3 Using the Cartridge
This chapter explains how to use the Oracle Communications Network Integrity Optical TMF814 CORBA cartridge.
Creating a Discover TMF814 Scan
The Optical TMF814 CORBA cartridge allows you to create a Discover TMF814 scan.
To create a Discover TMF814 scan:
Create a scan, as explained in the Network Integrity Help.
On the General tab, do the following:
From the Scan Action list, select one of the following:
To discover entities from a generic TMF814 element or network management system, select Discover TMF814.
To discover entities from a Huawei U2000, select Discover Huawei U2000.
The Scan Type field displays
Discovery. -
Enter the following TMF814 scan action parameters:
In the Username field, enter the username for the target element or network management system (EMS or NMS).
In the Password field, enter the password for the target EMS or NMS.
In the EMS Naming Service field, enter the EMS session factory CORBA object name.
From the EMS Naming Service Format list, specify whether the EMS session factory CORBA object name uses the Plain or the Stringified format.
From the Collect Equipment list, specify whether you want to collect equipment holder objects.
From the Collect Termination Points list, specify the type of termination points (TPs) you want to collect. To not collect any TPs, select None.
From the Collect Connection TP list, specify the type of connection TPs you want to collect. To not collect any connection TPs, select None.
(Optional) To set the number of equipment objects to retrieve with each EMS call, enter a value in the Equipment Fetch Size field. Leave this field blank to retrieve all equipment objects in a single EMS call.
(Optional) To set the number of TPs to retrieve with each EMS call, enter a value in the Termination Point Fetch Size field. Leave this field blank to retrieve all TPs in a single EMS call.
(Optional) To set the depth to which contained TPs are collected, enter a value in the Contained TP Collection Depth field. Leave this field blank to retrieve all contained TPs.
(Optional) To pass custom object request broker (ORB) properties to the Discover Abstract TMF814 action, enter name value pairs in the ORB Properties field, separated by a semicolon, as in the following example:
Property_1=value_1;Property_2=value_2;Property_n=value_n
(Optional) To pass custom ORB arguments to the Discover Abstract TMF814 action, enter name-value pairs in the ORB Arguments field, separated by a semicolon, as in the following example:
Argument_1=value_1;Argument_2=value_2;Argument_n=value_n
(Optional) To filter the discovered managed elements (MEs) by name, enter a name in the Managed Element Name(s) field and set the Managed Element Name Qualifier list.
(Optional) To filter the discovered network elements (NEs) by name, enter a name in the Network Element Name(s) field and set the Network Element Name Qualifier list.
In the Cross Connect Collection Type field, specify how cross-connect objects are collected. To not collect any cross-connect objects, select None.
In the Topological Link Collection Type field, specify how topological links are collected. To not collect any topological links, select None.
See Table 7-3 for more information.
On the Scope tab, do one of the following:
Enter the EMS CORBA Loc URL
Import the IOR file
Enter the content of the IOR file
All entries on the Scope tab must be unique. All entries are validated against the CorbaURLAddressHandler address handler.
Make any other required configurations.
