5 About Design Studio Construction
This chapter provides information on using Oracle Communications Design Studio to construct for the Oracle Communications Network Integrity MIB-II SNMP cartridge.
Model Collection
Table 5-1 shows the model collection for the MIB-II SNMP cartridge.
Table 5-1 MIB-II Model Collection
| Specification | Notes |
deviceGeneric |
Intended to represent any root object discovered on the network |
interfaceGeneric |
Intended to represent any interface discovered under deviceGeneric |
GenericMedia |
Intended to represent IpAddresses that are applied to a interfaceGeneric |
IPAddresses |
Container of IP addresses |
IPAddress |
Container of IP address details |
Specification Lineage
This section outlines the specification lineage.
deviceGeneric
[0..*] interfaceGeneric
[0..1] GenericMedia
[0..1] IP Addresses
[0..*] IpAddress
IpAddress (characteristic)
P refix (characteristic)
IpVersion (characteristic)Discovery Action
Table 5-2 shows the discovery action for the MIB-II SNMP cartridge.
Table 5-2 Discover MIB-II SNMP Action
| Result Category | Address Handler | Scan Parameters | Model | Processors |
Device |
IPAddressHandler |
MIB-II Model |
Figure 5-1 depicts the Discover MIB-II SNMP action chain.
Figure 5-1 Discover MIB-II SNMP Action Chain
Description of "Figure 5-1 Discover MIB-II SNMP Action Chain"
Discovery Processors
Table 5-3 shows the discovery processors for the MIB-II SNMP cartridge.
Table 5-3 Discovery Processors
| Processor Name | Variable |
MIB-II Properties Initializer |
Input: N/A Output:
MIB-II SNMP Collector |
Input: N/A Output:
MIB-II SNMP Modeler |
Input: mibiisnmpCollectorResponseDocument, snmpIfTypeMap Output:
The MIB-II SNMP Collector polling the SNMP variables implicitly outputs this data in mibiisnmpCollectorResponseDocument. This output field is not seen explicitly in Design Studio. This document is available to the MIB-II SNMP Modeler processor.
Property File Sample
Table 5-4 shows a sample of the property files being loaded by the MIB-II Properties Initializer.
Table 5-4 Sample Property Files Loaded by MIB-II Properties Initializer
| Sample snmpIfTypeMap | Sample snmpVendorNameMap |
1: other (1) |
0 = Reserved |
2: regular1822 (2) |
1 = NxNetworks |
3: hdh1822 (3) |
2 = IBM |
4: ddnX25 (4) |
3 = Carnegie Mellon |
5: rfc877x25 (5) |
4 = UNIX |
6: ethernetCsmacd (6) |
5 = ACC |
7: iso88023Csmacd (7) |
6 = TWG |
8: iso88024TokenBus (8) |
7 = CAYMAN |
9: iso88025TokenRing (9) |
8 = PSI |
10: iso88026Man (10) |
9 = ciscoSystems |
251: vdsl2 (251) |
34730 = FRANCILIENNE D'INGENIERIE ET DE SERVICES INFORMATIQUES SAS |
The snmpVendorNameMap is not used in this cartridge but is initialized for extension cartridges to make use of this map.
