6 About Design Studio Construction
This chapter provides information on the composition of the Oracle Communications Network Integrity MSS Integration cartridge from the Oracle Communications Design Studio perspective.
Model Collections
The MSS Integration cartridge models imported data to the TMF814 Generic specification. See Network Integrity Optical TMF814 CORBA Cartridge Guide for more information.
Actions
The following tables outline the Design Studio construction of the MSS Integration cartridge and associated components.
Table 6-1 Actions Design Studio Construction
| Action | Result Category | Scan Parameter Groups | Processors |
Import from MSS |
Device |
See Table 6-2 |
See Table 6-3 |
Detect Equipment Discrepancies |
Device |
N/A |
See Table 6-4 |
MSS Circuit Discrepancy Detection |
Circuit |
N/A |
See Table 6-5 |
Resolve in MSS |
Device |
N/A |
See Table 6-6 |
Table 6-2 Cartridge Scan Parameter Groups Design Studio Construction
| Characteristic Name | Type | Description | UI Label |
NetworkLocation |
Text box |
The network location. Enter either the common language location identifier (CLLI) code, or the coded location from MSS. |
Network Location |
Status |
Drop down |
List: All, Installed equipment, Equipment under maintenance The status of the root equipment. |
Status |
NodeNameQualifier |
Drop down |
Works in combination with the NodeName parameter to filter the imported nodes by name and qualifier. |
Node Name Qualifier |
NodeName |
Text box |
The device name or a list of device names. |
Node Name |
NodeId |
Text box |
The node ID or a list of node IDs. |
Node Id |
Scope |
Drop down |
List:
The scope of data to import from MSS. |
Scope |
RunMSSExtract |
Drop down |
Boolean to determine whether to run MSS incremental extraction procedure before the scan run. |
Run MSS Extract |
Table 6-3 Import Processors Design Studio Construction
| Processor Name | Variable |
Equipment DAOs Initializer |
Input: N/A Output:
Page Initializer |
Input: daoLocator Output:
Page Creator |
Input:
Output:
Node Collector |
Input: daoLocator, nodeNameList Output:
Device Modeler |
Input:
Output:
Equipment Hierarchy Collector |
Input:
Output:
Equipment Hierarchy Modeler |
Input: cardsToPortsMap, equipmentHierarchyDetails, rootEquipment, collectedPortsUnderNode, physicalDevice, logicalDevice Output: N/A |
Hierarchy Persister |
Input: logicalDevice, physicalDevice Output: N/A |
STM Link Discoverer |
Input: collectedPortsUnderNode, daoLocator, physicalDevice Output:
VC4 Circuit Discoverer |
Input: stmList, daoLocator, physicalDevice Output:
VC3 VC12 LOP Discoverer |
Input: daoLocator, igForCircuits, PhysicalDevice, vc4sForLops Output: N/A |
Table 6-4 Equipment Discrepancy Detection Processors Design Studio Construction
Equipment Filters Initializer |
Input: N/A Output: N/A |
Discrepancy Detector |
This processor is imported from the NetworkIntegritySDK cartridge project. |
Discrepancy Filter |
Check Auto Resolution Selected |
MSS Auto Resolve Selected Discrepancies |
Input: autoResolutionManager Output: N/A |
Identify Auto Resolving Discrepancies |
Prepare Resolving Discrepancies |
Table 6-5 Circuit Discrepancy Detection Processors Design Studio Construction
Circuit Discrepancy Name Filter Initializer |
Input: N/A Output: isTopLevel |
Missing Entity Filter Initializer |
Input: isTopLevel Output: N/A This processor extends the Optical Circuit Discrepancy Detection action on the Optical Circuit Assimilation cartridge. |
Partial Circuit Discrepancy Filter |
Input: N/A Output: N/A This processor extends the Base Detection cartridge. |
Table 6-6 Discrepancy Resolution Processors Design Studio Construction
CORBA Property Initializer |
Input: N/A Output:
MSS CORBA Property Initializer |
Input: corbaSeed Output:
CORBA Connection Manager |
Resolution Framework Initializer |
Input: mssCORBAConnectionDetails, mssEJBConnectionDetails Output:
MSS Resolution Initializer |
Input: mssCORBAConnectionDetails, mssEJBConnectionDetails, namingServer, orb, baseResolutionElement Output: mssCORBAConnectionDetails, mssEJBConnectionDetails |
Resolution Framework Dispatcher |
Input: mssCORBAConnectionDetails, mssEJBConnectionDetails, baseResolutionElement Output: mssCORBAConnectionDetails, mssEJBConnectionDetails |
