4 About Collected Data
This chapter explains how the Oracle Communications Network Integrity Optical TMF814 CORBA cartridge treats collected data.
The Oracle Communications Network Integrity Optical TMF814 CORBA cartridge uses a standard TMF814 common object request broker architecture (CORBA) interface, which models network elements using the Multi Technology Network Management (MTNM) standard.
Table 4-1 lists MTNM objects and corresponding TMF814 IDL API class definitions.
Table 4-1 MTNM IDL Class Definitions
| MTNM Object Name | TMF814 IDL API Class Definition |
Managed Element (ME) |
ManagedElement_T |
Equipment Holder (Rack) |
EquipmentHolder_T |
Equipment Holder (Shelf) |
EquipmentHolder_T |
Equipment Holder (Slot) |
EquipmentHolder_T |
Equipment Holder (Sub Slot) |
EquipmentHolder_T |
Equipment (Card) |
Equipment_T |
Physical Termination Point (PTP) |
TerminationPoint_T |
Floating Termination Point (FTP) |
Connection Termination Point (CTP) |
Cross-connect |
CrossConnect_T |
Topological Link |
TopologicalLink_T |
LayeredParameters |
LayeredParameters_T |
A CTP can have a child CTP with infinite nesting levels. LayeredParameters are not top-level MTNM objects. They are the property of a termination point (TP).
Multi Technology Network Management Hierarchy
The following example demonstrates the MTNM hierarchy:
Managed Element
Equipment Holder(rack 1)
Equipment Holder (shelf 1)
Equipment Holder (sub shelf 1)
Equipment Holder (slot 1)
Equipment Holder(sub slot 1)
Equipment(card 1)
Termination Point (PTP){0…*}
Termination Point (CTP){0…*}
Equipment Holder(sub slot 2)
Equipment(card 2)
The following tables describe the properties of each MTNM object collected by the Optical TMF814 CORBA cartridge:
Table 4-2 Managed Elements Properties
| Property Name | Description |
name |
The name of the managed element (ME) that is assigned by the element management system (EMS) upon creation. |
userLabel |
Identifies the label assigned to the ME by the operator. |
nativeEMSName |
Indicates how the ME is referred to on EMS displays. |
owner |
Provided by the network management system (NMS). |
location |
Indicates the geographical location of the ME. |
version |
The active software version of the ME. |
productName |
Identifies the ME product or type name. |
communicationState |
Indicates the viability of EMS-ME messaging. Possible values are CS_AVAILABLE, CS_UNAVAILABLE. |
emsInSyncState |
Indicates if the EMS is able to keep the current EMS data synchronized with the current ME data and generate all appropriate notifications. The EMS sets this attribute to FALSE to indicate that it requires re-synchronization with ME data and that it is not able to generate the appropriate notifications while doing so. |
supportedRates |
This attribute is a list of potential cross-connection rates at which it is possible to have cross-connections within the ME. |
additionalInfo |
Represents a list of attributes that are EMS and NMS implementation specific. This field is common to all MTNM-managed objects. This field consists of a list of name and value pairs that call additional information, which allows EMS or NMS to give additional information that is not explicitly modeled at the MTNM interface. Some parameter names and values may be predefined. |
Table 4-3 Equipment Properties
name |
The name of the Equipment that is assigned by the EMS upon creation. |
nativeEMSName |
Indicates how the Equipment is referred to on EMS displays. |
userLabel |
A label assigned to the Equipment by the operator. |
owner |
Provided by the NMS. |
alarmReportingIndicator |
Indicates whether alarm reporting for this instance is active. |
expectedEquipmentObjectType |
Defines the type of expected Equipment. Leave empty if there is no expected Equipment. Example value: MBP_300. |
installedEquipmentObjectType |
Defines the type of installed Equipment. Leave empty if there is no installed Equipment. |
installedPartNumber |
Indicates the part number of the installed Equipment. |
installedSerialNumber |
Indicates the serial number of the installed Equipment. |
installedVersion |
Indicates the firmware version of the installed Equipment. |
serviceState |
Indicates the current state of the Equipment. Possible values are IN_SERVICE, OUT_OF_SERVICE, OUT_OF_SERVICE_BY_MAINTENANCE, SERV_NA. |
additionalInfo |
Represents a list of attributes that are EMS and NMS implementation specific. This field is common to all MTNM-managed objects. This field consists of a list of name and value pairs calling additional information and allowing EMSs or NMSs to give additional information that is not explicitly modeled at the MTNM interface. Some parameter names and values may be predefined. |
Table 4-4 Equipment Holder Properties
name |
Equipment Holder unique name. The EMS is responsible for the uniqueness of the name within the context of the ME. |
nativeEMSName |
Indicates how the Equipment Holder is referred to on EMS displays. |
userLabel |
owner |
Indicates whether alarm reporting is active for the instance. |
holderType |
Indicates the type of Equipment Holder. Valid values are: rack, shelf, sub_shelf, slot, sub_slot. |
holderState |
Indicates the state of the Equipment Holder directly contained equipment. Possible values are: EMPTY (0), INSTALLED_AND_EXPECTED (1), EXPECTED_AND_NOT_INSTALLED (2), INSTALLED_AND_NOT_EXPECTED (3), MISMATCH_OF_INSTALLED_AND_EXPECTED (4), UNAVAILABLE (5), UNKNOWN (6). |
expectedOrInstalledEquipment |
The Equipment object expected or installed in the Equipment Holder, if any. A value of NULL indicates that the Equipment Holder is empty or that it contains only other Equipment Holders. |
acceptableEquipmentTypeList |
Represents the types of Equipment objects that can be directly supported by the Equipment Holder. |
additionalInfo |
Represents a list of attributes that are EMS and NMS implementation specific. This field is common to all MTNM-managed objects. This field consists of a list of name and value pairs that call additional information, which allow EMS or NMS to give additional information that is not explicitly modeled at the MTNM interface. Some parameter names and values may be predefined. |
Table 4-5 PTP, FTP, and CTP Properties
name |
Indicates the assigned TP name when created by the EMS. The EMS is responsible for guaranteeing the uniqueness of the name within the context of the ME. The naming for CTPs, PTPs, and FTPs is deterministic. |
nativeEMSName |
Indicates how the TP is referred to on EMS displays. |
userLabel |
The user label of the TP is set with NMS data (typically the end-to-end trail data). |
owner |
Indicates the ownership of the TP so that adminstrativeState can be managed. |
direction |
Indicates the direction of the TP. Possible values are: D_NA (0), D_BIDIRECTIONAL (1), D_SOURCE (2), D_SINK (3). |
tpProtectionAssociation |
Indicates the associated TP indication. The NMS is responsible for running the multiLayerSubnetwork::MultiLayerSubnetworkMgr_I::getAssociatedTP() service to obtain any related TP. |
edgePoint |
Indicates if the TP is an edge point of one or more subnetworks. |
ingressTransmissionDescriptorName |
Indicates whether a CTP references an ingress (incoming) Traffic Descriptor or Transmission Descriptor. |
egressTransmissionDescriptorName |
Indicates whether a CTP references an egress (outgoing) Traffic Descriptor or Transmission Descriptor. |
connectionState |
Indicates the connection state of the source. A value of TPCS_BI_CONNECTED indicates that the source is connected to one entity and the sink is connected to the other. Possible values are: TPCS_NA, TPCS_SOURCE_CONNECTED, TPCS_SINK_CONNECTED, TPCS_BI_CONNECTED, TPCS_NOT_CONNECTED. |
tpMappingMode |
Indicates and controls the connection of the named connection point at a specified LayerRate to the dedicated G.805 TCP and associated G.805 Termination Function at the same LayerRate within the CTP or FTP. Possible values are: TM_NA(0), TM_NEITHER_TERMINATED_NOR_AVAILABLE_FOR_MAPPING (1), TM_TERMINATED_AND_AVAILABLE_FOR_MAPPING (2). |
type |
Possible value are: TPT_PTP (0), TPT_CTP (1), TPT_TPPool (2). |
transmissionParams |
A list of transmission parameters that can be set or retrieved on the TP at a specified layer. This attribute must contain the complete set of layer rates represented by a PTP, CTP, or FTP, even if they have no parameters associated with them. The Layer Rates are listed in the order of their client-server relationship. |
additionalInfo |
Represents a list of attributes that are EMS and NMS implementation specific. This field is common to all MTNM-managed objects. This field consists of a list of name and value pairs that call additional information, which allows the EMS or NMS to give additional information that is not explicitly modeled at the MTNM interface. Some parameter names and values may be predefined. |
Table 4-6 Cross-Connect Properties
active |
Indicates if the cross-connect is active in the ME. |
ccType |
Indicates the cross-connect type. Possible values are: ST_SIMPLE, ST_ADD_DROP_A, ST_ADD_DROP_Z, ST_INTERCONNECT, ST_DOUBLE_INTERCONNECT, ST_DOUBLE_ADD_DROP, ST_OPEN_ADD_DROP, ST_EXPLICIT |
direction |
Directionality of the cross connection. Possible values are: CD_UNI, CD_BI |
aEndNameList |
Names of CTPs, FTPs, and group termination points (GTPs) at the aEnd of the cross-connect. |
zEndNameList |
Names of CTPs, FTPs, and GTPs at the zEnd of the cross-connect. |
additionalInfo |
Represents a list of name value pairs that allow EMSs or NMSs to give additional information that is not explicitly modeled at the MTNM interface, but some parameter names and values may be predefined. Some predefined parameter names may include: ConnectionId, Fixed, RouteActualState, RouteAdminState, RouteExclusive, RouteId, RouteIntended, RouteInUseBy. |
Table 4-7 Topological Link Properties
name |
Indicates the name of the Topological Link, assigned by the EMS upon creation. |
userLabel |
Indicates the topological link user label (end-to-end trail data) in NMS data. |
nativeEMSName |
Indicates how the topological link is referred to on EMS displays. |
owner |
direction |
Indicates the direction of the topological link. A topological link can be unidirectional even if both its ends are bidirectional TPs. Possible values are CD_UNI (unidirectional) and CD_BI (bidirectional). |
rate |
Indicates the layer rate (bandwidth) of the topological link. |
aEndTP |
Indicates the name of the aEnd for the PTP, CTP, or FTP. |
zEndTP |
Indicates the name of the zEnd for the PTP, CTP, or FTP. |
additionalInfo |
Represents a list of name/value pairs that allow EMSs or NMSs to give additional information that is not explicitly modeled at the MTNM interface, but some parameter names and values may be predefined. Some predefined parameter names may include: AlarmReporting, AllocatedNumber, ASAPpointer, FragmentServerLayer, NetworkAccessDomain. |
Layer Parameters
The Optical TMF814 CORBA cartridge collects layer parameters for TPs. In the MTNM model, these layer parameters are encapsulated by TPs as transmission parameters. For details on layered parameters see the TMF814 documentation.
TMF814 APIs
This section describes the APIs used by the Optical TMF814 CORBA cartridge to collect data.
CORBA APIs
Table 4-8 lists the APIs used by the Optical TMF814 CORBA cartridge.
Table 4-8 TMF814 ManagedElement and Equipment CORBA APIs
| API | Used Operations |
org.tmforum.mtnm.emsSessionFactory.EmsSessionFactory_I |
org.tmforum.mtnm.emsSession.EmsSession_I |
org.tmforum.mtnm.managedElementManager.ManagedElementMgr_I |
org.tmforum.mtnm.nmsSession.NmsSession_I |
org.tmforum.mtnm.equipment.EquipmentInventoryMgr_I |
APIs for Cross-Connect Collection
Table 4-9 lists the APIs used for cross-connect collection.
Table 4-9 TMF814 Cross-Connect Collection APIs
multiLayerSubnetwork.MultiLayerSubnetworkMgr_I |
APIs for Topological Link Collection
There are two levels of Topological Links that can be retrieved using two different APIs. Table 4-10 lists the APIs used for cross-connect collection.
Table 4-10 TMF814 Topological Link Collection APIs
| APIs | Used Operations |
emsMgr.EMSMgr_I |
The EMSMgs API is used when the entire network is treated as a subnetwork. The MLSN API is used when each ME is treated as a subnetwork.
Handling Vendor Variations
This section explains how the Optical TMF814 CORBA cartridge handles some of the particular data collected from some vendors.
FTP Collection API Variations
The ManagedElementMgr_I.getAllFTP() operation, from MTNM version 3.0, is the preferred API to get all FTPs of a ME. For the vendors and devices that do not support MTNM version 3.0, the getAllPTP() operation is used. The getAllPTP() operation returns both PTPs and FTPs. While modeling FTPs, PTPs are filtered out.
Cross-Connect Collection API Variation
Cross-connects are collected using different APIs depending on the vendor. Use the crossConnectCollectionType parameter to specify the collection method, based on vendor device specifications. See "APIs for Cross-Connect Collection" for more information.
Topological Link Collection API Variation
Topological links are collected using different APIs depending on the vendor. Use one or both methods as required by the vendor or vendor device. Use the topologicalLinkCollectionType parameter to specify the collection method. See "APIs for Topological Link Collection" for more information.
Cross-Connect Protection Role
The productized Optical TMF814 CORBA cartridge does not discover protection role information on cross-connect segments because vendors and devices differ in the way this information is accessed. You must extend the Optical TMF814 CORBA cartridge to collect and model protection role information. See "Collecting and Modeling Protection Role Information" for more information.
