3 Debug Tool
The Debug Tool provides third-party troubleshooting tools for debugging the runtime issues for the lab environment.
Following are the available tools:
- tcpdump
- ip
- netstat
- curl
- ping
- nmap
- dig
3.1 Preconfiguration Steps
- For CNE 23.2.0 and later versions, follow Step a of Configuration in CNE.
- For CNE versions prior to 23.2.0, follow Step b of Configuration in CNE.
- Configuration in CNE
The following configurations must be performed in the Bastion Host.
- When OCNWDAF is installed on CNE version 23.2.0 or above:
- In CNE version 23.2.0 or above, the default CNE 23.2.0 Kyverno policy, disallow-capabilities, do not allow NET_ADMIN and NET_RAW capabilities that are required for debug tool.
- To run Debug tool on CNE 23.2.0 and above, the user must modify the existing Kyverno policy, disallow-capabilities, as below.
Adding a Namespace to an Empty Resource- Run the following command to verify if the current disallow-capabilities cluster policy has namespace in it.
Example:
Sample output:$ kubectl get clusterpolicies disallow-capabilities -oyamlapiVersion: kyverno.io/v1 kind: ClusterPolicy ... ... spec: rules: -exclude: any: -resources:{} - If there are no namespaces, then patch the policy using the following command to add <namespace> under resources:
Example:$ kubectl patch clusterpolicy disallow-capabilities --type=json \ -p='[{"op": "add", "path": "/spec/rules/0/exclude/any/0/resources", "value": {"namespaces":["<namespace>"]} }]'
Sample output:$ kubectl patch clusterpolicy disallow-capabilities --type=json \ -p='[{"op": "add", "path": "/spec/rules/0/exclude/any/0/resources", "value": {"namespaces":["ocnwdaf"]} }]'apiVersion: kyverno.io/v1 kind: ClusterPolicy ... ... spec: rules: -exclude: resources: namespaces: -ocnwdaf - If in case it is needed to remove the namespace added in the above step, use the following command:
Sample output:$ kubectl patch clusterpolicy disallow-capabilities --type=json \ -p='[{"op": "replace", "path": "/spec/rules/0/exclude/any/0/resources", "value": {} }]'apiVersion: kyverno.io/v1 kind: ClusterPolicy ... ... spec: rules: -exclude: any: -resources:{}
Adding a Namespace to an Existing Namespace List- Run the following command to verify if the current disallow-capabilities cluster policy has namespaces in it.
Example:
Sample output:$ kubectl get clusterpolicies disallow-capabilities -oyamlapiVersion: kyverno.io/v1 kind: ClusterPolicy ... ... spec: rules: -exclude: any: -resources: namespaces: -namespace1 -namespace2 -namespace3 - If there are namespaces already added, then patch the policy using the following command to add <namespace> to the existing list:
Example:$ kubectl patch clusterpolicy disallow-capabilities --type=json \ -p='[{"op": "add", "path": "/spec/rules/0/exclude/any/0/resources/namespaces/-", "value": "<namespace>" }]'
Sample output:$ kubectl patch clusterpolicy disallow-capabilities --type=json \ -p='[{"op": "add", "path": "/spec/rules/0/exclude/any/0/resources/namespaces/-", "value": "ocnwdaf" }]'apiVersion: kyverno.io/v1 kind: ClusterPolicy ... ... spec: rules: -exclude: resources: namespaces: -namespace1 -namespace2 -namespace3 -ocnwdaf - If in case it is needed to remove the namespace added in the above step, use the following command:
Example:$ kubectl patch clusterpolicy disallow-capabilities --type=json \ -p='[{"op": "remove", "path": "/spec/rules/0/exclude/any/0/resources/namespaces/<index>"}]'
Sample output:$ kubectl patch clusterpolicy disallow-capabilities --type=json \ -p='[{"op": "remove", "path": "/spec/rules/0/exclude/any/0/resources/namespaces/3"}]'apiVersion: kyverno.io/v1 kind: ClusterPolicy ... ... spec: rules: -exclude: resources: namespaces: -namespace1 -namespace2 -namespace3Note:
While removing the namespace, provide the index value for namespace within the array. The index starts from '0'.
- When OCNWDAF is installed on CNE version prior to 23.2.0
PodSecurityPolicy (PSP) Creation
Create a PSP by running the following command from the bastion host. The parameters readOnlyRootFileSystem, allowPrivilegeEscalation, and allowedCapabilities are required by debug container.Note:
Other parameters are mandatory for PSP creation and can be customized as per the CNE environment. The default values are recommended.$ kubectl apply -f - <<EOF apiVersion: policy/v1beta1 kind: PodSecurityPolicy metadata: name: debug-tool-psp spec: readOnlyRootFilesystem: false allowPrivilegeEscalation: true allowedCapabilities: - NET_ADMIN - NET_RAW fsGroup: ranges: - max: 65535 min: 1 rule: MustRunAs runAsUser: rule: MustRunAsNonRoot seLinux: rule: RunAsAny supplementalGroups: rule: RunAsAny volumes: - configMap - downwardAPI - emptyDir - persistentVolumeClaim - projected - secret EOFRole Creation
Run the following command to create a role for the PSP:kubectl apply -f - <<EOF apiVersion: rbac.authorization.k8s.io/v1 kind: Role metadata: name: debug-tool-role namespace: cncc rules: - apiGroups: - policy resources: - podsecuritypolicies verbs: - use resourceNames: - debug-tool-psp EOFRoleBinding Creation
Run the following command to associate the service account for the OCNWDAF namespace with the role created for the PSP:$ kubectl apply -f - <<EOF apiVersion: rbac.authorization.k8s.io/v1 kind: RoleBinding metadata: name: debug-tool-rolebinding namespace: ocnwdaf roleRef: apiGroup: rbac.authorization.k8s.io kind: Role name: debug-tool-role subjects: - kind: Group apiGroup: rbac.authorization.k8s.io name: system:serviceaccounts EOF
- Configuration in NF specific Helm
Following updates must be performed in custom_values.yaml file.
- Log in to the NF server.
- Open the custom_values file:
$ vim <custom_values file> - Under global configuration, add the following:
# Allowed Values: DISABLED, ENABLED # Preference is to set "resources" request and limit to same values to avoid HPA issues. extraContainers: DISABLED debugToolContainerMemoryLimit: 4Gi extraContainersVolumesTpl: | - name: debug-tools-dir emptyDir: medium: Memory sizeLimit: {{ .Values.global.debugToolContainerMemoryLimit | quote }} extraContainersTpl: | - command: - /bin/sleep - infinity image: <image-name>:<image-tag> imagePullPolicy: Always name: tools resources: requests: ephemeral-storage: "512Mi" cpu: "0.5" memory: {{ .Values.global.debugToolContainerMemoryLimit | quote }} limits: ephemeral-storage: "512Mi" cpu: "0.5" memory: {{ .Values.global.debugToolContainerMemoryLimit | quote }} securityContext: allowPrivilegeEscalation: true capabilities: drop: - ALL add: - NET_RAW - NET_ADMIN runAsUser: <user-id> volumeMounts: - mountPath: /tmp/tools name: debug-tools-dirNote:
Debug Tool Container comes up with the default user ID - 7000. If you want to override this default value, use the `runAsUser` field, or else, you can skip the field.
Default value: uid=7000(debugtool) gid=7000(debugtool) groups=7000(debugtool)
- In case you want to customize the container name, replace the `name` field in the above values.yaml with the following:
This will ensure that the container name is prefixed and suffixed with the necessary values.name: {{ printf "%s-tools-%s" (include "getprefix" .) (include "getsuffix" .) | trunc 63 | trimPrefix "-" | trimSuffix "-" }}
- Under service specific configurations for which debugging is required, add the following:
# Allowed Values: DISABLED, ENABLED, USE_GLOBAL_VALUE extraContainers: USE_GLOBAL_VALUENote:
- At the global level,
extraContainersflag can be used to enable or disable injecting extra containers globally. This ensures that all the services that use this global value have extra containers enabled or disabled using a single flag. - At the service level,
extraContainersflag determines whether to use the extra container configuration from the global level or enable or disable injecting extra containers for the specific service.
3.2 Deploy Debug Tool
Following is the procedure to run Debug Tool.
- Run the following command to retrieve the POD details:
$ kubectl get pods -n <k8s namespace>Example:
$ kubectl get pods -n ocnwdaf - Run the following command to enter Debug Tool Container:
$ kubectl exec -it <pod name> -c <debug_container name> -n <namespace> bash - Run the debug tools:
bash -4.2$ <debug_tools>Example:bash -4.2$ tcpdump - Copy the output files from container to host:
$ kubectl cp -c <debug_container name> <pod name>:<file location in container> -n <namespace> <destination location>
3.3 Tools Tested in Debug Container
Following is the list of debugging tools that are tested.
tcpdump
The following table describes the options that are testing using tcpdump tool.
Table 3-1 tcpdump
| Options Tested | Description | Output | Capabilities |
| -D | Print the list of the network interfaces available on the system and on which tcpdump can capture packets. | tcpdump -D
NET_ADMIN, NET_RAW |
| -i | Listen on interface | tcpdump -i eth0tcpdump: verbose output suppressed, use -v or -vv for full protocol decodelistening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes12:10:37.381199 IP cncc-core-ingress-gateway-7ffc49bb7f-2kkhc.46519 > kubernetes.default.svc.cluster.local.https: Flags [P.], seq 1986927241:1986927276, ack 1334332290, win 626, options [nop,nop,TS val 849591834 ecr 849561833], length 3512:10:37.381952 IP cncc-core-ingress-gateway-7ffc49bb7f-2kkhc.45868 > kube-dns.kube-system.svc.cluster.local.domain: 62870+ PTR? 1.0.96.10.in-addr.arpa. (40) |
| -w | Write the raw packets to file rather than parsing and printing them out. | tcpdump -w capture.pcap -i eth0 |
| -r | Read packets from file (which was created with the -w option). | tcpdump -r capture.pcapreading from file /tmp/capture.pcap, link-type EN10MB (Ethernet)12:13:07.381019 IP cncc-core-ingress-gateway-7ffc49bb7f-2kkhc.46519 > kubernetes.default.svc.cluster.local.https: Flags [P.], seq 1986927416:1986927451, ack 1334332445, win 626, options [nop,nop,TS val 849741834 ecr 849711834], length 3512:13:07.381194 IP kubernetes.default.svc.cluster.local.https > cncc-core-ingress-gateway-7ffc49bb7f-2kkhc.46519: Flags [P.], seq 1:32, ack 35, win 247, options [nop,nop,TS val 849741834 ecr 849741834], length 3112:13:07.381207 IP cncc-core-ingress-gateway-7ffc49bb7f-2kkhc.46519 > kubernetes.default.svc.cluster.local.https: Flags [.], ack 32, win 626, options [nop,nop,TS val 849741834 ecr 849741834], length 0 |
ip
The following table describes the options that are testing using ip tool.
Table 3-2 ip
| addr show | Look at protocol addresses. | ip addr show1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group defaultlink/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00inet 127.0.0.1/8 scope host lovalid_lft forever preferred_lft forever2: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group defaultlink/ipip 0.0.0.0 brd 0.0.0.04: eth0@if190: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1440 qdisc noqueue state UP group defaultlink/ether aa:5a:27:8d:74:6f brd ff:ff:ff:ff:ff:ff link-netnsid 0inet 192.168.219.112/32 scope global eth0valid_lft forever preferred_lft forever |
| route show | List routes | ip route showdefault via 169.254.1.1 dev eth0 169.254.1.1 dev eth0 scope link |
| addrlabel list | List address labels | ip addrlabel listprefix ::1/128 label 0 prefix ::/96 label 3 prefix ::ffff:0.0.0.0/96 label 4 prefix 2001::/32 label 6 prefix 2001:10::/28 label 7 prefix 3ffe::/16 label 12 prefix 2002::/16 label 2 prefix fec0::/10 label 11 prefix fc00::/7 label 5 prefix ::/0 label 1 |
netstat
The following table describes the options that are testing using netstat tool.
Table 3-3 netstat
| -a | Show both listening and non-listening (for TCP, this means established connections) sockets. | netstat -aActive Internet connections (servers and established)Proto Recv-Q Send-Q Local Address Foreign Address Statetcp 0 0 0.0.0.0:tproxy 0.0.0.0:* LISTENtcp 0 0 0.0.0.0:websm 0.0.0.0:* LISTENtcp 0 0 cncc-core-ingress:websm 10-178-254-194.ku:47292 TIME_WAITtcp 0 0 cncc-core-ingress:46519 kubernetes.defaul:https ESTABLISHEDtcp 0 0 cncc-core-ingress:websm 10-178-254-194.ku:47240 TIME_WAITtcp 0 0 cncc-core-ingress:websm 10-178-254-194.ku:47347 TIME_WAITudp 0 0 localhost:59351 localhost:ambit-lm ESTABLISHEDActive UNIX domain sockets (servers and established)Proto RefCnt Flags Type State I-Node Pathunix 2 [ ] STREAM CONNECTED 576064861 |
| -l | Show only listening sockets. | netstat -lActive Internet connections (only servers)Proto Recv-Q Send-Q Local Address Foreign Address Statetcp 0 0 0.0.0.0:tproxy 0.0.0.0:* LISTENtcp 0 0 0.0.0.0:websm 0.0.0.0:* LISTENActive UNIX domain sockets (only servers)Proto RefCnt Flags Type State I-Node Path |
| -s | Display summary statistics for each protocol. | netstat -sIp:4070 total packets received0 forwarded0 incoming packets discarded4070 incoming packets delivered4315 requests sent outIcmp:0 ICMP messages received0 input ICMP message failed.ICMP input histogram:2 ICMP messages sent0 ICMP messages failedICMP output histogram:destination unreachable: 2 |
| -i | Display a table of all network interfaces. | netstat -iKernel Interface tableIface MTU RX-OK RX-ERR RX-DRP RX-OVR TX-OK TX-ERR TX-DRP TX-OVR Flgeth0 1440 4131 0 0 0 4355 0 0 0 BMRUlo 65536 0 0 0 0 0 0 0 0 LRU |
curl
The following table describes the options that are testing using curl tool.
Table 3-4 curl
| -o | Write output to <file> instead of stdout. | curl -o file.txt http://abc.com/file.txt |
| -x | Use the specified HTTP proxy. | curl -x proxy.com:8080 -o http://abc.com/file.txt |
ping
The following table describes the options that are testing using ping tool.
Table 3-5 ping
| <ip> | Run a ping test to see whether the target host is reachable or not. | ping 10.178.254.194 |
| -c | Stop after sending 'c' number of ECHO_REQUEST packets. | ping -c 5 10.178.254.194 |
| -f (with non zero interval) | Flood ping. For every ECHO_REQUEST sent, a period ''.'' is printed, while for every ECHO_REPLY received a backspace is printed. | ping -f -i 2 10.178.254.194 |
nmap
The following table describes the options that are testing using nmap tool.
Table 3-6 nmap
| <ip> | Scan for Live hosts, Operating systems, packet filters and open ports running on remote hosts. | nmap 10.178.254.194 |
| -v | Increase verbosity level | nmap -v 10.178.254.194 |
| -iL | Scan all the listed IP addresses in a file. Sample file | nmap -iL sample.txt |
dig
The following table describes the options that are testing using dig tool.
Table 3-7 dig
| <ip> | It performs DNS lookups and displays the answers that are returned from the name server(s) that were queried. | dig 10.178.254.194Note: The IP should be reachable from inside the container. |
| -x | Query DNS Reverse lookup. | dig -x 10.178.254.194 |
3.4 Debug Tool Configuration Parameters
Following are the parameters used to configure debug tool.
CNE Parameters
Table 3-8 CNE Parameters
| Parameter | Description |
| apiVersion | APIVersion defines the version schema of this representation of an object. |
| kind | Kind is a string value representing the REST resource this object represents. |
| metadata | Standard object's metadata. |
| metadata.name | Name must be unique within a namespace. |
| spec | This defines the policy enforced. |
| spec.allowPrivilegeEscalation | Gates whether or not a user is allowed to set the security context of a container to allowPrivilegeEscalation=true. |
| spec.allowedCapabilities | Provides a list of capabilities that are allowed to be added to a container. |
| spec.fsGroup | Controls the supplemental group applied to some volumes. RunAsAny allows any fsGroup ID to be specified. |
| spec.runAsUser | Controls which user ID the containers are run with. RunAsAny allows any runAsUser to be specified. |
| spec.seLinux | RunAsAny allows any seLinuxOptions to be specified. |
| spec.supplementalGroups | Controls which group IDs containers add. RunAsAny allows any supplementalGroups to be specified. |
| spec.volumes | Provides a list of allowed volume types. The allowable values correspond to the volume sources that are defined when creating a volume. |
Role Creation Parameters
Table 3-9 Role Creation
| apiVersion | APIVersion defines the schema version of this representation of an object. |
| metadata.namespace | Namespace defines the space within which each name must be unique. |
| rules | Rules holds all the PolicyRules for this Role |
| apiGroups | APIGroups is the name of the APIGroup that contains the resources. |
| rules.resources | Resources is a list of resources this rule applies to. |
| rules.verbs | Verbs is a list of Verbs that apply to ALL the ResourceKinds and AttributeRestrictions contained in this rule. |
| rules.resourceNames | ResourceNames is an optional allowed list of names that the rule applies to. |
Table 3-10 Role Binding Creation
| apiVersion | APIVersion defines the version of schema of this representation of an object. |
| roleRef | RoleRef can reference a Role in the current namespace or a ClusterRole in the global namespace. |
| roleRef.apiGroup | APIGroup is the group for the resource being referenced |
| roleRef.kind | Kind is the type of resource being referenced |
| roleRef.name | Name is the name of resource being referenced |
| subjects | Subjects holds references to the objects the role applies to. |
| subjects.kind | Kind of object being referenced. Values defined by this API group are "User", "Group", and "ServiceAccount". |
| subjects.apiGroup | APIGroup holds the API group of the referenced subject. |
| subjects.name | Name of the object being referenced. |
Table 3-11 Debug Tool Configuration Parameters
| extraContainers | Specifies the spawns debug container along with application container in the pod. |
| debugToolContainerMemoryLimit | Indicates the memory assigned for the debug tool container. |
| extraContainersVolumesTpl | Specifies the extra container template for the debug tool volume. |
| extraContainersVolumesTpl.name | Indicates the name of the volume for debug tool logs storage. |
| extraContainersVolumesTpl.emptyDir.medium | Indicates the location where emptyDir volume is stored.
| extraContainersVolumesTpl.emptyDir.sizeLimit | Indicates the emptyDir volume size.
| command | String array used for container command. |
| image | Docker image name |
| imagePullPolicy | Image Pull Policy |
| name | Name of the container |
| resources | Compute Resources required by this container |
| resources.limits | Limits describes the maximum amount of compute resources allowed |
| resources.requests | Requests describes the minimum amount of compute resources required |
| resources.limits.cpu | CPU limits |
| resources.limits.memory | Memory limits |
| resources.limits.ephemeral-storage | Ephemeral Storage limits |
| resources.requests.cpu | CPU requests |
| resources.requests.memory | Memory requests |
| resources.requests.ephemeral-storage | Ephemeral Storage requests |
| securityContext | Security options the container should run with. |
| securityContext.allowPrivilegeEscalation | AllowPrivilegeEscalation controls whether a process can gain more privileges than its parent process. This directly controls if the no_new_privs flag will be set on the container process |
| secuirtyContext.readOnlyRootFilesystem | Whether this container has a read-only root filesystem. Default is false. |
| securityContext.capabilities | The capabilities to add or drop when running containers. Defaults to the default set of capabilities granted by the container runtime. |
| securityContext.capabilities.drop | Removed capabilities |
| secuirtyContext.capabilities.add | Added capabilities |
| securityContext.runAsUser | The UID to run the entry point of the container process. |
| volumeMounts.mountPath | Indicates the path for volume mount. |
| volumeMounts.name | Indicates the name of the directory for debug tool logs storage. |
