7 About Design Studio Construction
This chapter explains how the Oracle Communications Network Integrity Optical TMF814 CORBA cartridge is built from the Oracle Communications Design Studio perspective.
Model Collections
Table 7-1 shows the Design Studio construction of the Generic TMF814 model collection.
Table 7-1 Generic TMF814 Model Collection
| Specification Name | Dynamic Entity Type |
tmf814MEGeneric |
Physical Device Specification |
tmf814DeviceGeneric |
Logical Device Specification |
tmf814EquipmentGeneric |
Equipment Specification |
tmf814EquipmentHolderGeneric |
Equipment Holder Specification |
tmf814PortGeneric |
Physical Port Specification |
tmf814TPInterfaceGeneric |
Device Interface Specification This specification applies for all types of termination points (TPs). |
tmf814TPLayersGeneric |
Device Interface Configuration Specification |
Actions
The following tables outline the Design Studio construction of the Optical TMF814 CORBA cartridge actions and associated components.
Parameter values are case-sensitive and must be entered in capital letters when commands are run from a command line interface.
Table 7-2 Actions Design Studio Construction
| Action Name | Result Category | Address Handler | Scan Parameter Group | Processors |
Discover Abstract TMF814 action |
Device |
N/A |
IncrementalSacnParameter |
Discover TMF814 action |
Device |
N/A |
TMF814Parameters. See Table 7-3 AutoResolutionParameter. See Network Integrity Developer's Guide. Parallel Process Parameters. See Network Integrity Developer's Guide . |
Discover Huawei U2000 action |
Device |
N/A |
Parallel Process Parameters. See Network Integrity Developer's Guide. |
Table 7-3 TMF814 Scan Parameters Design Studio Construction
| Parameter Name | Parameter Type | Description | UI Label |
UserName |
Text box |
User name of the element management system (EMS) or network management system (NMS) used for getting details. |
Username |
Password |
Secret text |
Password of EMS or NMS system. |
Password |
EMSNamingService |
Text box |
EMS Naming Service The EMS session factory CORBA object name. |
Ems Naming Service |
EMSNamingServiceFormat |
Drop down |
List: PLAIN, STRINGIFIED The EMS session factory CORBA object name format. |
Ems Naming Service Format |
CollectEquipment |
Drop down |
List: TRUE, FALSE |
Collect Equipment |
CollectTP |
Drop down |
List: ALL, ONLY PTP, ONLY FTP, NONE |
Collect Termination Points |
CollectCTP |
Drop down |
List: CURRENT, IN USE, POTENTIAL, NONE |
Collect Connection TP |
EquipmentFetchSize |
Text box |
Number of equipment objects to fetch at a time for each EMS call. |
Equipment Fetch Size |
TPFetchSize |
Text box |
Number of contained TP objects to fetch at a time for each EMS call. |
Termination Point Fetch Size |
CTPCollectionDepth |
Text box |
The depth (level of children objects) to which contained TPs are collected. |
Contained TP Collection Depth |
ORBProperties |
Text box |
Semicolon separated name value pairs for ORB Properties. |
Orb Properties |
ORBArguments |
Text box |
Semicolon separated name value pairs for ORB Arguments. |
Orb Arguments |
ManagedElementName |
Text box |
Name of ME. This parameter works in combination with Managed Element Name Qualifier. This parameter helps to filter the scan. |
Managed Element Name |
ManagedElementNameQualifier |
Drop down |
List: EQUALS, EQUALS_IGNORE_CASE, CONTAINS, CONTAINS_IGNORE_CASE, STARTS_WITH, STARTS_WITH_IGNORE_CASE, ENDS_WITH, ENDS_WITH_IGNORE_CASE This parameter works in combination with Managed Element Name to filter the collected MEs by name and qualifier. |
Managed Element Name Qualifier |
NetworkElementNames |
Text Box |
Name of NE. This parameter works in combination with Network Element Names Qualifier. This parameter helps to filter the scan. |
Network Element Names |
NetworkElementNameQualifier |
Drop down |
List: EQUALS, EQUALS_IGNORE_CASE, CONTAINS, CONTAINS_IGNORE_CASE, STARTS_WITH, STARTS_WITH_IGNORE_CASE, ENDS_WITH, ENDS_WITH_IGNORE_CASE COMMA_DELIMITED_NAMES, COMMA_DELIMITED_NAMES_IGNORE_CASE This parameter works in combination with Network Element Name to filter the collected NEs by name and qualifier. |
Network Element Name Qualifier |
CrossConnectCollectionType |
Drop down |
List: USE_SNC, USE_ME_MANAGER, NONE This parameter controls how cross-connects are collected. Select None to disable cross-connect collection. |
Cross-connect Collection Type |
TopologicalLinkCollectionType |
Drop down |
List: ALL, BETWEEN_SN, INSIDE_SN, NONE This parameter controls how topological links are collected. Select None to disable topological link collection. |
Topological Link Collection Type |
Table 7-4 Discovery Processor Design Studio Construction
| Discovery Processors | Variable |
CORBA Property Initializer |
Input: N/A Output:
TMF814 CORBA Property Initializer |
Input: corbaSeed Output: corbaSeed |
CORBA Connection Manager |
See Network Integrity CORBA Cartridge Guide for more information. |
TMF814 Property Initializer |
Input: N/A Output:
TMF814 Property Customizer |
Input:
Output: tmf814Properties |
Huawei Customizer |
Input:
Output:
TMF814 Session Manager |
Input: tmf814Properties Output:
TMF814 Device Recorder Initializer |
Input: tmf814Properties, customProperties Output:
TMF814 ME Collector |
Input: N/A Output:
TMF814 Device Modeler |
Input:
Output:
TMF814 Equipment Collector |
Input: tmf814Properties, customProperties, sessionManager, physicalTree, managedElement Output:
TMF814 Equipment Modeler |
Input:
Output:
TMF814 PTP Collector |
Input:
Output:
TMF814 PTP Modeler |
Input:
Output:
TMF814 CTP Discoverer for PTP |
Input:
Output: n/a |
TMF814 FTP Collector |
Input:
Output:
TMF814 FTP Modeler |
Input:
Output:
TMF814 CTP Discoverer for FTP |
Input:
Output: n/a |
TMF814 Device Persister |
Input:
Output: n/a |
TMF814 Device Recorder Persister |
Input: tmf814Properties Output: n/a |
TMF814 Cross-Connect Discoverer |
Input: tmf814Properties, customProperties, tpDetailMap Output: n/a |
TMF Topological Link Collector |
TMF814 Topological Link Modeler |
Input:
Output:
TMF814 Pipe Persister |
Input: tmf814Properties, tpDetailMap, tlPipeMap Output: n/a |
