1 About Cartridge Packs
This chapter provides an overview of the Oracle Communications Offline Mediation Controller Cartridge Packs.
Topics in this chapter:
Cartridge packs are optional Offline Mediation Controller components that provide functionality for specific mediation or pre-charging functions. Table 1-1 lists the cartridge packs.
Table 1-1 Cartridge Packs
Cartridge Pack Description
AMA CDK Cartridge Pack
Provides the functionality to collect and process AMA data.
ECE Cartridge Pack
Enables Offline Mediation Controller to submit offline charging requests to ECE.
IMS CDF/CGF Cartridge Pack
Collects raw diameter data from IMS devices, converts that data into 32.298 ASN.1 format, and outputs the data to downstream applications.
IPDRv2 Distribution Cartridge Pack
Processes IP detail records (IPDRs).
NetFlow Collection and Processing Cartridge Pack
Processes Netflow records.
Nortel CS 2000 AMADNS Collection Cartridge Pack
Supports the collection of Nortel CS 2000 SN09 AMADNS records.
Nortel DMS-100 MMP AMA Collection Cartridge Pack
Supports the collection of Nortel DMS-100 MMP AMA (I) SN09 records generated by Nortel DMS-100 switches.
Nortel DMS Operational Metrics Cartridge Pack
Provides functionality to retrieve files containing OM records from various telecom switches and send them to external systems. The OM node chain does not modify OM records; there are no EP or AP nodes.
Nortel DMS SMDR Cartridge Pack
Provides the ability to collect SMDR records from DMS-100 switches.
Nortel GSM/UMTS AMA Cartridge Pack
Provides the functionality to collect AMA data from DMS-MSC SDMs, process that data and send it to downstream applications, such as billing systems and/or databases.
Real-Time ASCII File Collection CDK Cartridge Pack
Collects ASCII records from files in real-time.
SGSN06 Cartridge Pack
Supports 3GPP TS 32.298 V6.4.1, 3GPP TS 32.298 7.3.0, and 3GPP TS 32.298 V10.5.0 for SGSN call data records (CDR).
Syslog Collection Cartridge Pack
Collects syslog files from multiple devices.
