7 Network Integrity Post-Installation Tasks
Learn about Oracle Communications Network Integrity, including installation and post-installation steps, as well as cartridge deployment.
Overview of Network Integrity Post-Installation Tasks
Post-installation tasks for Network Integrity include:
Migrating the Application Keystore to AES-256 Encryption
Network Integrity uses the application keystore to encrypt sensitive application data, including scan parameter values such as connection details, passwords, and other configurable values provided while configuring a scan. The application keystore uses AES-256 encryption to protect these values.
Use this information while upgrading an existing Network Integrity installation and is not required for a complete installation. For a complete installation, the Network Integrity installer automatically configures the application keystore to use AES-256 encryption. When upgrading from Release 8.0.0 or an earlier release, use the NIDBTools utility as a post-upgrade task to update the application keystore encryption from AES-128 to AES-256 and migrate the existing encrypted scan parameter values to AES-256 encryption. Before performing this task, ensure that a valid backup of the Network Integrity database schema has been taken.
- Navigate to NI_Home/Tools/NIDBTools and extract NIDBTools.zip to a temporary location.
- Set
JAVA_HOMEto the latestJDK 21installation. - Open a command prompt and navigate to the extracted NIDBTools directory and run the following:
java -jar NIDBTools.jar - Provide the following information when prompted:
Select operation [1=Model upgrade, 2=AES-256 migration, 0=Exit]: Enter2to perform AES-256 migration.Enter Database Hostname: Provide NI Schema Host Name.Enter Database Port Number: Provide NI Schema Port Number.Enter Database Service Name: Provide Schema Name.Enter MDS Schema Username: Provide Schema password.After the utility connects to the database, it prompts for confirmation.
Type MIGRATE to continue: Enter MIGRATE to begin the migration.The utility migrates the Application Keystore key from AES-128 to AES-256 and re-encrypts the existing protected data.
- Review the command-line logs for errors. If an error occurs, resolve the reported issue and run the utility again.
Configuring Proxy Server
You may select and configure a proxy server according to your specific requirements. By default, Network Integrity supports Oracle HTTP Server (OHS). For more information on setting up OHS as a proxy server, see Configuring Oracle HTTP Server as Proxy.
Managing Network Integrity Cartridges
Managing Network Integrity cartridges includes deploying and undeploying cartridges, viewing deployed and available cartridges, and migrating older cartridges to the latest version of Network Integrity.
Deploying Network Integrity Cartridges
You can deploy cartridges into Network Integrity in the following ways:
From Service Catalog and Design - Design Studio. You can deploy cartridges interactively from Design Studio to test environments. Design Studio enables you to manage cartridges in the test environment consistently, manage common test environment connection parameters across the design team, and compare cartridge version and build numbers in the development environment with those of the cartridges deployed in the test environment. See "Getting Started with Design Studio for Network Integrity (1)" in SCD Design Studio Modeling Network Integrity for more information.
By using the Service Catalog and Design Cartridge Management Tool (CMT). The CMT enables you to automate cartridge deployment. You can use the CMT to deploy cartridges into both test and production environments. You can also use it to deploy cartridges into cluster environments. See "Deploying Cartridges to Environments (1)" in SCD Developer's Guide for more information about the CMT.
By using the Network Integrity Cartridge Deployer Tool (CDT). The Network Integrity CDT is a GUI-based tool that enables you to deploy to Network Integrity run-time environments. The Oracle Universal Installer installs the CDT as part of the Network Integrity installation process. You can use the CDT to deploy cartridges into both test and production environments. You can also use it to deploy cartridges into cluster environments. See "Deploying Cartridges with the Network Integrity Cartridge Deployer Tool" for more information.
By writing your own custom scripts. See "Managing Cartridges With Custom Scripts" for more information.
The Cartridge Deployer Tool is available as a component of the core Network Integrity application. The Oracle Universal Installer installs the Cartridge Deployer Tool as part of the installation process in the same folder as the Network Integrity application.
The WebLogic Server Administration Console must not be locked for editing for the Cartridge Deployer Tool to successfully manage cartridges. See your WebLogic Server documentation for more information.
Before deploying or undeploying cartridges, ensure that:
You are logged out of the WebLogic Server Administration Console.
No one else is deploying or undeploying cartridges on the same server.
Network Integrity is not running a scan that uses the cartridge.
To deploy cartridges with the Network Integrity Cartridge Deployer Tool:
Go to the NI_Home/CartridgeDeployerClients/CartridgeDeployer folder.
Run the Cartridge Deployer Tool executable with the following command:
./runCartridgeDeployer.sh
The Cartridge Deployer Welcome screen appears.
Select the Deploy Cartridge option and click Next.
The Select Cartridge Type screen appears.
In this screen, you select the cartridge type that is same as the application for which you are deploying the cartridges.
Select Network Integrity from the Cartridge Type list and click Next.
The Cartridge Location screen appears.
Click Browse to search for and select the required cartridges for the Cartridge Deployer Tool to deploy.
You can select multiple cartridges from a single directory by holding down the Ctrl key.
Enable Ignore dependency check failures for all Cartridges.
Before deploying the selected cartridge, ensure that all dependent cartridges have been successfully deployed to the environment. If the dependent cartridges are not deployed, the selected cartridge deployment may fail. - Verify the default selections and click Next.
On the WebLogic Connection Information screen, if the Use SSL checkbox is selected and the "SSL Handshaking failed. You can proceed without SSL by unchecking SSL options on the bottom of this screen" error message appears, it indicates that SSL is not properly configured for the environment.To proceed without SSL:- Click OK on the error message dialog.
- Deselect the Use SSL checkbox at the bottom of the screen.
View the details of the selected cartridges, confirm your selection, and click Next.
To add Deploy property or Model property, under Details for that cartridge, right-click Properties and select the respective options for related menus.
The WebLogic Connection Information screen appears.
Do the following:
In the Host name or IP address field, enter the host name or IP address of the WebLogic Administration Server.
In the Port number field, enter the port number of the WebLogic Administration Server.
Select whether or not to enable SSL by selecting or deselecting the Use SSL check box.
You must enter the Admin Server SSL Port if the Use SSL check box is selected.
In the Keystore field, enter the keystore location if the Use SSL check box is selected.
In the CMWS User field, enter the user name of the CMWS user.
Use your WebLogic administrator user name and password here, and in the next step.
The cartridge management web service (CMWS) user is a WebLogic server user belonging to the administrators group.
In the Password field, enter the password for the CMWS user.
Use your WebLogic administrator user name and password here.
Click Next.
The Select WebLogic Target screen appears.
Click Next.
The Review Deployment screen appears.
Review and confirm your selections, and click Deploy.
The Cartridge Deployment screen appears that shows the deployment progress. A message appears upon successful deployment.
The Cartridge Deployer Tool rejects cartridges whose higher versions already exist. You can view rejected cartridges in the Cartridges rejected for this deployment session list.
Logs returned by the adapter are displayed after each cartridge deployment operation irrespective of its success.
If the system or server goes down during cartridge deployment, the cartridge is recovered after the system is up again, or during the next cartridge deployment session, with the cartridge deployment request showing as “failed".
Click Exit to close the Cartridge Deployment Tool.
You must log back into the Network Integrity application (if it is already opened) after cartridge deployment.
Undeploying Cartridges with the Network Integrity Cartridge Deployer Tool
You can use the Cartridge Deployer Tool to undeploy the cartridges.
When a cartridge is undeployed, all Network Integrity scans that use scan actions associated with the undeployed cartridge are deleted.
To undeploy a cartridge:
Run the Cartridge Deployer Tool executable by running the following command:
Select Undeploy Cartridge and click Next.
From the Cartridge Type list, select NetworkIntegrity and click Next.
Do the following:
The CMWS user is a WebLogic server user belonging to the administrators group.
Click Next.
On the WebLogic Connection Information screen, if the Use SSL checkbox is selected and you receive the error message
SSL Handshaking failed. You can proceed without SSL by unchecking SSL options on the bottom of this screen., it means that SSL is not properly set up in the environment. -
(Optional) To proceed without SSL:
Clear the Use SSL checkbox at the bottom of the screen.
Click Next.
The Select Cartridges for Undeployment screen appears.
You can view all of the cartridges that you had selected earlier, deployed in Network Integrity.
Click on the cartridge name to select it, then right-click on that cartridge name and select Select for Undeployment.
The cartridge name must be selected before right-clicking.
Click Next.
Network Integrity does not use undeployment properties.
The Review Undeployment screen appears.
Review your selection(s) and click Next.
The Cartridge Undeployment screen appears.
You can view the undeployment progress in this screen and a message after the cartridge is undeployed. Logs returned by the adapter are displayed after each cartridge operation irrespective of its success.
For more information about managing cartridges and deploying cartridges using Design Studio, see "Getting Started with Design Studio for Network Integrity (1)" in SCD Design Studio Modeling Network Integrity.
Caution:
If the server or system goes down during cartridge undeployment, the cartridge is recovered after the system is up again, or during the next cartridge undeployment session, with the cartridge deployment request showing as “deploy".
Ensure that you deploy the recovered cartridge first and then undeploy it.
Deploying Cartridges into Cluster Environments That Use Proxy Server
To deploy cartridges into a cluster environment that uses a proxy server as a frontend host:
Shut down all the managed servers except the managed server on which the cartridge_management_ws application is deployed. If you do not know the managed server on which the cartridge_management_ws application is deployed, continue with step 3; otherwise, proceed to step 4.
For proxy server:
Log in to the WebLogic console and go to Edit Tree.
Select the required cluster from Clusters under Environments.
Go to HTTP Tab and remove the front-end host and port details.
Restart the servers.
(Optional) Locate the cartridge_management_ws application and the corresponding server on which it is deployed by doing the following:
Log in to the WebLogic Server Administration console.
On the Home page, under Domain Structure, click the Deployments link.
The Summary of Deployments page appears.
Under the Name column, locate the cartridge_management_ws application; under the Targets column, locate the server on which this application is deployed.
Deploy the required cartridges.
After you have deployed the cartridges, configure the front-end host and port details for the cluster in the console.
Restart all servers.
Repeat this procedure for every cartridge deployment life cycle.
Viewing Cartridges with the Network Integrity Cartridge Deployer Tool
To view deployed cartridges:
Select the View Cartridges option, and click Next.
Select Network Integrity in the Cartridge Type list, and click Next.
Do the following:
Click Next.
Click Next.
The Deployed Cartridges screen appears.
You can view the deployed cartridges.
For more information about managing cartridges, see "Getting Started with Design Studio for Network Integrity (1)" in SCD Design Studio Modeling Network Integrity, which is part of Design Studio Online Help.
For information about deploying cartridges using Design Studio, see "Getting Started with Design Studio for Network Integrity (1)" in Design Studio Online Help.
Scripted cartridge management allows you to develop custom scripts that deploy, undeploy, list deployed cartridges, and list available cartridges. Scripts can be run manually, or from a command prompt, and can be used to process cartridge operations to secure and non-secure network systems.
To manage cartridges using Java, you must develop a custom Java application. Or, to manage cartridges using ANT tasks, you must develop a custom XML script.
You can automate cartridge deployment using the Design Studio Cartridge Management Tool (CMT). You can use the CMT to deploy cartridges into both test and production environments. See "Creating, Packaging, and Distributing Plug-in Projects (1)" in SCD Developer's Guide for more information about the CMT.
Developing a Custom Java Application
Refer to NI_Home/CartridgeDeployerClients/tools/Sample.java for an example custom Java application, containing example syntax and sample Java classes.
To develop a custom Java application with which to manage cartridges:
Open Oracle Communications Service Catalog and Design - Design Studio or any Java Integrated Development Environment (IDE) in the Java perspective.
Create a Java project and a /lib directory in the project.
Import all the JAR files from the NI_Home/CartridgeDeployerClients/lib/ directory to the /lib directory in the project.
Download cartridge-management-client-tools.jar from the NI_Home/CartridgeDeployerClients/tools directory to the /lib directory in the project.
Inside /lib directory, create a Java file to develop the Java classes that are required to implement cartridge management operations by doing all of the following:
Import the following files:
oracle.communications.platform.cartridgemanagement.client.domain.Cartridge
oracle.communications.platform.cartridgemanagement.client.domain.CartridgeOperationResponse
oracle.communications.platform.cartridgemanagement.client.core.CartridgeManager
To deploy cartridges, create an oracle.communications.platform.cartridgemanagement.client.domain.Cartridge object with the following class attributes:
name
version
buildId
type
deploy properties
Call the deployCartridge() operation on the cartridge manager object with the following arguments:
webServiceUrl
keystore_location
cmwsUserName
password
cartridge_object
pollwait
pollcount
To undeploy cartridges, create an oracle.communications.platform.cartridgemanagement.client.domain.Cartridge object with the following class attributes:
name
version
type
undeploy properties
Call the unDeployCartridge() operation on the cartridge manager object with the following arguments:
webServiceUrl
keystore_location
cmwsUserName
password
cartridge_object
pollwait
pollcount
To list cartridges of a specific type, call the getInstalledCartridges() operation on the cartridge manager object with the following arguments:
webServiceUrl
keystore_location
cmwsUserName
password
cartridgeType
To list existing cartridges of a specific type, create an oracle.communications.platform.cartridgemanagement.client.domain.Cartridge object with the following class attributes:
name
version
type
Call the cartridgeExist() operation on the cartridge manager object with the following arguments:
webServiceUrl
keystore_location
cmwsUserName
password
cartridge_object
comparisonOperator
To get the environment, call the getEnvironmentVersion() operation on the cartridge manager object with the following arguments:
webServiceUrl
keystore_location
cmwsUserName
password
cartridgeType
Developing Custom ANT Tasks
Refer to NI_Home/CartridgeDeployerClients/tools/sample-build.xml for an example custom ANT script, containing example syntax and sample operations. Refer to NI_Home/CartridgeDeployerClients/tools/sample-build.properties for an example custom Java application, containing example syntax and sample operations.
To develop custom ANT tasks with which to manage cartridges:
Open Design Studio or any Java Integrated Development Environment (IDE) in the XML perspective.
Inside the lib/ directory, create an XML file with the following cartridge management operations:
<taskdef name="deploy" classname="oracle.communications.sce.cartridgemanagement.ws.tools.DeployCartridge" classpathref="class.path"/> <taskdef name="undeploy" classname="oracle.communications.sce.cartridgemanagement.ws.tools.UndeployCartridge" classpathref="class.path"/> <taskdef name="list" classname="oracle.communications.sce.cartridgemanagement.ws.tools.ListCartridge" classpathref="class.path"/> <taskdef name="exist" classname="oracle.communications.sce.cartridgemanagement.ws.tools.CartridgeExist" classpathref="class.path"/> <taskdef name="environment" classname="oracle.communications.sce.cartridgemanagement.ws.tools.GetEnvironment Version" classpathref="class.path"/>
Add the valid attributes for each ANT task:
For the deploy task:
<target name="deploy"> <echo message="Deploying cartridge..."/> <deploy host="${host}" port="${port}" username="${username}" password="${password}" adminServerKeyStore="${adminServerKeyStore}" sslKeyStore="${sslKeyStore}" fileLocation="${fileLocation}" cartridgeType="${cartridgeType}" target="${target}" property="deployresponse"/> <echo message="Message from cartridge deploy task : ${deployresponse}"/> </target> -
For the list task:
<target name="list"> <echo message="Listing cartridge..."/> <list host="${host}" port="${port}" username="${username}" password="${password}" adminServerKeyStore="${adminServerKeyStore}" sslKeyStore="${sslKeyStore}" target="${target}" cartridgeType="${cartridgeType}" property="listval"/> <echo message="Message from cartridge list task : ${listval}"/> </target> -
For the undeploy task:
<target name="undeploy"> <echo message="Undeploying cartridge ${cartridgeName} ${cartridgeVersion}..."/> <undeploy host="${host}" port="${port}" username="${username}" password="${password}" adminServerKeyStore="${adminServerKeyStore}" sslKeyStore="${sslKeyStore}" target="${target}" cartridgeName="${cartridgeName}" cartridgeVersion="${cartridgeVersion}" cartridgeType="${cartridgeType}" property="undeployresponse"/> <echo message="Message from cartridge undeploy task : ${undeployresponse}"/> </target> -
For the exist task:
<target name="exist"> <echo message="Checking existance of cartridge ${cartridgeName} ${cartridgeVersion}..."/> <exist host="${host}" port="${port}" username="${username}" password="${password}" adminServerKeyStore="${adminServerKeyStore}" sslKeyStore="${sslKeyStore}" target="${target}" cartridgeName="${cartridgeName}" cartridgeVersion="${cartridgeVersion}" cartridgeType="${cartridgeType}" property="existval"/> <echo message="Message from cartridge exist task : ${existval}"/> </target> -
For the environment task:
<target name="env"> <echo message="Fetching environment version..."/> <environment host="${host}" port="${port}" username="${username}" password="${password}" adminServerKeyStore="${adminServerKeyStore}" adminServerKeyStore="${adminServerKeyStore}" sslKeyStore="${sslKeyStore}" target="${target}" cartridgeType="${cartridgeType}" property="envval"/> <echo message="Message from env task : ${envval}"/> </target>
Inside the lib/ directory, create an XML properties file to automate the ANT tasks:
ant -lib ..lib/ -f sample-build.xml deploy ant -lib ..lib/ -f sample-build.xml list ant -lib ..lib/ -f sample-build.xml undeploy ant -lib ..lib/ -f sample-build.xml exist ant -lib ..lib/ -f sample-build.xml env
Where lib/ refers to the location where the dependent libraries are stored.
Running Cartridge Operations From a Command-Line
To use a command-line interface to run cartridge operations:
Open a system console command-line or connect to the Network Integrity server using a remote client.
Set the Java path, as it is explained in your Java documentation.
Enter commands at the command-line.
From the command-line interface, you can:
Deploy one or more cartridges.
Undeploy one or more cartridges.
List all deployed cartridges.
List all available, undeployed cartridges.
Show the help message.
Table 7-1 lists all the arguments used at the command-line for managing cartridge operations.
Table 7-1 Valid Arguments for Command-Line Cartridge Management
| Valid Argument | Description |
-host |
The admin host name where the cartridge manager web service (CMWS) is deployed. |
-port |
A valid port number to the admin server. |
-user |
A CMWS user. |
-password |
The CMWS password for the specified user. If -password is omitted from the command, you are prompted to enter the password at the command prompt. |
-keystore |
A valid keystore location for SSL connection. |
-adminkeystore |
A valid keystore location for the admin server if the SSL connection is used. |
-type |
The cartridge type. When deploying multiple cartridges, -type must be set to |
-operation |
The cartridge operation to be performed. Possible values are: |
-location |
A path to a single cartridge, or a comma separated list of paths to multiple cartridges. |
-target |
The target server, where CMWS is deployed. |
-name |
A single cartridge name, or a comma-delimited list of cartridge names for multiple cartridges. Only the undeploy operation can accept multiple names. |
-version |
A single five-digit cartridge version, or a comma-delimited list of cartridge versions for multiple cartridges. Only the undeploy operation can accept multiple versions. |
-help |
Display the help message. |
Table 7-2 lists the commands for managing cartridge operations, with their mandatory and valid arguments.
Table 7-2 Valid Arguments for Each Cartridge Command
| Command | Description |
deploy |
Mandatory Arguments: -host, -port, -username, -password, -target, -keystore (if command is run on an SSL-enabled network system) Valid Arguments: -type, -location, -target |
undeploy |
Mandatory Arguments: -host, -port, -username, -password, -target, -keystore (if command is being run on an SSL-enabled network system) Valid Arguments: -type, -target, -name, -version |
list |
Mandatory Arguments: -host, -port, -username, -password, -target, -keystore (if command is being run on an SSL-enabled network system) Valid Arguments: -type, -target |
exist |
Mandatory Arguments: -host, -port, -username, -password, -target, -keystore (if command is being run on an SSL-enabled network system) Valid Arguments: -type, -name, -version, -target |
To display instruction messages, enter a command similar to the example below:
java -jar cartridge-management-client-tools.jar -help
To deploy a cartridge, enter a command similar to the example below:
java -Djava.util.logging.config.file=logger.conf -jar cartridge-management-client-tools.jar -operation deploy -host admin_host -port admin_port -user cmws_user -password cmws_password -target target_name_where_cmws_deployed -location cartridge_path -type cartridge_type -property model.modelname=modelvalue,deploy.deployname1=deployvalue1,deploy.deployname2=deployvalue2
To list deployed cartridges, enter a command similar to the example below:
java -Djava.util.logging.config.file=logger.conf -jar cartridge-management-client-tools.jar -operation list -host admin_host -port admin_port -user cmws_user -password cmws_password -type cartridge_type -target target_name_where_cmws_deployed
To undeploy a cartridge, enter a command similar to the example below:
java -Djava.util.logging.config.file=logger.conf -jar cartridge-management-client-tools.jar -operation undeploy -host admin_host -port admin_port -user cmws_user -password cmws_password -type cartridge_type -target target_name_where_cmws_deployed -name cartridge_name -version cartridge_version
To check if a cartridge exists, enter a command similar to the example below:
java -Djava.util.logging.config.file=logger.conf -jar cartridge-management-client-tools.jar -operation exist -host admin_host -port admin_port -user cmws_user -password cmws_password -type cartridge_type -target target_name_where_cmws_deployed -name name_of_cartridge -version version_of_cartridge
To fetch environment properties, enter a command similar to the example below:
java -Djava.util.logging.config.file=logger.conf -jar cartridge-management-client-tools.jar -operation env -host admin_host -port admin_port -user cmws_user -password cmws_password -type cartridge_type -target target_name_where_cmws_deployed
Configuring Network Integrity for Inventory Management
After installing Network Integrity, you can use it to discover devices on your network. To compare the discovered device data with an existing inventory model, and to detect and resolve discrepancies between the two, you must configure or extend Network Integrity to communicate with your inventory management system. You may also need to configure or extend your inventory system.
You can license and download components to simplify the task of configuring and extending Network Integrity to communicate with Unified Inventory Management (UIM).
You can license and download components to simplify the task of configuring and extending Network Integrity to communicate with MetaSolv Solution (MSS).
For information on Network Integrity cartridges or UIM technology packs that enable communication between Network Integrity and UIM, see "Overview" in UIM Integration Cartridge documentation.
Installing Network Integrity Report Templates
Network Integrity comes with pre-defined report templates that you can use. A folder, integrityreports, is created during installation, in the folder where Network Integrity is deployed. The integrityreports folder contains the following report templates:
Scan_History_Report
Discrepancy_Corrective_Action_Report
Device_Discrepancy_Detection_Summary_Report
Device_Discrepancy_Detection_Detailed_Report
Device_Discovery_Summary_Report
The integrityreports folder should be on the system where Oracle Analytics Publisher is installed. If Oracle Analytics Publisher is installed on a system separate from the system where Network Integrity is deployed, move the integrityreports folder to the location where Oracle Analytics Publisher is installed and provide the correct connection information as shown in "Installing Network Integrity Report Templates".
To deploy the report templates to Oracle Analytics Publisher:
Open the Oracle Analytics Publisher application, click on New and select Data Model from the dropdown menu.
Within the Diagram tab, click on the '+' symbol and select SQL Query.
The New Data Set - SQL Query window appears.
Open the .xdo file and copy the SQL from the file.
Paste the copied SQL into the SQL Query field on the window.
Provide the name of the Data Model and click OK.
The Add Parameter window appears. In this window, select all of the parameters and click on OK.
Click on View Data in the Data Model screen.
From the Data tab, click on View and click Table View to view the data in table format.
Click on the Save as Sample Data icon.
Check the .xdo file for any available valueSet values.
If there are any values then:- Click on List of Values on the left side of the Data Model screen.
- Click on '+' to add values.
- Provide the name and copy the SQL query from the .xdo file. Paste this code into the deviceTypes: Type: SQL Query field.
Click on Save icon.
The Save As window appears. Here, select the Data Model folder, provide the data model name and save it.
Click on New and select Report from the dropdown menu.
The Create Report window appears.
Click on the Search icon next to the Data Model field.
The Select Data Model window opens.
Select the corresponding data model for the report from the window and click Open.
Click Next on the Create Report window.
Under Layout options, select Table and click Next.
Select View Report and Click on Finish.
Select OAPubReports folder and provide the name of the report.
Click on Save to save your report.
Enabling HTTP Tunneling
For Network Integrity to transfer large amounts of data between the server and client, the WebLogic server must be configured for http tunneling. This will help the server to make a dedicated connection with the client, for the given timeout and within this time, the data can be transferred without giving any errors.
HTTP tunneling should be enabled on the server where Network Integrity is deployed. If Network Integrity is deployed in a single managed server installation, then the parameters need to be changed on the WebLogic administration server. If Network Integrity is deployed in a clustered server installation, then the parameters need to be changed on the WebLogic administration server and all the managed servers.
To enable http tunneling, perform the following:
Log in to the Administration console using the administrator user name and password.
Click Lock and edit.
Click Servers in the left panel.
Select the server name and click Protocols.
In the Enable tunneling field, select the check box.
In the Tunneling client ping field, enter 80 seconds.
In the Tunneling client timeout field, enter 900 seconds.
Click Activate Changes.
Repeat the same procedure for any managed servers.
Setting Up Oracle Internet Directory
To set up Oracle Internet Directory:
If you want to use Oracle Internet Directory, you must first complete all prerequisite steps outlined in the Installing and Configuring Additional Software. After doing so, you can proceed with the following post-installation steps.
Navigate to Domain_Home/config/fmwconfig.
Edit the file jps-config.xml.
Find the following serviceInstance parameter:
<serviceInstance name="idstore.ldap" provider="idstore.ldap.provider">
Add the following bold entries to the file:
<serviceInstance name="idstore.ldap" provider="idstore.ldap.provider"> <description>LDAP Identity Store Service Instance</description> <property name="idstore.config.provider" value="oracle.security.jps.wls.internal.idstore.WlsLdapIdStoreConfigProvider"/> <property name="CONNECTION_POOL_CLASS" value="oracle.security.idm.providers.stdldap.JNDIPool"/> <property name="virtualize" value="true"/> <serviceInstanceRef ref="NetworkIntegrityAuthenticationProvider"/> </serviceInstance> <serviceInstance name="NetworkIntegrityAuthenticationProvider" provider="idstore.ldap.provider"> <property name="idstore.type" value="ACTIVE_DIRECTORY" /> </serviceInstance>
Save and close the file.
Configuring the WebLogic Server StuckThreadMaxTime Value
During the installation of Oracle WebLogic Server and Network Integrity in a clustered environment, if the execute thread takes more time than the Stuck Thread Max Time declared in WebLogic, a Stuck Thread Max Time error is displayed.
Stuck Thread Max Time is a property in WebLogic for performance tuning. It is defined as “the number of seconds that a thread must be continually working before this server considers the thread stuck". The minimum value is 0 seconds; the default is 600 seconds.
Consider setting Stuck Thread Max Time from its default 600 seconds to a larger value such as 54000 seconds (15 hours).
Use the WebLogic Console to change this value:
Log in to the WebLogic Administration console.
In the Home page, select Environment.
Select Servers, and then click Admin Server.
Select Configuration, and then click Tuning.
Increase the value of Stuck Thread Max Time to 54000.
Restart your domain. Your changes take effect only after a restart.
Setting Memory Requirements for Network Integrity
To ensure that Network Integrity scans run successfully, you must configure appropriate memory settings in the WebLogic Server. Network Integrity may require different JVM heap sizes depending on the production volume processed by each scan.
- In the WebLogic domain’s bin directory, open the startNI.sh file.
- Set the JVM memory arguments as required. For example,
WLS_MEM_ARGS_64BIT="-Xms20g -Xmx20g"
This configures the JVM to use 20 GB of memory as both the minimum and maximum heap size.
See "Hardware Sizing Considerations" to determine the appropriate memory allocation for your JVM based on your specific requirements.
