4 Order-to-Activate Cartridge Contents
This chapter describes the various Order-to-Activate cartridges, their entities, and how these entities can be extended.
In the Oracle Communications Order to Cash solution, Oracle Communications Order and Service Management (OSM) does not directly interact with Oracle Communications Billing and Revenue Management (BRM), Siebel Customer Relationship Management (Siebel CRM), or provisioning systems. OSM uses Oracle Application Integration Architecture (Oracle AIA), which in turn uses BRM Application Business Connector Service (ABCS) for billing and CRM ABCS for Siebel CRM.
Cartridge Overview
Following is an overview of the cartridges. You should not modify productized cartridges, but demonstration cartridges are sample cartridges provided so that you can modify them to meet your needs.
Common Order Management Cartridges
Common order management cartridges contain data and entities that are available in all solution options and topologies.
Table 4-1 lists and describes the common order management cartridges.
Table 4-1 Common Order Management Cartridges
| Cartridge Name | Description |
OracleComms_OSM_CommonDataDictionary |
Productized cartridge. Orchestration Common ControlData dictionary (core Oracle Communications Design Studio product cartridge) |
OracleComms_OSM_O2A_AIAEBMDataDictionary |
Productized cartridge. This data dictionary cartridge contains the data schema that defines the data elements from the Oracle AIA Enterprise Business Message (EBM) schema. |
OracleComms_OSM_O2A_CommonUtility |
Productized cartridge. This data dictionary cartridge contains the data schema that defines the data elements for modeling orchestration entities in OSM. |
OracleComms_OSM_O2A_ControlMap |
Productized cartridge. This cartridge provides testing utilities including breakpoints, point of no return disabling, and support for fault simulation. |
OracleComms_OSM_O2A_RecognitionFallout |
Productized cartridge. This cartridge generates Oracle AIA trouble ticket creation request messages for unrecognizable customer order messages. |
OracleComms_OSM_O2A_SystemAdmin |
Productized cartridge. This cartridge works in conjunction with the Inbound Message Recovery message-driven bean (MDB) to create fallout tasks that help you recover from inbound message processing errors. |
Central Order Management Cartridges
Central order management cartridges contain the processes for the central order management functionality and also the Oracle AIA interaction mechanism which in turn interacts with Siebel CRM, BRM, and OSM in its service order management role.
Some central order management cartridges are common to both the solution option that uses calculate service order and the solution option that does not. Other cartridges are specific to one solution option or the other.
Common Central Order Management Cartridges
Table 4-2 lists the central order management cartridges that are used by both the calculate service order solution option and the service option without calculate service order.
Table 4-2 Common Central Order Management Cartridges
OracleComms_OSM_O2A_COM_Base |
Productized cartridge. This cartridge supports the orchestration of customer orders from Oracle AIA. |
OracleComms_OSM_O2A_COM_SalesOrderFulfillment |
Productized cartridge. This cartridge supports the communications between central order management and fulfillment systems. |
OracleComms_OSM_O2A_COM_Billing |
Productized cartridge. This cartridge supports billing fulfillment functions. |
OracleComms_OSM_O2A_COM_Provisioning |
Productized cartridge. This cartridge supports provisioning fulfillment functions. |
OracleComms_OSM_O2A_COM_Shipping_Sample |
Demonstration cartridge. This cartridge supports shipping fulfillment functions. |
OracleComms_OSM_O2A_COM_Install_Sample |
Demonstration cartridge. This cartridge supports installation fulfillment functions. |
OracleComms_OSM_O2A_COM_Recognition_Sample |
Demonstration cartridge. This cartridge recognizes a customer order from Oracle AIA and triggers the creation of a COM_SalesOrderFulfillment order. It is used for both solution options when the workspace contains only central order management. |
Central Order Management Cartridges for the Calculate Service Order Solution Option
Table 4-3 lists and describes the central order management cartridges for the Calculate Service Order solution option.
Table 4-3 Central Order Management Cartridges for the Calculate Service Order Solution Option
OracleComms_OSM_O2A_COM_CSO_Base |
Productized cartridge. This cartridge contains entities, like orchestration processes, order items, and transformation sequences, that support the orchestration of orders for the calculate service order solution option. |
OracleComms_OSM_O2A_COM_CSO_Broadband_Internet_Access_CFS |
Demonstration cartridge. This cartridge contains the mapping rules and order item parameter bindings associated with the customer facing service for broadband internet access. |
OracleComms_OSM_O2A_COM_CSO_Email_CFS |
Demonstration cartridge. This cartridge contains the mapping rules and order item parameter bindings associated with the customer facing service for email service. |
OracleComms_OSM_O2A_COM_CSO_FulfillmentPattern |
Productized cartridge. This cartridge contains fulfillment patterns and orchestration dependencies for the calculate service order solution option. |
OracleComms_OSM_O2A_COM_CSO_FulfillmentStateMap |
Productized cartridge. This cartridge contains fulfillment state maps and transformed order item fulfillment state composition rule sets specific to the calculate service order solution option. |
OracleComms_OSM_O2A_COM_CSO_Internet_Media_CFS |
Productized cartridge. This cartridge contains the mapping rules and order item parameter bindings associated with the customer facing service for Internet media service. |
OracleComms_OSM_O2A_COM_CSO_IP_Fax_CFS |
Productized cartridge. This cartridge contains the mapping rules and order item parameter bindings associated with the customer facing service for IP fax service. |
OracleComms_OSM_O2A_COM_CSO_Model_Container |
Demonstration cartridge. This cartridge defines the common model projects that contain elements that might need to be included in the deployment and contains the transformation manager for the calculate service order solution option. |
OracleComms_OSM_O2A_COM_CSO_Provisioning |
Demonstration cartridge. This cartridge contains order components for provisioning that are specific to the calculate service order solution option. |
OracleComms_OSM_O2A_COM_CSO_SalesOrders |
Demonstration cartridge. This cartridge contains sample customer orders for use with the calculate service order solution option. |
OracleComms_OSM_O2A_COM_CSO_Solution |
Demonstration composite cartridge. This cartridge references all cartridges required when the calculate service order solution option is used and the current workspace is for central order management only. |
OracleComms_OSM_O2A_COM_CSO_Topology |
Productized cartridge. This cartridge contains decomposition rules and order components for the topology you selected when installing the Order-to-Activate cartridges. |
OracleComms_OSM_O2A_COM_CSO_VoIP_Access_CFS |
Demonstration cartridge. This cartridge contains the mapping rules and order item parameter bindings associated with the customer facing service for Voice over Internet Protocol (VoIP) access. |
OracleComms_OSM_O2A_COM_CSO_Web_Conferencing_CFS |
Productized cartridge. This cartridge contains the mapping rules and order item parameter bindings associated with the customer facing service for web conferencing service. |
OracleComms_OSM_O2A_COM_FulfillmentPattern |
Productized cartridge. This cartridge contains the base fulfillment pattern from which other fulfillment patterns can inherit. |
OracleComms_OSM_O2A_COM_FulfillmentStateMap_Sample |
Demonstration cartridge. This cartridge contains fulfillment state entities used by the solution. |
OracleComms_OSM_O2A_COMSOM_CSO_Recognition |
Demonstration cartridge. This cartridge recognizes a customer order from Oracle AIA and triggers the creation of a COM_SalesOrderFulfillment order. It is used when the current workspace includes both central order management and service order management. |
OracleComms_OSM_O2A_COMSOM_CSO_Solution |
Demonstration composite cartridge. This cartridge references all cartridges required when the calculate service order solution option is used and the current workspace is for both central order management and service order management. |
Central Order Management Cartridges for the Solution Option Without Calculate Service Order
Table 4-4 lists and describes the central order management cartridges for the solution option without Calculate Service Order.
Table 4-4 Central Order Management Cartridges for the Solution Option Without Calculate Service Order
OracleComms_OSM_O2A_BBVoIP_FP_NP_Danube_Sample |
Demonstration cartridge. This cartridge contains fulfillment patterns and orchestration dependencies for the Simple topology. |
OracleComms_OSM_O2A_BBVoIP_FP_NP_Nile_Sample |
Demonstration cartridge. This cartridge contains fulfillment patterns and orchestration dependencies for the Typical or Complex topologies. |
OracleComms_OSM_O2A_COM_NCSO_Base |
OracleComms_OSM_O2A_COM_NCSO_Provisioning |
OracleComms_OSM_O2A_COM_Simple_NP_Soln |
Demonstration composite cartridge. This cartridge references all cartridges required for the Simple topology for central order management. |
OracleComms_OSM_O2A_COM_Typical_NP_Soln |
Demonstration composite cartridge. This cartridge references all cartridges required for the Typical or Complex topologies for central order management. |
OracleComms_OSM_O2A_COMSOM_Recognition_Sample |
OracleComms_OSM_O2A_COMSOM_Simple_NP_Soln |
Demonstration composite cartridge. This cartridge references all cartridges required for the Simple topology. It is used when the current workspace includes both central order management and service order management. |
OracleComms_OSM_O2A_COMSOM_Typical_NP_Soln |
Demonstration composite cartridge. This cartridge references all cartridges required for the Typical or Complex topologies. It is used when the current workspace includes both central order management and service order management. |
OracleComms_OSM_O2A_FulfillmentPatternMap_Sample |
Demonstration cartridge. This cartridge contains the mappings between product specifications and fulfillment patterns. |
OracleComms_OSM_O2A_SalesOrders_NP_Sample |
Demonstration cartridge. This cartridge contains sample customer orders. |
OracleComms_OSM_O2A_SimpleTopology_Sample |
Demonstration cartridge. This cartridge contains decomposition rules and order components for the Simple topology. |
OracleComms_OSM_O2A_TypicalTopology_Sample |
Demonstration cartridge. This cartridge contains decomposition rules and order components for the Typical or Complex topology |
Danube and Nile are the names for the process fulfillment patterns in the Simple and Typical topologies, respectively. See "About Fulfillment Topologies" for more details on topologies.
Service Order Management Cartridges
Service order management cartridges contain the OSM functionality that handles a provisioning request as a service order from central order management and completes the predetermined tasks to fulfill the service order.
Service order management cartridges are specific to either the solution option that uses calculate service order or the solution option that does not.
Service Order Management Cartridges for the Calculate Service Order Solution Option
Table 4-5 lists and describes the service order management cartridges for the Calculate Service Order solution option.
Table 4-5 Service Order Management Cartridges for the Calculate Service Order Solution Option
OracleComms_OSM_O2A_SOM_CSO_Base |
Productized cartridge. This cartridge supports the orchestration of service orders. |
OracleComms_OSM_O2A_SOM_CSO_Broadband_Internet_Access_CFS |
Demonstration cartridge. This cartridge contains the order item parameter bindings associated with the customer facing service for broadband internet access. |
OracleComms_OSM_O2A_SOM_CSO_Common |
Productized cartridge. This cartridge contains data elements and fulfillment modes for service order management with the calculate service order solution option. |
OracleComms_OSM_O2A_SOM_CSO_CompleteProvisioning |
Demonstration cartridge. This cartridge supports provisioning fulfillment functions for service order management. |
OracleComms_OSM_O2A_SOM_CSO_DeliverOrder |
Demonstration cartridge. This cartridge supports order delivery fulfillment functions for service order management. |
OracleComms_OSM_O2A_SOM_CSO_DesignService |
Demonstration cartridge. This cartridge supports service design functions for service order management. |
OracleComms_OSM_O2A_SOM_CSO_Email_CFS |
Demonstration cartridge. This cartridge contains the order item parameter bindings associated with the customer facing service for email service. |
OracleComms_OSM_O2A_SOM_CSO_FulfillmentPattern |
Productized cartridge. This cartridge contains fulfillment patterns for service order management. |
OracleComms_OSM_O2A_SOM_CSO_FulfillmentStateMap |
Productized cartridge. This cartridge contains fulfillment state entities for service order management. |
OracleComms_OSM_O2A_SOM_CSO_Internet_Media_CFS |
Demonstration cartridge. This cartridge contains the order item parameter bindings associated with the customer facing service for Internet media service. |
OracleComms_OSM_O2A_SOM_CSO_IP_Fax_CFS |
Demonstration cartridge. This cartridge contains the order item parameter bindings associated with the customer facing service for IP fax service. |
OracleComms_OSM_O2A_SOM_CSO_ModelContainer |
Demonstration cartridge. This cartridge defines the common model projects that contain elements that might need to be included in the deployment. |
OracleComms_OSM_O2A_SOM_CSO_PlanDelivery |
Demonstration cartridge. This cartridge supports delivery planning functions for service order management. |
OracleComms_OSM_O2A_SOM_CSO_Recognition |
Demonstration cartridge. This cartridge recognizes a service order from central order management and triggers the creation of a SOM_ProvisionServiceOrderFulfillment order. Catches all in-bound messages not recognized by any other provisioning recognition rules. |
OracleComms_OSM_O2A_SOM_CSO_Solution |
Demonstration composite cartridge. This cartridge references all cartridges required when the calculate service order solution option is used and the current workspace is for service order management only. |
OracleComms_OSM_O2A_SOM_CSO_Topology |
Productized cartridge. This cartridge contains entities, such as decomposition rules and order components, for service order management. |
OracleComms_OSM_O2A_SOM_CSO_VoIP_Access_CFS |
Demonstration cartridge. This cartridge contains the order item parameter bindings associated with the customer facing service for VoIP access. |
OracleComms_OSM_O2A_SOM_CSO_Web_Conferencing_CFS |
Demonstration cartridge. This cartridge contains the order item parameter bindings associated with the customer facing service for web conferencing service. |
Service Order Management Cartridges for the Solution Option Without Calculate Service Order
Table 4-6 lists and describes the service order management cartridges for the solution option without Calculate Service Order.
Table 4-6 Service Order Management Cartridges for the Solution Option Without Calculate Service Order
OracleComms_OSM_O2A_SOM_Base |
Productized cartridge. This cartridge supports the orchestration of service orders, including handling status and data updates from fulfillment requests back to central order management. |
OracleComms_OSM_O2A_SOM_Provisioning |
Productized cartridge. This cartridge supports provisioning fulfillment functions in service order management. |
OracleComms_OSM_O2A_SOM_Solution |
Demonstration composite cartridge. This cartridge references all cartridges required for service order management. |
OracleComms_OSM_O2A_SOM_Recognition_Sample |
OracleComms_OSM_O2A_SomBBVoIP_FP_NP_Sample |
Demonstration cartridge. This cartridge contains fulfillment patterns, decomposition rules, and order components for service order management functions. |
OracleComms_OSM_O2A_SomProvisionBroadband_Sample |
Demonstration cartridge. This cartridge supports service orders for broadband services. |
OracleComms_OSM_O2A_SomProvisionVoIP_Sample |
Demonstration cartridge. This cartridge supports service orders for VoIP services. |
Conceptual Model Projects
Conceptual model projects contain the relationships between your commercial products, the services that they represent, and the resources that are required to implement the services. These projects are not deployed, but the information in them that is needed for deployment is deployed with the OracleComms_OSM_O2A_COM_CSO_Model_Container cartridge.
For more information about the conceptual model, see Design Studio Concepts.
Common Conceptual Model Projects
Table 4-7 lists the conceptual model projects that are present in both central order management and service order management workspaces.
Table 4-7 Common Conceptual Model Projects
OracleComms_Model_Base |
Productized cartridge. This cartridge contains entities, like provider functions and functional areas, that support conceptual modeling. |
OracleComms_Model_BaseCatalog |
Productized cartridge. This cartridge contains conceptual model fulfillment patterns. |
OracleComms_Model_Common |
Productized cartridge. This cartridge contains a data schema with common data element definitions. |
OracleComms_Model_O2A_Broadband_Internet_Access_CFS |
Productized cartridge. This cartridge contains the customer facing services for broadband Internet access. |
OracleComms_Model_O2A_Broadband_Internet_Access_SA |
Productized cartridge. This cartridge contains the actions for broadband Internet access. |
OracleComms_Model_O2A_Broadband_Internet_DataModel |
Productized cartridge. This cartridge contains a data schema for data specific to broadband Internet access. |
OracleComms_Model_O2A_Email_CFS |
Productized cartridge. This cartridge contains the customer facing services for email. |
OracleComms_Model_O2A_Email_DataModel |
Productized cartridge. This cartridge contains a data schema for data specific to email. |
OracleComms_Model_O2A_Email_SA |
Productized cartridge. This cartridge contains the actions for email. |
OracleComms_Model_O2A_Internet_Media_CFS |
Productized cartridge. This cartridge contains the customer facing services for Internet media. |
OracleComms_Model_O2A_Internet_Media_DataModel |
Productized cartridge. This cartridge contains a data schema for data specific to Internet media. |
OracleComms_Model_O2A_Internet_Media_SA |
Productized cartridge. This cartridge contains the actions for Internet media. |
OracleComms_Model_O2A_VoIP_Access_CFS |
Productized cartridge. This cartridge contains the customer facing services for VoIP. |
OracleComms_Model_O2A_VoIP_Access_SA |
Productized cartridge. This cartridge contains the actions for VoIP. |
OracleComms_Model_O2A_VoIP_DataModel |
Productized cartridge. This cartridge contains a data schema for data specific to VoIP. |
Conceptual Model Projects for Central Order Management
Table 4-8 lists the conceptual model projects that are only present in workspaces with central order management installed.
Table 4-8 Conceptual Model Projects for Central Order Management
OracleComms_Model_O2A_Billing_PS |
Productized cartridge. This cartridge contains the domains and products for billing services. |
OracleComms_Model_O2A_Broadband_Internet_PS |
Productized cartridge. This cartridge contains the domains and products for broadband Internet access services. |
OracleComms_Model_O2A_Email_PS |
Productized cartridge. This cartridge contains the domains and products for email services. |
OracleComms_Model_O2A_Install_PS |
Productized cartridge. This cartridge contains the domains and products for installation services. |
OracleComms_Model_O2A_Internet_Media_PS |
Productized cartridge. This cartridge contains the domains and products for Internet media services. |
OracleComms_Model_O2A_VoIP_PS |
Productized cartridge. This cartridge contains the domains and products for VoIP services. |
Conceptual Model Projects for Service Order Management
Table 4-9 lists the conceptual model projects that are only present in workspaces with service order management installed.
Table 4-9 Conceptual Model Projects for Service Order Management
OracleComms_Model_O2A_SOM_PS |
Productized cartridge. This cartridge contains the products for service order management. This cartridge is only present when the service option without calculate service order is used. |
The following cartridges provide common data dictionary elements that are used by or referenced by other Order-to-Activate cartridges.
The OracleComms_OSM_CommonDataDictionary cartridge is a productized data dictionary cartridge. It contains the data schema that defines the data elements for modeling orchestration entities in OSM.
This cartridge is referenced by many other cartridges, including OracleComms_OSM_O2A_COM_Base, OracleComms_OSM_O2A_SOM_CSO_Base, and OracleComms_OSM_O2A_SOM_Base.
The OracleComms_OSM_O2A_AIAEBMDataDictionary cartridge is a productized data dictionary cartridge that is part of the core OSM product. It contains the data schema that defines the data elements from the Oracle AIA EBM schema. Cartridges that must include data elements from Oracle AIA EBM can reuse the elements defined in this cartridge.
This cartridge is referenced by the OracleComms_OSM_O2A_COM_Base cartridge.
The OracleComms_OSM_O2A_CommonUtility cartridge is a productized component cartridge. It contains the data schema that defines the data elements for Order-to-Activate cartridges. Cartridges that extend Order-to-Activate cartridges can reuse the elements defined in this cartridge.
Table 4-10 describes the data schema elements that can be reused when extending Order-to-Activate cartridges:
Table 4-10 OracleComms_OSM_O2A_CommonUtility Extensible Data Dictionary Elements
| Data Dictionary Element | Extension |
Order Component |
New fulfillment functions should use this data dictionary element or its extended type as the base fulfillment function type. |
Table 4-11 describes the XQuery modules in the cartridge.
Table 4-11 OracleComms_OSM_O2A_CommonUtility XQuery Modules
| XQuery Module | Extendable | Description |
AIAEBMUtilityModule |
No |
Provides utilities for manipulating Oracle AIA EBM. |
AIAFaultMsgEBMUtilityModule |
No |
Provides utilities for handling Oracle AIA fault messages. |
BreakpointControlModule |
No |
Provides services related to breakpoint control in Order-to-Activate. Please refer to the OracleComms_OSM_O2A_ControlMap cartridge for an extensible way to control breakpoints. |
ComponentDataManagementModule |
No |
Manipulates data structures for fulfillment functions. |
ExtensionPointModule |
No |
Defines XQuery extension points for fulfillment functions. |
ExtensionPointSelector |
No |
Sets the order of the fulfillment function's extension points based on priority. |
FalloutLifecycleModule |
No |
Provides services related to message fallout and trouble ticket tracking. |
FalloutSimulationModule |
No |
Simulates fallout. |
FulfillmentOrderEventModule |
No |
Manages the fulfillment request's events in central order management and service order management. |
FulfillmentOrderLifecycle-ManagementModule |
No |
Provides services related to the fulfillment request's order lifecycle management. |
LogModule |
No |
Provides logging facility for Order-to-Activate cartridges. |
OrderComponentMetadataBuilder |
No |
Provides an internal framework for data discrepancy detection. |
OrderExtensionPointModule |
No |
Provides support for order event extension points. |
OrderExtensionPointSelector |
No |
Provides support for order event extension point selection. |
OrderLifecycleModule |
No |
Provides services related to the fulfillment request's external fulfillment state, milestone tracking, upstream order status map, and status context calculation. |
OSMEBMUtilityModule |
No |
Provides utilities for manipulating EBM in central order management. |
OsmWebServiceModule |
No |
Provides services for OSM web service requests. |
PerspectiveModule |
No |
Provides utilities for retrieving historical perspectives. |
ProductClassToFulfillmentPatternModule |
No |
Provides utilities for order line retrieval for both fulfillment request and service order. |
ProductClassToProductSpec |
Yes |
Provides services related to the mapping between product specifications and fulfillment patterns. |
ProvisionOrderLifecycle-ManagementModule |
No |
Provides services related to service order management-to-fulfillment request lifecycle management. |
ServiceActionCodeModule |
No |
Provides services related to service action calculation. |
SOMEBMUtilityModule |
No |
Provides utilities for manipulating the EBM in service order management. |
SomProductClassToProductSpec |
Yes |
Provides services related to the mapping between product specifications and fulfillment patterns in SOM. |
SystemConfigModule |
No |
Provides constants and utilities for the calculate service order solution option. |
SystemInteractionModule |
No |
Provides services related to message sequencing and generation and order locking. |
TargetMapping |
No |
Returns the target system name for a given active interaction ID during fallout handling. |
TargetSystemManagementModule |
No |
Provides services related to target system information such as target system identifier and code. |
Topology |
No |
Calculates the system topology for the calculate service order solution option. |
TroubleTicket |
No |
Provides utilities for trouble ticketing during fallout handling. |
UpdateServiceOrderStatusFunctionsModule |
No |
Provides services to create EBM message for the service provisioning order to update the service order management order. |
The OracleComms_OSM_O2A_ControlMap cartridge is a productized cartridge that provides the ability to:
Stop at a breakpoint when OSM executes central order management tasks
Disable a point of no return
Simulate a fallout scenario
Configure the processing granularity of billing fulfillment functions dynamically
Manage the frequency of order updates to the upstream system for debugging
To use these functions:
Create a control file in XML, using the parameters listed in the following sections. The same control file can contain more than one control function.
Validate your control file against the BFPMap.xsd schema located in OracleComms_OSM_O2A_ControlMap\resource.
You must validate your control file against the schema because OSM will not validate control files and report errors during order processing. If the file is not a valid XML file, the entire file will be ignored by OSM. If a file contains an invalid element or value, the control function containing the invalid element or value will be ignored.
Put your control file into the OracleComms_OSM_O2A_ControlMap\resource directory.
When you want to use the control file for an order, preface the order number with the name of the control file inside square brackets and without the .xml extension. For example, if you have a control file named control001.xml in the OracleComms_OSM_O2A_ControlMap\resource directory, and you want to use it with an order numbered VOIP01, send the order in with the orderID [control001]VOIP01.
Configuring Breakpoints for Central Order Management and for Service Order Management Without Calculate Service Order
This section applies to configuring breakpoints for central order management for both the calculate service order solution option and the service option without calculate service order and configuring breakpoints for service order management for the solution option without calculate service order. For information about configuring breakpoints for service order management with the calculate service order solution option, see "Configuring Breakpoints for Service Order Management with Calculate Service Order."
If you enable breakpoint control, you can set a breakpoint in the order process to cause the order to go through a particular manual task or a special automated task before or after an interaction with an external system. This enables you to do things like check status and define data.
A breakpoint task for central order management or for service order management for the solution option without calculate service order is defined by:
BreakComponent: This is an order component name; for example, SyncCustomerFunction
ExecutionMode: do, redo, undo, and amend_do
Event: Component_PRESTART (before the component has started), only applicable to FulfillBillingFunction), Component_START (after the component has started), and Component_COMPLETE (after the component has completed)
TargetSystem: ANY, or a particular target system such as BRM-ALL
Example 4-1 contains a control file to configure a breakpoint before FulfillBillingFunction starts.
Example 4-1 Control File to Configure a Breakpoint in FulfillBillingFunction
<?xml version="1.0" encoding="UTF-8"?>
<oms:ControlMap xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="urn:com:metasolv:oms:xmlapi:1 BFPMap.xsd"
xmlns="urn:com:metasolv:oms:xmlapi:1"
xmlns:oms="urn:com:metasolv:oms:xmlapi:1">
<oms:BreakPointControlMap>
<oms:BreakComponent>FulfillBillingFunction</oms:BreakComponent>
<oms:ExecutionMode>do</oms:ExecutionMode>
<Event>Component_PRESTART</Event>
<TargetSystem>ANY</TargetSystem>
</oms:BreakPointControlMap>
</oms:ControlMap>
The valid component names for central order management are:
InitiateBillingFunction
ProvisionOrderFunction
The valid component names for service order management for the solution option without calculate service order are:
SomProvisionOrderFunction
This section applies to configuring breakpoints for service order management for the calculate service order solution option. For information about configuring breakpoints for other situations, see "Configuring Breakpoints for Central Order Management and for Service Order Management Without Calculate Service Order."
A breakpoint task for service order management for the calculate service order solution option is defined by:
BreakComponent: This is an order component name; for example, DesignServiceFunction
Event: The task name in the sub-process of the component
TargetSystem: ANY, or a particular target system such as SOM_DeliverySystem
Table 4-12 describes the components and events used for breakpoints for service order management with the calculate service order option.
Table 4-12 Breakpoint Events for Service Order Management with the Calculate Service Order Solution Option
| Component Name | Events |
DesignServiceFunction |
CaptureBITask ProcessBITask ApproveBITask |
PlanDeliveryFunction |
IssueBITask CalculateTechnicalActionsTask |
DeliverOrderFunction |
CreateTechnicalOrderTask QueryBITask |
CompleteProvisioningFunction |
CompleteBITask |
Example 4-2 contains a control file to configure a breakpoint before FulfillBillingFunction starts.
Example 4-2 Control File to Configure a Breakpoint in DesignServiceFunction
<oms:BreakComponent>DesignServiceFunction</oms:BreakComponent>
<Event>CaptureBITask</Event>
</oms:ControlMap>Controlling Point of No Return
During testing, a user may want to disable OSM's ability to set or check for points of no return. This allows the user to submit an amendment order successfully in situations that would not be allowed under normal circumstances.
You can disable point of no return processing either for all order components or selectively using the following field:
PONRComponent: This can contain any of the following
Order Component Name - For example, SyncCustomerFunction
ALL - Disable point of no return setting and checking for all order components
CONFIG - Disable point of no return checking for all order components when an order amendment is received
Example 4-3 contains a control file that disables point of no return setting and checking for all order components.
Example 4-3 Control File to Disable Points of No Return
<oms:PONRControlMap>
<oms:PONRComponent>ALL</oms:PONRComponent>
</oms:PONRControlMap>
</oms:ControlMap>Controlling Fault Simulation
If you are using the Oracle AIA emulators included with the Order-to-Activate cartridges, you can simulate fallout scenarios using control files.
There are two ways to trigger the emulator to generate a fault response rather than a successful response:
Using the VerbCode field in the EBM
Using a control file
Both methods are discussed in the following sections.
Simulating Faults in Central Order Management
To simulate a fault in central order management using the VerbCode field in the EBM, populate the following XPath location:
ProcessSalesOrderFulfillmentEBM/EBMHeader/VerbCode
Table 4-13 lists the valid values to put in the field and their descriptions.
Table 4-13 VerbCode Values for Central Order Management
| VerbCode Value | Description |
SIMULATE_FAIL_SYNCCUST_FAULT |
The SyncCustomer emulator generates a fault to the AIA error handler. |
SIMULATE_FAIL_SYNCCUST_RESP |
The SyncCustomer emulator sends back an invalid response. |
SIMULATE_FAIL_SYNCCUST_NOTIF |
The SyncCustomer emulator sends back a response with a fault indicator. |
SIMULATE_FAIL_INITBILL_FAULT |
The InitiateBilling emulator generates a fault to the AIA error handler. |
SIMULATE_FAIL_INITBILL_RESP |
The InitiateBilling emulator sends back an invalid response. |
SIMULATE_FAIL_INITBILL_NOTIF |
The InitiateBilling emulator sends back a response with a fault indicator. |
SIMULATE_FAIL_FULFILLBILL_FAULT |
The FulfillBilling emulator generates a fault to the AIA error handler. |
SIMULATE_FAIL_FULFILLBILL_RESP |
The FulfillBilling emulator sends back an invalid response. |
SIMULATE_FAIL_FULFILLBILL_NOTIF |
The FulfillBilling emulator sends back a response with a fault indicator. |
SIMULATE_FAIL_PROV_FAULT |
The ProvisionOrder emulator generates a fault to the AIA error handler. |
SIMULATE_FAIL_PROV_RESP |
The ProvisionOrder emulator sends back an invalid response. |
SIMULATE_FAIL_PROV_NOTIF |
The ProvisionOrder emulator sends back a response with a fault indicator. |
To create a control file to simulate fault situations in central order management, use the following parameters:
FaultComponent: this is an order component name, for example, SyncCustomerFunction
FaultMode:
Fault: generate a fault to the AIA error handler
InvalidRESP: send back an invalid response
FailNotification: send back a response with a fault indicator
Example 4-4 contains a control file that simulates an invalid response for SyncCustomerFunction.
Example 4-4 Control File to Simulate a Fault in Central Order Management
<oms:FaultControlMap>
<oms:FaultComponent>SyncCustomerFunction</oms:FaultComponent>
<FaultMode>InvalidRESP</FaultMode>
</oms:FaultControlMap>
</oms:ControlMap>Simulating Faults in Service Order Management Without Calculate Service Order
To simulate a fault in service order management without the calculate service order solution option using the VerbCode field in the EBM, populate the following XPath location:
Table 4-14 lists the valid values to put in the field and their descriptions.
Table 4-14 VerbCode Values for Service Order Management Without Calculate Service Order
SIMULATE_FAIL_BRD_SERVICEBUNDLE_FAULT |
Service order management generates a fault to the AIA error handler during broadband service bundle provisioning. |
SIMULATE_FAIL_BRD_EMAILSERVICEBUNDLE_FAULT |
Service order management generates a fault to the AIA error handler during broadband email service provisioning. |
SIMULATE_FAIL_BRD_MEDIASERVICEBUNDLE_FAULT |
Service order management generates a fault to the AIA error handler during broadband media service provisioning. |
SIMULATE_FAIL_BRD_CPE_FAULT |
Service order management generates a fault to the AIA error handler during broadband customer premise equipment provisioning. |
SIMULATE_FAIL_VOIP_SERVICEBUNDLE_FAULT |
Service order management generates a fault to the AIA error handler during VoIP service bundle provisioning. |
SIMULATE_FAIL_VOIP_CPE_FAULT |
Service order management generates a fault to the AIA error handler during VoIP customer premise equipment provisioning. |
To create a control file to simulate fault situations in service order management without the calculate service order solution option, use the following parameters:
VerbCode: This can contain any of the values in Table 4-14.
Example 4-5 contains a control file that simulates a failure in provisioning broadband customer premise equipment in execution mode redo.
Example 4-5 Control File to Simulate a Fault in Service Order Management Without Calculate Service Order
<oms:LF_FaultControlMap>
<oms:ExecutionMode>redo</oms:ExecutionMode>
<VerbCode>SIMULATE_FAIL_BRD_CPE_FAULT</VerbCode>
</oms:LF_FaultControlMap>
</oms:ControlMap>Simulating Faults in Service Order Management With Calculate Service Order
To simulate a fault in service order management with the calculate service order solution option using the VerbCode field in the EBM, populate the following XPath location:
Table 4-15 lists the valid values to put in the field and their descriptions.
Table 4-15 VerbCode Values for Service Order Management With Calculate Service Order
SIMULATE_FAIL_CAPTURE_BI_RESP |
The CaptureBI emulator generates a SOAP fault response message. |
SIMULATE_FAIL_CAPTURE_BI_NOTIF |
The CaptureBI emulator generates a normal response message with missing mandatory data. |
SIMULATE_FAIL_PROCESS_BI_RESP |
The ProcessBI emulator generates a SOAP fault response message. |
SIMULATE_FAIL_PROCESS_BI_NOTIF |
The ProcessBI emulator generates a normal response message with missing mandatory data. |
SIMULATE_FAIL_APPROVE_BI_RESP |
The ApproveBI emulator generates a SOAP fault response message. |
SIMULATE_FAIL_APPROVE_BI_NOTIF |
The ApproveBI emulator generates a normal response message with missing mandatory data. |
SIMULATE_FAIL_ISSUE_BI_RESP |
The IssueBI emulator generates a SOAP fault response message. |
SIMULATE_FAIL_ISSUE_BI_NOTIF |
The IssueBI emulator generates a normal response message with missing mandatory data. |
SIMULATE_FAIL_CALCULATE_TA_RESP |
The CalculateTA emulator generates a SOAP fault response message. |
SIMULATE_FAIL_CALCULATE_TA_NOTIF |
The CalculateTA emulator generates a normal response message with missing mandatory data. |
SIMULATE_FAIL_CREATE_TO_RESP |
The CreateTO emulator generates a SOAP fault response message. |
SIMULATE_FAIL_CREATE_TO_NOTIF |
The CreateTO emulator generates a normal response message with missing mandatory data. |
SIMULATE_FAIL_COMPLETE_BI_RESP |
The CompleteBI emulator generates a SOAP fault response message. |
SIMULATE_FAIL_COMPLETE_BI_NOTIF |
The CompleteBI emulator generates a normal response message with missing mandatory data. |
To create a control file to simulate fault situations in service order management with the calculate service order solution option, use the following parameters:
VerbCode: This can contain any of the values in Table 4-15.
Example 4-6 contains a control file that simulates a failure in provisioning broadband customer premise equipment in execution mode redo.
Example 4-6 Control File to Simulate a Fault in Service Order Management Without Calculate Service Order
<VerbCode>SIMULATE_FAIL_CAPTURE_BI_RESP</VerbCode>
</oms:ControlMap>Controlling Order Updates
In Order-to-Activate, order updates are sent by central order management to upstream systems at every milestone update on the order, unless the order is in the Canceling state. The milestones are defined in OracleComms_OSM_O2A_Configuration\solution-config\ComponentMilestoneMap.xml. You can use a control file to disable the order updates for one or more specific milestones.
Following are the attributes and elements to use in your control file to disable updates for a breakpoint:
system: OracleComms_OSM_O2A_SystemAdmintarget system name defined in the <oms:targetSystem> element of the resources/SolutionConfig/TargetSystemMap.xml file in the Order-to-Activate composite cartridge.
execMode: do, redo, and amend_do
ComponentMilestone: COMPONENT-START, COMPONENT-UPDATE, or COMPONENT-COMPLETE
Milestone: Milestone defined by external system such as PROVISION DESIGNED. This field is optional and only applicable to the COMPONENT-UPDATE component milestone.
UpdateUpstreamSystem: Set this to false to disable the event
Example 4-7 contains a control file that disables the sending of updates for the PROVISION START milestone.
Example 4-7 Control File to Disable Updates for PROVISION START
<oms:MilestoneMap system="OSMPROV" systemName="*" execMode="do">
<oms:ComponentMilestone>COMPONENT-START</oms: ComponentMilestone >
<oms:Milestone>PROVISION START</oms:Milestone>
<oms:UpdateUpstreamSystem>false</oms:UpdateUpstreamSystem>
</oms: MilestoneMap>
</oms:ControlMap>Controlling Processing Granularity for FulfillBillingFunction
In Order-to-Activate, the granularity decomposition rule for FulfillBillingFunction uses ServiceBundle granularity by default. If you want to test Order granularity on FulfillBillingFunction, use a control file.
Following are the elements in the control file to change processing granularity:
GranularityFunction: Only FulfillBillingFunction is supported for this element. Any other value is ignored.
Granularity: Only Order and ServiceBundle are supported for this element. Any other value is ignored.
Example 4-8 contains a control file that changes the processing granularity to Order:
Example 4-8 Control File to Change Processing Granularity
<oms:GranularityControlMap>
<oms:GranularityFunction>FulfillBillingFunction</oms:GranularityFunction>
<oms:Granularity>Order</oms: Granularity>
</oms:GranularityControlMap>
</oms:ControlMap>OracleComms_OSM_O2A_RecognitionFallout
The OracleComms_OSM_O2A_RecognitionFallout cartridge is a productized cartridge that generates Oracle AIA trouble ticket creation request messages for unrecognizable customer order messages.
Table 4-16 lists entities that are defined in this cartridge.
Table 4-16 OracleComms_OSM_O2A_RecognitionFallout Entities
| Entity Name | Entity Type | Description |
ORPFalloutPIPOrder |
Order |
The order that is created when an unrecognizable message is received. |
CreationORPFalloutTask |
Manual Task |
Creation task that is used to create an ORPFalloutPIPOrder. |
ORPQueryTask |
Manual Task |
Query task used by a manual user to view the fallout order. |
ORPFalloutProcessErrorTask |
Manual Task |
Task that handles error when creating a fault message in service order management or when creating a fulfillment request for the trouble ticketing system. |
ORPFalloutProcess |
Process and tasks |
Fallout process that creates a trouble ticket for Oracle AIA. |
orpfalloutrole |
Role |
Role with privileges to create and view fallout orders. |
Table 4-17 lists XQuery modules defined in this cartridge.
Table 4-17 OracleComms_OSM_O2A_RecognitionFallout XQuery Modules
CreateErrorFault |
No |
Used by service order management to create a fault notification. |
CreateORPFalloutTroubleTicket |
No |
Creates a trouble ticket EBM for Oracle AIA indicating an ORP error. |
CreateORPFalloutTroubleTicketResponse |
No |
Handles responses from the ORP trouble ticket request. |
DetectORPFalloutHandlingType |
No |
Determines the fallout mode depending on whether this is used in a central order management or service order management context. For central order management, the fallout processing requires creation of a trouble ticket request to the upstream system. For service order management, fallout processing requires creation of a fault notification that is sent to the Oracle AIA error handling queue. |
Table 4-18 lists the automation modules (with their associated automated tasks) defined in this cartridge.
Table 4-18 OracleComms_OSM_O2A_RecognitionFallout Automation Modules
| Automation Module | Automated Task | Description |
CreateErrorFaultBean |
CreateFaultErrorTask |
Calls the CreateErrorFault XQuery. |
CreateORPFalloutTroubleTicketRequestBean |
CreateORPFalloutTroubleTicketTask |
Calls the CreateORPFalloutTroubleTicket XQuery. |
ORPTTResponseBean |
External event receiver to invoke CreateORPFalloutTroubleTicketResponse XQuery. |
DetectORPFalloutHandlingTypeBean |
DetectORPFalloutHandlingTypeTask |
Calls the DetectORPFalloutHandlingType XQuery. |
The OracleComms_OSM_O2A_SystemAdmin cartridge is a productized cartridge that works in conjunction with the Inbound Message Recovery MDB to create fallout tasks that help you recover from inbound message processing errors. The OracleComms_OSM_O2A_SystemAdmin cartridge and Inbound Message Recovery MDB handle errors caused by the following:
Suspended orders (See "Recovering from Inbound Message Errors Due to Suspended Orders")
Order-to-Activate resource issues (See "Recovering from Inbound Message Errors Due to Resource Issues")
Table 4-19 describes the XQuery modules in the cartridge.
Table 4-19 OracleComms_OSM_O2A_SystemAdmin XQuery Modules
InboundMessageHandlerDetection |
No |
Utility module for fallout recovery. Used to find out the handling component type from the response message based on the EBM type. |
InBoundMessageRecovery |
No |
Routes the inbound message for recovery to appropriate target system. |
ResumePendingInBoundMessage_OrderDataRule |
No |
Module used as order data rule when recognizing the inbound message to create the ResumePendingInBoundMessage order. |
How the Inbound Message Recovery MDB Works
The Inbound Message Recovery MDB works with the OracleComms_OSM_O2A_SystemAdmin cartridge to handle inbound message errors. When the message cannot be delivered to the response queue due to JMS system errors, the response queue uses the OSM Integration Pack Fallout Queue. The Inbound Message Recovery MDB listens to the OSM Integration Pack Fallout Queue and does the following:
Routes the message (response) to the OSM InBoundMessageRecoveryQueue queue.
Produces a request to OSM to create the ResumePendingInBoundMessage order (using the OracleComms_OSM_O2A_SystemAdmin cartridge) by doing the following:
Running a manual task that enables order management personnel to confirm that resource or XQuery logic errors have been resolved.
This step can be configured to redeliver the inbound message automatically, by setting the JVM parameter pip.require.ack to NO. The number of automatic redelivery attempts for inbound messages is configured in the model variable named IB_MSG_MAX_RETRY in the Order-to-Activate composite cartridge.
Running an automated task that moves the message from the recovery queue to the response queue.
OSM recognizes the ResumePendingInBoundMessage order, and the OracleComms_OSM_O2A_SystemAdmin cartridge begins to process.
The following steps demonstrate how the Inbound Message Recovery MDB and the OracleComms_OSM_O2A_SystemAdmin cartridge recover from an error scenario where an inbound message is not processed because its associated order is suspended.
OSM sends a message to an external system using an automation task.
Before the automation task receives the inbound response message from the external system, the order associated with the automation task is suspended.
OSM receives the response message from the external system.
The automation task that receives the inbound response message does the following:
Checks the order state while processing the response.
If the order state is Suspended, moves the message to the OSM Inbound Message Recovery Queue (passing required order information such as order ID and FulfillmentFunction name, etc.).
This logic is implemented in the resource AIAEBMResponse.xqy, which is located in OracleComms_OSM_O2A_COM_SalesOrderFulfillmentPIP/resources/ComponentInteraction.
When the order state changes from Suspended to In Progress, the order state change event handler creates the ResumePendingInBoundMessage order (using the OracleComms_OSM_O2A_SystemAdmin cartridge).
The ResumePendingInBoundMessage automation task of the process associated with the ResumePendingInBoundMessage order moves the original response message from the OSM Inbound Message Recovery Queue back to the response queue.
The automation task that could not process the inbound message in the response queue originally (due to its associated order being suspended) processes the inbound message successfully.
The following steps demonstrate how the Inbound Message Recovery MDB and the OracleComms_OSM_O2A_SystemAdmin cartridge recover from an error scenario where an inbound message processing error occurs due to a resource issue such as a Global Transaction Error (GTX) or an incorrect XQuery script.
OSM sends a message to an external system using an automation task and receives a response back from the external system.
The automation task receives the inbound response message in the response queue but cannot process the message because a resource required to process the message is currently locked by another task.
For example, the resource could be locked because of a GTX timeout or because of an error in the logic of an XQuery script.
After a few retries, the automation task raises a fallout.
The fallout message goes to the OSM Integration Pack Fallout Queue.
The Inbound Message Recovery MDB, listening on the OSM Integration Pack Fallout Queue, moves the response message to the OSM Inbound Message Recovery Queue.
The MDB creates the ResumePendingInBoundMessage order (using the OracleComms_OSM_O2A_SystemAdmin cartridge), and its process begins to run.
The order process assigns a manual task (a fallout or confirmation task) to order management personnel who manage fallout.
The fallout task is displayed on the worklist of the Task web client.
OSM does not raise a fallout notification to inform order management personnel that a fallout task has been created on the worklist.
Order management personnel resolve the resource error. For example, they correct the XQuery script logic and restart the system.
In the worklist, order management personnel click the Confirm button on the task and (optionally) specify the name of the response queue of the automation task that could not originally process the inbound message. If the name of the response queue is not specified, the ResumePendingInBoundMessage automated task uses the EBM type to detect which queue is the response queue and routes the message accordingly.
After the confirmation task completes, the process in the OracleComms_OSM_O2A_SystemAdmin cartridge runs the ResumePendingInBoundMessage automation task, which moves the original response message back to the response queue.
The original automation task that could not process the inbound message in the response queue is retried, and the message processes successfully.
The following cartridges operate in the central order management role, which coordinates fulfillment functions across the Business Support Systems (BSS) and Operations Support Systems (OSS) such as Siebel CRM, BRM, and provisioning.
The OracleComms_OSM_O2A_COM_Base cartridge is a productized cartridge supporting the orchestration of customer orders from Oracle AIA. It includes communication to and from fulfillment providers and handles status and data updates.
Order Events
When the COM_SalesOrderFulfillment order reaches one of the order events listed in Table 4-20, it triggers the listed XQuery module to send an order update to the upstream system.
Table 4-20 OracleComms_OSM_O2A_COM_Base Order Events
| Order Event | Description |
stateChange |
Calls the OrderStateChangeHandler XQuery module to send an order update to the Siebel CRM system. |
completion |
Calls the OrderCompletionHandler XQuery module to send the order completion to the Siebel CRM system. |
Processing Granularity Rules
There are four orchestration stages defined in the orchestration sequence to decompose the order line items. The result of each stage of decomposition is the source for the next stage of decomposition.
In the first stage, the order line items are decomposed by fulfillment function.
In the second stage, the order line items are decomposed by fulfillment provider.
In the third stage, the order line items are decomposed by granularity rule.
In the fourth stage, depending on the fulfillment function process, central order management will use the fulfillment function process to determine whether to create an executable order component with all of the order line items if a significant change is detected on any order line item.
Granularity rules provide the configuration for the third stage of decomposition. During orchestration plan generation at run time, the granularity rule takes as input the order line items that have already been grouped by fulfillment function and subdivided by fulfillment provider.
The behavior of granularity rules varies between design time and run time.
For example, during design time, a granularity rule such as ServiceBundleGranularity or BundleGranularity is selected per fulfillment function by creating one decomposition rule per fulfillment function for use in the third stage of decomposition.
During run time, granularity rules group the order line items into one or more fulfillment requests. Granularity rules group the order line items that are targeted at the same fulfillment function and are specific to a fulfillment provider.
Table 4-21 lists the processing granularity rules.
Table 4-21 OracleComms_OSM_O2A_COM_Base Processing Granularity Rules
BundleGranularity |
Order Component Specification |
This granularity rule selects:
OfferGranularity |
OrderGranularity |
This granularity rule selects all lines targeted at the same fulfillment function and specific to a fulfillment provider make a single fulfillment request. |
ServiceBundleGranularity |
This granularity rule implements an optimization to group together offers and non-service billing items into a single fulfillment request to be fulfilled at the same time |
WholeItemGranularity |
Abstract Orchestration Entities
Table 4-22 lists the orchestration entities that are used as base entities for fulfillment function, fulfillment system, process granularity rule, and fulfillment function updates.
Table 4-22 OracleComms_OSM_O2A_COM_Base Abstract Orchestration Entities
| Name | Type | Description |
COM_FulfillmentFunction |
This order component specification represents the base fulfillment function in central order management. All fulfillment functions, such as SyncCustomerFunction, should extend from it. This order component also contains the external fulfillment state definitions. |
COM_FulfillmentGranularity |
This order component specification represents the processing granularity rule used in the orchestration stage. All processing granularity rules should extend from it. |
COM_FulfillmentSystem |
This order component specification represents the base fulfillment system in central order management. All fulfillment systems, such as BRM-VOIP, should extend from it. |
COM_FulfillmentSignificantUpdates |
This order component specification represents the base fulfillment function with significant updates in the fourth orchestration stage. |
Order Lifecycle Manager Configuration
The Order-to-Activate order lifecycle manager is configured with the header values for the Order Lifecycle Management user interface. It also contains mappings between Order-to-Activate central order management fulfillment states and standard order lifecycle manager states.
Table 4-23 displays the mappings that are configured. The high-level fulfillment states are mapped, which causes the child states to be mapped as well.
Table 4-23 Fulfillment State to Order Lifecycle Manager State Mapping
| Fulfillment State | Order Lifecycle Manager State |
CANCELLED |
Canceled |
COMPLETE |
Complete |
FAILED |
Failed |
IN_PROGRESS |
In Progress |
If you have both central order management and service order management in the same Design Studio workspace, you will see service order management fulfillment states in the list in the order lifecycle manager. The names of the high-level fulfillment states for service order management all start with SOM_. The service order management fulfillment states do not need to be mapped here, because they are mapped in the order lifecycle manager in the service order management configuration. See "Order Lifecycle Manager Configuration" for information about service order management state mappings.
XQuery Modules in the OracleComms_OSM_O2A_COM_Base Cartridge
Table 4-24 through Table 4-32 list the different types of XQuery modules in this cartridge.
No table is included for the Order Item Property XQuery modules because none are extendable and each XQuery module does the same thing: retrieves the specified order item property from the appropriate location in the order data.
Table 4-24 OracleComms_OSM_O2A_COM_Base XQuery Modules for Constants
| Constants XQuery Module | Extendable | Description |
O2AConstants |
No |
Defines overall solution constants. |
PromotionGroupConstants |
No |
Defines constants for processing promotion groups in central order management. |
QueryViewConstants |
No |
Defines constants for querying views in central order management. |
Table 4-25 OracleComms_OSM_O2A_COM_Base XQuery Modules for Fallout Handling
| Fallout Handling XQuery Module | Extendable | Description |
AbortOrderRequest |
No |
Sends an order termination request for the fulfillment request through the web service API. |
AbortOrderResponse |
No |
Receives the response to the order termination request for the fulfillment request through the web service API. |
CFwsResponseHandler |
No |
Utility module for providing retrieval and update to central order management order. |
CloseCreationFailedTroubleTickets |
No |
Sends a request to the trouble ticketing system to close the trouble tickets for orders with the same Oracle AIA sales order key. |
CloseTroubleTicket |
No |
Creates a request to the trouble ticketing system to close a trouble ticket. |
CreateSIFalloutTroubleTicket |
No |
Creates a trouble ticket for system interaction. |
CreateTroubleTicket |
No |
Creates a trouble ticket for both system interactions and Order Request Processor (ORP) errors. |
FalloutNotificationRouter |
No |
Routes fallout notifications to different fallout process to handle updating EBM, creating a trouble ticket, and keeping track of the trouble ticket in the OSM order. |
FalloutNotificationToCFTask |
No |
Directs fallout notifications to central order management. |
FindFulfillmentOrderData |
No |
Retrieves the fulfillment request data in fallout. |
FindOrderCreationFailedTroubleTickets |
No |
Finds an order that failed at creation with the Oracle AIA sales order key. |
GetCreationFailFulfillmentOrder |
No |
Retrieves the order data for an order that failed at creation. |
GetFulfillmentOrderResponse |
No |
Utility module to handle the web service response for the find order request. |
GetTroubleTicketData |
No |
Updates trouble ticket data on the OSM order. |
OrderAbortPropagation |
No |
Sends an order termination request to the service order through the Oracle AIA provisioning order queue. |
OrderAbortPropagationCheck |
No |
Checks the status of the order termination request for the service order. |
OrderAbortPropagationResp |
No |
Handles the response of the order termination request to the service order. |
SuspendCFOrder |
No |
Suspends a central order management order. |
SuspendCFOrderResponse |
No |
Utility module to handle the web service response for the suspend order request. |
UpdateCreationFailFulfillmentOrder |
No |
Updates the trouble ticket information back to the OSM order that failed at creation. |
UpdateFulfillmentOrder |
No |
Updates the trouble ticket data on the OSM order. This is used by both UpdateCreationFailFulfillmentOrder and UpdateSIFalloutTroubleTicket XQuery file. |
UpdateSIFalloutTroubleTicket |
No |
Updates the trouble ticket information back to the OSM order that has system interaction fallout. |
UpdateStatusRequest |
No |
Creates an update status EBM to the Siebel CRM system for fallout. |
UpdateTroubleTicket |
No |
Creates the trouble ticket payload for the trouble ticketing system. |
Table 4-26 OracleComms_OSM_O2A_COM_Base Orchestration Sequence XQuery Modules
| Orchestration Sequence XQuery Module | Extendable | Description |
FulfillmentModeExpression |
No |
Marshals the fulfillment mode code from the customer order. |
OrderItemSelector |
No |
Selects all order line items from the customer order. |
Table 4-27 OracleComms_OSM_O2A_COM_Base Order Data Change XQuery Modules
| Order Data Change XQuery Module | Extendable | Description |
CloseFalloutTroubleTicket |
No |
Creates a request to close a trouble ticket. |
CreateFalloutOrderNotification |
No |
Creates a fallout order notification to handle fallout for an order that failed at creation. |
UpdateSalesOrderFalloutStatusRequest |
No |
Creates an EBM with order status context being populated with fallout information. |
Table 4-28 OracleComms_OSM_O2A_COM_Base Order Item Hierarchy XQuery Modules
| Order Item XQuery Module | Extendable | Description |
InterOrderDependency |
No |
Determines the inter-order dependency based on the order item's dependencies across different orders. |
LineIdKey |
No |
Retrieves the order line item's ID. |
ParentLineIdKey |
No |
Retrieves the parent order line item's ID. |
PromotionGroupKey |
No |
Retrieves the order line item's promotion group. |
PromotionGroupParentKey |
No |
Retrieves the parent order line item's promotion group. |
RelatedSalesOrderLineIdKey |
No |
Retrieves the related sales order line item's ID. |
RootParentSalesOrderLineIdKey |
No |
Retrieves the root order item business component ID. |
Table 4-29 OracleComms_OSM_O2A_COM_Base Order Recognition XQuery Modules
| Order Recognition XQuery Module | Extendable | Description |
AIAOrderData |
No |
Transforms the customer order to an OSM order. |
AIAOrderPriority |
No |
Retrieves the priority of the customer order. |
AIAOrderRecognition |
No |
Recognizes the customer order. |
AIAOrderReference |
No |
Adds the -TSQ suffix to order identification if the order is to be processed in Technical Service Qualification mode. (This allows the same customer order to be sent later as a DELIVER order with the same order ID.) |
AIAOrderValidation |
No |
Validates the customer order. |
Table 4-30 OracleComms_OSM_O2A_COM_Base Order State XQuery Modules
| Order State XQuery Module | Extendable | Description |
OrderAbortedStateHandler |
No |
Creates an EBM to update the Siebel CRM order with an aborted status context. |
OrderCancelledStateHandler |
No |
Creates an EBM to update the Siebel CRM order with a canceled status context. |
OrderCompletedStateHandler |
No |
Creates an EBM to update the Siebel CRM order with a completed status context. |
OrderCompletionHandler |
No |
Responds to the central order management order completion event and triggers the OrderCompletedStateHandler module. |
OrderFailedStateHandler |
No |
Creates an EBM to update the Siebel CRM order with a failed status context. |
OrderInProgressStateHandler |
No |
Creates an EBM to update the Siebel CRM order with an in-progress status context. |
OrderStateChangeHandler |
No |
Responds to the central order management order state change event and triggers the appropriate OrderStateHandler according to the order state. |
OrderStateUtilityModule |
No |
Provides utility functions related to order state. |
Table 4-31 OracleComms_OSM_O2A_COM_Base Order Transformation Manager XQuery Modules
| Order Transformation Manager XQuery Module | Extendable | Description |
OTMMappingModule |
No |
Utilities to support the order transformation manager. |
Table 4-32 OracleComms_OSM_O2A_COM_Base Processing Granularity XQuery Modules
| Processing Granularity XQuery Module | Extendable | Description |
BundleGranularity |
No |
Groups related order items as a bundle for processing. |
GranularityModule |
No |
Utility module to group order items based on service action code. |
OfferBundleGranularity |
No |
Groups related order items as an offer for processing. |
OrderGranularity |
No |
Groups related order items as an order for processing. |
No |
Groups related order items as a service for processing. |
No |
Groups related order items as a whole item for processing. |
Automation Modules in the OracleComms_OSM_O2A_COM_Base Cartridge
Table 4-33 lists the automation modules in the cartridge with their associated automated tasks.
Table 4-33 OracleComms_OSM_O2A_COM_Base Automation Modules
AbortOrderRequestBean |
AbortFulfillmentOrderTask |
Calls the AbortOrderRequest XQuery. |
CloseOrderCreationFailedTroubleTicketsBean |
CloseCreationFailedTroubleTicketTask |
External event receiver to invoke CloseCreationFailedTroubleTicket XQuery. |
FindOrderCreationFailedTroubleTicketsBean |
Calls the FindOrderCreationFailedTroubleTickets XQuery. |
CreateSIFalloutTroubleTicketRequestBean |
CreateSIFalloutTroubleTicketTask |
Calls the CreateSIFalloutTroubleTicket XQuery. |
GetSIFalloutTroubleTicketResponse |
External event receiver to invoke GetTroubleTicketData XQuery. |
FalloutnotificationRouterBean |
FalloutNotificationRouterTask |
Calls the FalloutNotificationRouter XQuery. |
SIFalloutNotificationToCF |
Internal event receiver to invoke FalloutNotificationToCFTask XQuery. |
GetCreationFailFulfillmentOrderBean |
GetCreationFailFulfillmentOrderTask |
Internal event receiver to invoke GetCreationFailFulfillmentOrder XQuery. |
GetFulfillmentOrder |
GetFulfillmentOrderTask |
Calls the FindFulfillmentOrderData XQuery. |
External event receiver to invoke CFwsResponseHandler XQuery. |
OrderAbortPropagationCheckPlugin |
Calls the OrderAbortPropagationCheck XQuery. |
OrderAbortPropagationPlugin |
OrderAbortPropagationTask |
Calls the OrderAbortPropagation XQuery. |
OrderAbortPropagationRespPlugin |
External event receiver to invoke OrderAbortPropagationResp XQuery. |
SuspendCFOrderPlugin |
SetCFOrderAbortInProgressTask |
Calls the SuspendCFOrder XQuery. |
SuspendCFOrderRespPlugin |
UpdateCreationFailFulfillmentOrderBean |
UpdateCreationFailFulfillmentOrderTask |
Calls the UpdateCreationFailFulfillmentOrder XQuery. |
UpdateFulfillmentOrderBean |
UpdateFulfillmentOrderTask |
Calls the UpdateFulfillmentOrder XQuery. |
UpdateSIFalloutTroubleTicketRequest |
UpdateSIFalloutTroubleTicketTask |
Calls the UpdateSIFalloutTroubleTicket XQuery. |
UpdateStatusRequestBean |
UpdateStatusToCRMTask |
Calls the UpdateStatusRequest XQuery. |
External Fulfillment States
External fulfillment states in the OracleComms_OSM_O2A_COM_Base cartridge are defined in the COM_FulfillmentFunction order component specification, representing the base fulfillment function. All fulfillment functions, such as SyncCustomerFunction, extend from COM_FulfillmentFunction.
The following external fulfillment states are defined in this cartridge:
OPEN
IN_PROGRESS
IN_PROGRESS-FULFILL_BILLING_START
IN_PROGRESS-INITIATE_BILLING_START
IN_PROGRESS-INSTALL_START
IN_PROGRESS-INSTALL_PLANNED
IN_PROGRESS-INSTALL_COMMITTED
IN_PROGRESS-PROVISION_START
IN_PROGRESS-PROVISION_DESIGNED
IN_PROGRESS-SHIP_ORDER_START
IN_PROGRESS-SHIP_ORDER_PLANNED
IN_PROGRESS-SYNC_CUSTOMER_START
COMPLETE
COMPLETE-FULFILL_BILLING_COMPLETE
COMPLETE-INITIATE_BILLING_COMPLETE
COMPLETE-INSTALL_COMPLETE
COMPLETE-PROVISION_COMPLETE
COMPLETE-SHIP_ORDER_SHIPPED
COMPLETE-SYNC_CUSTOMER_COMPLETE
CANCELLED
CANCELLED-FULFILL_BILLING_COMPLETE
CANCELLED-FULFILL_BILLING_START
CANCELLED-INITIATE_BILLING_COMPLETE
CANCELLED-INITIATE_BILLING_START
CANCELLED-INSTALL_COMMITTED
CANCELLED-INSTALL_COMPLETE
CANCELLED-INSTALL_PLANNED
CANCELLED-INSTALL_START
CANCELLED-PROVISION_COMPLETE
CANCELLED-PROVISION_DESIGNED
CANCELLED-PROVISION_START
CANCELLED-SHIP_ORDER_PLANNED
CANCELLED-SHIP_ORDER_SHIPPED
CANCELLED-SHIP_ORDER_START
CANCELLED-SYNC_CUSTOMER_COMPLETE
CANCELLED-SYNC_CUSTOMER_START
FAILED
FAILED-FULFILL_BILLING_COMPLETE
FAILED-FULFILL_BILLING_START
FAILED-INITIATE_BILLING_COMPLETE
FAILED-INITIATE_BILLING_START
FAILED-INSTALL_COMMITTED
FAILED-INSTALL_COMPLETE
FAILED-INSTALL_PLANNED
FAILED-INSTALL_START
FAILED-PROVISION_COMPLETE
FAILED-PROVISION_DESIGNED
FAILED-PROVISION_START
FAILED-SHIP_ORDER_PLANNED
FAILED-SHIP_ORDER_SHIPPED
FAILED-SHIP_ORDER_START
FAILED-SYNC_CUSTOMER_COMPLETE
FAILED-SYNC_CUSTOMER_START
TSQ_Passed
TSQ_Passed-PROVISION_DESIGNED
TSQ_Failed
TSQ_Failed-PROVISION_DESIGNED
The OracleComms_OSM_O2A_COM_SalesOrderFulfillment cartridge is a productized cartridge supporting the communications between central order management and fulfillment systems. It includes resources to generate requests to fulfillment providers and consume their responses and to do validation and condition evaluation.
Table 4-34 lists the XQuery modules defined in this cartridge.
Table 4-34 OracleComms_OSM_O2A_COM_SalesOrderFulfillment XQuery Modules
AIAEBMRequest_do |
No |
Generates Oracle AIA EBM requests to a fulfillment provider. |
AIAEBMRequest_redo |
No |
Generates Oracle AIA EBM requests to a fulfillment provider for redo. |
AIAEBMRequest_undo |
No |
Generates Oracle AIA EBM requests to a fulfillment provider for undo. |
AIAEBMResponse_ValidationModule |
No |
Validates Oracle AIA EBM responses from a fulfillment provider. |
AIAEBMResponse |
No |
Consumes Oracle AIA EBM responses from a fulfillment provider. |
DoublePlayComponentDependency |
No |
Order component dependency rule used to create the orchestration plan. |
FalseRevision |
No |
Utility module to detect a false revision order. |
InitiateWaitForProvisioningResponse |
No |
Initiates the wait for a provisioning response. |
OrderLifecycleManagementModule |
No |
Utility module to support order lifecycle management for order and order line items. |
PostSIBreakpoint |
No |
Supports breakpoints for the automated task FunctionPostSIBreakTask during undo. |
PreSIBreakpoint |
No |
Supports breakpoints for the automated task FunctionPreSIBreakTask during undo. |
SIEntryPoint |
No |
Provides lifecycle management for both customer order and service order. Used by automated task FunctionEntryPointTask. (This task should be used as the entry point task for a new fulfillment function.) |
SIExitPoint |
No |
Module used by automated task FunctionExitPointTask to simulate order item data updates for the InstallOrder and ShipOrder fulfillment functions. |
SIMilestone_doredo |
No |
Simulates milestone updates for the automated task FunctionPlannedTask for both InstallOrder and ShipOrder fulfillment function. |
SIStartPoint |
No |
Module used by automated task FulfillBillingStartTask to provide a breakpoint before the start of the FulfillBilling function. |
UpdateSalesOrderStatusFunctions |
No |
Provides functions for updating customer order's status. |
FulfillmentStateModule |
No |
Contains configuration for calculating order and order item fulfillment state. |
PointOfNoReturn |
No |
Checks whether an order component or order item has reached the point of no return. |
OracleComms_OSM_O2A_COM_Billing
The OracleComms_OSM_O2A_COM_Billing cartridge is a productized cartridge that supports billing fulfillment functions. These functions specify subprocesses to handle delivery of a relevant subset of order data to the BRM ABCS, and handle responses from BRM ABCS. The modeled interaction includes coping with fallout, order change management, and status or data updates back to the CRM ABCS.
Table 4-35 lists the fulfillment functions defined in the cartridge.
Table 4-35 OracleComms_OSM_O2A_COM_Billing Fulfillment Functions
| Fulfillment Function | Billing Pattern | Description |
SyncCustomerFunction |
Single-phase, two-phase |
Provides the ability to synchronize only accounts from CRM to Billing as part of an order. SyncCustomerFunction is used in both single-phase and two-phase billing patterns. This function is essential because the pre-existence of a customer account in the billing provider is assumed before billing. |
InitiateBillingFunction |
Two-phase |
Provides the ability to start the usage cycle. InitiateBillingFunction is the first phase in the two-phase billing pattern. In two-phase billing patterns, the first phase invokes InitiateBillingFunction, and the second phase invokes FulfillBillingFunction. |
FulfillBillingFunction |
Provides the ability to start the billing cycle. FulfillBillingFunction is the single phase in the single-phase billing pattern and the second phase in the two-phase billing pattern. |
Table 4-36 lists the XQuery modules in the cartridge that support component interaction.
Table 4-36 OracleComms_OSM_O2A_COM_Billing Component Interaction XQuery Modules
| Component Interaction XQuery Module | Extendable | Description |
BillingPatternModule |
No |
Determines the billing pattern based on order item's billing product type and product specification. |
BillingInteractionModule |
No |
Creates a fulfillment request (in the format of an Oracle AIA EBM) to send to the billing system. |
SyncCustomerInteractionModule |
No |
Provides functions to support SyncCustomerFunction. |
InitiateBillingInteractionModule |
No |
Provides functions to support InitiateBillingFunction, using the BillingInteractionModule utility module. |
FulfillBillingInteractionModule |
No |
Provides functions to support FulfillBillingFunction, using the BillingInteractionModule utility module. |
This section provides details of SyncCustomerFunction, one of the three fulfillment functions in the OracleComms_OSM_O2A_COM_Billing.
SyncCustomerFunction and Decomposition Rules
For the fulfillment request to be relevant for the billing provider to process, there must be at least one order line item with a service action that is relevant for the SyncCustomerFunction function to process. The decomposition rules in Table 4-37 ensure that SyncCustomerFunction is called only if relevant.
Table 4-37 Decomposition Rules for SyncCustomerFunction
| Configuration | Cartridge | Decomposition Rule |
Solution option without calculate service order, Simple Topology |
OracleComms_OSM_O2A_SimpleTopology_Sample |
Simple_DetermineSignificantUpdates_For_SyncCustomer |
Solution option without calculate service order, Typical or Complex Topology |
OracleComms_OSM_O2A_TypicalTopology_Sample |
Typical_DetermineSignificantUpdates_For_SyncCustomer |
Calculate service order solution option, all topologies |
OracleComms_OSM_O2A_COM_CSO_Topology |
The decomposition conditions in the rules above return true() if fromOrderComponent (the order component being decomposed from) has at least one order line item that is relevant for SyncCustomerFunction to process. An order line item property is initialized to YES if the order line item is relevant for the billing provider's SyncCustomerFunction to process. By default, the service actions that are relevant for SyncCustomerFunction to process are:
Order line items with ServiceActionCode=ADD
SyncCustomer compensation-significant updates: Order line items with ServiceActionCode=UPDATE or MOVE-ADD with compensation-significant updates as determined by a comparison of the new and prior values from Siebel CRM in the customer order
SyncCustomerFunction and Fulfillment Patterns
The SyncCustomerFunction order component for fulfillment mode DELIVER is selected for each fulfillment pattern that supports the single and two-phase billing patterns. The order component SyncCustomerFunction is included in the BaseProductSpec fulfillment pattern. As a result, all fulfillment patterns which inherit from BaseProductSpec include SyncCustomerFunction as part of their fulfillment flow. This applies to each entity in the cartridge that configures fulfillment patterns, including any custom cartridge specifying the COM_SalesOrderFulfillment namespace.
SyncCustomerFunction XQuery Modules
Table 4-38 lists the XQuery modules defined for the SyncCustomerFunction fulfillment function. Customers can provide their own implementation of the XQuery modules in this fulfillment function indicated extension points. See "Extending XQuery Modules" for more information about XQuery extension points.
Table 4-38 SyncCustomerFunction XQuery Modules
| XQuery Module | XQuery Extension Point | Description |
SyncCustomerComplete_Event |
COMPONENT-COMPLETE |
Invoked when the SyncCustomerFunction component is completed. |
SyncCustomerCreateAllOrderItemsEBM_Event |
CREATE-EBM-ALL-ORDERITEMS |
Invoked after CREATE-EBM-CUSTOM for the SyncCustomerFunction component to create all order items. This should always be invoked unless you want to create only the order header without any order items. |
SyncCustomerCreateCustomEBM_Event |
CREATE-EBM-CUSTOM |
Invoked after CREATE-EBM for the SyncCustomerFunction component. Invokes extension logic on the order-level CUSTOM element. |
SyncCustomerCreateEBM_DoEvent |
CREATE-EBM (execution mode: do) |
Invoked when the EBM is created in the do execution mode for the SyncCustomerFunction component. |
SyncCustomerCreateEBM_ReDoEvent |
CREATE-EBM (execution mode: redo) |
Invoked when the EBM is created in the redo execution mode for the SyncCustomerFunction component. |
SyncCustomerCreateEBM_UnDoEvent |
CREATE-EBM (execution mode: undo) |
Invoked when the EBM is created in the undo execution mode for the SyncCustomerFunction component. |
SyncCustomerCreateOrderItemCustomEBM_Event |
CREATE-EBM-ORDERITEM-CUSTOM |
Invoked after CREATE-EBM-ORDERITEM for the SyncCustomerFunction component. Invokes extension logic on the order-item-level CUSTOM element. |
SyncCustomerCreateOrderItemEBM_DoEvent |
CREATE-EBM-ORDERITEM (execution mode: do) |
Invoked after CREATE-EBM-ALL-ORDERITEMS for the SyncCustomerFunction component in do execution mode. Invokes extension logic on the order item element. |
SyncCustomerCreateOrderItemEBM_ReDoEvent |
CREATE-EBM-ORDERITEM (execution mode: redo) |
Invoked after CREATE-EBM-ALL-ORDERITEMS for the SyncCustomerFunction component in redo execution mode. Invokes extension logic on the order item element. |
SyncCustomerCreateOrderItemEBM_UnDoEvent |
CREATE-EBM-ORDERITEM (execution mode: undo) |
Invoked after CREATE-EBM-ALL-ORDERITEMS for the SyncCustomerFunction component in undo execution mode. Invokes extension logic on the order item element. |
SyncCustomerCreatePriorOrderItemCustomEBM_Event |
CREATE-EBM-PRIORORDERITEM-CUSTOM |
Invoked after CREATE-EBM-PRIORORDERITEM for the SyncCustomerFunction component. Invokes extension logic on the prior-order-item-level CUSTOM element. |
SyncCustomerCreatePriorOrderItemEBM_Event |
CREATE-EBM-PRIORORDERITEM |
Invoked after CREATE-EBM-ORDERITEM-CUSTOM for the SyncCustomerFunction component. Invokes extension logic on the prior order item element. |
SyncCustomerStart_Event |
COMPONENT-START |
Invoked when the SyncCustomerFunction component is started. |
SyncCustomerUpdate_Event |
COMPONENT-RESPONSE-UPDATE |
Invoked when the SyncCustomerFunction updates are received to process order items on the billing response. |
SyncCustomerValidateResponseEBM_Event |
VALIDATE-RESPONSE-EBM |
Invoked to validate the EBM response for the SyncCustomerFunction component. |
SyncCustomerFunction Automation Modules
Table 4-39 lists the automation modules (with their associated automated tasks) defined in the OracleComms_OSM_O2A_COM_Billing cartridge for the SyncCustomerFunction fulfillment function.
Table 4-39 SyncCustomerFunction Automation Modules
SyncCustomerEntryPointBean_doredo |
SyncCustomerEntryPointTask |
Calls the SIEntryPoint XQuery. |
SyncCustomerRequestBean_do |
SyncCustomerSITask |
Calls the AIAEBMRequest_do XQuery. |
SyncCustomerRequestBean_redo |
Calls the AIAEBMRequest_redo XQuery. |
SyncCustomerRequestBean_undo |
Calls the AIAEBMRequest_undo XQuery. |
SyncCustomerResponseBean |
External event receiver to invoke AIAEBMResponse XQuery. |
This section provides details of InitiateBillingFunction, one of the three fulfillment functions in the OracleComms_OSM_O2A_COM_Billing.
InitiateBillingFunction and Decomposition Rules
For the fulfillment request to be relevant for the billing provider to process, there must be at least one order line item with a service action that is relevant for the InitiateBillingFunction function to process. The decomposition rules in Table 4-40 ensure that InitiateBillingFunction is called only if relevant.
Table 4-40 Decomposition Rules for InitiateBillingFunction
| Topology | Cartridge | Decomposition Rule |
Simple_DetermineSignificantUpdates_For_InitiateBilling |
Typical_DetermineSignificantUpdates_For_InitiateBilling |
The decomposition conditions in the rules above return true() if fromOrderComponent (the order component being decomposed from) has at least one order line item that is relevant for InitiateBillingFunction to process. By default, the service actions that are relevant for InitiateBillingFunction to process are:
InitiateBillingFunction and Fulfillment Patterns
The InitiateBillingFunction order component for fulfillment mode DELIVER is selected for each fulfillment pattern that supports the two-phase billing pattern. This includes the OracleComms_OSM_O2A_BBVoIPFulfillmentPatternNileFlow_Sample, OracleComms_OSM_O2A_BBVoIPFulfillmentPatternDanubeFlow_Sample, or any custom cartridge specifying the COM_SalesOrderFulfillment namespace.
Some of the sample fulfillment patterns included in the InitiateBillingFunction in the fulfillment flow are:
Service.VoIP
Service.CPE.VoIP (The IntiateBillingFunction order component is conditional based on whether the VoIP CPE is contained in a VoIP service. This condition is included in decomposition rules InitiateBillingFunction_To_YourSystemInstanceName1… InitiateBillingFunction_To_YourSystemInstanceNameN)
NonService.Offer (The IntiateBillingFunction order component is conditional based on whether the Offer contains VoIP services. This condition is included in decomposition rules InitiateBillingFunction_To_YourSystemInstanceName1… InitiateBillingFunction_To_YourSystemInstanceNameN)
NonService.BillingInitiatedItem
Non.Service.BillingItem
InitiateBillingFunction XQuery Modules
Table 4-41 lists the XQuery modules defined for the InitiateBillingFunction fulfillment function. Customers can provide their own implementation of the XQuery modules in this fulfillment function indicated extension points. See "Extending XQuery Modules" for more information about XQuery extension points.
Table 4-41 InitiateBillingFunction XQuery Modules
InitiateBillingComplete_Event |
Invoked when the InitiateBillingFunction component is completed. |
InitiateBillingCreateAllOrderItemsEBM_Event |
Invoked after CREATE-EBM-CUSTOM for the InitiateBillingFunction component to create all order items. This should always be invoked unless you want to create only the order header without any order items. |
InitiateBillingCreateCustomEBM_Event |
CREATE-EBM-CUSTOM |
Invoked after CREATE-EBM for the InitiateBillingFunction component. Invokes extension logic on the order-level CUSTOM element. |
InitiateBillingCreateEBM_DoEvent |
Invoked when the EBM is created in the do execution mode for the InitiateBillingFunction component. |
InitiateBillingCreateEBM_ReDoEvent |
Invoked when the EBM is created in the redo execution mode for the InitiateBillingFunction component. |
InitiateBillingCreateEBM_UnDoEvent |
Invoked when the EBM is created in the undo execution mode for the InitiateBillingFunction component. |
InitiateBillingCreateOrderItemCustomEBM_Event |
Invoked after CREATE-EBM-ORDERITEM for the InitiateBillingFunction component. Invokes extension logic on the order-item-level CUSTOM element. |
InitiateBillingCreateOrderItemEBM_DoEvent |
Invoked after CREATE-EBM-ALL-ORDERITEMS for the InitiateBillingFunction component in do execution mode. Invokes extension logic on the order item element. |
InitiateBillingCreateOrderItemEBM_ReDoEvent |
Invoked after CREATE-EBM-ALL-ORDERITEMS for the InitiateBillingFunction component in redo execution mode. Invokes extension logic on the order item element. |
InitiateBillingCreateOrderItemEBM_UnDoEvent |
Invoked after CREATE-EBM-ALL-ORDERITEMS for the InitiateBillingFunction component in undo execution mode. Invokes extension logic on the order item element. |
InitiateBillingCreatePriorOrderItemCustomEBM_Event |
Invoked after CREATE-EBM-PRIORORDERITEM for the InitiateBillingFunction component. Invokes extension logic on the prior-order-item-level CUSTOM element. |
InitiateBillingCreatePriorOrderItemEBM_Event |
Invoked after CREATE-EBM-ORDERITEM-CUSTOM for the InitiateBillingFunction component. Invokes extension logic on the prior order item element. |
InitiateBillingStart_Event |
COMPONENT-START |
Invoked when the InitiateBillingFunction component is started. |
InitiateBillingUpdate_Event |
Invoked when the InitiateBillingFunction updates are received to process order items on the billing response. |
InitiateBillingValidateResponseEBM_Event |
Invoked to validate the EBM response for the InitiateBillingFunction component. |
InitiateBillingFunction Automation Modules
Table 4-42 lists the automation modules (with their associated automated tasks) defined in the OracleComms_OSM_O2A_COM_Billing cartridge for the InitiateBillingFunction fulfillment function.
Table 4-42 InitiateBillingFunction Automation Modules
InitiateBillingEntryPointBean_doredo |
InitiateBillingEntryPointTask |
InitiateBillingRequestBean_do |
InitiateBillingSITask |
InitiateBillingRequestBean_redo |
InitiateBillingRequestBean_undo |
InitiateBillingResponseBean |
This section provides details of FulfillBillingFunction, one of the three fulfillment functions in the OracleComms_OSM_O2A_COM_Billing.
FulfillBillingFunction and Decomposition Rules
For the fulfillment request to be relevant for the billing provider to process, there must be at least one order line item with a service action that is relevant for the FulfillBillingFunction function to process. The decomposition rules in Table 4-43 ensure that FulfillBillingFunction is called only if relevant.
Table 4-43 Decomposition Rules for FulfillBillingFunction
Simple_DetermineSignificantUpdates_For_FulfillBilling |
Typical_DetermineSignificantUpdates_For_FulfillBilling |
The decomposition conditions in the rules above return true() if fromOrderComponent (the order component being decomposed from) has at least one order line item that is relevant for FulfillBillingFunction to process. By default, the service actions that are relevant for FulfillBillingFunction to process are:
Order line items with ServiceActionCode=ADD, DELETE, UPDATE, SUSPEND, RESUME, MOVE-ADD, or MOVE-DELETE
FulfillBillingFunction and Fulfillment Patterns
The order component FulfillBillingFunction is included in the orchestration plan for the BaseProductSpec fulfillment pattern. This ensures that FulfillBillingFunction is included in the fulfillment flow for all fulfillment pattern entities that extend from BaseProductSpec. This includes any cartridge specifying the COM_SalesOrderFulfillment namespace.
All sample fulfillment patterns include FulfillBillingFunction.
Sample fulfillment patterns that include FulfillBillingFunction in a single-phase billing pattern (without InitiateBillingFunction) in the fulfillment flow are:
Service.Broadband
Service.CPE.Broadband
NonService.BillingItem
FulfillBillingFunction XQuery Modules
Table 4-44 lists the XQuery modules defined for the FulfillBillingFunction fulfillment function. Customers can provide their own implementation of the XQuery modules in this fulfillment function indicated extension points. See "Extending XQuery Modules" for more information about XQuery extension points.
Table 4-44 FulfillBillingFunction XQuery Modules
FulfillBillingComplete_Event |
Invoked when the FulfillBillingFunction component is completed. |
FulfillBillingCreateAllOrderItemsEBM_Event |
Invoked after CREATE-EBM-CUSTOM for the FulfillBillingFunction component to create all order items. This should always be invoked unless you want to create only the order header without any order items. |
FulfillBillingCreateCustomEBM_Event |
CREATE-EBM-CUSTOM |
Invoked after CREATE-EBM for the FulfillBillingFunction component. Invokes extension logic on the order-level CUSTOM element. |
FulfillBillingCreateEBM_DoEvent |
Invoked when the EBM is created in the do execution mode for the FulfillBillingFunction component. |
FulfillBillingCreateEBM_ReDoEvent |
Invoked when the EBM is created in the redo execution mode for the FulfillBillingFunction component. |
FulfillBillingCreateEBM_UnDoEvent |
Invoked when the EBM is created in the undo execution mode for the FulfillBillingFunction component. |
FulfillBillingCreateOrderItemCustomEBM_Event |
Invoked after CREATE-EBM-ORDERITEM for the FulfillBillingFunction component. Invokes extension logic on the order-item-level CUSTOM element. |
FulfillBillingCreateOrderItemEBM_DoEvent |
Invoked after CREATE-EBM-ALL-ORDERITEMS for the FulfillBillingFunction component in do execution mode. Invokes extension logic on the order item element. |
FulfillBillingCreateOrderItemEBM_ReDoEvent |
Invoked after CREATE-EBM-ALL-ORDERITEMS for the FulfillBillingFunction component in redo execution mode. Invokes extension logic on the order item element. |
FulfillBillingCreateOrderItemEBM_UnDoEvent |
Invoked after CREATE-EBM-ALL-ORDERITEMS for the FulfillBillingFunction component in undo execution mode. Invokes extension logic on the order item element. |
FulfillBillingCreatePriorOrderItemCustomEBM_Event |
Invoked after CREATE-EBM-PRIORORDERITEM for the FulfillBillingFunction component. Invokes extension logic on the prior-order-item-level CUSTOM element. |
FulfillBillingCreatePriorOrderItemEBM_Event |
Invoked after CREATE-EBM-ORDERITEM-CUSTOM for the FulfillBillingFunction component. Invokes extension logic on the prior order item element. |
FulfillBillingStart_Event |
COMPONENT-START |
Invoked when the FulfillBillingFunction component is started. |
FulfillBillingUpdate_Event |
Invoked when the FulfillBillingFunction updates are received to process order items on the billing response. |
FulfillBillingValidateResponseEBM_Event |
Invoked to validate the EBM response for the FulfillBillingFunction component. |
FulfillBillingFunction Automation Modules
Table 4-45 lists the automation modules (with their associated automated tasks) defined in the OracleComms_OSM_O2A_COM_Billing cartridge for the FulfillBillingFunction fulfillment function.
Table 4-45 FulfillBillingFunction Automation Modules
FulfillBillingEntryPointBean_doredo |
FulfillBillingEntryPointTask |
FulfillBillingRequestBean_do |
FulfillBillingSITask |
FulfillBillingRequestBean_redo |
FulfillBillingRequestBean_undo |
FulfillBillingResponseBean |
FulfillBillingStart |
FulfillBillingStartTask |
Calls the SIStartPoint XQuery. |
Billing Dates for Billing Patterns
Billing dates are set when usage events start being rated (usage start date time), when cycle charges start being billed (cycle start date time), and when one time purchase charges should be billed (purchase start time). This section discusses how billing dates are generated.
Default Billing Dates for Two-Phase Billing Patterns
In a two-phase billing pattern, the billing dates are calculated based on data from the customer order and the determination of whether the LATENCY or VALIDATION pattern is used.
The billing dates are reset between the two billing phases (InitiateBillingFunction and FulfillBillingFunction).Billing dates are only set for order line items having the ServiceActionCode of ADD. The following order item properties are updated with the billing dates:
For phase 1, order item properties in ControlData/Functions/IntiateBillingFunction/orderItem/orderItemRef/WorkLineItemData/SalesOrderSchedule
ServiceUsageStartDate
PurchaseDate
CycleStartDate
The three elements above have a data type of DateTime. However the names of the data elements as defined in the Oracle AIA EBM do not end with DateTime but Date only. O2A is following the names defined in the Oracle AIA EBM.
For phase 2, the order item properties from phase 1 are copied into properties with the same names in ControlData/Functions/FulfillBillingFunction/orderItem/orderItemRef/WorkPriorLineItemData/SalesOrderSchedule and all three Date fields are re-calculated as indicated in the Default Billing Dates for Phase 2 column in Table 4-46.
Table 4-46 lists the default date calculations applicable to two-phase billing patterns.
Table 4-46 Two-Phase Billing Pattern Date Calculations
| Billing Pattern | Default Billing Dates for Phase 1 | Default Billing Dates for Phase 2 |
LATENCY |
ServiceUsageStartDate= OrderingBaseDateTime PurchaseDate = OrderingBaseDateTime CycleStartDate = OrderingBaseDateTime + 1 year |
CycleStartDate = SalesOrderLine/CycleStartDate if populated; otherwise compute as Actual Delivery Date Time or Requested Delivery Date Time, whichever is later. |
VALIDATION |
ServiceUsageStartDate= OrderingBaseDateTime + 1 year PurchaseDate=OrderingBaseDateTime + 1 year CycleStartDate = OrderingBaseDateTime + 1 year |
ServiceUsageStartDate = SalesOrderLine/ ServiceUsageStartDate if populated; otherwise Actual Delivery Date Time PurchaseDate = SalesOrderLine/PurchaseDate if populated; otherwise Actual Delivery Date Time CycleStartDate = SalesOrderLine/ CycleStartDate if populated; otherwise Actual Delivery Date Time or Requested Delivery Date Time, whichever is later. |
Default Billing Dates for Single-Phase Billing Patterns
In a single-phase billing pattern, the billing dates are calculated based on data from the customer order.
Order item properties in ControlData/Functions/IntiateBillingFunction/orderItem/orderItemRef/WorkLineItemData/SalesOrderSchedule
ServiceUsageStartDate: This is set to SalesOrderLine/ ServiceUsageStartDate if populated; otherwise ActualDeliveryDateTime
PurchaseDate: This is set to SalesOrderLine/PurchaseDate if populated; otherwise ActualDeliveryDateTime
CycleStartDateTime: This is set to SalesOrderLine/CycleStartDateTime if populated; otherwise Actual Delivery Date Time or Requested Delivery Date Time, whichever is later.
OracleComms_OSM_O2A_COM_Provisioning
The OracleComms_OSM_O2A_COM_Provisioning cartridge is a productized cartridge that supports the provisioning fulfillment functions. These functions specify a subprocess to handle delivery of a relevant subset of order data to the provisioning ABCS and to handle responses from the provisioning ABCS.
Table 4-47 lists the XQuery modules in the cartridge that support component interaction.
Table 4-47 OracleComms_OSM_O2A_COM_Provisioning Component Interaction XQuery Modules
ProvisionOrderInteractionModule |
No |
Provides functions to support ProvisionOrderFunction when the calculate service order solution option is not being used. |
ProvisionOrderInteractionModule_base |
No |
Provides base functions to support ProvisionOrderFunction when the calculate service order solution option is being used. |
ProvisionOrderInteractionModule_do |
No |
Provides functions to support ProvisionOrderFunction for the do execution mode when the calculate service order solution option is being used. |
ProvisionOrderInteractionModule_events |
No |
Provides event-related functions to support ProvisionOrderFunction when the calculate service order solution option is being used. |
ProvisionOrderInteractionModule_redo |
No |
Provides functions to support ProvisionOrderFunction for the redo execution mode when the calculate service order solution option is being used. |
ProvisionOrderInteractionModule_undo |
No |
Provides functions to support ProvisionOrderFunction for the undo execution mode when the calculate service order solution option is being used. |
Table 4-48 lists the XQuery modules defined for the ProvisionOrderFunction fulfillment function. Customers can provide their own implementation of the XQuery modules in this fulfillment function indicated extension points. See "Extending XQuery Modules" for more information about XQuery extension points.
Table 4-48 ProvisionOrderFunction XQuery Modules
ProvisionOrderComplete_Event |
Invoked when the ProvisionOrderFunction component is completed. |
ProvisionOrderCreateEBM_DoEvent |
Invoked when the EBM is created in the do execution mode for the ProvisionOrderFunction component. |
ProvisionOrderCreateEBM_ReDoEvent |
Invoked when the EBM is created in the redo execution mode for the ProvisionOrderFunction component. |
ProvisionOrderCreateEBM_UnDoEvent |
Invoked when the EBM is created in the undo execution mode for the ProvisionOrderFunction component. |
ProvisionOrderStart_Event |
COMPONENT-START |
Invoked when the ProvisionOrderFunction component is started. |
ProvisionOrderValidateResponseEBM_Event |
Invoked to validate the EBM response for the ProvisionOrderFunction component. |
ProvisionOrderUpdate_Event |
Invoked when the EBM response for ProvisionOrderFunction component is updated. |
Table 4-49 lists the automation modules (with their associated automated tasks) defined in the OracleComms_OSM_O2A_COM_Provisioning cartridge for the ProvisionOrderFunction fulfillment function.
Table 4-49 ProvisionOrderFunction Automation Modules
ProvisionOrderEntryPointBean_doredo |
ProvisionOrderSIEntryPointTask |
ProvisionOrderRequestBean_do |
ProvisionOrderSITask |
ProvisionOrderRequestBean_redo |
ProvisionOrderRequestBean_undo |
ProvisionOrderResponseBean |
OracleComms_OSM_O2A_COM_Shipping_Sample
The OracleComms_OSM_O2A_COM_Shipping_Sample cartridge is a demonstration cartridge that supports the shipping fulfillment functions. These functions specify subprocesses to handle delivery of a relevant subset of order data to supply chain management.
Table 4-50 lists he XQuery modules in the cartridge that support component interaction.
Table 4-50 OracleComms_OSM_O2A_COM_Shipping_Sample Component Interaction XQuery Modules
ShipOrderInteractionModule |
Yes |
Provides functions to support ShipOrderFunction. |
Table 4-51 lists the XQuery modules defined for the ShipOrderFunction fulfillment function. Customers can provide their own implementation of the XQuery modules in this fulfillment function indicated extension points. See "Extending XQuery Modules" for more information about XQuery extension points.
Table 4-51 ShipOrderFunction XQuery Modules
ShipOrderComplete_Event |
Invoked when the ShipOrderFunction component is completed. |
ShipOrderStart_Event |
COMPONENT-START |
Invoked when the ShipOrderFunction component is started. |
Table 4-52 lists the automation modules (with their associated automated tasks) defined in the OracleComms_OSM_O2A_COM_Shipping_Sample cartridge for the ShipOrderFunction fulfillment function.
Table 4-52 ShipOrderFunction Automation Modules
ShipOrderEntryPointBean |
ShipOrderEntryPointTask |
ShipOrderPlannedBean |
ShipOrderPlannedTask |
Calls the SIMilestone_doredo XQuery to return the SHIP ORDER PLANNED milestone. |
ShipOrderExitPointBean |
ShipOrderExitPointTask |
Calls the SIExitPoint XQuery. |
OracleComms_OSM_O2A_COM_Install_Sample
The OracleComms_OSM_O2A_COM_Install_Sample cartridge is a demonstration cartridge that supports the installation fulfillment functions for High-Speed Internet. These functions specify subprocesses to handle delivery of a relevant subset of order data to supply chain management.
Table 4-53 lists he XQuery modules in the cartridge that support component interaction.
Table 4-53 OracleComms_OSM_O2A_COM_Install_Sample Component Interaction XQuery Modules
InstallOrderInteractionModule |
Yes |
Provides functions to support InstallOrderFunction. |
Table 4-54 lists the XQuery modules defined for the InstallOrderFunction fulfillment function. Customers can provide their own implementation of the XQuery modules in this fulfillment function indicated extension points. See "Extending XQuery Modules" for more information about XQuery extension points.
Table 4-54 InstallOrderFunction XQuery Modules
InstallOrderComplete_Event |
Invoked when the InstallOrderFunction component is completed. |
InstallOrderStart_Event |
COMPONENT-START |
Invoked when the InstallOrderFunction component is started. |
Table 4-55 lists the automation modules (with their associated automated tasks) defined in the OracleComms_OSM_O2A_COM_Install_Sample cartridge for the InstallOrderFunction fulfillment function.
Table 4-55 InstallOrderFunction Automation Modules
InstallOrderEntryPointBean |
InstallOrderEntryPointTask |
InstallOrderPlannedBean |
InstallOrderPlannedTask |
Calls the SIMilestone_doredo XQuery to return the INSTALL PLANNED milestone. |
InstallOrderCommittedBean |
InstallOrderCommittedTask |
Calls the SIMilestone_doredo XQuery to return the INSTALL COMMITTED milestone. |
InstallOrderExitPointBean |
InstallOrderExitPointTask |
OracleComms_OSM_O2A_COM_Recognition_Sample
The OracleComms_OSM_O2A_COM_Recognition_Sample cartridge is a demonstration cartridge that recognizes a customer order from Oracle AIA and triggers the creation of a COM_SalesOrderFulfillment order. In addition, this cartridge recognizes order fallout notifications, trouble ticket requests, and inbound message errors due to suspended orders or resource issues. It also catches all unrecognizable messages.
Table 4-56 lists the order recognition rules defined in this cartridge.
Table 4-56 OracleComms_OSM_O2A_COM_Recognition_Sample Order Recognition Rules
| Order Recognition Rule | Description |
COM_CloseTroubleTicketWorkOrder_Recognition |
Recognizes a request to close an order as a result of a trouble ticket. |
COM_FaultNotificationOrder_Recognition |
Recognizes order fallout notifications from Oracle AIA. |
COM_ORPFallout_CTT_OrderRecognitionRule |
Recognizes an ORP fallout and triggers creation of a fulfillment request for a trouble ticketing system. |
COM_ResumePendingIbMsg_OrderRecognitionRule |
Recognizes an inbound message and triggers creation of a ResumePendingInBoundMessage order. |
COM_SalesOrderFulfillment_Recognition |
Recognizes an Oracle AIA customer order and triggers the creation of a COM_SalesOrderFulfillment order. |
Revision Number Update for Canceled Orders
When AIA receives an order that has a mode of CANCEL, or when an order is received in which all of the order line items have an action code of NONE, AIA does not update the revision number. Because OSM will ignore a revision order if its revision number is the same as on a previously received order revision, the OTA recognition cartridges update the revision number on orders of this type to 999999999. This ensures that the cancelation is processed.
Central Order Management Cartridges for the Calculate Service Order Solution Option
The following cartridges operate in the central order management role, which coordinates fulfillment functions across the Business Support Systems (BSS) and Operations Support Systems (OSS) such as Siebel CRM, BRM, and provisioning. These cartridges are used in the calculate service order solution option.
OracleComms_OSM_O2A_COM_CSO_Base
The OracleComms_OSM_O2A_COM_CSO_Base cartridge is a productized cartridge. It contains entities that support the orchestration of orders for the calculate service order solution option. It includes the following entities:
Order Item Specification: COM_TransformedServiceLine: This order item specification defines the order item information for transformed order items.
Data Schema: OracleComms_OSM_O2A_COM_CSO_Data: This data schema contains elements relating to transformed order items.
Orchestration Process: COM_SalesOrderFulfillmentOrchestrationProcess: This orchestration process invokes the order transformation manager.
Transformation Sequence: COM_OTM_Sequence: This orchestration sequence has four stages. For more information, see the discussion of transformation sequences in OSM Concepts.
OracleComms_OSM_O2A_COM_CSO_Broadband_Internet_Access_CFS
The OracleComms_OSM_O2A_COM_CSO_Broadband_Internet_Access_CFS cartridge is a demonstration cartridge that contains the mapping rules and order item parameter bindings associated with the customer facing service for broadband internet access. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_COM_CSO_Email_CFS
The OracleComms_OSM_O2A_COM_CSO_Email_CFS cartridge is a demonstration cartridge that contains the mapping rules and order item parameter bindings associated with the customer facing service for email service. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_COM_CSO_FulfillmentPattern
The OracleComms_OSM_O2A_COM_CSO_FulfillmentPattern cartridge is a productized cartridge that contains fulfillment patterns and orchestration dependencies for the calculate service order solution option.
OracleComms_OSM_O2A_COM_CSO_FulfillmentStateMap
The OracleComms_OSM_O2A_COM_CSO_FulfillmentStateMap cartridge is a productized cartridge. It fulfillment state maps and transformed order item fulfillment state composition rule sets specific to the calculate service order solution option.
OracleComms_OSM_O2A_COM_CSO_Internet_Media_CFS
The OracleComms_OSM_O2A_COM_CSO_Internet_Media_CFS cartridge is a demonstration cartridge that contains the mapping rules and order item parameter bindings associated with the customer facing service for Internet media service. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_COM_CSO_IP_Fax_CFS
The OracleComms_OSM_O2A_COM_CSO_IP_Fax_CFS cartridge is a demonstration cartridge that contains the mapping rules and order item parameter bindings associated with the customer facing service for IP fax service. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_COM_CSO_Model_Container
The OracleComms_OSM_O2A_COM_CSO_Model_Container cartridge is a demonstration cartridge. It defines the common model projects that contain elements that might need to be included in the deployment and contains the transformation manager for the calculate service order solution option.
To see the common model projects that are contained by this cartridge, open the Properties tab of the cartridge editor. For more information about the common model projects included with the Order-to-Activate cartridges, see "Conceptual Model Projects."
OracleComms_OSM_O2A_COM_CSO_Provisioning
The OracleComms_OSM_O2A_COM_CSO_Provisioning cartridge is a demonstration cartridge. It contains order components for provisioning that are specific to the calculate service order solution option.
External fulfillment states in the OracleComms_OSM_O2A_COM_CSO_Provisioning cartridge are defined in the ProvisioningOrderFunction order component specification for use withy the calculate service order solution option.
IN_PROGRESS-BROADBANDINTERNETDOMAIN_PROVISION_DESIGNED
IN_PROGRESS-BROADBANDINTERNETDOMAIN_PROVISION_ISSUED
IN_PROGRESS-VOIPDOMAIN_PROVISION_DESIGNED
IN_PROGRESS-VOIPDOMAIN_PROVISION_ISSUED
FAILED-VOIPDOMAIN_PROVISION_FAILED
FAILED-BROADBANDINTERNETDOMAIN_PROVISION_FAILED
IN_PROGRESS-BROADBANDINTERNETDOMAIN_PROVISION_START
IN_PROGRESS-VOIPDOMAIN_PROVISION_START
CANCELLED-VOIPDOMAIN_PROVISION_DESIGNED
CANCELLED-VOIPDOMAIN_PROVISION_START
CANCELLED-VOIPDOMAIN_PROVISION_ISSUED
CANCELLED-BROADBANDINTERNETDOMAIN_PROVISION_DESIGNED
CANCELLED-BROADBANDINTERNETDOMAIN_PROVISION_START
CANCELLED-BROADBANDINTERNETDOMAIN_PROVISION_ISSUED
COMPLETE-VOIPDOMAIN_PROVISION_COMPLETE
COMPLETE-BROADBANDINTERNETDOMAIN_PROVISION_COMPLETE
FAILED-BROADBANDINTERNETDOMAIN_PROVISION_AUXILIARY_FAILED
FAILED-VOIPDOMAIN_PROVISION_AUXILIARY_FAILED
IN_PROGRESS-INTERNETMEDIADOMAIN_PROVISION_START
IN_PROGRESS-INTERNETMEDIADOMAIN_PROVISION_DESIGNED
IN_PROGRESS-INTERNETMEDIADOMAIN_PROVISION_ISSUED
IN_PROGRESS-EMAILDOMAIN_PROVISION_START
IN_PROGRESS-EMAILDOMAIN_PROVISION_DESIGNED
IN_PROGRESS-EMAILDOMAIN_PROVISION_ISSUED
CANCELLED-EMAILDOMAIN_PROVISION_DESIGNED
CANCELLED-EMAILDOMAIN_PROVISION_START
CANCELLED-EMAILDOMAIN_PROVISION_ISSUED
CANCELLED-INTERNETMEDIADOMAIN_PROVISION_DESIGNED
CANCELLED-INTERNETMEDIADOMAIN_PROVISION_START
CANCELLED-INTERNETMEDIADOMAIN_PROVISION_ISSUED
COMPLETE-EMAILDOMAIN_PROVISION_COMPLETE
COMPLETE-INTERNETMEDIADOMAIN_PROVISION_COMPLETE
FAILED-EMAILDOMAIN_PROVISION_FAILED
FAILED-EMAILDOMAIN_PROVISION_AUXILIARY_FAILED
FAILED-INTERNETMEDIADOMAIN_PROVISION_FAILED
FAILED-INTERNETMEDIADOMAIN_PROVISION_AUXILIARY_FAILED
OracleComms_OSM_O2A_COM_CSO_SalesOrders
The OracleComms_OSM_O2A_COM_CSO_SalesOrders cartridge is a demonstration cartridge that contains sample customer orders for use with the calculate service order solution option. These orders are in the same format as orders that are received in an integrated environment with Oracle AIA, Siebel CRM, and CRM ABCS. In a standalone OSM environment, you can submit them to central order management to generate and execute an orchestration plan. In a standalone OSM environment, EBMs are placed on OSM JMS queues for pickup by Oracle AIA.
Each customer order that you send must contain a unique EBM ID. For example, the EBM ID of a cancel order request (revision order) cannot be the same as the EBM ID of the original base order (new order).
Table 4-57 describes the order numbers for new and change orders:
Table 4-57 OracleComms_OSM_O2A_COM_CSO_SalesOrders Order Descriptions
| Order ID | Order XML File | Description |
testcso-doubleplay-voip-broadband |
testcso-all.xml |
Adds all domain services (Broadband, VoIP, Email and Internet Media) and creates all CFS services lines. |
testcso-bandwidth |
testcso-bandwidth.xml |
Add primary broadband line with auxiliary line that defines upload/download bandwidth. |
testcso-broadband |
testcso-broadband.xml |
Add primary basic broadband line only. |
testcso-cme-voip |
testcso-cme-voip_base.xml |
Add VoIP feature services. |
testcso-cme-voip |
testcso-cme-voip_revision.xml |
Revision to add extra VoIP services |
testcso-doubleplay-voip-delete |
testcso-doubleplay-voip-broadband.xml |
Add Broadband and VoIP services. |
testcso-email |
testcso-email.xml |
Add Email service. |
testcso-firewall |
testcso-firewall.xml |
Add Firewall service. |
TestCSO_InternetMedia_1 |
testcso-internetmedia.xml |
Add Internet Media service. |
TestCSO_IP_FAX |
testcso-ip-fax.xml |
Add IP Fax service. |
testcso-modem |
testcso-modem.xml |
Add Broadband Modem service. |
testcso-modem |
testcso-modem-cancel.xml |
Cancel Broadband Modem service. |
testcso-router |
testcso-router.xml |
Add Broadband Router service. |
testcso-voip-callerid |
testcso-voip-callerid.xml |
Add VoIP Caller ID service via Value Added Services. |
testcso-voip |
testcso-voip.xml |
Add VoIP Services. |
testcso-web-conference |
testcso-web-conference.xml |
Add Web Conference service. |
OracleComms_OSM_O2A_COM_CSO_Solution
The OracleComms_OSM_O2A_COM_CSO_Solution cartridge is a demonstration composite cartridge that references all cartridges required for central order management in the topology you selected when installing the Order-to-Activate cartridges.
To see the component cartridges referenced in this cartridge for your solution, open the Dependencies tab in the composite cartridge editor.
The following table lists the CDT and extension point model variables in the OracleComms_OSM_O2A_COM_CSO_Solution cartridge.
Table 4-58 CDT and Extension Point Model Variables in OracleComms_OSM_O2A_COM_CSO_Solution Cartridge
| Model Variable | Description | Possible Values | Default Value |
| O2A_CDT_ENABLE_FLAG | This variable is used to find out whether the Distributed Template
feature is enabled or not. This is used in the CSO solution. In the CSO
O2A solution, the model variable would be defined at the solution level.
The value should be set to enable or
disable. If not specified, it will assume the
default value disable. For the non-CSO solution, the
model variable is not specified in the solution level. Hence, it will
assume the value is disable.
disable |
| O2A_CSO_ENABLE_FLAG | This variable is used to find out whether the solution is using CSO
or not. In the CSO O2A solution, the model varilable is defined at the
solution level with the value enable. If the model
variable is not defined at the solution level, it will assume the
default value disable. For the NON-CSO solution, the
disable |
| EXTENSION_POINT_OPTIMIZATION_FLAG | This variable is used to find out whether the extension framework is
used or not. By default, for each extension point, there would be a
default implementation in the solution. If the extension framework is
not used, then it will use the default implementation. Otherwise, it
would use the extension framework. If the variable is defined at the
solution level with value disable, then it will use the
default implementation. If the variable is not defined or defined with
value enable, then it will use the extension framework.
In a NON-CSO solution, by default, the variable is not defined at the
solution level. Hence, it assumes the value enable and
uses the extension framework.
enable |
| EXTENSION_POINT_DEFAULT_ON_ERROR | This parameter defines how the extension point framework failure should be handled. It is not used in a NON-CSO solution. |
disable |
The OracleComms_OSM_O2A_COM_CSO_Topology cartridge is a demonstration cartridge containing decomposition rules and order component specifications to decompose billing, provisioning, shipping, and install fulfillment functions into the topology you selected when installing the Order-to-Activate cartridges.
Table 4-59 contains a list of the order component specifications defined in this cartridge.
Table 4-59 OracleComms_OSM_O2A_COM_CSO_Topology Order Component Specifications
| Order Component Specification | Description |
BRM-ALL |
Represents the billing fulfillment system if there is a single billing system. |
BRM-BIZBDB |
Represents the billing fulfillment system for business broadband customers. |
BRM-REZBDB |
Represents the billing fulfillment system for residential broadband customers. |
BRM-VIRTUAL |
Represents the billing fulfillment system for non-service billing functions. |
BRM-VoIP |
Represents the billing fulfillment system for VoIP customers. |
Provisioning-ALL |
Represents the provisioning fulfillment system if there is a single provisioning system. |
Provisioning-Broadband |
Represents the provisioning system for broadband customers. |
Provisioning-VoIP |
Represents the provisioning system for VoIP customers. |
Shipping-ALL |
Represents the shipping fulfillment system if there is a single shipping system. |
Shipping-InHouse |
Represents the shipping system for shipments without partner involvement. |
Shipping-PartnerInc |
Represents the shipping system for shipments with partner involvement. |
WFM-A |
Represents the first workflow management fulfillment system if there is more than one workflow management system. |
WFM-ALL |
Represents the workflow management fulfillment system if there is a single workflow management system. |
WFM-B |
Represents the second workflow management fulfillment system if there is more than one workflow management system. |
OracleComms_OSM_O2A_COM_CSO_VoIP_Access_CFS
The OracleComms_OSM_O2A_COM_CSO_VoIP_Access_CFS cartridge is a demonstration cartridge that contains the mapping rules and order item parameter bindings associated with the customer facing service for VoIP access. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_COM_CSO_Web_Conferencing_CFS
The OracleComms_OSM_O2A_COM_CSO_Web_Conferencing_CFS cartridge is a demonstration cartridge that contains the mapping rules and order item parameter bindings associated with the customer facing service for web conferencing service. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_COM_FulfillmentPattern
The OracleComms_OSM_O2A_COM_FulfillmentPattern cartridge is a productized cartridge. It contains the base fulfillment pattern, BaseProductSpec, from which other fulfillment patterns can inherit.
OracleComms_OSM_O2A_COM_FulfillmentStateMap_Sample
The OracleComms_OSM_O2A_COM_FulfillmentStateMap_Sample cartridge is a productized cartridge that contains fulfillment state entities used by the solution.
This cartridge contains the following common fulfillment state definitions, which are used in composition rules. Listed under each main fulfillment state are its child states.
OPEN
IN_PROGRESS
IN_PROGRESS-PROVISION_ISSUED
COMPLETE
COMPLETE-FULFILL_BILLING_START
COMPLETE-INITIATE_BILLING_START
COMPLETE-INSTALL_START
COMPLETE-PROVISION_DESIGNED
COMPLETE-PROVISION_ISSUED
COMPLETE-PROVISION_START
COMPLETE-SHIP_ORDER_START
COMPLETE-SYNC_CUSTOMER_START
CANCELLED
CANCELLED-PROVISION_ISSUED
FAILED
FAILED-PROVISION_AUXILIARY
FAILED-PROVISION_FAILED
FAILED-PROVISION_ISSUED
OracleComms_OSM_O2A_COMSOM_CSO_Recognition
The OracleComms_OSM_O2A_COMSOM_CSO_Recognition cartridge is a demonstration cartridge that recognizes a customer order from Oracle AIA and triggers the creation of a COM_SalesOrderFulfillment order. In addition, this cartridge recognizes order fallout notifications, trouble ticket requests, and inbound message errors due to suspended orders or resource issues. It also catches all unrecognizable messages.
Table 4-60 lists the order recognition rules defined in this cartridge.
Table 4-60 OracleComms_OSM_O2A_COMSOM_CSO_Recognition Order Recognition Rules
COMSOM_CSO_Recognize_AbortPropagationServiceOrder |
Recognizes a termination request for an order. |
COMSOM_CSO_RecognizeEBM_ProvisioningOrder |
Recognizes and EBM provisioning order. |
OracleComms_OSM_O2A_COMSOM_CSO_Solution
The OracleComms_OSM_O2A_COMSOM_CSO_Solution cartridge is a demonstration composite cartridge that references all cartridges required for central order management and service order management in the topology you selected when installing the Order-to-Activate cartridges.
The following table lists the CDT and extension point model variables in the OracleComms_OSM_O2A_COMSOM_CSO_Solution cartridge.
Table 4-61 CDT and Extension Point Model Variables in OracleComms_OSM_O2A_COMSOM_CSO_Solution Cartridge
disable |
disable |
enable |
disable |
Central Order Management Cartridges for the Solution Option Without Calculate Service Order
The following cartridges operate in the central order management role, which coordinates fulfillment functions across the Business Support Systems (BSS) and Operations Support Systems (OSS) such as Siebel CRM, BRM, and provisioning. These cartridges are used in the solution option without calculate service order.
OracleComms_OSM_O2A_BBVoIP_FP_NP_Danube_Sample
The OracleComms_OSM_O2A_BBVoIP_FP_NP_Danube_Sample cartridge contains fulfillment patterns and orchestration dependencies for the Simple topology.
The following fulfillment patterns are configured in this cartridge:
BaseProductSpec – All other fulfillment patterns extend from this.
NonService.Offer
Service.Broadband
Service.CPE.VoIP
Service.Install
Service.VoIP
OracleComms_OSM_O2A_BBVoIP_FP_NP_Nile_Sample
The OracleComms_OSM_O2A_BBVoIP_FP_NP_Nile_Sample cartridge contains fulfillment patterns and orchestration dependencies for the Typical or Complex topologies.
NonService.Offer
Service.Broadband
Service.CPE.VoIP
Service.Install
Service.VoIP
OracleComms_OSM_O2A_COM_NCSO_Base
The OracleComms_OSM_O2A_COM_NCSO_Base cartridge is a productized cartridge. It contains the orchestration process, COM_SalesOrderFulfillmentOrchestrationProcess, that supports the orchestration of orders for the solution option without calculate service order.
OracleComms_OSM_O2A_COM_NCSO_Provisioning
The OracleComms_OSM_O2A_COM_NCSO_Provisioning cartridge is a demonstration cartridge. It contains an order component for provisioning, ProvisionOrderFunction, that is specific to the service option without calculate service order.
Table 4-62 lists the XQuery modules defined for the ProvisionOrderFunction fulfillment function. Customers can provide their own implementation of the XQuery modules in this fulfillment function indicated extension points. See "Extending XQuery Modules" for more information about XQuery extension points.
Table 4-62 ProvisionOrderFunction XQuery Modules
COMPONENT-START |
Table 4-63 lists the automation modules (with their associated automated tasks) defined in the OracleComms_OSM_O2A_COM_Provisioning cartridge for the ProvisionOrderFunction fulfillment function.
Table 4-63 ProvisionOrderFunction Automation Modules
| Automation Module | Automated Task | Description |
InitiateWaitforProvisioningResponseBean |
ProvisionOrderSIResponseTask |
Calls the InitiateWaitforProvisioningResponse XQuery. |
External event receiver to invoke AIAEBMResponse XQuery for do, redo and amend-do mode. |
OracleComms_OSM_O2A_COM_Simple_NP_Soln
The OracleComms_OSM_O2A_COM_Simple_NP_Soln cartridge is a demonstration composite cartridge that references all cartridges required for central order management in the Simple topology.
OracleComms_OSM_O2A_COM_Typical_NP_Soln
The OracleComms_OSM_O2A_COM_Typical_NP_Soln cartridge is a demonstration composite cartridge that references all cartridges required for central order management in the Typical or Complex topologies.
OracleComms_OSM_O2A_COMSOM_Recognition_Sample
The OracleComms_OSM_O2A_COMSOM_Recognition_Sample cartridge is a demonstration cartridge that is used when central order management and service order management are deployed together in the same OSM instance. It recognizes a customer order from Oracle AIA and triggers the creation of a COM_SalesOrderFulfillment order. In addition, this cartridge recognizes order fallout notifications, trouble ticket requests, and inbound message errors due to suspended orders or resource issues. It also catches all unrecognizable messages.
Table 4-64 lists the order recognition rules defined in this cartridge.
Table 4-64 OracleComms_OSM_O2A_COMSOM_Recognition_Sample Order Recognition Rules
COMSOM_CloseTroubleTicketWorkOrder |
COMSOM_FaultNotificationOrder |
COMSOM_LFAbortOrderPropagationOrder |
COMSOM_ORPFallout_CTT_Order |
COMSOM_ProvisionOrderFulfillment |
Recognizes a service order that must be executed and creates a SOM_ProvisionOrderFulfillment order. |
COMSOM_ResumePendingIbMsg |
COMSOM_SalesOrderFulfillment |
For information about special revision number processing for canceled orders, see "Revision Number Update for Canceled Orders."
OracleComms_OSM_O2A_COMSOM_Simple_NP_Soln
The OracleComms_OSM_O2A_COMSOM_Simple_NP_Soln cartridge is a demonstration composite cartridge that references all cartridges required for central order management and service order management in the Simple topology.
OracleComms_OSM_O2A_COMSOM_Typical_NP_Soln
The OracleComms_OSM_O2A_COMSOM_Typical_NP_Soln cartridge is a demonstration composite cartridge that references all cartridges required for central order management and service order management in the Typical or Complex topology.
OracleComms_OSM_O2A_FulfillmentPatternMap_Sample
The OracleComms_OSM_O2A_FulfillmentPatternMap_Sample cartridge is a demonstration cartridge. It contains the mappings between product specifications and fulfillment patterns, where the product specifications are either imported from customer's Siebel CRM system or manually created. In either case, this cartridge can be extended and can contain custom product specification information.
This cartridge also contains the following common fulfillment state definitions, which are used in composition rules. Listed under each main fulfillment state are its child states.
OPEN
IN_PROGRESS
COMPLETE
CANCELLED
FAILED
OracleComms_OSM_O2A_SalesOrders_NP_Sample
The OracleComms_OSM_O2A_SalesOrders_NP_Sample cartridge is a demonstration cartridge that contains sample customer orders. These orders are in the same format as orders that are received in an integrated environment with Oracle AIA, Siebel CRM, and CRM ABCS. In a standalone OSM environment, you can submit them to central order management to generate and execute an orchestration plan. In a standalone OSM environment, EBMs are placed on OSM JMS queues for pickup by Oracle AIA.
This cartridge contains sample orders in XML files. The names of the XML files use the following conventions:
NSalesOrder: Order to add services
CSalesOrder: Change order, otherwise known as a Move Add Change Delete (MACD) order
FSalesOrder: Follow-on order, used to update an order that has passed the point of no return
R1, R2, R3, R4: revision order for submission after the original base order with the same name
TBO: An order specifying time-based offerings
Cancel: Cancel order
Table 4-65 describes the order numbers for new and change orders:
Table 4-65 OracleComms_OSM_O2A_SalesOrders_NP_Sample Order Descriptions
| Order Number | Description |
Sales Order 10000 |
Double Play First-Time Purchase |
Sales Order 10010 |
Double Play Promotion change orders for broadband |
Sales Order 10020 |
Double Play Promotion change orders for VoIP |
Sales Order 10030 |
Double Play Change Purchased Products |
Sales Order 10040 |
Double Play Update Attributes of a Product |
Sales Order 10050 |
Double Play Suspend Services |
Sales Order 10060 |
Double Play Suspend and Resume on the Same Order |
Sales Order 10070 |
Double Play Move Services to Different Address |
Sales Order 10080 |
Double Play Disconnect Optional Products |
Following is a list of the order XML files included in the cartridge:
NEWPROD_NSalesOrderTBOEBM.xml
NEWPROD_CSalesOrderTBOEBM.xml
NEWPROD_GoldFSalesOrder10000F-1FFEBM.xml
NEWPROD_GoldNSalesOrder10000-V2EBM-Predecessor.xml
NEWPROD_GoldNSalesOrder10000-V2EBM-Successor.xml
NEWPROD_GoldNSalesOrder10000-V2EBM.xml
NEWPROD_GoldNSalesOrder10000F-1EBM.xml
NEWPROD_GoldNSalesOrder10000F-1FO1EBM.xml
NEWPROD_GoldNSalesOrder10000WithAdditionalFulfillmentItemCodeEBM.xml
NEWPROD_GoldNSalesOrder10010-V2EBM.xml
NEWPROD_GoldCSalesOrder10010-V2EBM.xml
NEWPROD_GoldCSalesOrder10020-2-1EBM.xml
NEWPROD_GoldCSalesOrder10020-2-1R1EBM.xml
NEWPROD_GoldCSalesOrder10020-V2EBM.xml
NEWPROD_GoldNSalesOrder10020-2-1EBM.xml
NEWPROD_GoldNSalesOrder10020-V2EBM.xml
NEWPROD_GoldNSalesOrder10030-V2EBM.xml
NEWPROD_GoldNSalesOrder10030_2V1EBM.xml
NEWPROD_GoldCSalesOrder10030-V2EBM.xml
NEWPROD_GoldCSalesOrder10030R1_2V1EBM.xml
NEWPROD_GoldCSalesOrder10030R3_2V1EBM.xml
NEWPROD_GoldCSalesOrder10030R4_2V1EBM.xml
NEWPROD_GoldCSalesOrder10030_2V1EBM.xml
NEWPROD_GoldNSalesOrder10040-V2EBM.xml
NEWPROD_GoldNSalesOrder10040_2V1EBM.xml
NEWPROD_GoldCSalesOrder10040-V2EBM.xml
NEWPROD_GoldR1SalesOrder10040-V2EBM.xml
NEWPROD_GoldCSalesOrder10040R2_2V1EBM.xml
NEWPROD_GoldR3SalesOrder10040-V2EBM.xml
NEWPROD_GoldCSalesOrder10040R4_2V1EBM.xml
NEWPROD_GoldCSalesOrder10040_2V1EBM.xml
NEWPROD_GoldNSalesOrder10050-V2EBM.xml
NEWPROD_GoldCSalesOrder10050-V2EBM.xml
NEWPROD_GoldNSalesOrder10060-V2EBM.xml
NEWPROD_GoldCSalesOrder10060-V2EBM.xml
NEWPROD_GoldNSalesOrder10070-V2EBM.xml
NEWPROD_GoldCSalesOrder10070-V2EBM.xml
NEWPROD_GoldCSalesOrder10070R1-V2EBM.xml
NEWPROD_GoldNSalesOrder10080-V2EBM.xml
NEWPROD_GoldCSalesOrder10080-V2EBM.xml
NEWPROD_GoldR1SalesOrder10080-V2EBM.xml
NEWPROD_GoldR2SalesOrder10080-V2EBM.xml
NEWPROD_NSalesOrderWirelessProductsEBM.xml
NEWPROD_SalesOrder10000CancelEBM.xml
NEWPROD_SalesOrder10000DeliverEBM.xml
The NEWPROD_testfalloutnotification.xml file is a sample order fallout notification but not a sample customer order. This XML file is used to send a particular task to fallout manually by pausing the corresponding queue.
Table 4-66 contains information about the changes included in the specific revision orders above:
Table 4-66 OracleComms_OSM_O2A_SalesOrders_NP_Sample Order Revision Details
GoldCSalesOrder10030R1_2V1EBM |
ADD canceled on revision, DELETE canceled on revision |
GoldCSalesOrder10030R3_2V1EBM |
ADD modified on revision |
GoldCSalesOrder10030R4_2V1EBM |
New ADD on revision |
GoldR1SalesOrder10040-V2EBM |
UPDATE modified on revision |
GoldCSalesOrder10040R2_2V1EBM |
UPDATE canceled on revision |
GoldR3SalesOrder10040-V2EBM |
GoldCSalesOrder10040R4_2V1EBM |
DELETE added on revision |
GoldCSalesOrder10070R1-V2EBM |
MOVE canceled on revision |
GoldR1SalesOrder10080-V2EBM |
DELETE modified on revision (future date) |
GoldR2SalesOrder10080-V2EBM |
UPDATE added on revision |
The OracleComms_OSM_O2A_SimpleTopology_Sample cartridge is a demonstration cartridge containing decomposition rules and order component specifications to decompose billing and provisioning fulfillment functions into the Simple topology: a single billing instance and a single local fulfillment instance.
Table 4-67 contains a list of the order component specifications defined in this cartridge.
Table 4-67 OracleComms_OSM_O2A_SimpleTopology_Sample Order Component Specifications
BRM-ALL |
Represents the billing fulfillment system. |
Provisioning-ALL |
Represents the provisioning fulfillment system. |
The OracleComms_OSM_O2A_TypicalTopology_Sample cartridge is a demonstration cartridge containing decomposition rules and order component specifications to decompose billing, provisioning, shipping, and install fulfillment functions into the Typical topology: multiple billing, local fulfillment, supply chain management, and workforce management instances.
Table 4-68 contains a list of the order component specifications defined in this cartridge.
Table 4-68 OracleComms_OSM_O2A_TypicalTopology_Sample Order Component Specifications
BRM-ALL |
BRM-BIZBDB |
BRM-REZBDB |
BRM-VIRTUAL |
BRM-VoIP |
Provisioning-ALL |
Provisioning-DSL |
Represents the provisioning system for DSL customers outside the UK. |
Provisioning-UKDSL |
Represents the provisioning system for DSL customers inside the UK. |
Provisioning-VOIP |
Shipping-ALL |
Shipping-InHouse |
WFM-A |
WFM-ALL |
WFM-B |
Service Order Management Cartridges for the Calculate Service Order Solution Option
The following cartridges operate in the service order management role, which translates Oracle AIA service orders into OSM service orders and processes those orders. These cartridges are used in the calculate service order solution option.
OracleComms_OSM_O2A_SOM_CSO_Base
The OracleComms_OSM_O2A_SOM_CSO_Base cartridge is a productized cartridge that supports the provisioning of service orders.
Order Events
When the COM_SalesOrderFulfillment order reaches one of the order events listed in Table 4-69, it triggers the listed XQuery module to send an order update to the upstream system.
Table 4-69 OracleComms_OSM_O2A_SOM_CSO_Base Order Events
| Order Event | Description |
creation |
Calls the SOMOrderCreationFailure XQuery module to determine if a failure has occurred. If so, generates a message to central order management through the Oracle AIA error handling framework. |
completion |
Calls the SOMCompletionStatusSender XQuery module to send the order completion to central order management. |
Order Lifecycle Manager Configuration
The Order-to-Activate order lifecycle manager is configured with the header values for the Order Lifecycle Management user interface. It also contains mappings between Order-to-Activate central order management fulfillment states and standard order lifecycle manager states.
Table 4-70 displays the mappings that are configured. The high-level fulfillment states are mapped, which causes the child states to be mapped as well.
Table 4-70 Fulfillment State to Order Lifecycle Manager State Mapping
| Fulfillment State | Order Lifecycle Manager State |
SOM_CANCELLED |
Canceled |
SOM_COMPLETE |
Complete |
SOM_FAILED |
Failed |
SOM_INPROGRESS |
In Progress |
If you have both central order management and service order management in the same Design Studio workspace, you will see service order management fulfillment states in the list in the order lifecycle manager. The names of the high-level fulfillment states for central order management do not start with SOM_. The central order management fulfillment states do not need to be mapped here, because they are mapped in the order lifecycle manager in the central order management configuration. See "Order Lifecycle Manager Configuration" for information about central order management state mappings.
XQuery Modules in the OracleComms_OSM_O2A_SOM_CSO_Base Cartridge
Table 4-71 through Table 4-74 list the different types of XQuery modules in this cartridge.
Table 4-71 OracleComms_OSM_O2A_SOM_CSO_Base XQuery Modules for Fallout Handling
| Fallout Handling XQuery Module | Extendable | Description |
SendAbortLFOrderFailure |
No |
Sends a fulfillment order failure update when the order termination request failed. |
SendAbortLFOrderSuccess |
No |
Sends a fulfillment order success update when the order termination request succeeded. |
SomAbortOrder |
No |
Sends an order termination request for a given fulfillment request. |
SomFindOrder |
No |
Creates a find order request for a fulfillment request with a given order key. |
SomSuspendOrder |
No |
Creates a suspend order request for a fulfillment request with a given order key. |
SomWebServicesResponseHandler |
No |
Utility module for providing retrieval and update to service order. |
Table 4-72 OracleComms_OSM_O2A_SOM_CSO_Base Orchestration Sequence XQuery Modules
| Orchestration Sequence XQuery Module | Extendable | Description |
SOM_FulfillmentModeExpression |
No |
Marshals the fulfillment mode code from the service order. |
SOM_OrderItemSelector |
No |
Module to select all order line items from the service order. |
Table 4-73 OracleComms_OSM_O2A_SOM_CSO_Base Order Recognition XQuery Modules
| Order Recognition XQuery Module | Extendable | Description |
SOM_DataTransform |
No |
Transforms the Oracle AIA service order to an OSM service order. |
SOM_DataValidation |
No |
Validates the Oracle AIA service order. |
Table 4-74 OracleComms_OSM_O2A_SOM_CSO_Base Order State XQuery Modules
| Order State XQuery Module | Extendable | Description |
SOM_Reference |
No |
Accesses the sales order reference. |
Automation Modules in the OracleComms_OSM_O2A_SOM_CSO_Base Cartridge
Table 4-75 lists the automation modules in the cartridge with their associated automated tasks.
Table 4-75 OracleComms_OSM_O2A_SOM_CSO_Base Automation Modules
AbortSomOrderRequest |
AbortSomOrderTask |
Calls the SomAbortOrder XQuery. |
AbortSomOrderResponse |
AbortSomOrderTask |
External event receiver to invoke SomWebServicesResponseHandler XQuery. |
FindSomOrderRequest |
FindSomOrderTask |
Calls the SomFindOrder XQuery. |
FindSomOrderResponse |
FindSomOrderTask |
SendAbortStatusToUpstream |
SendAbortStatusToUpstreamTask |
Calls the SendAbortLFOrderSuccess XQuery |
SuspendSomOrderRequest |
SuspendSomOrderTask |
Calls the SomSuspendOrder XQuery. |
SuspendSomOrderResponse |
External event receiver to invoke SomWebServicesResponseHandler XQuery |
OracleComms_OSM_O2A_SOM_CSO_Broadband_Internet_Access_CFS
The OracleComms_OSM_O2A_SOM_CSO_Broadband_Internet_Access_CFS cartridge is a demonstration cartridge that contains the order item parameter bindings associated with the customer facing service for broadband Internet access. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_SOM_CSO_Common
The OracleComms_OSM_O2A_SOM_CSO_Common cartridge is a productized cartridge that contains data elements and fulfillment modes for service order management with the calculate service order solution option.
The following fulfillment modes are defined in this cartridge:
SOM_CANCEL
SOM_DELIVER
SOM_TSQ
OracleComms_OSM_O2A_SOM_CSO_CompleteProvisioning
The OracleComms_OSM_O2A_COM_CSO_Base cartridge is a demonstration cartridge that supports provisioning fulfillment functions for service order management.
OracleComms_OSM_O2A_SOM_CSO_DeliverOrder
The OracleComms_OSM_O2A_SOM_CSO_DeliverOrder cartridge is a demonstration cartridge that supports order delivery fulfillment functions for service order management.
OracleComms_OSM_O2A_SOM_CSO_DesignService
The OracleComms_OSM_O2A_SOM_CSO_DesignService cartridge is a demonstration cartridge that supports service design fulfillment functions for service order management.
OracleComms_OSM_O2A_SOM_CSO_Email_CFS
The OracleComms_OSM_O2A_SOM_CSO_Email_CFS cartridge is a demonstration cartridge that contains the order item parameter bindings associated with the customer facing service for email service. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_SOM_CSO_FulfillmentPattern
The OracleComms_OSM_O2A_SOM_CSO_FulfillmentPattern cartridge is a productized cartridge that contains service order management fulfillment patterns for the calculate service order solution option.
OracleComms_OSM_O2A_SOM_CSO_FulfillmentStateMap
The OracleComms_OSM_O2A_COM_CSO_Base cartridge is a productized cartridge that contains fulfillment state entities used by the solution.
SOM_PENDING
SOM_INPROGRESS
IN_PROGRESS-BI_CAPTURED
IN_PROGRESS-BI_ISSUED
IN_PROGRESS-BI_PROCESSED
IN_PROGRESS-TO_CREATE
SOM_COMPLETED
COMPLETE-BI_APPROVED
COMPLETE-BI_COMPLETED
COMPLETE-TA_CALCULATED
COMPLETE-TO_COMPLETED
SOM_CANCELLED
CANCELLED-BI_APPROVED
CANCELLED-BI_CAPTURED
CANCELLED-BI_COMPLETED
CANCELLED-BI_ISSUED
CANCELLED-BI_PROCESSED
CANCELLED-TA_CALCULATED
CANCELLED-TO_COMPLETED
CANCELLED-TO_CREATE
SOM_FAILED
FAILED-BI_APPROVED
FAILED-BI_CAPTURED
FAILED-BI_COMPLETED
FAILED-BI_ISSUED
FAILED-BI_PROCESSED
FAILED-SERVICE
FAILED-TO_COMPLETED
FAILED-TO_CREATE
OracleComms_OSM_O2A_SOM_CSO_Internet_Media_CFS
The OracleComms_OSM_O2A_SOM_CSO_Internet_Media_CFS cartridge is a demonstration cartridge that contains the order item parameter bindings associated with the customer facing service for Internet media service. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_SOM_CSO_IP_Fax_CFS
The OracleComms_OSM_O2A_COM_CSO_Base cartridge is a demonstration cartridge that contains the order item parameter bindings associated with the customer facing service for IP fax service. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_SOM_CSO_ModelContainer
The OracleComms_OSM_O2A_SOM_CSO_ModelContainer cartridge defines the common model projects that contain elements that might need to be included in the deployment.
OracleComms_OSM_O2A_SOM_CSO_PlanDelivery
The OracleComms_OSM_O2A_COM_CSO_Base cartridge is a demonstration cartridge that supports delivery planning fulfillment functions for service order management.
OracleComms_OSM_O2A_SOM_CSO_Recognition
The OracleComms_OSM_O2A_SOM_CSO_Recognition cartridge is a demonstration cartridge that recognizes a service order and triggers the creation of a SOM_ProvisionOrderFulfillment order. In addition, this cartridge catches all in-bound messages not recognized by any other provisioning recognition rules.
Table 4-76 lists the order recognition rules defined in this cartridge.
Table 4-76 OracleComms_OSM_O2A_SOM_CSO_Recognition Recognition Rules
SOM_ORPFallout_CFM_OrderRecognitionRule |
Recognizes an ORP fallout to create a fault message to be sent to Oracle AIA error handling queue. |
SOM_ResumePendingIbMsg_OrderRecognitionRule |
Recognizes an inbound message to create a ResumePendingInBoundMessage order in service order management. |
OracleComms_OSM_O2A_SOM_CSO_Solution
The OracleComms_OSM_O2A_SOM_CSO_Solution cartridge is a demonstration composite cartridge that references all cartridges required for service order management.
OracleComms_OSM_O2A_SOM_CSO_Topology
The OracleComms_OSM_O2A_SOM_CSO_Topology cartridge is a demonstration cartridge. This cartridge contains entities, such as decomposition rules and order components, for service order management.
OracleComms_OSM_O2A_SOM_CSO_VoIP_Access_CFS
The OracleComms_OSM_O2A_SOM_CSO_VoIP_Access_CFS cartridge is a demonstration cartridge that contains the order item parameter bindings associated with the customer facing service for VoIP access. It also contains XQuery modules to support the order item parameter bindings.
OracleComms_OSM_O2A_SOM_CSO_Web_Conferencing_CFS
The OracleComms_OSM_O2A_SOM_CSO_Internet_Media_CFS cartridge is a demonstration cartridge that contains the order item parameter bindings associated with the customer facing service for web conferencing service. It also contains XQuery modules to support the order item parameter bindings.
Service Order Management Cartridges for the Solution Option Without Calculate Service Order
The following cartridges operate in the service order management role, which translates Oracle AIA service orders into OSM service orders and processes those orders. These cartridges are used in the solution option without calculate service order.
OracleComms_OSM_O2A_SOM_Base
The OracleComms_OSM_O2A_SOM_Base cartridge is a productized cartridge supporting the orchestration of service orders that have come from Oracle AIA. It includes handling status and data updates from fulfillment requests back to central order management.
Order Events
When the COM_SalesOrderFulfillment order reaches one of the order events listed in Table 4-77, it triggers the listed XQuery module to send an order update to the upstream system.
Table 4-77 OracleComms_OSM_O2A_SOM_Base Order Events
creation |
Calls the LFCheckCreationOrderFailure XQuery to determine if a failure has occurred. If so, generates a message to central order management through the Oracle AIA error handling framework. |
completion |
Calls the ProvisionOrderCompleteEventHandler XQuery module to send the order completion to central order management. |
Processing Granularity Rules
There are three orchestration stages defined in the orchestration sequence to decompose the order line items. The result of each stage of decomposition is the source for the next stage of decomposition.
In the first stage, the order line items are decomposed by fulfillment function.
In the second stage, the order line items are decomposed by fulfillment provider.
In the third stage, the order line items are decomposed by granularity rule.
Granularity rules provide the configuration for the third stage of decomposition. During orchestration plan generation at run time, the granularity rule takes as input the order line items that have already been grouped by fulfillment function and subdivided by fulfillment provider.
Table 4-78 lists the processing granularity rule entities.
Table 4-78 OracleComms_OSM_O2A_SOM_Base Processing Granularity Rules
| Entity Name | Entity Type | Description |
ServiceGranularity |
This granularity rule selects:
XQuery Modules in the OracleComms_OSM_O2A_SOM_Base Cartridge
Table 4-79 through Table 4-85 list the different types of XQuery modules in this cartridge.
No table is included for the Order Item Property XQuery modules because none are extendable and each XQuery module does the same thing: retrieves the specified order item property from the appropriate location in the order data.
Table 4-79 OracleComms_OSM_O2A_SOM_Base XQuery Modules for Constants
| Constants XQuery Module | Extendable | Description |
SomQueryViewConstants |
No |
Defines constants for querying views in service order management. |
Table 4-80 OracleComms_OSM_O2A_SOM_Base XQuery Modules for Fallout Handling
AbortLFOrderRequest |
No |
Sends an order termination request for the fulfillment request through the web service API. |
FindLFOrder |
No |
LFAbortOrderPropagation |
No |
LFAbortOrderPropagationCheck |
No |
Checks the status of the order termination request for fulfillment request. |
LFAbortOrderPropagationResp |
No |
Handles the response of the order termination request for the fulfillment request. |
LFwsResponseHandler |
No |
No |
No |
SuspendLFOrder |
No |
Table 4-81 OracleComms_OSM_O2A_SOM_Base Orchestration Sequence XQuery Modules
No |
OrderItemSelector |
No |
Table 4-82 OracleComms_OSM_O2A_SOM_Base Order Data Change XQuery Modules
| Order Data Change XQuery Module | Extendable | Description |
CreateLFFaultToAIAEH |
No |
Creates an error message to be sent to the Oracle AIA error handling queue. |
Table 4-83 OracleComms_OSM_O2A_SOM_Base Order Item Hierarchy XQuery Modules
| Order Item XQuery Module | Extendable | Description |
LineIdKey |
No |
Retrieves the order line item's ID. |
ParentLineIdKey |
No |
Retrieves the parent order line item's ID. |
Table 4-84 OracleComms_OSM_O2A_SOM_Base Order Recognition XQuery Modules
ProvisionOrderData |
No |
ProvisionOrderPriority |
No |
Retrieves the priority of the Oracle AIA service order. |
ProvisionOrderRecognition |
No |
Recognizes the Oracle AIA service order. |
ProvisionOrderValidation |
No |
Table 4-85 OracleComms_OSM_O2A_SOM_Base Order State XQuery Modules
LFCheckCreationOrderFailure |
No |
Determines if a failure has occurred. If so, generates an error message to central order management through the Oracle AIA error handling framework. |
ProvisionOrderCompleteEventHandler |
No |
Sends service order status update with COMPLETE status code back to central order management. |
Automation Modules in the OracleComms_OSM_O2A_SOM_Base Cartridge
Table 4-86 lists the automation modules in the cartridge with their associated automated tasks.
Table 4-86 OracleComms_OSM_O2A_SOM_Base Automation Modules
AbortLFOrderPlugin |
AbortLFOrderTask |
Calls the AbortLFOrderRequest XQuery. |
AbortLFOrderRespPlugin |
AbortLFOrderTask |
External event receiver to invoke LFwsResponseHandler XQuery. |
FindLFOrderPlugin |
GetLFOrderTask |
Calls the FindLFOrder XQuery. |
GetLFOrderDataPlugin |
GetLFOrderTask |
SendAbortLFOrderFailurePlugin |
LFAbortOrderFailureTask |
Calls the SendAbortLFOrderFailure XQuery. |
SendAbortLFOrderSuccessPlugin |
LFAbortOrderSuccessTask |
Calls the SendAbortLFOrderSuccess XQuery. |
LFOrderAbortPropagationCheckPlugin |
LFOrderAbortPropagationCheck |
Internal event receiver to invoke LFAbortOrderPropagationCheck XQuery. |
LFAbortOrderPropagationPlugin |
LFOrderAbortPropagationTask |
Internal event receiver to invoke LFAbortOrderPropagation XQuery. |
LFAbortOrderPropagationRespPlugin |
External event receiver to invoke LFAbortOrderPropagationResp XQuery. |
SuspendLFOrderPlugin |
SuspendLFOrderTask |
Internal event receiver to invoke SuspendLFOrder XQuery. |
SuspendLFOrderRespPlugin |
Calls the LFwsResponseHandler XQuery. |
OracleComms_OSM_O2A_SOM_Provisioning
The OracleComms_OSM_O2A_SOM_Provisioning cartridge is a productized cartridge that supports provisioning fulfillment functions. These functions specify a subprocess to handle delivery of a relevant subset of order data to the provisioning system and handle responses from the provisioning system.
Table 4-87 lists he XQuery modules in the cartridge that support component interaction.
Table 4-87 OracleComms_OSM_O2A_SOM_Provisioning Component Interaction XQuery Modules
| Component Interaction XQuery Module | Extendable | Description |
SomProvisionOrderInteractionModule |
Yes |
Provides functions to support ProvisionOrderFunction in service order management. |
Table 4-88 lists the XQuery modules defined for the SomProvisionOrderFunction fulfillment function.
Table 4-88 SomProvisionOrderFunction XQuery Modules
CreateProvisioningOrderRequest_do |
No |
Generates the Oracle AIA EBM requests to the external provisioning system. |
CreateProvisioningOrderRequest_redo |
No |
CreateProvisioningOrderRequest_undo |
No |
Generates the Oracle AIA EBM requests to external provisioning system for undo. |
CreateProvisioningOrderResponse |
No |
Consumes the Oracle AIA EBM response from the external provisioning system. |
InitialSomProvisionOrderSIResponse |
No |
Sets the correlation context before consuming Oracle AIA EBM response from the external provisioning system. |
RetryCreateProvisioningOrderResponse |
No |
Handles fallout in service order management's provisioning order by re-creating the response from the external provisioning system. |
SomProvisionOrderSIEntryPoint |
No |
Handles extension point COMPONENT-START, updates order item properties, and reports milestones to lifecycle management for service order management and then to central order management. |
No |
SomProvisionOrderSIResponseFalloutPrepare |
No |
Handles manual retry process to re-submit EBM to the external provisioning system. |
UpdateProvisionOrderStatusFunctions |
No |
Provides functions to create an EBM that contains the fulfillment request's update and send the EBM to central order management. |
Table 4-89 lists the automation modules (with their associated automated tasks) defined in the OracleComms_OSM_O2A_SOM_Provisioning cartridge for the SomProvisionOrderFunction fulfillment function.
Table 4-89 SomProvisionOrderFunction Automation Modules
SomProvisionOrderSIEntryPointBean |
SomProvisionOrderSIEntryPointTask |
Calls the SomProvisionOrderSIEntryPoint XQuery. |
SomProvisionOrderSIResponseFalloutPrepareBean |
SomProvisionOrderSIResponseFalloutPrepareTask |
Calls the SomProvisionOrderSIResponseFalloutPrepare XQuery. |
InitialSomProvisionOrderSIResponseBean |
SomProvisionOrderSIResponseTask |
Calls the InitialSomProvisionOrderSIResponse XQuery. |
External event receiver to invoke SomProvisionOrderSIResponse XQuery. |
RetryCreateProvisioningOrderRequestBean |
SomProvisionOrderSIRetryTask |
Calls the CreateProvisioningOrderRequest_do XQuery. |
RetryCreateProvisioningOrderResponseBean |
External event receiver to invoke RetryCreateProvisoningOrderResponse XQuery. |
CreateProvisiongOrderRequestBean_do |
SomProvisionOrderSITask |
CreateProvisiongOrderRequestBean_redo |
Calls the CreateProvisioningOrderRequest_redo XQuery. |
CreateProvisiongOrderRequestBean_undo |
Calls the CreateProvisioningOrderRequest_undo XQuery. |
External event receiver to invoke CreateProvisoningOrderResponse XQuery. |
SomProvisionOrderSIResponseUndoBean |
OracleComms_OSM_O2A_SOM_Solution
The OracleComms_OSM_O2A_SOM_Solution cartridge is a demonstration composite cartridge that references all cartridges required for service order management.
OracleComms_OSM_O2A_SOM_Recognition_Sample
The OracleComms_OSM_O2A_SOM_Recognition_Sample cartridge is a demonstration cartridge that recognizes a service order and triggers the creation of a SOM_ProvisionOrderFulfillment order. In addition, this cartridge catches all in-bound messages not recognized by any other provisioning recognition rules.
Table 4-90 lists the order recognition rules defined in this cartridge.
Table 4-90 OracleComms_OSM_O2A_SOM_Recognition_Sample Recognition Rules
SOM_LFAbortOrderPropagationOrder_Recognition |
SOM_ProvisionOrderFulfillment_Recognition |
OracleComms_OSM_O2A_SomBBVoIP_FP_NP_Sample
The OracleComms_OSM_O2A_SomBBVoIP_FP_NP_Sample cartridge is a demonstration cartridge containing fulfillment patterns, each of which configures a fulfillment flow for provisioning fulfillment functions. The demonstration VoIP and Broadband products map to the fulfillment patterns.
SOM_Service.Provision – All other fulfillment patterns extend from this.
SOM_Service.Broadband
SOM_Service.CPE.Broadband
SOM_Service.CPE.VoIP
SOM_Service.VoIP
OracleComms_OSM_O2A_SomProvisionBroadband_Sample
The OracleComms_OSM_O2A_SomProvisionBroadband_Sample cartridge is a demonstration cartridge supporting service orders for broadband services.
Table 4-91 to Table 4-93 list the entities in the OracleComms_OSM_O2A_SomProvisionBroadband_Sample cartridge.
Table 4-91 OracleComms_OSM_O2A_SomProvisionBroadband_Sample Entities
| Name | Type | Description |
OSM_O2A_SomProvisionBroadband_Recognition |
Recognizes a broadband service order and creates an OracleComms_OSM_O2A_SomProvisionBroadband_SampleOrder service order to manage its fulfillment. |
OracleComms_OSM_O2A_SomProvisionBroadband_SampleOrder |
Order |
Local service order structure for managing a service order for broadband services. |
BroadbandProvisioningOrderLifeCycle |
Lifecycle Policy |
Defines the security permissions for order transactions. |
BroadbandProvisioningRole |
Role |
Role with permissions to create and view OracleComms_OSM_O2A_SomProvisionBroadband_SampleOrder. |
BroadbandServicesProvisioningProcess |
Process and Tasks |
Process to handle provisioning of broadband services such as email, Internet and customer premise equipment. |
CreateBroadbandServicesProvisioningOrderTask |
Manual Task |
Creation task to create an OracleComms_OSM_O2A_SomProvisionBroadband_SampleOrder. |
OracleComms_OSM_O2A_SomProvisionBroadband_Sample |
Data Schema |
Data structures for managing broadband services. |
Table 4-92 OracleComms_OSM_O2A_SomProvisionBroadband_Sample XQuery Modules
ActivityRouterTask |
Yes |
Transit to the next task with different task exit status depending on broadband provisioning service. |
BroadbandServiceErrorFault |
Yes |
Creates error fault for broadband provisioning service. |
BroadbandServiceOrderCompleteEventHandler |
Yes |
Sends broadband service order status update with COMPLETE status code back to service order management. |
BroadbandServiceProcessEntryUndoBean |
Yes |
Updates the provisioning order and sends broadband service order status. |
BroadbandServiceProvisioningOrderDataRule |
Yes |
BroadbandServiceUtilityModule |
Yes |
Utility module to provide functions to support provisioning broadband service. |
ProvisionTaskComplete |
Yes |
Completes a provisioning task. |
ProvisionTaskStart |
Yes |
Starts a provisioning task. |
Table 4-93 OracleComms_OSM_O2A_SomProvisionBroadband_Sample Automation Modules
ActivityRouterBean |
Calls the ActivityRouterTask XQuery. |
BroadbandServiceErrorFaultBean |
BroadbandServiceErrorFaultTask |
Calls the BroadbandServiceErrorFault XQuery. |
BroadbandServiceErrorFaultBean_redo |
Calls the BroadbandServiceErrorFault XQuery for redo mode. |
BroadbandServiceProcessEntryTask |
Calls the BroadbandServiceProcessEntryUndoBean XQuery. |
BroadbandServiceProcessExitBean |
BroadbandServiceProcessExitTask |
Calls the BroadbandServiceProcessExitBean XQuery. |
ProvisionCPEEntryPointBean |
ProvisionCPEEntryPointTask |
Calls the ProvisionTaskStart XQuery. |
ProvisionCPEExitPointBean |
ProvisionCPEExitPointTask |
Calls the ProvisionTaskComplete XQuery. |
ProvisionInternetEmailServiceBundleEntryPointBean |
ProvisionInternetEmailServiceBundleEntryPointTask |
ProvisionInternetEmailServiceBundleExitPointBean |
ProvisionInternetEmailServiceBundleExitPointTask |
ProvisionInternetMediaServiceBundleEntryPointBean |
ProvisionInternetMediaServiceBundleEntryPointTask |
ProvisionInternetMediaServiceBundleExitPointBean |
ProvisionInternetMediaServiceBundleExitPointTask |
ProvisionInternetServiceBundleEntryPointBean |
ProvisionInternetServiceBundleEntryPointTask |
ProvisionInternetServiceBundleExitPointBean |
ProvisionInternetServiceBundleExitPointTask |
OracleComms_OSM_O2A_SomProvisionVoIP_Sample
The OracleComms_OSM_O2A_SomProvisionVoIP_Sample cartridge is a demonstration cartridge supporting service orders for VoIP services.
Table 4-94 to Table 4-96 list the entities in the OracleComms_OSM_O2A_SomProvisionVoIP_Sample cartridge.
Table 4-94 OracleComms_OSM_O2A_SomProvisionVoIP_Sample Entities
OSM_O2A_SomProvisionVoIP_Recognition |
Recognizes a VoIP service order and creates an OracleComms_OSM_O2A_SomProvisionVoIP_SampleOrder service order to manage its fulfillment. |
OracleComms_OSM_O2A_SomProvisionVoIP_SampleOrder |
Order |
Local service order structure for managing a service order for VoIP services. |
VoIPProvisioningOrderLifeCycle |
Lifecycle Policy |
VoIPProvisioningRole |
Role |
Role with permissions to create and view OracleComms_OSM_O2A_SomProvisionVoIP_SampleOrder. |
VoIPServicesProvisioningProcess |
Process and Tasks |
Process to handle provisioning of VoIP services such as VoIP service and customer premise equipment. |
CreateVoIPServicesProvisioningOrderTask |
Manual Task |
Creation task to create an OracleComms_OSM_O2A_SomProvisionVoIP_SampleOrder. |
OracleComms_OSM_O2A_SomProvisionVoIP_Sample |
Data Schema |
Data structures for managing VoIP services. |
Table 4-95 OracleComms_OSM_O2A_SomProvisionVoIP_Sample XQuery Modules
VoIPActivityRouterTask |
Yes |
Transit to the next task with different task exit status depending on VoIP provisioning service. |
VoIPServiceErrorFault |
Yes |
Creates error fault for VoIP provisioning service. |
VoIPServiceOrderCompleteEventHandler |
Yes |
Sends VoIP service order status update with COMPLETE status code back to service order management. |
VoIPServiceProcessEntryBean |
Yes |
Updates the provisioning order and sends VoIP service order status. |
VoIPServiceProvisioningOrderDataRule |
Yes |
VoIPServiceUtilityModule |
Yes |
Utility module to provide functions to support provisioning VoIP service. |
VoIPProvisionTaskComplete |
Yes |
VoIPProvisionTaskStart |
Yes |
VoIPServiceProcessExitBean |
Yes |
Completes a task using a successful status. |
Table 4-96 OracleComms_OSM_O2A_SomProvisionVoIP_Sample Automation Modules
VoIPActivityRouterBean |
Calls the VoIPActivityRouterTask XQuery. |
VoIPServiceErrorFaultBean |
VoIPServiceErrorFaultTask |
Calls the VoIPServiceErrorFault XQuery. |
VoIPServiceErrorFaultBean_redo |
Calls the VoIPServiceErrorFault XQuery for redo mode. |
VoIPServiceProcessEntryTask |
Calls the VoIPServiceProcessEntryBean XQuery. |
VoIPServiceProcessExitTask |
Calls the VoIPServiceProcessExitBean XQuery. |
ProvisionVoIPCPEEntryPointBean |
ProvisionVoIPCPEEntryPointTask |
Calls the VoIPProvisionTaskStart XQuery. |
ProvisionVoIPCPEExitPointBean |
ProvisionVoIPCPEExitPointTask |
Calls the VoIPProvisionTaskComplete XQuery. |
ProvisionVoIPServiceBundleEntryPointBean |
ProvisionVoIPServiceBundleEntryPointTask |
ProvisionVoIPServiceBundleExitPointBean |
ProvisionVoIPServiceBundleExitPointTask |
Common Conceptual Model Projects
The following cartridges provide entities that are used by or referenced by other Order-to-Activate cartridges.
For more information about the conceptual model, see Design Studio Concepts.
OracleComms_Model_Base
The OracleComms_Model_Base project contains entities that are used for multiple services, including provider functions, functional areas, relationship types, action codes, and units of measure.
OracleComms_Model_BaseCatalog
The OracleComms_Model_BaseCatalog project contains conceptual model fulfillment patterns. It also contains the data schema that defines the data elements from the Oracle AIA EBM schema. Cartridges that must include data elements from Oracle AIA EBM can reuse the elements defined in this cartridge.
OracleComms_Model_Common
The OracleComms_Model_Common project contains common data elements for all of the services.
OracleComms_Model_O2A_Broadband_Internet_Access_CFS
The OracleComms_Model_O2A_Broadband_Internet_Access_CFS project contains the customer facing services for broadband Internet access.
The following customer facing services are defined in this project:
OracleComms_Model_O2A_Broadband_Internet_Access_SA
The OracleComms_Model_O2A_Broadband_Internet_Access_SA project contains the actions for broadband Internet access.
The following action codes are defined in this project for the customer facing service in the OracleComms_Model_O2A_Broadband_Internet_Access_CFS project:
Add
Change
Disconnect
Modify
Move-Add
Move-Delete
Query
Remove
Resume
Suspend
OracleComms_Model_O2A_Broadband_Internet_DataModel
The OracleComms_Model_O2A_Broadband_Internet_DataModel project contains the data schema for data specific to broadband Internet access.
OracleComms_Model_O2A_Email_CFS
The OracleComms_Model_O2A_Email_CFS project contains the customer facing services for email service.
Email_CFS
OracleComms_Model_O2A_Email_DataModel
The OracleComms_Model_O2A_Email_CFS project contains the data schema for data specific to email service.
OracleComms_Model_O2A_Email_SA
The OracleComms_Model_O2A_Email_CFS project contains the actions for email service.
The following action codes are defined in this project for the customer facing service in the OracleComms_Model_O2A_Email_CFS project:
Add
Change
Disconnect
Modify
Move-Add
Move-Delete
Query
Remove
Resume
Suspend
OracleComms_Model_O2A_Internet_Media_CFS
The OracleComms_Model_O2A_Internet_Media_CFS project contains the customer facing services for Internet media service.
InternetMedia_CFS
OracleComms_Model_O2A_Internet_Media_DataModel
The OracleComms_Model_O2A_Internet_Media_DataModel project contains the data schema for data specific to Internet media service.
OracleComms_Model_O2A_Internet_Media_SA
The OracleComms_Model_O2A_Internet_Media_SA project contains the actions for internet media service.
The following action codes are defined in this project for the customer facing service in the OracleComms_Model_O2A_Internet_Media_CFS project:
Add
Change
Disconnect
Modify
Move-Add
Move-Delete
Query
Remove
Resume
Suspend
OracleComms_Model_O2A_VoIP_Access_CFS
The OracleComms_Model_O2A_VoIP_Access_CFS project contains the customer facing services for VoIP access.
IP_Fax_CFS
VoIP_Access_CFS
OracleComms_Model_O2A_VoIP_Access_SA
The OracleComms_Model_O2A_VoIP_Access_CFS project contains the actions for VoIP access.
The following action codes are defined in this project for each of the customer facing services in the OracleComms_Model_O2A_VoIP_Access_CFS project:
Add
Change
Delete
Disconnect
Modify
Move-Add
Move-Delete
None
Query
Remove
Resume
Suspend
Update
Conceptual Model Projects for Central Order Management
The following cartridges provide entities that are used by or referenced by central order management Order-to-Activate cartridges.
OracleComms_Model_O2A_Billing_PS
The OracleComms_Model_O2A_Billing_PS project contains the products for billing services.
The following products are defined in this project:
Broadband_Pricing_Event_PS
Group_Member_PS
Group_Owner_PS
Offer_Sponsorship_PS
Pricing_Event_PS
Promotion_Group_PS
VoIP_Pricing_Event_Billing_Validation_PS
VoIP_Pricing_Event_PS
OracleComms_Model_O2A_Broadband_Internet_Access_PS
The OracleComms_Model_O2A_Broadband_Internet_Access_PS project contains the domains and products for broadband Internet services.
The following domains are defined in this project:
BroadbandInternetDomain
Broadband_Bandwidth_PS
Broadband_Modem_PS
Broadband_Offer_Charge_Class
Broadband_PS
Broadband_Router_PS
Firewall_PS
OracleComms_Model_O2A_Email_PS
The OracleComms_Model_O2A_Email_PS project contains the domains and products for email services.
EmailDomain
Email_Service_PS
OracleComms_Model_O2A_Install_PS
The OracleComms_Model_O2A_Install_PS project contains the products for installation services.
High_Speed_Internet_Installation_PS
OracleComms_Model_O2A_Internet_Media_PS
The OracleComms_Model_O2A_Internet_Media_PS project contains the domains and products for Internet media services.
InternetMediaDomain
Internet_Media_PS
OracleComms_Model_O2A_VoIP_PS
The OracleComms_Model_O2A_VoIP_PS project contains the domains and products for VoIP services.
VoIPDomain
Value_Added_Features_PS
VoIP_Adaptor_PS
VoIP_Fax_Service_PS
VoIP_Offer_Charge_Class
VoIP_Phone_PS
VoIP_PS
VoIP_Soft_Phone_PS
VoIP_Visual_Voicemail_PS
VoIP_Voicemail_PS
Web_Conferencing_PS
Conceptual Model Projects for Service Order Management
The following cartridges provide entities that are used by or referenced by service order management Order-to-Activate cartridges when the service option without calculate service order is used.
OracleComms_Model_O2A_SOM_PS
The OracleComms_Model_O2A_SOM_PS project contains the products for service order management services when the service option without calculate service order is used.
SOM_Broadband_Bandwidth_PS
SOM_Broadband_Modem_PS
SOM_Broadband_PS
SOM_Broadband_Router_PS
SOM_Email_Service_PS
SOM_Firewall_PS
SOM_Internet_Media_PS
SOM_Value_Added_Features_PS
SOM_VoIP_Adaptor_PS
SOM_VoIP_Fax_Service_PS
SOM_VoIP_Phone_PS
SOM_VoIP_PS
SOM_VoIP_Service_Feature_Billing_Validation_PS
SOM_VoIP_Service_Plan_Billing_Validation_PS
SOM_VoIP_Soft_Phone_PS
SOM_VoIP_Visual_Voicemail_PS
SOM_VoIP_Voicemail_PS
SOM_Web_Conferencing_PS
Oracle AIA Emulators
The Oracle AIA emulators are used in development and testing when Oracle AIA is not available.
Table 4-97 lists and describes the emulators contained in the OracleComms_OSM_O2A_Install project.
In the Order to Cash solution, OSM interacts with billing, CRM, and Provisioning systems using Oracle AIA. It does not directly interact with Siebel CRM, BRM, and provisioning systems.
Table 4-97 Emulators in OSM
| Name | Description |
osm_AIASyncCustomerEmulator |
Emulates Oracle AIA billing service (for example, BRM ABCS by generating response messages in EBM format for requests targeted at a billing provider to synchronize customer account details. |
osm_AIAInitiateFulfillBillingEmulator |
Emulates Oracle AIA billing service by generating response messages in EBM format for requests targeted at a billing provider to initiate or fulfill billing. |
osm_AIAFalloutNotificationToOrderEmulator |
Emulates Oracle AIA error handling by generating order fallout notification messages for faults targeted at Oracle AIA error handling. These are error faults generated by the external systems (such as Provisioning). Error faults are sent to Oracle AIA which then translate them into fallout notifications and sent to OSM central order management. |
osm_AIATroubleTicketEmulator |
Emulates an Oracle AIA trouble ticket Siebel CRM service by generating response messages in EBM format for requests targeted at Siebel CRM to create trouble tickets. Note that no trouble ticket response is generated for Update Trouble ticket EBMs but only for Create Trouble ticket EBMs. |
osm_CF2LFProvisionOrderCreateEmulator |
Emulates an OSM service (for example, OSM ABCS) for service order creation by wrapping EBM format messages in OSM format for requests targeted at OSM service order management fulfillment to process service orders. |
osm_LF2CFProvisionOrderUpdateEmulator |
Emulates an OSM service (for example, OSM ABCS) for order update by wrapping EBM format messages in OSM format for messages targeted at OSM central order management fulfillment to update service orders. |
osm_AIAProvisionOrderEmulator |
Emulates Oracle AIA Provisioning service (for example, order management) fulfillment by generating response messages in EBM format for requests targeted at OSM service order management fulfillment to process service orders. |
osm_InventoryOrderEmulator |
Emulates UIM by setting simulated enriched data from inventory such as Service ID and MAC Address. |
osm_TomOrderEmulator |
Emulates a technical order management system by returning a successful status to requests. |
