16 CCP Dashboard
This chapter explains the features of Oracle Communications Network Charging and Control Customer Care Portal that are available from the CCP Dashboard.
This chapter contains the following topics.
CCP Dashboard Screen
The CCP Dashboard screen displays information about your subscribers. It contains a number of features that help you to manage subscriber data quickly. You can:
Search for subscriber accounts. For details, see Searching for Subscribers.
View a summary of a subscriber's details. For details, see Quick View.
Search for and change the status of vouchers or redeem vouchers. For details, see Vouchers in CCP.
View the subscriber's recent EDRs. For details, see View EDRs from Dashboard.
Complete common administrative tasks. For details, see Common Tasks.
Quickly find and select recently viewed subscribers or vouchers. For details, see History.
Open the Edit Subscriber screen. For more information about editing subscribers, see Accessing the Edit Subscriber screen.
The CCP Dashboard screen also provides the following security features:
Lock the dashboard. For details, see Locking and Unlocking the Dashboard.
Change your password. For details, see Changing Your Password.
Buttons
This table describes the buttons available in the CCP Dashboard screen.
| Button | Function |
Hides the CCP Dashboard screen and opens the CCP Dashboard Locked screen. The user must enter their user name and password before the CCP Dashboard screen will be reopened. Note: This must be the same user and password combination as the one entered when the user initially logged in. |
Use to change your password. |
Opens the CCP help files. |
Use to search for subscriber or voucher records. |
Opens the Edit Subscriber screen for a selected subscriber. |
Refreshes the details in the screen. |
Changes the voucher state. |
Redeems a voucher for a selected subscriber. |
Toggles the Vouchers panel on or off. |
Toggles the Common Tasks panel on or off. |
Toggles the History panel on or off. |
Toggles the EDR panel on or off. |
Status bar
In the bottom left corner of the CCP Dashboard there is a status bar. The status bar displays messages about the tasks being performed using the CCP Dashboard.
Follow these steps to open the Edit Subscriber screen for a selected subscriber.
Note: Only primary wallet information is available for editing when you open the Edit Subscriber screen from the CCP Dashboard.
In the CCP Dashboard screen, search for the subscriber to view or edit using the subscriber search fields. For details see Finding a subscriber.
Highlight the row in the search results for the subscriber to edit.
Click Open.
Result: You see the details of the subscriber selected from the search results in the Edit Subscriber screen.
Tip: To quickly open the Edit Subscriber screen, double click the required entry in the search results.
You can search for subscribers in the CCP Dashboard screen based on criteria entered in the subscriber search fields. The available search fields will depend on how your system has been set up. A maximum of four search fields may be available.
Follow these steps to search for a subscriber in the CCP Dashboard screen.
From the drop down list, select the Service Provider.
In the search panel, enter the search strings you are using to find the required subscriber in one or more of the available search fields.
If your search is based on any of these fields, you can enter just the first few characters to search for in the search field:
Subscriber ID
Card Number
Customer
Wallet Reference
If you are searching on any other field, then you must enter the full value to search for in the search field.
Click Search.
Result: Subscribers that match all the search criteria will be displayed in the search results.
Note: You may only access wallet information for a subscriber's primary wallet in the CCP, therefore only primary wallet information will be returned.
Search results
The results of a subscriber search are displayed in the search results table immediately below the subscriber search fields. Only the first 100 records matching your search criteria will be listed. If the subscriber you require does not appear in the list and more than 100 records were returned, then you will need to refine your search criteria. For example, enter longer search strings and/or specify more search fields.
Tip: To reorder subscribers by a particular column name, select the column in the search results table.
Finding linked subscribers
Follow these steps to find any additional subscribers that share their primary wallet with a selected subscriber.
In the search results panel select the subscriber for whom you want to find any linked subscribers.
In the search panel select the Show Linked Subscribers check box.
Result: Any additional subscribers that share the primary wallet of the selected subscriber will appear in the search results list.
Quick View
The Quick View panel in the CCP Dashboard screen lets you view important information about a selected subscriber account. The information which is available will depend on the configuration defined for the selected service provider.
Viewing a subscriber
Follow these steps to see a quick view of a selected subscriber.
In the search results panel on the CCP Dashboard, select the subscriber record to view.
Result: The Subscriber's details appear in the Quick View panel.
Tip: To display the details of a previously selected subscriber in the Quick View, select the subscriber ID from the History panel.
The View EDRs panel in the CCP Dashboard screen lets you view the recent EDRs for a selected subscriber account. The information which is available will depend on the configuration defined for the selected service provider.
Viewing EDR list
Follow these steps to see the EDRs of a selected subscriber.
Result: The subscriber's details appear in the Quick View panel, and the EDR details are listed in the View EDRs panel.
Tip: To display the details of a previously selected subscriber in the Quick View, select the Subscriber ID from the History panel.
Click View EDRs if panel is not displayed.
Note: The information which is available will depend on the configuration defined for the selected service provider. The default EDRs shown will depend on configuration in the smsGui.bat/smsGui.sh or ccpGui.bat/ccpGui.sh file.
View EDR detail
Follow these steps to view the details of an EDR record.
Select the EDR record to view in the table in the View EDRs panel.
Double click the EDR record.
Result: You see the EDR Details for Subscriber screen.
Note: The screen layout and available fields depend on the category and template definition configured for the EDR in CCS. For more information, refer to CCS User's Guide.
To change the currency used to display costs and balances, select the Display Currency drop down list.
When you have finished viewing that EDR record, click Close.
Result: You return to the Dashboard.
Notes:
From the Dashboard the EDR details can only be viewed, they cannot be reversed.
To reverse a charge the EDR must be accessed through the Edit Subscriber process. See the Reversing a charge procedure.
Common Tasks
The CCP Dashboard screen provides the facility to execute any common tasks that have been set up for you. You execute common tasks from the Common Tasks panel where a button is provided for each available task.
Note: Common Tasks may also be referred to as BPL tasks.
Executing a common task
Follow these steps to execute a common task for a subscriber.
Note: The common task will be executed for the subscriber currently displayed in the Quick View.
In the CCP Dashboard screen search for the subscriber. For details, see Finding a subscriber.
Select the subscriber record in the search results so that their details appear in the Quick View.
Tip: Select a subscriber from the History panel to redisplay their details in the Quick View.
If the Common Tasks panel is not currently visible in the CCP Dashboard screen, then click Common Tasks to display it.
Note: If no common tasks have been defined for the service provider then the Common Tasks panel is not displayed. You see the following message in the Status bar at the bottom of the screen: "
No Common Tasks defined." -
In the Common Tasks panel, click the button for the task you want to execute.
Result: You see the Confirm Execute Common Task prompt.
If any parameters have been defined for the tasks, enter the values for these as prompted.
Warning: You must enter a value for all mandatory parameters.
Click Execute.
Result: You see the Executing Common Task progress box.
Then you see the Execute Common Task Result prompt.
Note: If the task fails then a message giving the failure reason is displayed in the Execute Common Task Result screen.
Click OK.
History
The search history for subscriber accounts and Vouchers is displayed on the Subscriber and Voucher tabs in the History panel. A new entry is added to the subscriber history each time a subscriber account is displayed in the Quick View panel. Similarly, a new entry is added to the voucher history each time a valid voucher is retrieved in the Vouchers panel.
Viewing history
Follow these steps to view a historical list of subscribers or vouchers.
If the History panel is not currently visible in the CCP Dashboard screen, click History to display it.
In the History panel select the tab for the type of history you want to view. Select one of:
Subscriber
Voucher
Select an item from the history to review its details. Select one of:
Subscriber ID to view its details in the Quick View panel
Voucher ID to view its details in the Vouchers panel
Tip: Double-click a subscriber ID to access its details in the Edit Subscriber screen.
The Change Password screen appears when you click Password in the CCP Dashboard screen.
Use this screen to change the password for your user account.
Changing your password
Follow these steps to change your password.
In the CCP Dashboard screen, click Password.
Result: You see the Change Password screen.
Enter your current password in the Old Password field.
Enter your new password in the New Password field.
Note: For security reasons, a password must be at least 8 characters long.
Re-enter your new password in the Confirmation field.
Click OK to save the changed password.
If you need to leave your work station for a short period, then you can lock the CCP Dashboard screen so that the screen contents are protected. When you lock the CCP Dashboard, the screen is hidden from view and the CCP Dashboard Locked prompt is displayed. The CCP Dashboard will be redisplayed as soon as you reenter your original user name and password correctly.
You can make a maximum of three attempts to enter the correct user name and password combination. If you make more than three failed attempts, then you will receive a warning message and the CCP application will be terminated.
Note: The CCP Dashboard will also be locked automatically if the SMS quality of service feature is enabled and you have not used the CCP Dashboard for a configurable period of time.
For further information on this feature refer to SMS User's Guide.
Locking the dashboard
Follow these steps to lock the CCP Dashboard.
In the CCP Dashboard screen, click Lock Dashboard.
Result: The CCP Dashboard screen is hidden from view and you see the CCP Dashboard Locked prompt.
Unlocking the dashboard
Follow these steps to unlock the CCP Dashboard screen.
Enter your user name in the User Name field in the CCP Dashboard Locked screen.
Note: This must be the same user name as the one you originally used to log in with for this session.
Enter your password in the Password field.
Click Ok.
Result: The CCP Dashboard screen reappears.
