5 About Cartridge Modeling
This chapter provides information on how imported data is modeled.
To facilitate discrepancy detection and resolution, the Oracle Communications Network Integrity MSS Integration cartridge models the imported data from Oracle Communications MetaSolv Solution (MSS) to the Oracle Communications Information Model.
The MSS Integration cartridge uses different modeling logic depending on the action it is performing. See the following sections for more information:
About Import Data Modeling
This section explains how Network Integrity models data imported from MSS.
You can configure various parameters in the Network Integrity UI to determine the quantity of data to import from MSS. Network Integrity logically applies the parameters to filter the imported data. When no filtering parameters are configured in the UI, Network Integrity imports all MSS data.
API Mapping
Network Integrity uses APIs to map the imported MSS data to the Information Model, which allows the MSS data to map directly to TMF814 entities. The MSS Integration cartridge uses TMF814 specifications to model the MSS data.
Table 5-1 shows the relationship between the imported MSS data, physical TMF814 entities, and physical Information Model entities.
Table 5-1 MSS Data Modeling to the Physical Information Model Tree
| MSS Data Object | TMF814 Entity | Information Model Entity |
Network Node |
Managed Element (ME) |
Physical Device, Logical Device |
Equipment |
Equipment Holder (Rack) |
Equipment |
Equipment |
Equipment Holder (Shelf) |
Equipment |
Equipment |
Equipment Holder (Sub-Shelf) |
Equipment |
Mounting Position |
Equipment Holder (Slot) |
Equipment Holder |
Mounting Position |
Equipment Holder (Sub-Slot) |
Equipment Holder |
Equipment |
Equipment (Card) |
Equipment |
Port |
Physical Termination Point (PTP) |
Physical Port |
Table 5-2 shows the relationship between the imported MSS data, logical TMF814 entities, and logical Information Model entities.
Table 5-2 MSS Data Modeling to the Logical Information Model Tree
| MSS Data | TMF814 Entity | Information Model Entity |
Network Node from EXTRACT.MV_EQUIPMENT |
ME |
LogicalDevice |
Port from EXTRACT.MV_PORT_ADDRESS |
Point Termination Port (PTP) and Floating Termination Point (FTP) |
DeviceInterface |
(Port) Circuit and (Rack/Shelf) Circuit from EXTRACT.V_PA_HIER |
Connection Termination Point (CTP) |
DeviceInterface |
N/A |
LayeredParameters |
DeviceInterfaceConfigurationItem |
Field Mapping
The following tables explain the field mappings for each imported MSS object.
Table 5-3 Physical Device Field Mapping
| Information Model Attribute | Information Model Support | MSS Inventory Field | Used for Discrepancy Detection |
Id |
Static |
EXTRACT.MV_EQUIPMENT.NETWORK_NODE_ID/EXTRACT.MV_NETWORK_NODE.NETWORK_NODE_ID |
No |
name |
Static |
EXTRACT.V_EQUIPMENT.NW_NODE_NAME/EXTRACT.MV_NETWORK_NODE.NETWORK_NODE_NAME |
No |
description |
Static |
N/A |
No |
discoveredVendorName |
Dynamic |
EXTRACT.V_EQUIPMENT_SPEC.VENDOR_NAME |
No |
serialNumber |
Static |
EXTRACT.MV_EQUIPMENT.SERIAL_NBR |
No |
physicalLocation |
Static |
EXTRACT.V_EQUIPMENT.LOC_ID_CLLI_CODE/V_NETWORK_NODE.CLLI_CODE |
No |
softwareRev |
Dynamic |
EXTRACT.MV_EQUIPMENT.SOFTWARE_RELEASE_IDENTIFIER |
No |
modelName |
Dynamic |
EXTRACT.MV_EQUIPMENT_SPEC.EQUIPSPEC_TYPE/V_NETWORK_NODE.NST_COMP_TYPE |
No |
nativeEmsName |
Static |
EXTRACT.V_EQUIPMENT.NW_NODE_NAME/ EXTRACT.MV_NETWORK_NODE.NETWORK_NODE_NAME |
No |
userLabel |
Dynamic |
No |
owner |
Dynamic |
No |
Table 5-4 Root Equipment Field Mapping
Id |
Static |
EXTRACT.V_EQUIPMENT.EQUIPMENT_ID |
No |
name |
Static |
EXTRACT.MV_EQUIPMENT_SPEC.EQUIPMENT_ACRONYM |
No |
description |
Static |
N/A |
No |
Dynamic |
Yes |
serialNumber |
Static |
Yes |
physicalLocation |
Static |
EXTRACT.V_EQUIPMENT.LOC_ID_CLLI_CODE |
No |
discoveredPartNumber |
Dynamic |
EXTRACT.MV_EQUIPMENT_SPEC.VENDOR_PART_NUMBER |
Yes |
hardwareRev |
Dynamic |
EXTRACT.MV_EQUIPMENT.VERSION_OF_HARDWARE_INSTALLED |
No |
modelName |
Dynamic |
EXTRACT.MV_EQUIPMENT_SPEC.EQUIPSPEC_TYPE |
No |
nativeEmsName |
Static |
No |
expectedObjectType |
Dynamic |
N/A |
No |
serviceState |
Dynamic |
EXTRACT.MV_EQUIPMENT.AVAILABILITY_STATUS Valid values are IN_SERVICE, OUT_OF_SERVICE, IN_MAINTENANCE, UNKNOWN, TESTING |
No |
userLabel |
Dynamic |
EXTRACT.MV_EQUIPMENT.EQUIPMENT_NAME |
No |
owner |
Dynamic |
EXTRACT.MV_EQUIPMENT_SPEC.VENDOR_NAME |
No |
Table 5-5 Non-Root Equipment Field Mapping
Id |
Static |
Derived From EQUIP_ID_2_HIER with mounting_position_seq |
No |
name |
Static |
Derived from EXTRACT.V_MP_HIER.EQUIPMENT_ACRONYM_HIER |
No |
description |
Static |
N/A |
No |
Dynamic |
Derived from EXTRACT.V_MP_HIER.VENDOR_NAME_HIER |
No |
serialNumber |
Static |
Derived from EXTRACT.V_MP_HIER.SERIAL_NBR_HIER |
Yes |
physicalLocation |
Static |
EXTRACT.V_EQUIPMENT.LOC_ID_CLLI_CODE This field value corresponds to the root equipment. |
No |
Dynamic |
Derived from EXTRACT.V_MP_HIER.VENDOR_PART_NUMBER_HIER |
Yes |
hardwareRev |
Dynamic |
N/A |
Yes |
modelName |
Dynamic |
Derived from EXTRACT.V_MP_HIER.EQUIPSPEC_TYPE_HIER |
No |
nativeEmsName |
Static |
No |
Dynamic |
N/A |
No |
serviceState |
Dynamic |
EXTRACT.V_MP_HIER.AVAILABILITY_STATUS_HIER This field is assigned one of the following values: IN_SERVICE, OUT_OF_SERVICE, IN_MAINTENANCE, UNKNOWN, TESTING. |
No |
userLabel |
Dynamic |
Derived from EXTRACT.V_MP_HIER.EQUIPMENT_NAME_HIER |
No |
owner |
Dynamic |
No |
Table 5-6 Equipment Holder Field Mapping
Id |
Static |
No |
name |
Static |
Derived from V_MP_HIER.EQUIPMENT_ACRONYM_HIER The slot number is equivalent to mounting position number. |
No |
description |
Static |
N/A |
No |
serialNumber |
Static |
N/A |
No |
physicalLocation |
Static |
N/A |
No |
modelName |
Dynamic |
No |
nativeEmsName |
Static |
Derived from V_MP_HIER.EQUIPMENT_ACRONYM_HIER |
No |
userLabel |
Dynamic |
Derived from V_MP_HIER.EQUIPMENT_NAME_HIER |
No |
owner |
Dynamic |
Derived from V_MP_HIER.VENDOR_NAME_HIER |
No |
Table 5-7 Physical Port Field Mapping
Id |
Static |
Derived with parent-id from EXTRACT.MV_PORT_ADDRESS.PORTADDR_SEQ |
No |
name |
Static |
Derived from EXTRACT.MV_PORT_ADDRESS.PORTADDR_SEQ |
Yes |
description |
Static |
N/A |
No |
portNumber |
Static |
N/A |
No |
customerPortName |
Static |
N/A |
No |
vendorPortName |
Static |
N/A |
No |
serialNumber |
Static |
N/A |
No |
physicalLocation |
Static |
N/A |
No |
nativeEmsName |
Static |
N/A |
No |
direction |
Dynamic |
Bidirection |
No |
tpProtectionAssociation |
Dynamic |
N/A |
No |
edgePoint |
Dynamic |
True |
No |
physicalAddress |
Static |
EXTRACT.MV_PORT_ADDRESS.NODE_ADDRESS when EXTRACT.MV_PORT_ADDRESS.PORTADDR_TYPE value corresponds to physical |
No |
Table 5-8 Logical Device Field Mapping
Id |
Static |
N/A |
No |
name |
Static |
EXTRACT.V_EQUIPMENT.NW_NODE_NAME |
Yes |
description |
Static |
N/A |
No |
specification |
Static |
N/A |
No |
nativeEmsAdminServiceState |
Static |
N/A |
No |
nativeEmsServiceState |
Static |
N/A |
No |
physicalLocation |
Static |
No |
Table 5-9 Media Interface Field Mapping
Id |
Static |
N/A |
No |
name |
Static |
No |
description |
Static |
N/A |
No |
ifType |
Static |
PTP, FTP, or CTP, according to the entity being modeled |
No |
interfaceNumber |
Static |
N/A |
No |
customerInterfaceNumber |
Static |
N/A |
No |
vendorInterfaceNumber |
Static |
N/A |
No |
nativeEmsName |
Static |
N/A |
No |
Static |
N/A |
No |
Static |
N/A |
No |
mtuSupported |
Static |
N/A |
No |
mtuCurrent |
Static |
N/A |
No |
physicalAddress |
Static |
N/A |
No |
physicalLocation |
Static |
N/A |
No |
minSpeed |
Static |
N/A |
No |
maxSpeed |
Static |
N/A |
No |
nominalSpeed |
Static |
N/A |
No |
connectionState |
Dynamic |
EXTRACT.MV_CIRCUIT.STATUS |
No |
tpMappingMode |
Dynamic |
N/A |
No |
Direction |
Dynamic |
Bidirection |
No |
Dynamic |
N/A |
No |
edgePoint |
Dynamic |
N/A |
No |
userLabel |
Dynamic |
N/A |
No |
owner |
Dynamic |
N/A |
No |
activeEmsConnectorPresent |
Static |
N/A |
No |
Table 5-10 Pipe Field Mapping
name |
Static |
V_CIRCUIT.EXCHANGE_CARRIER_CIRCUIT_ID |
Yes |
Id |
Static |
EXTRACT.MV_CIRCUIT.CIRCUIT_DESIGN_ID |
No |
gapPipe |
Static |
Hard-coded to FALSE |
No |
physicalLocation |
Static |
EXTRACT.V_CIRCUIT.LOC_A_CLLI_CODE |
No |
layerRate |
Dynamic |
EXTRACT.MV_CIRCUIT.RATE_CODE |
No |
Rerouted |
Dynamic |
No |
partial |
Dynamic |
Derived: set to FALSE if the number of ports is greater than one, else it is TRUE. |
No |
Table 5-11 Transport Pipe Field Mapping
name |
Static |
Yes |
Id |
Static |
No |
gapPipe |
Static |
No |
physicalLocation |
Static |
No |
layerRate |
Dynamic |
No |
Rerouted |
Dynamic |
No |
partial |
Dynamic |
No |
Table 5-12 STM Link Field Mapping
name |
Static |
EXTRACT.V_CIRCUIT.EXCHANGE_CARRIER_CIRCUIT_ID |
Yes |
Id |
Static |
No |
gapPipe |
Static |
No |
physicalLocation |
Static |
No |
layerRate |
Dynamic |
No |
Table 5-13 Trail Path Field Mapping
name |
Static |
EXTRACT.V_CIRCUIT_POSITION.EXCHANGE_CARRIER_CIRCUIT_ID |
Yes |
gapPipe |
Static |
No |
layerRate |
Dynamic |
EXTRACT.V_CIRCUIT_POSITION.RATE_CODE |
No |
channel |
Dynamic |
EXTRACT.V_CIRCUIT_POSITION.JKLM |
Yes |
Table 5-14 Trail Pipe Field Mapping
name |
Static |
Yes |
AEnd |
Static |
Derived from the originating port name |
No |
ZEnd |
Dynamic |
Derived from the terminating port name |
No |
channel |
Dynamic |
Yes |
Table 5-15 Pipe Termination Point Field Mapping
name |
Static |
Hierarchical name derived from of the following:
Yes |
physicalLocation |
Static |
EXTRACT.V_PA_HIER.CLLI_CODE |
No |
Device |
Dynamic |
EXTRACT.V_PA_HIER.NW_NODE_NAME |
Yes |
Directionality |
Dynamic |
EXTRACT.V_PA_HIER.A_Z_OTHER_CD |
Yes |
Data Import Algorithm
This section explains the various algorithms and logic used to model the imported MSS inventory data.
Import Equipment Hierarchy Algorithm
This algorithm uses Java framework pagination to incrementally retrieve node names from each page created by the Page Creator processor. This algorithm uses the following logic:
Gets all the node names from EquipmentExportDAO.
For each node:
Creates a physical and logical device in the Information Model.
Gets the root equipment (such as a shelf, or rack) from EquipmentExportDAO.
For each root equipment:
Verifies that the occupiedMountingPositions attribute value is 0:
If yes, the equipment is modeled as a rack.
If no, verifies whether the root equipment has a mounting position. If there is a mounting position, the equipment is modeled as a shelf.
Associates the rack and shelf to the physical device and states the equipment type (rack or shelf) in the equipment name.
Retrieves the child equipment hierarchy from EquipmentPositionHierDAO (child equipment are represented as EquipmentPositionHier entities).
Queries the ports in the root equipment hierarchy from EquipmentPortAddressDAO (ports are represented as EquipmentPortAddress entities).
Creates a list that maps card IDs to their ports.
For each EquipmentPortAddress entity, verifies if leafEquipmentId equals EquipmentId.
If yes, models the port as a physical port (FTP) and associates it with the parent equipment. Models a media interface, associates it to the physical port, and sets the media interface as a child of the logical device.
If no, fills the card ID and all ports with the leafEquipmentId value as the list of associated ports.
Builds the child equipment hierarchy in the Information Model with the EquipmentPositionHier entities.
Saves the modeling information to the physical and logical trees.
Build Equipment Hierarchy Algorithm
The input for this algorithm is the list of EquipmentPositionHier entities and the map of cards-to-ports. Each EquipmentPositionHier is an immediate child (either a card or shelf) of the root equipment. This algorithm uses the following logic:
Gets the list of mounting position numbers down the hierarchy for each EquipmentPositionHier entity.
For each mounting position number:
Models a shelf object as an equipment entity if its parent is a rack object and the shelf is not yet built in this hierarchy and associates the child with its parent.
Models a card object as an equipment entity if the shelf is already built. Models a slot object as an equipment holder entity for the card. If the slot is already built, models a sub-slot object as an equipment holder entity. Associates children objects with their parent.
Gets the list of ports associated with the card from the map of cards-to-ports.
Models each port as a physical port and a media interface entity. Associates the media interface and the physical port with the logical device.
Adds the EquipmentPortAddressDAO entities to each port as a collection.
Import Circuit Hierarchy Algorithm
MSS and the MSS Integration cartridge distinguish between the following types of circuits:
STM (physical circuit, such as STM1 or STM4)
HOT (logical circuit, such as VC4)
LOP (logical circuit, such as E1, E3, or E4)
Table 5-16 shows the relationship between the imported MSS data, physical TMF814 entities, and physical Information Model entities.
Table 5-16 MSS Circuit Data Mapping to Information Model
STM-Type Circuit |
STM Link |
Link |
LOP-Type Circuit |
Customer Circuit or LOP |
Pipe |
HOT-Type Circuit |
HOT |
Transport Pipe |
MSS organizes logical circuits as children to physical circuits. The input for this algorithm is the list of EquipmentPortAddress entities produced by the Build Equipment Hierarchy algorithm. This algorithm uses the following logic:
For each port entity from the EquipmentPortAddress table:
Gets the CircuitPortAddress instance containing the circuit ID corresponding to an STM link passing through that port.
Queries the CircutExport table to get the STM link with the circuit ID.
Obtains the aPort and zPort for the STM link from the CircuitPortAddress table.
Models the STM link as an optical topological link entity, models its ports as pipe termination point entities, and associates the ports to their link.
Adds the modeled STM link circuit ID to the stmSet collection.
Identifies all VC4 HOT circuits for all the STM circuit IDs in the stmSet collection by querying the trail from CircuitPositionDAO. For each trail:
Identifies E4 customer circuits by counting its children in the CircuitPosition table. For each E4 customer circuit:
Queries the CircuitExport table for the circuit ID and models the CircuitExport object as a pipe entity.
Queries the ports for the circuit from the CircuitPortAddress table, models them as PTPs, and associates them to their pipe entity.
Queries the trail path from the CircuitPosition table, models them as trail path entities, and associates them to their pipe entity.
Verifies the JKLM value for the trail path, and corrects it if necessary.
Identifies VC4 HOT circuits by evaluating the layer rate code. For each VC4 HOT circuit:
Models them as transport pipe entities.
Queries the CircuitExport table for circuit ID and models the CircuitExport object as a transport pipe entity.
Queries the parent STM link from the CircuitPosition table, and queries the STM link ports from the CircuitPortAddress table.
Determines the start-port and end-port from the STM link ports, models them as pipe termination points entities, and associates them to their transport pipe entity.
Queries the trail paths from the CircuitPosition table, models them as trail path entities, and associates them to their pipe entity.
Adds the modeled transport pipe circuit ID to the vc4sForLops list.
Queries E1 and E3 trail circuits for each VC4 circuit in the vc4sForLop list. For each trail circuit:
Queries circuits from the CircuitExport table and models them as pipe entities.
Queries customer circuit ports from the CircuitPortAddress table, models them as pipe termination point entities, and associates the ports to the pipe.
Queries trail paths from the CircuitPosition table, models them as trail path entities, and associates them to the pipe.
About Discrepancy Resolution Modeling
The Discrepancy Resolution action uses different field mappings depending on the type of entity being resolved.
Discrepancy Resolution Field Mapping for Equipment
The MSS Integration cartridge uses MSS CORBA API methods to resolve equipment discrepancies. Each API method runs a Type Java object. Table 5-17 explains the field mapping for physical entities mapping to circuits in the Information Model.
Table 5-17 Equipment Resolution Field Mapping
| MSS CORBA API | Information Model Attribute | API Type Field |
MetaSolv.CORBA.WDIEquipmentTypes.EquipSpecQuery (Equipment entity) |
MetaSolv.CORBA.WDIEquipmentTypes_v2.EquipmentInstallation (Equipment entity) |
MetaSolv.CORBA.WDIEquipmentTypes_v2.EquipmentUpdate (Equipment entity) |
MetaSolv.CORBA.WDIEquipmentTypes_v2.EquipInstallQuery (Equipment entity) |
MetaSolv.CORBA.WDIEquipmentTypes_v2.NetworkElementQuery (Equipment entity) |
MetaSolv.CORBA.WDIEquipmentTypes_v2.NetworkElementCreate (PhysicalDevice entity) |
MetaSolv.CORBA.WDIEquipmentTypes_v2.NetworkElementResult (PhysicalDevice entity) |
MetaSolv.CORBA.WDINetworkLocationTypes_v2.NetworkLocationQuery (PhysicalDevice entity) |
Discrepancy Resolution Field Mapping for Circuits
Table 5-18 explains the field mapping for circuit entities mapping to circuits in the Information Model.
Table 5-18 Circuit Resolution Field Mapping
| Information Model Entity | Information Model Attribute | Connection Field |
Pipe |
Specification Name |
Ratecode |
Pipe |
Termination points |
Ports |
Pipe |
Channel |
Circuit positions |
Pipe |
PipeTerminationPoint.Originating.location |
ALocation |
Pipe |
PipeTerminationPoint.Terminating.location |
ZLocation |
