8 Fault Recovery
This chapter provides information about fault recovery for OCNADD deployment.
8.1 Overview
This section describes procedures to perform the backup and restore for the Oracle Communications Network Analytics Data Director (OCNADD) deployment. The backup and restore procedures will be used in the fault recovery of OCNADD. The OCNADD operators can take only the OCNADD-instance-specific database and required OCNADD Kafka metadata backup and restore them either on the same or a different Kubernetes cluster.
The backup and restore procedures are helpful in the following scenarios:
  • OCNADD fault recovery
  • OCNADD cluster migration
  • OCNADD setup replication from production to development or staging
  • OCNADD cluster upgrade to a new CNE version or K8s version
The OCNADD backup contains the following data:
  • OCNADD database(s) backup
  • OCNADD Kafka metadata backup, including the topics and partitions information
If the deployed Helm charts and the customized custom values for the management, relay agent, and mediation groups for the current deployment are stored in the Helm or artifact repository, then the Helm chart and custom values backup is not required.
To successfully execute backup and restore operations for Kafka metadata, it is essential that the configuration service is operational and running. The absence of a running configuration service prevents Kafka metadata backup and restore from being performed.
Figure 8-1 OCNADD Backup and Restore
OCNADD Database(s) Backup
The OCNADD database consists of the following:
  • Configuration data: This data is exclusive to the given OCNADD instance. Therefore, an exclusive logical database is created and used by an OCNADD instance to store its configuration data and operator-driven configuration. Operators can configure the OCNADD-instance-specific configurations using the Configuration UI service through the Cloud Native Configuration Console.
  • Health monitoring data: This data is also exclusive to the given OCNADD instance. Therefore, an exclusive logical database is created and used by an OCNADD Health Monitoring service instance to store the health profile of various other services.
The database backup job uses the mysqldump utility.
Scheduled regular backups help in:
  • Restoring the stable version of the data directory databases
  • Minimizing significant loss of data due to upgrade or rollback failure
  • Minimizing loss of data due to system failure
  • Minimizing loss of data due to data corruption or deletion due to external input
  • Migration of the database information from one site to another site
OCNADD Kafka Metadata Backup
The OCNADD Kafka metadata backup contains the following information:
  • Created topics information
  • Created partitions per topic information
8.1.1 Fault Recovery Impact Areas
The following table shares information about impact of OCNADD fault recovery scenarios:
Table 8-1 OCNADD Fault Recovery Scenarios Impact Information
Scenario Requires Fault Recovery or Reinstallation of CNE? Requires Fault Recovery or Reinstallation of cnDBTier? Requires Fault Recovery or Reinstallation of Data Director?
Scenario 1: Deployment Failure
Recovering OCNADD when its deployment is corrupted
No No Yes
Scenario 2: cnDBTier Corruption No Yes No
However, it requires to restore the databases from backup and Helm upgrade of the same OCNADD version to update the OCNADD configuration. For example, change in cnDBTier service information, such as cnDB endpoints, DB credentials, and so on.
Scenario 3: Database Corruption
Recovering from corrupted OCNADD configuration database
No No No
However, it requires to restore the databases from old backup.
Scenario 4: Site Failure
Complete site failure due to infrastructure failure, for example, hardware, CNE, and so on.
Yes Yes Yes
8.1.2 Prerequisites
Before you run any fault recovery procedure, ensure that the following prerequisites are met:
  • cnDBTier must be in a healthy state and available on a new or newly installed site where the restore needs to be performed.
  • Do not change DB Secret or cnDBTier MySQL FQDN or IP or PORT configurations during backup and restore.
  • Automatic backup should be enabled for OCNADD.
  • Docker images used during the last installation or upgrade must be retained in the external data storage or repository.
  • The management, relay agent, and mediation group custom values file used at the time of the OCNADD deployment must be retained. If the custom values files are not retained, they must be recreated manually. This task increases the overall fault recovery time.
8.2 Backup and Restore Flow
Important:
  • It is recommended to keep the backup storage in the external storage that can be shared between different clusters. This is required, so that in an event of a fault, the backup is accessible on the other clusters. The backup job should create a PV or PVC from the external storage provided for the backup.
  • In case the external storage is not made available for the backup storage, the customer should take care to copy the backups from the associated backup PV in the cluster to the external storage. The security and connectivity to the external storage should be managed by the customer. To copy the backup from the backup PV to the external server, follow Verifying OCNADD Backup.
  • The restore job should have access to the external storage so that the backup from the external storage can be used for the restoration of the OCNADD services. In case the external storage is not available, the backup should be copied from the external storage to the backup PV in the new cluster. For information on the procedure, see Verifying OCNADD Backup.
  • In case of two site redundancy feature is enabled then respective site backup should be used to restore the site during failure recovery.
At a time, only one of the three backup jobs (ocnaddmanualbackup, ocnaddverify, or ocnaddrestore) can be running. If any existing backup job is running, that job needs to be deleted to spawn the new job.
kubectl delete job.batch/<ocnadd*> -n <namespace>
where,
  • namespace = Namespace of OCNADD deployment
  • ocnadd* = Running jobs in the namespace (ocnaddmanualbackup, ocnaddverify, or ocnaddrestore)
Example:
kubectl delete job.batch/ocnaddverify -n ocnadd-deploy
Backup
  1. The OCNADD backup is managed using the backup job created at the time of installation. The backup job runs as a cron job and takes the daily backup of the following:
    • OCNADD databases for configuration, alarms, and health monitoring
    • OCNADD Kafka metadata including topics and partitions, which are previously created
  2. The automated backup job spawns as a container and takes the backup at the scheduled time. The backup file OCNADD_Backup_DD-MM-YYYY_hh-mm-ss.tar.bz2 is created and stored in the PV mounted on the path /work-dir/backup by the backup container.
  3. On-demand backup can also be created by creating the backup container. For more information, see Performing OCNADD Manual Backup.
  4. The backup can be stored on external storage.
Restore
  1. The OCNADD restore job must have access to the backups from the backup PV/PVC.
  2. The restore uses the latest backup file available in the backup storage if the BACKUP_FILE argument is not given.
  3. The restore job performs the restore in the following order:
    1. Restore the OCNADD database(s) on the cnDBTier.
    2. Restore the Kafka metadata.
8.3 OCNADD Backup
The OCNADD backup is of two types:
  • Automated backup
  • Manual backup
Automated Backup
  • This is managed by the automated K8s job configured during the installation of the OCNADD. For more information, see Updating the OCNADD Backup Cronjob step.
  • It is a scheduled job and runs daily at the configured time to collect the OCNADD backup and creates the backup file OCNADD_Backup_DD-MM-YYYY_hh-mm-ss.tar.bz2.
Manual Backup
8.4 Performing OCNADD Backup Procedures
8.4.1 Performing OCNADD Manual Backup
Perform the following steps to take the manual backup:
  1. Go to the custom_templates folder in the extracted OCNADD release package and update the ocnadd_manualBackup.yaml file, or the ocnadd_manualBackup_occm.yaml file if OCCM is used, with the following information:
    1. Value for BACKUP_DATABASES can be set to ALL (that is, configuration_schema and healthdb_schema), or the individual DB names can also be passed. By default, the value is ALL.
    2. Value of BACKUP_ARG can be set to ALL, DB, or KAFKA. By default, the value is ALL.
    3. Update other values as follows:
      apiVersion: batch/v1
      kind: Job
      metadata:
         namespace: ocnadd-mgmt          #---> update the management namespace
      spec:
             serviceAccountName: ocnadd-mgmt-sa-ocnadd  #---> update the service account name. Format:<serviceAccount>-sa-ocnadd
             containers:
             - name: ocnaddmanualbackup
             image: <repo-path>/ocdd.repo/ocnaddbackuprestore:2.0.9 #---> update repository path
             initContainers:
             - name: ocnaddinitcontainer
             image: <repo-path>/utils.repo/jdk21-openssl:1.0.9 #---> update repository path
             env:
               - name: BACKUP_DATABASES
                 value: ALL
               - name: BACKUP_ARG
                 value: ALL
      If (1) Single Certs for each component is selected as the certificate generation process, run the below commands:
      1. When generate_certs.sh is used:
        sed -i 's/ocnaddbackuprestore-secret/ocnadd-secret/g' ocnadd_manualBackup.yaml
        sed -i 's/ocnaddbackuprestore-servercert/ocnadd-servercert/g' ocnadd_manualBackup.yaml
        sed -i 's/ocnaddbackuprestore-serverprivatekey/ocnadd-serverprivatekey/g' ocnadd_manualBackup.yaml
      2. When OCCM is used:
        sed -i 's/ocnaddbackuprestore-secret/ocnadd-secret/g' ocnadd_manualBackup_occm.yaml
        sed -i 's/ocnaddbackuprestore-servercert/ocnadd-servercert/g' ocnadd_manualBackup_occm.yaml
  2. Run the following command to run the job:
    kubectl create -f ocnadd_manualBackup.yaml
    OR, if OCCM is used:
    kubectl create -f ocnadd_manualBackup_occm.yaml
8.4.2 Verifying OCNADD Backup
Caution:
The connectivity between the external storage through either PV/PVC or network connectivity must be ensured.
To verify the backup, perform the following steps:
  1. Go to the custom_templates folder in the extracted OCNADD release package and update the ocnadd_verify_backup.yaml file, or the ocnadd_verify_backup_occm.yaml file if OCCM is used, with the following information:
    1. Sleep time is configurable, update it if required (the default value is set to 10m).
    2. Update other values as follows:
      kind: Job
      metadata:
      spec:
            serviceAccountName: ocnadd-mgmt-sa-ocnadd       -                 #---> update the service account name. Format:<serviceAccount>-sa-ocnadd
            containers:
            - name: ocnaddverify
            initContainers:
      sed -i 's/ocnaddbackuprestore-secret/ocnadd-secret/g' ocnadd_verify_backup.yaml
      sed -i 's/ocnaddbackuprestore-servercert/ocnadd-servercert/g' ocnadd_verify_backup.yaml
      sed -i 's/ocnaddbackuprestore-secret/ocnadd-secret/g' ocnadd_verify_backup_occm.yaml
      sed -i 's/ocnaddbackuprestore-servercert/ocnadd-servercert/g' ocnadd_verify_backup_occm.yaml
      sed -i 's/ocnaddbackuprestore-serverprivatekey/ocnadd-serverprivatekey/g' ocnadd_verify_backup_occm.yaml
  2. Run the below command to create the job:
    kubectl create -f ocnadd_verify_backup.yaml
    Or, use the following command if OCCM is used:
    kubectl create -f ocnadd_verify_backup_occm.yaml
  3. If the external storage is used as PV/PVC, then enter the ocnaddverify-xxxx container using the following commands:
    1. kubectl exec -it <ocnaddverify-xxxx> -n <ocnadd namespace> -- bash
    2. Change the directory to /work-dir/backup and inside the latest backup file OCNADD_BACKUP_DD-MM-YYYY_hh-mm-ss.tar.bz2, verify the DB backup and Kafka metadata backup files.
8.4.3 Retrieving the OCNADD Backup Files
  1. Run the Verifying OCNADD Backup procedure to spawn the ocnaddverify-xxxx.
  2. Go to the running ocnaddverify pod to identify and retrieve the desired backup folder using the following commands:
    1. Run the following command to access the pod:
      kubectl exec -it <ocnaddverify-xxxx> -n <ocandd-namespace> -- bash
      where,
      <ocnadd-namespace> is the namespace where the ocnadd management group services are running.
      <ocnaddverify-xxxx> is the backup verification pod in the same namespace.
    2. Change the directory to /work-dir/backup and identify the backup file "OCNADD_BACKUP_DD-MM-YYYY_hh-mm-ss.tar.bz2".
    3. Exit the ocnaddverify pod.
  3. Copy the backup file from the pod to the local bastion server by copying the file OCNADD_BACKUP_DD-MM-YYYY_hh-mm-ss.tar.bz2, and run the following command:
    kubectl cp -n <ocnadd-namespace> <ocnaddverify-xxxx>:/work-dir/backup/<OCNADD_Backup_DD-MM-YYYY_hh-mm-ss.tar.bz2> <OCNADD_Backup_DD-MM-YYYY_hh-mm-ss.tar.bz2>
    where,
    For example:
    kubectl cp -n ocnadd-mgmt ocnaddverify-drwzq:/work-dir/backup/OCNADD_BACKUP_10-05-2023_08-00-05.tar.bz2 OCNADD_BACKUP_10-05-2023_08-00-05.tar.bz2
8.4.4 Copying and Restoring the OCNADD backup
  1. Retrieve the OCNADD backup file.
  2. Perform the Verifying OCNADD Backup procedure to spawn the ocnaddverify-xxxx.
  3. Copy the backup file from the local bastion server to the running ocnaddverify pod, run the following command:
    kubectl cp <OCNADD_Backup_DD-MM-YYYY_hh-mm-ss.tar.bz2> <ocnaddverify-xxxx>:/work-dir/backup/<OCNADD_Backup_DD-MM-YYYY_hh-mm-ss.tar.bz2> -n <management-group-namespace>
    For example:
    kubectl cp OCNADD_BACKUP_10-05-2023_08-00-05.tar.bz2 ocnaddverify-mrdxn:/work-dir/backup/OCNADD_BACKUP_10-05-2023_08-00-05.tar.bz2 -n ocnadd-mgmt
  4. Go to ocnaddverify pod and path, /workdir/backup/OCNADD_BACKUP_DD-MM-YYYY_hh-mm-ss.tar.bz2 to verify if the backup has been copied.
  5. Restore OCNADD using the procedure defined in Creating OCNADD Restore Job.
8.5 Fault Recovery Scenarios
This chapter describes the fault recovery procedures for different recovery scenarios.
8.5.1 Scenario 1: Deployment Failure
This section describes how to recover OCNADD when the OCNADD deployment corrupts.
For more information, see Restoring OCNADD.
8.5.2 Scenario 2: cnDBTier Corruption
This section describes how to recover the cnDBTier corruption. For more information, see Oracle Communications Cloud Native Core cnDBTier Installation, Upgrade, and Fault Recovery Guide. After the cnDBTier recovery, restore the OCNADD database from the previous backup.
To restore the OCNADD database, execute the procedure Creating OCNADD Restore Job by setting BACKUP_ARG to DB.
8.5.3 Scenario 3: Database Corruption
This section describes how to recover from the corrupted OCNADD database.
Perform the following steps to recover the OCNADD configuration database (DB) from the corrupted database:
  1. Retain the working ocnadd backup by following Retrieving the OCNADD Backup Files procedure.
  2. Drop the existing Databases by accessing the MySql DB.
  3. Perform the Copying and Restoring the OCNADD backup procedure to restore the backup.
8.5.4 Scenario 4: Site Failure
This section describes how to perform fault recovery when the OCNADD site has software failure.
Perform the following steps in case of a complete site failure:
  1. Run the Cloud Native Environment (CNE) installation procedure to install a new Kubernetes cluster. For more information, see Oracle Communications Cloud Native Environment Installation, Upgrade, and Fault Recovery Guide.
  2. Run the cnDBTier installation procedure. For more information, see Oracle Communications Cloud Native Core cnDBTier Installation, Upgrade, and Fault Recovery Guide.
  3. For cnDBTier fault recovery, take a data backup from an older site and restore it to a new site. For more information about cnDBTier backup, see "Create On-demand Database Backup" and to restore the database to a new site, see "Restore DB with Backup" in Oracle Communications Cloud Native Core cnDBTier Installation, Upgrade, and Fault Recovery Guide.
  4. Restore OCNADD. For more information, see Restoring OCNADD.
8.6 Restoring OCNADD
Perform this procedure to restore OCNADD when a fault event has occurred or deployment is corrupted.
This procedure expects the OCNADD backup folder is retained.
  1. Get the retained backup file "OCNADD_BACKUP_DD-MM-YYYY_hh-mm-ss.tar.bz2".
  2. Get the Helm charts that was used in the earlier deployment.
  3. Run the following command to uninstall the corrupted OCNADD deployment: Management Group or Worker Group (Relay Agent or Mediation):
    helm uninstall <release_name> --namespace <namespace>
    Where,
    <release_name> is the release name of the ocnadd deployment which is being uninstalled.
    <namespace> is the namespace of OCNADD deployment which is being uninstalled.
    For example: To uninstall the Management Group
    helm  uninstall ocnadd-mgmt --namespace dd-mgmt-group
  4. Install the Management Group or Worker Group (Relay Agent or Mediation) that was corrupted and uninstalled in the previous step using the helm charts that were used in the earlier deployment. For the installation procedure see, Installing OCNADD.
  5. To verify whether OCNADD installation is complete, see Verifying OCNADD Installation.
  6. Follow procedure Copying and Restoring the OCNADD backup
8.7 Creating OCNADD Restore Job
Follow the below steps to create and run OCNADD restore job:
  1. Restore the OCNADD database by following below steps:
    1. Go to the custom_templates folder inside the extracted ocnadd-release package and update the ocnadd_restore.yaml or the ocnadd_restore_occm.yaml file if OCCM is used, with the following information:
      1. The value of BACKUP_ARG can be set to DB, KAFKA, and ALL. By default, the value is 'ALL'.
      2. The value of BACKUP_FILE can be set to folder name which needs to be restored, if not mentioned the latest backup will be used.
      3. Update other values as below:
        kind: Job
        metadata:
        spec:
              containers:
              - name: ocnaddrestore
              initContainers:
              env:
                  - name: BACKUP_ARG
                    value: ALL
                  - name: BACKUP_FILE
                    value: "" #---> update the backup file name which needs to be restored, if not mentioned the latest backup will be used for example "OCNADD_Backup_DD-MM-YYYY_hh-mm-ss.tar.bz2"
        sed -i 's/ocnaddbackuprestore-secret/ocnadd-secret/g' ocnadd_restore.yaml
        sed -i 's/ocnaddbackuprestore-servercert/ocnadd-servercert/g' ocnadd_restore.yaml
        sed -i 's/ocnaddbackuprestore-serverprivatekey/ocnadd-serverprivatekey/g' ocnadd_restore.yaml
        sed -i 's/ocnaddbackuprestore-secret/ocnadd-secret/g' ocnadd_restore_occm.yaml
        sed -i 's/ocnaddbackuprestore-servercert/ocnadd-servercert/g' ocnadd_restore_occm.yaml
        sed -i 's/ocnaddbackuprestore-serverprivatekey/ocnadd-serverprivatekey/g' ocnadd_restore_occm.yaml
  2. Run the following command to run the restore job:
    kubectl create -f ocnadd_restore.yaml
    kubectl create -f ocnadd_restore_occm.yaml
    Make sure to delete all the backup, restore, and verify jobs before creating the restore job. Related jobs are ocnaddbackup, ocnaddrestore, ocnaddverify, and ocnaddmanualbackup.
  3. Wait for the restore job to be completed. It usually takes 10 to 15 minutes or more depending upon the size of the backup.
  4. To restart the Redundancy Agent pods post OCNADD Restore, see Two-Site Redundancy Fault Recovery.
  5. Perform the rollout restart for the deployments in management group and all the available worker groups (relay agent and mediation) in the provided order:
    1. Perform rollout restart for management group
      kubectl rollout restart deployment -n <mgmt-grp-namespace>
    2. Perform rollout restart for relay agent group
      kubectl rollout restart deployment -n <relay-agent-grp-namespace>
    3. Perform rollout restart for all mediation group(s) one after the other
      kubectl rollout restart deployment -n <mediation-grp-namespace>
If the backup is not available for the mentioned date, the pod will be in an error state, notifying the backup is not available for the given date: $DATE. In such case, provide the correct backup dates and repeat the procedure.
8.8 Configuring Backup and Restore Parameters
To configure backup and restore parameters, configure the parameters listed in the following table:
Table 8-2 Backup and Restore Parameters
Parameter Name Data Type Range Default Value Mandatory(M)/Optional(O)/Conditional(C) Description
BACKUP_STORAGE STRING - 20Gi M Persistent Volume storage to keep the OCNADD backups
BACKUP_CRONEXPRESSION STRING - 0 8 * * * M Cron expression to schedule backup cronjob
BACKUP_ARG STRING - ALL M KAFKA, DB, or ALL backup
BACKUP_DATABASES STRING - ALL M Individual databases or all databases backup that need to be taken
PURGE_DAYS INTEGER - 7 M The number of days after which the backup file will be purged
8.9 Two-Site Redundancy Fault Recovery
This section describes how to perform fault recovery of the OCNADD sites with Two-Site Redundancy enabled.
Scenario 1: When DB backup is available for both sites
  1. Follow the generic recovery procedure based on the failure scenarios described in the section "Fault Recovery."
  2. Use the respective site's backup during the restore procedure.
  3. Once the recovery is completed, restart the Redundancy Agent pods of the Primary site and the Secondary site.
Scenario 2: When DB backup is not available on one of the mated sites
  1. Access any one of the pods of the working site and run the below curl command to delete Redundancy Configuration:
    • kubectl exec -it -n <namespace> <pod> -- bash
      For example:
      kubectl exec -it -n ocnadd-deploy ocnaddmanagementgateway-xxxx -- bash
    • curl -k --cert-type P12 --cert /var/securityfiles/keystore/serverKeyStore.p12:$OCNADD_SERVER_KS_PASSWORD --location -X DELETE 'https://ocnaddconfiguration:12590/ocnadd-configuration/v1/tsr-configure/<workergroup name>?sync=false'
      Where,
      <workergroup-name> is the logical name of the worker group. For example, wg1.
  2. Follow the generic recovery procedure based on the failure scenarios described in the section Fault Recovery Scenarios.
  3. Once the recovery is completed, restart the Redundancy Agent pods first on the Primary site, then on the Secondary site.
  4. Re-create the Redundancy Configuration from the Primary UI.
If the DB was lost on the Primary site and the user wants the Secondary site configuration to be restored on the Primary site, then set the Way to Bidirectional while creating the Redundancy Configuration.
