a list of fields,
contact, notes, locations, serviceValue, remarks, userData
Contact
element
ISRContactType
ISRContactType
complexType
notes
element
ISRNoteValueType
ISRNoteValueType
complexType
locations
element
ISRLocation
ISRLocation
complexType
locationValueA, locationValueB
locationValueA
element
locationValueB
element
complexType
MetaSolvLocationKey
serviceValue
element
ISRServiceValueType
ISRServiceValueType
complexType
remarks
element
ISRRemarkType
ISRRemarkType
complexType
userData
element
UserDataValueType
UserDataValueType
complexType
Table 7-42 describes the required fields for MetaSolvServiceValue.
Table 7-42 Required Fields for MetaSolvServiceValue
externalServiceKey
string
External service key value from the external system.
activityCd
Enum
Valid values of ActivityCodeEnumType. Activity to be performed on this item. Pass the value based on the scenario.
productGroup
integer
The name of the product grouping. This field should be zero if a value is not applicable.
Table 7-43 describes the required fields for serviceKey and parentServiceKey.
Table 7-43 Required Fields for serviceKey and parentServiceKey
servicePrimaryKey
string
Field is required only for change orders and is populated using service item ID. For new orders, this value is 0.
Table 7-44 describes the required fields for parentSpecKey and describingSpecificationKey.
Table 7-44 Required Fields for parentSpecKey and describingSpecificationKey
serviceSpecificationPrimaryKey
string
Field is populated using the product catalog ID which is added under the service structure.
Table 7-45 describes the required fields for serviceLocationKey.
Table 7-45 Required Fields for serviceLocationKey
locationPrimaryKey
string
Value of the location ID where the product is assigned. This is populated for products which are under Service Location and is 0 for Global products.
Table 7-46 describes the required fields for ipNumberInventoryKey and addressKey.
Table 7-46 Required Fields for ipNumberInventoryKey and addressKey
resourcePrimaryKey
string
Value of the address ID where the product is assigned. This is populated for products which are under Service Location and is 0 for Global products.
Table 7-47 describes the required values for serviceItemValues.
Table 7-47 Required Values for serviceItemValues
label
string
Name or purpose of additional information that you want to capture for a service item.
Value
string
Specific value for a given value label. Values can be lists of predefined choices, or text-entry fields.
valueCd
string
Code used to identify a value, such as a shortened version of the value's “name" or a number.
activityCd
Enum
assignedTelephoneNr
Table 7-48 defines assignedTelephoneNr information.
This tag applies for PSR orders which has products that require Telephone Numbers to be assigned.
Table 7-48 assignedTelephoneNr Definition
assignedTelNr
element
AssignedTelNrType
AssignedTelNrType
complexType
Set of simple data types:
  • CnamType
  • LidbType
  • StructureFormatType
CnamType
element
psrCnam
psrCnam
element
PsrCnamType
PsrCnamType
complexType
LidbType
element
psrLidbType
psrLidbType
element
PsrLidbType
PsrLidbType
complexType
StructureFormatType
complexType
structureFormatComponents
element
StructureFormatComponentType
complexType
assignedTelNrRel
element
AssignedTelNrRelType
complexType
  • AssignedTelNrType
  • MetaSolvServiceKey
AssignedTelNrType
complexType
MetaSolvServiceKey
element
MetaSolvServiceKey
ServiceEntities.xsd
MetaSolvServiceKey
complexType
servicePrimaryKey
ServiceEntities.xsd
Table 7-49 describes the required fields for MetaSolvServiceKey.
Table 7-49 Required Fields for MetaSolvServiceKey
servicePrimaryKey
string
Field is required only for change orders and is populated using service item ID and for new orders, this is 0.
Table 7-50 describes the required fields for assignedTelephoneNr.
Table 7-50 Required Fields for assignedTelephoneNr
relationshipType
Enum
Relationship between two telephone numbers. Valid values are rtRCF, rtPorted, rtPortedTo, rtTollfree and rtNone.
Table 7-51 describes the required fields for AssignedTelNrType.
Table 7-51 Required Fields for AssignedTelNrType
telNrSuf
string
System tracks a number's history by assigning a suffix counter to each number. Each time the number is recalled into an Unassigned status, the counter increases by one.
respOrg
string
Organization that owns the NPA NXX.
telNrTypeCd
Enum
Telephone number type code and valid values are Valid values are
tntINPOUT, tntRESALE, tntNPIN, tntTFWTN, tntTF, tntFORWTN,
tntNPOUT, tntWTN, tntNone.
activityCd
Enum
identityCd
Enum
Identify whether the telephone number as main telephone number or alternate. Valid values are: MPTN, ALT and NONE.
locationId
Long
The location ID of the telephone number and if not mapped, it should be 0.
btnInd
Boolean
Default is false and should be changed to true if the TN needs to set as billing telephone number.
Table 7-52 describes the required fields for PsrCnamType.
Table 7-52 Required Fields for PsrCnamType
callingName
string
The name of the business or residential customer, as desired for the caller ID display.
presentationInd
Enum
Valid values of PresentationIndEnumType. Indicates that caller ID name information is sent for calls made from this number.
activityCode
Enum
manualIndicator
Enum
Valid values of IndicatorEnumType. Indicates that you do not want to send the CNAM information electronically to the gateway vendor.
If you do not send the information electronically, you must send it manually.
effectiveDateChg
CbeDateTime
Indicates a future date for any change to be effective, if it is not effective immediately.
Table 7-53 describes the required fields for PsrLidbType.
Table 7-53 Required Fields for PsrLidbType
bnsCode
Enum
Valid values of BNSCodeEnumType. The Billed Number Screening Code is a code to indicate the type of screening, if any, applied to this number.
marketInd
Enum
Valid values of MarketIndicatorEnumType. Indicates the type of market this number is assigned to.
serviceClassCode
Enum
Valid values of ClassCodeEnumType. A code that describes how a service is used by a business, residential, or pay phone customer. Examples include business, residential, public coin, public non-coin, and semi-public coin.
manualIndicator
Enum
Valid values of IndicatorEnumType. Indicates that you do not want to send the LIDB information electronically to the gateway vendor.
activityCd
Enum
effectiveDateChg
CbeDateTime
Table 7-54 describes the required fields for StructureFormatType.
Table 7-54 Required Fields for StructureFormatType
sfType
string
Category that describes a structure.
name
string
Name of a specific customizing of a structured format type.
Table 7-55 describes the required fields for StructureFormatComponentType.
Table 7-55 Required Fields for StructureFormatComponentType
Id
int
ID of a component of a structured format.
name
string
Name of a component of a structured format.
componentType
string
Type of component, such as table-driven drop-down or valid value drop-down.
Value
string
Name of a value for a component.
Table 7-56 describes Access.
Table 7-56 Access Definition
Access
element
AccessType
ServiceEntities.xsd
AccessType
complexType
AccessInformationType
complexType
Table 7-57 describes the required fields for AccessInformationType.
Table 7-57 Required Fields for AccessInformationType
Floor
string
The floor where the product is installed.
Room
string
The room where the product is installed.
jackCd
string
A standard code for the registered or non-registered jack used to terminate service at the service location.
jackNr
string
If the jack is existing, the number associated with the jack.
jackPosition
integer
The position of the circuit within the jack.
jackStatus
string
Indicates whether the jack used to terminate service is new or existing.
accessInfo
string
Special instructions regarding access to the service location and times that access is available.
additionalLocationDetails
string
Specific details not included in the Additional Information field.
locationIdSpot
integer
The CLLI code for the physical point of termination at the end user location.
activityCd
Enum
Table 7-58 describes isdnTrunkGroup.
Table 7-58 isdnTrunkGroup Definition
isdnTrunkGroup
element
IsdnTrunkGroupType
ServiceEntities.xsd
IsdnTrunkGroupType
complexType
isdnTrunkGroupInformation
complexType
IsdnTrunkGroupInformationType
complexType
Table 7-59 describes the required fields for IsdnTrunkGroupInformationType.
Table 7-59 Required Fields for IsdnTrunkGroupInformationType
bchanFunctionCd
Enum
Valid values of BchanFuncEnumType. Identifies the purpose of the bearer channels.
nfasBkupDchanInd
Enum
Valid values of IndicatorWNAEnumType. Indicates if a backup D-Channel is used on a subsequent DS1 in a multiple DS1 trunk group.
premierCallInd
Enum
Valid values of IndicatorEnumType. Identifies whether the premier calling features are available.
nfasInd
Enum
Valid values of IndicatorEnumType. Indicates whether the DS1 circuits in the ISDN trunk group shares the same D channel for signaling. When NFAS is not used, each DS1 uses its own D channel.
dialableGroup
Enum
Valid values of DialableGroupEnumType. The grouping method for the DS0 time slot (channel).
dialableSearch
Enum
Valid values of DialableSrchEnumType.
Table 7-60 defines trunkGroup.
Table 7-60 trunkGroup Definition
trunkGroup
element
TrunkGroupType
ServiceEntities.xsd
TrunkGroupType
complexType
complexType
complexType
  • intoCO
  • outFromCO
intoCO
element
IntoCOType
outFromCO
element
OutFromCOType
Table 7-61 describes the required fields TrunkGroupInformationType.
Table 7-61 Required Fields for TrunkGroupInformationType
coDirection
string
Describes the direction of the signals traveling along this trunk.
interfaceType
string
Indicates whether the interface for the trunk group is digital or analog.
glareAction
string
Indicates who has control of the trunks when both ends are seized at the same time for different uses or by different users.
ncCd
string
Network Channel code - A code that identifies the type of service provided by the trunk.
ncCdOption
string
Two optional characters further identify the performance specifications and transmission options of the trunk.
nciCd
string
Network Channel Interface code - A code that identifies the electrical conditions of the trunk at the customer location.
twoSixCd
string
A code that identifies the trunk group. The code consists of a two-character company code, followed by the six-digit serial number of the trunk.
framing
string
The type of frame pattern used for DS1 service.
lineCoding
string
The type of pulse code modulation (PCM) pattern used for DS1 service.
trunkSegment
string
Suffix added to a trunk to make it unique. This suffix is created by a local telephone trunk service.
selectionSequence
string
The method of selecting idle trunks in a trunk group during call processing. This field is required for all types of special trunk groups.
Table 7-62 describes the required fields for IntoCOType.
Table 7-62 Required Fields for IntoCOType
digitsQty
integer
The number of digits that are to be received by the central office switch from the customer for a Direct Outward-Dial (DOD) trunk.
maxDigit
string
The maximum number of digits that can be sent from a PBX, terminal equipment, or similar device to the central office switch.
minDigit
string
The minimum number of digits that can be sent from a PBX, terminal equipment, or similar device to the central office switch.
pulseType
string
The pulsing method used to send digits from a customer to a central office switch.
startSignal
string
The timing or method used to start signaling from the customer to the central office switch.
supervisionSignal
string
The type of signaling sent from a PBX, terminal equipment, or similar device to a central office switch.
Table 7-63 describes the required fields for OutFromCOType.
Table 7-63 Required Fields for OutFromCOType
digitsQty
integer
The number of digits sent from the central office switch to the customer for a Direct In-Dial (DID) trunk.
outgoingDigitsDelete
string
The actual digits that are inserted before the Digits Outpulsed and sent from the central office switch to the PBX, terminal equipment, or similar device.
outgoingDigitsPrefix
string
The quantity of digits that are extracted from the Digits Outpulsed before they are sent from the central office switch to the PBX, terminal equipment, or similar device.
pulseType
string
The pulsing method used to send digits from a central office switch to a customer.
startSignal
string
supervisionSignal
string
Table 7-64 defines Circuit.
Table 7-64 Circuit Definition
circuit
element
CircuitType
ServiceEntities.xsd
CircuitType
complexType
circuitInformation
circuitInformation
complexType
CircuitInformationType
complexType
Table 7-65 describes the required fields for CircuitInformationType.
Table 7-65 Required Fields for CircuitInformationType
rateCd
string
Identifies the transmission rate of the requested circuit (measured in bits per second).
aPot
string
The CLLI associated with the additional termination point of the circuit, if applicable.
framing
string
framingAnsiInd
Enum
Valid values of IndicatorWNAEnumType. Only applicable if framing is used.
lineCoding
string
ownedLeasedCd
Enum
Valid values of CktServiceTypeEnumType. Description of the service provided, broken down into Special Services (for IntraLATA/Boundary and LATA/Boundary Access), Switched Services, and Facility Services.
serviceTypeExt
string
Service a circuit provides. The extension further defines a service type code.
serviceTypeCd
string
Service type code.
ncCd
string
Identifies performance and other technical specifications for the circuit.
ncCdOption
string
Jurisdiction
string
Jurisdiction classification, which categorizes the circuit (for its originating/terminating end) for toll separation purposes.
Table 7-66 defines circuitLocation.
Table 7-66 circuitLocation Definition
Name Defined As Field Description File Name
circuitLocation
element
CircuitLocationType
ServiceEntities.xsd
CircuitLocationType
complexType
circuitLocationInformation
complexType
CircuitLocationInformationType
complexType
  • primaryLocation
  • secondaryLocation
primaryLocation
element
LocationType
secondaryLocation
element
LocationType
LocationType
complexType
CodedLocationType,
EndUserLocationType
CodedLocationType
complexType
locationKey
locationKey
element
MetaSolvLocationKey
EndUserLocationType
complexType
  • locationKey
  • jackInformation
jackInformation
element
JackInformationType
JackInformationType
complexType
Table 7-67 describes the required fields for CodedLocationType.
Table 7-67 Required Fields for CodedLocationType
serviceLocationRef
integer
Relates to the Service Location field that appears for End User locations.
clliCd
string
Only applicable for network locations. The network location for the circuit connection. This field is only applicable to network locations and is only required when the CodedLocationType is populated.
nciCd
string
Network Channel Interface code that identifies the interface specifications associated with a circuit.
cfa
string
Connecting Facility Assignment field. If applicable, the circuit on another provider's network where the ordered circuit is connected and the channel that it is assigned.
activityCd
Enum
supervisionSignal
string
Type of signaling sent from a PBX, terminal equipment, or similar device to a central office switch.
Table 7-68 describes the required fields for EndUserLocationType.
Table 7-68 Required Fields for EndUserLocationType
serviceLocationRef
integer
endUserClli
Enum
Valid values of MomLocationTypeEnumType. The network location for the circuit connection.
nciCd
string
cfa
string
backboardSpace
Enum
Valid values of IndicatorWNAEnumType. This field is only required if the parent tag is populated. This field is applicable for private line (including LAN) connections. Indicates whether backboard space for equipment installation is available, not available, or not applicable at this location.
offNetType
Enum
Valid values of NniUniCDEnumType. This field is only required if the parent tag is populated. This field is applicable for frame relay orders when the On Net Location box is not checked.
equipSpace
Enum
Valid values of IndicatorWNAEnumType. Indicates whether equipment space is available, not available, or not applicable at this location.
seperatlyFused
Enum
Valid values of IndicatorEnumType. Indicates whether the power available to this location is separately fused.
buildingGround
Enum
Valid values of IndicatorEnumType. Indicates whether a building ground is available at this location.
powerAvail
Enum
Valid values of IndicatorEnumType. Indicates whether power is available at this location.
localLoop
Enum
Valid values of IndicatorEnumType. Indicates whether you need to order a local loop connection to this location.
Muxing
Enum
Valid values of IndicatorEnumType. Indicates whether the customer requests multiplexing (muxing).
onNetLoc
Enum
Valid values of IndicatorEnumType. Indicates whether your company currently serves this location.
powerType
Enum
Valid values of PowerTypeEnumType. A description of the type of power available at this location.
activityCd
Enum
Table 7-69 describes the required fields for JackInformationType.
Table 7-69 Required Fields for JackInformationType
jackCd
string
Standard code for the registered or non-registered jack used to terminate service at the service location.
jackPosition
integer
Position of the circuit within the jack.
jackNr
string
jackStatus
Enum
Valid values of JackStatusEnumType. Indicates whether the jack used to terminate service is new or existing.
activityCd
Enum
Table 7-70 defines Connector.
Table 7-70 Connector Definition
connector
element
ConnectorType
ServiceEntities.xsd
ConnectorType
complexType
connectorInformation
complexType
ConnectorInformationType
complexType
  • serviceLocationKeyA
  • serviceLocationKeyB
serviceLocationKeyA
element
MetaSolvLocationKey
serviceLocationKeyB
element
MetaSolvLocationKey
Table 7-71 describes the required fields for ConnectorInformationType.
Table 7-71 Required Fields for ConnectorInformationType
compTypeConId
integer
Type of connection on an order.
rateCd
string
Framing
string
Type of frame pattern used for DS1 service.
lineCoding
string
Type of pulse code modulation (PCM) pattern used for DS1 service.
Jurisdiction
string
serviceLocationRefA
integer
Primary location for the circuit termination for A.
addressKeyA
integer
Address key A value.
serviceLocationRefB
integer
Primary location for the circuit termination for B.
addressKeyB
integer
Address key B value.
Table 7-72 defines caUsageInstance.
Table 7-72 caUsageInstance Definition
caUsageInstance
element
CaUsageInstanceType
ServiceEntities.xsd
CaUsageInstanceType
complexType
caUsageValue
caUsageValue
element
CaUsageValueType
CaUsageValueType
complexType
Table 7-73 describes the required fields for CaUsageInstanceType.
Table 7-73 Required Fields for CaUsageInstanceType
caUsageKey
integer
Unique ID of custom attribute.
caValueLabel
string
Label of custom attribute.
Table 7-74 describes the required fields for CaUsageValueType.
Table 7-74 Required Fields for CaUsageValueType
caValueKey
integer
Key of valid value custom attribute.
caValue
string
Value of custom attribute.
caUom
string
Unit of measure. For example, meters, yards, or feet.
caUsageVvKey
integer
Table 7-75 defines picInfo.
Table 7-75 picInfo Definition
picInfo
element
PicInfoType
ServiceEntities.xsd
PicInfoType
complexType
Table 7-76 describes the required fields for PicInfoType.
Table 7-76 Required Fields for PicInfoType
Pic
string
A Primary Interexchange (or IntraLata) Carrier code or Carrier identification code (CIC) that represents an end user's toll provider.
picTypeCd
string
Toll calling area of a PIC, including intraLATA/Boundary, interLATA/Boundary, and international.
freezePic
Enum
Valid values of IndicatorType. Indicates the customer requested the freeze option on the PIC. The end user is specifying that the PIC can only be changed when authorized by the end user.
partyName
string
Name for the given primary interexchange code. This field is information only not used in business logic for create or update transactions.
activityCd
Enum
Table 7-77 defines orderItemPrice.
Table 7-77 orderItemPrice Definition
orderItemPrice
element
PSROrderItemPriceType
ServiceEntities.xsd
complexType
psrOrderItemPrice
psrOrderItemPrice
complexType
MomPsrOrderItemPriceType
complexType
Table 7-78 describes the required fields for MomPsrOrderItemPriceType.
Table 7-78 Required Fields for MomPsrOrderItemPriceType
priceID
integer
ID for the price.
basePriceSeq
string
Base price sequence.
priceVarSeq
string
Price variation sequence.
priceOverride
Float
Indicator on whether to override the price.
activityCD
Enum
Table 7-79 defines EmailInfo.
Table 7-79 EmailInfo Definition
EmailInfo
element
EmailInfoType
ServiceEntities.xsd
EmailInfoType
complexType
internetEmailInformation
complexType
InternetEmailInformationType
complexType
Table 7-80 describes the required fields for InternetEmailInformationType.
Table 7-80 Required Fields for InternetEmailInformationType
emailName
string
Email that is used by the customer.
Domain
string
Domain name.
domainSuffix
string
Suffix for the domain name.
Table 7-81 defines DialupInfo.
Table 7-81 DialupInfo Definition
DialupInfo
element
DialupInfoType
ServiceEntities.xsd
DialupInfoType
complexType
internetDialupInformation
complexType
InternetDialupInformationType
complexType
Table 7-82 describes the required fields for InternetDialupInformationType.
Table 7-82 Required Fields for InternetDialupInformationType
url
string
URL for the dial up.
Domain
string
Domain name.
domainSuffix
string
userId
string
User ID for the dial up.
accessTnNbrInvId
integer
Associated Number inventory ID.
Table 7-83 defines TemplateInfo.
Table 7-83 TemplateInfo Definition
TemplateInfo
element
TemplateInfoType
ServiceEntities.xsd
TemplateInfoType
complexType
templateInformation
templateInformation
complexType
TemplateInformationType
complexType
Table 7-84 describes the required fields for TemplateInformationType.
Table 7-84 Required Fields for TemplateInformationType
Field Name Data Type Field Decription
configTypeId
integer
Config type ID.
shortName
string
Short name that is going to be defined for the template product.
longName
string
Long name that is going to be defined for the template product.
providerId
string
Provider ID of the template.
customerId
string
Customer ID that is assigned to this template.
Table 7-85 defines ElementInfo.
Table 7-85 ElementInfo Definition
ElementInfo
element
ElementInfoType
ServiceEntities.xsd
ElementInfoType
complexType
elementInformation
elementInformation
complexType
ElementInformationType
complexType
Table 7-86 describes the required fields for ElementInformationType.
Table 7-86 Required Fields for ElementInformationType
configTypeId
integer
Config type ID.
elementType
string
Type of element that is used.
elementNbr
integer
Element number.
elementNm
string
Element name that is used.
networkElementId
string
Network element ID that is assigned.
locationId
string
Location ID that is assigned.
addressId
string
Address ID that is assigned.
Table 7-87 defines EquipmentInfo.
Table 7-87 EquipmentInfo Definition
EquipmentInfo
element
EquipmentInfoType
ServiceEntities.xsd
EquipmentInfoType
complexType
equipmentInformation
complexType
EquipmentInformationType
complexType
Table 7-88 describes the required fields for EquipmentInformationType.
Table 7-88 Required Fields for EquipmentInformationType
equipmentSpecId
integer
Equipment specification ID that is assigned to this order.
equipmentId
integer
Equipment id that is assigned to this order.
Table 7-89 defines PSRDirServ.
Table 7-89 PSRDirServ Definition
PSRDirServ
element
PSRDirServType
ServiceEntities.xsd
PSRDirServType
complexType
directoryServiceRequest
complexType
directoryServiceType
complexType
  • BANUsageOne
  • BANUsageTwo
  • ACNAInfo
BANUsageOne
element
PSRBillingAccountNumberUsageType
BANUsageTwo
element
complexType
ACNAInfo
element
PSRDirServReqACNAType
complexType
Table 7-90 describes the required fields for directoryServiceType.
Table 7-90 Required Fields for directoryServiceType
serviceCenter1
string
Service center 1 details.
serviceCenter2
string
Service center 2 details.
accountNumber
string
Identifies the main account number assigned by the NSP.
accountTelNbr
string
Identifies the account telephone number assigned by the NSP.
TOSTYPE
Enum
Valid values of TypeOfServiceEnumType. Type of Service identifies the type of service or the line ordered. Byte 1 of 4-byte field.
TOSPROD
Enum
Valid values of TypeOfServiceProdEnumType. Type of Service identifies the type of service for the line ordered. Byte 2 of 4-byte field.
TOSCLASS
Enum
Valid values of TypeOfServiceClassEnumType. Type of Service identifies the type of service or the line ordered. Byte 3 of 4-byte field.
TOSCHAR
Enum
Valid values of TypeOfServiceClassEnumType. Type of Service identifies the type of service or the line ordered. Byte 4 of 4-byte field.
Table 7-91 describes the required fields for PSRBillingAccountNumberUsageType.
Table 7-91 Required Fields for PSRBillingAccountNumberUsageType
billingAcctNbr
string
Identifies the billing account number for the recurring and non-recurring charges for this request.
banSvcCat
Enum
Valid values of BanServiceTypeEnumType. Identifies the type of billing account number.
Table 7-92 describes the required fields for PSRDirServReqACNAType.
Table 7-92 Required Fields for PSRDirServReqACNAType
Acna
string
ACNA value.
partyPrimaryName
string
Primary name of the party.
partySecondaryName
string
Secondary name of the party.
Table 7-93 defines PSRDirListing.
Table 7-93 PSRDirListing Definition
PSRDirListing
element
PSRDirListingType
ServiceEntities.xsd
PSRDirListingType
complexType
directoryListing
directoryListing
complexType
directoryListingType
complexType
  • address
  • telNbr
  • delivery
  • addlInfo
  • text
Address
element
PSRDirectoryListingAddress
complexType
telNbr
element
PSRDirectoryListingTelephoneNumber
complexType
delivery
element
PSRDirectoryListingDeliveryLocation
complexType
PSRDirectoryListingDirectoryTypeSegments
addlInfo
element
PSRDirectoryListingAdditionalInformation
complexType
Text
element
PSRDirectoryListingLinesOfText
complexType
complexType
Table 7-94 describes the required fields for directoryListingType
Table 7-94 Required Fields for directoryListingType
ALICd
string
Uniquely identifies each listing for an account number.
listingType
Enum
Valid values of listingType. For DSR, identifies the type of listing being submitted for the publication and directory assistance (DA) appearance rules.
listAcctType
Enum
Valid values of TypeOfAccountEnum. Identifies the type of account for this listing and determines the placement of the listing in split directories and directory assistance.
styleCd
Enum
Valid values of StyleCodeEnum. Identifies if the listing is a straight line, caption header.
Yphdgcd
string
Identifies the heading under which a business listing should appear in the Yellow Pages Directory.
Yphdgverbiage
string
Identifies the heading under which a business listing should appear in the Yellow Pages.
placeListingAs
string
When a customer wishes to override the normal sequencing, the special filing words that are used rather than using the listed name.
dirName
string
Identifies the name of the directory in which the listing is to be placed.
listedNmAddrAddl
string
This is a twelve-character alphaNumeric field.
listedNmLineageDual
Enum
Valid values of LineageNameEnum.
listedNmAddrDual
Enum
Valid values of AddressNameEnum.
Table 7-95 describes the required fields for PSRDirectoryListingAddress.
Table 7-95 Required Fields for PSRDirectoryListingAddress
listedNmLineage
Enum
listedNmLast
string
Last name for the listing.
listedNmFirst
string
First name for the listing.
houseNbrPref
string
Identifies the prefix for the house number.
houseNbr
string
The number of the street address, not including extensions such as 1/2, A, D.
streetNm
string
Name of the road of the address.
City
string
Community of the street name/house number as designated by the Master Street Address Guide, MSAG.
stateCd
string
A two-character abbreviation for the State associated with the address.
zipCode
string
Zip code of the address.
omitAddr
Enum
Valid values of CheckBoxOptionEnum.
omitTelNbr
Enum
Table 7-96 describes the required fields for PSRDirectoryListingTelephoneNumber.
Table 7-96 Required Fields for PSRDirectoryListingTelephoneNumber
Listingtelnbr
string
Indicates the telephone number to be placed in the directory and quoted in Directory Assistance (DA) as appropriate based on LTY, RTY, and STYC field entries.
mainTelNbr
string
Field identifies the main telephone number used to link the main listing with any other associated listings.
Telnbrnpa
string
Area code (NPA) portion of the telephone number. The first three digits of a ten-digit phone number.
Telnbrnxx
string
Central Office, or Exchange, portion of the phone number. The first three digits of a seven-digit telephone number, and the fourth through sixth digits of a ten-digit phone number.
Telnbrlinerange
string
Line number of the telephone. This is the last four digits a ten-digit telephone number, and the last four digits of a seven-digit number.
Telnbrsuf
string
Suffix or PIN used to differentiate between two otherwise identical telephone numbers.
Table 7-97 describes the required fields for PSRDirectoryListingDeliveryLocation.
Table 7-97 Required Fields for PSRDirectoryListingDeliveryLocation
dirDirectoryDeliveryId
integer
Oracle sequence uniquely identifies the delivery location information.
delRefNbr
string
Identifies the delivery address/information segment and each additional delivery address/information segment with a unique number.
delAddressType
Enum
Valid values of deliveryAddTypeEnum. Identifies a delivery address segment as being valid for hand delivery, postal delivery or both. (Represents the DATY field on the DL Form.).
endUserName
string
Recipient name for the delivery address.
houseNbrPref
string
houseNbr
string
Number of the street address, not including extensions such as 1/2, A, D.
streetnm
string
City
string
stateCd
string
Two-character abbreviation for the State associated with the address.
zipCd
string
Table 7-98 describes the required fields for PSRDirectoryListingAdditionalInformation.
Table 7-98 Required Fields for PSRDirectoryListingAdditionalInformation
ttyttdCd
Enum
Valid values of TTYTDDEnum. Identifies that this listing should include a special TTY or TDD phrase and which phrase should be included.
localNpaNxx
string
The telephone number being listed is not local to the service address and this column indicates the provider's local NPA NXX. Examples of when this might be used include foreign exchange numbers and ported numbers.
noSoliciationCd
Enum
listedNmPlacement
Enum
omitStAddr
Enum
Valid values of CheckBoxOptionEnum. Identifies if this listing is to be omitted from the street address (reverse) directory.
omitDirectMail
Enum
Valid values of CheckBoxOptionEnum. Indicates whether this listing is to be omitted from any direct mail lists.
omitTeleMktg
Enum
Valid values of CheckBoxOptionEnum. Indicates that this listing is to be omitted from any telemarketing lists.
placementOverrideCd
Enum
Valid values of OverrideCodeEnum. Identifies an override of the normal placement of business or residence listings.
profList
Enum
Valid values of CheckBoxOptionEnum. Indicates that this is a professional listing.
doNotAbbrev
Enum
Valid values of doNotAbbrevEnum. Identifies that data in specific fields must not be abbreviated.
existingAdvert
Enum
Valid values of ExistingAdvertisingEnum. Identifies the end user's directory advertising status.
Table 7-99 describes the required fields for PSRDirectoryListingDirectoryTypeSegments.
Table 7-99 Required Fields for PSRDirectoryListingDirectoryTypeSegments
dirTypeCd
Enum
Valid values of DirectoryTypeEnum. Identifies the type of directory to be delivered.
dirAnnualQty
integer
Identifies the number of directories to be delivered on an annual basis.
dirNCQty
integer
Identifies the number of directories to be delivered at the time of new connection.
dirDelCd
integer
Identifies the directory code of the book to be delivered.
dirName
string
Table 7-100 defines AuthCDUsage.
Table 7-100 AuthCDUsage Definition
AuthCDUsage
element
AuthCDUsageType
ServiceEntities.xsd
AuthCDUsageType
complexType
authCodeUsage
authCodeUsage
complexType
AuthCodeUsageType
AuthCodeUsageType
complexType
Table 7-101 describes the required fields for AuthCodeUsageType.
Table 7-101 Required Fields for AuthCodeUsageType
authTypeCD
string
User recognizable code for the auth type being defined.
authCD
string
Actual code assigned to the service item.
Translation
string
For a verified auth code, you must enter a verbal translation which is the response to the telephone user after the user enters the verified auth code correctly.
authCDName
string
Describes who is using an auth code. This name can be used on the bill format.
fromEffectiveDateTime
CbeDateTime
The date the entity became effective.
toEffectiveDateTime
CbeDateTime
Date product became inactive. This field must be non-null. It may have a zero date value.
activityCD
Enum
Valid values of ActivityCodeEnumType. An enumerated type describing the activity for this item. Set this type to indicate how the operation processes this structure.
Table 7-102 defines huntGroup.
Table 7-102 huntGroup Definition
huntGroup
element
HuntGroupType
ServiceEntities.xsd
HuntGroupType
complexType
huntGroupToFrom
huntGroupToFrom
element
HuntToFromType
HuntToFromType
complexType
huntToServItemKey,
huntFromServItemKey
huntToServItemKey
element
MetaSolvServiceKey
huntFromServItemKey
element
MetaSolvServiceKey
Table 7-103 describes the required fields for HuntGroupType.
Table 7-103 Required Fields for HuntGroupType
huntKey
integer
Unique Key that identifies a hunt group in the database.
huntType
string
Hunt Type of hunting requested.
huntName
string
Hunt Group Name
huntNumber
string
Number of members in the hunt group.
activityCd
Enum
Table 7-104 describes the required fields for HuntToFromType.
Table 7-104 Required Fields for HuntToFromType
activityCd
Enum
Table 7-105 defines lineDirectoryType.
Table 7-105 lineDirectoryType Definition
lineDirectoryType
complexType
  • address
  • telNbr
  • addlInfo
  • text
Address
element
complexType
telNbr
element
complexType
delivery
element
complexType
addlInfo
element
complexType
Text
element
complexType
complexType
Table 7-106 describes the required fields for lineDirectoryType.
Table 7-106 Required Fields for lineDirectoryType
rcdType
Enum
Valid values of RecordTypeEnum
rcdTypeArea
Enum
Valid values of RecordTypeAreaEnum
referenceNumber
string
A number that uniquely identifies a delivery location.
listingType
Enum
Valid values of ListingTypeEnum. For DSR, identifies the type of listing being submitted for the publication and directory assistance (DA) appearance rules.
styleCd
Enum
listAcctType
Enum
degreeofIdent
Long
Identifies the degree of indention for this listing.
listedNmLineageDual
Enum
listedNmAddrDual
Enum
ALICd
string
Yphdgcd
string
Yphdgverbiage
string
sicCode
string
Industry code to identify yellow page heading.
The createOrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-107 describes the returned information in the response.
Table 7-107 Payload Information for the Response
element
OrderAPI.wsdl
element
mommekey
mommekey
element
complexType
metaSolvOrderKey
createPSROrderRequest Operation
This operation creates a new PSR order in the system and returns the key for the new order created. A single OrderValue is the only value passed into the request. The state values in OrderValue are ignored; the state is initialized to STARTED by the system.
Request Structure: createPSROrderRequest
Response Structure: createPSROrderRequestResponse
The createPSROrderRequest element contains the input information for the operation. Each row in Table 7-108 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-108 Payload Information for the Request
element
OrderAPI.wsdl
element
Mommevalue
Mommevalue
element
complexType
Contains a choice of types:
complexType
The createPSROrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-109 describes the returned information in the response.
Table 7-109 Payload Information for the Response
element
OrderAPI.wsdl
element
mommekey
mommekey
element
complexType
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
Table 7-110 describes the error messages for the operation.
Table 7-110 Error Messages for the Operation
Miscellaneous Error: Telephone Number already exists in inventory and has status of statusValue.
The telephone number you specified already exists in the database.
Provide a new telephone number.
Telephone Number already exists in inventory with a different telephone number type.
The telephone number type you specified does not match the type in the database or the telephone number already exists.
Retrieve the type for the telephone number and provide the matching type or provide a new telephone number.
Unable to copy item valueForItem to the order as the Service Item is on another open PSR Order. The Preference to Copy Pending PSR Items is set to No.
You requested a copy of a service item that is on an open PSR.
Remove the request to copy the item or change the preference for the Copy Pending PSR Items to Yes.
getCnamData Operation
This operation retrieves the Calling Name (CNAM) records. This operation provides the extract sequence for updating the Calling Name information.
Request Structure: getCnamData
Response Structure: getCnamDataResponse
getCnamData
The getCnamData element contains the input information for the operation. Each row in Table 7-111 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-111 Payload Information for the Request
getCnamData
element
getCNAMDataRequest
OrderAPI.wsdl
getCnamDataResponse
The getCnamDataResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-112 describes the returned information in the response.
Table 7-112 Payload Information for the Response
Name Defined As Type Descriptions File Name
getCnamDataResponse
element
momGetCNAMDataResponse
OrderAPI.wsdl
element
CNAMDataValue
OrderManagementAPI.xsd
CNAMDataValue
element
CNAMDataType
CNAMDataType
complexType
CNAMRecords
OrderManagementEntities.xsd
CNAMRecords
element
CNAMRecordType
CNAMRecordType
complexType
OrderAncillaryManagementData.xsd
getE911Data Operation
This operation retrieves the E911 records. This operation provides the extract sequence for updating the E911 information.
The following are the request and response structures:
Request Structure: getE911Data
Response Structure: getE911DataResponse
getE911Data
The getE911Data element contains the input information for the operation. Each row in Table 7-113 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-113 Payload Information for the Request
Name Defined As Type Description File Name
getE911Data
element
getE911DataRequest
OrderAPI.wsdl
getE911DataResponse
The getE911DataResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-114 describes the returned information in the response.
Table 7-114 Payload Information for the Response
getE911DataResponse
element
momGetE911DataResponse
OrderAPI.wsdl
element
e911DataValue
e911DataValue
element
E911DataType
E911DataType
complexType
e911Records
e911Records
element
E911RecordType
E911RecordType
complexType
getLidbData Operation
This operation retrieves the Line Database (LIDB) records. This operation provides the extract sequence used for updating the Line Database details.
Request Structure: getLidbData
Response Structure: getLidbDataResponse
getLidbData
The getLidbData element contains the input information for the operation. Each row in Table 7-115 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-115 Payload Information for the Request
getLidbData
element
getLIDBDataRequest
OrderAPI.wsdl
getLidbDataResponse
The getLidbDataResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-116 describes the returned information in the response.
Table 7-116 Payload Information for the Response
getLidbDataResponse
element
momGetLIDBDataResponse
OrderAPI.wsdl
element
LIDBDataValue
LIDBDataValue
element
LIDBDataType
LIDBDataType
complexType
LIDBRecords
LIDBRecords
element
LIDBRecordType
LIDBRecordType
complexType
Contains a list of fields
getOrderByKey Operation
This operation retrieves the order details given an input order number (document number of the order). The output consists of order header, user data, and services information.
Request Structure: getOrderByKey
Response Structure: getOrderByKeyResponse
getOrderByKey
The getOrderByKey element contains the input information for the operation. Each row in Table 7-117 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-117 Payload Information for the Request
getOrderByKey
element
momGetOrderByKeyRequest
OrderAPI.wsdl
element
mommekey
Mommekey
element
complexType
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
primaryKey
Table 7-118 describes the required fields for getOrderByKey.
Table 7-118 Required Fields for getOrderByKey
Field Name Data Type Field Description
PrimaryKey
string
Document number of the order where the details are required.
The getOrderByKeyResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-119 describes the returned information in the response.
Table 7-119 Payload Information for the Response
element
momGetOrderByKeyResponse
OrderAPI.wsdl
element
Mommevalue
mommevalue
element
complexType
complexType
complexType
getPSROrderByTN Operation
This operation retrieves the PSR order details given the input telephone number and TN format. The output includes the order header, user data and service details.
Request Structure: getPSROrderByTN
getPSROrderByTN
The getPSROrderByTN element contains the input information for the operation. Each row in Table 7-120 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-120 Payload Information for the Request
getPSROrderByTN
element
getPSROrderByTNRequest
OrderAPI.wsdl
element
GetPSROrderByTNRequestValue
element
GetPSROrderByTNRequestValueType
complexType
OrderManagementData.xsd
Table 7-121 describes the required fields for getPSROrderByTN.
Table 7-121 Required Fields for getPSROrderByTN
TelephoneNbr
string
Element is used to pass the telephone number and the details are required.
TelephoneNbrFormat
string
Element is used to specify the format of the telephone number. For example in case of US format i.e NPA-NXX-LINE the format is 'xxx-xxx-xxxx'.
getPSROrderByTNResponse
The getPSROrderByTNResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-122 describes the returned information in the response.
Table 7-122 Payload Information for the Response
element
momGetPSROrderByTNResponse
OrderAPI.wsdl
element
mommevalue
mommevalue
element
complexType
complexType
complexType
processSuppOrderRequest Operation
This operation requests a supplement to the order. It takes in the supplement type, and order number. You have the option to reopen tasks and gateway events attached to the order.
Request Structure: processSuppOrderRequest
Response Structure: assignProvPlanRequestResponse
The processSuppOrderRequest element contains the input information for the operation. Each row in Table 7-123 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-123 Payload Information for the Request
element
momProcessSuppOrderRequest
OrderAPI.wsdl
element
ProcessSuppOrderRequestValueType
complexType
orderKey
orderKey
element
OrderKey
OrderKey
complexType
Table 7-124 describes the required fields for processSuppOrderRequest.
Table 7-124 Required Fields for processSuppOrderRequest
suppType
Enum
Valid values of SuppTypeEnumType. This field indicates the reason that the order is being supplemented, or changed.
reopenTasksIndicator
boolean
Indicates whether the found tasks need to be re-opened for later processing.
reopenGatewayEventsIndicator
boolean
Indicates whether the found Gateway Events need to re-opened for later processing.
Table 7-125 describes the required fields for OrderKey.
Table 7-125 Required Fields for OrderKey
PrimaryKey
string
processSuppOrderRequestResponse
The processSuppOrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-126 describes the returned information in the response.
Table 7-126 Payload Information for the Response
element
processSuppOrderResponse
OrderAPI.wsdl
queryOrderManagementRequest Operation
This operation retrieves the order management information for:
  • validateOrderQueryValue
  • getTaskGWEventQueryValue
  • getServReqTasksQueryValue
  • getServiceRequestDLRsValue
  • getDLRInfosByOrderAndServiceItemIdValue
  • getDLRInfosByServiceItemIdInServiceValue
  • getServItemReferenceValue
  • getServItemsValue
Request Structure: queryOrderManagementRequest
Response Structure: queryOrderManagementRequestResponse
The queryOrderManagementRequest element contains the input information for the operation. Each row in Table 7-127 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-127 Payload Information for the Request
element
momQueryOrderManagementRequest
OrderAPI.wsdl
element
queryValue
queryValue
element
MetaSolvQueryValueChoice
complexType
Contains a choice of:
  • getServItemsValue
  • getProductCatalog
  • getOrderStatus
Table 7-128 defines getTaskGWEventQueryValue.
Table 7-128 getTaskGWEventQueryValue Definition
complexType
Extension of MomQueryValue
  • orderKey
  • taskKey
  • requestId
orderKey
element
OrderKey
taskKey
element
TaskKey
Table 7-129 describes the required fields for getTaskGWEventQueryValue.
Table 7-129 Required Fields for getTaskGWEventQueryValue
requestId
short
Request ID for get task gateway event query.
Table 7-130 describes the required fields for orderKey.
Table 7-130 Required Fields for OrderKey
primaryKey
string
Document number of the order in the OrderKey type.
Table 7-131 describes the required fields for TaskKey.
Table 7-131 Required Fields for TaskKey
taskPrimaryKey
string
Task number of the order.
Table 7-132 defines getServReqTasksQueryValue.
Table 7-132 getServReqTasksQueryValue Definition
complexType
mommekey
mommekey
element
mommekey
Mommekey
element
MetaSolvOrderKeyChoice
element
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
Table 7-133 describes the required fields for getServTasksQueryValue.
Table 7-133 Required Fields for getServReqTasksQueryValue
timeZone
string
Time zone.
Table 7-134 defines getServiceRequestDLRsValue.
Table 7-134 getServiceRequestDLRsValue Definition
element
GetServiceRequestDLRsValue
complexType
orderKey
orderKey
element
OrderKey
Table 7-135 defines getDLRInfosByOrderAndServiceItemIdValue.
Table 7-135 getDLRInfosByOrderAndServiceItemIdValue Definition
complexType
orderKey
orderKey
element
OrderKey
Table 7-136 describes the required fields for getDLRInfosByOrderAndServiceItemIdValue.
Table 7-136 Required Fields for getDLRInfosByOrderAndServiceItemIdValue
serviceItemId
long
Service item ID of the product where the DLR information is retrieved.
Table 7-137 defines getServItemReferenceValue.
Table 7-137 getServItemReferenceValue Definition
Name Defined As Type Definition File Name
complexType
orderKey
element
OrderKey
Table 7-138 describes the required fields for getServItemReferenceValue.
Table 7-138 Required Fields for getServItemReferenceValue.
serviceItemId
long
The service item ID of the product where the DLR information is retrieved.
Table 7-139 defines getProductCatalog.
Table 7-139 getProductCatalog Definition
getProductCatalog
complexType
  • productCatalogPolicy
  • criteria
element
criteria
element
CatalogExportCriteria
complexType
  • specificationKey
  • partyRoleCriteria
MIPCommonEntities.xsd
specificationKey
element
MetaSolvServiceSpecificationKey
complexType
ServiceEntities.xsd
Table 7-140 defines CatalogExportCriteria.
Table 7-140 CatalogExportCriteria Definition
complexType
  • specificationKey
  • partyRoleCriteria
specificationKey
element
complexType
ServiceEntities.xsd
Table 7-141 describes the required fields for productCatalogPolicy.
Table 7-141 Required Fields for productCatalogPolicy
customAttribute
boolean
Specifies whether the custom attribute should be included with the product catalog.
Table 7-142 describes the required fields for CatalogExportCriteria.
Table 7-142 Required Fields for CatalogExportCriteria
exportInd
boolean
Indicates if you only want level one products.
applicationUseCode
string
Application use code indicates which module uses the product catalog item created. If the application use code is Global the product catalog item is used by a PSR order.
Table 7-143 describes the required fields for MetaSolvServiceSpecificationKey.
Table 7-143 Required Fields for MetaSolvServiceSpecificationKey
string
Product specification ID of the product
Table 7-144 defines getOrderStatus.
Table 7-144 getOrderStatus Definition
getOrderStatus
complexType
orderKey
element
OrderKey
The queryOrderManagementRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-145 describes the returned information in the response.
Table 7-145 Payload Information for the Response
element
queryOrderManagementResponse
OrderAPI.wsdl
element
queryResponse
queryResponse
element
MetaSolvQueryResponseChoice
complexType
Contains a choice of the following:
  • getTaskGWEventQueryResponse
  • getServReqTasksQueryResponse
  • getDLRInfosByOrderAndServiceItemIdResponse
  • getDLRInfosByServiceItemIdInServiceResponse
  • getServItemReferenceResponse
  • getServItemsResponse
  • getProductCatalogResponse
  • getOrderStatusResponse
Table 7-146 defines getTaskGWEventQueryResponse.
Table 7-146 getTaskGWEventQueryResponse Definition
complexType
gWEventTypes
element
MetaSolvGatewayEventValue
element
GatewayEventType
GatewayEventType
complexType
OrderManagementEvents.xsd
gatewayEventKey
element
GatewayEventKey
taskKeyPredecessor
element
TaskKey
Table 7-147 defines GetServReqTasksQueryResponse.
Table 7-147 GetServReqTasksQueryResponse Definition
complexType
predFollows
element
PredFollowType
PredFollowType
complexType
taskKey
element
TaskKey
orderKey
element
OrderKey
Table 7-148 defines getDLRInfosByOrderAndServiceItemIdResponse.
Table 7-148 getDLRInfosByOrderAndServiceItemIdResponse Definition
complexType
orderKey
element
OrderKey
dlrInfos
element
DLRInfo
DLRInfo
complexType
Table 7-149 defines getDLRInfosByServiceItemIdInServiceResponse.
Table 7-149 getDLRInfosByServiceItemIdInServiceResponse Definition
complexType
orderKey
element
OrderKey
dlrInfos
element
DLRInfo
DLRInfo
complexType
Table 7-150 defines getServItemReferenceResponse.
Table 7-150 getServItemReferenceResponse Definition
complexType
orderKey
element
OrderKey
serviceItemAlias
string
numberKey
element
MetaSolvResourceKey
Table 7-151 defines getServItemsResponse.
Table 7-151 getServItemsResponse Definition
complexType
element
complexType
ServiceEntities.xsd
serviceKey
element
MetaSolvServiceKey
ServiceEntities.xsd
parentSpecKey
element
ServiceEntities.xsd
element
ServiceEntities.xsd
parentServiceKey
element
MetaSolvServiceKey
ServiceEntities.xsd
serviceLocationKey
element
MetaSolvLocationKey
ServiceEntities.xsd
addressKey
element
MetaSolvResourceKey
ServiceEntities.xsd
element
MetaSolvResourceKey
ServiceEntities.xsd
serviceItemValues
element
ServiceItemValueType
ServiceEntities.xsd
assignedTelephoneNr
element
AssignedTelephoneNrType
ServiceEntities.xsd
Access
element
AccessType
ServiceEntities.xsd
isdnTrunkGroup
element
IsdnTrunkGroupType
ServiceEntities.xsd
trunkGroup
element
TrunkGroupType
ServiceEntities.xsd
Circuit
element
CircuitType
ServiceEntities.xsd
circuitLocation
element
CircuitLocationType
ServiceEntities.xsd
Connector
element
ConnectorType
ServiceEntities.xsd
caUsageInstance
element
CaUsageInstanceType
ServiceEntities.xsd
picInfo
element
PicInfoType
ServiceEntities.xsd
orderItemPrice
element
ServiceEntities.xsd
EmailInfo
element
EmailInfoType
ServiceEntities.xsd
DialupInfo
element
DialupInfoType
ServiceEntities.xsd
TemplateInfo
element
TemplateInfoType
ServiceEntities.xsd
ElementInfo
element
ElementInfoType
ServiceEntities.xsd
EquipmentInfo
element
EquipmentInfoType
ServiceEntities.xsd
PSRDirServ
element
PSRDirServType
ServiceEntities.xsd
PSRDirListing
element
PSRDirListingType
ServiceEntities.xsd
AuthCDUsage
element
AuthCDUsageType
ServiceEntities.xsd
huntGroup
element
HuntGroupType
ServiceEntities.xsd
Table 7-152 defines getProductCatalogResponse.
Table 7-152 getProductCatalogResponse Definition
complexType
productSpecification
element
pSRSpecItemType
element
pSRSpecItemType
pSRSpecItemType
complexType
specificationKey
element
levelOneSpecKey
element
LevelOneSpecKey
parentSpecId
element
parentSpecId
Netarea
element
NetworkAreaType
Prices
element
PSRSpecItemPriceType
Labels
element
PSRDefaultValueType
levelOne
element
LevelOneUnionType
Standard
element
IndicatorEnumType
Required
element
IndicatorEnumType
global
element
IndicatorEnumType
guideInd
element
IndicatorEnumType
softProvInd
element
IndicatorEnumType
CaUsages
element
CaUsageType
partyRoles
element
PSRSpecItemPartyRoleType
Table 7-153 defines getOrderStatusResponse.
Table 7-153 getOrderStatusResponse Definition
complexType
orderStatus
orderStatus
element
OrderStatusEnumType
reopenTaskRequest Operation
This operation requests a task to be reopened. This is for a task that is already completed. This operation takes an input order number and task number.
Request Structure: reopenTaskRequest
Response Structure: reopenTaskRequestResponse
reopenTaskRequest
The reopenTaskRequest element contains the input information for the operation. Each row in Table 7-154 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-154 Payload Information for the Request
reopenTaskRequest
element
momReopenTaskRequest
OrderAPI.wsdl
element
reopenTaskValue
reopenTaskValue
element
ReopenTaskValueType
ReopenTaskValueType
complexType
orderNumber
element
OrderKey
taskNumber
element
TaskKey
The reopenTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-155 describes the returned information in the response.
Table 7-155 Payload Information for the Response
element
reopenTaskResponse
OrderAPI.wsdl
reopenTaskResponse
element
orderKey
orderKey
element
OrderKey
OrderKey
complexType
rejectTaskRequest Operation
This operation rejects a completed predecessor task. It takes an input order number, task number, new work queue id, and reject reason.
Request Structure: rejectTaskRequest
Response Structure: rejectTaskRequestResponse
rejectTaskRequest
The rejectTaskRequest element contains the input information for the operation. Each row in Table 7-156 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-156 Payload Information for the Request
rejectTaskRequest
element
momRejectTaskRequest
OrderAPI.wsdl
element
rejectTaskValue
rejectTaskValue
element
RejectTaskValueType
RejectTaskValueType
complexType
orderNumber
element
OrderKey
taskNumber
element
TaskKey
newWorkQueueId
element
string
rejectReason
element
string
The rejectTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-157 describes the returned information in the response.
Table 7-157 Payload Information for the Response
element
rejectTaskResponse
OrderAPI.wsdl
rejectTaskResponse
element
orderKey
orderKey
element
OrderKey
OrderKey
complexType
startOrderRequest Operation
This operation validates the order along with a finish order option request. This operation takes an input document number (order number).
Request Structure: startOrderRequest
Response Structure: startOrderRequestResponse
startOrderRequest
The startOrderRequest element contains the input information for the operation. Each row in Table 7-158 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-158 Payload Information for the Request
startOrderRequest
element
startOrderByKeyRequest
OrderAPI.wsdl
element
mommekey
Mommekey
element
complexType
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
The startOrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-159 describes the returned information in the response.
Table 7-159 Payload Information for the Response
element
startOrderByKeyResponse
OrderAPI.wsdl
element
mommekey
mommekey
element
complexType
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
Table 7-160 describes the error messages for the operation.
Table 7-160 Error Messages for the Operation
Error Message Cause Resolution
The Broadband Service Category is missing for this bandwidth circuit. Please add a Broadband Service Category value to this order.
This order cannot be started until the Broadband Service Category is added.
Add the Broadband Service Category to this circuit.
Error: This service item has required labels with no values. Please add values.
You have requested a start order but values are missing from a service item.
Put in values for the required labels on the service items.
TaskJeopardyRequest Operation
This operation adds task jeopardy information for the input task number.
Request Structure: TaskJeopardyRequest
Response Structure: TaskRequestResponse
TaskJeopardyRequest
The TaskJeopardyRequest element contains the input information for the operation. Each row in Table 7-161 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-161 Payload Information for the Request
TaskJeopardyRequest
element
getTaskJeopardyRequest
OrderAPI.wsdl
element
GetTaskJeopardyRequestValue
element
GetTaskJeopardyRequestValueType
element
Contains the following:
  • orderKey
  • taskKey
orderKey
element
OrderKey
taskKey
element
TaskKey
Table 7-162 describes the required fields for TaskJeopardyRequest.
Table 7-162 Required Fields for TaskJeopardyRequest
circuitId
string
Circuit ID assigned to the order.
timeZone
string
Time zone.
TaskJeopardyRequestResponse
The TaskJeopardyRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-163 describes the returned information in the response.
Table 7-163 Payload Information for the Response
element
getTaskJeopardyResponse
OrderAPI.wsdl
element
getTaskJeopardyReponseValue
element
GetTaskJeopardyResponseValueType
complexType
orderKey
element
OrderKey
taskKey
element
TaskKey
This operation retrieves task details for the input task number and document number.
Request Structure: TaskRequest
TaskRequest
The TaskRequest element contains the input information for the operation. Each row in Table 7-164 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-164 Payload Information for the Request
TaskRequest
element
getTaskDetailRequest
OrderAPI.wsdl
element
getTaskDetailValue
getTaskDetailValue
element
getTaskDetailRequestValueType
complexType
  • orderKey
  • taskKey
orderKey
element
OrderKey
taskKey
element
TaskKey
Table 7-165 describes the required fields for getTaskDetailRequestValueType.
Table 7-165 Required Fields for getTaskDetailRequestValueType
timeZone
string
Time zone.
TaskRequestResponse
The TaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-166 describes the returned information in the response.
Table 7-166 Payload Information for the Response
TaskRequestResponse
element
getTaskDetailResponse
OrderAPI.wsdl
element
TaskDetailResponseValue
element
getTaskDetailResponseValueType
complexType
orderKey
element
OrderKey
taskKey
element
TaskKey
transferTaskRequest Operation
This operation transfers tasks from one work queue to another work queue.
Request Structure: transferTaskRequest
Response Structure: transferTaskRequestResponse
transferTaskRequest
The transferTaskRequest element contains the input information for the operation. Each row in Table 7-167 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-167 Payload Information for the Request
transferTaskRequest
element
momTransferTaskRequest
OrderAPI.wsdl
element
transferTaskValue
transferTaskValue
element
TransferTaskValueType
complexType
orderKey
orderKey
element
OrderKey
Table 7-168 describes the required fields for TransferTaskValueType.
Table 7-168 Required Fields for TransferTaskValueType
taskNumber
long
Task that is being transferred.
currentWorkQueue
string
Work queue where a task is currently assigned.
newWorkQueue
string
Work queue where you are transferring a task.
The transferTaskRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-169 describes the returned information in the response.
Table 7-169 Payload Information for the Response
element
transferTaskResponse
OrderAPI.wsdl
element
orderKey
orderKey
element
OrderKey
Table 7-170 describes the error messages for the operation.
Table 7-170 Error Messages for the Operation
The Transfer TO Work Queue is an invalid work queue.
For the input task, the provided work queue to transfer the task, does not exist in the database.
Populate the transfer to work queue with a valid input value that exists in the database.
updateCnamData Operation
This operation updates the details of CNAM records.
Request Structure: updateCnamData
Response Structure: updateCnamDataResponse
updateCnamData
The updateCnamData element contains the input information for the operation. Each row in Table 7-171 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-171 Payload Information for the Request
updateCnamData
element
updateCNAMDataRequest
OrderAPI.wsdl
element
CNAMDataValue
CNAMDataValue
element
CNAMDataType
CNAMDataType
complexType
CNAMRecords
CNAMRecords
element
CNAMRecordType
CNAMRecordType
complexType
Table 7-172 describes the required fields for CNAMDataType.
Table 7-172 Required Fields for CNAMDataType
extractSequence
long
Oracle-generated sequence that identifies a group of CNAM records returned from a call to getCNAMDataRequest. You must pass back the same extractSequence value for the corresponding set of extract records in the call to updateCNAMDataRequest.
Table 7-173 describes the required fields for CNAMRecordType.
Table 7-173 Required Fields for CNAMRecordType
bsp
string
Billing service provider.
callingNm
string
Name that is shown on the called party's caller ID.
Line
string
Line portion of the telephone number. Valid values are a 4-digit number created using numeric characters (0-9).
Npa
string
Numbering plan area of the telephone number. Valid values are a 3-digit number created using numeric characters (0-9).
Nxx
string
Exchange portion of the telephone number. NXX is also known as the central office (CO) prefix or code. Valid values are a 3-digit number created using numeric characters (0-9).
ocn
string
Number assigned to a local exchange carrier or an interexchange carrier. This field is also referred to as the company code (CC).
presCd
CharType
Code that indicates if the name should be presented when the called party has caller ID. Valid values are ALLOW and RESTRICT.
rao
string
Revenue accounting office (RAO) associated with the NPA NXX. The RAO processes message usage in the form of automatic message accounting (AMA).
transCd
CharType
Indicates the action taken by the database provider. Valid values are ADD, MODIFY, and DELETE.
Date
string
The effective date of the CNAM update. This date field is only recorded to resolve discrepancies. Format: YYYY-MM-DD. Example: 2015-06-01.
entrySrc
CharType
Identifies the mechanism used to send information to the LIDB/CNAM database provider.
The updateCnamDataResponse elementelementelement contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-174 describes the returned information in the response.
Table 7-174 Payload Information for the Response
element
updateCNAMDataReponse
OrderAPI.wsdl
element
status
updateE911DataRequest Operation
This operation updates the status of E911 records.
Request Structure: updateE911DataRequest
Response Structure: updateE911DataRequestResponse
The updateE911DataRequest element contains the input information for the operation. Each row in Table 7-175 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-175 Payload Information for the Request
element
momUpdateE911DataRequest
OrderAPI.wsdl
element
e911DataValue
e911DataValue
element
E911DataType
E911DataType
complexType
e911Records
e911Records
element
E911RecordType
E911RecordType
complexType
E911ErrorType
complexType
e911ErrorStruc
e911ErrorStruc
element
E911ErrorStruc
E911ErrorStruc
complexType
Table 7-176 describes the required fields for E911DataType.
Table 7-176 Required Fields for E911DataType
extractSequence
long
Oracle-generated sequence that identifies a group of E911 records returned from a call to getE911DataRequest. You must pass back the same extractSequence value for the corresponding set of extract records in the call to updateE911DataRequest.
Table 7-177 describes the required fields for E911RecordType.
Table 7-177 Required Fields for E911RecordType
Cls
CharType
Class of service.
cpd
string
Completion date (YYYY-MM-DD) .
Ctn
string
Calling telephone number.
Exd
string
Extract Date YYYY-MM-DD
Foc
CharType
Function code (function of change).
Hno
string
House number of the service location for the calling telephone number.
Nam
string
Customer name.
Ord
string
Order number.
Pcn
string
Postal community name of the service location for the calling telephone number.
Sta
string
State/province of the service location for the calling telephone number.
Stn
string
Street name of the service location for the calling telephone number.
Table 7-178 describes the required fields for E911ErrorStruc.
Table 7-178 Required Fields for E911ErrorStruc
Code
integer
Error code.
Reason
string
Reason for the error.
The updateE911DataRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-179 describes the returned information in the response.
Table 7-179 Payload Information for the Response
element
updateE911DataReponse
OrderAPI.wsdl
element
status
updateEstimationCompletedDateRequest Operation
This operation updates the estimated completion date for an input task. The request takes an input document number, task number and estimated completion date.
Request Structure: updateEstimationCompletedDateRequest
Response Structure: updateEstimationCompletedDateRequestResponse
The updateEstimationCompletedDateRequest element contains the input information for the operation. Each row in Table 7-180 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-180 Payload Information for the Request
element
updateEstimatedCompletionDateRequest
OrderAPI.wsdl
element
updateEstimatedCompletionDateValue
element
UpdateEstimatedCompletionDateValueType
complexType
  • orderNumber
  • taskNumber
orderNumber
element
OrderKey
taskNumber
element
TaskKey
Table 7-181 describes the required fields for UpdateEstimatedCompletionDateValueType.
Table 7-181 Required Fields for UpdateEstimatedCompletionDateValueType
timeZone
string
Time zone associated with an NPA NXX/building location.
estCompDateTime
string
Work queue owner's estimate of the task completion date and time.
The updateEstimationCompletedDateRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-182 describes the returned information in the response.
Table 7-182 Payload Information for the Response
element
updateEstimatedCompletionDateResponse
OrderAPI.wsdl
element
status
updateGWEventRequest Operation
This operation updates order management details for the following:
  • updateOrderTaskGWEventValue
  • completeTaskProcedureValue
  • updateOrderTaskEventProcedureValue
  • reopenTaskProcedureValue
  • updateServicesInOrderProcedureValue
Request Structure: updateGWEventRequest
Response Structure: updateGWEventRequestResponse
The updateGWEventRequest element contains the input information for the operation. Each row in Table 7-183 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-183 Payload Information for the Request
element
updateOrderManagementRequest
OrderAPI.wsdl
element
updateValue
updateValue
element
MetaSolvUpdateProcedureValueChoice
complexType
complexType
metaSolvGatewayEventKey
element
GatewayEventKey
GatewayEventKey
complexType
  • orderKey
  • taskKey
  • serviceKey
orderKey
element
OrderKey
taskKey
element
TaskKey
serviceKey
element
MetaSolvServiceKey
ServiceEntities.xsd
Table 7-184 describes the required fields for updateOrderTaskGWEventValue.
Table 7-184 Required Fields for updateOrderTaskGWEventValue
statusCode
Enum
Valid values of GatewayEventStatusEnumType. Current state of the gateway event.
requestId
short
Request ID
Table 7-185 describes the required fields for serviceKey.
Table 7-185 Required Fields for serviceKey
servicePrimaryKey
string
The updateGWEventRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-186 describes the returned information in the response.
Table 7-186 Payload Information for the Response
element
updateOrderTaskGWEventResponse
OrderAPI.wsdl
element
UpdateOrderTaskGWEventResponse
complexType
Extension of UpdateProcedureResponse metaSolvGatewayEventKey
element
GatewayEventKey
GatewayEventKey
complexType
Extension of EventKey
  • orderKey
  • taskKey
  • serviceKey
EventKey
complexType
Extension of ManagedEntityKey
orderKey
element
OrderKey
taskKey
element
TaskKey
serviceKey
element
MetaSolvServiceKey
updateLidbData Operation
This operation updates the details of LIDB records.
Request Structure: updateLidbData
Response Structure: updateLidbDataResponse
updateLidbData
The updateLidbData element contains the input information for the operation. Each row in Table 7-187 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-187 Payload Information for the Request
updateLidbData
element
updateLIDBDataRequest
OrderAPI.wsdl
element
LIDBDataValue
LIDBDataValue
element
LIDBDataType
LIDBDataType
complexType
LIDBRecords
LIDBRecords
element
LIDBRecordType
LIDBRecordType
complexType
Table 7-188 describes the required fields for LIDBDataType.
Table 7-188 Required Fields for LIDBDataType
extractSequence
long
Oracle-generated sequence that identifies a group of LIDB records returned from a call to getLIDBDataRequest. You must pass back the same extractSequence value for the corresponding set of extract records in the call to updateLIDBDataRequest.
Table 7-189 describes the required fields for LIDBRecordType.
Table 7-189 Required Fields for LIDBRecordType
bnsCd
CharType
Determines what kind of calls can be made from another telephone but billed to this number.
busResCd
CharType
Indicates the type of market that this telephone number is intended. Valid values are B = BUSINESS, R = RESIDENCE.
Line
string
Npa
string
Nxx
string
ocn
string
servClassCd
string
Class of Service code. Valid values are BUS = Business, RES = Residential, PBC = Public Coin, PBN = Public non-coin.
transCd
CharType
Indicates the action taken by the database provider. Valid values are I = ADD, C = MODIFY, D = DELETE.
entrySrc
CharType
Field identifies the mechanism used to send information to the LIDB/CNAM database provider.
thirdNbrAcc
CharType
Third number acceptance indicator. Valid values are B = DENIED (This value prevents the PSR from go into Complete status), C = VERIFIED.
collCallAcc
CharType
Collect call acceptance indicator. Valid values are B = DENIED, A = VERIFIED.
The updateLidbDataResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-190 describes the returned information in the response.
Table 7-190 Payload Information for the Response
element
updateLIDBDataReponse
OrderAPI.wsdl
element
Success
updateOrderRequest Operation
Request Structure: updateOrderRequest
Response Structure: updateOrderRequestResponse
updateOrderRequest
The updateOrderRequest element contains the input information for the operation. Each row in Table 7-191 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-191 Payload Information for the Request
updateOrderRequest
element
OrderAPI.wsdl
element
updateValue
updateValue
element
complexType
Table 7-192 defines UpdateServicesInOrderProcedureValue.
Table 7-192 UpDateServicesInOrderProcedureValue Definition
element
metaSolvPSROrderValue
complexType
Described in Table 7-36
Table 7-193 defines updateOrderTaskGWEventValue.
Table 7-193 updateOrderTaskGWEventValue Definition
element
UpdateOrderTaskGWEventValue
complexType
metaSolvGatewayEventKey,statusCode
element
GatewayEventKey
GatewayEventKey
complexType
Table 7-194 defines CompleteTaskProcedureValue
Table 7-194 CompleteTaskProcedureValue Definition
Name Defined As File Description File Name
complexType
whyMissInputs
element
WhyMissInputType
WhyMissInputType
complexType
Mommekey
element
element
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
The updateOrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-195 describes the returned information in the response.
Table 7-195 updateOrderRequestResponse
element
updateOrderManagementResponse
OrderAPI.wsdl
element
updateValueResponse
updateValueResponse
element
MetaSolvUpdateProcedureValueResponseChoice
complexType
  • updateServicesInOrderProcedureResponse
  • completeTaskProcedureResponse
  • updateOrderTaskGWEventResponse
element
UpdateServicesInOrderProcedureResponse
complexType
Extension of UpdateProcedureResponse metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
element
CompleteTaskProcedureResponse
complexType
Extension of UpdateProcedureResponse mommekey
mommekey
element
complexType
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
element
complexType
element
GatewayEventKey
GatewayEventKey
complexType
  • orderKey
  • taskKey
  • serviceKey
EventKey
complexType
orderKey
element
OrderKey
OrderKey
complexType
taskKey
element
TaskKey
TaskKey
complexType
serviceKey
element
MetaSolvServiceKey
MetaSolvServiceKey
complexType
ServiceEntities.xsd
updatePSROrderRequest Operation
Request Structure: updatePSROrderRequest
Response Structure: updatePSROrderRequestResponse
The updatePSROrderRequest element contains the input information for the operation. Each row in Table 7-196 describes the element or type name, the XSD declaration, the type description, and the file name that contains the item's definition.
Table 7-196 Payload Information for the Request
element
OrderAPI.wsdl
element
updateValue
updateValue
element
complexType
Table 7-197 defines updateServicesInOrderProcedureValue.
Table 7-197 UpdateServicesInOrderProcedureValue
element
complexType
Table 7-198 defines updateOrderTaskGWEventValue.
Table 7-198 updateOrderTaskGWEventValue
element
complexType
Extension of UpdateProcedureValue
statusCode
element
element
GatewayEventKey
GatewayEventKey
complexType
EventKey
element
eventPrimaryKey
taskKey
element
taskKey
orderKey
element
taskKey
serviceKey
element
MetaSolvServiceKey
Table 7-199 defines CompleteTaskProcedureValue.
Table 7-199 CompleteTaskProcedureValue Definition
complexType
whyMissInputs
element
WhyMissInputType
WhyMissInputType
complexType
Mommekey
element
element
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
The updatePSROrderRequestResponse element contains the output information for the operation. The information returned in the response indicates if the operation is successful. Table 7-200 describes the returned information in the response.
Table 7-200 Payload Information for the Response
element
OrderAPI.wsdl
element
complexType
metaSolvOrderKey
metaSolvOrderKey
element
OrderKey
OrderKey
complexType
Table 7-201 describes the error messages for the operation.
Table 7-201 Error Messages for the Operation
The telephone number type you specified does not match the type in the database or the telephone number is invalid.
