2 Installing Cartridge Packs
This chapter describes how to install and set up Oracle Communications Offline Mediation Controller cartridge packs.
Topics in this chapter:
Software Requirements
Offline Mediation Controller cartridge packs require Offline Mediation Controller 15.1.
Before installing the Nortel CS 2000 AMADNS Collection Cartridge Pack or the Nortel DMS-100 MMP AMA Collection Cartridge Pack, install the AMA CDK Cartridge Pack.
To install cartridge packs:
  1. Stop all node managers, administration servers, and administration clients on the system where you are installing the cartridge pack.
  2. Delete any existing cartridge pack JAR file from the OMC_home/cartridges directory, where OMC_home is the directory in which Offline Mediation Controller is installed.
    Table 2-2 lists the cartridge pack names and JAR file names.
  3. Download the cartridge pack from the Oracle software delivery website:
    http://edelivery.oracle.com
  4. Unzip the cartridge kit JAR file to the OMC_home/cartridges directory.
  5. For these cartridges only, copy the JAR file to OMC_home/dbscripts:
    • Nortel DMS SMDR Cartridge Pack
    • Nortel GSM/UMTS AMA Cartridge Pack
  6. Start all node managers, administration servers, and administration clients.
  7. Verify that the cartridge pack has been properly installed by viewing Version Info from the Help menu in Administration Client.
Uninstalling a Cartridge Pack
To uninstall a cartridge pack:
  1. Go to the OMC_home/cartridges directory, where OMC_home is the directory in which Offline Mediation Controller is installed.
  2. Delete the JAR file for the cartridge. See Table 2-2.
  3. For these cartridges only, delete the JAR file from the OMC_home/dbscripts directory:
    You must also remove these cartridges' scripts from the Oracle database. See "Removing Scripts From the Database".
The following cartridge packs include scripts that you must remove from the Oracle database when you uninstall them:
To remove the scripts from the Oracle database:
  1. Run the following command:
    Oracle_home/bin/oemapp dbastudio&
    where Oracle_home is the directory in which you installed the Oracle database software.
    The Oracle Enterprise Console screen appears.
  2. Log in using the following information:
    user: system
    password: oracle
    service: NMCDRS
  3. In the left frame, expand the schema directory and then expand the NMUSER1 directory, which lists the sub-directories.
  4. Expand the sub-directories item by item as follows:
    • Tables
    • Source Types
      • Packages
      • Procedures
      • Functions
      • Java Sources
      • Java Classes
        For each sub-directory mentioned above, there are files related to the schema.
  5. Right-click on each file and then select Remove.
  6. Expand the Storage directory.
  7. Expand the TableSpace directory.
  8. Right-click on each item and then select Remove for the tables listed in Table 2-1.
    Table 2-1 Tables to Remove for Each Cartridge Pack
    Cartridge Pack Tables
    • ENHNMCDRS_MAIN
    • TBLSPC_NAME_YYYYMMDD (if a partition table was created) Where TBLSPC_NAME is configured in REPOMAN_CONFIGURATION table
    • SMDR_MAIN
    • MSLV_YYYYMMDD (if a partition table was created)
  9. (Nortel DMS SMDR Cartridge Pack only) Run the following command as the system user:
    drop user nmuser1 cascade
List of Cartridge Packs and JAR Files
Table 2-2 lists the cartridge packs and their associated JAR file names.
Table 2-2 Cartridge Packs and Their JAR Files
Cartridge Pack JAR File
ama_cdk_r12_0_0.jar
ECE Cartridge Pack
ocece_r12_0_0.jar
IMS CDF/CGF Cartridge Pack
IMS_R12_0_0.jar
IPDRv2 Distribution Cartridge Pack
ipdr_v2_r12_0_0.jar
NetFlow Collection and Processing Cartridge Pack
netflow_r12_0_0.jar
cs2k_amadns_r12_0_0.jar
DMS_100_MMP_Collection_R12_0_0.jar
Nortel DMS Operational Metrics Cartridge Pack
om_r12_0_0.jar
smdr_r12_0_0.jar
ama_r12_0_0.jar
Real-Time ASCII File Collection CDK Cartridge Pack
realtime_ascii_r12__0_0.jar
SGSN06 Cartridge Pack
sgsn06_r12_0_0.jar
Syslog Collection Cartridge Pack
syslog_r12_0_0.jar
