5 Working with the POMS SDK
This chapter provides information about how the persistent object modeling service (POMS) manages persistent data in Oracle Communications Network Integrity.
About POMS
POMS manages all persisted data for Network Integrity. You use POMS for most cartridge development, but you rarely need to deal explicitly with persistence details.
POMS includes the Java definition of the entities and relationships described in Oracle Communications Information Model Reference.
While POMS includes both interface and implementation classes for the entities, you work only with interfaces. These interfaces provide getters and setters for attributes and relationships. Use the PersistenceHelper POMS SDK class to instantiate entities.
You can use the POMS SDK Finder class to find and retrieve existing persisted entities.
POMS is built on the EclipseLink Java persistence API (JPA) platform. You do not usually need to know EclipseLink or JPA to use the POMS SDK. The exception is find operations where you may have to know Java Persistence Query Language (JPQL). See "Working with the POMS Finder" for more information about the find operations.
Table 5-1 describes the POMS SDK APIs.
Table 5-1 POMS SDK API Description
| POMS SDK APIs | Description |
Entities |
The POMS SDK represents modelled entities as Java interfaces with getters and setters for attributes and relationships. See "Working with POMS Relationships". |
Specifications and characteristics |
The POMS SDK includes APIs that allow you to operate on specifications and characteristics. See "Working with Specifications and Characteristics". |
PersistenceHelper |
The POMS SDK provides methods to instantiate a POMS entity or POMS Finder. See "Working with POMS Entities" and "POMS SDK Interfaces". |
Finder |
The POMS SDK provides various methods to define a query and retrieve matching persisted entities. See "Working with the POMS Finder" and "POMS SDK Interfaces". |
The POMS Java interface for an entity has the same name as the entity described in the model document. For example, entity Equipment becomes:
public interface Equipment
Attributes are accessed with familiar Java getters and setters. For example. The Equipment name attribute is defined by:
public java.lang.String getName(); public void setName( java.lang.String name );
An entity may contain enumerated values for certain attributes. POMS implements these as Java enumerations. For example, the EMSServiceState from LogicalDevice has the following:
public enum EMSServiceState {
UNKNOWN( "UNKNOWN" ),
IN_SERVICE( "IN_SERVICE" ),
OUT_OF_SERVICE( "OUT_OF_SERVICE" ),
TESTING( "TESTING" ),
IN_MAINTENANCE( "IN_MAINTENANCE" );
public oracle.communications.inventory.api.entity.EMSServiceState getNativeEmsServiceState();
public void setNativeEmsServiceState( oracle.communications.inventory.api.entity.EMSServiceState nativeEmsServiceState );
When creating results, for example in a discovery processor, you must instantiate POMS entities. Use the PersistenceHelper class, passing the desired entity class to the makeEntity method:
Equipment equipment = PersistenceHelper.makeEntity(Equipment.class);
Related entities are also accessed with getters and setters.
One-to-one Relationships
When a relationship refers to a single entity, the entity is accessed directly. For example, the mapped physical and logical devices:
public oracle.communications.inventory.api.entity.LogicalDevice getMappedLogicalDevice(); public void setMappedLogicalDevice( oracle.communications.inventory.api.entity.LogicalDevice mappedLogicalDevice );
One-to-Many or Many-to-Many Relationships
When a relationship refers to multiple entities, the entities are accessed through a collection. For example, the equipment to physical port relationship:
public java.util.List<oracle.communications.inventory.api.entity.PhysicalPort> getPhysicalPorts(); public void setPhysicalPorts( java.util.List<oracle.communications.inventory.api.entity.PhysicalPort> physicalPorts );
A getter never returns null for the collection. If there are no related entities, an empty collection is returned. That means the developer can safely add entities without creating a collection. For example:
equipment.getPhysicalPorts().add(physicalPort);
Ordered and Unordered Relationships
POMS uses a List for the collection because the Oracle Communications Information Model defines an ordered relationship for physical ports on equipment. In other cases, order does not matter and so POMS uses a Set for the collection. For example, the parent relationship from Equipment to EquipmentHolder:
public java.util.Set<oracle.communications.inventory.api.entity.EquipmentHolderEquipmentRel> getParentEquipmentHolders(); public void setParentEquipmentHolders(java.util.Set<oracle.communications.inventory.api.entity.EquipmentHolderEquipmentRel> equipmentHolders);
Bi-directional Relationships
Certain relationships in the model are bi-directional. POMS includes accessors on entities on both sides of a bi-directional relationship, and the relationship can be set from either side. The physical device to logical device relationship described in the "One-to-one Relationships" example is bi-directional. The other side of this relationship, on the logical device, is defined as:
public java.util.List<oracle.communications.inventory.api.entity.PhysicalDevice> getMappedPhysicalDevices(); public void setMappedPhysicalDevices( java.util.List<oracle.communications.inventory.api.entity.PhysicalDevice> mappedPhysicalDevices );
This is a many-to-one relationship, so there is a collection on the logical device side and single entity on the physical device side. To relate a physical and logical device, you can either set from the physical device:
physicalDevice.setMappedLogicalDevice(logicalDevice);
or set from the logical device:
logicalDevice.getMappedPhysicalDevices ().add(physicalDevice);
Relationship Entities
In some cases, the model defines an intermediate relationship entity instead of relating two entities directly. For example, the Information Model defines EquipmentEquipmentRel to relate two pieces of equipment. To create this type of relationship, instantiate the relationship entity and set the related entities. For the equipment to equipment example:
EquipmentEquipmentRel parentEquipmentRel = PersistenceHelper.makeEntity(EquipmentEquipmentRel.class); parentEquipmentRel.setChildEquipment(equipment); parentEquipmentRel.setParentEquipment(parentEquipment);
You can use the generated specification helper classes to avoid directly dealing with specifications and characteristics. See "About Specifications" and "Working with Specifications" for a description of the underlying API and for more information on when to directly manipulate specifications.
You can determine if an entity supports characteristics and specification by referencing the model documentation, or by checking the POMS interface. Entities that support characteristics and specifications extend the CharacteristicExtensible interface. For example:
oracle.communications.inventory.api.CharacteristicExtensible <oracle.communications.inventory.api.entity.EquipmentCharacteristic>;
The specification and characteristics are related entities like any other, characteristics being multi-valued:
public oracle.communications.inventory.api.entity.EquipmentSpecification getSpecification(); public void setSpecification( oracle.communications.inventory.api.entity.EquipmentSpecification specification ); public java.util.Set<oracle.communications.inventory.api.entity.EquipmentCharacteristic> getCharacteristics(); public void setCharacteristics( java.util.Set<oracle.communications.inventory.api.entity.EquipmentCharacteristic> characteristics );
As a convenience, POMS also lets you access a characteristic by name through the map returned by getCharacteristicMap:
public java.util.Map<String, oracle.communications.inventory.api.entity.EquipmentCharacteristic> getCharacteristicMap();
You can use the POMS Finder to retrieve previously persisted data, however, you do not typically need to use the Finder.
The most basic use of the Finders is "Find by Entity". More powerful and flexible queries are possible with the Java Persistence Query Language (JPQL). You can also control whether entities are returned completely or a with a subset of attributes. You can also use paging to return data in manageable chunks where queries might return a large volume of data.
Find by Entity
To find entities matching an example entity, instantiate an entity of the appropriate type and set one or more attributes. Use the findByEntity method to return a collection of matching entities. Here is an example that looks for the specification for a Cisco 3640 physical device:
Finder finder = PersistenceHelper.makeFinder();
PhysicalDeviceSpecification example =
PersistenceHelper.makeEntity(PhysicalDeviceSpecification.class);
example.setName("Cisco3640");
Collection<PhysicalDeviceSpecification> specifications =
finder.findByEntity(example, "name");
if (specifications.size() == 1) {
System.out.println("found specification");
}Find by JPQL
Java Persistence Query Language (JPQL) is a powerful way to express queries. The following examples can be understood without knowing JPQL, especially if the developer is familiar with SQL; however, you must learn JPQL to build their own queries.
For an introduction to JPQL, use the following link:
http://download.oracle.com/javaee/6/tutorial/doc/bnbtg.html.
To perform a JPQL query use the following workflow:
Instantiate a Finder.
Initialize any parameters (these parameters are bound to variables in the JPQL expression).
Specify the desired result type.
Use the findByJPQL method to return matching results.
In following example queries, the first is equivalent to the example in the "Find by Entity" section and returns a particular specification. The second uses a join in the JPQL expression to return all physical devices that use this specification.
finder.addParameter("name", "Cisco3640");
finder.setRsultClass(PhysicalDeviceSpecification.class);
Collection< PhysicalDeviceSpecification> specifications = finder.findByJPQL(
"SELECT o FROM PhysicalDeviceSpecification o " +
"WHERE o.name = :name");
finder.setRsultClass(PhysicalDevice.class);
Collection< PhysicalDevice> cisco3640Devices = finder.findByJPQL(
"SELECT o FROM PhysicalDevice o JOIN o.specification s " +
"WHERE s.name = :name");
A JPQL query does not need to return complete entities. It can return one or more attributes from matched entities. To return only name and ID from a physical device, the developer would modify the previous example as follows:
Collection cisco3640Devices = finder.findByJPQL(
"SELECT o.name,o.id FROM PhysicalDevice o JOIN o.specification s WHERE s.name = :name");
for (Oject device : cisco3640Devices) {
Object[] attributes = (cisco3640DevicesObject[]) device;
System.out.println("Found Cisco 3640 named " + attributes[0] + " with id " +
attributes[1]);
The code snippet also shows how to iterate over the results. Since the returned type is not a POMS entity, the attribute values are available as Object arrays. You would not set the result class in this case.
While JPQL and the Finder support operations that modify persisted data (update, delete, and so on), you should never modify POMS data with JPQL. The Finder is intended only for read operations.
Find with Paged Results
When working with a large number of entities, process them in smaller batches to reduce memory usage. The Finder supports paged results. Initialize the Finder normally, then specify the range of value to retrieve. This modifies the original physical device example to page through devices 20 at a time:
int pageSize = 20;
int start = 0;
while (true) {
finder.setRange(start, start + pageSize - 1);
Collection<Physicaldevice> cisco3640Devices = finder.findByJPQL(
"SELECT o FROM PhysicalDevice o JOIN o.specification s WHERE s.name = :name");
for (PhysicalDevice device : cisco3640Devices) {
System.out.println(device.getName());
if (cisco3640Devices.size()) < pageSize) {
break;
start += pageSize;
}POMS SDK Interfaces
The following are the PersistenceHelper API methods:
public static < E extends Object > E makeEntity( Class< E > entity ); public static oracle.communications.platform.persistence.Finder makeFinder( ) ;
The following are the Finder API methods:
* Set the result Class to query.
* @param resultClass
* the interface of each result in the result set
public void setResultClass(Class resultClass);
* Set the range of the result set to return, starting of the zero-based
* start index and ending at the end index, exclusive. For example,
* setRange(0,5) returns 5 results indexed at 0 thru 4.
* <p>
* Setting the range is meaningless if the order of the results is not
* consistent. setOrdering is assumed.
* @param start
* zero-based start index
* @param end
* ending index, exclusive
* @see javax.jdo.Query#setRange
public void setRange(long start, long end);
* Add the parameter name and value that are used to define the filter.
* <p>
* Parameter names beginning with an underscore ('_') are illegal. They may
* conflict with additional parameters used internally by this Finder.
* @param names
* the parameter name to be declared
* @param param
* the parameter value to be bound to the query
* @throws java.lang.IllegalArgumentException
* if illegal parameters are passed
public void addParameter(String name, Object param);
* Find entities by example.
* Any non-null attributes in the example entity is used as the search criteria, however
* the attribute names in the mustUseAttributes argument are used as criteria if the
* attribute is null.
* <p>
* This is a convenience method that performs a simple query in one call.
* Incremental query construction is not over-written by calling this
* method.
* @param entity
* the example entity which non-null attributes are used as the search criteria.
* @param attributes
* list of attribute names which must be used as search criteria even if their values
* in the example entity are null.
* @param <E>
* a oracle.communications.platform.persistence.Persistent type
* @return Collection of results of the matching entities
public < E extends Persistent > Collection< E > findByEntity( E entity, String ... mustUseAttributes );
* This method returns the result of executing a JPQL search using the passed expression.
* The caller can pass the query parameter with {@link #addParameter(Integer, Object) addParameter} or
* {@link #addParameter(String, Object) addParameter}.
* @param jpql The JPQL
* @return Collection of search results
public Collection findByJPQL(String jpql);About Persist Results
The persistResults method is available in the context of discovery, import and assimilation scan action types. This method persists in-memory result entities to the database and invalidates the entities. You may or may not need to explicitly call this method, depending on the sort of results that your action produces for a given invocation.
If the result set is small (for example, one result group for a particular device), then there is no need to call this method. Your result entities are automatically persisted when the action completes.
If the result set is large (for example multiple devices imported from an inventory system), call persistResults to write the information to the database, reducing memory consumption. In the context of an import action, you would likely want to call the persistResults after results for each device are modeled.
Since persistResults invalidates any in-memory entities, you should not hold a reference to any result entity across a call to persist results.
